LinuxBoxer Posted August 1, 2023 Posted August 1, 2023 (edited) Looking for Linux for this X96 TVBox variant, model PROB3000 2GB DDRIII + 16 GB eMMC https://www.google.com/search?q=PROSB-3000%2F16 Tag on board: BA301 v1.3 XR819 NJ 2+16 CPU: Allwinner h313 (H616 datasheet covers H313, just higher clock and 4GB RAM support: https://linux-sunxi.org/images/3/30/H616_Datasheet_V1.0.pdf ) MCP> LPDDR3 SDRAM + eMMC chip: Samsung KMR8X000IM-B608 ( https://file2.dzsc.com/product/20/05/07/1115580_113217385.pdf ) WLAN chip: XR819 ( https://linux-sunxi.org/images/8/8f/XR819_Datasheet_V1.0-EN.pdf ) Edited August 1, 2023 by LinuxBoxer 0 Quote
LinuxBoxer Posted August 3, 2023 Author Posted August 3, 2023 Looks like a kind of X96Q variant. PMU: AXP313A 1 Quote
javaxsousa Posted August 23, 2023 Posted August 23, 2023 my tv box uses the same chip,Ik316=h313, but when I use the h616 image it gives the following error U-Boot SPL 2021.04 (May 25 2023 - 13:06:08 +0200) DRAM:This DRAM setup is currently not supported. Attached I send the boot log and the images of my tvbox bootik316.txt 0 Quote
SteeMan Posted August 23, 2023 Posted August 23, 2023 31 minutes ago, javaxsousa said: when I use the h616 image What exact image are you using? 0 Quote
javaxsousa Posted August 23, 2023 Posted August 23, 2023 i used this image: Armbian_23.5.2_Orangepizero2_bookworm_current_6.1.30 0 Quote
LinuxBoxer Posted September 8, 2023 Author Posted September 8, 2023 On 8/23/2023 at 4:54 PM, javaxsousa said: Attached I send the boot log Lots of fails, that firmware is improper for your hardware, and your hardware is older and not even similar to this one in this post. Better open a separate post and add more photos, I think there are missing chips in your photo. Your PMU is pictured as AXP305 and your log says "Unknown PMU AXP806" ? Very different circuit and chipset. 0 Quote
George Zhavoronkov Posted October 24, 2023 Posted October 24, 2023 Hello! I also have such a console and can’t run the orange Pi zero2, Bigtreetech-cb1 images. Error: U-Boot SPL 2023.10-armbian (Oct 14 2023 - 01:14:07 +0000) DRAM:This DRAM setup is currently not supported. resetting... 0 Quote
LinuxBoxer Posted November 4, 2023 Author Posted November 4, 2023 Your board seems the same, your ram/emmc chip is a Micron model instead of the Samsung eMMC+LPDDR3, not sure about full compatibility between both. 0 Quote
djoness Posted November 29, 2023 Posted November 29, 2023 Hi. First of all, I would like to congratulate you on this forum and the enormous work you do to keep it up to date. I just got an X96Q, it has a CPU: Allwinner H313, I would like to know how to install Armbian on it, thanks in advance. 0 Quote
jvs Posted March 24, 2024 Posted March 24, 2024 Hi, is there a image available for this model (prosb3000)? Or we need build one? 0 Quote
SteeMan Posted March 24, 2024 Posted March 24, 2024 @Juliano Schmitt https://forum.armbian.com/topic/16976-status-of-armbian-on-tv-boxes-please-read-first 0 Quote
DrEaD Posted May 21, 2024 Posted May 21, 2024 Quote Hi, sorry my english Did you got a working system? I can boot MiniArch-20231112-6.7.4-board-h313.x96_q_lpddr3-SD-Image but ethernet won't work and MiniArch-20231112-6.7.4-board-h616.tanix_tx6s_axp313-SD-Image won't boot.. I'm in hope to get Klipper work on this tvbox 0 Quote
DrEaD Posted May 22, 2024 Posted May 22, 2024 I get all working with USB Tethering, after install miniarch WiFi works... 1 Quote
Othmen chargui Posted June 5, 2024 Posted June 5, 2024 How to connect with usb tethering please. And ethernet work after install or only wifi 0 Quote
DrEaD Posted June 6, 2024 Posted June 6, 2024 Quote Connect usb cable into an Android smartphone and select "USB Thetering" in smartphone... But in new release(v20240522) Ethernet was showing working(not tested), and wifi too(tested). I've give up because can't add CAN network module(don't know how), this is necessary to run my project (3d printer with klipper and can toolhead). 0 Quote
Othmen chargui Posted June 6, 2024 Posted June 6, 2024 Thank you friend Usb thetering done Install done After installing endeavouros How to boot to os 0 Quote
DrEaD Posted June 6, 2024 Posted June 6, 2024 You need install lightdm manually, welcome to Arch world, everything need medium/advanced knowledge in linux... 😅 0 Quote
Othmen chargui Posted June 6, 2024 Posted June 6, 2024 Could you help me This is my first time using it Thank you 0 Quote
Othmen chargui Posted June 6, 2024 Posted June 6, 2024 I have a question ❓️ If I found driver ethernet I can Install on miniarch I don't need to install endeavouros 0 Quote
