I try install armhf packets (piaware) from it's repo, what I do:
dpkg --add-architecture armhf
nano /etc/apt/sources.list.d/piaware.list
change it to:
 deb [arch=armhf]  http://flightaware.com/adsb/piaware/files/packages jessie piaware
then
apt-get update
apt-get install piaware
and have this error:
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation:
The following packages have unmet dependencies:
 piaware:armhf : Depends: tcllib:armhf but it is not installable
E: Unable to correct problems, you have held broken packages.
If I try install tcllib:armhf (apt-get install tcllib:armhf) I receve error:
Package 'tcllib:armhf' has no installation candidate
How can I fix this problem?
Thank you for answer, it's good news, but if I typed apt-get install tcllib:arm64 - it's compile without error, maybe have any way for install tcllib like tcllib:armhf? ;)
Please check what you have installed, for what architecture and from what repository
dpkg -l | grep tcllib
apt-cache policy tcllib
and also check dependencies for piaware
apt-cache depends piaware
odroidc2:~# dpkg -l | grep tcllib
ii  tcllib                         1.16-dfsg-2               all          Standard Tcl Library
odroidc2:~# apt-cache policy tcllib
tcllib:
  Installed: 1.16-dfsg-2
  Candidate: 1.16-dfsg-2
  Version table:
 *** 1.16-dfsg-2 0
        500 http://httpredir.debian.org/debian/ jessie/main arm64 Packages
        100 /var/lib/dpkg/status
odroidc2:~# apt-cache depends piaware
piaware:armhf
  Depends: libbz2-1.0:armhf
  Depends: libc6:armhf
  Depends: libexpat1:armhf
  Depends: libtcl8.6:armhf
  Depends: zlib1g:armhf
  Depends: <init-system-helpers:armhf>
    init-system-helpers
  Depends: net-tools:armhf
  Depends: iproute2:armhf
    iproute2
  Depends: tclx8.4:armhf
  Depends: tcl8.6:armhf
    tcl8.6
  Depends: <tcllib:armhf>
  Depends: tcl-tls:armhf
  Depends: itcl3:armhf
  Suggests: dump1090-fa:armhf
  Conflicts: <fa-mlat-client>
  Conflicts: <fa-mlat-client:armhf>
  Replaces: <fa-mlat-client>
  Replaces: <fa-mlat-client:armhf>
