Blue tomato Posted August 4, 2023 Posted August 4, 2023 Hi. By updating the system today caused the hardware acceleration to fail. Start-Date: 2023-08-04 12:26:33 Commandline: apt upgrade Upgrade: armbian-jammy-desktop-gnome:arm64 (23.02.2, 23.08.0-trunk--1-Vf900-B4c8e), system-monitoring-center:arm64 (1.43.9, 1.43.10), ufw:arm64 (0.36.1-4build1, 0.36.1-4ubuntu0.1), libmutter-10-0:arm64 (42.9-0ubuntu1, 42.9-0ubuntu4), libpoppler-cpp0v5:arm64 (22.02.0-2ubuntu0.1, 22.02.0-2ubuntu0.2), mutter-common:arm64 (42.9-0ubuntu1, 42.9-0ubuntu4), poppler-utils:arm64 (22.02.0-2ubuntu0.1, 22.02.0-2ubuntu0.2), libpoppler-glib8:arm64 (22.02.0-2ubuntu0.1, 22.02.0-2ubuntu0.2), gir1.2-mutter-10:arm64 (42.9-0ubuntu1, 42.9-0ubuntu4), libpoppler118:arm64 (22.02.0-2ubuntu0.1, 22.02.0-2ubuntu0.2) End-Date: 2023-08-04 12:26:38 All the best! 0 Quote
NicoD Posted August 4, 2023 Posted August 4, 2023 You mean GPU acceleration? Show the output of "glxinfo -B" And would help if you'd do "armbianmonitor -u" and give the result. The ppa responsible for Panfork on RK3588 is from @amazingfate Might be something broke. I hope not. 0 Quote
Blue tomato Posted August 4, 2023 Author Posted August 4, 2023 Hi NicoD Yes gpu acceleration is gone. Chrome is not working well with youtube. Does anyone else have the same problem? glxinfo -B gives name of display: :0 display: :0 screen: 0 direct rendering: Yes Extended renderer info (GLX_MESA_query_renderer): Vendor: Panfrost (0xffffffff) Device: Mali-G610 (Panfrost) (0xffffffff) Version: 23.0.0 Accelerated: yes Video memory: 7689MB Unified memory: yes Preferred profile: compat (0x2) Max core profile version: 0.0 Max compat profile version: 3.0 Max GLES1 profile version: 1.1 Max GLES[23] profile version: 3.1 OpenGL vendor string: Panfrost OpenGL renderer string: Mali-G610 (Panfrost) OpenGL version string: 3.0 Mesa 23.0.0-devel OpenGL shading language version string: 1.30 OpenGL context flags: (none) OpenGL ES profile version string: OpenGL ES 3.1 Mesa 23.0.0-devel OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.10 armbianmonitor is attached armbianmonitorFetching info... 0 Quote
Behlül BİROL Posted August 7, 2023 Posted August 7, 2023 (edited) hello, i have the same problem, they are below. Thanks in advance for your help bilonemsi:~:% glxinfo -B name of display: :0 display: :0 screen: 0 direct rendering: Yes Extended renderer info (GLX_MESA_query_renderer): Vendor: Panfrost (0xffffffff) Device: Mali-G610 (Panfrost) (0xffffffff) Version: 23.0.0 Accelerated: yes Video memory: 7688MB Unified memory: yes Preferred profile: compat (0x2) Max core profile version: 0.0 Max compat profile version: 3.0 Max GLES1 profile version: 1.1 Max GLES[23] profile version: 3.1 OpenGL vendor string: Panfrost OpenGL renderer string: Mali-G610 (Panfrost) OpenGL version string: 3.0 Mesa 23.0.0-devel OpenGL shading language version string: 1.30 OpenGL context flags: (none) OpenGL ES profile version string: OpenGL ES 3.1 Mesa 23.0.0-devel OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.10 Reveal hidden contents Save New Duplicate & Edit Just Text ### Activated 1 lzo-rle zram swap devices with 3844MB each. ### Activated Armbian ramlog partition with zstd compression Thu Jul 6 08:17:45 PM UTC 2023 | Orange Pi 5 | 23.08.0-trunk | arm64 | aarch64 | 5.10.160-rk35xx ### dmesg: [ 2.575104] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [ 2.575128] Linux version 5.10.160-rk35xx (armbian@next) (aarch64-linux-gnu-gcc (Ubuntu 11.3.0-1ubuntu1~22.04) 11.3.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP Thu Jul 6 13:36:29 UTC 2023 [ 2.585936] Machine model: Orange Pi 5 [ 2.586117] efi: UEFI not found. [ 2.589771] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB [ 2.589791] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@00000000': base 0x0000000000000000, size 0 MiB [ 2.589881] Reserved memory: created CMA memory pool at 0x0000000010000000, size 256 MiB [ 2.589886] OF: reserved mem: initialized node cma, compatible id shared-dma-pool [ 2.740430] Zone ranges: [ 2.740437] DMA [mem 0x0000000000200000-0x00000000ffffffff] [ 2.740449] DMA32 empty [ 2.740455] Normal [mem 0x0000000100000000-0x00000001ffffffff] [ 2.740463] Movable zone start for each node [ 2.740467] Early memory node ranges [ 2.740473] node 0: [mem 0x0000000000200000-0x00000000efffffff] [ 2.740481] node 0: [mem 0x0000000100000000-0x00000001ffffffff] [ 2.740489] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff] [ 2.740495] On node 0 totalpages: 2031104 [ 2.740501] DMA zone: 15352 pages used for memmap [ 2.740505] DMA zone: 0 pages reserved [ 2.740510] DMA zone: 982528 pages, LIFO batch:63 [ 2.740516] Normal zone: 16384 pages used for memmap [ 2.740521] Normal zone: 1048576 pages, LIFO batch:63 [ 2.787492] psci: probing for conduit method from DT. [ 2.787504] psci: PSCIv1.1 detected in firmware. [ 2.787509] psci: Using standard PSCI v0.2 function IDs [ 2.787515] psci: MIGRATE_INFO_TYPE not supported. [ 2.787521] psci: SMC Calling Convention v1.2 [ 2.787941] percpu: Embedded 32 pages/cpu s93480 r8192 d29400 u131072 [ 2.787983] pcpu-alloc: s93480 r8192 d29400 u131072 alloc=32*4096 [ 2.787990] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7 [ 2.788133] Detected VIPT I-cache on CPU0 [ 2.788180] CPU features: detected: GIC system register CPU interface [ 2.788186] CPU features: detected: Virtualization Host Extensions [ 2.788197] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 2.788210] alternatives: patching kernel code [ 2.788594] Built 1 zonelists, mobility grouping on. Total pages: 1999368 [ 2.788604] Kernel command line: root=UUID=329a3cf7-a8ce-4ea6-a3ef-c2128bda1678 rootwait rootfstype=ext4 splash plymouth.ignore-serial-consoles console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart= usb-storage.quirks= cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 [ 2.789939] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) [ 2.790345] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 2.790352] mem auto-init: stack:off, heap alloc:off, heap free:off [ 2.796859] software IO TLB: mapped [mem 0x00000000ec000000-0x00000000f0000000] (64MB) [ 2.872007] Memory: 7589184K/8124416K available (16832K kernel code, 3506K rwdata, 6500K rodata, 6976K init, 639K bss, 273088K reserved, 262144K cma-reserved) [ 2.872165] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1 [ 2.872203] ftrace: allocating 64539 entries in 253 pages [ 2.982561] ftrace: allocated 253 pages with 7 groups [ 2.982869] rcu: Hierarchical RCU implementation. [ 2.982875] rcu: RCU event tracing is enabled. [ 2.982881] Rude variant of Tasks RCU enabled. [ 2.982884] Tracing variant of Tasks RCU enabled. [ 2.982891] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies. [ 2.988553] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 2.991485] GICv3: GIC: Using split EOI/Deactivate mode [ 2.991493] GICv3: 480 SPIs implemented [ 2.991498] GICv3: 0 Extended SPIs implemented [ 2.991536] GICv3: Distributor has no Range Selector support [ 2.991547] GICv3: 16 PPIs implemented [ 2.991592] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000 [ 2.991718] ITS [mem 0xfe640000-0xfe65ffff] [ 2.991776] ITS@0x00000000fe640000: allocated 8192 Devices @100200000 (indirect, esz 8, psz 64K, shr 0) [ 2.991805] ITS@0x00000000fe640000: allocated 32768 Interrupt Collections @100210000 (flat, esz 2, psz 64K, shr 0) [ 2.991815] ITS: using cache flushing for cmd queue [ 2.991857] ITS [mem 0xfe660000-0xfe67ffff] [ 2.991906] ITS@0x00000000fe660000: allocated 8192 Devices @100230000 (indirect, esz 8, psz 64K, shr 0) [ 2.991934] ITS@0x00000000fe660000: allocated 32768 Interrupt Collections @100240000 (flat, esz 2, psz 64K, shr 0) [ 2.991943] ITS: using cache flushing for cmd queue [ 2.992169] GICv3: using LPI property table @0x0000000100250000 [ 2.992299] GIC: using cache flushing for LPI property table [ 2.992311] GICv3: CPU0: using allocated LPI pending table @0x0000000100260000 [ 3.128849] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 3.128859] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 3.128869] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 3.130274] Console: colour dummy device 80x25 [ 3.130316] printk: console [tty1] enabled [ 3.130345] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000) [ 3.130356] pid_max: default: 32768 minimum: 301 [ 3.130469] LSM: Security Framework initializing [ 3.130540] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 3.130566] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 3.132822] rcu: Hierarchical SRCU implementation. [ 3.133806] Platform MSI: msi-controller@fe640000 domain created [ 3.133828] Platform MSI: msi-controller@fe660000 domain created [ 3.134226] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe640000 domain created [ 3.134252] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe660000 domain created [ 3.134438] EFI services will not be available. [ 3.134891] smp: Bringing up secondary CPUs ... [ 3.135611] Detected VIPT I-cache on CPU1 [ 3.135648] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000 [ 3.135668] GICv3: CPU1: using allocated LPI pending table @0x0000000100270000 [ 3.135713] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [ 3.136490] Detected VIPT I-cache on CPU2 [ 3.136523] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000 [ 3.136542] GICv3: CPU2: using allocated LPI pending table @0x0000000100280000 [ 3.136583] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [ 3.137311] Detected VIPT I-cache on CPU3 [ 3.137341] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000 [ 3.137360] GICv3: CPU3: using allocated LPI pending table @0x0000000100290000 [ 3.137398] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [ 3.138138] CPU features: detected: Spectre-v4 [ 3.138142] CPU features: detected: Spectre-BHB [ 3.138144] Detected PIPT I-cache on CPU4 [ 3.138160] GICv3: CPU4: found redistributor 400 region 0:0x00000000fe700000 [ 3.138171] GICv3: CPU4: using allocated LPI pending table @0x00000001002a0000 [ 3.138196] CPU4: Booted secondary processor 0x0000000400 [0x414fd0b0] [ 3.138921] Detected PIPT I-cache on CPU5 [ 3.138938] GICv3: CPU5: found redistributor 500 region 0:0x00000000fe720000 [ 3.138949] GICv3: CPU5: using allocated LPI pending table @0x00000001002b0000 [ 3.138975] CPU5: Booted secondary processor 0x0000000500 [0x414fd0b0] [ 3.139668] Detected PIPT I-cache on CPU6 [ 3.139684] GICv3: CPU6: found redistributor 600 region 0:0x00000000fe740000 [ 3.139695] GICv3: CPU6: using allocated LPI pending table @0x00000001002c0000 [ 3.139720] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b0] [ 3.140395] Detected PIPT I-cache on CPU7 [ 3.140411] GICv3: CPU7: found redistributor 700 region 0:0x00000000fe760000 [ 3.140422] GICv3: CPU7: using allocated LPI pending table @0x00000001002d0000 [ 3.140447] CPU7: Booted secondary processor 0x0000000700 [0x414fd0b0] [ 3.140525] smp: Brought up 1 node, 8 CPUs [ 3.140545] SMP: Total of 8 processors activated. [ 3.140550] CPU features: detected: Privileged Access Never [ 3.140555] CPU features: detected: User Access Override [ 3.140560] CPU features: detected: 32-bit EL0 Support [ 3.140564] CPU features: detected: Common not Private translations [ 3.140569] CPU features: detected: RAS Extension Support [ 3.140573] CPU features: detected: Data cache clean to the PoU not required for I/D coherence [ 3.140578] CPU features: detected: CRC32 instructions [ 3.140582] CPU features: detected: Speculative Store Bypassing Safe (SSBS) [ 3.140589] CPU features: detected: RCpc load-acquire (LDAPR) [ 3.140676] CPU: All CPU(s) started at EL2 [ 3.144120] devtmpfs: initialized [ 3.158887] Registered cp15_barrier emulation handler [ 3.158896] Registered setend emulation handler [ 3.158901] KASLR disabled due to lack of seed [ 3.158988] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns [ 3.158995] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 3.161775] pinctrl core: initialized pinctrl subsystem [ 3.161895] regulator-dummy: no parameters, enabled [ 3.162013] DMI not present or invalid. [ 3.162313] NET: Registered protocol family 16 [ 3.163339] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations [ 3.163443] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 3.163460] audit: initializing netlink subsys (disabled) [ 3.163543] audit: type=2000 audit(0.033:1): state=initialized audit_enabled=0 res=1 [ 3.164056] Registered FIQ tty driver [ 3.164208] thermal_sys: Registered thermal governor 'fair_share' [ 3.164211] thermal_sys: Registered thermal governor 'step_wise' [ 3.164213] thermal_sys: Registered thermal governor 'user_space' [ 3.164216] thermal_sys: Registered thermal governor 'power_allocator' [ 3.164546] cpuidle: using governor menu [ 3.164776] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 3.164923] ASID allocator initialised with 65536 entries [ 3.166428] ramoops: dmesg-0 0x20000@0x0000000000110000 [ 3.166443] ramoops: console 0x80000@0x0000000000130000 [ 3.166453] ramoops: pmsg 0x50000@0x00000000001b0000 [ 3.166500] printk: console [ramoops-1] enabled [ 3.166502] pstore: Registered ramoops as persistent store backend [ 3.166505] ramoops: using 0xf0000@0x110000, ecc: 0 [ 3.220663] rockchip-gpio fd8a0000.gpio: probed /pinctrl/gpio@fd8a0000 [ 3.220958] rockchip-gpio fec20000.gpio: probed /pinctrl/gpio@fec20000 [ 3.221192] rockchip-gpio fec30000.gpio: probed /pinctrl/gpio@fec30000 [ 3.221468] rockchip-gpio fec40000.gpio: probed /pinctrl/gpio@fec40000 [ 3.221748] rockchip-gpio fec50000.gpio: probed /pinctrl/gpio@fec50000 [ 3.221798] rockchip-pinctrl pinctrl: probed pinctrl [ 3.230346] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 3.230350] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 3.230353] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 3.230355] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 3.288790] raid6: neonx8 gen() 5348 MB/s [ 3.345537] raid6: neonx8 xor() 4146 MB/s [ 3.402289] raid6: neonx4 gen() 5486 MB/s [ 3.459036] raid6: neonx4 xor() 4167 MB/s [ 3.515785] raid6: neonx2 gen() 5031 MB/s [ 3.572534] raid6: neonx2 xor() 3933 MB/s [ 3.629283] raid6: neonx1 gen() 4205 MB/s [ 3.686031] raid6: neonx1 xor() 3239 MB/s [ 3.742794] raid6: int64x8 gen() 1308 MB/s [ 3.799541] raid6: int64x8 xor() 863 MB/s [ 3.856279] raid6: int64x4 gen() 1612 MB/s [ 3.913038] raid6: int64x4 xor() 876 MB/s [ 3.969784] raid6: int64x2 gen() 1878 MB/s [ 4.026531] raid6: int64x2 xor() 1296 MB/s [ 4.083285] raid6: int64x1 gen() 1963 MB/s [ 4.140041] raid6: int64x1 xor() 958 MB/s [ 4.140043] raid6: using algorithm neonx4 gen() 5486 MB/s [ 4.140045] raid6: .... xor() 4167 MB/s, rmw enabled [ 4.140047] raid6: using neon recovery algorithm [ 4.140620] fiq_debugger fiq_debugger.0: IRQ fiq not found [ 4.140626] fiq_debugger fiq_debugger.0: IRQ wakeup not found [ 4.140630] fiq_debugger_probe: could not install nmi irq handler [ 4.140719] printk: console [ttyFIQ0] enabled [ 4.140819] Registered fiq debugger ttyFIQ0 [ 4.141047] vcc12v_dcin: 12000 mV, enabled [ 4.141127] reg-fixed-voltage vcc12v-dcin: vcc12v_dcin supplying 12000000uV [ 4.141178] reg-fixed-voltage vcc5v0-sys: Looking up vin-supply from device tree [ 4.141182] vcc5v0_sys: supplied by vcc12v_dcin [ 4.141187] vcc12v_dcin: could not add device link regulator.2: -ENOENT [ 4.141202] vcc5v0_sys: 5000 mV, enabled [ 4.141268] reg-fixed-voltage vcc5v0-sys: vcc5v0_sys supplying 5000000uV [ 4.141317] reg-fixed-voltage vcc5v0-usbdcin: Looking up vin-supply from device tree [ 4.141321] vcc5v0_usbdcin: supplied by vcc12v_dcin [ 4.141325] vcc12v_dcin: could not add device link regulator.3: -ENOENT [ 4.141340] vcc5v0_usbdcin: 5000 mV, enabled [ 4.141401] reg-fixed-voltage vcc5v0-usbdcin: vcc5v0_usbdcin supplying 5000000uV [ 4.141449] reg-fixed-voltage vcc5v0-usb: Looking up vin-supply from device tree [ 4.141453] vcc5v0_usb: supplied by vcc5v0_usbdcin [ 4.141457] vcc5v0_usbdcin: could not add device link regulator.4: -ENOENT [ 4.141476] vcc5v0_usb: 5000 mV, enabled [ 4.141536] reg-fixed-voltage vcc5v0-usb: vcc5v0_usb supplying 5000000uV [ 4.141641] vbus5v0_typec: 5000 mV, disabled [ 4.141692] reg-fixed-voltage vbus5v0-typec: Looking up vin-supply from device tree [ 4.141696] vbus5v0_typec: supplied by vcc5v0_usb [ 4.141732] reg-fixed-voltage vbus5v0-typec: vbus5v0_typec supplying 5000000uV [ 4.141785] reg-fixed-voltage vcc-1v1-nldo-s3: Looking up vin-supply from device tree [ 4.141789] vcc_1v1_nldo_s3: supplied by vcc5v0_sys [ 4.141792] vcc5v0_sys: could not add device link regulator.6: -ENOENT [ 4.141807] vcc_1v1_nldo_s3: 1100 mV, enabled [ 4.141867] reg-fixed-voltage vcc-1v1-nldo-s3: vcc_1v1_nldo_s3 supplying 1100000uV [ 4.141919] reg-fixed-voltage vcc3v3-pcie2x1l2: Looking up vin-supply from device tree [ 4.141923] vcc3v3_pcie2x1l2: supplied by vcc5v0_sys [ 4.141926] vcc5v0_sys: could not add device link regulator.7: -ENOENT [ 4.198898] vcc3v3_pcie2x1l2: 1800 mV, enabled [ 4.198967] reg-fixed-voltage vcc3v3-pcie2x1l2: vcc3v3_pcie2x1l2 supplying 1800000uV [ 4.199244] iommu: Default domain type: Translated [ 4.199678] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vdpu-supply from device tree [ 4.199697] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vdpu-supply property in node /power-management@fd8d8000/power-controller failed [ 4.199965] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga30-supply from device tree [ 4.199983] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga30-supply property in node /power-management@fd8d8000/power-controller failed [ 4.200164] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga31-supply from device tree [ 4.200182] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga31-supply property in node /power-management@fd8d8000/power-controller failed [ 4.201496] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc0-supply from device tree [ 4.201514] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc0-supply property in node /power-management@fd8d8000/power-controller failed [ 4.201670] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vcodec-supply from device tree [ 4.201688] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vcodec-supply property in node /power-management@fd8d8000/power-controller failed [ 4.201790] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc1-supply from device tree [ 4.201807] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc1-supply property in node /power-management@fd8d8000/power-controller failed [ 4.202084] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec0-supply from device tree [ 4.202102] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec0-supply property in node /power-management@fd8d8000/power-controller failed [ 4.202396] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec1-supply from device tree [ 4.202414] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec1-supply property in node /power-management@fd8d8000/power-controller failed [ 4.202638] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vi-supply from device tree [ 4.202655] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vi-supply property in node /power-management@fd8d8000/power-controller failed [ 4.202891] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up isp1-supply from device tree [ 4.202908] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up isp1-supply property in node /power-management@fd8d8000/power-controller failed [ 4.203610] SCSI subsystem initialized [ 4.203626] libata version 3.00 loaded. [ 4.203695] usbcore: registered new interface driver usbfs [ 4.203710] usbcore: registered new interface driver hub [ 4.203726] usbcore: registered new device driver usb [ 4.203765] mc: Linux media interface: v0.10 [ 4.203775] videodev: Linux video capture interface: v2.00 [ 4.203803] pps_core: LinuxPPS API ver. 1 registered [ 4.203805] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [ 4.203810] PTP clock support registered [ 4.204096] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled. [ 4.204128] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0 [ 4.205335] Advanced Linux Sound Architecture Driver Initialized. [ 4.205605] Bluetooth: Core ver 2.22 [ 4.205622] NET: Registered protocol family 31 [ 4.205624] Bluetooth: HCI device and connection manager initialized [ 4.205629] Bluetooth: HCI socket layer initialized [ 4.205633] Bluetooth: L2CAP socket layer initialized [ 4.205639] Bluetooth: SCO socket layer initialized [ 4.205652] NetLabel: Initializing [ 4.205654] NetLabel: domain hash size = 128 [ 4.205655] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 4.205682] NetLabel: unlabeled traffic allowed by default [ 4.207004] rockchip-cpuinfo cpuinfo: SoC : 35881000 [ 4.207008] rockchip-cpuinfo cpuinfo: Serial : 2eae2cb9d903d20e [ 4.207438] clocksource: Switched to clocksource arch_sys_counter [ 4.624970] VFS: Disk quotas dquot_6.6.0 [ 4.624999] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 4.630563] NET: Registered protocol family 2 [ 4.630687] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 4.632734] tcp_listen_portaddr_hash hash table entries: 4096 (order: 5, 163840 bytes, linear) [ 4.632813] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 4.633160] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear) [ 4.633964] TCP: Hash tables configured (established 65536 bind 65536) [ 4.634078] MPTCP token hash table entries: 8192 (order: 6, 393216 bytes, linear) [ 4.634196] UDP hash table entries: 4096 (order: 6, 393216 bytes, linear) [ 4.634354] UDP-Lite hash table entries: 4096 (order: 6, 393216 bytes, linear) [ 4.634569] NET: Registered protocol family 1 [ 4.634941] RPC: Registered named UNIX socket transport module. [ 4.634944] RPC: Registered udp transport module. [ 4.634946] RPC: Registered tcp transport module. [ 4.634948] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 4.635357] PCI: CLS 0 bytes, default 64 [ 4.635626] Trying to unpack rootfs image as initramfs... [ 5.030150] Freeing initrd memory: 14952K [ 5.030861] rockchip-thermal fec00000.tsadc: Missing rockchip,grf property [ 5.031512] rockchip-thermal fec00000.tsadc: tsadc is probed successfully! [ 5.032456] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 5.033074] kvm [1]: IPA Size Limit: 40 bits [ 5.033085] kvm [1]: GICv3: no GICV resource entry [ 5.033088] kvm [1]: disabling GICv2 emulation [ 5.033090] kvm [1]: GIC system register CPU interface enabled [ 5.033245] kvm [1]: vgic interrupt IRQ9 [ 5.033424] kvm [1]: VHE mode initialized successfully [ 5.036452] Initialise system trusted keyrings [ 5.036566] workingset: timestamp_bits=46 max_order=21 bucket_order=0 [ 5.039640] NFS: Registering the id_resolver key type [ 5.039660] Key type id_resolver registered [ 5.039662] Key type id_legacy registered [ 5.039700] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 5.039703] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 5.039715] ntfs: driver 2.1.32 [Flags: R/W]. [ 5.060732] NET: Registered protocol family 38 [ 5.060737] xor: measuring software checksum speed [ 5.062353] 8regs : 6139 MB/sec [ 5.063563] 32regs : 8147 MB/sec [ 5.064576] arm64_neon : 10013 MB/sec [ 5.064579] xor: using function: arm64_neon (10013 MB/sec) [ 5.064584] Key type asymmetric registered [ 5.064586] Asymmetric key parser 'x509' registered [ 5.064604] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242) [ 5.064719] io scheduler mq-deadline registered [ 5.064724] io scheduler kyber registered [ 5.066565] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up phy-supply from device tree [ 5.066574] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up phy-supply property in node /syscon@fd5d0000/usb2-phy@0/otg-port failed [ 5.066622] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up vbus-supply from device tree [ 5.066629] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up vbus-supply property in node /syscon@fd5d0000/usb2-phy@0/otg-port failed [ 5.067963] phy phy-fd5d8000.syscon:usb2-phy@8000.1: Looking up phy-supply from device tree [ 5.067972] phy phy-fd5d8000.syscon:usb2-phy@8000.1: Looking up phy-supply property in node /syscon@fd5d8000/usb2-phy@8000/host-port failed [ 5.069162] phy phy-fd5dc000.syscon:usb2-phy@c000.2: Looking up phy-supply from device tree [ 5.069170] phy phy-fd5dc000.syscon:usb2-phy@c000.2: Looking up phy-supply property in node /syscon@fd5dc000/usb2-phy@c000/host-port failed [ 5.071042] phy phy-fee00000.phy.3: Looking up phy-supply from device tree [ 5.071049] phy phy-fee00000.phy.3: Looking up phy-supply property in node /phy@fee00000 failed [ 5.071196] phy phy-fee20000.phy.4: Looking up phy-supply from device tree [ 5.071202] phy phy-fee20000.phy.4: Looking up phy-supply property in node /phy@fee20000 failed [ 5.071700] phy phy-feda0000.phy.5: Looking up phy-supply from device tree [ 5.071705] phy phy-feda0000.phy.5: Looking up phy-supply property in node /phy@feda0000 failed [ 5.071839] phy phy-fedb0000.phy.6: Looking up phy-supply from device tree [ 5.071844] phy phy-fedb0000.phy.6: Looking up phy-supply property in node /phy@fedb0000 failed [ 5.072225] phy phy-fed60000.hdmiphy.7: Looking up phy-supply from device tree [ 5.072231] phy phy-fed60000.hdmiphy.7: Looking up phy-supply property in node /hdmiphy@fed60000 failed [ 5.073004] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy init success [ 5.073959] phy phy-fed80000.phy.8: Looking up phy-supply from device tree [ 5.073967] phy phy-fed80000.phy.8: Looking up phy-supply property in node /phy@fed80000/dp-port failed [ 5.074000] phy phy-fed80000.phy.9: Looking up phy-supply from device tree [ 5.074005] phy phy-fed80000.phy.9: Looking up phy-supply property in node /phy@fed80000/u3-port failed [ 5.075493] rk-pcie fe190000.pcie: invalid prsnt-gpios property in node [ 5.075505] rk-pcie fe190000.pcie: Looking up vpcie3v3-supply from device tree [ 5.075870] pwm-backlight backlight: Looking up power-supply from device tree [ 5.075876] pwm-backlight backlight: Looking up power-supply property in node /backlight failed [ 5.075881] pwm-backlight backlight: supply power not found, using dummy regulator [ 5.076065] pwm-backlight backlight_1: Looking up power-supply from device tree [ 5.076071] pwm-backlight backlight_1: Looking up power-supply property in node /backlight_1 failed [ 5.076075] pwm-backlight backlight_1: supply power not found, using dummy regulator [ 5.076164] rk-pcie fe190000.pcie: IRQ msi not found [ 5.076171] rk-pcie fe190000.pcie: use outband MSI support [ 5.076178] rk-pcie fe190000.pcie: Missing *config* reg space [ 5.076201] rk-pcie fe190000.pcie: host bridge /pcie@fe190000 ranges: [ 5.076227] rk-pcie fe190000.pcie: err 0x00f4000000..0x00f40fffff -> 0x00f4000000 [ 5.076251] rk-pcie fe190000.pcie: IO 0x00f4100000..0x00f41fffff -> 0x00f4100000 [ 5.076281] rk-pcie fe190000.pcie: MEM 0x00f4200000..0x00f4ffffff -> 0x00f4200000 [ 5.076297] rk-pcie fe190000.pcie: MEM 0x0a00000000..0x0a3fffffff -> 0x0a00000000 [ 5.076334] rk-pcie fe190000.pcie: Missing *config* reg space [ 5.076350] iep: Module initialized. [ 5.076365] rk-pcie fe190000.pcie: invalid resource [ 5.076390] mpp_service mpp-srv: unknown mpp version for missing VCS info [ 5.076392] mpp_service mpp-srv: probe start [ 5.078417] mpp_vdpu2 fdb50400.vdpu: Adding to iommu group 1 [ 5.078636] mpp_vdpu2 fdb50400.vdpu: probe device [ 5.078752] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0 [ 5.078758] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0 [ 5.078899] mpp_vdpu2 fdb50400.vdpu: probing finish [ 5.079118] mpp_vepu2 jpege-ccu: probing start [ 5.079122] mpp_vepu2 jpege-ccu: probing finish [ 5.079233] mpp_vepu2 fdb50000.vepu: Adding to iommu group 1 [ 5.079316] mpp_vepu2 fdb50000.vepu: probing start [ 5.079418] mpp_vepu2 fdb50000.vepu: reset_group->rw_sem_on=0 [ 5.079422] mpp_vepu2 fdb50000.vepu: reset_group->rw_sem_on=0 [ 5.079567] mpp_vepu2 fdb50000.vepu: probing finish [ 5.079685] mpp_vepu2 fdba0000.jpege-core: Adding to iommu group 5 [ 5.079824] mpp_vepu2 fdba0000.jpege-core: probing start [ 5.079930] mpp_vepu2 fdba0000.jpege-core: attach ccu success [ 5.080074] mpp_vepu2 fdba0000.jpege-core: probing finish [ 5.080185] mpp_vepu2 fdba4000.jpege-core: Adding to iommu group 6 [ 5.080324] mpp_vepu2 fdba4000.jpege-core: probing start [ 5.080432] mpp_vepu2 fdba4000.jpege-core: attach ccu success [ 5.080579] mpp_vepu2 fdba4000.jpege-core: probing finish [ 5.080686] mpp_vepu2 fdba8000.jpege-core: Adding to iommu group 7 [ 5.080842] mpp_vepu2 fdba8000.jpege-core: probing start [ 5.080945] mpp_vepu2 fdba8000.jpege-core: attach ccu success [ 5.081095] mpp_vepu2 fdba8000.jpege-core: probing finish [ 5.081189] mpp_vepu2 fdbac000.jpege-core: Adding to iommu group 8 [ 5.081325] mpp_vepu2 fdbac000.jpege-core: probing start [ 5.081429] mpp_vepu2 fdbac000.jpege-core: attach ccu success [ 5.081569] mpp_vepu2 fdbac000.jpege-core: probing finish [ 5.081847] mpp-iep2 fdbb0000.iep: Adding to iommu group 9 [ 5.081990] mpp-iep2 fdbb0000.iep: probe device [ 5.082120] mpp-iep2 fdbb0000.iep: allocate roi buffer failed [ 5.082250] mpp-iep2 fdbb0000.iep: probing finish [ 5.082474] mpp_jpgdec fdb90000.jpegd: Adding to iommu group 4 [ 5.082681] mpp_jpgdec fdb90000.jpegd: probe device [ 5.082930] mpp_jpgdec fdb90000.jpegd: probing finish [ 5.083302] mpp_rkvdec2 fdc30000.rkvdec-ccu: rkvdec-ccu, probing start [ 5.083360] mpp_rkvdec2 fdc30000.rkvdec-ccu: ccu-mode: 1 [ 5.083363] mpp_rkvdec2 fdc30000.rkvdec-ccu: probing finish [ 5.083457] mpp_rkvdec2 fdc38100.rkvdec-core: Adding to iommu group 12 [ 5.083716] mpp_rkvdec2 fdc38100.rkvdec-core: rkvdec-core, probing start [ 5.083843] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found! [ 5.083846] rkvdec2_init:1022: No niu aclk reset resource define [ 5.083849] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found! [ 5.083851] rkvdec2_init:1025: No niu hclk reset resource define [ 5.083866] mpp_rkvdec2 fdc38100.rkvdec-core: Looking up vdec-supply from device tree [ 5.083871] mpp_rkvdec2 fdc38100.rkvdec-core: Looking up vdec-supply property in node /rkvdec-core@fdc38000 failed [ 5.083877] mpp_rkvdec2 fdc38100.rkvdec-core: no regulator, devfreq is disabled [ 5.083933] mpp_rkvdec2 fdc38100.rkvdec-core: core_mask=00010001 [ 5.083936] mpp_rkvdec2 fdc38100.rkvdec-core: attach ccu as core 0 [ 5.084083] mpp_rkvdec2 fdc38100.rkvdec-core: sram_start 0x00000000ff001000 [ 5.084086] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_iova 0x00000000fff00000 [ 5.084089] mpp_rkvdec2 fdc38100.rkvdec-core: sram_size 491520 [ 5.084092] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_size 1048576 [ 5.084109] mpp_rkvdec2 fdc38100.rkvdec-core: min_width 512 [ 5.084113] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_info_count 20 [ 5.084116] mpp_rkvdec2 fdc38100.rkvdec-core: [136, 24576] [ 5.084119] mpp_rkvdec2 fdc38100.rkvdec-core: [137, 49152] [ 5.084121] mpp_rkvdec2 fdc38100.rkvdec-core: [141, 90112] [ 5.084124] mpp_rkvdec2 fdc38100.rkvdec-core: [140, 49152] [ 5.084126] mpp_rkvdec2 fdc38100.rkvdec-core: [139, 180224] [ 5.084129] mpp_rkvdec2 fdc38100.rkvdec-core: [133, 49152] [ 5.084132] mpp_rkvdec2 fdc38100.rkvdec-core: [134, 8192] [ 5.084134] mpp_rkvdec2 fdc38100.rkvdec-core: [135, 4352] [ 5.084137] mpp_rkvdec2 fdc38100.rkvdec-core: [138, 13056] [ 5.084140] mpp_rkvdec2 fdc38100.rkvdec-core: [142, 291584] [ 5.084173] mpp_rkvdec2 fdc38100.rkvdec-core: probing finish [ 5.084264] mpp_rkvdec2 fdc48100.rkvdec-core: Adding to iommu group 13 [ 5.084499] mpp_rkvdec2 fdc48100.rkvdec-core: rkvdec-core, probing start [ 5.084620] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found! [ 5.084623] rkvdec2_init:1022: No niu aclk reset resource define [ 5.084626] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found! [ 5.084628] rkvdec2_init:1025: No niu hclk reset resource define [ 5.084643] mpp_rkvdec2 fdc48100.rkvdec-core: Looking up vdec-supply from device tree [ 5.084648] mpp_rkvdec2 fdc48100.rkvdec-core: Looking up vdec-supply property in node /rkvdec-core@fdc48000 failed [ 5.084654] mpp_rkvdec2 fdc48100.rkvdec-core: no regulator, devfreq is disabled [ 5.084695] mpp_rkvdec2 fdc48100.rkvdec-core: core_mask=00020002 [ 5.084711] mpp_rkvdec2 fdc48100.rkvdec-core: attach ccu as core 1 [ 5.084891] mpp_rkvdec2 fdc48100.rkvdec-core: sram_start 0x00000000ff079000 [ 5.084894] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_iova 0x00000000ffe00000 [ 5.084896] mpp_rkvdec2 fdc48100.rkvdec-core: sram_size 487424 [ 5.084899] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_size 1048576 [ 5.084903] mpp_rkvdec2 fdc48100.rkvdec-core: min_width 512 [ 5.084907] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_info_count 20 [ 5.084910] mpp_rkvdec2 fdc48100.rkvdec-core: [136, 24576] [ 5.084912] mpp_rkvdec2 fdc48100.rkvdec-core: [137, 49152] [ 5.084915] mpp_rkvdec2 fdc48100.rkvdec-core: [141, 90112] [ 5.084918] mpp_rkvdec2 fdc48100.rkvdec-core: [140, 49152] [ 5.084920] mpp_rkvdec2 fdc48100.rkvdec-core: [139, 180224] [ 5.084923] mpp_rkvdec2 fdc48100.rkvdec-core: [133, 49152] [ 5.084926] mpp_rkvdec2 fdc48100.rkvdec-core: [134, 8192] [ 5.084928] mpp_rkvdec2 fdc48100.rkvdec-core: [135, 4352] [ 5.084931] mpp_rkvdec2 fdc48100.rkvdec-core: [138, 13056] [ 5.084933] mpp_rkvdec2 fdc48100.rkvdec-core: [142, 291584] [ 5.084963] mpp_rkvdec2 fdc48100.rkvdec-core: probing finish [ 5.085157] mpp_rkvenc2 rkvenc-ccu: probing start [ 5.085161] mpp_rkvenc2 rkvenc-ccu: probing finish [ 5.085279] mpp_rkvenc2 fdbd0000.rkvenc-core: Adding to iommu group 10 [ 5.085463] mpp_rkvenc2 fdbd0000.rkvenc-core: probing start [ 5.085607] mpp_rkvenc2 fdbd0000.rkvenc-core: Looking up venc-supply from device tree [ 5.085613] mpp_rkvenc2 fdbd0000.rkvenc-core: Looking up venc-supply property in node /rkvenc-core@fdbd0000 failed [ 5.085619] mpp_rkvenc2 fdbd0000.rkvenc-core: dev_pm_opp_set_regulators: no regulator (venc) found: -19 [ 5.085635] rkvenc_init:1814: failed to add venc devfreq [ 5.085663] mpp_rkvenc2 fdbd0000.rkvenc-core: attach ccu as core 0 [ 5.085814] mpp_rkvenc2 fdbd0000.rkvenc-core: probing finish [ 5.085896] mpp_rkvenc2 fdbe0000.rkvenc-core: Adding to iommu group 11 [ 5.086083] mpp_rkvenc2 fdbe0000.rkvenc-core: probing start [ 5.086213] mpp_rkvenc2 fdbe0000.rkvenc-core: Looking up venc-supply from device tree [ 5.086219] mpp_rkvenc2 fdbe0000.rkvenc-core: Looking up venc-supply property in node /rkvenc-core@fdbe0000 failed [ 5.086225] mpp_rkvenc2 fdbe0000.rkvenc-core: dev_pm_opp_set_regulators: no regulator (venc) found: -19 [ 5.086238] rkvenc_init:1814: failed to add venc devfreq [ 5.086287] mpp_rkvenc2 fdbe0000.rkvenc-core: attach ccu as core 1 [ 5.086432] mpp_rkvenc2 fdbe0000.rkvenc-core: probing finish [ 5.086682] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up av1-supply from device tree [ 5.086703] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up av1-supply property in node /power-management@fd8d8000/power-controller failed [ 5.087010] mpp_av1dec: Adding child /av1d@fdc70000 [ 5.087089] mpp_av1dec: register device av1d-master [ 5.087119] mpp_av1dec av1d-master: av1_iommu_of_xlate,784 [ 5.087138] av1_iommu_probe_device,736, consumer : av1d-master, supplier : fdca0000.iommu [ 5.087169] mpp_av1dec av1d-master: Adding to iommu group 18 [ 5.087409] mpp_av1dec av1d-master: probing start [ 5.087693] mpp_av1dec av1d-master: probing finish [ 5.087732] mpp_service mpp-srv: probe success [ 5.098874] dma-pl330 fea10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 5.098881] dma-pl330 fea10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 5.099892] dma-pl330 fea30000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 5.099898] dma-pl330 fea30000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 5.100901] dma-pl330 fed10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 5.100906] dma-pl330 fed10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 5.101411] rockchip-pvtm fda40000.pvtm: pvtm@0 probed [ 5.101474] rockchip-pvtm fda50000.pvtm: pvtm@1 probed [ 5.101532] rockchip-pvtm fda60000.pvtm: pvtm@2 probed [ 5.101588] rockchip-pvtm fdaf0000.pvtm: pvtm@3 probed [ 5.101647] rockchip-pvtm fdb30000.pvtm: pvtm@4 probed [ 5.102247] rockchip-system-monitor rockchip-system-monitor: system monitor probe [ 5.103064] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [ 5.103580] febc0000.serial: ttyS9 at MMIO 0xfebc0000 (irq = 101, base_baud = 1500000) is a 16550A [ 5.104898] random: crng init done [ 5.104943] led_vk2c21_init ============================================= [ 5.105928] rockchip-vop2 fdd90000.vop: Adding to iommu group 17 [ 5.114617] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x5, primary plane phy id: 0 [ 5.114624] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp1 assign plane mask: 0xa, primary plane phy id: 1 [ 5.114629] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x140, primary plane phy id: 6 [ 5.114635] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp3 assign plane mask: 0x280, primary plane phy id: 7 [ 5.114729] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart0-win0 as cursor plane for vp0 [ 5.114821] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart1-win0 as cursor plane for vp1 [ 5.114908] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart2-win0 as cursor plane for vp2 [ 5.114990] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart3-win0 as cursor plane for vp3 [ 5.115008] [drm] failed to init overlay plane Cluster0-win1 [ 5.115011] [drm] failed to init overlay plane Cluster1-win1 [ 5.115013] [drm] failed to init overlay plane Cluster2-win1 [ 5.115016] [drm] failed to init overlay plane Cluster3-win1 [ 5.126630] rockchip-drm display-subsystem: bound fdd90000.vop (ops 0xffff8000091b2620) [ 5.127578] dwhdmi-rockchip fde80000.hdmi: registered ddc I2C bus driver [ 5.127795] rockchip-drm display-subsystem: bound fde80000.hdmi (ops 0xffff8000091c0798) [ 5.127874] rockchip-drm display-subsystem: bound fde50000.dp (ops 0xffff8000091c3278) [ 5.128504] rockchip-drm display-subsystem: failed to parse loader memory [ 5.281938] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x2 [ 5.348690] dwhdmi-rockchip fde80000.hdmi: use tmds mode [ 5.348734] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] Update mode to 1920x1080p60, type: 11(if:800) for vp0 dclk: 148500000 [ 5.348901] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] dclk_out0 div: 0 dclk_core0 div: 2 [ 5.348919] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx_ropll_cmn_config bus_width:16a8c8 rate:1485000 [ 5.349197] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy pll locked! [ 5.349203] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] set dclk_vop0 to 148500000, get 148500000 [ 5.349227] dwhdmi-rockchip fde80000.hdmi: final tmdsclk = 148500000 [ 5.349257] dwhdmi-rockchip fde80000.hdmi: don't use dsc mode [ 5.349260] dwhdmi-rockchip fde80000.hdmi: dw hdmi qp use tmds mode [ 5.349267] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: bus_width:0x16a8c8,bit_rate:1485000 [ 5.349461] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy lane locked! [ 5.364139] rk-pcie fe190000.pcie: PCIe Link up, LTSSM is 0x30011 [ 5.364314] rk-pcie fe190000.pcie: PCI host bridge to bus 0004:40 [ 5.364325] pci_bus 0004:40: root bus resource [bus 40-4f] [ 5.364333] pci_bus 0004:40: root bus resource [??? 0xf4000000-0xf40fffff flags 0x0] [ 5.364342] pci_bus 0004:40: root bus resource [io 0x0000-0xfffff] (bus address [0xf4100000-0xf41fffff]) [ 5.364349] pci_bus 0004:40: root bus resource [mem 0xf4200000-0xf4ffffff] [ 5.364356] pci_bus 0004:40: root bus resource [mem 0xa00000000-0xa3fffffff pref] [ 5.364400] pci 0004:40:00.0: [1d87:3588] type 01 class 0x060400 [ 5.364429] pci 0004:40:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref] [ 5.364509] pci 0004:40:00.0: supports D1 D2 [ 5.364515] pci 0004:40:00.0: PME# supported from D0 D1 D3hot [ 5.377681] pci 0004:40:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 5.377941] pci 0004:41:00.0: [144d:a804] type 00 class 0x010802 [ 5.378041] pci 0004:41:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit] [ 5.378776] pci 0004:41:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x1 link at 0004:40:00.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link) [ 5.400088] pci_bus 0004:41: busn_res: [bus 41-4f] end is updated to 41 [ 5.400118] pci 0004:40:00.0: BAR 8: assigned [mem 0xf4200000-0xf42fffff] [ 5.400129] pci 0004:40:00.0: BAR 6: assigned [mem 0xf4300000-0xf430ffff pref] [ 5.400143] pci 0004:41:00.0: BAR 0: assigned [mem 0xf4200000-0xf4203fff 64bit] [ 5.400183] pci 0004:40:00.0: PCI bridge to [bus 41] [ 5.400193] pci 0004:40:00.0: bridge window [mem 0xf4200000-0xf42fffff] [ 5.403593] pcieport 0004:40:00.0: PME: Signaling with IRQ 125 [ 5.432597] Console: switching to colour frame buffer device 240x67 [ 5.574444] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device [ 5.574946] [drm] Initialized rockchip 3.0.0 20140818 for display-subsystem on minor 0 [ 5.582161] brd: module loaded [ 5.585669] loop: module loaded [ 5.585882] zram: Added device: zram0 [ 5.586033] lkdtm: No crash points registered, enable through debugfs [ 5.586205] system_heap: orders[0] = 6 [ 5.586208] system_heap: orders[1] = 4 [ 5.586210] system_heap: orders[2] = 0 [ 5.587245] nvme nvme0: pci function 0004:41:00.0 [ 5.587308] nvme 0004:41:00.0: enabling device (0000 -> 0002) [ 5.588911] rockchip-spi feb20000.spi: no high_speed pinctrl state [ 5.590465] rk806 spi2.0: chip id: RK806,ver:0x2, 0x1 [ 5.590601] rk806 spi2.0: ON: 0x40 OFF:0x0 [ 5.592512] rk806-regulator rk806-regulator.6.auto: Looking up vcc1-supply from device tree [ 5.592522] vdd_gpu_s0: supplied by vcc5v0_sys [ 5.592528] vcc5v0_sys: could not add device link regulator.8: -ENOENT [ 5.593274] vdd_gpu_s0: 550 <--> 950 mV at 750 mV, enabled [ 5.593674] rk806-regulator rk806-regulator.6.auto: Looking up vcc2-supply from device tree [ 5.593680] vdd_cpu_lit_s0: supplied by vcc5v0_sys [ 5.593686] vcc5v0_sys: could not add device link regulator.9: -ENOENT [ 5.593899] vdd_cpu_lit_s0: 550 <--> 950 mV at 750 mV, enabled [ 5.594482] rk806-regulator rk806-regulator.6.auto: Looking up vcc3-supply from device tree [ 5.594489] vdd_log_s0: supplied by vcc5v0_sys [ 5.594494] vcc5v0_sys: could not add device link regulator.10: -ENOENT [ 5.594712] vdd_log_s0: 675 <--> 750 mV at 750 mV, enabled [ 5.595190] rk806-regulator rk806-regulator.6.auto: Looking up vcc4-supply from device tree [ 5.595196] vdd_vdenc_s0: supplied by vcc5v0_sys [ 5.595201] vcc5v0_sys: could not add device link regulator.11: -ENOENT [ 5.595412] vdd_vdenc_s0: 550 <--> 950 mV at 750 mV, enabled [ 5.595919] rk806-regulator rk806-regulator.6.auto: Looking up vcc5-supply from device tree [ 5.595925] vdd_ddr_s0: supplied by vcc5v0_sys [ 5.595930] vcc5v0_sys: could not add device link regulator.12: -ENOENT [ 5.596141] vdd_ddr_s0: 675 <--> 900 mV at 850 mV, enabled [ 5.596342] rk806-regulator rk806-regulator.6.auto: Looking up vcc6-supply from device tree [ 5.596348] vdd2_ddr_s3: supplied by vcc5v0_sys [ 5.596353] vcc5v0_sys: could not add device link regulator.13: -ENOENT [ 5.596616] vdd2_ddr_s3: at 500 mV, enabled [ 5.596966] rk806-regulator rk806-regulator.6.auto: Looking up vcc7-supply from device tree [ 5.596972] vdd_2v0_pldo_s3: supplied by vcc5v0_sys [ 5.596977] vcc5v0_sys: could not add device link regulator.14: -ENOENT [ 5.597188] vdd_2v0_pldo_s3: 2000 mV, enabled [ 5.597526] rk806-regulator rk806-regulator.6.auto: Looking up vcc8-supply from device tree [ 5.597533] vcc_3v3_s3: supplied by vcc5v0_sys [ 5.597540] vcc5v0_sys: could not add device link regulator.15: -ENOENT [ 5.597758] vcc_3v3_s3: 3300 mV, enabled [ 5.598078] rk806-regulator rk806-regulator.6.auto: Looking up vcc9-supply from device tree [ 5.598084] vddq_ddr_s0: supplied by vcc5v0_sys [ 5.598089] vcc5v0_sys: could not add device link regulator.16: -ENOENT [ 5.598360] vddq_ddr_s0: at 500 mV, enabled [ 5.598700] rk806-regulator rk806-regulator.6.auto: Looking up vcc10-supply from device tree [ 5.598707] vcc_1v8_s3: supplied by vcc5v0_sys [ 5.598711] vcc5v0_sys: could not add device link regulator.17: -ENOENT [ 5.598922] vcc_1v8_s3: 1800 mV, enabled [ 5.599298] rk806-regulator rk806-regulator.6.auto: Looking up vcc13-supply from device tree [ 5.599373] vdd_0v75_s3: supplied by vcc_1v1_nldo_s3 [ 5.599378] vcc_1v1_nldo_s3: could not add device link regulator.18: -ENOENT [ 5.599600] vdd_0v75_s3: 750 mV, enabled [ 5.600047] rk806-regulator rk806-regulator.6.auto: Looking up vcc13-supply from device tree [ 5.600054] vdd_ddr_pll_s0: supplied by vcc_1v1_nldo_s3 [ 5.600059] vcc_1v1_nldo_s3: could not add device link regulator.19: -ENOENT [ 5.600293] vdd_ddr_pll_s0: 850 mV, enabled [ 5.600695] avdd_0v75_s0: Bringing 750000uV into 837500-837500uV [ 5.600828] avdd_0v75_s0: ramp_delay not set [ 5.600928] rk806-regulator rk806-regulator.6.auto: Looking up vcc13-supply from device tree [ 5.600935] avdd_0v75_s0: supplied by vcc_1v1_nldo_s3 [ 5.600940] vcc_1v1_nldo_s3: could not add device link regulator.20: -ENOENT [ 5.601151] avdd_0v75_s0: 837 mV, enabled [ 5.601548] rk806-regulator rk806-regulator.6.auto: Looking up vcc14-supply from device tree [ 5.601555] vdd_0v85_s0: supplied by vcc_1v1_nldo_s3 [ 5.601560] vcc_1v1_nldo_s3: could not add device link regulator.21: -ENOENT [ 5.601873] vdd_0v85_s0: 850 mV, enabled [ 5.602343] rk806-regulator rk806-regulator.6.auto: Looking up vcc14-supply from device tree [ 5.602350] vdd_0v75_s0: supplied by vcc_1v1_nldo_s3 [ 5.602355] vcc_1v1_nldo_s3: could not add device link regulator.22: -ENOENT [ 5.602666] vdd_0v75_s0: 750 mV, enabled [ 5.603194] rk806-regulator rk806-regulator.6.auto: Looking up vcc11-supply from device tree [ 5.603233] avcc_1v8_s0: supplied by vdd_2v0_pldo_s3 [ 5.603238] vdd_2v0_pldo_s3: could not add device link regulator.23: -ENOENT [ 5.603664] avcc_1v8_s0: 1800 mV, enabled [ 5.604109] rk806-regulator rk806-regulator.6.auto: Looking up vcc11-supply from device tree [ 5.604117] vcc_1v8_s0: supplied by vdd_2v0_pldo_s3 [ 5.604122] vdd_2v0_pldo_s3: could not add device link regulator.24: -ENOENT [ 5.604536] vcc_1v8_s0: 1800 mV, enabled [ 5.604890] rk806-regulator rk806-regulator.6.auto: Looking up vcc11-supply from device tree [ 5.604898] avdd_1v2_s0: supplied by vdd_2v0_pldo_s3 [ 5.604903] vdd_2v0_pldo_s3: could not add device link regulator.25: -ENOENT [ 5.605275] avdd_1v2_s0: 1200 mV, enabled [ 5.605602] rk806-regulator rk806-regulator.6.auto: Looking up vcc12-supply from device tree [ 5.605608] vcc_3v3_s0: supplied by vcc5v0_sys [ 5.605615] vcc5v0_sys: could not add device link regulator.26: -ENOENT [ 5.605830] vcc_3v3_s0: 3300 mV, enabled [ 5.606153] rk806-regulator rk806-regulator.6.auto: Looking up vcc12-supply from device tree [ 5.606159] vccio_sd_s0: supplied by vcc5v0_sys [ 5.606164] vcc5v0_sys: could not add device link regulator.27: -ENOENT [ 5.606372] vccio_sd_s0: 1800 <--> 3300 mV at 3300 mV, enabled [ 5.606719] rk806-regulator rk806-regulator.6.auto: Looking up vcca-supply from device tree [ 5.606725] pldo6_s3: supplied by vcc5v0_sys [ 5.606730] vcc5v0_sys: could not add device link regulator.28: -ENOENT [ 5.606939] pldo6_s3: 1800 mV, enabled [ 5.607279] rk806 spi2.0: no sleep-setting state [ 5.607283] rk806 spi2.0: no reset-setting pinctrl state [ 5.607286] rk806 spi2.0: no dvs-setting pinctrl state [ 5.609145] rockchip-spi feb20000.spi: register misc device rkspi-dev2 [ 5.609149] rockchip-spi feb20000.spi: probed, poll=0, rsd=0 [ 5.610576] spi-nor spi5.0: XM25QU128C (16384 Kbytes) read_data x4 [ 5.610594] 1 fixed-partitions partitions found on MTD device sfc_nor [ 5.610597] Creating 1 MTD partitions on "sfc_nor": [ 5.610601] 0x000000000000-0x000001000000 : "loader" [ 5.612644] rk_gmac-dwmac fe1c0000.ethernet: IRQ eth_lpi not found [ 5.612792] rk_gmac-dwmac fe1c0000.ethernet: Looking up phy-supply from device tree [ 5.612805] rk_gmac-dwmac fe1c0000.ethernet: Looking up phy-supply property in node /ethernet@fe1c0000 failed [ 5.612818] rk_gmac-dwmac fe1c0000.ethernet: no regulator found [ 5.612823] rk_gmac-dwmac fe1c0000.ethernet: clock input or output? (output). [ 5.612827] rk_gmac-dwmac fe1c0000.ethernet: TX delay(0x42). [ 5.612831] rk_gmac-dwmac fe1c0000.ethernet: Can not read property: rx_delay. [ 5.612834] rk_gmac-dwmac fe1c0000.ethernet: set rx_delay to 0xffffffff [ 5.612842] rk_gmac-dwmac fe1c0000.ethernet: integrated PHY? (no). [ 5.612848] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_rx [ 5.612852] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_tx [ 5.612866] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock clk_mac_speed [ 5.613087] rk_gmac-dwmac fe1c0000.ethernet: init for RGMII_RXID [ 5.613236] rk_gmac-dwmac fe1c0000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 5.613241] rk_gmac-dwmac fe1c0000.ethernet: DWMAC4/5 [ 5.613246] rk_gmac-dwmac fe1c0000.ethernet: DMA HW capability register supported [ 5.613250] rk_gmac-dwmac fe1c0000.ethernet: RX Checksum Offload Engine supported [ 5.613252] rk_gmac-dwmac fe1c0000.ethernet: TX Checksum insertion supported [ 5.613255] rk_gmac-dwmac fe1c0000.ethernet: Wake-Up On Lan supported [ 5.613288] rk_gmac-dwmac fe1c0000.ethernet: TSO supported [ 5.613291] rk_gmac-dwmac fe1c0000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 5.613296] rk_gmac-dwmac fe1c0000.ethernet: Enabled Flow TC (entries=2) [ 5.613299] rk_gmac-dwmac fe1c0000.ethernet: TSO feature enabled [ 5.613303] rk_gmac-dwmac fe1c0000.ethernet: Using 32 bits DMA width [ 5.616903] nvme nvme0: 7/0/0 default/read/poll queues [ 5.628718] GPT:Primary header thinks Alt. header is not at the end of the disk. [ 5.628724] GPT:15081471 != 976773167 [ 5.628727] GPT:Alternate GPT header not at the end of the disk. [ 5.628729] GPT:15081471 != 976773167 [ 5.628732] GPT: Use GNU Parted to correct GPT errors. [ 5.628748] nvme0n1: p1 p2 [ 5.753362] usbcore: registered new interface driver rndis_wlan [ 5.753382] usbcore: registered new interface driver asix [ 5.753397] usbcore: registered new interface driver cdc_ether [ 5.753413] usbcore: registered new interface driver rndis_host [ 5.753434] usbcore: registered new interface driver cdc_ncm [ 5.758812] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up usb-supply from device tree [ 5.758842] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up usb-supply property in node /power-management@fd8d8000/power-controller failed [ 5.760879] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 5.760889] ehci-pci: EHCI PCI platform driver [ 5.760919] ehci-platform: EHCI generic platform driver [ 5.763189] ehci-platform fc800000.usb: EHCI Host Controller [ 5.763202] ehci-platform fc800000.usb: new USB bus registered, assigned bus number 1 [ 5.763271] ehci-platform fc800000.usb: irq 20, io mem 0xfc800000 [ 5.774118] ehci-platform fc800000.usb: USB 2.0 started, EHCI 1.00 [ 5.774235] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 5.774239] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.774243] usb usb1: Product: EHCI Host Controller [ 5.774247] usb usb1: Manufacturer: Linux 5.10.160-rk35xx ehci_hcd [ 5.774250] usb usb1: SerialNumber: fc800000.usb [ 5.774490] hub 1-0:1.0: USB hub found [ 5.774507] hub 1-0:1.0: 1 port detected [ 5.776919] ehci-platform fc880000.usb: EHCI Host Controller [ 5.776929] ehci-platform fc880000.usb: new USB bus registered, assigned bus number 2 [ 5.776990] ehci-platform fc880000.usb: irq 22, io mem 0xfc880000 [ 5.787450] ehci-platform fc880000.usb: USB 2.0 started, EHCI 1.00 [ 5.787556] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 5.787561] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.787564] usb usb2: Product: EHCI Host Controller [ 5.787568] usb usb2: Manufacturer: Linux 5.10.160-rk35xx ehci_hcd [ 5.787571] usb usb2: SerialNumber: fc880000.usb [ 5.787786] hub 2-0:1.0: USB hub found [ 5.787803] hub 2-0:1.0: 1 port detected [ 5.788238] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 5.788248] ohci-platform: OHCI generic platform driver [ 5.788412] ohci-platform fc840000.usb: Generic Platform OHCI controller [ 5.788421] ohci-platform fc840000.usb: new USB bus registered, assigned bus number 3 [ 5.788475] ohci-platform fc840000.usb: irq 21, io mem 0xfc840000 [ 5.848216] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10 [ 5.848221] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.848225] usb usb3: Product: Generic Platform OHCI controller [ 5.848228] usb usb3: Manufacturer: Linux 5.10.160-rk35xx ohci_hcd [ 5.848231] usb usb3: SerialNumber: fc840000.usb [ 5.848442] hub 3-0:1.0: USB hub found [ 5.848460] hub 3-0:1.0: 1 port detected [ 5.848753] ohci-platform fc8c0000.usb: Generic Platform OHCI controller [ 5.848762] ohci-platform fc8c0000.usb: new USB bus registered, assigned bus number 4 [ 5.848813] ohci-platform fc8c0000.usb: irq 23, io mem 0xfc8c0000 [ 5.908209] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10 [ 5.908214] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.908217] usb usb4: Product: Generic Platform OHCI controller [ 5.908220] usb usb4: Manufacturer: Linux 5.10.160-rk35xx ohci_hcd [ 5.908223] usb usb4: SerialNumber: fc8c0000.usb [ 5.908431] hub 4-0:1.0: USB hub found [ 5.908449] hub 4-0:1.0: 1 port detected [ 5.909049] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 5.909059] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 5 [ 5.909138] xhci-hcd xhci-hcd.7.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000200002010010 [ 5.909162] xhci-hcd xhci-hcd.7.auto: irq 139, io mem 0xfcd00000 [ 5.909321] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 5.909325] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.909329] usb usb5: Product: xHCI Host Controller [ 5.909332] usb usb5: Manufacturer: Linux 5.10.160-rk35xx xhci-hcd [ 5.909335] usb usb5: SerialNumber: xhci-hcd.7.auto [ 5.909545] hub 5-0:1.0: USB hub found [ 5.909564] hub 5-0:1.0: 1 port detected [ 5.909719] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 5.909726] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 6 [ 5.909732] xhci-hcd xhci-hcd.7.auto: Host supports USB 3.0 SuperSpeed [ 5.909769] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM. [ 5.909839] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 [ 5.909843] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.909847] usb usb6: Product: xHCI Host Controller [ 5.909850] usb usb6: Manufacturer: Linux 5.10.160-rk35xx xhci-hcd [ 5.909853] usb usb6: SerialNumber: xhci-hcd.7.auto [ 5.910056] hub 6-0:1.0: USB hub found [ 5.910072] hub 6-0:1.0: 1 port detected [ 5.910286] usbcore: registered new interface driver cdc_acm [ 5.910290] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 5.910398] usbcore: registered new interface driver uas [ 5.910455] usbcore: registered new interface driver usb-storage [ 5.911093] Error: Driver 'Goodix-TS' is already registered, aborting... [ 5.911128] usbcore: registered new interface driver usbtouchscreen [ 5.912242] input: rk805 pwrkey as /devices/platform/feb20000.spi/spi_master/spi2/spi2.0/rk805-pwrkey.5.auto/input/input0 [ 5.912507] i2c /dev entries driver [ 5.916130] rk860-regulator 0-0042: Looking up vin-supply from device tree [ 5.916138] vdd_cpu_big0_s0: supplied by vcc5v0_sys [ 5.916145] vcc5v0_sys: could not add device link regulator.29: -ENOENT [ 5.920245] vdd_cpu_big0_s0: 550 <--> 1050 mV at 800 mV, enabled [ 5.924777] rk860-regulator 0-0043: Looking up vin-supply from device tree [ 5.924783] vdd_cpu_big1_s0: supplied by vcc5v0_sys [ 5.924789] vcc5v0_sys: could not add device link regulator.30: -ENOENT [ 5.928880] vdd_cpu_big1_s0: 550 <--> 1050 mV at 800 mV, enabled [ 5.931113] Goodix-TS 2-0014: Looking up AVDD28-supply from device tree [ 5.931122] Goodix-TS 2-0014: Looking up AVDD28-supply property in node /i2c@feaa0000/touchscreen@14 failed [ 5.931136] Goodix-TS 2-0014: supply AVDD28 not found, using dummy regulator [ 5.931192] Goodix-TS 2-0014: Looking up VDDIO-supply from device tree [ 5.931199] Goodix-TS 2-0014: Looking up VDDIO-supply property in node /i2c@feaa0000/touchscreen@14 failed [ 5.931208] Goodix-TS 2-0014: supply VDDIO not found, using dummy regulator [ 6.024258] Goodix-TS 2-0014: i2c test failed attempt 1: -6 [ 6.050918] Goodix-TS 2-0014: i2c test failed attempt 2: -6 [ 6.077441] Goodix-TS 2-0014: I2C communication failure: -6 [ 6.080619] rk860-regulator 2-0042: Looking up vin-supply from device tree [ 6.080626] vdd_npu_s0: supplied by vcc5v0_sys [ 6.080631] vcc5v0_sys: could not add device link regulator.31: -ENOENT [ 6.084711] vdd_npu_s0: 550 <--> 950 mV at 800 mV, enabled [ 6.087648] typec_fusb302 6-0022: Looking up vbus-supply from device tree [ 6.115146] rtc-hym8563 6-0051: rtc information is invalid [ 6.121992] rtc-hym8563 6-0051: registered as rtc0 [ 6.123003] rtc-hym8563 6-0051: setting system clock to 2021-01-01T12:00:00 UTC (1609502400) [ 6.125676] Goodix-TS 7-0014: Looking up AVDD28-supply from device tree [ 6.125686] Goodix-TS 7-0014: Looking up AVDD28-supply property in node /i2c@fec90000/touchscreen@14 failed [ 6.125701] Goodix-TS 7-0014: supply AVDD28 not found, using dummy regulator [ 6.125766] Goodix-TS 7-0014: Looking up VDDIO-supply from device tree [ 6.125773] Goodix-TS 7-0014: Looking up VDDIO-supply property in node /i2c@fec90000/touchscreen@14 failed [ 6.125782] Goodix-TS 7-0014: supply VDDIO not found, using dummy regulator [ 6.217593] Goodix-TS 7-0014: i2c test failed attempt 1: -6 [ 6.244254] Goodix-TS 7-0014: i2c test failed attempt 2: -6 [ 6.270774] Goodix-TS 7-0014: I2C communication failure: -6 [ 6.271753] rkcifhw fdce0000.rkcif: Adding to iommu group 16 [ 6.272127] rkcifhw fdce0000.rkcif: No reserved memory region assign to CIF [ 6.273296] rkisp_hw fdcb0000.rkisp: Adding to iommu group 14 [ 6.273403] rkisp_hw fdcb0000.rkisp: is_thunderboot: 0 [ 6.273407] rkisp_hw fdcb0000.rkisp: max input:0x0@0fps [ 6.273411] rkisp_hw fdcb0000.rkisp: Missing rockchip,grf property [ 6.273514] rkisp_hw fdcb0000.rkisp: no find phandle sram [ 6.273581] rkisp_hw fdcc0000.rkisp: Adding to iommu group 15 [ 6.273730] rkisp_hw fdcc0000.rkisp: is_thunderboot: 0 [ 6.273734] rkisp_hw fdcc0000.rkisp: max input:0x0@0fps [ 6.273737] rkisp_hw fdcc0000.rkisp: Missing rockchip,grf property [ 6.273829] rkisp_hw fdcc0000.rkisp: no find phandle sram [ 6.274797] usbcore: registered new interface driver uvcvideo [ 6.274799] USB Video Class driver (1.1.1) [ 6.276199] cpu cpu0: Looking up cpu-supply from device tree [ 6.277146] cpu cpu0: bin=0 [ 6.277347] cpu cpu0: leakage=8 [ 6.277394] cpu cpu0: Looking up cpu-supply from device tree [ 6.279059] cpu cpu0: pvtm=1379 [ 6.279321] cpu cpu0: pvtm-volt-sel=0 [ 6.279392] cpu cpu0: Looking up cpu-supply from device tree [ 6.279668] cpu cpu0: Looking up mem-supply from device tree [ 6.280046] cpu cpu4: Looking up cpu-supply from device tree [ 6.282094] cpu cpu4: bin=0 [ 6.282355] cpu cpu4: leakage=6 [ 6.282398] cpu cpu4: Looking up cpu-supply from device tree [ 6.289205] cpu cpu4: pvtm=1588 [ 6.293386] cpu cpu4: pvtm-volt-sel=0 [ 6.293478] cpu cpu4: Looking up cpu-supply from device tree [ 6.294139] cpu cpu4: Looking up mem-supply from device tree [ 6.294831] cpu cpu6: Looking up cpu-supply from device tree [ 6.296773] cpu cpu6: bin=0 [ 6.296963] cpu cpu6: leakage=6 [ 6.297003] cpu cpu6: Looking up cpu-supply from device tree [ 6.303793] cpu cpu6: pvtm=1589 [ 6.307981] cpu cpu6: pvtm-volt-sel=0 [ 6.308072] cpu cpu6: Looking up cpu-supply from device tree [ 6.308698] cpu cpu6: Looking up mem-supply from device tree [ 6.311065] cpu cpu0: avs=0 [ 6.313105] cpu cpu4: avs=0 [ 6.315165] cpu cpu6: avs=0 [ 6.315565] cpu cpu0: EM: OPP:816000 is inefficient [ 6.315574] cpu cpu0: EM: OPP:600000 is inefficient [ 6.315821] cpu cpu0: EM: created perf domain [ 6.315900] cpu cpu0: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=1608000000 h_table=0 [ 6.317085] cpu cpu4: EM: OPP:816000 is inefficient [ 6.317092] cpu cpu4: EM: OPP:600000 is inefficient [ 6.317288] cpu cpu4: EM: created perf domain [ 6.317329] cpu cpu4: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0 [ 6.326039] cpu cpu6: EM: OPP:816000 is inefficient [ 6.326045] cpu cpu6: EM: OPP:600000 is inefficient [ 6.326252] cpu cpu6: EM: created perf domain [ 6.326852] cpu cpu6: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0 [ 6.327467] usb 3-1: new full-speed USB device number 2 using ohci-platform [ 6.342514] sdhci: Secure Digital Host Controller Interface driver [ 6.342522] sdhci: Copyright(c) Pierre Ossman [ 6.342528] Synopsys Designware Multimedia Card Interface Driver [ 6.343452] sdhci-pltfm: SDHCI platform and OF driver helper [ 6.346853] ledtrig-cpu: registered to indicate activity on CPUs [ 6.346887] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active. [ 6.346942] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 6.347797] cryptodev: driver 1.12 loaded. [ 6.347840] hid: raw HID events driver (C) Jiri Kosina [ 6.348021] usbcore: registered new interface driver usbhid [ 6.348025] usbhid: USB HID core driver [ 6.348348] ashmem: initialized [ 6.352593] rockchip-saradc fec10000.saradc: Looking up vref-supply from device tree [ 6.354003] optee: probing for conduit method. [ 6.354011] optee: api uid mismatch [ 6.354023] optee: probe of firmware:optee failed with error -22 [ 6.355184] usbcore: registered new interface driver snd-usb-audio [ 6.361989] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up audio-supply from device tree [ 6.362032] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up audio-supply property in node /power-management@fd8d8000/power-controller failed [ 6.366244] debugfs: File 'Capture' in directory 'dapm' already present! [ 6.367967] input: rockchip-dp0 rockchip-dp0 as /devices/platform/dp0-sound/sound/card0/input1 [ 6.370025] input: rockchip-hdmi0 rockchip-hdmi0 as /devices/platform/hdmi0-sound/sound/card1/input2 [ 6.371763] input: headset-keys as /devices/platform/es8388-sound/input/input3 [ 6.383153] ES8323 6-0010: ASoC: error at soc_component_write_no_lock on ES8323.6-0010: -5 [ 6.440546] input: rockchip-es8388 Headset as /devices/platform/es8388-sound/sound/card2/input4 [ 6.441308] Initializing XFRM netlink socket [ 6.441321] NET: Registered protocol family 17 [ 6.441566] [BT_RFKILL]: Enter rfkill_rk_init [ 6.441570] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 6.441965] Key type dns_resolver registered [ 6.443184] registered taskstats version 1 [ 6.443192] Loading compiled-in X.509 certificates [ 6.443963] Btrfs loaded, crc32c=crc32c-generic [ 6.444078] pstore: Using crash dump compression: deflate [ 6.444329] rga3_core0 fdb60000.rga: Adding to iommu group 2 [ 6.444518] rga: rga3_core0, irq = 35, match scheduler [ 6.444822] rga: rga3_core0 hardware loaded successfully, hw_version:3.0.76831. [ 6.444868] rga: rga3_core0 probe successfully [ 6.445175] rga3_core1 fdb70000.rga: Adding to iommu group 3 [ 6.445338] rga: rga3_core1, irq = 36, match scheduler [ 6.445642] rga: rga3_core1 hardware loaded successfully, hw_version:3.0.76831. [ 6.445689] rga: rga3_core1 probe successfully [ 6.446017] rga: rga2, irq = 37, match scheduler [ 6.446315] rga: rga2 hardware loaded successfully, hw_version:3.2.63318. [ 6.446323] rga: rga2 probe successfully [ 6.446522] rga_iommu: IOMMU binding successfully, default mapping core[0x1] [ 6.446718] rga: Module initialized. v1.2.25 [ 6.499039] reg-fixed-voltage combophy-avdd0v85: Looking up vin-supply from device tree [ 6.499213] combophy_avdd0v85: supplied by vdd_0v85_s0 [ 6.499222] vdd_0v85_s0: could not add device link regulator.32: -ENOENT [ 6.499243] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up gpu-supply from device tree [ 6.499320] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up gpu-supply property in node /power-management@fd8d8000/power-controller failed [ 6.499519] mali fb000000.gpu: Kernel DDK version g17p0-01eac0 [ 6.499645] mali fb000000.gpu: Looking up mali-supply from device tree [ 6.499891] mali fb000000.gpu: Looking up mem-supply from device tree [ 6.499917] combophy_avdd0v85: 850 mV, enabled [ 6.500014] mali fb000000.gpu: Looking up mali-supply from device tree [ 6.500039] vdd_gpu_s0: could not add device link fb000000.gpu: -EEXIST [ 6.500046] vdd_gpu_s0: Failed to create debugfs directory [ 6.500055] mali fb000000.gpu: Looking up mem-supply from device tree [ 6.500075] vdd_gpu_s0: could not add device link fb000000.gpu: -EEXIST [ 6.500081] vdd_gpu_s0: Failed to create debugfs directory [ 6.500236] mali fb000000.gpu: Looking up mali-supply from device tree [ 6.500266] vdd_gpu_s0: could not add device link fb000000.gpu: -EEXIST [ 6.500272] vdd_gpu_s0: Failed to create debugfs directory [ 6.500341] reg-fixed-voltage combophy-avdd0v85: combophy_avdd0v85 supplying 850000uV [ 6.500567] mali fb000000.gpu: bin=0 [ 6.500643] reg-fixed-voltage combophy-avdd1v8: Looking up vin-supply from device tree [ 6.500815] mali fb000000.gpu: leakage=13 [ 6.500851] combophy_avdd1v8: supplied by avcc_1v8_s0 [ 6.500868] avcc_1v8_s0: could not add device link regulator.33: -ENOENT [ 6.500872] mali fb000000.gpu: Looking up mali-supply from device tree [ 6.500898] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present! [ 6.501693] combophy_avdd1v8: 1800 mV, enabled [ 6.501999] reg-fixed-voltage combophy-avdd1v8: combophy_avdd1v8 supplying 1800000uV [ 6.502266] vcc_3v3_sd_s0: 3300 mV, disabled [ 6.502464] reg-fixed-voltage vcc-3v3-sd-s0: Looking up vin-supply from device tree [ 6.502484] vcc_3v3_sd_s0: supplied by vcc_3v3_s3 [ 6.502824] reg-fixed-voltage vcc-3v3-sd-s0: vcc_3v3_sd_s0 supplying 3300000uV [ 6.503057] mali fb000000.gpu: pvtm=847 [ 6.503563] mali fb000000.gpu: pvtm-volt-sel=2 [ 6.504166] rockchip-dmc dmc: Looking up center-supply from device tree [ 6.504748] rockchip-dmc dmc: Looking up mem-supply from device tree [ 6.505019] mali fb000000.gpu: avs=0 [ 6.505151] rockchip-dmc dmc: Looking up center-supply from device tree [ 6.505188] vdd_ddr_s0: could not add device link dmc: -EEXIST [ 6.505196] vdd_ddr_s0: Failed to create debugfs directory [ 6.505383] rockchip-dmc dmc: Looking up mem-supply from device tree [ 6.505418] vdd_log_s0: could not add device link dmc: -EEXIST [ 6.505426] vdd_log_s0: Failed to create debugfs directory [ 6.505445] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 143; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available. [ 6.505926] rockchip-dmc dmc: leakage=30 [ 6.505949] rockchip-dmc dmc: leakage-volt-sel=0 [ 6.506563] mali fb000000.gpu: GPU hardware issue table may need updating: r0p0 status 5 is unknown; treating as r0p0 status 0 [ 6.506580] mali fb000000.gpu: GPU identified as 0x7 arch 10.8.6 r0p0 status 0 [ 6.506667] mali fb000000.gpu: No priority control manager is configured [ 6.506845] rockchip-dmc dmc: avs=0 [ 6.506873] rockchip-dmc dmc: current ATF version 0x100 [ 6.507074] rockchip-dmc dmc: normal_rate = 1560000000 [ 6.507087] rockchip-dmc dmc: reboot_rate = 2112000000 [ 6.507097] rockchip-dmc dmc: suspend_rate = 528000000 [ 6.507107] rockchip-dmc dmc: video_4k_rate = 1560000000 [ 6.507117] rockchip-dmc dmc: video_4k_10b_rate = 1560000000 [ 6.507131] mali fb000000.gpu: No memory group manager is configured [ 6.507136] rockchip-dmc dmc: video_svep_rate = 1560000000 [ 6.507145] rockchip-dmc dmc: boost_rate = 2112000000 [ 6.507156] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 2112000000 [ 6.507166] rockchip-dmc dmc: performance_rate = 2112000000 [ 6.507177] rockchip-dmc dmc: hdmirx_rate = 2112000000 [ 6.507182] mali fb000000.gpu: Protected memory allocator not available [ 6.507203] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate [ 6.507212] rockchip-dmc dmc: failed to get vop pn to msch rl [ 6.507493] rockchip-dmc dmc: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0 [ 6.508107] rockchip-dmc dmc: could not find power_model node [ 6.508445] mali fb000000.gpu: Capping CSF_FIRMWARE_TIMEOUT to CSF_FIRMWARE_PING_TIMEOUT [ 6.509680] mali fb000000.gpu: Couldn't find power_model DT node matching 'arm,mali-simple-power-model' [ 6.509698] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.static-coefficient = 1*[0] [ 6.510065] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.dynamic-coefficient = 1*[0] [ 6.510416] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.ts = 4*[0] [ 6.510815] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.thermal-zone = '' [ 6.516279] mali fb000000.gpu: Using configured power model mali-lodx-power-model, and fallback mali-simple-power-model [ 6.516491] input: adc-keys as /devices/platform/adc-keys/input/input5 [ 6.516528] mali fb000000.gpu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0 [ 6.518058] mali fb000000.gpu: Probed as mali0 [ 6.518350] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode. [ 6.518388] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller. [ 6.518396] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a [ 6.518433] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 90,32 bit host data width,256 deep fifo [ 6.518509] dwmmc_rockchip fe2c0000.mmc: Looking up vmmc-supply from device tree [ 6.518667] dwmmc_rockchip fe2c0000.mmc: Looking up vqmmc-supply from device tree [ 6.519354] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up sdio-supply from device tree [ 6.519390] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up sdio-supply property in node /power-management@fd8d8000/power-controller failed [ 6.519431] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up pcie-supply from device tree [ 6.519458] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up pcie-supply property in node /power-management@fd8d8000/power-controller failed [ 6.519496] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu-supply from device tree [ 6.519523] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu-supply property in node /power-management@fd8d8000/power-controller failed [ 6.521671] RKNPU fdab0000.npu: Adding to iommu group 0 [ 6.521799] RKNPU fdab0000.npu: RKNPU: rknpu iommu is enabled, using iommu mode [ 6.521880] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 6.522565] RKNPU fdab0000.npu: Looking up mem-supply from device tree [ 6.523197] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff] [ 6.523217] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff] [ 6.523227] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff] [ 6.523691] [drm] Initialized rknpu 0.8.5 20230202 for fdab0000.npu on minor 1 [ 6.524003] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up nputop-supply from device tree [ 6.524031] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up nputop-supply property in node /power-management@fd8d8000/power-controller failed [ 6.524133] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu1-supply from device tree [ 6.524156] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu1-supply property in node /power-management@fd8d8000/power-controller failed [ 6.524214] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu2-supply from device tree [ 6.524235] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu2-supply property in node /power-management@fd8d8000/power-controller failed [ 6.524373] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 6.524394] vdd_npu_s0: could not add device link fdab0000.npu: -EEXIST [ 6.524397] vdd_npu_s0: Failed to create debugfs directory [ 6.524954] RKNPU fdab0000.npu: Looking up mem-supply from device tree [ 6.524994] vdd_npu_s0: could not add device link fdab0000.npu: -EEXIST [ 6.524998] vdd_npu_s0: Failed to create debugfs directory [ 6.525715] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 6.525746] vdd_npu_s0: could not add device link fdab0000.npu: -EEXIST [ 6.525749] vdd_npu_s0: Failed to create debugfs directory [ 6.527731] RKNPU fdab0000.npu: RKNPU: bin=0 [ 6.527907] RKNPU fdab0000.npu: leakage=7 [ 6.527944] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 6.527973] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present! [ 6.535946] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 6.536697] RKNPU fdab0000.npu: pvtm=846 [ 6.542261] RKNPU fdab0000.npu: pvtm-volt-sel=2 [ 6.543375] RKNPU fdab0000.npu: avs=0 [ 6.543603] RKNPU fdab0000.npu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0 [ 6.543936] usb 3-1: New USB device found, idVendor=046d, idProduct=c539, bcdDevice=39.06 [ 6.543944] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 6.543951] usb 3-1: Product: USB Receiver [ 6.543956] usb 3-1: Manufacturer: Logitech [ 6.552769] input: Logitech USB Receiver as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.0/0003:046D:C539.0001/input/input6 [ 6.554987] RKNPU fdab0000.npu: failed to find power_model node [ 6.554995] RKNPU fdab0000.npu: RKNPU: failed to initialize power model [ 6.555000] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient [ 6.556446] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 6.566305] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 6.568052] rockchip-pm rockchip-suspend: not set pwm-regulator-config [ 6.568066] rockchip-suspend not set sleep-mode-config for mem-lite [ 6.568070] rockchip-suspend not set wakeup-config for mem-lite [ 6.568076] rockchip-suspend not set sleep-mode-config for mem-ultra [ 6.568080] rockchip-suspend not set wakeup-config for mem-ultra [ 6.569503] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 406; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '13:36:29', on 'Jul 6 2023'. [ 6.569858] Mali: [ 6.569861] Mali device driver loaded [ 6.569871] ALSA device list: [ 6.569876] #0: rockchip-dp0 [ 6.569880] #1: rockchip-hdmi0 [ 6.569883] #2: rockchip-es8388 [ 6.573999] Freeing unused kernel memory: 6976K [ 6.608702] Run /init as init process [ 6.608714] with arguments: [ 6.608721] /init [ 6.608728] splash [ 6.608735] with environment: [ 6.608741] HOME=/ [ 6.608748] TERM=linux [ 6.608754] ubootpart= [ 6.608761] cgroup_enable=memory [ 6.608773] cgroup_memory=1 [ 6.609136] hid-generic 0003:046D:C539.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-fc840000.usb-1/input0 [ 6.615817] input: Logitech USB Receiver Mouse as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input7 [ 6.671217] input: Logitech USB Receiver Consumer Control as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input8 [ 6.671531] input: Logitech USB Receiver System Control as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input9 [ 6.671991] hid-generic 0003:046D:C539.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-fc840000.usb-1/input1 [ 6.678446] hid-generic 0003:046D:C539.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-fc840000.usb-1/input2 [ 7.604950] EXT4-fs (nvme0n1p2): mounted filesystem with writeback data mode. Opts: (null) [ 7.802072] systemd[1]: System time before build time, advancing clock. [ 7.826970] NET: Registered protocol family 10 [ 7.828850] Segment Routing with IPv6 [ 7.845146] systemd[1]: systemd 249.11-0ubuntu3.9 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified) [ 7.846248] systemd[1]: Detected architecture arm64. [ 7.846506] systemd[1]: Detected first boot. [ 7.847196] systemd[1]: Hostname set to . [ 7.848061] systemd[1]: Initializing machine ID from random generator. [ 8.381312] systemd[1]: Failed to populate /etc with preset unit settings, ignoring: Read-only file system [ 8.444035] systemd[1]: Queued start job for default target Graphical Interface. [ 8.445688] systemd[1]: Created slice Slice /system/modprobe. [ 8.446224] systemd[1]: Created slice Slice /system/serial-getty. [ 8.446657] systemd[1]: Created slice Slice /system/systemd-fsck. [ 8.446912] systemd[1]: Created slice User and Session Slice. [ 8.447019] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 8.447315] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 8.447423] systemd[1]: Reached target User and Group Name Lookups. [ 8.447484] systemd[1]: Reached target Slice Units. [ 8.447518] systemd[1]: Reached target Swaps. [ 8.447545] systemd[1]: Reached target System Time Set. [ 8.447607] systemd[1]: Reached target Local Verity Protected Volumes. [ 8.455103] systemd[1]: Listening on RPCbind Server Activation Socket. [ 8.455339] systemd[1]: Listening on Syslog Socket. [ 8.455486] systemd[1]: Listening on fsck to fsckd communication Socket. [ 8.455584] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 8.455841] systemd[1]: Listening on Journal Audit Socket. [ 8.455966] systemd[1]: Listening on Journal Socket (/dev/log). [ 8.456141] systemd[1]: Listening on Journal Socket. [ 8.457048] systemd[1]: Listening on udev Control Socket. [ 8.457198] systemd[1]: Listening on udev Kernel Socket. [ 8.458339] systemd[1]: Mounting Huge Pages File System... [ 8.459443] systemd[1]: Mounting POSIX Message Queue File System... [ 8.460600] systemd[1]: Mounting Kernel Debug File System... [ 8.461922] systemd[1]: Mounting Kernel Trace File System... [ 8.462265] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped. [ 8.463925] systemd[1]: Starting Restore / save the current clock... [ 8.465629] systemd[1]: Starting Set the console keyboard layout... [ 8.467111] systemd[1]: Starting Create List of Static Device Nodes... [ 8.468749] systemd[1]: Starting Load Kernel Module chromeos_pstore... [ 8.470558] systemd[1]: Starting Load Kernel Module configfs... [ 8.472462] systemd[1]: Starting Load Kernel Module drm... [ 8.474578] systemd[1]: Starting Load Kernel Module efi_pstore... [ 8.476634] systemd[1]: Starting Load Kernel Module fuse... [ 8.478741] systemd[1]: Starting Load Kernel Module pstore_blk... [ 8.480657] systemd[1]: Starting Load Kernel Module pstore_zone... [ 8.482468] fuse: init (API version 7.32) [ 8.482529] systemd[1]: Starting Load Kernel Module ramoops... [ 8.484598] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 8.486938] systemd[1]: Starting Load Kernel Modules... [ 8.488579] systemd[1]: Starting Remount Root and Kernel File Systems... [ 8.490151] systemd[1]: Starting Coldplug All udev Devices... [ 8.493808] systemd[1]: Mounted Huge Pages File System. [ 8.494128] systemd[1]: Mounted POSIX Message Queue File System. [ 8.494326] systemd[1]: Mounted Kernel Debug File System. [ 8.494513] systemd[1]: Mounted Kernel Trace File System. [ 8.495000] systemd[1]: Finished Restore / save the current clock. [ 8.495574] systemd[1]: Finished Create List of Static Device Nodes. [ 8.495957] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully. [ 8.496265] systemd[1]: Finished Load Kernel Module chromeos_pstore. [ 8.496623] systemd[1]: modprobe@configfs.service: Deactivated successfully. [ 8.496893] systemd[1]: Finished Load Kernel Module configfs. [ 8.497207] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 8.497677] systemd[1]: Finished Load Kernel Module drm. [ 8.498001] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [ 8.498260] systemd[1]: Finished Load Kernel Module efi_pstore. [ 8.498574] systemd[1]: modprobe@fuse.service: Deactivated successfully. [ 8.498837] systemd[1]: Finished Load Kernel Module fuse. [ 8.499139] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully. [ 8.499420] systemd[1]: Finished Load Kernel Module pstore_blk. [ 8.499731] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully. [ 8.499994] systemd[1]: Finished Load Kernel Module pstore_zone. [ 8.500304] systemd[1]: modprobe@ramoops.service: Deactivated successfully. [ 8.500554] systemd[1]: Finished Load Kernel Module ramoops. [ 8.500998] systemd[1]: Finished Load Kernel Modules. [ 8.502672] systemd[1]: Mounting FUSE Control File System... [ 8.503954] systemd[1]: Mounting Kernel Configuration File System... [ 8.505475] systemd[1]: Starting Apply Kernel Variables... [ 8.507076] systemd[1]: Mounted FUSE Control File System. [ 8.508523] EXT4-fs (nvme0n1p2): re-mounted. Opts: commit=600,errors=remount-ro [ 8.509765] systemd[1]: Mounted Kernel Configuration File System. [ 8.510409] systemd[1]: Finished Remount Root and Kernel File Systems. [ 8.510658] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 8.512126] systemd[1]: Starting Load/Save Random Seed... [ 8.513773] systemd[1]: Starting Create System Users... [ 8.526472] systemd[1]: Finished Create System Users. [ 8.527951] systemd[1]: Starting Create Static Device Nodes in /dev... [ 8.529170] systemd[1]: Finished Load/Save Random Seed. [ 8.529460] systemd[1]: Reached target First Boot Complete. [ 8.535051] systemd[1]: Finished Set the console keyboard layout. [ 8.536589] systemd[1]: Finished Apply Kernel Variables. [ 8.547234] systemd[1]: Finished Create Static Device Nodes in /dev. [ 8.547423] systemd[1]: Reached target Preparation for Local File Systems. [ 8.548517] systemd[1]: Mounting /tmp... [ 8.550139] systemd[1]: Starting Rule-based Manager for Device Events and Files... [ 8.553550] systemd[1]: Mounted /tmp. [ 8.595068] systemd[1]: Started Rule-based Manager for Device Events and Files. [ 8.684042] systemd[1]: Created slice Slice /system/systemd-backlight. [ 8.685919] systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:backlight... [ 8.698184] systemd[1]: Finished Coldplug All udev Devices. [ 8.699729] systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:backlight. [ 8.703086] systemd[1]: Starting Helper to synchronize boot up for ifupdown... [ 8.706273] systemd[1]: Starting Show Plymouth Boot Screen... [ 8.709228] systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:backlight_1... [ 8.710839] systemd[1]: Finished Helper to synchronize boot up for ifupdown. [ 8.716289] systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:backlight_1. [ 8.727892] systemd[1]: Started Show Plymouth Boot Screen. [ 8.728389] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 8.728870] systemd[1]: Started Forward Password Requests to Plymouth Directory Watch. [ 8.729025] systemd[1]: Reached target Local Encrypted Volumes. [ 8.756168] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 8.757488] systemd[1]: Starting Load Kernel Module chromeos_pstore... [ 8.758847] systemd[1]: Starting Load Kernel Module efi_pstore... [ 8.760028] systemd[1]: Starting Load Kernel Module pstore_blk... [ 8.761479] systemd[1]: Starting Load Kernel Module pstore_zone... [ 8.762735] systemd[1]: Starting Load Kernel Module ramoops... [ 8.762842] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 8.763369] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [ 8.763637] systemd[1]: Finished Load Kernel Module efi_pstore. [ 8.764024] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully. [ 8.764282] systemd[1]: Finished Load Kernel Module pstore_blk. [ 8.767022] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully. [ 8.767359] systemd[1]: Finished Load Kernel Module pstore_zone. [ 8.767734] systemd[1]: modprobe@ramoops.service: Deactivated successfully. [ 8.768053] systemd[1]: Finished Load Kernel Module ramoops. [ 8.772092] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully. [ 8.772414] systemd[1]: Finished Load Kernel Module chromeos_pstore. [ 8.772596] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 8.783456] systemd[1]: Found device Samsung SSD 960 EVO 500GB armbi_boot. [ 8.785183] systemd[1]: Starting File System Check on /dev/disk/by-uuid/1BD1-7F33... [ 8.786095] systemd[1]: Found device /dev/ttyFIQ0. [ 8.792362] systemd[1]: Started File System Check Daemon to report status. [ 8.798418] systemd[1]: Reached target Hardware activated USB gadget. [ 8.807116] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 8.808509] systemd[1]: Starting Load Kernel Module chromeos_pstore... [ 8.809680] systemd[1]: Starting Load Kernel Module efi_pstore... [ 8.810900] systemd[1]: Starting Load Kernel Module pstore_blk... [ 8.812118] systemd[1]: Starting Load Kernel Module pstore_zone... [ 8.813243] systemd[1]: Starting Load Kernel Module ramoops... [ 8.813360] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 8.813719] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully. [ 8.814013] systemd[1]: Finished Load Kernel Module chromeos_pstore. [ 8.814984] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [ 8.815251] systemd[1]: Finished Load Kernel Module efi_pstore. [ 8.815605] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully. [ 8.815850] systemd[1]: Finished Load Kernel Module pstore_zone. [ 8.816146] systemd[1]: modprobe@ramoops.service: Deactivated successfully. [ 8.816380] systemd[1]: Finished Load Kernel Module ramoops. [ 8.816664] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully. [ 8.816909] systemd[1]: Finished Load Kernel Module pstore_blk. [ 8.817154] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 8.829663] systemd[1]: Finished File System Check on /dev/disk/by-uuid/1BD1-7F33. [ 8.831251] systemd[1]: Mounting /boot... [ 8.832988] FAT-fs (nvme0n1p1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive! [ 8.837919] systemd[1]: Mounted /boot. [ 8.838329] systemd[1]: Reached target Local File Systems. [ 8.841550] systemd[1]: Starting Armbian leds state... [ 8.846017] systemd[1]: Starting Armbian ZRAM config... [ 8.852332] systemd[1]: Starting Set console font and keymap... [ 8.855528] systemd[1]: Starting Raise network interfaces... [ 8.858717] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data... [ 8.858977] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped. [ 8.859902] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. [ 8.859957] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 8.861206] systemd[1]: Starting Commit a transient machine-id on disk... [ 8.861904] systemd[1]: Finished Armbian leds state. [ 8.863871] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 8.869726] systemd[1]: Received SIGRTMIN+20 from PID 292 (plymouthd). [ 8.870867] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data. [ 8.904373] systemd[1]: Finished Commit a transient machine-id on disk. [ 8.938365] zram0: detected capacity change from 0 to 4031107072 [ 8.974173] Adding 3936624k swap on /dev/zram0. Priority:5 extents:1 across:3936624k SS [ 8.983582] zram: Added device: zram1 [ 9.001550] systemd[1]: Finished Raise network interfaces. [ 9.056193] zram1: detected capacity change from 0 to 52428800 [ 9.077510] systemd[1]: Finished Armbian ZRAM config. [ 9.080761] systemd[1]: Starting Armbian memory supported logging... [ 9.113585] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard [ 9.498131] systemd[1]: etc-machine\x2did.mount: Deactivated successfully. [ 9.540873] vendor storage:20190527 ret = -1 [ 9.795552] systemd[1]: Finished Set console font and keymap. [ 10.502150] systemd[1]: Finished Armbian memory supported logging. [ 10.510921] systemd[1]: Starting Journal Service... [ 10.651424] systemd[1]: Started Journal Service. [ 10.672170] systemd-journald[907]: Received client request to flush runtime journal. ### armbian-release: # PLEASE DO NOT EDIT THIS FILE BOARD=orangepi5 BOARD_NAME="Orange Pi 5" BOARDFAMILY=rockchip-rk3588 BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=bfc8271 VERSION=23.08.0-trunk LINUXFAMILY=rk35xx ARCH=arm64 IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm64 KERNEL_IMAGE_TYPE=Image FORCE_BOOTSCRIPT_UPDATE= VENDOR=Armbian REVISION=23.08.0-trunk BOOTSCRIPT_FORCE_UPDATE="no" BOOTSCRIPT_DST="boot.cmd" ### boot environment: verbosity=1 bootlogo=true overlay_prefix=rockchip-rk3588 fdtfile=rockchip/rk3588s-orangepi-5.dtb rootdev=UUID=329a3cf7-a8ce-4ea6-a3ef-c2128bda1678 rootfstype=ext4 ### lsusb: Thu Jul 6 08:17:45 PM UTC 2023 | Orange Pi 5 | 23.08.0-trunk | arm64 | aarch64 | 5.10.160-rk35xx Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 002: ID 046d:c539 Logitech, Inc. USB Receiver Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub ### lscpu: Architecture: aarch64 CPU op-mode(s): 32-bit, 64-bit Byte Order: Little Endian CPU(s): 8 On-line CPU(s) list: 0-7 Vendor ID: ARM Model name: Cortex-A55 Model: 0 Thread(s) per core: 1 Core(s) per socket: 4 Socket(s): 1 Stepping: r2p0 CPU max MHz: 1800.0000 CPU min MHz: 408.0000 BogoMIPS: 48.00 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp Model name: Cortex-A76 Model: 0 Thread(s) per core: 1 Core(s) per socket: 2 Socket(s): 2 Stepping: r4p0 CPU max MHz: 2256.0000 CPU min MHz: 408.0000 BogoMIPS: 48.00 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp L1d cache: 384 KiB (8 instances) L1i cache: 384 KiB (8 instances) L2 cache: 2.5 MiB (8 instances) L3 cache: 3 MiB (1 instance) Vulnerability Itlb multihit: Not affected Vulnerability L1tf: Not affected Vulnerability Mds: Not affected Vulnerability Meltdown: Not affected Vulnerability Mmio stale data: Not affected Vulnerability Retbleed: Not affected Vulnerability Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl Vulnerability Spectre v1: Mitigation; __user pointer sanitization Vulnerability Spectre v2: Vulnerable: Unprivileged eBPF enabled Vulnerability Srbds: Not affected Vulnerability Tsx async abort: Not affected ### cpuinfo: processor : 0 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 1 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 2 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 3 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 4 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 processor : 5 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 processor : 6 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 processor : 7 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 Serial : 2eae2cb9d903d20e ### meminfo: ### [resize2fs] Trying to resize partition /dev/nvme0n1p2: MemTotal: 7873256 kB MemFree: 7563552 kB MemAvailable: 7586232 kB Buffers: 12608 kB Cached: 83100 kB SwapCached: 0 kB Active: 25652 kB Inactive: 106772 kB Active(anon): 592 kB Inactive(anon): 66104 kB Active(file): 25060 kB Inactive(file): 40668 kB Unevictable: 19608 kB Mlocked: 0 kB SwapTotal: 3936624 kB SwapFree: 3936624 kB Dirty: 1308 kB Writeback: 0 kB AnonPages: 57156 kB Mapped: 29388 kB Shmem: 25788 kB KReclaimable: 37336 kB Slab: 78648 kB SReclaimable: 37336 kB SUnreclaim: 41312 kB KernelStack: 3936 kB PageTables: 3508 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 7873252 kB Committed_AS: 130336 kB VmallocTotal: 135290290112 kB VmallocUsed: 36924 kB VmallocChunk: 0 kB Percpu: 2848 kB CmaTotal: 262144 kB CmaAllocated: 4672 kB CmaReleased: 257472 kB CmaFree: 257472 kB HugePages_Total: 0 HugePages_Free: 0 HugePages_Rsvd: 0 HugePages_Surp: 0 Hugepagesize: 2048 kB Hugetlb: 0 kB ### virtual memory: vm.admin_reserve_kbytes = 8192 diskdevname: nvme0n1 diskdev: /dev/nvme0n1 vm.block_dump = 0 vm.dirty_background_bytes = 0 partindex: 2 vm.dirty_background_ratio = 10 vm.dirty_bytes = 0 vm.dirty_expire_centisecs = 3000 Warning: Not all of the space available to /dev/nvme0n1 appears to be used, you can fix the GPT to use all of the space (an extra 961691696 blocks) or continue with the current setting? vm.dirty_ratio = 20 vm.dirtytime_expire_seconds = 43200 vm.dirty_writeback_centisecs = 500 Warning: Not all of the space available to /dev/nvme0n1 appears to be used, you can fix the GPT to use all of the space (an extra 961691696 blocks) or continue with the current setting? partstart: 557056s partend: 15081438s vm.extra_free_kbytes = 0 vm.hugetlb_shm_group = 0 vm.laptop_mode = 0 Warning: Not all of the space available to /dev/nvme0n1 appears to be used, you can fix the GPT to use all of the space (an extra 961691696 blocks) or continue with the current setting? vm.legacy_va_layout = 0 vm.lowmem_reserve_ratio = 256 256 32 0 vm.max_map_count = 65530 Warning: Not all of the space available to /dev/nvme0n1 appears to be used, you can fix the GPT to use all of the space (an extra 961691696 blocks) or continue with the current setting? vm.min_free_kbytes = 11208 vm.mmap_min_addr = 32768 Warning: Not all of the space available to /dev/nvme0n1 appears to be used, you can fix the GPT to use all of the space (an extra 961691696 blocks) or continue with the current setting? vm.mmap_rnd_bits = 18 capacity: 976773168s sectorsize: 512B Leaving 1% spare area Old partition table: vm.mmap_rnd_compat_bits = 11 major minor #blocks name 1 0 4096 ram0 254 0 3936628 zram0 31 0 16384 mtdblock0 259 0 488386584 nvme0n1 259 1 262144 nvme0n1p1 259 2 7262191 nvme0n1p2 254 1 51200 zram1 Executing fdisk: vm.nr_hugepages = 0 Warning: Not all of the space available to /dev/nvme0n1 appears to be used, you can fix the GPT to use all of the space (an extra 961691696 blocks) or continue with the current setting? vm.nr_overcommit_hugepages = 0 vm.oom_dump_tasks = 1 vm.oom_kill_allocating_task = 0 vm.overcommit_kbytes = 0 vm.overcommit_memory = 0 Welcome to fdisk (util-linux 2.37.2). Changes will remain in memory only, until you decide to write them. Be careful before using the write command. GPT PMBR size mismatch (15081471 != 976773167) will be corrected by write. The backup GPT table is not on the end of the device. This problem will be corrected by write. This disk is currently in use - repartitioning is probably a bad idea. It's recommended to umount all file systems, and swapoff all swap partitions on this disk. Command (m for help): Partition number (1,2, default 2): Partition 2 has been deleted. Command (m for help): Partition number (2-128, default 2): Value out of range. Partition number (2-128, default 2): First sector (2048-976773134, default 557056): Last sector, +/-sectors or +/-size{K,M,G,T,P} (557056-976773134, default 976773134): Created a new partition 2 of type 'Linux filesystem' and of size 460.8 GiB. Partition #2 contains a ext4 signature. Command (m for help): vm.overcommit_ratio = 50 vm.page-cluster = 0 vm.page_lock_unfairness = 5 The partition table has been altered. Syncing disks. Executing partprobe: vm.panic_on_oom = 0 vm.percpu_pagelist_fraction = 0 vm.stat_interval = 1 vm.swappiness = 100 vm.user_reserve_kbytes = 131072 vm.vfs_cache_pressure = 100 vm.watermark_boost_factor = 15000 vm.watermark_scale_factor = 10 ### ip addr: 1: lo: mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet XXX.XXX.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: eth0: mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether ae:d8:3f:81:fa:0b brd ff:ff:ff:ff:ff:ff ### partitions: major minor #blocks name 254 0 3936628 zram0 31 0 16384 mtdblock0 259 0 488386584 nvme0n1 259 1 262144 nvme0n1p1 259 2 483213312 nvme0n1p2 254 1 51200 zram1 ### df: tmpfs 769M 9.6M 760M 2% /run /dev/nvme0n1p2 6.8G 5.4G 1.3G 81% / tmpfs 3.8G 0 3.8G 0% /dev/shm tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs 3.8G 4.0K 3.8G 1% /tmp /dev/nvme0n1p1 256M 106M 151M 42% /boot /dev/zram1 47M 1.3M 43M 3% /var/log ### lsblk: New partition table: major minor #blocks name 1 0 4096 ram0 254 0 3936628 zram0 31 0 16384 mtdblock0 259 0 488386584 nvme0n1 259 1 262144 nvme0n1p1 259 2 483213312 nvme0n1p2 254 1 51200 zram1 ### [resize2fs] Trying to resize ext4 filesystem on /dev/nvme0n1p2: Running 'resize2fs /dev/nvme0n1p2' now... NAME FSTYPE SIZE MOUNTPOINT UUID mtdblock0 16M zram1 50M /var/log nvme0n1 465.8G ├─nvme0n1p1 vfat 256M /boot 1BD1-7F33 └─nvme0n1p2 ext4 460.8G / 329a3cf7-a8ce-4ea6-a3ef-c2128bda1678 resize2fs 1.46.5 (30-Dec-2021) ### zramctl: NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT /dev/zram1 zstd 50M 1.3M 211.2K 540K 8 /var/log /dev/zram0 lzo-rle 3.8G 4K 74B 12K 8 [SWAP] ### mtab: /dev/nvme0n1p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=936,iocharset=utf8,shortname=mixed,errors=remount-ro 0 0 /dev/nvme0n1p2 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0 /dev/nvme0n1p2 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0 ### Boot system health: Time CPU_cl0/CPU_cl1 load %cpu %sys %usr %nice %io %irq Tcpu C.St. 20:17:45 1800/2256 MHz 0.16 19% 12% 6% 0% 1% 0% 36.1 °C 0/7 20:17:46 1800/ 408 MHz 0.16 13% 1% 0% 0% 11% 0% 35.2 °C 0/7 20:17:46 1800/ 408 MHz 0.16 14% 1% 0% 0% 11% 0% 34.2 °C 0/7 20:17:46 1800/ 408 MHz 0.16 14% 1% 1% 0% 11% 0% 33.3 °C 0/7 20:17:47 1800/ 408 MHz 0.16 13% 1% 0% 0% 11% 0% 33.3 °C 0/7 Filesystem at /dev/nvme0n1p2 is mounted on /; on-line resizing required old_desc_blocks = 1, new_desc_blocks = 29 The filesystem on /dev/nvme0n1p2 is now 120803328 (4k) blocks long. Removed /etc/systemd/system/basic.target.wants/armbian-resize-filesystem.service. ### quick iozone test: 4 22499 27154 14819 67577 27491 47132 ### [firstrun] Recreated SSH keys (entropy: 256 256) ### Activated 1 lzo-rle zram swap devices with 3844MB each. ### Activated Armbian ramlog partition with zstd compression Mon Aug 7 08:49:29 PM +03 2023 | Orange Pi 5 | 23.08.0-trunk | arm64 | aarch64 | 5.10.160-rk35xx ### dmesg: [ 2.522602] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [ 2.522627] Linux version 5.10.160-rk35xx (armbian@next) (aarch64-linux-gnu-gcc (Ubuntu 11.3.0-1ubuntu1~22.04) 11.3.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP Thu Jul 6 13:36:29 UTC 2023 [ 2.533440] Machine model: Orange Pi 5 [ 2.533624] efi: UEFI not found. [ 2.537279] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB [ 2.537298] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@00000000': base 0x0000000000000000, size 0 MiB [ 2.537389] Reserved memory: created CMA memory pool at 0x0000000010000000, size 256 MiB [ 2.537394] OF: reserved mem: initialized node cma, compatible id shared-dma-pool [ 2.687962] Zone ranges: [ 2.687969] DMA [mem 0x0000000000200000-0x00000000ffffffff] [ 2.687980] DMA32 empty [ 2.687986] Normal [mem 0x0000000100000000-0x00000001ffffffff] [ 2.687994] Movable zone start for each node [ 2.687998] Early memory node ranges [ 2.688003] node 0: [mem 0x0000000000200000-0x00000000efffffff] [ 2.688012] node 0: [mem 0x0000000100000000-0x00000001ffffffff] [ 2.688020] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff] [ 2.688027] On node 0 totalpages: 2031104 [ 2.688032] DMA zone: 15352 pages used for memmap [ 2.688036] DMA zone: 0 pages reserved [ 2.688042] DMA zone: 982528 pages, LIFO batch:63 [ 2.688047] Normal zone: 16384 pages used for memmap [ 2.688052] Normal zone: 1048576 pages, LIFO batch:63 [ 2.735018] psci: probing for conduit method from DT. [ 2.735031] psci: PSCIv1.1 detected in firmware. [ 2.735035] psci: Using standard PSCI v0.2 function IDs [ 2.735042] psci: MIGRATE_INFO_TYPE not supported. [ 2.735048] psci: SMC Calling Convention v1.2 [ 2.735470] percpu: Embedded 32 pages/cpu s93480 r8192 d29400 u131072 [ 2.735513] pcpu-alloc: s93480 r8192 d29400 u131072 alloc=32*4096 [ 2.735521] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7 [ 2.735663] Detected VIPT I-cache on CPU0 [ 2.735712] CPU features: detected: GIC system register CPU interface [ 2.735718] CPU features: detected: Virtualization Host Extensions [ 2.735728] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 2.735741] alternatives: patching kernel code [ 2.736125] Built 1 zonelists, mobility grouping on. Total pages: 1999368 [ 2.736135] Kernel command line: root=UUID=329a3cf7-a8ce-4ea6-a3ef-c2128bda1678 rootwait rootfstype=ext4 splash plymouth.ignore-serial-consoles console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart= usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 [ 2.737470] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) [ 2.737876] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 2.737884] mem auto-init: stack:off, heap alloc:off, heap free:off [ 2.744390] software IO TLB: mapped [mem 0x00000000ec000000-0x00000000f0000000] (64MB) [ 2.818168] Memory: 7589184K/8124416K available (16832K kernel code, 3506K rwdata, 6500K rodata, 6976K init, 639K bss, 273088K reserved, 262144K cma-reserved) [ 2.818329] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1 [ 2.818365] ftrace: allocating 64539 entries in 253 pages [ 2.928736] ftrace: allocated 253 pages with 7 groups [ 2.929042] rcu: Hierarchical RCU implementation. [ 2.929047] rcu: RCU event tracing is enabled. [ 2.929053] Rude variant of Tasks RCU enabled. [ 2.929056] Tracing variant of Tasks RCU enabled. [ 2.929063] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies. [ 2.934707] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 2.937513] GICv3: GIC: Using split EOI/Deactivate mode [ 2.937520] GICv3: 480 SPIs implemented [ 2.937525] GICv3: 0 Extended SPIs implemented [ 2.937565] GICv3: Distributor has no Range Selector support [ 2.937576] GICv3: 16 PPIs implemented [ 2.937621] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000 [ 2.937748] ITS [mem 0xfe640000-0xfe65ffff] [ 2.937804] ITS@0x00000000fe640000: allocated 8192 Devices @100200000 (indirect, esz 8, psz 64K, shr 0) [ 2.937833] ITS@0x00000000fe640000: allocated 32768 Interrupt Collections @100210000 (flat, esz 2, psz 64K, shr 0) [ 2.937843] ITS: using cache flushing for cmd queue [ 2.937886] ITS [mem 0xfe660000-0xfe67ffff] [ 2.937935] ITS@0x00000000fe660000: allocated 8192 Devices @100230000 (indirect, esz 8, psz 64K, shr 0) [ 2.937962] ITS@0x00000000fe660000: allocated 32768 Interrupt Collections @100240000 (flat, esz 2, psz 64K, shr 0) [ 2.937972] ITS: using cache flushing for cmd queue [ 2.938197] GICv3: using LPI property table @0x0000000100250000 [ 2.938326] GIC: using cache flushing for LPI property table [ 2.938337] GICv3: CPU0: using allocated LPI pending table @0x0000000100260000 [ 3.074710] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 3.074720] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 3.074731] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 3.076102] Console: colour dummy device 80x25 [ 3.076144] printk: console [tty1] enabled [ 3.076174] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000) [ 3.076186] pid_max: default: 32768 minimum: 301 [ 3.076298] LSM: Security Framework initializing [ 3.076369] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 3.076395] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 3.078653] rcu: Hierarchical SRCU implementation. [ 3.079621] Platform MSI: msi-controller@fe640000 domain created [ 3.079643] Platform MSI: msi-controller@fe660000 domain created [ 3.080023] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe640000 domain created [ 3.080049] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe660000 domain created [ 3.080236] EFI services will not be available. [ 3.080690] smp: Bringing up secondary CPUs ... [ 3.081412] Detected VIPT I-cache on CPU1 [ 3.081449] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000 [ 3.081469] GICv3: CPU1: using allocated LPI pending table @0x0000000100270000 [ 3.081513] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [ 3.082284] Detected VIPT I-cache on CPU2 [ 3.082316] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000 [ 3.082335] GICv3: CPU2: using allocated LPI pending table @0x0000000100280000 [ 3.082376] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [ 3.083105] Detected VIPT I-cache on CPU3 [ 3.083135] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000 [ 3.083153] GICv3: CPU3: using allocated LPI pending table @0x0000000100290000 [ 3.083192] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [ 3.083935] CPU features: detected: Spectre-v4 [ 3.083939] CPU features: detected: Spectre-BHB [ 3.083941] Detected PIPT I-cache on CPU4 [ 3.083957] GICv3: CPU4: found redistributor 400 region 0:0x00000000fe700000 [ 3.083968] GICv3: CPU4: using allocated LPI pending table @0x00000001002a0000 [ 3.083993] CPU4: Booted secondary processor 0x0000000400 [0x414fd0b0] [ 3.084716] Detected PIPT I-cache on CPU5 [ 3.084732] GICv3: CPU5: found redistributor 500 region 0:0x00000000fe720000 [ 3.084743] GICv3: CPU5: using allocated LPI pending table @0x00000001002b0000 [ 3.084769] CPU5: Booted secondary processor 0x0000000500 [0x414fd0b0] [ 3.085462] Detected PIPT I-cache on CPU6 [ 3.085478] GICv3: CPU6: found redistributor 600 region 0:0x00000000fe740000 [ 3.085488] GICv3: CPU6: using allocated LPI pending table @0x00000001002c0000 [ 3.085514] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b0] [ 3.086189] Detected PIPT I-cache on CPU7 [ 3.086205] GICv3: CPU7: found redistributor 700 region 0:0x00000000fe760000 [ 3.086216] GICv3: CPU7: using allocated LPI pending table @0x00000001002d0000 [ 3.086242] CPU7: Booted secondary processor 0x0000000700 [0x414fd0b0] [ 3.086320] smp: Brought up 1 node, 8 CPUs [ 3.086340] SMP: Total of 8 processors activated. [ 3.086346] CPU features: detected: Privileged Access Never [ 3.086350] CPU features: detected: User Access Override [ 3.086356] CPU features: detected: 32-bit EL0 Support [ 3.086360] CPU features: detected: Common not Private translations [ 3.086365] CPU features: detected: RAS Extension Support [ 3.086369] CPU features: detected: Data cache clean to the PoU not required for I/D coherence [ 3.086374] CPU features: detected: CRC32 instructions [ 3.086378] CPU features: detected: Speculative Store Bypassing Safe (SSBS) [ 3.086385] CPU features: detected: RCpc load-acquire (LDAPR) [ 3.086473] CPU: All CPU(s) started at EL2 [ 3.089757] devtmpfs: initialized [ 3.104549] Registered cp15_barrier emulation handler [ 3.104558] Registered setend emulation handler [ 3.104562] KASLR disabled due to lack of seed [ 3.104649] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns [ 3.104656] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 3.107400] pinctrl core: initialized pinctrl subsystem [ 3.107519] regulator-dummy: no parameters, enabled [ 3.107637] DMI not present or invalid. [ 3.107941] NET: Registered protocol family 16 [ 3.108969] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations [ 3.109074] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 3.109092] audit: initializing netlink subsys (disabled) [ 3.109174] audit: type=2000 audit(0.033:1): state=initialized audit_enabled=0 res=1 [ 3.109685] Registered FIQ tty driver [ 3.109837] thermal_sys: Registered thermal governor 'fair_share' [ 3.109840] thermal_sys: Registered thermal governor 'step_wise' [ 3.109842] thermal_sys: Registered thermal governor 'user_space' [ 3.109844] thermal_sys: Registered thermal governor 'power_allocator' [ 3.110171] cpuidle: using governor menu [ 3.110396] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 3.110534] ASID allocator initialised with 65536 entries [ 3.112067] ramoops: dmesg-0 0x20000@0x0000000000110000 [ 3.112084] ramoops: console 0x80000@0x0000000000130000 [ 3.112094] ramoops: pmsg 0x50000@0x00000000001b0000 [ 3.112142] printk: console [ramoops-1] enabled [ 3.112144] pstore: Registered ramoops as persistent store backend [ 3.112146] ramoops: using 0xf0000@0x110000, ecc: 0 [ 3.166409] rockchip-gpio fd8a0000.gpio: probed /pinctrl/gpio@fd8a0000 [ 3.166704] rockchip-gpio fec20000.gpio: probed /pinctrl/gpio@fec20000 [ 3.166939] rockchip-gpio fec30000.gpio: probed /pinctrl/gpio@fec30000 [ 3.167214] rockchip-gpio fec40000.gpio: probed /pinctrl/gpio@fec40000 [ 3.167484] rockchip-gpio fec50000.gpio: probed /pinctrl/gpio@fec50000 [ 3.167533] rockchip-pinctrl pinctrl: probed pinctrl [ 3.176162] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 3.176167] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 3.176170] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 3.176173] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 3.234666] raid6: neonx8 gen() 5343 MB/s [ 3.291414] raid6: neonx8 xor() 4142 MB/s [ 3.348163] raid6: neonx4 gen() 5481 MB/s [ 3.404912] raid6: neonx4 xor() 4163 MB/s [ 3.461658] raid6: neonx2 gen() 5026 MB/s [ 3.518408] raid6: neonx2 xor() 3930 MB/s [ 3.575159] raid6: neonx1 gen() 4201 MB/s [ 3.631907] raid6: neonx1 xor() 3237 MB/s [ 3.688673] raid6: int64x8 gen() 1308 MB/s [ 3.745418] raid6: int64x8 xor() 852 MB/s [ 3.802158] raid6: int64x4 gen() 1611 MB/s [ 3.858910] raid6: int64x4 xor() 856 MB/s [ 3.915660] raid6: int64x2 gen() 1876 MB/s [ 3.972413] raid6: int64x2 xor() 1294 MB/s [ 4.029159] raid6: int64x1 gen() 1961 MB/s [ 4.085919] raid6: int64x1 xor() 957 MB/s [ 4.085921] raid6: using algorithm neonx4 gen() 5481 MB/s [ 4.085923] raid6: .... xor() 4163 MB/s, rmw enabled [ 4.085925] raid6: using neon recovery algorithm [ 4.086501] fiq_debugger fiq_debugger.0: IRQ fiq not found [ 4.086507] fiq_debugger fiq_debugger.0: IRQ wakeup not found [ 4.086511] fiq_debugger_probe: could not install nmi irq handler [ 4.086599] printk: console [ttyFIQ0] enabled [ 4.086700] Registered fiq debugger ttyFIQ0 [ 4.086929] vcc12v_dcin: 12000 mV, enabled [ 4.087009] reg-fixed-voltage vcc12v-dcin: vcc12v_dcin supplying 12000000uV [ 4.087060] reg-fixed-voltage vcc5v0-sys: Looking up vin-supply from device tree [ 4.087064] vcc5v0_sys: supplied by vcc12v_dcin [ 4.087068] vcc12v_dcin: could not add device link regulator.2: -ENOENT [ 4.087084] vcc5v0_sys: 5000 mV, enabled [ 4.087149] reg-fixed-voltage vcc5v0-sys: vcc5v0_sys supplying 5000000uV [ 4.087199] reg-fixed-voltage vcc5v0-usbdcin: Looking up vin-supply from device tree [ 4.087202] vcc5v0_usbdcin: supplied by vcc12v_dcin [ 4.087206] vcc12v_dcin: could not add device link regulator.3: -ENOENT [ 4.087220] vcc5v0_usbdcin: 5000 mV, enabled [ 4.087282] reg-fixed-voltage vcc5v0-usbdcin: vcc5v0_usbdcin supplying 5000000uV [ 4.087329] reg-fixed-voltage vcc5v0-usb: Looking up vin-supply from device tree [ 4.087333] vcc5v0_usb: supplied by vcc5v0_usbdcin [ 4.087337] vcc5v0_usbdcin: could not add device link regulator.4: -ENOENT [ 4.087356] vcc5v0_usb: 5000 mV, enabled [ 4.087415] reg-fixed-voltage vcc5v0-usb: vcc5v0_usb supplying 5000000uV [ 4.087522] vbus5v0_typec: 5000 mV, disabled [ 4.087573] reg-fixed-voltage vbus5v0-typec: Looking up vin-supply from device tree [ 4.087577] vbus5v0_typec: supplied by vcc5v0_usb [ 4.087612] reg-fixed-voltage vbus5v0-typec: vbus5v0_typec supplying 5000000uV [ 4.087665] reg-fixed-voltage vcc-1v1-nldo-s3: Looking up vin-supply from device tree [ 4.087669] vcc_1v1_nldo_s3: supplied by vcc5v0_sys [ 4.087673] vcc5v0_sys: could not add device link regulator.6: -ENOENT [ 4.087687] vcc_1v1_nldo_s3: 1100 mV, enabled [ 4.087746] reg-fixed-voltage vcc-1v1-nldo-s3: vcc_1v1_nldo_s3 supplying 1100000uV [ 4.087798] reg-fixed-voltage vcc3v3-pcie2x1l2: Looking up vin-supply from device tree [ 4.087802] vcc3v3_pcie2x1l2: supplied by vcc5v0_sys [ 4.087805] vcc5v0_sys: could not add device link regulator.7: -ENOENT [ 4.144878] vcc3v3_pcie2x1l2: 1800 mV, enabled [ 4.144947] reg-fixed-voltage vcc3v3-pcie2x1l2: vcc3v3_pcie2x1l2 supplying 1800000uV [ 4.145218] iommu: Default domain type: Translated [ 4.145655] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vdpu-supply from device tree [ 4.145675] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vdpu-supply property in node /power-management@fd8d8000/power-controller failed [ 4.145946] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga30-supply from device tree [ 4.145964] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga30-supply property in node /power-management@fd8d8000/power-controller failed [ 4.146147] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga31-supply from device tree [ 4.146166] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga31-supply property in node /power-management@fd8d8000/power-controller failed [ 4.147474] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc0-supply from device tree [ 4.147493] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc0-supply property in node /power-management@fd8d8000/power-controller failed [ 4.147649] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vcodec-supply from device tree [ 4.147667] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vcodec-supply property in node /power-management@fd8d8000/power-controller failed [ 4.147768] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc1-supply from device tree [ 4.147785] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc1-supply property in node /power-management@fd8d8000/power-controller failed [ 4.148061] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec0-supply from device tree [ 4.148079] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec0-supply property in node /power-management@fd8d8000/power-controller failed [ 4.148374] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec1-supply from device tree [ 4.148392] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec1-supply property in node /power-management@fd8d8000/power-controller failed [ 4.148619] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vi-supply from device tree [ 4.148636] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vi-supply property in node /power-management@fd8d8000/power-controller failed [ 4.148871] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up isp1-supply from device tree [ 4.148889] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up isp1-supply property in node /power-management@fd8d8000/power-controller failed [ 4.149586] SCSI subsystem initialized [ 4.149601] libata version 3.00 loaded. [ 4.149668] usbcore: registered new interface driver usbfs [ 4.149683] usbcore: registered new interface driver hub [ 4.149700] usbcore: registered new device driver usb [ 4.149737] mc: Linux media interface: v0.10 [ 4.149748] videodev: Linux video capture interface: v2.00 [ 4.149775] pps_core: LinuxPPS API ver. 1 registered [ 4.149778] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [ 4.149784] PTP clock support registered [ 4.150066] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled. [ 4.150099] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0 [ 4.151276] Advanced Linux Sound Architecture Driver Initialized. [ 4.151533] Bluetooth: Core ver 2.22 [ 4.151560] NET: Registered protocol family 31 [ 4.151562] Bluetooth: HCI device and connection manager initialized [ 4.151567] Bluetooth: HCI socket layer initialized [ 4.151571] Bluetooth: L2CAP socket layer initialized [ 4.151577] Bluetooth: SCO socket layer initialized [ 4.151590] NetLabel: Initializing [ 4.151592] NetLabel: domain hash size = 128 [ 4.151594] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 4.151622] NetLabel: unlabeled traffic allowed by default [ 4.152944] rockchip-cpuinfo cpuinfo: SoC : 35881000 [ 4.152948] rockchip-cpuinfo cpuinfo: Serial : 2eae2cb9d903d20e [ 4.153373] clocksource: Switched to clocksource arch_sys_counter [ 4.571627] VFS: Disk quotas dquot_6.6.0 [ 4.571656] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 4.577157] NET: Registered protocol family 2 [ 4.577281] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 4.579314] tcp_listen_portaddr_hash hash table entries: 4096 (order: 5, 163840 bytes, linear) [ 4.579392] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 4.579741] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear) [ 4.580557] TCP: Hash tables configured (established 65536 bind 65536) [ 4.580674] MPTCP token hash table entries: 8192 (order: 6, 393216 bytes, linear) [ 4.580774] UDP hash table entries: 4096 (order: 6, 393216 bytes, linear) [ 4.580930] UDP-Lite hash table entries: 4096 (order: 6, 393216 bytes, linear) [ 4.581145] NET: Registered protocol family 1 [ 4.581522] RPC: Registered named UNIX socket transport module. [ 4.581525] RPC: Registered udp transport module. [ 4.581527] RPC: Registered tcp transport module. [ 4.581529] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 4.581965] PCI: CLS 0 bytes, default 64 [ 4.582259] Trying to unpack rootfs image as initramfs... [ 4.976745] Freeing initrd memory: 14952K [ 4.977414] rockchip-thermal fec00000.tsadc: Missing rockchip,grf property [ 4.978055] rockchip-thermal fec00000.tsadc: tsadc is probed successfully! [ 4.978990] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 4.979590] kvm [1]: IPA Size Limit: 40 bits [ 4.979601] kvm [1]: GICv3: no GICV resource entry [ 4.979604] kvm [1]: disabling GICv2 emulation [ 4.979606] kvm [1]: GIC system register CPU interface enabled [ 4.979762] kvm [1]: vgic interrupt IRQ9 [ 4.979944] kvm [1]: VHE mode initialized successfully [ 4.982975] Initialise system trusted keyrings [ 4.983089] workingset: timestamp_bits=46 max_order=21 bucket_order=0 [ 4.986179] NFS: Registering the id_resolver key type [ 4.986200] Key type id_resolver registered [ 4.986202] Key type id_legacy registered [ 4.986240] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 4.986243] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 4.986255] ntfs: driver 2.1.32 [Flags: R/W]. [ 5.007384] NET: Registered protocol family 38 [ 5.007389] xor: measuring software checksum speed [ 5.008998] 8regs : 6125 MB/sec [ 5.010220] 32regs : 8135 MB/sec [ 5.011214] arm64_neon : 9915 MB/sec [ 5.011217] xor: using function: arm64_neon (9915 MB/sec) [ 5.011222] Key type asymmetric registered [ 5.011224] Asymmetric key parser 'x509' registered [ 5.011241] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242) [ 5.011351] io scheduler mq-deadline registered [ 5.011356] io scheduler kyber registered [ 5.013143] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up phy-supply from device tree [ 5.013152] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up phy-supply property in node /syscon@fd5d0000/usb2-phy@0/otg-port failed [ 5.013201] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up vbus-supply from device tree [ 5.013208] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up vbus-supply property in node /syscon@fd5d0000/usb2-phy@0/otg-port failed [ 5.014626] phy phy-fd5d8000.syscon:usb2-phy@8000.1: Looking up phy-supply from device tree [ 5.014635] phy phy-fd5d8000.syscon:usb2-phy@8000.1: Looking up phy-supply property in node /syscon@fd5d8000/usb2-phy@8000/host-port failed [ 5.015819] phy phy-fd5dc000.syscon:usb2-phy@c000.2: Looking up phy-supply from device tree [ 5.015827] phy phy-fd5dc000.syscon:usb2-phy@c000.2: Looking up phy-supply property in node /syscon@fd5dc000/usb2-phy@c000/host-port failed [ 5.017671] phy phy-fee00000.phy.3: Looking up phy-supply from device tree [ 5.017677] phy phy-fee00000.phy.3: Looking up phy-supply property in node /phy@fee00000 failed [ 5.017822] phy phy-fee20000.phy.4: Looking up phy-supply from device tree [ 5.017828] phy phy-fee20000.phy.4: Looking up phy-supply property in node /phy@fee20000 failed [ 5.018331] phy phy-feda0000.phy.5: Looking up phy-supply from device tree [ 5.018337] phy phy-feda0000.phy.5: Looking up phy-supply property in node /phy@feda0000 failed [ 5.018468] phy phy-fedb0000.phy.6: Looking up phy-supply from device tree [ 5.018473] phy phy-fedb0000.phy.6: Looking up phy-supply property in node /phy@fedb0000 failed [ 5.018851] phy phy-fed60000.hdmiphy.7: Looking up phy-supply from device tree [ 5.018857] phy phy-fed60000.hdmiphy.7: Looking up phy-supply property in node /hdmiphy@fed60000 failed [ 5.019628] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy init success [ 5.020591] phy phy-fed80000.phy.8: Looking up phy-supply from device tree [ 5.020598] phy phy-fed80000.phy.8: Looking up phy-supply property in node /phy@fed80000/dp-port failed [ 5.020632] phy phy-fed80000.phy.9: Looking up phy-supply from device tree [ 5.020637] phy phy-fed80000.phy.9: Looking up phy-supply property in node /phy@fed80000/u3-port failed [ 5.022029] rk-pcie fe190000.pcie: invalid prsnt-gpios property in node [ 5.022035] rk-pcie fe190000.pcie: Looking up vpcie3v3-supply from device tree [ 5.022285] pwm-backlight backlight: Looking up power-supply from device tree [ 5.022292] pwm-backlight backlight: Looking up power-supply property in node /backlight failed [ 5.022297] pwm-backlight backlight: supply power not found, using dummy regulator [ 5.022378] rk-pcie fe190000.pcie: IRQ msi not found [ 5.022381] rk-pcie fe190000.pcie: use outband MSI support [ 5.022384] rk-pcie fe190000.pcie: Missing *config* reg space [ 5.022391] rk-pcie fe190000.pcie: host bridge /pcie@fe190000 ranges: [ 5.022404] rk-pcie fe190000.pcie: err 0x00f4000000..0x00f40fffff -> 0x00f4000000 [ 5.022411] rk-pcie fe190000.pcie: IO 0x00f4100000..0x00f41fffff -> 0x00f4100000 [ 5.022419] rk-pcie fe190000.pcie: MEM 0x00f4200000..0x00f4ffffff -> 0x00f4200000 [ 5.022426] rk-pcie fe190000.pcie: MEM 0x0a00000000..0x0a3fffffff -> 0x0a00000000 [ 5.022453] rk-pcie fe190000.pcie: Missing *config* reg space [ 5.022466] pwm-backlight backlight_1: Looking up power-supply from device tree [ 5.022471] pwm-backlight backlight_1: Looking up power-supply property in node /backlight_1 failed [ 5.022475] pwm-backlight backlight_1: supply power not found, using dummy regulator [ 5.022479] rk-pcie fe190000.pcie: invalid resource [ 5.022732] iep: Module initialized. [ 5.022768] mpp_service mpp-srv: unknown mpp version for missing VCS info [ 5.022771] mpp_service mpp-srv: probe start [ 5.024745] mpp_vdpu2 fdb50400.vdpu: Adding to iommu group 1 [ 5.024965] mpp_vdpu2 fdb50400.vdpu: probe device [ 5.025081] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0 [ 5.025088] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0 [ 5.025227] mpp_vdpu2 fdb50400.vdpu: probing finish [ 5.025440] mpp_vepu2 jpege-ccu: probing start [ 5.025444] mpp_vepu2 jpege-ccu: probing finish [ 5.025552] mpp_vepu2 fdb50000.vepu: Adding to iommu group 1 [ 5.025634] mpp_vepu2 fdb50000.vepu: probing start [ 5.025731] mpp_vepu2 fdb50000.vepu: reset_group->rw_sem_on=0 [ 5.025734] mpp_vepu2 fdb50000.vepu: reset_group->rw_sem_on=0 [ 5.025872] mpp_vepu2 fdb50000.vepu: probing finish [ 5.025989] mpp_vepu2 fdba0000.jpege-core: Adding to iommu group 5 [ 5.026128] mpp_vepu2 fdba0000.jpege-core: probing start [ 5.026234] mpp_vepu2 fdba0000.jpege-core: attach ccu success [ 5.026371] mpp_vepu2 fdba0000.jpege-core: probing finish [ 5.026481] mpp_vepu2 fdba4000.jpege-core: Adding to iommu group 6 [ 5.026619] mpp_vepu2 fdba4000.jpege-core: probing start [ 5.026737] mpp_vepu2 fdba4000.jpege-core: attach ccu success [ 5.026891] mpp_vepu2 fdba4000.jpege-core: probing finish [ 5.026999] mpp_vepu2 fdba8000.jpege-core: Adding to iommu group 7 [ 5.027139] mpp_vepu2 fdba8000.jpege-core: probing start [ 5.027243] mpp_vepu2 fdba8000.jpege-core: attach ccu success [ 5.027388] mpp_vepu2 fdba8000.jpege-core: probing finish [ 5.027484] mpp_vepu2 fdbac000.jpege-core: Adding to iommu group 8 [ 5.027621] mpp_vepu2 fdbac000.jpege-core: probing start [ 5.027725] mpp_vepu2 fdbac000.jpege-core: attach ccu success [ 5.027862] mpp_vepu2 fdbac000.jpege-core: probing finish [ 5.028136] mpp-iep2 fdbb0000.iep: Adding to iommu group 9 [ 5.028275] mpp-iep2 fdbb0000.iep: probe device [ 5.028404] mpp-iep2 fdbb0000.iep: allocate roi buffer failed [ 5.028539] mpp-iep2 fdbb0000.iep: probing finish [ 5.028758] mpp_jpgdec fdb90000.jpegd: Adding to iommu group 4 [ 5.028962] mpp_jpgdec fdb90000.jpegd: probe device [ 5.029210] mpp_jpgdec fdb90000.jpegd: probing finish [ 5.029579] mpp_rkvdec2 fdc30000.rkvdec-ccu: rkvdec-ccu, probing start [ 5.029637] mpp_rkvdec2 fdc30000.rkvdec-ccu: ccu-mode: 1 [ 5.029639] mpp_rkvdec2 fdc30000.rkvdec-ccu: probing finish [ 5.029731] mpp_rkvdec2 fdc38100.rkvdec-core: Adding to iommu group 12 [ 5.029992] mpp_rkvdec2 fdc38100.rkvdec-core: rkvdec-core, probing start [ 5.030131] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found! [ 5.030134] rkvdec2_init:1022: No niu aclk reset resource define [ 5.030137] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found! [ 5.030139] rkvdec2_init:1025: No niu hclk reset resource define [ 5.030154] mpp_rkvdec2 fdc38100.rkvdec-core: Looking up vdec-supply from device tree [ 5.030160] mpp_rkvdec2 fdc38100.rkvdec-core: Looking up vdec-supply property in node /rkvdec-core@fdc38000 failed [ 5.030166] mpp_rkvdec2 fdc38100.rkvdec-core: no regulator, devfreq is disabled [ 5.030223] mpp_rkvdec2 fdc38100.rkvdec-core: core_mask=00010001 [ 5.030226] mpp_rkvdec2 fdc38100.rkvdec-core: attach ccu as core 0 [ 5.030374] mpp_rkvdec2 fdc38100.rkvdec-core: sram_start 0x00000000ff001000 [ 5.030377] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_iova 0x00000000fff00000 [ 5.030380] mpp_rkvdec2 fdc38100.rkvdec-core: sram_size 491520 [ 5.030383] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_size 1048576 [ 5.030387] mpp_rkvdec2 fdc38100.rkvdec-core: min_width 512 [ 5.030391] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_info_count 20 [ 5.030394] mpp_rkvdec2 fdc38100.rkvdec-core: [136, 24576] [ 5.030397] mpp_rkvdec2 fdc38100.rkvdec-core: [137, 49152] [ 5.030400] mpp_rkvdec2 fdc38100.rkvdec-core: [141, 90112] [ 5.030402] mpp_rkvdec2 fdc38100.rkvdec-core: [140, 49152] [ 5.030405] mpp_rkvdec2 fdc38100.rkvdec-core: [139, 180224] [ 5.030408] mpp_rkvdec2 fdc38100.rkvdec-core: [133, 49152] [ 5.030410] mpp_rkvdec2 fdc38100.rkvdec-core: [134, 8192] [ 5.030413] mpp_rkvdec2 fdc38100.rkvdec-core: [135, 4352] [ 5.030415] mpp_rkvdec2 fdc38100.rkvdec-core: [138, 13056] [ 5.030418] mpp_rkvdec2 fdc38100.rkvdec-core: [142, 291584] [ 5.030452] mpp_rkvdec2 fdc38100.rkvdec-core: probing finish [ 5.030542] mpp_rkvdec2 fdc48100.rkvdec-core: Adding to iommu group 13 [ 5.030773] mpp_rkvdec2 fdc48100.rkvdec-core: rkvdec-core, probing start [ 5.030893] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found! [ 5.030896] rkvdec2_init:1022: No niu aclk reset resource define [ 5.030900] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found! [ 5.030902] rkvdec2_init:1025: No niu hclk reset resource define [ 5.030916] mpp_rkvdec2 fdc48100.rkvdec-core: Looking up vdec-supply from device tree [ 5.030922] mpp_rkvdec2 fdc48100.rkvdec-core: Looking up vdec-supply property in node /rkvdec-core@fdc48000 failed [ 5.030927] mpp_rkvdec2 fdc48100.rkvdec-core: no regulator, devfreq is disabled [ 5.030970] mpp_rkvdec2 fdc48100.rkvdec-core: core_mask=00020002 [ 5.030986] mpp_rkvdec2 fdc48100.rkvdec-core: attach ccu as core 1 [ 5.031164] mpp_rkvdec2 fdc48100.rkvdec-core: sram_start 0x00000000ff079000 [ 5.031166] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_iova 0x00000000ffe00000 [ 5.031169] mpp_rkvdec2 fdc48100.rkvdec-core: sram_size 487424 [ 5.031172] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_size 1048576 [ 5.031175] mpp_rkvdec2 fdc48100.rkvdec-core: min_width 512 [ 5.031180] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_info_count 20 [ 5.031182] mpp_rkvdec2 fdc48100.rkvdec-core: [136, 24576] [ 5.031185] mpp_rkvdec2 fdc48100.rkvdec-core: [137, 49152] [ 5.031187] mpp_rkvdec2 fdc48100.rkvdec-core: [141, 90112] [ 5.031190] mpp_rkvdec2 fdc48100.rkvdec-core: [140, 49152] [ 5.031192] mpp_rkvdec2 fdc48100.rkvdec-core: [139, 180224] [ 5.031195] mpp_rkvdec2 fdc48100.rkvdec-core: [133, 49152] [ 5.031198] mpp_rkvdec2 fdc48100.rkvdec-core: [134, 8192] [ 5.031200] mpp_rkvdec2 fdc48100.rkvdec-core: [135, 4352] [ 5.031203] mpp_rkvdec2 fdc48100.rkvdec-core: [138, 13056] [ 5.031205] mpp_rkvdec2 fdc48100.rkvdec-core: [142, 291584] [ 5.031235] mpp_rkvdec2 fdc48100.rkvdec-core: probing finish [ 5.031424] mpp_rkvenc2 rkvenc-ccu: probing start [ 5.031428] mpp_rkvenc2 rkvenc-ccu: probing finish [ 5.031545] mpp_rkvenc2 fdbd0000.rkvenc-core: Adding to iommu group 10 [ 5.031726] mpp_rkvenc2 fdbd0000.rkvenc-core: probing start [ 5.031871] mpp_rkvenc2 fdbd0000.rkvenc-core: Looking up venc-supply from device tree [ 5.031877] mpp_rkvenc2 fdbd0000.rkvenc-core: Looking up venc-supply property in node /rkvenc-core@fdbd0000 failed [ 5.031883] mpp_rkvenc2 fdbd0000.rkvenc-core: dev_pm_opp_set_regulators: no regulator (venc) found: -19 [ 5.031899] rkvenc_init:1814: failed to add venc devfreq [ 5.031927] mpp_rkvenc2 fdbd0000.rkvenc-core: attach ccu as core 0 [ 5.032077] mpp_rkvenc2 fdbd0000.rkvenc-core: probing finish [ 5.032161] mpp_rkvenc2 fdbe0000.rkvenc-core: Adding to iommu group 11 [ 5.032345] mpp_rkvenc2 fdbe0000.rkvenc-core: probing start [ 5.032473] mpp_rkvenc2 fdbe0000.rkvenc-core: Looking up venc-supply from device tree [ 5.032479] mpp_rkvenc2 fdbe0000.rkvenc-core: Looking up venc-supply property in node /rkvenc-core@fdbe0000 failed [ 5.032485] mpp_rkvenc2 fdbe0000.rkvenc-core: dev_pm_opp_set_regulators: no regulator (venc) found: -19 [ 5.032499] rkvenc_init:1814: failed to add venc devfreq [ 5.032548] mpp_rkvenc2 fdbe0000.rkvenc-core: attach ccu as core 1 [ 5.032689] mpp_rkvenc2 fdbe0000.rkvenc-core: probing finish [ 5.032932] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up av1-supply from device tree [ 5.032954] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up av1-supply property in node /power-management@fd8d8000/power-controller failed [ 5.033256] mpp_av1dec: Adding child /av1d@fdc70000 [ 5.033336] mpp_av1dec: register device av1d-master [ 5.033378] mpp_av1dec av1d-master: av1_iommu_of_xlate,784 [ 5.033397] av1_iommu_probe_device,736, consumer : av1d-master, supplier : fdca0000.iommu [ 5.033433] mpp_av1dec av1d-master: Adding to iommu group 18 [ 5.033672] mpp_av1dec av1d-master: probing start [ 5.033938] mpp_av1dec av1d-master: probing finish [ 5.033977] mpp_service mpp-srv: probe success [ 5.045086] dma-pl330 fea10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 5.045092] dma-pl330 fea10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 5.046110] dma-pl330 fea30000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 5.046115] dma-pl330 fea30000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 5.047120] dma-pl330 fed10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 5.047125] dma-pl330 fed10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 5.047622] rockchip-pvtm fda40000.pvtm: pvtm@0 probed [ 5.047685] rockchip-pvtm fda50000.pvtm: pvtm@1 probed [ 5.047743] rockchip-pvtm fda60000.pvtm: pvtm@2 probed [ 5.047800] rockchip-pvtm fdaf0000.pvtm: pvtm@3 probed [ 5.047860] rockchip-pvtm fdb30000.pvtm: pvtm@4 probed [ 5.048448] rockchip-system-monitor rockchip-system-monitor: system monitor probe [ 5.049266] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [ 5.049774] febc0000.serial: ttyS9 at MMIO 0xfebc0000 (irq = 101, base_baud = 1500000) is a 16550A [ 5.051038] random: crng init done [ 5.051127] led_vk2c21_init ============================================= [ 5.052106] rockchip-vop2 fdd90000.vop: Adding to iommu group 17 [ 5.060590] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x5, primary plane phy id: 0 [ 5.060598] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp1 assign plane mask: 0xa, primary plane phy id: 1 [ 5.060603] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x140, primary plane phy id: 6 [ 5.060609] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp3 assign plane mask: 0x280, primary plane phy id: 7 [ 5.060700] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart0-win0 as cursor plane for vp0 [ 5.060792] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart1-win0 as cursor plane for vp1 [ 5.060878] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart2-win0 as cursor plane for vp2 [ 5.060961] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart3-win0 as cursor plane for vp3 [ 5.060979] [drm] failed to init overlay plane Cluster0-win1 [ 5.060982] [drm] failed to init overlay plane Cluster1-win1 [ 5.060984] [drm] failed to init overlay plane Cluster2-win1 [ 5.060986] [drm] failed to init overlay plane Cluster3-win1 [ 5.072563] rockchip-drm display-subsystem: bound fdd90000.vop (ops 0xffff8000091b2620) [ 5.073553] dwhdmi-rockchip fde80000.hdmi: registered ddc I2C bus driver [ 5.073770] rockchip-drm display-subsystem: bound fde80000.hdmi (ops 0xffff8000091c0798) [ 5.073859] rockchip-drm display-subsystem: bound fde50000.dp (ops 0xffff8000091c3278) [ 5.074504] rockchip-drm display-subsystem: failed to parse loader memory [ 5.227825] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x2 [ 5.294612] dwhdmi-rockchip fde80000.hdmi: use tmds mode [ 5.294651] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] Update mode to 1920x1080p60, type: 11(if:800) for vp0 dclk: 148500000 [ 5.294818] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] dclk_out0 div: 0 dclk_core0 div: 2 [ 5.294836] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx_ropll_cmn_config bus_width:16a8c8 rate:1485000 [ 5.295114] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy pll locked! [ 5.295121] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] set dclk_vop0 to 148500000, get 148500000 [ 5.295144] dwhdmi-rockchip fde80000.hdmi: final tmdsclk = 148500000 [ 5.295173] dwhdmi-rockchip fde80000.hdmi: don't use dsc mode [ 5.295177] dwhdmi-rockchip fde80000.hdmi: dw hdmi qp use tmds mode [ 5.295183] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: bus_width:0x16a8c8,bit_rate:1485000 [ 5.295378] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy lane locked! [ 5.310054] rk-pcie fe190000.pcie: PCIe Link up, LTSSM is 0x30011 [ 5.310143] rk-pcie fe190000.pcie: PCI host bridge to bus 0004:40 [ 5.310149] pci_bus 0004:40: root bus resource [bus 40-4f] [ 5.310153] pci_bus 0004:40: root bus resource [??? 0xf4000000-0xf40fffff flags 0x0] [ 5.310157] pci_bus 0004:40: root bus resource [io 0x0000-0xfffff] (bus address [0xf4100000-0xf41fffff]) [ 5.310160] pci_bus 0004:40: root bus resource [mem 0xf4200000-0xf4ffffff] [ 5.310164] pci_bus 0004:40: root bus resource [mem 0xa00000000-0xa3fffffff pref] [ 5.310188] pci 0004:40:00.0: [1d87:3588] type 01 class 0x060400 [ 5.310204] pci 0004:40:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref] [ 5.310250] pci 0004:40:00.0: supports D1 D2 [ 5.310253] pci 0004:40:00.0: PME# supported from D0 D1 D3hot [ 5.316017] pci 0004:40:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 5.316190] pci 0004:41:00.0: [144d:a804] type 00 class 0x010802 [ 5.316273] pci 0004:41:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit] [ 5.316944] pci 0004:41:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x1 link at 0004:40:00.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link) [ 5.332280] pci_bus 0004:41: busn_res: [bus 41-4f] end is updated to 41 [ 5.332295] pci 0004:40:00.0: BAR 8: assigned [mem 0xf4200000-0xf42fffff] [ 5.332300] pci 0004:40:00.0: BAR 6: assigned [mem 0xf4300000-0xf430ffff pref] [ 5.332306] pci 0004:41:00.0: BAR 0: assigned [mem 0xf4200000-0xf4203fff 64bit] [ 5.332337] pci 0004:40:00.0: PCI bridge to [bus 41] [ 5.332341] pci 0004:40:00.0: bridge window [mem 0xf4200000-0xf42fffff] [ 5.333860] pcieport 0004:40:00.0: PME: Signaling with IRQ 125 [ 5.378519] Console: switching to colour frame buffer device 240x67 [ 5.520367] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device [ 5.520888] [drm] Initialized rockchip 3.0.0 20140818 for display-subsystem on minor 0 [ 5.527931] brd: module loaded [ 5.531434] loop: module loaded [ 5.531645] zram: Added device: zram0 [ 5.531797] lkdtm: No crash points registered, enable through debugfs [ 5.531969] system_heap: orders[0] = 6 [ 5.531972] system_heap: orders[1] = 4 [ 5.531974] system_heap: orders[2] = 0 [ 5.533015] nvme nvme0: pci function 0004:41:00.0 [ 5.533056] nvme 0004:41:00.0: enabling device (0000 -> 0002) [ 5.534621] rockchip-spi feb20000.spi: no high_speed pinctrl state [ 5.536191] rk806 spi2.0: chip id: RK806,ver:0x2, 0x1 [ 5.536330] rk806 spi2.0: ON: 0x40 OFF:0x0 [ 5.538122] rk806-regulator rk806-regulator.6.auto: Looking up vcc1-supply from device tree [ 5.538131] vdd_gpu_s0: supplied by vcc5v0_sys [ 5.538138] vcc5v0_sys: could not add device link regulator.8: -ENOENT [ 5.538875] vdd_gpu_s0: 550 <--> 950 mV at 750 mV, enabled [ 5.539283] rk806-regulator rk806-regulator.6.auto: Looking up vcc2-supply from device tree [ 5.539289] vdd_cpu_lit_s0: supplied by vcc5v0_sys [ 5.539294] vcc5v0_sys: could not add device link regulator.9: -ENOENT [ 5.539526] vdd_cpu_lit_s0: 550 <--> 950 mV at 750 mV, enabled [ 5.540069] rk806-regulator rk806-regulator.6.auto: Looking up vcc3-supply from device tree [ 5.540075] vdd_log_s0: supplied by vcc5v0_sys [ 5.540080] vcc5v0_sys: could not add device link regulator.10: -ENOENT [ 5.540313] vdd_log_s0: 675 <--> 750 mV at 750 mV, enabled [ 5.540774] rk806-regulator rk806-regulator.6.auto: Looking up vcc4-supply from device tree [ 5.540780] vdd_vdenc_s0: supplied by vcc5v0_sys [ 5.540785] vcc5v0_sys: could not add device link regulator.11: -ENOENT [ 5.541016] vdd_vdenc_s0: 550 <--> 950 mV at 750 mV, enabled [ 5.541538] rk806-regulator rk806-regulator.6.auto: Looking up vcc5-supply from device tree [ 5.541545] vdd_ddr_s0: supplied by vcc5v0_sys [ 5.541549] vcc5v0_sys: could not add device link regulator.12: -ENOENT [ 5.541784] vdd_ddr_s0: 675 <--> 900 mV at 850 mV, enabled [ 5.541987] rk806-regulator rk806-regulator.6.auto: Looking up vcc6-supply from device tree [ 5.541993] vdd2_ddr_s3: supplied by vcc5v0_sys [ 5.541998] vcc5v0_sys: could not add device link regulator.13: -ENOENT [ 5.542284] vdd2_ddr_s3: at 500 mV, enabled [ 5.542639] rk806-regulator rk806-regulator.6.auto: Looking up vcc7-supply from device tree [ 5.542645] vdd_2v0_pldo_s3: supplied by vcc5v0_sys [ 5.542650] vcc5v0_sys: could not add device link regulator.14: -ENOENT [ 5.542887] vdd_2v0_pldo_s3: 2000 mV, enabled [ 5.543231] rk806-regulator rk806-regulator.6.auto: Looking up vcc8-supply from device tree [ 5.543237] vcc_3v3_s3: supplied by vcc5v0_sys [ 5.543242] vcc5v0_sys: could not add device link regulator.15: -ENOENT [ 5.543481] vcc_3v3_s3: 3300 mV, enabled [ 5.543802] rk806-regulator rk806-regulator.6.auto: Looking up vcc9-supply from device tree [ 5.543808] vddq_ddr_s0: supplied by vcc5v0_sys [ 5.543813] vcc5v0_sys: could not add device link regulator.16: -ENOENT [ 5.544099] vddq_ddr_s0: at 500 mV, enabled [ 5.544451] rk806-regulator rk806-regulator.6.auto: Looking up vcc10-supply from device tree [ 5.544457] vcc_1v8_s3: supplied by vcc5v0_sys [ 5.544461] vcc5v0_sys: could not add device link regulator.17: -ENOENT [ 5.544707] vcc_1v8_s3: 1800 mV, enabled [ 5.545152] rk806-regulator rk806-regulator.6.auto: Looking up vcc13-supply from device tree [ 5.545248] vdd_0v75_s3: supplied by vcc_1v1_nldo_s3 [ 5.545255] vcc_1v1_nldo_s3: could not add device link regulator.18: -ENOENT [ 5.545509] vdd_0v75_s3: 750 mV, enabled [ 5.545960] rk806-regulator rk806-regulator.6.auto: Looking up vcc13-supply from device tree [ 5.545968] vdd_ddr_pll_s0: supplied by vcc_1v1_nldo_s3 [ 5.545973] vcc_1v1_nldo_s3: could not add device link regulator.19: -ENOENT [ 5.546236] vdd_ddr_pll_s0: 850 mV, enabled [ 5.546523] avdd_0v75_s0: Bringing 750000uV into 837500-837500uV [ 5.546676] avdd_0v75_s0: ramp_delay not set [ 5.546749] rk806-regulator rk806-regulator.6.auto: Looking up vcc13-supply from device tree [ 5.546756] avdd_0v75_s0: supplied by vcc_1v1_nldo_s3 [ 5.546761] vcc_1v1_nldo_s3: could not add device link regulator.20: -ENOENT [ 5.546995] avdd_0v75_s0: 837 mV, enabled [ 5.547351] rk806-regulator rk806-regulator.6.auto: Looking up vcc14-supply from device tree [ 5.547357] vdd_0v85_s0: supplied by vcc_1v1_nldo_s3 [ 5.547362] vcc_1v1_nldo_s3: could not add device link regulator.21: -ENOENT [ 5.547595] vdd_0v85_s0: 850 mV, enabled [ 5.547942] rk806-regulator rk806-regulator.6.auto: Looking up vcc14-supply from device tree [ 5.547949] vdd_0v75_s0: supplied by vcc_1v1_nldo_s3 [ 5.547954] vcc_1v1_nldo_s3: could not add device link regulator.22: -ENOENT [ 5.548185] vdd_0v75_s0: 750 mV, enabled [ 5.548592] rk806-regulator rk806-regulator.6.auto: Looking up vcc11-supply from device tree [ 5.548629] avcc_1v8_s0: supplied by vdd_2v0_pldo_s3 [ 5.548635] vdd_2v0_pldo_s3: could not add device link regulator.23: -ENOENT [ 5.548937] avcc_1v8_s0: 1800 mV, enabled [ 5.549343] rk806-regulator rk806-regulator.6.auto: Looking up vcc11-supply from device tree [ 5.549350] vcc_1v8_s0: supplied by vdd_2v0_pldo_s3 [ 5.549355] vdd_2v0_pldo_s3: could not add device link regulator.24: -ENOENT [ 5.549664] vcc_1v8_s0: 1800 mV, enabled [ 5.549998] rk806-regulator rk806-regulator.6.auto: Looking up vcc11-supply from device tree [ 5.550005] avdd_1v2_s0: supplied by vdd_2v0_pldo_s3 [ 5.550010] vdd_2v0_pldo_s3: could not add device link regulator.25: -ENOENT [ 5.550328] avdd_1v2_s0: 1200 mV, enabled [ 5.550671] rk806-regulator rk806-regulator.6.auto: Looking up vcc12-supply from device tree [ 5.550678] vcc_3v3_s0: supplied by vcc5v0_sys [ 5.550683] vcc5v0_sys: could not add device link regulator.26: -ENOENT [ 5.550914] vcc_3v3_s0: 3300 mV, enabled [ 5.551256] rk806-regulator rk806-regulator.6.auto: Looking up vcc12-supply from device tree [ 5.551263] vccio_sd_s0: supplied by vcc5v0_sys [ 5.551267] vcc5v0_sys: could not add device link regulator.27: -ENOENT [ 5.551502] vccio_sd_s0: 1800 <--> 3300 mV at 3300 mV, enabled [ 5.551854] rk806-regulator rk806-regulator.6.auto: Looking up vcca-supply from device tree [ 5.551860] pldo6_s3: supplied by vcc5v0_sys [ 5.551865] vcc5v0_sys: could not add device link regulator.28: -ENOENT [ 5.552104] pldo6_s3: 1800 mV, enabled [ 5.552441] rk806 spi2.0: no sleep-setting state [ 5.552445] rk806 spi2.0: no reset-setting pinctrl state [ 5.552448] rk806 spi2.0: no dvs-setting pinctrl state [ 5.553991] rockchip-spi feb20000.spi: register misc device rkspi-dev2 [ 5.553996] rockchip-spi feb20000.spi: probed, poll=0, rsd=0 [ 5.556118] spi-nor spi5.0: XM25QU128C (16384 Kbytes) read_data x4 [ 5.556151] 1 fixed-partitions partitions found on MTD device sfc_nor [ 5.556157] Creating 1 MTD partitions on "sfc_nor": [ 5.556167] 0x000000000000-0x000001000000 : "loader" [ 5.558315] rk_gmac-dwmac fe1c0000.ethernet: IRQ eth_lpi not found [ 5.558464] rk_gmac-dwmac fe1c0000.ethernet: Looking up phy-supply from device tree [ 5.558477] rk_gmac-dwmac fe1c0000.ethernet: Looking up phy-supply property in node /ethernet@fe1c0000 failed [ 5.558490] rk_gmac-dwmac fe1c0000.ethernet: no regulator found [ 5.558494] rk_gmac-dwmac fe1c0000.ethernet: clock input or output? (output). [ 5.558499] rk_gmac-dwmac fe1c0000.ethernet: TX delay(0x42). [ 5.558503] rk_gmac-dwmac fe1c0000.ethernet: Can not read property: rx_delay. [ 5.558507] rk_gmac-dwmac fe1c0000.ethernet: set rx_delay to 0xffffffff [ 5.558515] rk_gmac-dwmac fe1c0000.ethernet: integrated PHY? (no). [ 5.558520] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_rx [ 5.558525] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_tx [ 5.558539] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock clk_mac_speed [ 5.558760] rk_gmac-dwmac fe1c0000.ethernet: init for RGMII_RXID [ 5.558898] rk_gmac-dwmac fe1c0000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 5.558904] rk_gmac-dwmac fe1c0000.ethernet: DWMAC4/5 [ 5.558908] rk_gmac-dwmac fe1c0000.ethernet: DMA HW capability register supported [ 5.558912] rk_gmac-dwmac fe1c0000.ethernet: RX Checksum Offload Engine supported [ 5.558915] rk_gmac-dwmac fe1c0000.ethernet: TX Checksum insertion supported [ 5.558919] rk_gmac-dwmac fe1c0000.ethernet: Wake-Up On Lan supported [ 5.558952] rk_gmac-dwmac fe1c0000.ethernet: TSO supported [ 5.558956] rk_gmac-dwmac fe1c0000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 5.558960] rk_gmac-dwmac fe1c0000.ethernet: Enabled Flow TC (entries=2) [ 5.558963] rk_gmac-dwmac fe1c0000.ethernet: TSO feature enabled [ 5.558967] rk_gmac-dwmac fe1c0000.ethernet: Using 32 bits DMA width [ 5.559033] nvme nvme0: 7/0/0 default/read/poll queues [ 5.630140] nvme0n1: p1 p2 [ 5.699369] usbcore: registered new interface driver rndis_wlan [ 5.699392] usbcore: registered new interface driver asix [ 5.699407] usbcore: registered new interface driver cdc_ether [ 5.699423] usbcore: registered new interface driver rndis_host [ 5.699444] usbcore: registered new interface driver cdc_ncm [ 5.704307] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up usb-supply from device tree [ 5.704334] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up usb-supply property in node /power-management@fd8d8000/power-controller failed [ 5.706125] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 5.706134] ehci-pci: EHCI PCI platform driver [ 5.706161] ehci-platform: EHCI generic platform driver [ 5.708173] ehci-platform fc800000.usb: EHCI Host Controller [ 5.708203] ehci-platform fc800000.usb: new USB bus registered, assigned bus number 1 [ 5.708352] ehci-platform fc800000.usb: irq 20, io mem 0xfc800000 [ 5.720073] ehci-platform fc800000.usb: USB 2.0 started, EHCI 1.00 [ 5.720368] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 5.720378] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.720386] usb usb1: Product: EHCI Host Controller [ 5.720394] usb usb1: Manufacturer: Linux 5.10.160-rk35xx ehci_hcd [ 5.720401] usb usb1: SerialNumber: fc800000.usb [ 5.720975] hub 1-0:1.0: USB hub found [ 5.721024] hub 1-0:1.0: 1 port detected [ 5.724010] ehci-platform fc880000.usb: EHCI Host Controller [ 5.724038] ehci-platform fc880000.usb: new USB bus registered, assigned bus number 2 [ 5.724194] ehci-platform fc880000.usb: irq 22, io mem 0xfc880000 [ 5.736733] ehci-platform fc880000.usb: USB 2.0 started, EHCI 1.00 [ 5.737028] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 5.737039] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.737047] usb usb2: Product: EHCI Host Controller [ 5.737055] usb usb2: Manufacturer: Linux 5.10.160-rk35xx ehci_hcd [ 5.737062] usb usb2: SerialNumber: fc880000.usb [ 5.737589] hub 2-0:1.0: USB hub found [ 5.737636] hub 2-0:1.0: 1 port detected [ 5.738707] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 5.738728] ohci-platform: OHCI generic platform driver [ 5.739082] ohci-platform fc840000.usb: Generic Platform OHCI controller [ 5.739110] ohci-platform fc840000.usb: new USB bus registered, assigned bus number 3 [ 5.739217] ohci-platform fc840000.usb: irq 21, io mem 0xfc840000 [ 5.797658] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10 [ 5.797669] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.797677] usb usb3: Product: Generic Platform OHCI controller [ 5.797684] usb usb3: Manufacturer: Linux 5.10.160-rk35xx ohci_hcd [ 5.797692] usb usb3: SerialNumber: fc840000.usb [ 5.798218] hub 3-0:1.0: USB hub found [ 5.798268] hub 3-0:1.0: 1 port detected [ 5.798982] ohci-platform fc8c0000.usb: Generic Platform OHCI controller [ 5.799004] ohci-platform fc8c0000.usb: new USB bus registered, assigned bus number 4 [ 5.799110] ohci-platform fc8c0000.usb: irq 23, io mem 0xfc8c0000 [ 5.857637] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10 [ 5.857648] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.857656] usb usb4: Product: Generic Platform OHCI controller [ 5.857664] usb usb4: Manufacturer: Linux 5.10.160-rk35xx ohci_hcd [ 5.857672] usb usb4: SerialNumber: fc8c0000.usb [ 5.858197] hub 4-0:1.0: USB hub found [ 5.858245] hub 4-0:1.0: 1 port detected [ 5.859814] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 5.859837] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 5 [ 5.859977] xhci-hcd xhci-hcd.7.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000200002010010 [ 5.860060] xhci-hcd xhci-hcd.7.auto: irq 139, io mem 0xfcd00000 [ 5.860466] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 5.860476] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.860484] usb usb5: Product: xHCI Host Controller [ 5.860492] usb usb5: Manufacturer: Linux 5.10.160-rk35xx xhci-hcd [ 5.860499] usb usb5: SerialNumber: xhci-hcd.7.auto [ 5.861029] hub 5-0:1.0: USB hub found [ 5.861080] hub 5-0:1.0: 1 port detected [ 5.861498] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 5.861520] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 6 [ 5.861537] xhci-hcd xhci-hcd.7.auto: Host supports USB 3.0 SuperSpeed [ 5.861641] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM. [ 5.861824] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 [ 5.861834] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.861842] usb usb6: Product: xHCI Host Controller [ 5.861850] usb usb6: Manufacturer: Linux 5.10.160-rk35xx xhci-hcd [ 5.861858] usb usb6: SerialNumber: xhci-hcd.7.auto [ 5.862401] hub 6-0:1.0: USB hub found [ 5.862449] hub 6-0:1.0: 1 port detected [ 5.862994] usbcore: registered new interface driver cdc_acm [ 5.863001] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 5.863228] usbcore: registered new interface driver uas [ 5.863418] usbcore: registered new interface driver usb-storage [ 5.864920] Error: Driver 'Goodix-TS' is already registered, aborting... [ 5.865000] usbcore: registered new interface driver usbtouchscreen [ 5.866574] input: rk805 pwrkey as /devices/platform/feb20000.spi/spi_master/spi2/spi2.0/rk805-pwrkey.5.auto/input/input0 [ 5.866929] i2c /dev entries driver [ 5.870663] rk860-regulator 0-0042: Looking up vin-supply from device tree [ 5.870671] vdd_cpu_big0_s0: supplied by vcc5v0_sys [ 5.870677] vcc5v0_sys: could not add device link regulator.29: -ENOENT [ 5.874786] vdd_cpu_big0_s0: 550 <--> 1050 mV at 800 mV, enabled [ 5.879314] rk860-regulator 0-0043: Looking up vin-supply from device tree [ 5.879320] vdd_cpu_big1_s0: supplied by vcc5v0_sys [ 5.879325] vcc5v0_sys: could not add device link regulator.30: -ENOENT [ 5.883424] vdd_cpu_big1_s0: 550 <--> 1050 mV at 800 mV, enabled [ 5.885665] Goodix-TS 2-0014: Looking up AVDD28-supply from device tree [ 5.885674] Goodix-TS 2-0014: Looking up AVDD28-supply property in node /i2c@feaa0000/touchscreen@14 failed [ 5.885686] Goodix-TS 2-0014: supply AVDD28 not found, using dummy regulator [ 5.885752] Goodix-TS 2-0014: Looking up VDDIO-supply from device tree [ 5.885759] Goodix-TS 2-0014: Looking up VDDIO-supply property in node /i2c@feaa0000/touchscreen@14 failed [ 5.885768] Goodix-TS 2-0014: supply VDDIO not found, using dummy regulator [ 5.976863] Goodix-TS 2-0014: i2c test failed attempt 1: -6 [ 6.003525] Goodix-TS 2-0014: i2c test failed attempt 2: -6 [ 6.030045] Goodix-TS 2-0014: I2C communication failure: -6 [ 6.033222] rk860-regulator 2-0042: Looking up vin-supply from device tree [ 6.033229] vdd_npu_s0: supplied by vcc5v0_sys [ 6.033235] vcc5v0_sys: could not add device link regulator.31: -ENOENT [ 6.037306] vdd_npu_s0: 550 <--> 950 mV at 800 mV, enabled [ 6.040282] typec_fusb302 6-0022: Looking up vbus-supply from device tree [ 6.067679] rtc-hym8563 6-0051: rtc information is valid [ 6.073001] rtc-hym8563 6-0051: registered as rtc0 [ 6.074015] rtc-hym8563 6-0051: setting system clock to 2023-08-07T17:49:23 UTC (1691430563) [ 6.076662] Goodix-TS 7-0014: Looking up AVDD28-supply from device tree [ 6.076671] Goodix-TS 7-0014: Looking up AVDD28-supply property in node /i2c@fec90000/touchscreen@14 failed [ 6.076684] Goodix-TS 7-0014: supply AVDD28 not found, using dummy regulator [ 6.076755] Goodix-TS 7-0014: Looking up VDDIO-supply from device tree [ 6.076762] Goodix-TS 7-0014: Looking up VDDIO-supply property in node /i2c@fec90000/touchscreen@14 failed [ 6.076771] Goodix-TS 7-0014: supply VDDIO not found, using dummy regulator [ 6.170204] Goodix-TS 7-0014: i2c test failed attempt 1: -6 [ 6.196860] Goodix-TS 7-0014: i2c test failed attempt 2: -6 [ 6.223379] Goodix-TS 7-0014: I2C communication failure: -6 [ 6.224383] rkcifhw fdce0000.rkcif: Adding to iommu group 16 [ 6.224743] rkcifhw fdce0000.rkcif: No reserved memory region assign to CIF [ 6.225894] rkisp_hw fdcb0000.rkisp: Adding to iommu group 14 [ 6.226003] rkisp_hw fdcb0000.rkisp: is_thunderboot: 0 [ 6.226007] rkisp_hw fdcb0000.rkisp: max input:0x0@0fps [ 6.226012] rkisp_hw fdcb0000.rkisp: Missing rockchip,grf property [ 6.226114] rkisp_hw fdcb0000.rkisp: no find phandle sram [ 6.226182] rkisp_hw fdcc0000.rkisp: Adding to iommu group 15 [ 6.226332] rkisp_hw fdcc0000.rkisp: is_thunderboot: 0 [ 6.226336] rkisp_hw fdcc0000.rkisp: max input:0x0@0fps [ 6.226340] rkisp_hw fdcc0000.rkisp: Missing rockchip,grf property [ 6.226431] rkisp_hw fdcc0000.rkisp: no find phandle sram [ 6.227390] usbcore: registered new interface driver uvcvideo [ 6.227393] USB Video Class driver (1.1.1) [ 6.229287] cpu cpu0: Looking up cpu-supply from device tree [ 6.230263] cpu cpu0: bin=0 [ 6.230463] cpu cpu0: leakage=8 [ 6.230508] cpu cpu0: Looking up cpu-supply from device tree [ 6.232111] cpu cpu0: pvtm=1380 [ 6.232370] cpu cpu0: pvtm-volt-sel=0 [ 6.232440] cpu cpu0: Looking up cpu-supply from device tree [ 6.232725] cpu cpu0: Looking up mem-supply from device tree [ 6.233082] cpu cpu4: Looking up cpu-supply from device tree [ 6.235198] cpu cpu4: bin=0 [ 6.235390] cpu cpu4: leakage=6 [ 6.235429] cpu cpu4: Looking up cpu-supply from device tree [ 6.242243] cpu cpu4: pvtm=1587 [ 6.246420] cpu cpu4: pvtm-volt-sel=0 [ 6.246510] cpu cpu4: Looking up cpu-supply from device tree [ 6.247122] cpu cpu4: Looking up mem-supply from device tree [ 6.247824] cpu cpu6: Looking up cpu-supply from device tree [ 6.249791] cpu cpu6: bin=0 [ 6.249982] cpu cpu6: leakage=6 [ 6.250022] cpu cpu6: Looking up cpu-supply from device tree [ 6.256840] cpu cpu6: pvtm=1589 [ 6.261028] cpu cpu6: pvtm-volt-sel=0 [ 6.261118] cpu cpu6: Looking up cpu-supply from device tree [ 6.261730] cpu cpu6: Looking up mem-supply from device tree [ 6.264105] cpu cpu0: avs=0 [ 6.266163] cpu cpu4: avs=0 [ 6.268220] cpu cpu6: avs=0 [ 6.268623] cpu cpu0: EM: OPP:816000 is inefficient [ 6.268631] cpu cpu0: EM: OPP:600000 is inefficient [ 6.268879] cpu cpu0: EM: created perf domain [ 6.268958] cpu cpu0: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=1608000000 h_table=0 [ 6.270119] cpu cpu4: EM: OPP:816000 is inefficient [ 6.270130] cpu cpu4: EM: OPP:600000 is inefficient [ 6.270506] cpu cpu4: EM: created perf domain [ 6.270584] cpu cpu4: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0 [ 6.273407] usb 3-1: new full-speed USB device number 2 using ohci-platform [ 6.279698] cpu cpu6: EM: OPP:816000 is inefficient [ 6.279709] cpu cpu6: EM: OPP:600000 is inefficient [ 6.280136] cpu cpu6: EM: created perf domain [ 6.280828] cpu cpu6: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0 [ 6.292760] sdhci: Secure Digital Host Controller Interface driver [ 6.292764] sdhci: Copyright(c) Pierre Ossman [ 6.292766] Synopsys Designware Multimedia Card Interface Driver [ 6.293321] sdhci-pltfm: SDHCI platform and OF driver helper [ 6.295572] ledtrig-cpu: registered to indicate activity on CPUs [ 6.295601] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active. [ 6.295648] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 6.296632] cryptodev: driver 1.12 loaded. [ 6.296669] hid: raw HID events driver (C) Jiri Kosina [ 6.297122] usbcore: registered new interface driver usbhid [ 6.297125] usbhid: USB HID core driver [ 6.297489] ashmem: initialized [ 6.301893] rockchip-saradc fec10000.saradc: Looking up vref-supply from device tree [ 6.303275] optee: probing for conduit method. [ 6.303281] optee: api uid mismatch [ 6.303293] optee: probe of firmware:optee failed with error -22 [ 6.304423] usbcore: registered new interface driver snd-usb-audio [ 6.310273] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up audio-supply from device tree [ 6.310309] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up audio-supply property in node /power-management@fd8d8000/power-controller failed [ 6.313554] debugfs: File 'Capture' in directory 'dapm' already present! [ 6.315318] input: rockchip-dp0 rockchip-dp0 as /devices/platform/dp0-sound/sound/card0/input1 [ 6.317665] input: rockchip-hdmi0 rockchip-hdmi0 as /devices/platform/hdmi0-sound/sound/card1/input2 [ 6.319105] input: headset-keys as /devices/platform/es8388-sound/input/input3 [ 6.331738] ES8323 6-0010: ASoC: error at soc_component_write_no_lock on ES8323.6-0010: -5 [ 6.387721] input: rockchip-es8388 Headset as /devices/platform/es8388-sound/sound/card2/input4 [ 6.388375] Initializing XFRM netlink socket [ 6.388389] NET: Registered protocol family 17 [ 6.388831] [BT_RFKILL]: Enter rfkill_rk_init [ 6.388835] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 6.389246] Key type dns_resolver registered [ 6.390703] registered taskstats version 1 [ 6.390711] Loading compiled-in X.509 certificates [ 6.391469] Btrfs loaded, crc32c=crc32c-generic [ 6.391581] pstore: Using crash dump compression: deflate [ 6.391815] rga3_core0 fdb60000.rga: Adding to iommu group 2 [ 6.391999] rga: rga3_core0, irq = 35, match scheduler [ 6.392500] rga: rga3_core0 hardware loaded successfully, hw_version:3.0.76831. [ 6.392547] rga: rga3_core0 probe successfully [ 6.392849] rga3_core1 fdb70000.rga: Adding to iommu group 3 [ 6.393012] rga: rga3_core1, irq = 36, match scheduler [ 6.393553] rga: rga3_core1 hardware loaded successfully, hw_version:3.0.76831. [ 6.393602] rga: rga3_core1 probe successfully [ 6.393938] rga: rga2, irq = 37, match scheduler [ 6.394516] rga: rga2 hardware loaded successfully, hw_version:3.2.63318. [ 6.394525] rga: rga2 probe successfully [ 6.394725] rga_iommu: IOMMU binding successfully, default mapping core[0x1] [ 6.394935] rga: Module initialized. v1.2.25 [ 6.443937] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up gpu-supply from device tree [ 6.443955] reg-fixed-voltage combophy-avdd0v85: Looking up vin-supply from device tree [ 6.444123] combophy_avdd0v85: supplied by vdd_0v85_s0 [ 6.444137] vdd_0v85_s0: could not add device link regulator.32: -ENOENT [ 6.444158] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up gpu-supply property in node /power-management@fd8d8000/power-controller failed [ 6.444346] mali fb000000.gpu: Kernel DDK version g17p0-01eac0 [ 6.444433] mali fb000000.gpu: Looking up mali-supply from device tree [ 6.444541] combophy_avdd0v85: 850 mV, enabled [ 6.444613] mali fb000000.gpu: Looking up mem-supply from device tree [ 6.444721] mali fb000000.gpu: Looking up mali-supply from device tree [ 6.444749] vdd_gpu_s0: could not add device link fb000000.gpu: -EEXIST [ 6.444756] vdd_gpu_s0: Failed to create debugfs directory [ 6.444765] mali fb000000.gpu: Looking up mem-supply from device tree [ 6.444786] vdd_gpu_s0: could not add device link fb000000.gpu: -EEXIST [ 6.444792] vdd_gpu_s0: Failed to create debugfs directory [ 6.444918] reg-fixed-voltage combophy-avdd0v85: combophy_avdd0v85 supplying 850000uV [ 6.444960] mali fb000000.gpu: Looking up mali-supply from device tree [ 6.444987] vdd_gpu_s0: could not add device link fb000000.gpu: -EEXIST [ 6.444993] vdd_gpu_s0: Failed to create debugfs directory [ 6.445288] reg-fixed-voltage combophy-avdd1v8: Looking up vin-supply from device tree [ 6.445310] mali fb000000.gpu: bin=0 [ 6.445391] combophy_avdd1v8: supplied by avcc_1v8_s0 [ 6.445403] avcc_1v8_s0: could not add device link regulator.33: -ENOENT [ 6.445562] mali fb000000.gpu: leakage=13 [ 6.445605] mali fb000000.gpu: Looking up mali-supply from device tree [ 6.445632] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present! [ 6.445641] combophy_avdd1v8: 1800 mV, enabled [ 6.445938] reg-fixed-voltage combophy-avdd1v8: combophy_avdd1v8 supplying 1800000uV [ 6.446156] vcc_3v3_sd_s0: 3300 mV, disabled [ 6.446327] reg-fixed-voltage vcc-3v3-sd-s0: Looking up vin-supply from device tree [ 6.446344] vcc_3v3_sd_s0: supplied by vcc_3v3_s3 [ 6.446617] reg-fixed-voltage vcc-3v3-sd-s0: vcc_3v3_sd_s0 supplying 3300000uV [ 6.447258] mali fb000000.gpu: pvtm=847 [ 6.447659] mali fb000000.gpu: pvtm-volt-sel=2 [ 6.447818] rockchip-dmc dmc: Looking up center-supply from device tree [ 6.448165] rockchip-dmc dmc: Looking up mem-supply from device tree [ 6.448520] rockchip-dmc dmc: Looking up center-supply from device tree [ 6.448549] vdd_ddr_s0: could not add device link dmc: -EEXIST [ 6.448555] vdd_ddr_s0: Failed to create debugfs directory [ 6.448749] rockchip-dmc dmc: Looking up mem-supply from device tree [ 6.448778] vdd_log_s0: could not add device link dmc: -EEXIST [ 6.448784] vdd_log_s0: Failed to create debugfs directory [ 6.449063] mali fb000000.gpu: avs=0 [ 6.449197] rockchip-dmc dmc: leakage=30 [ 6.449215] rockchip-dmc dmc: leakage-volt-sel=0 [ 6.449547] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 143; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available. [ 6.449929] rockchip-dmc dmc: avs=0 [ 6.449950] rockchip-dmc dmc: current ATF version 0x100 [ 6.450245] rockchip-dmc dmc: normal_rate = 1560000000 [ 6.450255] rockchip-dmc dmc: reboot_rate = 2112000000 [ 6.450263] rockchip-dmc dmc: suspend_rate = 528000000 [ 6.450272] rockchip-dmc dmc: video_4k_rate = 1560000000 [ 6.450280] rockchip-dmc dmc: video_4k_10b_rate = 1560000000 [ 6.450288] rockchip-dmc dmc: video_svep_rate = 1560000000 [ 6.450296] rockchip-dmc dmc: boost_rate = 2112000000 [ 6.450304] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 2112000000 [ 6.450312] rockchip-dmc dmc: performance_rate = 2112000000 [ 6.450322] rockchip-dmc dmc: hdmirx_rate = 2112000000 [ 6.450334] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate [ 6.450341] rockchip-dmc dmc: failed to get vop pn to msch rl [ 6.450425] mali fb000000.gpu: GPU hardware issue table may need updating: r0p0 status 5 is unknown; treating as r0p0 status 0 [ 6.450438] mali fb000000.gpu: GPU identified as 0x7 arch 10.8.6 r0p0 status 0 [ 6.450513] mali fb000000.gpu: No priority control manager is configured [ 6.450533] rockchip-dmc dmc: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0 [ 6.450935] mali fb000000.gpu: No memory group manager is configured [ 6.450982] mali fb000000.gpu: Protected memory allocator not available [ 6.451018] rockchip-dmc dmc: could not find power_model node [ 6.452170] mali fb000000.gpu: Capping CSF_FIRMWARE_TIMEOUT to CSF_FIRMWARE_PING_TIMEOUT [ 6.453193] mali fb000000.gpu: Couldn't find power_model DT node matching 'arm,mali-simple-power-model' [ 6.453206] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.static-coefficient = 1*[0] [ 6.453596] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.dynamic-coefficient = 1*[0] [ 6.453937] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.ts = 4*[0] [ 6.454256] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.thermal-zone = '' [ 6.459119] mali fb000000.gpu: Using configured power model mali-lodx-power-model, and fallback mali-simple-power-model [ 6.459283] mali fb000000.gpu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0 [ 6.460329] mali fb000000.gpu: Probed as mali0 [ 6.463107] input: adc-keys as /devices/platform/adc-keys/input/input5 [ 6.466062] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode. [ 6.466126] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller. [ 6.466138] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a [ 6.466174] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up sdio-supply from device tree [ 6.466195] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 90,32 bit host data width,256 deep fifo [ 6.466205] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up sdio-supply property in node /power-management@fd8d8000/power-controller failed [ 6.466245] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up pcie-supply from device tree [ 6.466267] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up pcie-supply property in node /power-management@fd8d8000/power-controller failed [ 6.466304] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu-supply from device tree [ 6.466315] dwmmc_rockchip fe2c0000.mmc: Looking up vmmc-supply from device tree [ 6.466427] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu-supply property in node /power-management@fd8d8000/power-controller failed [ 6.466586] dwmmc_rockchip fe2c0000.mmc: Looking up vqmmc-supply from device tree [ 6.468536] RKNPU fdab0000.npu: Adding to iommu group 0 [ 6.468690] RKNPU fdab0000.npu: RKNPU: rknpu iommu is enabled, using iommu mode [ 6.468779] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 6.469508] RKNPU fdab0000.npu: Looking up mem-supply from device tree [ 6.470186] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff] [ 6.470218] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff] [ 6.470230] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff] [ 6.471264] [drm] Initialized rknpu 0.8.5 20230202 for fdab0000.npu on minor 1 [ 6.471642] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up nputop-supply from device tree [ 6.471676] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up nputop-supply property in node /power-management@fd8d8000/power-controller failed [ 6.471756] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu1-supply from device tree [ 6.471778] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu1-supply property in node /power-management@fd8d8000/power-controller failed [ 6.471836] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu2-supply from device tree [ 6.471856] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu2-supply property in node /power-management@fd8d8000/power-controller failed [ 6.472017] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 6.472039] vdd_npu_s0: could not add device link fdab0000.npu: -EEXIST [ 6.472043] vdd_npu_s0: Failed to create debugfs directory [ 6.472638] RKNPU fdab0000.npu: Looking up mem-supply from device tree [ 6.472692] vdd_npu_s0: could not add device link fdab0000.npu: -EEXIST [ 6.472695] vdd_npu_s0: Failed to create debugfs directory [ 6.473310] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 6.473326] vdd_npu_s0: could not add device link fdab0000.npu: -EEXIST [ 6.473329] vdd_npu_s0: Failed to create debugfs directory [ 6.475660] RKNPU fdab0000.npu: RKNPU: bin=0 [ 6.475871] RKNPU fdab0000.npu: leakage=7 [ 6.475941] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 6.476012] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present! [ 6.482818] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 6.484022] RKNPU fdab0000.npu: pvtm=845 [ 6.488992] RKNPU fdab0000.npu: pvtm-volt-sel=2 [ 6.489816] usb 3-1: New USB device found, idVendor=046d, idProduct=c539, bcdDevice=39.06 [ 6.489830] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 6.489839] usb 3-1: Product: USB Receiver [ 6.489848] usb 3-1: Manufacturer: Logitech [ 6.490716] RKNPU fdab0000.npu: avs=0 [ 6.491015] RKNPU fdab0000.npu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0 [ 6.499412] input: Logitech USB Receiver as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.0/0003:046D:C539.0001/input/input6 [ 6.503066] RKNPU fdab0000.npu: failed to find power_model node [ 6.503078] RKNPU fdab0000.npu: RKNPU: failed to initialize power model [ 6.503087] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient [ 6.513718] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 6.529633] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 6.534534] rockchip-pm rockchip-suspend: not set pwm-regulator-config [ 6.534564] rockchip-suspend not set sleep-mode-config for mem-lite [ 6.534573] rockchip-suspend not set wakeup-config for mem-lite [ 6.534588] rockchip-suspend not set sleep-mode-config for mem-ultra [ 6.534595] rockchip-suspend not set wakeup-config for mem-ultra [ 6.537238] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 406; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '13:36:29', on 'Jul 6 2023'. [ 6.537963] Mali: [ 6.537970] Mali device driver loaded [ 6.537984] ALSA device list: [ 6.537995] #0: rockchip-dp0 [ 6.538004] #1: rockchip-hdmi0 [ 6.538013] #2: rockchip-es8388 [ 6.545664] Freeing unused kernel memory: 6976K [ 6.558845] hid-generic 0003:046D:C539.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-fc840000.usb-1/input0 [ 6.565918] input: Logitech USB Receiver Mouse as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input7 [ 6.580857] Run /init as init process [ 6.580877] with arguments: [ 6.580892] /init [ 6.580904] splash [ 6.580916] with environment: [ 6.580929] HOME=/ [ 6.580944] TERM=linux [ 6.580957] ubootpart= [ 6.580970] cgroup_enable=memory [ 6.580984] cgroup_memory=1 [ 6.623993] input: Logitech USB Receiver Consumer Control as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input8 [ 6.624857] input: Logitech USB Receiver System Control as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input9 [ 6.625841] hid-generic 0003:046D:C539.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-fc840000.usb-1/input1 [ 6.632050] hid-generic 0003:046D:C539.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-fc840000.usb-1/input2 [ 8.396223] EXT4-fs (nvme0n1p2): mounted filesystem with writeback data mode. Opts: (null) [ 9.219854] NET: Registered protocol family 10 [ 9.222067] Segment Routing with IPv6 [ 9.239324] systemd[1]: systemd 249.11-0ubuntu3.9 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified) [ 9.240690] systemd[1]: Detected architecture arm64. [ 9.241708] systemd[1]: Hostname set to . [ 9.486980] vendor storage:20190527 ret = -1 [ 9.568183] systemd[1]: Queued start job for default target Graphical Interface. [ 9.570260] systemd[1]: Created slice Slice /system/modprobe. [ 9.570928] systemd[1]: Created slice Slice /system/serial-getty. [ 9.571537] systemd[1]: Created slice Slice /system/systemd-fsck. [ 9.571922] systemd[1]: Created slice User and Session Slice. [ 9.572086] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 9.572482] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 9.572633] systemd[1]: Reached target User and Group Name Lookups. [ 9.572701] systemd[1]: Reached target Slice Units. [ 9.572757] systemd[1]: Reached target Swaps. [ 9.572799] systemd[1]: Reached target System Time Set. [ 9.572893] systemd[1]: Reached target Local Verity Protected Volumes. [ 9.586283] systemd[1]: Listening on RPCbind Server Activation Socket. [ 9.586612] systemd[1]: Listening on Syslog Socket. [ 9.586840] systemd[1]: Listening on fsck to fsckd communication Socket. [ 9.586963] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 9.587314] systemd[1]: Listening on Journal Audit Socket. [ 9.587496] systemd[1]: Listening on Journal Socket (/dev/log). [ 9.587736] systemd[1]: Listening on Journal Socket. [ 9.588768] systemd[1]: Listening on udev Control Socket. [ 9.588984] systemd[1]: Listening on udev Kernel Socket. [ 9.590384] systemd[1]: Mounting Huge Pages File System... [ 9.591921] systemd[1]: Mounting POSIX Message Queue File System... [ 9.593623] systemd[1]: Mounting Kernel Debug File System... [ 9.595460] systemd[1]: Mounting Kernel Trace File System... [ 9.595841] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped. [ 9.598167] systemd[1]: Starting Restore / save the current clock... [ 9.600397] systemd[1]: Starting Set the console keyboard layout... [ 9.602478] systemd[1]: Starting Create List of Static Device Nodes... [ 9.604670] systemd[1]: Starting Load Kernel Module chromeos_pstore... [ 9.606798] systemd[1]: Starting Load Kernel Module configfs... [ 9.609266] systemd[1]: Starting Load Kernel Module drm... [ 9.611864] systemd[1]: Starting Load Kernel Module efi_pstore... [ 9.614511] systemd[1]: Starting Load Kernel Module fuse... [ 9.616838] systemd[1]: Starting Load Kernel Module pstore_blk... [ 9.618870] systemd[1]: Starting Load Kernel Module pstore_zone... [ 9.620891] systemd[1]: Starting Load Kernel Module ramoops... [ 9.621276] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 9.624543] systemd[1]: Starting Load Kernel Modules... [ 9.626343] systemd[1]: Starting Remount Root and Kernel File Systems... [ 9.626888] fuse: init (API version 7.32) [ 9.628188] systemd[1]: Starting Coldplug All udev Devices... [ 9.631271] systemd[1]: Mounted Huge Pages File System. [ 9.631688] systemd[1]: Mounted POSIX Message Queue File System. [ 9.631878] systemd[1]: Mounted Kernel Debug File System. [ 9.632040] systemd[1]: Mounted Kernel Trace File System. [ 9.632718] systemd[1]: Finished Restore / save the current clock. [ 9.633543] systemd[1]: Finished Create List of Static Device Nodes. [ 9.634013] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully. [ 9.634364] systemd[1]: Finished Load Kernel Module chromeos_pstore. [ 9.634804] systemd[1]: modprobe@configfs.service: Deactivated successfully. [ 9.635143] systemd[1]: Finished Load Kernel Module configfs. [ 9.635562] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 9.635873] systemd[1]: Finished Load Kernel Module drm. [ 9.636421] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [ 9.636866] systemd[1]: Finished Load Kernel Module efi_pstore. [ 9.637325] systemd[1]: modprobe@fuse.service: Deactivated successfully. [ 9.637641] systemd[1]: Finished Load Kernel Module fuse. [ 9.638036] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully. [ 9.638368] systemd[1]: Finished Load Kernel Module pstore_blk. [ 9.638761] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully. [ 9.639097] systemd[1]: Finished Load Kernel Module pstore_zone. [ 9.639486] systemd[1]: modprobe@ramoops.service: Deactivated successfully. [ 9.639811] systemd[1]: Finished Load Kernel Module ramoops. [ 9.640357] systemd[1]: Finished Load Kernel Modules. [ 9.642122] EXT4-fs (nvme0n1p2): re-mounted. Opts: commit=600,errors=remount-ro [ 9.642249] systemd[1]: Mounting FUSE Control File System... [ 9.643938] systemd[1]: Mounting Kernel Configuration File System... [ 9.645712] systemd[1]: Starting Apply Kernel Variables... [ 9.649044] systemd[1]: Finished Remount Root and Kernel File Systems. [ 9.649514] systemd[1]: Mounted FUSE Control File System. [ 9.649788] systemd[1]: Mounted Kernel Configuration File System. [ 9.651733] systemd[1]: Starting Platform Persistent Storage Archival... [ 9.653512] systemd[1]: Starting Load/Save Random Seed... [ 9.655216] systemd[1]: Starting Create System Users... [ 9.663252] systemd[1]: Finished Apply Kernel Variables. [ 9.669391] systemd[1]: Finished Platform Persistent Storage Archival. [ 9.678387] systemd[1]: Finished Create System Users. [ 9.679044] systemd[1]: Finished Load/Save Random Seed. [ 9.679292] systemd[1]: Condition check resulted in First Boot Complete being skipped. [ 9.680388] systemd[1]: Starting Create Static Device Nodes in /dev... [ 9.688589] systemd[1]: Finished Set the console keyboard layout. [ 9.689042] systemd[1]: Finished Create Static Device Nodes in /dev. [ 9.689197] systemd[1]: Reached target Preparation for Local File Systems. [ 9.690366] systemd[1]: Mounting /tmp... [ 9.692095] systemd[1]: Starting Rule-based Manager for Device Events and Files... [ 9.695328] systemd[1]: Mounted /tmp. [ 9.752645] systemd[1]: Started Rule-based Manager for Device Events and Files. [ 9.804807] systemd[1]: Finished Coldplug All udev Devices. [ 9.806754] systemd[1]: Starting Helper to synchronize boot up for ifupdown... [ 9.808287] systemd[1]: Starting Show Plymouth Boot Screen... [ 9.811423] systemd[1]: Finished Helper to synchronize boot up for ifupdown. [ 9.827788] systemd[1]: Started Show Plymouth Boot Screen. [ 9.828078] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 9.828267] systemd[1]: Started Forward Password Requests to Plymouth Directory Watch. [ 9.828321] systemd[1]: Reached target Local Encrypted Volumes. [ 9.865844] systemd[1]: Created slice Slice /system/systemd-backlight. [ 9.868885] systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:backlight_1... [ 9.879189] systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:backlight_1. [ 9.882856] systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:backlight... [ 9.889141] systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:backlight. [ 9.962597] systemd[1]: Found device Samsung SSD 960 EVO 500GB armbi_boot. [ 9.963434] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 9.963513] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 9.965069] systemd[1]: Starting File System Check on /dev/disk/by-uuid/1BD1-7F33... [ 9.972238] systemd[1]: Started File System Check Daemon to report status. [ 9.996564] systemd[1]: Found device /dev/ttyFIQ0. [ 10.008203] systemd[1]: Finished File System Check on /dev/disk/by-uuid/1BD1-7F33. [ 10.010026] systemd[1]: Mounting /boot... [ 10.011976] FAT-fs (nvme0n1p1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive! [ 10.016856] systemd[1]: Mounted /boot. [ 10.017285] systemd[1]: Reached target Local File Systems. [ 10.020548] systemd[1]: Starting Armbian leds state... [ 10.023938] systemd[1]: Starting Armbian ZRAM config... [ 10.027496] systemd[1]: Starting Set console font and keymap... [ 10.030955] systemd[1]: Starting Raise network interfaces... [ 10.034527] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data... [ 10.034821] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped. [ 10.035363] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. [ 10.035406] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 10.035444] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 10.036084] systemd[1]: Finished Set console font and keymap. [ 10.037589] systemd[1]: Finished Armbian leds state. [ 10.042105] systemd[1]: Reached target Hardware activated USB gadget. [ 10.045644] systemd[1]: Received SIGRTMIN+20 from PID 298 (plymouthd). [ 10.047312] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data. [ 10.055197] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 10.055317] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. [ 10.055343] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 10.055378] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 10.075521] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 10.120483] zram0: detected capacity change from 0 to 4031107072 [ 10.156907] Adding 3936624k swap on /dev/zram0. Priority:5 extents:1 across:3936624k SS [ 10.164294] zram: Added device: zram1 [ 10.179607] systemd[1]: Finished Raise network interfaces. [ 10.268906] zram1: detected capacity change from 0 to 52428800 [ 10.299108] systemd[1]: Finished Armbian ZRAM config. [ 10.302978] systemd[1]: Starting Armbian memory supported logging... [ 10.348262] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard [ 11.838362] systemd[1]: Finished Armbian memory supported logging. [ 11.847079] systemd[1]: Starting Journal Service... [ 11.988898] systemd[1]: Started Journal Service. [ 12.017624] systemd-journald[720]: Received client request to flush runtime journal. ### armbian-release: # PLEASE DO NOT EDIT THIS FILE BOARD=orangepi5 BOARD_NAME="Orange Pi 5" BOARDFAMILY=rockchip-rk3588 BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=bfc8271 VERSION=23.08.0-trunk LINUXFAMILY=rk35xx ARCH=arm64 IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm64 KERNEL_IMAGE_TYPE=Image FORCE_BOOTSCRIPT_UPDATE= VENDOR=Armbian REVISION=23.08.0-trunk BOOTSCRIPT_FORCE_UPDATE="no" BOOTSCRIPT_DST="boot.cmd" BRANCH=legacy ### boot environment: verbosity=1 bootlogo=true overlay_prefix=rockchip-rk3588 fdtfile=rockchip/rk3588s-orangepi-5.dtb rootdev=UUID=329a3cf7-a8ce-4ea6-a3ef-c2128bda1678 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u ### lsusb: Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 002: ID 046d:c539 Logitech, Inc. USB Receiver Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub ### lscpu: Architecture: aarch64 CPU op-mode(s): 32-bit, 64-bit Byte Order: Little Endian CPU(s): 8 On-line CPU(s) list: 0-7 Vendor ID: ARM Model name: Cortex-A55 Model: 0 Thread(s) per core: 1 Core(s) per socket: 4 Socket(s): 1 Stepping: r2p0 CPU max MHz: 1800.0000 CPU min MHz: 408.0000 BogoMIPS: 48.00 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp Model name: Cortex-A76 Model: 0 Thread(s) per core: 1 Core(s) per socket: 2 Socket(s): 2 Stepping: r4p0 CPU max MHz: 2256.0000 CPU min MHz: 408.0000 BogoMIPS: 48.00 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp L1d cache: 384 KiB (8 instances) L1i cache: 384 KiB (8 instances) L2 cache: 2.5 MiB (8 instances) L3 cache: 3 MiB (1 instance) Vulnerability Itlb multihit: Not affected Vulnerability L1tf: Not affected Vulnerability Mds: Not affected Vulnerability Meltdown: Not affected Vulnerability Mmio stale data: Not affected Vulnerability Retbleed: Not affected Vulnerability Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl Vulnerability Spectre v1: Mitigation; __user pointer sanitization Vulnerability Spectre v2: Vulnerable: Unprivileged eBPF enabled Vulnerability Srbds: Not affected Vulnerability Tsx async abort: Not affected ### cpuinfo: processor : 0 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 1 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 2 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 3 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 4 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 processor : 5 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 processor : 6 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 processor : 7 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 Serial : 2eae2cb9d903d20e ### meminfo: MemTotal: 7873256 kB MemFree: 7568132 kB MemAvailable: 7587736 kB Buffers: 12108 kB Cached: 80180 kB SwapCached: 0 kB Active: 23580 kB Inactive: 105828 kB Active(anon): 636 kB Inactive(anon): 66044 kB Active(file): 22944 kB Inactive(file): 39784 kB Unevictable: 19608 kB Mlocked: 0 kB SwapTotal: 3936624 kB SwapFree: 3936624 kB Dirty: 2248 kB Writeback: 0 kB AnonPages: 56624 kB Mapped: 29224 kB Shmem: 25952 kB KReclaimable: 37184 kB Slab: 78720 kB SReclaimable: 37184 kB SUnreclaim: 41536 kB KernelStack: 3872 kB PageTables: 3176 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 7873252 kB Committed_AS: 129972 kB VmallocTotal: 135290290112 kB VmallocUsed: 36636 kB VmallocChunk: 0 kB Percpu: 2752 kB CmaTotal: 262144 kB CmaAllocated: 4672 kB CmaReleased: 257472 kB CmaFree: 257472 kB HugePages_Total: 0 HugePages_Free: 0 HugePages_Rsvd: 0 HugePages_Surp: 0 Hugepagesize: 2048 kB Hugetlb: 0 kB ### virtual memory: vm.admin_reserve_kbytes = 8192 vm.block_dump = 0 vm.dirty_background_bytes = 0 vm.dirty_background_ratio = 10 vm.dirty_bytes = 0 vm.dirty_expire_centisecs = 3000 vm.dirty_ratio = 20 vm.dirtytime_expire_seconds = 43200 vm.dirty_writeback_centisecs = 500 vm.extra_free_kbytes = 0 vm.hugetlb_shm_group = 0 vm.laptop_mode = 0 vm.legacy_va_layout = 0 vm.lowmem_reserve_ratio = 256 256 32 0 vm.max_map_count = 65530 vm.min_free_kbytes = 11208 vm.mmap_min_addr = 32768 vm.mmap_rnd_bits = 18 vm.mmap_rnd_compat_bits = 11 vm.nr_hugepages = 0 vm.nr_overcommit_hugepages = 0 vm.oom_dump_tasks = 1 vm.oom_kill_allocating_task = 0 vm.overcommit_kbytes = 0 vm.overcommit_memory = 0 vm.overcommit_ratio = 50 vm.page-cluster = 0 vm.page_lock_unfairness = 5 vm.panic_on_oom = 0 vm.percpu_pagelist_fraction = 0 vm.stat_interval = 1 vm.swappiness = 100 vm.user_reserve_kbytes = 131072 vm.vfs_cache_pressure = 100 vm.watermark_boost_factor = 15000 vm.watermark_scale_factor = 10 ### ip addr: 1: lo: mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet XXX.XXX.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: eth0: mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether ae:d8:3f:81:fa:0b brd ff:ff:ff:ff:ff:ff ### partitions: major minor #blocks name 254 0 3936628 zram0 31 0 16384 mtdblock0 259 0 488386584 nvme0n1 259 1 262144 nvme0n1p1 259 2 483213312 nvme0n1p2 254 1 51200 zram1 ### df: tmpfs 769M 9.7M 760M 2% /run /dev/nvme0n1p2 454G 5.4G 444G 2% / tmpfs 3.8G 0 3.8G 0% /dev/shm tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs 3.8G 4.0K 3.8G 1% /tmp /dev/nvme0n1p1 256M 106M 151M 42% /boot /dev/zram1 47M 2.5M 41M 6% /var/log ### lsblk: NAME FSTYPE SIZE MOUNTPOINT UUID mtdblock0 16M zram1 50M /var/log nvme0n1 465.8G ├─nvme0n1p1 vfat 256M /boot 1BD1-7F33 └─nvme0n1p2 ext4 460.8G / 329a3cf7-a8ce-4ea6-a3ef-c2128bda1678 ### zramctl: NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT /dev/zram1 zstd 50M 2.5M 436K 780K 8 /var/log /dev/zram0 lzo-rle 3.8G 4K 74B 12K 8 [SWAP] ### mtab: /dev/nvme0n1p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=936,iocharset=utf8,shortname=mixed,errors=remount-ro 0 0 /dev/nvme0n1p2 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0 /dev/nvme0n1p2 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0 ### Boot system health: Time CPU_cl0/CPU_cl1 load %cpu %sys %usr %nice %io %irq Tcpu C.St. 20:49:30 1800/2256 MHz 0.16 19% 11% 6% 0% 1% 0% 41.6 °C 0/7 20:49:30 1800/2256 MHz 0.16 25% 6% 16% 0% 3% 0% 39.8 °C 0/7 20:49:30 1800/2256 MHz 0.23 17% 4% 12% 0% 0% 0% 39.8 °C 0/7 20:49:31 1800/2256 MHz 0.23 16% 4% 11% 0% 0% 0% 39.8 °C 0/7 20:49:31 1800/2256 MHz 0.23 15% 2% 12% 0% 0% 0% 39.8 °C 0/7 ### Activated 1 lzo-rle zram swap devices with 3844MB each. ### Activated Armbian ramlog partition with zstd compression Mon Aug 7 08:50:16 PM +03 2023 | Orange Pi 5 | 23.08.0-trunk | arm64 | aarch64 | 5.10.160-rk35xx ### dmesg: [ 1.763035] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [ 1.763059] Linux version 5.10.160-rk35xx (armbian@next) (aarch64-linux-gnu-gcc (Ubuntu 11.3.0-1ubuntu1~22.04) 11.3.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP Thu Jul 6 13:36:29 UTC 2023 [ 1.773864] Machine model: Orange Pi 5 [ 1.774048] efi: UEFI not found. [ 1.777701] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB [ 1.777721] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@00000000': base 0x0000000000000000, size 0 MiB [ 1.777811] Reserved memory: created CMA memory pool at 0x0000000010000000, size 256 MiB [ 1.777817] OF: reserved mem: initialized node cma, compatible id shared-dma-pool [ 1.928343] Zone ranges: [ 1.928351] DMA [mem 0x0000000000200000-0x00000000ffffffff] [ 1.928362] DMA32 empty [ 1.928368] Normal [mem 0x0000000100000000-0x00000001ffffffff] [ 1.928376] Movable zone start for each node [ 1.928379] Early memory node ranges [ 1.928385] node 0: [mem 0x0000000000200000-0x00000000efffffff] [ 1.928394] node 0: [mem 0x0000000100000000-0x00000001ffffffff] [ 1.928402] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff] [ 1.928409] On node 0 totalpages: 2031104 [ 1.928415] DMA zone: 15352 pages used for memmap [ 1.928419] DMA zone: 0 pages reserved [ 1.928424] DMA zone: 982528 pages, LIFO batch:63 [ 1.928430] Normal zone: 16384 pages used for memmap [ 1.928434] Normal zone: 1048576 pages, LIFO batch:63 [ 1.975393] psci: probing for conduit method from DT. [ 1.975406] psci: PSCIv1.1 detected in firmware. [ 1.975410] psci: Using standard PSCI v0.2 function IDs [ 1.975416] psci: MIGRATE_INFO_TYPE not supported. [ 1.975423] psci: SMC Calling Convention v1.2 [ 1.975841] percpu: Embedded 32 pages/cpu s93480 r8192 d29400 u131072 [ 1.975884] pcpu-alloc: s93480 r8192 d29400 u131072 alloc=32*4096 [ 1.975892] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7 [ 1.976034] Detected VIPT I-cache on CPU0 [ 1.976084] CPU features: detected: GIC system register CPU interface [ 1.976090] CPU features: detected: Virtualization Host Extensions [ 1.976100] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 1.976113] alternatives: patching kernel code [ 1.976494] Built 1 zonelists, mobility grouping on. Total pages: 1999368 [ 1.976505] Kernel command line: root=UUID=329a3cf7-a8ce-4ea6-a3ef-c2128bda1678 rootwait rootfstype=ext4 splash plymouth.ignore-serial-consoles console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart= usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 [ 1.977839] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) [ 1.978244] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 1.978252] mem auto-init: stack:off, heap alloc:off, heap free:off [ 1.984759] software IO TLB: mapped [mem 0x00000000ec000000-0x00000000f0000000] (64MB) [ 2.056194] Memory: 7589184K/8124416K available (16832K kernel code, 3506K rwdata, 6500K rodata, 6976K init, 639K bss, 273088K reserved, 262144K cma-reserved) [ 2.056353] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1 [ 2.056389] ftrace: allocating 64539 entries in 253 pages [ 2.166876] ftrace: allocated 253 pages with 7 groups [ 2.167181] rcu: Hierarchical RCU implementation. [ 2.167186] rcu: RCU event tracing is enabled. [ 2.167192] Rude variant of Tasks RCU enabled. [ 2.167195] Tracing variant of Tasks RCU enabled. [ 2.167202] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies. [ 2.172837] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 2.175668] GICv3: GIC: Using split EOI/Deactivate mode [ 2.175675] GICv3: 480 SPIs implemented [ 2.175680] GICv3: 0 Extended SPIs implemented [ 2.175721] GICv3: Distributor has no Range Selector support [ 2.175732] GICv3: 16 PPIs implemented [ 2.175777] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000 [ 2.175903] ITS [mem 0xfe640000-0xfe65ffff] [ 2.175960] ITS@0x00000000fe640000: allocated 8192 Devices @100200000 (indirect, esz 8, psz 64K, shr 0) [ 2.175988] ITS@0x00000000fe640000: allocated 32768 Interrupt Collections @100210000 (flat, esz 2, psz 64K, shr 0) [ 2.175998] ITS: using cache flushing for cmd queue [ 2.176041] ITS [mem 0xfe660000-0xfe67ffff] [ 2.176090] ITS@0x00000000fe660000: allocated 8192 Devices @100230000 (indirect, esz 8, psz 64K, shr 0) [ 2.176117] ITS@0x00000000fe660000: allocated 32768 Interrupt Collections @100240000 (flat, esz 2, psz 64K, shr 0) [ 2.176127] ITS: using cache flushing for cmd queue [ 2.176347] GICv3: using LPI property table @0x0000000100250000 [ 2.176477] GIC: using cache flushing for LPI property table [ 2.176487] GICv3: CPU0: using allocated LPI pending table @0x0000000100260000 [ 2.312781] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 2.312791] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 2.312801] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 2.314180] Console: colour dummy device 80x25 [ 2.314223] printk: console [tty1] enabled [ 2.314253] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000) [ 2.314265] pid_max: default: 32768 minimum: 301 [ 2.314376] LSM: Security Framework initializing [ 2.314446] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 2.314472] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 2.316727] rcu: Hierarchical SRCU implementation. [ 2.317698] Platform MSI: msi-controller@fe640000 domain created [ 2.317720] Platform MSI: msi-controller@fe660000 domain created [ 2.318103] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe640000 domain created [ 2.318129] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe660000 domain created [ 2.318313] EFI services will not be available. [ 2.318766] smp: Bringing up secondary CPUs ... [ 2.319485] Detected VIPT I-cache on CPU1 [ 2.319522] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000 [ 2.319542] GICv3: CPU1: using allocated LPI pending table @0x0000000100270000 [ 2.319587] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [ 2.320357] Detected VIPT I-cache on CPU2 [ 2.320389] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000 [ 2.320408] GICv3: CPU2: using allocated LPI pending table @0x0000000100280000 [ 2.320449] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [ 2.321180] Detected VIPT I-cache on CPU3 [ 2.321209] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000 [ 2.321227] GICv3: CPU3: using allocated LPI pending table @0x0000000100290000 [ 2.321266] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [ 2.322009] CPU features: detected: Spectre-v4 [ 2.322012] CPU features: detected: Spectre-BHB [ 2.322015] Detected PIPT I-cache on CPU4 [ 2.322031] GICv3: CPU4: found redistributor 400 region 0:0x00000000fe700000 [ 2.322041] GICv3: CPU4: using allocated LPI pending table @0x00000001002a0000 [ 2.322066] CPU4: Booted secondary processor 0x0000000400 [0x414fd0b0] [ 2.322788] Detected PIPT I-cache on CPU5 [ 2.322804] GICv3: CPU5: found redistributor 500 region 0:0x00000000fe720000 [ 2.322815] GICv3: CPU5: using allocated LPI pending table @0x00000001002b0000 [ 2.322841] CPU5: Booted secondary processor 0x0000000500 [0x414fd0b0] [ 2.323534] Detected PIPT I-cache on CPU6 [ 2.323550] GICv3: CPU6: found redistributor 600 region 0:0x00000000fe740000 [ 2.323561] GICv3: CPU6: using allocated LPI pending table @0x00000001002c0000 [ 2.323586] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b0] [ 2.324265] Detected PIPT I-cache on CPU7 [ 2.324281] GICv3: CPU7: found redistributor 700 region 0:0x00000000fe760000 [ 2.324292] GICv3: CPU7: using allocated LPI pending table @0x00000001002d0000 [ 2.324317] CPU7: Booted secondary processor 0x0000000700 [0x414fd0b0] [ 2.324396] smp: Brought up 1 node, 8 CPUs [ 2.324416] SMP: Total of 8 processors activated. [ 2.324422] CPU features: detected: Privileged Access Never [ 2.324426] CPU features: detected: User Access Override [ 2.324431] CPU features: detected: 32-bit EL0 Support [ 2.324436] CPU features: detected: Common not Private translations [ 2.324440] CPU features: detected: RAS Extension Support [ 2.324445] CPU features: detected: Data cache clean to the PoU not required for I/D coherence [ 2.324449] CPU features: detected: CRC32 instructions [ 2.324454] CPU features: detected: Speculative Store Bypassing Safe (SSBS) [ 2.324460] CPU features: detected: RCpc load-acquire (LDAPR) [ 2.324547] CPU: All CPU(s) started at EL2 [ 2.327758] devtmpfs: initialized [ 2.342618] Registered cp15_barrier emulation handler [ 2.342626] Registered setend emulation handler [ 2.342631] KASLR disabled due to lack of seed [ 2.342717] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns [ 2.342724] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 2.345476] pinctrl core: initialized pinctrl subsystem [ 2.345594] regulator-dummy: no parameters, enabled [ 2.345711] DMI not present or invalid. [ 2.346012] NET: Registered protocol family 16 [ 2.347096] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations [ 2.347220] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 2.347240] audit: initializing netlink subsys (disabled) [ 2.347331] audit: type=2000 audit(0.033:1): state=initialized audit_enabled=0 res=1 [ 2.347837] Registered FIQ tty driver [ 2.347986] thermal_sys: Registered thermal governor 'fair_share' [ 2.347988] thermal_sys: Registered thermal governor 'step_wise' [ 2.347990] thermal_sys: Registered thermal governor 'user_space' [ 2.347993] thermal_sys: Registered thermal governor 'power_allocator' [ 2.348313] cpuidle: using governor menu [ 2.348541] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 2.348675] ASID allocator initialised with 65536 entries [ 2.350159] ramoops: dmesg-0 0x20000@0x0000000000110000 [ 2.350176] ramoops: console 0x80000@0x0000000000130000 [ 2.350187] ramoops: pmsg 0x50000@0x00000000001b0000 [ 2.350233] printk: console [ramoops-1] enabled [ 2.350236] pstore: Registered ramoops as persistent store backend [ 2.350238] ramoops: using 0xf0000@0x110000, ecc: 0 [ 2.404117] rockchip-gpio fd8a0000.gpio: probed /pinctrl/gpio@fd8a0000 [ 2.404402] rockchip-gpio fec20000.gpio: probed /pinctrl/gpio@fec20000 [ 2.404643] rockchip-gpio fec30000.gpio: probed /pinctrl/gpio@fec30000 [ 2.404919] rockchip-gpio fec40000.gpio: probed /pinctrl/gpio@fec40000 [ 2.405188] rockchip-gpio fec50000.gpio: probed /pinctrl/gpio@fec50000 [ 2.405238] rockchip-pinctrl pinctrl: probed pinctrl [ 2.413918] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 2.413922] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 2.413925] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 2.413928] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 2.476104] raid6: neonx8 gen() 5370 MB/s [ 2.532862] raid6: neonx8 xor() 4169 MB/s [ 2.589622] raid6: neonx4 gen() 5505 MB/s [ 2.646383] raid6: neonx4 xor() 4183 MB/s [ 2.703143] raid6: neonx2 gen() 5049 MB/s [ 2.759903] raid6: neonx2 xor() 3946 MB/s [ 2.816663] raid6: neonx1 gen() 4220 MB/s [ 2.873424] raid6: neonx1 xor() 3252 MB/s [ 2.930199] raid6: int64x8 gen() 1305 MB/s [ 2.986949] raid6: int64x8 xor() 855 MB/s [ 3.043711] raid6: int64x4 gen() 1560 MB/s [ 3.100477] raid6: int64x4 xor() 861 MB/s [ 3.157229] raid6: int64x2 gen() 1886 MB/s [ 3.213988] raid6: int64x2 xor() 1301 MB/s [ 3.270757] raid6: int64x1 gen() 1970 MB/s [ 3.327522] raid6: int64x1 xor() 962 MB/s [ 3.327524] raid6: using algorithm neonx4 gen() 5505 MB/s [ 3.327526] raid6: .... xor() 4183 MB/s, rmw enabled [ 3.327529] raid6: using neon recovery algorithm [ 3.328134] fiq_debugger fiq_debugger.0: IRQ fiq not found [ 3.328141] fiq_debugger fiq_debugger.0: IRQ wakeup not found [ 3.328145] fiq_debugger_probe: could not install nmi irq handler [ 3.328229] printk: console [ttyFIQ0] enabled [ 3.328330] Registered fiq debugger ttyFIQ0 [ 3.328534] vcc12v_dcin: 12000 mV, enabled [ 3.328613] reg-fixed-voltage vcc12v-dcin: vcc12v_dcin supplying 12000000uV [ 3.328664] reg-fixed-voltage vcc5v0-sys: Looking up vin-supply from device tree [ 3.328668] vcc5v0_sys: supplied by vcc12v_dcin [ 3.328673] vcc12v_dcin: could not add device link regulator.2: -ENOENT [ 3.328689] vcc5v0_sys: 5000 mV, enabled [ 3.328757] reg-fixed-voltage vcc5v0-sys: vcc5v0_sys supplying 5000000uV [ 3.328804] reg-fixed-voltage vcc5v0-usbdcin: Looking up vin-supply from device tree [ 3.328808] vcc5v0_usbdcin: supplied by vcc12v_dcin [ 3.328811] vcc12v_dcin: could not add device link regulator.3: -ENOENT [ 3.328826] vcc5v0_usbdcin: 5000 mV, enabled [ 3.328892] reg-fixed-voltage vcc5v0-usbdcin: vcc5v0_usbdcin supplying 5000000uV [ 3.328937] reg-fixed-voltage vcc5v0-usb: Looking up vin-supply from device tree [ 3.328941] vcc5v0_usb: supplied by vcc5v0_usbdcin [ 3.328945] vcc5v0_usbdcin: could not add device link regulator.4: -ENOENT [ 3.328960] vcc5v0_usb: 5000 mV, enabled [ 3.329016] reg-fixed-voltage vcc5v0-usb: vcc5v0_usb supplying 5000000uV [ 3.329120] vbus5v0_typec: 5000 mV, disabled [ 3.329171] reg-fixed-voltage vbus5v0-typec: Looking up vin-supply from device tree [ 3.329175] vbus5v0_typec: supplied by vcc5v0_usb [ 3.329209] reg-fixed-voltage vbus5v0-typec: vbus5v0_typec supplying 5000000uV [ 3.329260] reg-fixed-voltage vcc-1v1-nldo-s3: Looking up vin-supply from device tree [ 3.329264] vcc_1v1_nldo_s3: supplied by vcc5v0_sys [ 3.329267] vcc5v0_sys: could not add device link regulator.6: -ENOENT [ 3.329284] vcc_1v1_nldo_s3: 1100 mV, enabled [ 3.329348] reg-fixed-voltage vcc-1v1-nldo-s3: vcc_1v1_nldo_s3 supplying 1100000uV [ 3.329400] reg-fixed-voltage vcc3v3-pcie2x1l2: Looking up vin-supply from device tree [ 3.329404] vcc3v3_pcie2x1l2: supplied by vcc5v0_sys [ 3.329408] vcc5v0_sys: could not add device link regulator.7: -ENOENT [ 3.385007] vcc3v3_pcie2x1l2: 1800 mV, enabled [ 3.385075] reg-fixed-voltage vcc3v3-pcie2x1l2: vcc3v3_pcie2x1l2 supplying 1800000uV [ 3.385357] iommu: Default domain type: Translated [ 3.385794] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vdpu-supply from device tree [ 3.385813] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vdpu-supply property in node /power-management@fd8d8000/power-controller failed [ 3.386084] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga30-supply from device tree [ 3.386102] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga30-supply property in node /power-management@fd8d8000/power-controller failed [ 3.386281] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga31-supply from device tree [ 3.386300] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga31-supply property in node /power-management@fd8d8000/power-controller failed [ 3.387611] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc0-supply from device tree [ 3.387629] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc0-supply property in node /power-management@fd8d8000/power-controller failed [ 3.387783] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vcodec-supply from device tree [ 3.387801] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vcodec-supply property in node /power-management@fd8d8000/power-controller failed [ 3.387903] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc1-supply from device tree [ 3.387920] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc1-supply property in node /power-management@fd8d8000/power-controller failed [ 3.388196] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec0-supply from device tree [ 3.388213] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec0-supply property in node /power-management@fd8d8000/power-controller failed [ 3.388505] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec1-supply from device tree [ 3.388523] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec1-supply property in node /power-management@fd8d8000/power-controller failed [ 3.388741] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vi-supply from device tree [ 3.388758] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vi-supply property in node /power-management@fd8d8000/power-controller failed [ 3.388992] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up isp1-supply from device tree [ 3.389011] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up isp1-supply property in node /power-management@fd8d8000/power-controller failed [ 3.389713] SCSI subsystem initialized [ 3.389727] libata version 3.00 loaded. [ 3.389799] usbcore: registered new interface driver usbfs [ 3.389815] usbcore: registered new interface driver hub [ 3.389831] usbcore: registered new device driver usb [ 3.389871] mc: Linux media interface: v0.10 [ 3.389882] videodev: Linux video capture interface: v2.00 [ 3.389910] pps_core: LinuxPPS API ver. 1 registered [ 3.389913] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [ 3.389919] PTP clock support registered [ 3.390187] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled. [ 3.390220] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0 [ 3.391428] Advanced Linux Sound Architecture Driver Initialized. [ 3.391692] Bluetooth: Core ver 2.22 [ 3.391706] NET: Registered protocol family 31 [ 3.391709] Bluetooth: HCI device and connection manager initialized [ 3.391713] Bluetooth: HCI socket layer initialized [ 3.391717] Bluetooth: L2CAP socket layer initialized [ 3.391723] Bluetooth: SCO socket layer initialized [ 3.391736] NetLabel: Initializing [ 3.391738] NetLabel: domain hash size = 128 [ 3.391740] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 3.391766] NetLabel: unlabeled traffic allowed by default [ 3.393092] rockchip-cpuinfo cpuinfo: SoC : 35881000 [ 3.393096] rockchip-cpuinfo cpuinfo: Serial : 2eae2cb9d903d20e [ 3.393539] clocksource: Switched to clocksource arch_sys_counter [ 3.809888] VFS: Disk quotas dquot_6.6.0 [ 3.809917] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 3.815604] NET: Registered protocol family 2 [ 3.815729] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 3.817756] tcp_listen_portaddr_hash hash table entries: 4096 (order: 5, 163840 bytes, linear) [ 3.817855] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 3.818201] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear) [ 3.819002] TCP: Hash tables configured (established 65536 bind 65536) [ 3.819109] MPTCP token hash table entries: 8192 (order: 6, 393216 bytes, linear) [ 3.819203] UDP hash table entries: 4096 (order: 6, 393216 bytes, linear) [ 3.819360] UDP-Lite hash table entries: 4096 (order: 6, 393216 bytes, linear) [ 3.819574] NET: Registered protocol family 1 [ 3.819943] RPC: Registered named UNIX socket transport module. [ 3.819946] RPC: Registered udp transport module. [ 3.819948] RPC: Registered tcp transport module. [ 3.819949] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 3.820412] PCI: CLS 0 bytes, default 64 [ 3.820704] Trying to unpack rootfs image as initramfs... [ 4.214921] Freeing initrd memory: 14952K [ 4.215595] rockchip-thermal fec00000.tsadc: Missing rockchip,grf property [ 4.216238] rockchip-thermal fec00000.tsadc: tsadc is probed successfully! [ 4.217198] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 4.217799] kvm [1]: IPA Size Limit: 40 bits [ 4.217810] kvm [1]: GICv3: no GICV resource entry [ 4.217813] kvm [1]: disabling GICv2 emulation [ 4.217815] kvm [1]: GIC system register CPU interface enabled [ 4.217967] kvm [1]: vgic interrupt IRQ9 [ 4.218151] kvm [1]: VHE mode initialized successfully [ 4.221214] Initialise system trusted keyrings [ 4.221335] workingset: timestamp_bits=46 max_order=21 bucket_order=0 [ 4.224374] NFS: Registering the id_resolver key type [ 4.224392] Key type id_resolver registered [ 4.224395] Key type id_legacy registered [ 4.224430] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 4.224432] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 4.224444] ntfs: driver 2.1.32 [Flags: R/W]. [ 4.246721] NET: Registered protocol family 38 [ 4.246726] xor: measuring software checksum speed [ 4.248347] 8regs : 6129 MB/sec [ 4.249556] 32regs : 8141 MB/sec [ 4.250604] arm64_neon : 9968 MB/sec [ 4.250606] xor: using function: arm64_neon (9968 MB/sec) [ 4.250624] Key type asymmetric registered [ 4.250627] Asymmetric key parser 'x509' registered [ 4.250644] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242) [ 4.250764] io scheduler mq-deadline registered [ 4.250769] io scheduler kyber registered [ 4.252578] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up phy-supply from device tree [ 4.252587] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up phy-supply property in node /syscon@fd5d0000/usb2-phy@0/otg-port failed [ 4.252635] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up vbus-supply from device tree [ 4.252641] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up vbus-supply property in node /syscon@fd5d0000/usb2-phy@0/otg-port failed [ 4.253973] phy phy-fd5d8000.syscon:usb2-phy@8000.1: Looking up phy-supply from device tree [ 4.253982] phy phy-fd5d8000.syscon:usb2-phy@8000.1: Looking up phy-supply property in node /syscon@fd5d8000/usb2-phy@8000/host-port failed [ 4.255162] phy phy-fd5dc000.syscon:usb2-phy@c000.2: Looking up phy-supply from device tree [ 4.255169] phy phy-fd5dc000.syscon:usb2-phy@c000.2: Looking up phy-supply property in node /syscon@fd5dc000/usb2-phy@c000/host-port failed [ 4.257022] phy phy-fee00000.phy.3: Looking up phy-supply from device tree [ 4.257029] phy phy-fee00000.phy.3: Looking up phy-supply property in node /phy@fee00000 failed [ 4.257173] phy phy-fee20000.phy.4: Looking up phy-supply from device tree [ 4.257178] phy phy-fee20000.phy.4: Looking up phy-supply property in node /phy@fee20000 failed [ 4.257677] phy phy-feda0000.phy.5: Looking up phy-supply from device tree [ 4.257682] phy phy-feda0000.phy.5: Looking up phy-supply property in node /phy@feda0000 failed [ 4.257811] phy phy-fedb0000.phy.6: Looking up phy-supply from device tree [ 4.257816] phy phy-fedb0000.phy.6: Looking up phy-supply property in node /phy@fedb0000 failed [ 4.258192] phy phy-fed60000.hdmiphy.7: Looking up phy-supply from device tree [ 4.258198] phy phy-fed60000.hdmiphy.7: Looking up phy-supply property in node /hdmiphy@fed60000 failed [ 4.258974] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy init success [ 4.259915] phy phy-fed80000.phy.8: Looking up phy-supply from device tree [ 4.259922] phy phy-fed80000.phy.8: Looking up phy-supply property in node /phy@fed80000/dp-port failed [ 4.259957] phy phy-fed80000.phy.9: Looking up phy-supply from device tree [ 4.259962] phy phy-fed80000.phy.9: Looking up phy-supply property in node /phy@fed80000/u3-port failed [ 4.261368] rk-pcie fe190000.pcie: invalid prsnt-gpios property in node [ 4.261375] rk-pcie fe190000.pcie: Looking up vpcie3v3-supply from device tree [ 4.261614] pwm-backlight backlight: Looking up power-supply from device tree [ 4.261623] pwm-backlight backlight: Looking up power-supply property in node /backlight failed [ 4.261629] pwm-backlight backlight: supply power not found, using dummy regulator [ 4.261716] rk-pcie fe190000.pcie: IRQ msi not found [ 4.261719] rk-pcie fe190000.pcie: use outband MSI support [ 4.261723] rk-pcie fe190000.pcie: Missing *config* reg space [ 4.261729] rk-pcie fe190000.pcie: host bridge /pcie@fe190000 ranges: [ 4.261742] rk-pcie fe190000.pcie: err 0x00f4000000..0x00f40fffff -> 0x00f4000000 [ 4.261749] rk-pcie fe190000.pcie: IO 0x00f4100000..0x00f41fffff -> 0x00f4100000 [ 4.261756] rk-pcie fe190000.pcie: MEM 0x00f4200000..0x00f4ffffff -> 0x00f4200000 [ 4.261762] rk-pcie fe190000.pcie: MEM 0x0a00000000..0x0a3fffffff -> 0x0a00000000 [ 4.261788] rk-pcie fe190000.pcie: Missing *config* reg space [ 4.261801] pwm-backlight backlight_1: Looking up power-supply from device tree [ 4.261806] pwm-backlight backlight_1: Looking up power-supply property in node /backlight_1 failed [ 4.261810] pwm-backlight backlight_1: supply power not found, using dummy regulator [ 4.261812] rk-pcie fe190000.pcie: invalid resource [ 4.262070] iep: Module initialized. [ 4.262108] mpp_service mpp-srv: unknown mpp version for missing VCS info [ 4.262111] mpp_service mpp-srv: probe start [ 4.264085] mpp_vdpu2 fdb50400.vdpu: Adding to iommu group 1 [ 4.264304] mpp_vdpu2 fdb50400.vdpu: probe device [ 4.264424] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0 [ 4.264432] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0 [ 4.264576] mpp_vdpu2 fdb50400.vdpu: probing finish [ 4.264789] mpp_vepu2 jpege-ccu: probing start [ 4.264792] mpp_vepu2 jpege-ccu: probing finish [ 4.264901] mpp_vepu2 fdb50000.vepu: Adding to iommu group 1 [ 4.264983] mpp_vepu2 fdb50000.vepu: probing start [ 4.265084] mpp_vepu2 fdb50000.vepu: reset_group->rw_sem_on=0 [ 4.265088] mpp_vepu2 fdb50000.vepu: reset_group->rw_sem_on=0 [ 4.265234] mpp_vepu2 fdb50000.vepu: probing finish [ 4.265353] mpp_vepu2 fdba0000.jpege-core: Adding to iommu group 5 [ 4.265494] mpp_vepu2 fdba0000.jpege-core: probing start [ 4.265602] mpp_vepu2 fdba0000.jpege-core: attach ccu success [ 4.265738] mpp_vepu2 fdba0000.jpege-core: probing finish [ 4.265846] mpp_vepu2 fdba4000.jpege-core: Adding to iommu group 6 [ 4.265982] mpp_vepu2 fdba4000.jpege-core: probing start [ 4.266092] mpp_vepu2 fdba4000.jpege-core: attach ccu success [ 4.266228] mpp_vepu2 fdba4000.jpege-core: probing finish [ 4.266336] mpp_vepu2 fdba8000.jpege-core: Adding to iommu group 7 [ 4.266470] mpp_vepu2 fdba8000.jpege-core: probing start [ 4.266574] mpp_vepu2 fdba8000.jpege-core: attach ccu success [ 4.266709] mpp_vepu2 fdba8000.jpege-core: probing finish [ 4.266804] mpp_vepu2 fdbac000.jpege-core: Adding to iommu group 8 [ 4.266951] mpp_vepu2 fdbac000.jpege-core: probing start [ 4.267059] mpp_vepu2 fdbac000.jpege-core: attach ccu success [ 4.267205] mpp_vepu2 fdbac000.jpege-core: probing finish [ 4.267478] mpp-iep2 fdbb0000.iep: Adding to iommu group 9 [ 4.267619] mpp-iep2 fdbb0000.iep: probe device [ 4.267744] mpp-iep2 fdbb0000.iep: allocate roi buffer failed [ 4.267876] mpp-iep2 fdbb0000.iep: probing finish [ 4.268096] mpp_jpgdec fdb90000.jpegd: Adding to iommu group 4 [ 4.268301] mpp_jpgdec fdb90000.jpegd: probe device [ 4.268563] mpp_jpgdec fdb90000.jpegd: probing finish [ 4.268927] mpp_rkvdec2 fdc30000.rkvdec-ccu: rkvdec-ccu, probing start [ 4.268987] mpp_rkvdec2 fdc30000.rkvdec-ccu: ccu-mode: 1 [ 4.268990] mpp_rkvdec2 fdc30000.rkvdec-ccu: probing finish [ 4.269086] mpp_rkvdec2 fdc38100.rkvdec-core: Adding to iommu group 12 [ 4.269346] mpp_rkvdec2 fdc38100.rkvdec-core: rkvdec-core, probing start [ 4.269467] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found! [ 4.269470] rkvdec2_init:1022: No niu aclk reset resource define [ 4.269474] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found! [ 4.269476] rkvdec2_init:1025: No niu hclk reset resource define [ 4.269491] mpp_rkvdec2 fdc38100.rkvdec-core: Looking up vdec-supply from device tree [ 4.269496] mpp_rkvdec2 fdc38100.rkvdec-core: Looking up vdec-supply property in node /rkvdec-core@fdc38000 failed [ 4.269503] mpp_rkvdec2 fdc38100.rkvdec-core: no regulator, devfreq is disabled [ 4.269558] mpp_rkvdec2 fdc38100.rkvdec-core: core_mask=00010001 [ 4.269561] mpp_rkvdec2 fdc38100.rkvdec-core: attach ccu as core 0 [ 4.269711] mpp_rkvdec2 fdc38100.rkvdec-core: sram_start 0x00000000ff001000 [ 4.269714] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_iova 0x00000000fff00000 [ 4.269716] mpp_rkvdec2 fdc38100.rkvdec-core: sram_size 491520 [ 4.269719] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_size 1048576 [ 4.269723] mpp_rkvdec2 fdc38100.rkvdec-core: min_width 512 [ 4.269727] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_info_count 20 [ 4.269730] mpp_rkvdec2 fdc38100.rkvdec-core: [136, 24576] [ 4.269733] mpp_rkvdec2 fdc38100.rkvdec-core: [137, 49152] [ 4.269736] mpp_rkvdec2 fdc38100.rkvdec-core: [141, 90112] [ 4.269738] mpp_rkvdec2 fdc38100.rkvdec-core: [140, 49152] [ 4.269741] mpp_rkvdec2 fdc38100.rkvdec-core: [139, 180224] [ 4.269743] mpp_rkvdec2 fdc38100.rkvdec-core: [133, 49152] [ 4.269746] mpp_rkvdec2 fdc38100.rkvdec-core: [134, 8192] [ 4.269749] mpp_rkvdec2 fdc38100.rkvdec-core: [135, 4352] [ 4.269751] mpp_rkvdec2 fdc38100.rkvdec-core: [138, 13056] [ 4.269754] mpp_rkvdec2 fdc38100.rkvdec-core: [142, 291584] [ 4.269789] mpp_rkvdec2 fdc38100.rkvdec-core: probing finish [ 4.269881] mpp_rkvdec2 fdc48100.rkvdec-core: Adding to iommu group 13 [ 4.270111] mpp_rkvdec2 fdc48100.rkvdec-core: rkvdec-core, probing start [ 4.270250] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found! [ 4.270252] rkvdec2_init:1022: No niu aclk reset resource define [ 4.270256] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found! [ 4.270258] rkvdec2_init:1025: No niu hclk reset resource define [ 4.270275] mpp_rkvdec2 fdc48100.rkvdec-core: Looking up vdec-supply from device tree [ 4.270280] mpp_rkvdec2 fdc48100.rkvdec-core: Looking up vdec-supply property in node /rkvdec-core@fdc48000 failed [ 4.270286] mpp_rkvdec2 fdc48100.rkvdec-core: no regulator, devfreq is disabled [ 4.270329] mpp_rkvdec2 fdc48100.rkvdec-core: core_mask=00020002 [ 4.270345] mpp_rkvdec2 fdc48100.rkvdec-core: attach ccu as core 1 [ 4.270525] mpp_rkvdec2 fdc48100.rkvdec-core: sram_start 0x00000000ff079000 [ 4.270527] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_iova 0x00000000ffe00000 [ 4.270530] mpp_rkvdec2 fdc48100.rkvdec-core: sram_size 487424 [ 4.270533] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_size 1048576 [ 4.270536] mpp_rkvdec2 fdc48100.rkvdec-core: min_width 512 [ 4.270540] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_info_count 20 [ 4.270543] mpp_rkvdec2 fdc48100.rkvdec-core: [136, 24576] [ 4.270546] mpp_rkvdec2 fdc48100.rkvdec-core: [137, 49152] [ 4.270548] mpp_rkvdec2 fdc48100.rkvdec-core: [141, 90112] [ 4.270551] mpp_rkvdec2 fdc48100.rkvdec-core: [140, 49152] [ 4.270553] mpp_rkvdec2 fdc48100.rkvdec-core: [139, 180224] [ 4.270556] mpp_rkvdec2 fdc48100.rkvdec-core: [133, 49152] [ 4.270559] mpp_rkvdec2 fdc48100.rkvdec-core: [134, 8192] [ 4.270561] mpp_rkvdec2 fdc48100.rkvdec-core: [135, 4352] [ 4.270564] mpp_rkvdec2 fdc48100.rkvdec-core: [138, 13056] [ 4.270566] mpp_rkvdec2 fdc48100.rkvdec-core: [142, 291584] [ 4.270596] mpp_rkvdec2 fdc48100.rkvdec-core: probing finish [ 4.270788] mpp_rkvenc2 rkvenc-ccu: probing start [ 4.270792] mpp_rkvenc2 rkvenc-ccu: probing finish [ 4.270909] mpp_rkvenc2 fdbd0000.rkvenc-core: Adding to iommu group 10 [ 4.271086] mpp_rkvenc2 fdbd0000.rkvenc-core: probing start [ 4.271240] mpp_rkvenc2 fdbd0000.rkvenc-core: Looking up venc-supply from device tree [ 4.271246] mpp_rkvenc2 fdbd0000.rkvenc-core: Looking up venc-supply property in node /rkvenc-core@fdbd0000 failed [ 4.271252] mpp_rkvenc2 fdbd0000.rkvenc-core: dev_pm_opp_set_regulators: no regulator (venc) found: -19 [ 4.271268] rkvenc_init:1814: failed to add venc devfreq [ 4.271297] mpp_rkvenc2 fdbd0000.rkvenc-core: attach ccu as core 0 [ 4.271453] mpp_rkvenc2 fdbd0000.rkvenc-core: probing finish [ 4.271536] mpp_rkvenc2 fdbe0000.rkvenc-core: Adding to iommu group 11 [ 4.271720] mpp_rkvenc2 fdbe0000.rkvenc-core: probing start [ 4.271849] mpp_rkvenc2 fdbe0000.rkvenc-core: Looking up venc-supply from device tree [ 4.271855] mpp_rkvenc2 fdbe0000.rkvenc-core: Looking up venc-supply property in node /rkvenc-core@fdbe0000 failed [ 4.271861] mpp_rkvenc2 fdbe0000.rkvenc-core: dev_pm_opp_set_regulators: no regulator (venc) found: -19 [ 4.271874] rkvenc_init:1814: failed to add venc devfreq [ 4.271923] mpp_rkvenc2 fdbe0000.rkvenc-core: attach ccu as core 1 [ 4.272077] mpp_rkvenc2 fdbe0000.rkvenc-core: probing finish [ 4.272321] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up av1-supply from device tree [ 4.272341] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up av1-supply property in node /power-management@fd8d8000/power-controller failed [ 4.272640] mpp_av1dec: Adding child /av1d@fdc70000 [ 4.272720] mpp_av1dec: register device av1d-master [ 4.272749] mpp_av1dec av1d-master: av1_iommu_of_xlate,784 [ 4.272767] av1_iommu_probe_device,736, consumer : av1d-master, supplier : fdca0000.iommu [ 4.272798] mpp_av1dec av1d-master: Adding to iommu group 18 [ 4.273036] mpp_av1dec av1d-master: probing start [ 4.273293] mpp_av1dec av1d-master: probing finish [ 4.273331] mpp_service mpp-srv: probe success [ 4.284456] dma-pl330 fea10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 4.284462] dma-pl330 fea10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 4.285485] dma-pl330 fea30000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 4.285490] dma-pl330 fea30000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 4.286462] dma-pl330 fed10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 4.286467] dma-pl330 fed10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 4.286987] rockchip-pvtm fda40000.pvtm: pvtm@0 probed [ 4.287054] rockchip-pvtm fda50000.pvtm: pvtm@1 probed [ 4.287112] rockchip-pvtm fda60000.pvtm: pvtm@2 probed [ 4.287170] rockchip-pvtm fdaf0000.pvtm: pvtm@3 probed [ 4.287224] rockchip-pvtm fdb30000.pvtm: pvtm@4 probed [ 4.287809] rockchip-system-monitor rockchip-system-monitor: system monitor probe [ 4.288640] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [ 4.289201] febc0000.serial: ttyS9 at MMIO 0xfebc0000 (irq = 101, base_baud = 1500000) is a 16550A [ 4.290542] random: crng init done [ 4.290756] led_vk2c21_init ============================================= [ 4.291722] rockchip-vop2 fdd90000.vop: Adding to iommu group 17 [ 4.300233] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x5, primary plane phy id: 0 [ 4.300240] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp1 assign plane mask: 0xa, primary plane phy id: 1 [ 4.300246] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x140, primary plane phy id: 6 [ 4.300251] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp3 assign plane mask: 0x280, primary plane phy id: 7 [ 4.300346] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart0-win0 as cursor plane for vp0 [ 4.300436] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart1-win0 as cursor plane for vp1 [ 4.300523] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart2-win0 as cursor plane for vp2 [ 4.300605] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart3-win0 as cursor plane for vp3 [ 4.300624] [drm] failed to init overlay plane Cluster0-win1 [ 4.300627] [drm] failed to init overlay plane Cluster1-win1 [ 4.300629] [drm] failed to init overlay plane Cluster2-win1 [ 4.300632] [drm] failed to init overlay plane Cluster3-win1 [ 4.312251] rockchip-drm display-subsystem: bound fdd90000.vop (ops 0xffff8000091b2620) [ 4.313195] dwhdmi-rockchip fde80000.hdmi: registered ddc I2C bus driver [ 4.313401] rockchip-drm display-subsystem: bound fde80000.hdmi (ops 0xffff8000091c0798) [ 4.313478] rockchip-drm display-subsystem: bound fde50000.dp (ops 0xffff8000091c3278) [ 4.314109] rockchip-drm display-subsystem: failed to parse loader memory [ 4.467996] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x2 [ 4.533572] dwhdmi-rockchip fde80000.hdmi: use tmds mode [ 4.533615] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] Update mode to 1920x1080p60, type: 11(if:800) for vp0 dclk: 148500000 [ 4.533786] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] dclk_out0 div: 0 dclk_core0 div: 2 [ 4.533804] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx_ropll_cmn_config bus_width:16a8c8 rate:1485000 [ 4.534083] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy pll locked! [ 4.534089] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] set dclk_vop0 to 148500000, get 148500000 [ 4.534112] dwhdmi-rockchip fde80000.hdmi: final tmdsclk = 148500000 [ 4.534141] dwhdmi-rockchip fde80000.hdmi: don't use dsc mode [ 4.534145] dwhdmi-rockchip fde80000.hdmi: dw hdmi qp use tmds mode [ 4.534151] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: bus_width:0x16a8c8,bit_rate:1485000 [ 4.534345] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy lane locked! [ 4.550218] rk-pcie fe190000.pcie: PCIe Link up, LTSSM is 0x30011 [ 4.550306] rk-pcie fe190000.pcie: PCI host bridge to bus 0004:40 [ 4.550311] pci_bus 0004:40: root bus resource [bus 40-4f] [ 4.550315] pci_bus 0004:40: root bus resource [??? 0xf4000000-0xf40fffff flags 0x0] [ 4.550320] pci_bus 0004:40: root bus resource [io 0x0000-0xfffff] (bus address [0xf4100000-0xf41fffff]) [ 4.550323] pci_bus 0004:40: root bus resource [mem 0xf4200000-0xf4ffffff] [ 4.550326] pci_bus 0004:40: root bus resource [mem 0xa00000000-0xa3fffffff pref] [ 4.550350] pci 0004:40:00.0: [1d87:3588] type 01 class 0x060400 [ 4.550366] pci 0004:40:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref] [ 4.550415] pci 0004:40:00.0: supports D1 D2 [ 4.550418] pci 0004:40:00.0: PME# supported from D0 D1 D3hot [ 4.556207] pci 0004:40:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 4.556378] pci 0004:41:00.0: [144d:a804] type 00 class 0x010802 [ 4.556462] pci 0004:41:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit] [ 4.557139] pci 0004:41:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x1 link at 0004:40:00.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link) [ 4.572443] pci_bus 0004:41: busn_res: [bus 41-4f] end is updated to 41 [ 4.572458] pci 0004:40:00.0: BAR 8: assigned [mem 0xf4200000-0xf42fffff] [ 4.572463] pci 0004:40:00.0: BAR 6: assigned [mem 0xf4300000-0xf430ffff pref] [ 4.572469] pci 0004:41:00.0: BAR 0: assigned [mem 0xf4200000-0xf4203fff 64bit] [ 4.572501] pci 0004:40:00.0: PCI bridge to [bus 41] [ 4.572506] pci 0004:40:00.0: bridge window [mem 0xf4200000-0xf42fffff] [ 4.574029] pcieport 0004:40:00.0: PME: Signaling with IRQ 125 [ 4.617486] Console: switching to colour frame buffer device 240x67 [ 4.759317] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device [ 4.759815] [drm] Initialized rockchip 3.0.0 20140818 for display-subsystem on minor 0 [ 4.766828] brd: module loaded [ 4.770279] loop: module loaded [ 4.770498] zram: Added device: zram0 [ 4.770655] lkdtm: No crash points registered, enable through debugfs [ 4.770846] system_heap: orders[0] = 6 [ 4.770849] system_heap: orders[1] = 4 [ 4.770851] system_heap: orders[2] = 0 [ 4.771880] nvme nvme0: pci function 0004:41:00.0 [ 4.771916] nvme 0004:41:00.0: enabling device (0000 -> 0002) [ 4.773504] rockchip-spi feb20000.spi: no high_speed pinctrl state [ 4.775118] rk806 spi2.0: chip id: RK806,ver:0x2, 0x1 [ 4.775255] rk806 spi2.0: ON: 0x80 OFF:0x80 [ 4.777120] rk806-regulator rk806-regulator.6.auto: Looking up vcc1-supply from device tree [ 4.777130] vdd_gpu_s0: supplied by vcc5v0_sys [ 4.777136] vcc5v0_sys: could not add device link regulator.8: -ENOENT [ 4.777871] vdd_gpu_s0: 550 <--> 950 mV at 750 mV, enabled [ 4.778282] rk806-regulator rk806-regulator.6.auto: Looking up vcc2-supply from device tree [ 4.778288] vdd_cpu_lit_s0: supplied by vcc5v0_sys [ 4.778296] vcc5v0_sys: could not add device link regulator.9: -ENOENT [ 4.778540] vdd_cpu_lit_s0: 550 <--> 950 mV at 750 mV, enabled [ 4.779056] rk806-regulator rk806-regulator.6.auto: Looking up vcc3-supply from device tree [ 4.779062] vdd_log_s0: supplied by vcc5v0_sys [ 4.779067] vcc5v0_sys: could not add device link regulator.10: -ENOENT [ 4.779297] vdd_log_s0: 675 <--> 750 mV at 750 mV, enabled [ 4.779752] rk806-regulator rk806-regulator.6.auto: Looking up vcc4-supply from device tree [ 4.779758] vdd_vdenc_s0: supplied by vcc5v0_sys [ 4.779763] vcc5v0_sys: could not add device link regulator.11: -ENOENT [ 4.779993] vdd_vdenc_s0: 550 <--> 950 mV at 750 mV, enabled [ 4.780519] rk806-regulator rk806-regulator.6.auto: Looking up vcc5-supply from device tree [ 4.780525] vdd_ddr_s0: supplied by vcc5v0_sys [ 4.780530] vcc5v0_sys: could not add device link regulator.12: -ENOENT [ 4.780763] vdd_ddr_s0: 675 <--> 900 mV at 850 mV, enabled [ 4.780966] rk806-regulator rk806-regulator.6.auto: Looking up vcc6-supply from device tree [ 4.780973] vdd2_ddr_s3: supplied by vcc5v0_sys [ 4.780977] vcc5v0_sys: could not add device link regulator.13: -ENOENT [ 4.781265] vdd2_ddr_s3: at 500 mV, enabled [ 4.781615] rk806-regulator rk806-regulator.6.auto: Looking up vcc7-supply from device tree [ 4.781621] vdd_2v0_pldo_s3: supplied by vcc5v0_sys [ 4.781626] vcc5v0_sys: could not add device link regulator.14: -ENOENT [ 4.781857] vdd_2v0_pldo_s3: 2000 mV, enabled [ 4.782207] rk806-regulator rk806-regulator.6.auto: Looking up vcc8-supply from device tree [ 4.782213] vcc_3v3_s3: supplied by vcc5v0_sys [ 4.782218] vcc5v0_sys: could not add device link regulator.15: -ENOENT [ 4.782442] vcc_3v3_s3: 3300 mV, enabled [ 4.782787] rk806-regulator rk806-regulator.6.auto: Looking up vcc9-supply from device tree [ 4.782793] vddq_ddr_s0: supplied by vcc5v0_sys [ 4.782798] vcc5v0_sys: could not add device link regulator.16: -ENOENT [ 4.783112] vddq_ddr_s0: at 500 mV, enabled [ 4.783493] rk806-regulator rk806-regulator.6.auto: Looking up vcc10-supply from device tree [ 4.783499] vcc_1v8_s3: supplied by vcc5v0_sys [ 4.783504] vcc5v0_sys: could not add device link regulator.17: -ENOENT [ 4.783821] vcc_1v8_s3: 1800 mV, enabled [ 4.784732] rk806-regulator rk806-regulator.6.auto: Looking up vcc13-supply from device tree [ 4.784917] vdd_0v75_s3: supplied by vcc_1v1_nldo_s3 [ 4.784932] vcc_1v1_nldo_s3: could not add device link regulator.18: -ENOENT [ 4.785343] vdd_0v75_s3: 750 mV, enabled [ 4.786116] rk806-regulator rk806-regulator.6.auto: Looking up vcc13-supply from device tree [ 4.786126] vdd_ddr_pll_s0: supplied by vcc_1v1_nldo_s3 [ 4.786132] vcc_1v1_nldo_s3: could not add device link regulator.19: -ENOENT [ 4.786382] vdd_ddr_pll_s0: 850 mV, enabled [ 4.786689] avdd_0v75_s0: Bringing 750000uV into 837500-837500uV [ 4.786828] avdd_0v75_s0: ramp_delay not set [ 4.786899] rk806-regulator rk806-regulator.6.auto: Looking up vcc13-supply from device tree [ 4.786906] avdd_0v75_s0: supplied by vcc_1v1_nldo_s3 [ 4.786912] vcc_1v1_nldo_s3: could not add device link regulator.20: -ENOENT [ 4.787133] avdd_0v75_s0: 837 mV, enabled [ 4.787479] rk806-regulator rk806-regulator.6.auto: Looking up vcc14-supply from device tree [ 4.787486] vdd_0v85_s0: supplied by vcc_1v1_nldo_s3 [ 4.787491] vcc_1v1_nldo_s3: could not add device link regulator.21: -ENOENT [ 4.787713] vdd_0v85_s0: 850 mV, enabled [ 4.788052] rk806-regulator rk806-regulator.6.auto: Looking up vcc14-supply from device tree [ 4.788059] vdd_0v75_s0: supplied by vcc_1v1_nldo_s3 [ 4.788067] vcc_1v1_nldo_s3: could not add device link regulator.22: -ENOENT [ 4.788285] vdd_0v75_s0: 750 mV, enabled [ 4.788691] rk806-regulator rk806-regulator.6.auto: Looking up vcc11-supply from device tree [ 4.788730] avcc_1v8_s0: supplied by vdd_2v0_pldo_s3 [ 4.788736] vdd_2v0_pldo_s3: could not add device link regulator.23: -ENOENT [ 4.789030] avcc_1v8_s0: 1800 mV, enabled [ 4.789445] rk806-regulator rk806-regulator.6.auto: Looking up vcc11-supply from device tree [ 4.789453] vcc_1v8_s0: supplied by vdd_2v0_pldo_s3 [ 4.789458] vdd_2v0_pldo_s3: could not add device link regulator.24: -ENOENT [ 4.789744] vcc_1v8_s0: 1800 mV, enabled [ 4.790084] rk806-regulator rk806-regulator.6.auto: Looking up vcc11-supply from device tree [ 4.790091] avdd_1v2_s0: supplied by vdd_2v0_pldo_s3 [ 4.790096] vdd_2v0_pldo_s3: could not add device link regulator.25: -ENOENT [ 4.790407] avdd_1v2_s0: 1200 mV, enabled [ 4.790745] rk806-regulator rk806-regulator.6.auto: Looking up vcc12-supply from device tree [ 4.790751] vcc_3v3_s0: supplied by vcc5v0_sys [ 4.790756] vcc5v0_sys: could not add device link regulator.26: -ENOENT [ 4.790980] vcc_3v3_s0: 3300 mV, enabled [ 4.791313] rk806-regulator rk806-regulator.6.auto: Looking up vcc12-supply from device tree [ 4.791319] vccio_sd_s0: supplied by vcc5v0_sys [ 4.791324] vcc5v0_sys: could not add device link regulator.27: -ENOENT [ 4.791559] vccio_sd_s0: 1800 <--> 3300 mV at 3300 mV, enabled [ 4.791915] rk806-regulator rk806-regulator.6.auto: Looking up vcca-supply from device tree [ 4.791921] pldo6_s3: supplied by vcc5v0_sys [ 4.791926] vcc5v0_sys: could not add device link regulator.28: -ENOENT [ 4.792144] pldo6_s3: 1800 mV, enabled [ 4.792487] rk806 spi2.0: no sleep-setting state [ 4.792491] rk806 spi2.0: no reset-setting pinctrl state [ 4.792494] rk806 spi2.0: no dvs-setting pinctrl state [ 4.794018] rockchip-spi feb20000.spi: register misc device rkspi-dev2 [ 4.794023] rockchip-spi feb20000.spi: probed, poll=0, rsd=0 [ 4.795615] spi-nor spi5.0: XM25QU128C (16384 Kbytes) read_data x4 [ 4.795632] 1 fixed-partitions partitions found on MTD device sfc_nor [ 4.795635] Creating 1 MTD partitions on "sfc_nor": [ 4.795640] 0x000000000000-0x000001000000 : "loader" [ 4.797674] nvme nvme0: 7/0/0 default/read/poll queues [ 4.797748] rk_gmac-dwmac fe1c0000.ethernet: IRQ eth_lpi not found [ 4.797895] rk_gmac-dwmac fe1c0000.ethernet: Looking up phy-supply from device tree [ 4.797908] rk_gmac-dwmac fe1c0000.ethernet: Looking up phy-supply property in node /ethernet@fe1c0000 failed [ 4.797922] rk_gmac-dwmac fe1c0000.ethernet: no regulator found [ 4.797927] rk_gmac-dwmac fe1c0000.ethernet: clock input or output? (output). [ 4.797931] rk_gmac-dwmac fe1c0000.ethernet: TX delay(0x42). [ 4.797936] rk_gmac-dwmac fe1c0000.ethernet: Can not read property: rx_delay. [ 4.797939] rk_gmac-dwmac fe1c0000.ethernet: set rx_delay to 0xffffffff [ 4.797948] rk_gmac-dwmac fe1c0000.ethernet: integrated PHY? (no). [ 4.797953] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_rx [ 4.797958] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_tx [ 4.797972] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock clk_mac_speed [ 4.798194] rk_gmac-dwmac fe1c0000.ethernet: init for RGMII_RXID [ 4.798303] rk_gmac-dwmac fe1c0000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 4.798308] rk_gmac-dwmac fe1c0000.ethernet: DWMAC4/5 [ 4.798312] rk_gmac-dwmac fe1c0000.ethernet: DMA HW capability register supported [ 4.798316] rk_gmac-dwmac fe1c0000.ethernet: RX Checksum Offload Engine supported [ 4.798319] rk_gmac-dwmac fe1c0000.ethernet: TX Checksum insertion supported [ 4.798322] rk_gmac-dwmac fe1c0000.ethernet: Wake-Up On Lan supported [ 4.798358] rk_gmac-dwmac fe1c0000.ethernet: TSO supported [ 4.798361] rk_gmac-dwmac fe1c0000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 4.798366] rk_gmac-dwmac fe1c0000.ethernet: Enabled Flow TC (entries=2) [ 4.798369] rk_gmac-dwmac fe1c0000.ethernet: TSO feature enabled [ 4.798373] rk_gmac-dwmac fe1c0000.ethernet: Using 32 bits DMA width [ 4.809583] nvme0n1: p1 p2 [ 4.939441] usbcore: registered new interface driver rndis_wlan [ 4.939462] usbcore: registered new interface driver asix [ 4.939477] usbcore: registered new interface driver cdc_ether [ 4.939495] usbcore: registered new interface driver rndis_host [ 4.939517] usbcore: registered new interface driver cdc_ncm [ 4.944224] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up usb-supply from device tree [ 4.944253] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up usb-supply property in node /power-management@fd8d8000/power-controller failed [ 4.946063] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 4.946072] ehci-pci: EHCI PCI platform driver [ 4.946100] ehci-platform: EHCI generic platform driver [ 4.948107] ehci-platform fc800000.usb: EHCI Host Controller [ 4.948123] ehci-platform fc800000.usb: new USB bus registered, assigned bus number 1 [ 4.948194] ehci-platform fc800000.usb: irq 20, io mem 0xfc800000 [ 4.960219] ehci-platform fc800000.usb: USB 2.0 started, EHCI 1.00 [ 4.960335] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 4.960339] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.960343] usb usb1: Product: EHCI Host Controller [ 4.960347] usb usb1: Manufacturer: Linux 5.10.160-rk35xx ehci_hcd [ 4.960350] usb usb1: SerialNumber: fc800000.usb [ 4.960600] hub 1-0:1.0: USB hub found [ 4.960620] hub 1-0:1.0: 1 port detected [ 4.963028] ehci-platform fc880000.usb: EHCI Host Controller [ 4.963040] ehci-platform fc880000.usb: new USB bus registered, assigned bus number 2 [ 4.963097] ehci-platform fc880000.usb: irq 22, io mem 0xfc880000 [ 4.973552] ehci-platform fc880000.usb: USB 2.0 started, EHCI 1.00 [ 4.973655] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 4.973659] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.973663] usb usb2: Product: EHCI Host Controller [ 4.973666] usb usb2: Manufacturer: Linux 5.10.160-rk35xx ehci_hcd [ 4.973670] usb usb2: SerialNumber: fc880000.usb [ 4.973881] hub 2-0:1.0: USB hub found [ 4.973900] hub 2-0:1.0: 1 port detected [ 4.974313] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 4.974326] ohci-platform: OHCI generic platform driver [ 4.974487] ohci-platform fc840000.usb: Generic Platform OHCI controller [ 4.974496] ohci-platform fc840000.usb: new USB bus registered, assigned bus number 3 [ 4.974544] ohci-platform fc840000.usb: irq 21, io mem 0xfc840000 [ 5.034312] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10 [ 5.034317] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.034320] usb usb3: Product: Generic Platform OHCI controller [ 5.034324] usb usb3: Manufacturer: Linux 5.10.160-rk35xx ohci_hcd [ 5.034327] usb usb3: SerialNumber: fc840000.usb [ 5.034538] hub 3-0:1.0: USB hub found [ 5.034556] hub 3-0:1.0: 1 port detected [ 5.034851] ohci-platform fc8c0000.usb: Generic Platform OHCI controller [ 5.034860] ohci-platform fc8c0000.usb: new USB bus registered, assigned bus number 4 [ 5.034918] ohci-platform fc8c0000.usb: irq 23, io mem 0xfc8c0000 [ 5.094308] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10 [ 5.094313] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.094316] usb usb4: Product: Generic Platform OHCI controller [ 5.094319] usb usb4: Manufacturer: Linux 5.10.160-rk35xx ohci_hcd [ 5.094323] usb usb4: SerialNumber: fc8c0000.usb [ 5.094531] hub 4-0:1.0: USB hub found [ 5.094549] hub 4-0:1.0: 1 port detected [ 5.095137] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 5.095147] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 5 [ 5.095225] xhci-hcd xhci-hcd.7.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000200002010010 [ 5.095249] xhci-hcd xhci-hcd.7.auto: irq 139, io mem 0xfcd00000 [ 5.095408] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 5.095413] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.095417] usb usb5: Product: xHCI Host Controller [ 5.095420] usb usb5: Manufacturer: Linux 5.10.160-rk35xx xhci-hcd [ 5.095423] usb usb5: SerialNumber: xhci-hcd.7.auto [ 5.095634] hub 5-0:1.0: USB hub found [ 5.095652] hub 5-0:1.0: 1 port detected [ 5.095807] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 5.095814] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 6 [ 5.095821] xhci-hcd xhci-hcd.7.auto: Host supports USB 3.0 SuperSpeed [ 5.095857] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM. [ 5.095920] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 [ 5.095924] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.095928] usb usb6: Product: xHCI Host Controller [ 5.095931] usb usb6: Manufacturer: Linux 5.10.160-rk35xx xhci-hcd [ 5.095934] usb usb6: SerialNumber: xhci-hcd.7.auto [ 5.096138] hub 6-0:1.0: USB hub found [ 5.096154] hub 6-0:1.0: 1 port detected [ 5.096364] usbcore: registered new interface driver cdc_acm [ 5.096367] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 5.096486] usbcore: registered new interface driver uas [ 5.096542] usbcore: registered new interface driver usb-storage [ 5.097166] Error: Driver 'Goodix-TS' is already registered, aborting... [ 5.097200] usbcore: registered new interface driver usbtouchscreen [ 5.098286] input: rk805 pwrkey as /devices/platform/feb20000.spi/spi_master/spi2/spi2.0/rk805-pwrkey.5.auto/input/input0 [ 5.098550] i2c /dev entries driver [ 5.102175] rk860-regulator 0-0042: Looking up vin-supply from device tree [ 5.102184] vdd_cpu_big0_s0: supplied by vcc5v0_sys [ 5.102190] vcc5v0_sys: could not add device link regulator.29: -ENOENT [ 5.106304] vdd_cpu_big0_s0: 550 <--> 1050 mV at 800 mV, enabled [ 5.110831] rk860-regulator 0-0043: Looking up vin-supply from device tree [ 5.110837] vdd_cpu_big1_s0: supplied by vcc5v0_sys [ 5.110843] vcc5v0_sys: could not add device link regulator.30: -ENOENT [ 5.114935] vdd_cpu_big1_s0: 550 <--> 1050 mV at 800 mV, enabled [ 5.117181] Goodix-TS 2-0014: Looking up AVDD28-supply from device tree [ 5.117190] Goodix-TS 2-0014: Looking up AVDD28-supply property in node /i2c@feaa0000/touchscreen@14 failed [ 5.117201] Goodix-TS 2-0014: supply AVDD28 not found, using dummy regulator [ 5.117256] Goodix-TS 2-0014: Looking up VDDIO-supply from device tree [ 5.117264] Goodix-TS 2-0014: Looking up VDDIO-supply property in node /i2c@feaa0000/touchscreen@14 failed [ 5.117272] Goodix-TS 2-0014: supply VDDIO not found, using dummy regulator [ 5.210361] Goodix-TS 2-0014: i2c test failed attempt 1: -6 [ 5.237024] Goodix-TS 2-0014: i2c test failed attempt 2: -6 [ 5.263544] Goodix-TS 2-0014: I2C communication failure: -6 [ 5.266697] rk860-regulator 2-0042: Looking up vin-supply from device tree [ 5.266704] vdd_npu_s0: supplied by vcc5v0_sys [ 5.266710] vcc5v0_sys: could not add device link regulator.31: -ENOENT [ 5.270783] vdd_npu_s0: 550 <--> 950 mV at 800 mV, enabled [ 5.273695] typec_fusb302 6-0022: Looking up vbus-supply from device tree [ 5.302991] rtc-hym8563 6-0051: rtc information is valid [ 5.308642] rtc-hym8563 6-0051: registered as rtc0 [ 5.309689] rtc-hym8563 6-0051: setting system clock to 2023-08-07T17:50:11 UTC (1691430611) [ 5.314219] Goodix-TS 7-0014: Looking up AVDD28-supply from device tree [ 5.314238] Goodix-TS 7-0014: Looking up AVDD28-supply property in node /i2c@fec90000/touchscreen@14 failed [ 5.314270] Goodix-TS 7-0014: supply AVDD28 not found, using dummy regulator [ 5.314403] Goodix-TS 7-0014: Looking up VDDIO-supply from device tree [ 5.314421] Goodix-TS 7-0014: Looking up VDDIO-supply property in node /i2c@fec90000/touchscreen@14 failed [ 5.314445] Goodix-TS 7-0014: supply VDDIO not found, using dummy regulator [ 5.407084] Goodix-TS 7-0014: i2c test failed attempt 1: -6 [ 5.433741] Goodix-TS 7-0014: i2c test failed attempt 2: -6 [ 5.460242] Goodix-TS 7-0014: I2C communication failure: -6 [ 5.462558] rkcifhw fdce0000.rkcif: Adding to iommu group 16 [ 5.463237] rkcifhw fdce0000.rkcif: No reserved memory region assign to CIF [ 5.466082] rkisp_hw fdcb0000.rkisp: Adding to iommu group 14 [ 5.466333] rkisp_hw fdcb0000.rkisp: is_thunderboot: 0 [ 5.466344] rkisp_hw fdcb0000.rkisp: max input:0x0@0fps [ 5.466352] rkisp_hw fdcb0000.rkisp: Missing rockchip,grf property [ 5.466574] rkisp_hw fdcb0000.rkisp: no find phandle sram [ 5.466744] rkisp_hw fdcc0000.rkisp: Adding to iommu group 15 [ 5.467085] rkisp_hw fdcc0000.rkisp: is_thunderboot: 0 [ 5.467096] rkisp_hw fdcc0000.rkisp: max input:0x0@0fps [ 5.467104] rkisp_hw fdcc0000.rkisp: Missing rockchip,grf property [ 5.467332] rkisp_hw fdcc0000.rkisp: no find phandle sram [ 5.469721] usbcore: registered new interface driver uvcvideo [ 5.469727] USB Video Class driver (1.1.1) [ 5.472807] cpu cpu0: Looking up cpu-supply from device tree [ 5.473323] cpu cpu0: bin=0 [ 5.473498] cpu cpu0: leakage=8 [ 5.473523] cpu cpu0: Looking up cpu-supply from device tree [ 5.474984] cpu cpu0: pvtm=1380 [ 5.475151] cpu cpu0: pvtm-volt-sel=0 [ 5.475186] cpu cpu0: Looking up cpu-supply from device tree [ 5.475322] cpu cpu0: Looking up mem-supply from device tree [ 5.475495] cpu cpu4: Looking up cpu-supply from device tree [ 5.477195] cpu cpu4: bin=0 [ 5.477366] cpu cpu4: leakage=6 [ 5.477387] cpu cpu4: Looking up cpu-supply from device tree [ 5.483892] cpu cpu4: pvtm=1587 [ 5.487860] cpu cpu4: pvtm-volt-sel=0 [ 5.487902] cpu cpu4: Looking up cpu-supply from device tree [ 5.488405] cpu cpu4: Looking up mem-supply from device tree [ 5.488947] cpu cpu6: Looking up cpu-supply from device tree [ 5.490642] cpu cpu6: bin=0 [ 5.490813] cpu cpu6: leakage=6 [ 5.490833] cpu cpu6: Looking up cpu-supply from device tree [ 5.497359] cpu cpu6: pvtm=1589 [ 5.501353] cpu cpu6: pvtm-volt-sel=0 [ 5.501394] cpu cpu6: Looking up cpu-supply from device tree [ 5.501897] cpu cpu6: Looking up mem-supply from device tree [ 5.503083] cpu cpu0: avs=0 [ 5.503893] cpu cpu4: avs=0 [ 5.504663] cpu cpu6: avs=0 [ 5.504843] cpu cpu0: EM: OPP:816000 is inefficient [ 5.504847] cpu cpu0: EM: OPP:600000 is inefficient [ 5.504937] cpu cpu0: EM: created perf domain [ 5.504977] cpu cpu0: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=1608000000 h_table=0 [ 5.505598] cpu cpu4: EM: OPP:816000 is inefficient [ 5.505602] cpu cpu4: EM: OPP:600000 is inefficient [ 5.505722] cpu cpu4: EM: created perf domain [ 5.505752] cpu cpu4: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0 [ 5.513615] usb 3-1: new full-speed USB device number 2 using ohci-platform [ 5.514367] cpu cpu6: EM: OPP:816000 is inefficient [ 5.514373] cpu cpu6: EM: OPP:600000 is inefficient [ 5.514558] cpu cpu6: EM: created perf domain [ 5.515110] cpu cpu6: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0 [ 5.530965] sdhci: Secure Digital Host Controller Interface driver [ 5.530973] sdhci: Copyright(c) Pierre Ossman [ 5.530979] Synopsys Designware Multimedia Card Interface Driver [ 5.532229] sdhci-pltfm: SDHCI platform and OF driver helper [ 5.536228] ledtrig-cpu: registered to indicate activity on CPUs [ 5.536285] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active. [ 5.536368] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 5.537944] cryptodev: driver 1.12 loaded. [ 5.538012] hid: raw HID events driver (C) Jiri Kosina [ 5.538337] usbcore: registered new interface driver usbhid [ 5.538344] usbhid: USB HID core driver [ 5.538890] ashmem: initialized [ 5.544805] rockchip-saradc fec10000.saradc: Looking up vref-supply from device tree [ 5.546430] optee: probing for conduit method. [ 5.546438] optee: api uid mismatch [ 5.546450] optee: probe of firmware:optee failed with error -22 [ 5.547668] usbcore: registered new interface driver snd-usb-audio [ 5.555582] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up audio-supply from device tree [ 5.555636] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up audio-supply property in node /power-management@fd8d8000/power-controller failed [ 5.560770] debugfs: File 'Capture' in directory 'dapm' already present! [ 5.562541] input: rockchip-dp0 rockchip-dp0 as /devices/platform/dp0-sound/sound/card0/input1 [ 5.564311] input: rockchip-hdmi0 rockchip-hdmi0 as /devices/platform/hdmi0-sound/sound/card1/input2 [ 5.566229] input: headset-keys as /devices/platform/es8388-sound/input/input3 [ 5.579263] ES8323 6-0010: ASoC: error at soc_component_write_no_lock on ES8323.6-0010: -5 [ 5.635316] input: rockchip-es8388 Headset as /devices/platform/es8388-sound/sound/card2/input4 [ 5.636126] Initializing XFRM netlink socket [ 5.636139] NET: Registered protocol family 17 [ 5.636440] [BT_RFKILL]: Enter rfkill_rk_init [ 5.636444] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 5.636836] Key type dns_resolver registered [ 5.638102] registered taskstats version 1 [ 5.638110] Loading compiled-in X.509 certificates [ 5.638843] Btrfs loaded, crc32c=crc32c-generic [ 5.638970] pstore: Using crash dump compression: deflate [ 5.639189] rga3_core0 fdb60000.rga: Adding to iommu group 2 [ 5.639374] rga: rga3_core0, irq = 35, match scheduler [ 5.639672] rga: rga3_core0 hardware loaded successfully, hw_version:3.0.76831. [ 5.639693] rga: rga3_core0 probe successfully [ 5.639982] rga3_core1 fdb70000.rga: Adding to iommu group 3 [ 5.640164] rga: rga3_core1, irq = 36, match scheduler [ 5.640511] rga: rga3_core1 hardware loaded successfully, hw_version:3.0.76831. [ 5.640529] rga: rga3_core1 probe successfully [ 5.640848] rga: rga2, irq = 37, match scheduler [ 5.641140] rga: rga2 hardware loaded successfully, hw_version:3.2.63318. [ 5.641148] rga: rga2 probe successfully [ 5.641336] rga_iommu: IOMMU binding successfully, default mapping core[0x1] [ 5.641523] rga: Module initialized. v1.2.25 [ 5.688641] reg-fixed-voltage combophy-avdd0v85: Looking up vin-supply from device tree [ 5.688665] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up gpu-supply from device tree [ 5.688793] combophy_avdd0v85: supplied by vdd_0v85_s0 [ 5.688806] vdd_0v85_s0: could not add device link regulator.32: -ENOENT [ 5.688973] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up gpu-supply property in node /power-management@fd8d8000/power-controller failed [ 5.689107] combophy_avdd0v85: 850 mV, enabled [ 5.689170] mali fb000000.gpu: Kernel DDK version g17p0-01eac0 [ 5.689252] mali fb000000.gpu: Looking up mali-supply from device tree [ 5.689389] reg-fixed-voltage combophy-avdd0v85: combophy_avdd0v85 supplying 850000uV [ 5.689483] mali fb000000.gpu: Looking up mem-supply from device tree [ 5.689625] mali fb000000.gpu: Looking up mali-supply from device tree [ 5.689656] vdd_gpu_s0: could not add device link fb000000.gpu: -EEXIST [ 5.689663] vdd_gpu_s0: Failed to create debugfs directory [ 5.689672] mali fb000000.gpu: Looking up mem-supply from device tree [ 5.689695] vdd_gpu_s0: could not add device link fb000000.gpu: -EEXIST [ 5.689701] vdd_gpu_s0: Failed to create debugfs directory [ 5.689768] reg-fixed-voltage combophy-avdd1v8: Looking up vin-supply from device tree [ 5.689930] combophy_avdd1v8: supplied by avcc_1v8_s0 [ 5.689945] avcc_1v8_s0: could not add device link regulator.33: -ENOENT [ 5.689988] mali fb000000.gpu: Looking up mali-supply from device tree [ 5.690012] vdd_gpu_s0: could not add device link fb000000.gpu: -EEXIST [ 5.690017] vdd_gpu_s0: Failed to create debugfs directory [ 5.690492] combophy_avdd1v8: 1800 mV, enabled [ 5.690890] reg-fixed-voltage combophy-avdd1v8: combophy_avdd1v8 supplying 1800000uV [ 5.690916] mali fb000000.gpu: bin=0 [ 5.691111] mali fb000000.gpu: leakage=13 [ 5.691157] vcc_3v3_sd_s0: 3300 mV, disabled [ 5.691181] mali fb000000.gpu: Looking up mali-supply from device tree [ 5.691219] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present! [ 5.691405] reg-fixed-voltage vcc-3v3-sd-s0: Looking up vin-supply from device tree [ 5.691427] vcc_3v3_sd_s0: supplied by vcc_3v3_s3 [ 5.692309] reg-fixed-voltage vcc-3v3-sd-s0: vcc_3v3_sd_s0 supplying 3300000uV [ 5.693157] mali fb000000.gpu: pvtm=846 [ 5.693638] mali fb000000.gpu: pvtm-volt-sel=2 [ 5.693661] rockchip-dmc dmc: Looking up center-supply from device tree [ 5.694165] rockchip-dmc dmc: Looking up mem-supply from device tree [ 5.694574] rockchip-dmc dmc: Looking up center-supply from device tree [ 5.694617] vdd_ddr_s0: could not add device link dmc: -EEXIST [ 5.694625] vdd_ddr_s0: Failed to create debugfs directory [ 5.694805] rockchip-dmc dmc: Looking up mem-supply from device tree [ 5.694840] vdd_log_s0: could not add device link dmc: -EEXIST [ 5.694848] vdd_log_s0: Failed to create debugfs directory [ 5.695048] mali fb000000.gpu: avs=0 [ 5.695344] rockchip-dmc dmc: leakage=30 [ 5.695366] rockchip-dmc dmc: leakage-volt-sel=0 [ 5.695554] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 143; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available. [ 5.696499] rockchip-dmc dmc: avs=0 [ 5.696525] rockchip-dmc dmc: current ATF version 0x100 [ 5.696582] mali fb000000.gpu: GPU hardware issue table may need updating: r0p0 status 5 is unknown; treating as r0p0 status 0 [ 5.696599] mali fb000000.gpu: GPU identified as 0x7 arch 10.8.6 r0p0 status 0 [ 5.696688] mali fb000000.gpu: No priority control manager is configured [ 5.696708] rockchip-dmc dmc: normal_rate = 1560000000 [ 5.696738] rockchip-dmc dmc: reboot_rate = 2112000000 [ 5.696749] rockchip-dmc dmc: suspend_rate = 528000000 [ 5.696759] rockchip-dmc dmc: video_4k_rate = 1560000000 [ 5.696770] rockchip-dmc dmc: video_4k_10b_rate = 1560000000 [ 5.696780] rockchip-dmc dmc: video_svep_rate = 1560000000 [ 5.696790] rockchip-dmc dmc: boost_rate = 2112000000 [ 5.696800] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 2112000000 [ 5.696810] rockchip-dmc dmc: performance_rate = 2112000000 [ 5.696821] rockchip-dmc dmc: hdmirx_rate = 2112000000 [ 5.696837] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate [ 5.696846] rockchip-dmc dmc: failed to get vop pn to msch rl [ 5.697231] rockchip-dmc dmc: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0 [ 5.697299] mali fb000000.gpu: No memory group manager is configured [ 5.697343] mali fb000000.gpu: Protected memory allocator not available [ 5.697792] rockchip-dmc dmc: could not find power_model node [ 5.698561] mali fb000000.gpu: Capping CSF_FIRMWARE_TIMEOUT to CSF_FIRMWARE_PING_TIMEOUT [ 5.699697] input: adc-keys as /devices/platform/adc-keys/input/input5 [ 5.700175] mali fb000000.gpu: Couldn't find power_model DT node matching 'arm,mali-simple-power-model' [ 5.700192] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.static-coefficient = 1*[0] [ 5.700579] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.dynamic-coefficient = 1*[0] [ 5.700920] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.ts = 4*[0] [ 5.701271] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.thermal-zone = '' [ 5.706500] mali fb000000.gpu: Using configured power model mali-lodx-power-model, and fallback mali-simple-power-model [ 5.706786] mali fb000000.gpu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0 [ 5.707964] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up sdmmc-supply from device tree [ 5.708004] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up sdmmc-supply property in node /power-management@fd8d8000/power-controller failed [ 5.708040] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up sdio-supply from device tree [ 5.708067] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up sdio-supply property in node /power-management@fd8d8000/power-controller failed [ 5.708100] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up pcie-supply from device tree [ 5.708127] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up pcie-supply property in node /power-management@fd8d8000/power-controller failed [ 5.708165] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu-supply from device tree [ 5.708202] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu-supply property in node /power-management@fd8d8000/power-controller failed [ 5.708373] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode. [ 5.708398] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller. [ 5.708407] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a [ 5.708448] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 90,32 bit host data width,256 deep fifo [ 5.708522] dwmmc_rockchip fe2c0000.mmc: Looking up vmmc-supply from device tree [ 5.708612] mali fb000000.gpu: Probed as mali0 [ 5.708722] dwmmc_rockchip fe2c0000.mmc: Looking up vqmmc-supply from device tree [ 5.709684] RKNPU fdab0000.npu: Adding to iommu group 0 [ 5.709825] RKNPU fdab0000.npu: RKNPU: rknpu iommu is enabled, using iommu mode [ 5.709919] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 5.710618] RKNPU fdab0000.npu: Looking up mem-supply from device tree [ 5.711253] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff] [ 5.711276] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff] [ 5.711296] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff] [ 5.712053] [drm] Initialized rknpu 0.8.5 20230202 for fdab0000.npu on minor 1 [ 5.712454] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up nputop-supply from device tree [ 5.712487] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up nputop-supply property in node /power-management@fd8d8000/power-controller failed [ 5.712562] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu1-supply from device tree [ 5.712589] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu1-supply property in node /power-management@fd8d8000/power-controller failed [ 5.712649] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu2-supply from device tree [ 5.712676] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu2-supply property in node /power-management@fd8d8000/power-controller failed [ 5.712821] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 5.712845] vdd_npu_s0: could not add device link fdab0000.npu: -EEXIST [ 5.712849] vdd_npu_s0: Failed to create debugfs directory [ 5.713421] RKNPU fdab0000.npu: Looking up mem-supply from device tree [ 5.713463] vdd_npu_s0: could not add device link fdab0000.npu: -EEXIST [ 5.713468] vdd_npu_s0: Failed to create debugfs directory [ 5.714245] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 5.714282] vdd_npu_s0: could not add device link fdab0000.npu: -EEXIST [ 5.714286] vdd_npu_s0: Failed to create debugfs directory [ 5.716442] RKNPU fdab0000.npu: RKNPU: bin=0 [ 5.716620] RKNPU fdab0000.npu: leakage=7 [ 5.716659] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 5.716692] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present! [ 5.722942] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 5.724009] RKNPU fdab0000.npu: pvtm=845 [ 5.728634] RKNPU fdab0000.npu: pvtm-volt-sel=2 [ 5.729515] RKNPU fdab0000.npu: avs=0 [ 5.729709] RKNPU fdab0000.npu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0 [ 5.742511] RKNPU fdab0000.npu: failed to find power_model node [ 5.742522] RKNPU fdab0000.npu: RKNPU: failed to initialize power model [ 5.742527] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient [ 5.743870] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 5.747021] usb 3-1: New USB device found, idVendor=046d, idProduct=c539, bcdDevice=39.06 [ 5.747037] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 5.747047] usb 3-1: Product: USB Receiver [ 5.747056] usb 3-1: Manufacturer: Logitech [ 5.755914] input: Logitech USB Receiver as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.0/0003:046D:C539.0001/input/input6 [ 5.759031] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 5.768102] rockchip-pm rockchip-suspend: not set pwm-regulator-config [ 5.768133] rockchip-suspend not set sleep-mode-config for mem-lite [ 5.768143] rockchip-suspend not set wakeup-config for mem-lite [ 5.768158] rockchip-suspend not set sleep-mode-config for mem-ultra [ 5.768163] rockchip-suspend not set wakeup-config for mem-ultra [ 5.770031] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 406; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '13:36:29', on 'Jul 6 2023'. [ 5.770552] Mali: [ 5.770557] Mali device driver loaded [ 5.770570] ALSA device list: [ 5.770577] #0: rockchip-dp0 [ 5.770582] #1: rockchip-hdmi0 [ 5.770586] #2: rockchip-es8388 [ 5.776024] Freeing unused kernel memory: 6976K [ 5.797375] Run /init as init process [ 5.797387] with arguments: [ 5.797394] /init [ 5.797401] splash [ 5.797408] with environment: [ 5.797415] HOME=/ [ 5.797422] TERM=linux [ 5.797429] ubootpart= [ 5.797437] cgroup_enable=memory [ 5.797444] cgroup_memory=1 [ 5.811941] hid-generic 0003:046D:C539.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-fc840000.usb-1/input0 [ 5.818133] input: Logitech USB Receiver Mouse as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input7 [ 5.877199] input: Logitech USB Receiver Consumer Control as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input8 [ 5.877521] input: Logitech USB Receiver System Control as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input9 [ 5.878121] hid-generic 0003:046D:C539.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-fc840000.usb-1/input1 [ 5.882981] hid-generic 0003:046D:C539.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-fc840000.usb-1/input2 [ 6.835494] EXT4-fs (nvme0n1p2): mounted filesystem with writeback data mode. Opts: (null) [ 7.080608] NET: Registered protocol family 10 [ 7.082178] Segment Routing with IPv6 [ 7.099371] systemd[1]: systemd 249.11-0ubuntu3.9 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified) [ 7.100730] systemd[1]: Detected architecture arm64. [ 7.101726] systemd[1]: Hostname set to . [ 7.348068] systemd[1]: Queued start job for default target Graphical Interface. [ 7.349740] systemd[1]: Created slice Slice /system/modprobe. [ 7.350355] systemd[1]: Created slice Slice /system/serial-getty. [ 7.350849] systemd[1]: Created slice Slice /system/systemd-fsck. [ 7.351139] systemd[1]: Created slice User and Session Slice. [ 7.351271] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 7.351602] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 7.351718] systemd[1]: Reached target User and Group Name Lookups. [ 7.351770] systemd[1]: Reached target Slice Units. [ 7.351803] systemd[1]: Reached target Swaps. [ 7.351830] systemd[1]: Reached target System Time Set. [ 7.351888] systemd[1]: Reached target Local Verity Protected Volumes. [ 7.362581] systemd[1]: Listening on RPCbind Server Activation Socket. [ 7.362864] systemd[1]: Listening on Syslog Socket. [ 7.363027] systemd[1]: Listening on fsck to fsckd communication Socket. [ 7.363119] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 7.363394] systemd[1]: Listening on Journal Audit Socket. [ 7.363545] systemd[1]: Listening on Journal Socket (/dev/log). [ 7.363727] systemd[1]: Listening on Journal Socket. [ 7.364641] systemd[1]: Listening on udev Control Socket. [ 7.364794] systemd[1]: Listening on udev Kernel Socket. [ 7.365854] systemd[1]: Mounting Huge Pages File System... [ 7.367131] systemd[1]: Mounting POSIX Message Queue File System... [ 7.368337] systemd[1]: Mounting Kernel Debug File System... [ 7.369768] systemd[1]: Mounting Kernel Trace File System... [ 7.370127] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped. [ 7.371909] systemd[1]: Starting Restore / save the current clock... [ 7.373706] systemd[1]: Starting Set the console keyboard layout... [ 7.375267] systemd[1]: Starting Create List of Static Device Nodes... [ 7.377027] systemd[1]: Starting Load Kernel Module chromeos_pstore... [ 7.378860] systemd[1]: Starting Load Kernel Module configfs... [ 7.380848] systemd[1]: Starting Load Kernel Module drm... [ 7.383161] systemd[1]: Starting Load Kernel Module efi_pstore... [ 7.385211] systemd[1]: Starting Load Kernel Module fuse... [ 7.387014] systemd[1]: Starting Load Kernel Module pstore_blk... [ 7.389035] systemd[1]: Starting Load Kernel Module pstore_zone... [ 7.391529] systemd[1]: Starting Load Kernel Module ramoops... [ 7.391960] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 7.392451] fuse: init (API version 7.32) [ 7.394548] systemd[1]: Starting Load Kernel Modules... [ 7.396348] systemd[1]: Starting Remount Root and Kernel File Systems... [ 7.398137] systemd[1]: Starting Coldplug All udev Devices... [ 7.401691] systemd[1]: Mounted Huge Pages File System. [ 7.402056] systemd[1]: Mounted POSIX Message Queue File System. [ 7.402270] systemd[1]: Mounted Kernel Debug File System. [ 7.402473] systemd[1]: Mounted Kernel Trace File System. [ 7.403015] systemd[1]: Finished Restore / save the current clock. [ 7.403767] systemd[1]: Finished Create List of Static Device Nodes. [ 7.404264] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully. [ 7.404615] systemd[1]: Finished Load Kernel Module chromeos_pstore. [ 7.405083] systemd[1]: modprobe@configfs.service: Deactivated successfully. [ 7.405443] systemd[1]: Finished Load Kernel Module configfs. [ 7.405890] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 7.406230] systemd[1]: Finished Load Kernel Module drm. [ 7.406636] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [ 7.407123] systemd[1]: Finished Load Kernel Module efi_pstore. [ 7.407551] systemd[1]: modprobe@fuse.service: Deactivated successfully. [ 7.407848] systemd[1]: Finished Load Kernel Module fuse. [ 7.408217] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully. [ 7.408534] systemd[1]: Finished Load Kernel Module pstore_blk. [ 7.408895] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully. [ 7.409186] systemd[1]: Finished Load Kernel Module pstore_zone. [ 7.409543] systemd[1]: modprobe@ramoops.service: Deactivated successfully. [ 7.409845] systemd[1]: Finished Load Kernel Module ramoops. [ 7.410336] systemd[1]: Finished Load Kernel Modules. [ 7.412078] systemd[1]: Mounting FUSE Control File System... [ 7.413547] systemd[1]: Mounting Kernel Configuration File System... [ 7.413738] EXT4-fs (nvme0n1p2): re-mounted. Opts: commit=600,errors=remount-ro [ 7.415299] systemd[1]: Starting Apply Kernel Variables... [ 7.417687] systemd[1]: Finished Remount Root and Kernel File Systems. [ 7.418021] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 7.419517] systemd[1]: Starting Load/Save Random Seed... [ 7.422274] systemd[1]: Starting Create System Users... [ 7.423460] systemd[1]: Mounted FUSE Control File System. [ 7.423767] systemd[1]: Mounted Kernel Configuration File System. [ 7.431580] systemd[1]: Finished Apply Kernel Variables. [ 7.439362] systemd[1]: Finished Load/Save Random Seed. [ 7.439570] systemd[1]: Condition check resulted in First Boot Complete being skipped. [ 7.442019] systemd[1]: Finished Create System Users. [ 7.443137] systemd[1]: Starting Create Static Device Nodes in /dev... [ 7.463241] systemd[1]: Finished Create Static Device Nodes in /dev. [ 7.465458] systemd[1]: Starting Rule-based Manager for Device Events and Files... [ 7.474390] systemd[1]: Finished Set the console keyboard layout. [ 7.474655] systemd[1]: Reached target Preparation for Local File Systems. [ 7.476107] systemd[1]: Mounting /tmp... [ 7.480901] systemd[1]: Mounted /tmp. [ 7.539513] systemd[1]: Started Rule-based Manager for Device Events and Files. [ 7.634223] systemd[1]: Finished Coldplug All udev Devices. [ 7.638126] systemd[1]: Created slice Slice /system/systemd-backlight. [ 7.640697] systemd[1]: Starting Helper to synchronize boot up for ifupdown... [ 7.643970] systemd[1]: Starting Show Plymouth Boot Screen... [ 7.647190] systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:backlight... [ 7.649451] systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:backlight_1... [ 7.651288] systemd[1]: Finished Helper to synchronize boot up for ifupdown. [ 7.656836] systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:backlight. [ 7.669546] systemd[1]: Started Show Plymouth Boot Screen. [ 7.671680] systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:backlight_1. [ 7.672341] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 7.672631] systemd[1]: Started Forward Password Requests to Plymouth Directory Watch. [ 7.672744] systemd[1]: Reached target Local Encrypted Volumes. [ 7.746149] systemd[1]: Found device Samsung SSD 960 EVO 500GB armbi_boot. [ 7.758911] systemd[1]: Found device /dev/ttyFIQ0. [ 7.778255] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 7.778289] systemd[1]: Reached target Hardware activated USB gadget. [ 7.778401] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 7.779733] systemd[1]: Starting Load Kernel Module chromeos_pstore... [ 7.781564] systemd[1]: Starting Load Kernel Module efi_pstore... [ 7.782848] systemd[1]: Starting Load Kernel Module pstore_blk... [ 7.784139] systemd[1]: Starting Load Kernel Module pstore_zone... [ 7.785439] systemd[1]: Starting Load Kernel Module ramoops... [ 7.785580] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 7.787733] systemd[1]: Starting File System Check on /dev/disk/by-uuid/1BD1-7F33... [ 7.788432] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully. [ 7.788723] systemd[1]: Finished Load Kernel Module chromeos_pstore. [ 7.789126] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [ 7.789393] systemd[1]: Finished Load Kernel Module efi_pstore. [ 7.789768] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully. [ 7.790059] systemd[1]: Finished Load Kernel Module pstore_blk. [ 7.790445] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully. [ 7.790706] systemd[1]: Finished Load Kernel Module pstore_zone. [ 7.791084] systemd[1]: modprobe@ramoops.service: Deactivated successfully. [ 7.791342] systemd[1]: Finished Load Kernel Module ramoops. [ 7.791700] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 7.793879] systemd[1]: Started File System Check Daemon to report status. [ 7.831773] systemd[1]: Finished File System Check on /dev/disk/by-uuid/1BD1-7F33. [ 7.833217] systemd[1]: Mounting /boot... [ 7.837140] FAT-fs (nvme0n1p1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive! [ 7.840388] systemd[1]: Mounted /boot. [ 7.840546] systemd[1]: Reached target Local File Systems. [ 7.841653] systemd[1]: Starting Armbian leds state... [ 7.842857] systemd[1]: Starting Armbian ZRAM config... [ 7.844064] systemd[1]: Starting Set console font and keymap... [ 7.845245] systemd[1]: Starting Raise network interfaces... [ 7.846326] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data... [ 7.846421] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped. [ 7.847030] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. [ 7.847080] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 7.847125] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 7.848938] systemd[1]: Finished Set console font and keymap. [ 7.858956] systemd[1]: Received SIGRTMIN+20 from PID 292 (plymouthd). [ 7.861824] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data. [ 7.863042] systemd[1]: Finished Armbian leds state. [ 7.943168] zram0: detected capacity change from 0 to 4031107072 [ 7.987062] Adding 3936624k swap on /dev/zram0. Priority:5 extents:1 across:3936624k SS [ 7.998069] zram: Added device: zram1 [ 8.000724] systemd[1]: Finished Raise network interfaces. [ 8.125930] zram1: detected capacity change from 0 to 52428800 [ 8.157855] systemd[1]: Finished Armbian ZRAM config. [ 8.164691] systemd[1]: Starting Armbian memory supported logging... [ 8.214746] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard [ 8.730332] vendor storage:20190527 ret = -1 [ 9.689504] systemd[1]: Finished Armbian memory supported logging. [ 9.704783] systemd[1]: Starting Journal Service... [ 9.849972] systemd[1]: Started Journal Service. [ 9.879902] systemd-journald[721]: Received client request to flush runtime journal. ### armbian-release: # PLEASE DO NOT EDIT THIS FILE BOARD=orangepi5 BOARD_NAME="Orange Pi 5" BOARDFAMILY=rockchip-rk3588 BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=bfc8271 VERSION=23.08.0-trunk LINUXFAMILY=rk35xx ARCH=arm64 IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm64 KERNEL_IMAGE_TYPE=Image FORCE_BOOTSCRIPT_UPDATE= VENDOR=Armbian REVISION=23.08.0-trunk BOOTSCRIPT_FORCE_UPDATE="no" BOOTSCRIPT_DST="boot.cmd" BRANCH=legacy ### boot environment: verbosity=1 bootlogo=true overlay_prefix=rockchip-rk3588 fdtfile=rockchip/rk3588s-orangepi-5.dtb rootdev=UUID=329a3cf7-a8ce-4ea6-a3ef-c2128bda1678 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u ### lsusb: Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 002: ID 046d:c539 Logitech, Inc. USB Receiver Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub ### lscpu: Architecture: aarch64 CPU op-mode(s): 32-bit, 64-bit Byte Order: Little Endian CPU(s): 8 On-line CPU(s) list: 0-7 Vendor ID: ARM Model name: Cortex-A55 Model: 0 Thread(s) per core: 1 Core(s) per socket: 4 Socket(s): 1 Stepping: r2p0 CPU max MHz: 1800.0000 CPU min MHz: 408.0000 BogoMIPS: 48.00 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp Model name: Cortex-A76 Model: 0 Thread(s) per core: 1 Core(s) per socket: 2 Socket(s): 2 Stepping: r4p0 CPU max MHz: 2256.0000 CPU min MHz: 408.0000 BogoMIPS: 48.00 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp L1d cache: 384 KiB (8 instances) L1i cache: 384 KiB (8 instances) L2 cache: 2.5 MiB (8 instances) L3 cache: 3 MiB (1 instance) Vulnerability Itlb multihit: Not affected Vulnerability L1tf: Not affected Vulnerability Mds: Not affected Vulnerability Meltdown: Not affected Vulnerability Mmio stale data: Not affected Vulnerability Retbleed: Not affected Vulnerability Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl Vulnerability Spectre v1: Mitigation; __user pointer sanitization Vulnerability Spectre v2: Vulnerable: Unprivileged eBPF enabled Vulnerability Srbds: Not affected Vulnerability Tsx async abort: Not affected ### cpuinfo: processor : 0 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 1 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 2 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 3 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 4 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 processor : 5 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 processor : 6 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 processor : 7 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 Serial : 2eae2cb9d903d20e ### meminfo: MemTotal: 7873256 kB MemFree: 7577720 kB MemAvailable: 7596808 kB Buffers: 11076 kB Cached: 80468 kB SwapCached: 0 kB Active: 23596 kB Inactive: 99884 kB Active(anon): 556 kB Inactive(anon): 60976 kB Active(file): 23040 kB Inactive(file): 38908 kB Unevictable: 19608 kB Mlocked: 0 kB SwapTotal: 3936624 kB SwapFree: 3936624 kB Dirty: 2716 kB Writeback: 0 kB AnonPages: 52004 kB Mapped: 28824 kB Shmem: 25792 kB KReclaimable: 37708 kB Slab: 78100 kB SReclaimable: 37708 kB SUnreclaim: 40392 kB KernelStack: 3744 kB PageTables: 2904 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 7873252 kB Committed_AS: 121904 kB VmallocTotal: 135290290112 kB VmallocUsed: 36516 kB VmallocChunk: 0 kB Percpu: 2624 kB CmaTotal: 262144 kB CmaAllocated: 4672 kB CmaReleased: 257472 kB CmaFree: 257472 kB HugePages_Total: 0 HugePages_Free: 0 HugePages_Rsvd: 0 HugePages_Surp: 0 Hugepagesize: 2048 kB Hugetlb: 0 kB ### virtual memory: vm.admin_reserve_kbytes = 8192 vm.block_dump = 0 vm.dirty_background_bytes = 0 vm.dirty_background_ratio = 10 vm.dirty_bytes = 0 vm.dirty_expire_centisecs = 3000 vm.dirty_ratio = 20 vm.dirtytime_expire_seconds = 43200 vm.dirty_writeback_centisecs = 500 vm.extra_free_kbytes = 0 vm.hugetlb_shm_group = 0 vm.laptop_mode = 0 vm.legacy_va_layout = 0 vm.lowmem_reserve_ratio = 256 256 32 0 vm.max_map_count = 65530 vm.min_free_kbytes = 11208 vm.mmap_min_addr = 32768 vm.mmap_rnd_bits = 18 vm.mmap_rnd_compat_bits = 11 vm.nr_hugepages = 0 vm.nr_overcommit_hugepages = 0 vm.oom_dump_tasks = 1 vm.oom_kill_allocating_task = 0 vm.overcommit_kbytes = 0 vm.overcommit_memory = 0 vm.overcommit_ratio = 50 vm.page-cluster = 0 vm.page_lock_unfairness = 5 vm.panic_on_oom = 0 vm.percpu_pagelist_fraction = 0 vm.stat_interval = 1 vm.swappiness = 100 vm.user_reserve_kbytes = 131072 vm.vfs_cache_pressure = 100 vm.watermark_boost_factor = 15000 vm.watermark_scale_factor = 10 ### ip addr: 1: lo: mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet XXX.XXX.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: eth0: mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether ae:d8:3f:81:fa:0b brd ff:ff:ff:ff:ff:ff ### partitions: major minor #blocks name 254 0 3936628 zram0 31 0 16384 mtdblock0 259 0 488386584 nvme0n1 259 1 262144 nvme0n1p1 259 2 483213312 nvme0n1p2 254 1 51200 zram1 ### df: tmpfs 769M 9.7M 760M 2% /run /dev/nvme0n1p2 454G 5.4G 444G 2% / tmpfs 3.8G 0 3.8G 0% /dev/shm tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs 3.8G 268K 3.8G 1% /tmp /dev/nvme0n1p1 256M 106M 151M 42% /boot /dev/zram1 47M 3.0M 41M 7% /var/log ### lsblk: NAME FSTYPE SIZE MOUNTPOINT UUID mtdblock0 16M zram1 50M /var/log nvme0n1 465.8G ├─nvme0n1p1 vfat 256M /boot 1BD1-7F33 └─nvme0n1p2 ext4 460.8G / 329a3cf7-a8ce-4ea6-a3ef-c2128bda1678 ### zramctl: NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT /dev/zram1 zstd 50M 3M 561.7K 944K 8 /var/log /dev/zram0 lzo-rle 3.8G 4K 74B 12K 8 [SWAP] ### mtab: /dev/nvme0n1p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=936,iocharset=utf8,shortname=mixed,errors=remount-ro 0 0 /dev/nvme0n1p2 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0 /dev/nvme0n1p2 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0 ### Boot system health: Time CPU_cl0/CPU_cl1 load %cpu %sys %usr %nice %io %irq Tcpu C.St. 20:50:16 1800/2256 MHz 0.32 20% 12% 7% 0% 0% 0% 42.5 °C 0/7 20:50:17 1800/2256 MHz 0.32 31% 8% 17% 0% 6% 0% 40.7 °C 0/7 20:50:17 1800/2256 MHz 0.32 17% 4% 12% 0% 0% 0% 40.7 °C 0/7 20:50:17 1800/2256 MHz 0.32 18% 5% 12% 0% 0% 0% 39.8 °C 0/7 20:50:18 1800/2256 MHz 0.32 17% 3% 13% 0% 0% 0% 38.8 °C 0/7 ### Activated 1 lzo-rle zram swap devices with 3844MB each. ### Activated Armbian ramlog partition with zstd compression Mon Aug 7 09:00:23 PM +03 2023 | Orange Pi 5 | 23.08.0-trunk | arm64 | aarch64 | 5.10.160-rk35xx ### dmesg: [ 1.766798] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [ 1.766822] Linux version 5.10.160-rk35xx (armbian@next) (aarch64-linux-gnu-gcc (Ubuntu 11.3.0-1ubuntu1~22.04) 11.3.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP Thu Jul 6 13:36:29 UTC 2023 [ 1.777635] Machine model: Orange Pi 5 [ 1.777816] efi: UEFI not found. [ 1.781469] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB [ 1.781488] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@00000000': base 0x0000000000000000, size 0 MiB [ 1.781579] Reserved memory: created CMA memory pool at 0x0000000010000000, size 256 MiB [ 1.781584] OF: reserved mem: initialized node cma, compatible id shared-dma-pool [ 1.932149] Zone ranges: [ 1.932157] DMA [mem 0x0000000000200000-0x00000000ffffffff] [ 1.932169] DMA32 empty [ 1.932176] Normal [mem 0x0000000100000000-0x00000001ffffffff] [ 1.932184] Movable zone start for each node [ 1.932187] Early memory node ranges [ 1.932193] node 0: [mem 0x0000000000200000-0x00000000efffffff] [ 1.932202] node 0: [mem 0x0000000100000000-0x00000001ffffffff] [ 1.932210] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff] [ 1.932217] On node 0 totalpages: 2031104 [ 1.932222] DMA zone: 15352 pages used for memmap [ 1.932227] DMA zone: 0 pages reserved [ 1.932232] DMA zone: 982528 pages, LIFO batch:63 [ 1.932237] Normal zone: 16384 pages used for memmap [ 1.932242] Normal zone: 1048576 pages, LIFO batch:63 [ 1.979213] psci: probing for conduit method from DT. [ 1.979225] psci: PSCIv1.1 detected in firmware. [ 1.979229] psci: Using standard PSCI v0.2 function IDs [ 1.979236] psci: MIGRATE_INFO_TYPE not supported. [ 1.979243] psci: SMC Calling Convention v1.2 [ 1.979666] percpu: Embedded 32 pages/cpu s93480 r8192 d29400 u131072 [ 1.979709] pcpu-alloc: s93480 r8192 d29400 u131072 alloc=32*4096 [ 1.979717] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7 [ 1.979860] Detected VIPT I-cache on CPU0 [ 1.979909] CPU features: detected: GIC system register CPU interface [ 1.979915] CPU features: detected: Virtualization Host Extensions [ 1.979925] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 1.979937] alternatives: patching kernel code [ 1.980324] Built 1 zonelists, mobility grouping on. Total pages: 1999368 [ 1.980335] Kernel command line: root=UUID=329a3cf7-a8ce-4ea6-a3ef-c2128bda1678 rootwait rootfstype=ext4 splash plymouth.ignore-serial-consoles console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart= usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 [ 1.981670] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) [ 1.982075] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 1.982083] mem auto-init: stack:off, heap alloc:off, heap free:off [ 1.988590] software IO TLB: mapped [mem 0x00000000ec000000-0x00000000f0000000] (64MB) [ 2.062167] Memory: 7589180K/8124416K available (16832K kernel code, 3506K rwdata, 6500K rodata, 6976K init, 639K bss, 273092K reserved, 262144K cma-reserved) [ 2.062328] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1 [ 2.062363] ftrace: allocating 64539 entries in 253 pages [ 2.172753] ftrace: allocated 253 pages with 7 groups [ 2.173059] rcu: Hierarchical RCU implementation. [ 2.173066] rcu: RCU event tracing is enabled. [ 2.173071] Rude variant of Tasks RCU enabled. [ 2.173075] Tracing variant of Tasks RCU enabled. [ 2.173080] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies. [ 2.178723] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 2.181553] GICv3: GIC: Using split EOI/Deactivate mode [ 2.181560] GICv3: 480 SPIs implemented [ 2.181564] GICv3: 0 Extended SPIs implemented [ 2.181603] GICv3: Distributor has no Range Selector support [ 2.181613] GICv3: 16 PPIs implemented [ 2.181658] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000 [ 2.181786] ITS [mem 0xfe640000-0xfe65ffff] [ 2.181843] ITS@0x00000000fe640000: allocated 8192 Devices @100200000 (indirect, esz 8, psz 64K, shr 0) [ 2.181872] ITS@0x00000000fe640000: allocated 32768 Interrupt Collections @100210000 (flat, esz 2, psz 64K, shr 0) [ 2.181883] ITS: using cache flushing for cmd queue [ 2.181925] ITS [mem 0xfe660000-0xfe67ffff] [ 2.181974] ITS@0x00000000fe660000: allocated 8192 Devices @100230000 (indirect, esz 8, psz 64K, shr 0) [ 2.182002] ITS@0x00000000fe660000: allocated 32768 Interrupt Collections @100240000 (flat, esz 2, psz 64K, shr 0) [ 2.182011] ITS: using cache flushing for cmd queue [ 2.182234] GICv3: using LPI property table @0x0000000100250000 [ 2.182364] GIC: using cache flushing for LPI property table [ 2.182375] GICv3: CPU0: using allocated LPI pending table @0x0000000100260000 [ 2.318750] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 2.318760] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 2.318771] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 2.320146] Console: colour dummy device 80x25 [ 2.320189] printk: console [tty1] enabled [ 2.320219] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000) [ 2.320231] pid_max: default: 32768 minimum: 301 [ 2.320343] LSM: Security Framework initializing [ 2.320414] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 2.320440] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 2.322690] rcu: Hierarchical SRCU implementation. [ 2.323667] Platform MSI: msi-controller@fe640000 domain created [ 2.323690] Platform MSI: msi-controller@fe660000 domain created [ 2.324080] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe640000 domain created [ 2.324106] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe660000 domain created [ 2.324297] EFI services will not be available. [ 2.324749] smp: Bringing up secondary CPUs ... [ 2.325471] Detected VIPT I-cache on CPU1 [ 2.325509] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000 [ 2.325528] GICv3: CPU1: using allocated LPI pending table @0x0000000100270000 [ 2.325573] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [ 2.326347] Detected VIPT I-cache on CPU2 [ 2.326378] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000 [ 2.326397] GICv3: CPU2: using allocated LPI pending table @0x0000000100280000 [ 2.326439] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [ 2.327169] Detected VIPT I-cache on CPU3 [ 2.327199] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000 [ 2.327217] GICv3: CPU3: using allocated LPI pending table @0x0000000100290000 [ 2.327256] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [ 2.327999] CPU features: detected: Spectre-v4 [ 2.328002] CPU features: detected: Spectre-BHB [ 2.328005] Detected PIPT I-cache on CPU4 [ 2.328020] GICv3: CPU4: found redistributor 400 region 0:0x00000000fe700000 [ 2.328031] GICv3: CPU4: using allocated LPI pending table @0x00000001002a0000 [ 2.328056] CPU4: Booted secondary processor 0x0000000400 [0x414fd0b0] [ 2.328779] Detected PIPT I-cache on CPU5 [ 2.328795] GICv3: CPU5: found redistributor 500 region 0:0x00000000fe720000 [ 2.328806] GICv3: CPU5: using allocated LPI pending table @0x00000001002b0000 [ 2.328833] CPU5: Booted secondary processor 0x0000000500 [0x414fd0b0] [ 2.329526] Detected PIPT I-cache on CPU6 [ 2.329542] GICv3: CPU6: found redistributor 600 region 0:0x00000000fe740000 [ 2.329552] GICv3: CPU6: using allocated LPI pending table @0x00000001002c0000 [ 2.329578] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b0] [ 2.330253] Detected PIPT I-cache on CPU7 [ 2.330269] GICv3: CPU7: found redistributor 700 region 0:0x00000000fe760000 [ 2.330279] GICv3: CPU7: using allocated LPI pending table @0x00000001002d0000 [ 2.330305] CPU7: Booted secondary processor 0x0000000700 [0x414fd0b0] [ 2.330383] smp: Brought up 1 node, 8 CPUs [ 2.330404] SMP: Total of 8 processors activated. [ 2.330409] CPU features: detected: Privileged Access Never [ 2.330414] CPU features: detected: User Access Override [ 2.330419] CPU features: detected: 32-bit EL0 Support [ 2.330424] CPU features: detected: Common not Private translations [ 2.330428] CPU features: detected: RAS Extension Support [ 2.330433] CPU features: detected: Data cache clean to the PoU not required for I/D coherence [ 2.330438] CPU features: detected: CRC32 instructions [ 2.330442] CPU features: detected: Speculative Store Bypassing Safe (SSBS) [ 2.330448] CPU features: detected: RCpc load-acquire (LDAPR) [ 2.330532] CPU: All CPU(s) started at EL2 [ 2.333751] devtmpfs: initialized [ 2.348722] Registered cp15_barrier emulation handler [ 2.348731] Registered setend emulation handler [ 2.348736] KASLR disabled due to lack of seed [ 2.348823] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns [ 2.348830] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 2.351584] pinctrl core: initialized pinctrl subsystem [ 2.351704] regulator-dummy: no parameters, enabled [ 2.351822] DMI not present or invalid. [ 2.352126] NET: Registered protocol family 16 [ 2.353154] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations [ 2.353258] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 2.353276] audit: initializing netlink subsys (disabled) [ 2.353353] audit: type=2000 audit(0.033:1): state=initialized audit_enabled=0 res=1 [ 2.353874] Registered FIQ tty driver [ 2.354032] thermal_sys: Registered thermal governor 'fair_share' [ 2.354035] thermal_sys: Registered thermal governor 'step_wise' [ 2.354037] thermal_sys: Registered thermal governor 'user_space' [ 2.354039] thermal_sys: Registered thermal governor 'power_allocator' [ 2.354364] cpuidle: using governor menu [ 2.354590] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 2.354725] ASID allocator initialised with 65536 entries [ 2.356207] ramoops: dmesg-0 0x20000@0x0000000000110000 [ 2.356225] ramoops: console 0x80000@0x0000000000130000 [ 2.356237] ramoops: pmsg 0x50000@0x00000000001b0000 [ 2.356284] printk: console [ramoops-1] enabled [ 2.356286] pstore: Registered ramoops as persistent store backend [ 2.356289] ramoops: using 0xf0000@0x110000, ecc: 0 [ 2.410251] rockchip-gpio fd8a0000.gpio: probed /pinctrl/gpio@fd8a0000 [ 2.410544] rockchip-gpio fec20000.gpio: probed /pinctrl/gpio@fec20000 [ 2.410777] rockchip-gpio fec30000.gpio: probed /pinctrl/gpio@fec30000 [ 2.411050] rockchip-gpio fec40000.gpio: probed /pinctrl/gpio@fec40000 [ 2.411324] rockchip-gpio fec50000.gpio: probed /pinctrl/gpio@fec50000 [ 2.411373] rockchip-pinctrl pinctrl: probed pinctrl [ 2.420042] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 2.420047] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 2.420049] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 2.420052] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 2.482069] raid6: neonx8 gen() 5362 MB/s [ 2.538816] raid6: neonx8 xor() 4164 MB/s [ 2.595565] raid6: neonx4 gen() 5498 MB/s [ 2.652315] raid6: neonx4 xor() 4145 MB/s [ 2.709067] raid6: neonx2 gen() 5043 MB/s [ 2.765814] raid6: neonx2 xor() 3942 MB/s [ 2.822566] raid6: neonx1 gen() 4214 MB/s [ 2.879312] raid6: neonx1 xor() 3248 MB/s [ 2.936068] raid6: int64x8 gen() 1312 MB/s [ 2.992817] raid6: int64x8 xor() 853 MB/s [ 3.049565] raid6: int64x4 gen() 1616 MB/s [ 3.106318] raid6: int64x4 xor() 879 MB/s [ 3.163069] raid6: int64x2 gen() 1884 MB/s [ 3.219816] raid6: int64x2 xor() 1300 MB/s [ 3.276565] raid6: int64x1 gen() 1967 MB/s [ 3.333322] raid6: int64x1 xor() 960 MB/s [ 3.333325] raid6: using algorithm neonx4 gen() 5498 MB/s [ 3.333327] raid6: .... xor() 4145 MB/s, rmw enabled [ 3.333329] raid6: using neon recovery algorithm [ 3.333948] fiq_debugger fiq_debugger.0: IRQ fiq not found [ 3.333954] fiq_debugger fiq_debugger.0: IRQ wakeup not found [ 3.333958] fiq_debugger_probe: could not install nmi irq handler [ 3.334042] printk: console [ttyFIQ0] enabled [ 3.334147] Registered fiq debugger ttyFIQ0 [ 3.334357] vcc12v_dcin: 12000 mV, enabled [ 3.334437] reg-fixed-voltage vcc12v-dcin: vcc12v_dcin supplying 12000000uV [ 3.334487] reg-fixed-voltage vcc5v0-sys: Looking up vin-supply from device tree [ 3.334491] vcc5v0_sys: supplied by vcc12v_dcin [ 3.334495] vcc12v_dcin: could not add device link regulator.2: -ENOENT [ 3.334512] vcc5v0_sys: 5000 mV, enabled [ 3.334578] reg-fixed-voltage vcc5v0-sys: vcc5v0_sys supplying 5000000uV [ 3.334626] reg-fixed-voltage vcc5v0-usbdcin: Looking up vin-supply from device tree [ 3.334630] vcc5v0_usbdcin: supplied by vcc12v_dcin [ 3.334633] vcc12v_dcin: could not add device link regulator.3: -ENOENT [ 3.334648] vcc5v0_usbdcin: 5000 mV, enabled [ 3.334714] reg-fixed-voltage vcc5v0-usbdcin: vcc5v0_usbdcin supplying 5000000uV [ 3.334759] reg-fixed-voltage vcc5v0-usb: Looking up vin-supply from device tree [ 3.334763] vcc5v0_usb: supplied by vcc5v0_usbdcin [ 3.334767] vcc5v0_usbdcin: could not add device link regulator.4: -ENOENT [ 3.334782] vcc5v0_usb: 5000 mV, enabled [ 3.334838] reg-fixed-voltage vcc5v0-usb: vcc5v0_usb supplying 5000000uV [ 3.334942] vbus5v0_typec: 5000 mV, disabled [ 3.334992] reg-fixed-voltage vbus5v0-typec: Looking up vin-supply from device tree [ 3.334996] vbus5v0_typec: supplied by vcc5v0_usb [ 3.335030] reg-fixed-voltage vbus5v0-typec: vbus5v0_typec supplying 5000000uV [ 3.335081] reg-fixed-voltage vcc-1v1-nldo-s3: Looking up vin-supply from device tree [ 3.335085] vcc_1v1_nldo_s3: supplied by vcc5v0_sys [ 3.335088] vcc5v0_sys: could not add device link regulator.6: -ENOENT [ 3.335105] vcc_1v1_nldo_s3: 1100 mV, enabled [ 3.335169] reg-fixed-voltage vcc-1v1-nldo-s3: vcc_1v1_nldo_s3 supplying 1100000uV [ 3.335222] reg-fixed-voltage vcc3v3-pcie2x1l2: Looking up vin-supply from device tree [ 3.335226] vcc3v3_pcie2x1l2: supplied by vcc5v0_sys [ 3.335230] vcc5v0_sys: could not add device link regulator.7: -ENOENT [ 3.391021] vcc3v3_pcie2x1l2: 1800 mV, enabled [ 3.391089] reg-fixed-voltage vcc3v3-pcie2x1l2: vcc3v3_pcie2x1l2 supplying 1800000uV [ 3.391371] iommu: Default domain type: Translated [ 3.391806] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vdpu-supply from device tree [ 3.391825] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vdpu-supply property in node /power-management@fd8d8000/power-controller failed [ 3.392093] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga30-supply from device tree [ 3.392110] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga30-supply property in node /power-management@fd8d8000/power-controller failed [ 3.392291] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga31-supply from device tree [ 3.392309] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga31-supply property in node /power-management@fd8d8000/power-controller failed [ 3.393617] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc0-supply from device tree [ 3.393636] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc0-supply property in node /power-management@fd8d8000/power-controller failed [ 3.393791] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vcodec-supply from device tree [ 3.393808] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vcodec-supply property in node /power-management@fd8d8000/power-controller failed [ 3.393910] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc1-supply from device tree [ 3.393927] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc1-supply property in node /power-management@fd8d8000/power-controller failed [ 3.394204] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec0-supply from device tree [ 3.394221] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec0-supply property in node /power-management@fd8d8000/power-controller failed [ 3.394512] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec1-supply from device tree [ 3.394529] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec1-supply property in node /power-management@fd8d8000/power-controller failed [ 3.394750] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vi-supply from device tree [ 3.394767] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vi-supply property in node /power-management@fd8d8000/power-controller failed [ 3.395000] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up isp1-supply from device tree [ 3.395017] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up isp1-supply property in node /power-management@fd8d8000/power-controller failed [ 3.395721] SCSI subsystem initialized [ 3.395736] libata version 3.00 loaded. [ 3.395812] usbcore: registered new interface driver usbfs [ 3.395828] usbcore: registered new interface driver hub [ 3.395842] usbcore: registered new device driver usb [ 3.395882] mc: Linux media interface: v0.10 [ 3.395892] videodev: Linux video capture interface: v2.00 [ 3.395922] pps_core: LinuxPPS API ver. 1 registered [ 3.395924] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [ 3.395929] PTP clock support registered [ 3.396198] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled. [ 3.396233] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0 [ 3.397439] Advanced Linux Sound Architecture Driver Initialized. [ 3.397704] Bluetooth: Core ver 2.22 [ 3.397718] NET: Registered protocol family 31 [ 3.397721] Bluetooth: HCI device and connection manager initialized [ 3.397725] Bluetooth: HCI socket layer initialized [ 3.397729] Bluetooth: L2CAP socket layer initialized [ 3.397735] Bluetooth: SCO socket layer initialized [ 3.397749] NetLabel: Initializing [ 3.397751] NetLabel: domain hash size = 128 [ 3.397753] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 3.397779] NetLabel: unlabeled traffic allowed by default [ 3.399109] rockchip-cpuinfo cpuinfo: SoC : 35881000 [ 3.399113] rockchip-cpuinfo cpuinfo: Serial : 2eae2cb9d903d20e [ 3.399555] clocksource: Switched to clocksource arch_sys_counter [ 3.816514] VFS: Disk quotas dquot_6.6.0 [ 3.816543] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 3.822236] NET: Registered protocol family 2 [ 3.822359] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 3.824392] tcp_listen_portaddr_hash hash table entries: 4096 (order: 5, 163840 bytes, linear) [ 3.824490] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 3.824837] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear) [ 3.825640] TCP: Hash tables configured (established 65536 bind 65536) [ 3.825750] MPTCP token hash table entries: 8192 (order: 6, 393216 bytes, linear) [ 3.825848] UDP hash table entries: 4096 (order: 6, 393216 bytes, linear) [ 3.826004] UDP-Lite hash table entries: 4096 (order: 6, 393216 bytes, linear) [ 3.826236] NET: Registered protocol family 1 [ 3.826605] RPC: Registered named UNIX socket transport module. [ 3.826607] RPC: Registered udp transport module. [ 3.826609] RPC: Registered tcp transport module. [ 3.826611] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 3.827077] PCI: CLS 0 bytes, default 64 [ 3.827394] Trying to unpack rootfs image as initramfs... [ 4.222291] Freeing initrd memory: 14956K [ 4.223018] rockchip-thermal fec00000.tsadc: Missing rockchip,grf property [ 4.223659] rockchip-thermal fec00000.tsadc: tsadc is probed successfully! [ 4.224599] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 4.225214] kvm [1]: IPA Size Limit: 40 bits [ 4.225225] kvm [1]: GICv3: no GICV resource entry [ 4.225228] kvm [1]: disabling GICv2 emulation [ 4.225230] kvm [1]: GIC system register CPU interface enabled [ 4.225380] kvm [1]: vgic interrupt IRQ9 [ 4.225559] kvm [1]: VHE mode initialized successfully [ 4.228636] Initialise system trusted keyrings [ 4.228756] workingset: timestamp_bits=46 max_order=21 bucket_order=0 [ 4.231838] NFS: Registering the id_resolver key type [ 4.231853] Key type id_resolver registered [ 4.231855] Key type id_legacy registered [ 4.231892] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 4.231894] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 4.231907] ntfs: driver 2.1.32 [Flags: R/W]. [ 4.253685] NET: Registered protocol family 38 [ 4.253690] xor: measuring software checksum speed [ 4.255301] 8regs : 6119 MB/sec [ 4.256521] 32regs : 8135 MB/sec [ 4.257516] arm64_neon : 9907 MB/sec [ 4.257518] xor: using function: arm64_neon (9907 MB/sec) [ 4.257523] Key type asymmetric registered [ 4.257526] Asymmetric key parser 'x509' registered [ 4.257542] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242) [ 4.257658] io scheduler mq-deadline registered [ 4.257663] io scheduler kyber registered [ 4.259488] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up phy-supply from device tree [ 4.259497] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up phy-supply property in node /syscon@fd5d0000/usb2-phy@0/otg-port failed [ 4.259546] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up vbus-supply from device tree [ 4.259583] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up vbus-supply property in node /syscon@fd5d0000/usb2-phy@0/otg-port failed [ 4.260917] phy phy-fd5d8000.syscon:usb2-phy@8000.1: Looking up phy-supply from device tree [ 4.260925] phy phy-fd5d8000.syscon:usb2-phy@8000.1: Looking up phy-supply property in node /syscon@fd5d8000/usb2-phy@8000/host-port failed [ 4.262107] phy phy-fd5dc000.syscon:usb2-phy@c000.2: Looking up phy-supply from device tree [ 4.262116] phy phy-fd5dc000.syscon:usb2-phy@c000.2: Looking up phy-supply property in node /syscon@fd5dc000/usb2-phy@c000/host-port failed [ 4.263980] phy phy-fee00000.phy.3: Looking up phy-supply from device tree [ 4.263987] phy phy-fee00000.phy.3: Looking up phy-supply property in node /phy@fee00000 failed [ 4.264136] phy phy-fee20000.phy.4: Looking up phy-supply from device tree [ 4.264141] phy phy-fee20000.phy.4: Looking up phy-supply property in node /phy@fee20000 failed [ 4.264636] phy phy-feda0000.phy.5: Looking up phy-supply from device tree [ 4.264643] phy phy-feda0000.phy.5: Looking up phy-supply property in node /phy@feda0000 failed [ 4.264773] phy phy-fedb0000.phy.6: Looking up phy-supply from device tree [ 4.264778] phy phy-fedb0000.phy.6: Looking up phy-supply property in node /phy@fedb0000 failed [ 4.265149] phy phy-fed60000.hdmiphy.7: Looking up phy-supply from device tree [ 4.265156] phy phy-fed60000.hdmiphy.7: Looking up phy-supply property in node /hdmiphy@fed60000 failed [ 4.265935] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy init success [ 4.266892] phy phy-fed80000.phy.8: Looking up phy-supply from device tree [ 4.266899] phy phy-fed80000.phy.8: Looking up phy-supply property in node /phy@fed80000/dp-port failed [ 4.266934] phy phy-fed80000.phy.9: Looking up phy-supply from device tree [ 4.266939] phy phy-fed80000.phy.9: Looking up phy-supply property in node /phy@fed80000/u3-port failed [ 4.268380] rk-pcie fe190000.pcie: invalid prsnt-gpios property in node [ 4.268390] rk-pcie fe190000.pcie: Looking up vpcie3v3-supply from device tree [ 4.268749] pwm-backlight backlight: Looking up power-supply from device tree [ 4.268755] pwm-backlight backlight: Looking up power-supply property in node /backlight failed [ 4.268760] pwm-backlight backlight: supply power not found, using dummy regulator [ 4.268945] pwm-backlight backlight_1: Looking up power-supply from device tree [ 4.268952] pwm-backlight backlight_1: Looking up power-supply property in node /backlight_1 failed [ 4.268956] pwm-backlight backlight_1: supply power not found, using dummy regulator [ 4.269049] rk-pcie fe190000.pcie: IRQ msi not found [ 4.269056] rk-pcie fe190000.pcie: use outband MSI support [ 4.269062] rk-pcie fe190000.pcie: Missing *config* reg space [ 4.269088] rk-pcie fe190000.pcie: host bridge /pcie@fe190000 ranges: [ 4.269118] rk-pcie fe190000.pcie: err 0x00f4000000..0x00f40fffff -> 0x00f4000000 [ 4.269143] rk-pcie fe190000.pcie: IO 0x00f4100000..0x00f41fffff -> 0x00f4100000 [ 4.269168] rk-pcie fe190000.pcie: MEM 0x00f4200000..0x00f4ffffff -> 0x00f4200000 [ 4.269184] rk-pcie fe190000.pcie: MEM 0x0a00000000..0x0a3fffffff -> 0x0a00000000 [ 4.269217] rk-pcie fe190000.pcie: Missing *config* reg space [ 4.269236] iep: Module initialized. [ 4.269248] rk-pcie fe190000.pcie: invalid resource [ 4.269276] mpp_service mpp-srv: unknown mpp version for missing VCS info [ 4.269278] mpp_service mpp-srv: probe start [ 4.271283] mpp_vdpu2 fdb50400.vdpu: Adding to iommu group 1 [ 4.271503] mpp_vdpu2 fdb50400.vdpu: probe device [ 4.271622] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0 [ 4.271629] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0 [ 4.271770] mpp_vdpu2 fdb50400.vdpu: probing finish [ 4.271982] mpp_vepu2 jpege-ccu: probing start [ 4.271986] mpp_vepu2 jpege-ccu: probing finish [ 4.272094] mpp_vepu2 fdb50000.vepu: Adding to iommu group 1 [ 4.272179] mpp_vepu2 fdb50000.vepu: probing start [ 4.272272] mpp_vepu2 fdb50000.vepu: reset_group->rw_sem_on=0 [ 4.272276] mpp_vepu2 fdb50000.vepu: reset_group->rw_sem_on=0 [ 4.272420] mpp_vepu2 fdb50000.vepu: probing finish [ 4.272538] mpp_vepu2 fdba0000.jpege-core: Adding to iommu group 5 [ 4.272678] mpp_vepu2 fdba0000.jpege-core: probing start [ 4.272788] mpp_vepu2 fdba0000.jpege-core: attach ccu success [ 4.272946] mpp_vepu2 fdba0000.jpege-core: probing finish [ 4.273056] mpp_vepu2 fdba4000.jpege-core: Adding to iommu group 6 [ 4.273194] mpp_vepu2 fdba4000.jpege-core: probing start [ 4.273302] mpp_vepu2 fdba4000.jpege-core: attach ccu success [ 4.273442] mpp_vepu2 fdba4000.jpege-core: probing finish [ 4.273551] mpp_vepu2 fdba8000.jpege-core: Adding to iommu group 7 [ 4.273686] mpp_vepu2 fdba8000.jpege-core: probing start [ 4.273790] mpp_vepu2 fdba8000.jpege-core: attach ccu success [ 4.273923] mpp_vepu2 fdba8000.jpege-core: probing finish [ 4.274018] mpp_vepu2 fdbac000.jpege-core: Adding to iommu group 8 [ 4.274156] mpp_vepu2 fdbac000.jpege-core: probing start [ 4.274261] mpp_vepu2 fdbac000.jpege-core: attach ccu success [ 4.274405] mpp_vepu2 fdbac000.jpege-core: probing finish [ 4.274679] mpp-iep2 fdbb0000.iep: Adding to iommu group 9 [ 4.274817] mpp-iep2 fdbb0000.iep: probe device [ 4.274944] mpp-iep2 fdbb0000.iep: allocate roi buffer failed [ 4.275073] mpp-iep2 fdbb0000.iep: probing finish [ 4.275292] mpp_jpgdec fdb90000.jpegd: Adding to iommu group 4 [ 4.275497] mpp_jpgdec fdb90000.jpegd: probe device [ 4.275760] mpp_jpgdec fdb90000.jpegd: probing finish [ 4.276124] mpp_rkvdec2 fdc30000.rkvdec-ccu: rkvdec-ccu, probing start [ 4.276185] mpp_rkvdec2 fdc30000.rkvdec-ccu: ccu-mode: 1 [ 4.276188] mpp_rkvdec2 fdc30000.rkvdec-ccu: probing finish [ 4.276299] mpp_rkvdec2 fdc38100.rkvdec-core: Adding to iommu group 12 [ 4.276562] mpp_rkvdec2 fdc38100.rkvdec-core: rkvdec-core, probing start [ 4.276686] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found! [ 4.276689] rkvdec2_init:1022: No niu aclk reset resource define [ 4.276692] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found! [ 4.276694] rkvdec2_init:1025: No niu hclk reset resource define [ 4.276710] mpp_rkvdec2 fdc38100.rkvdec-core: Looking up vdec-supply from device tree [ 4.276715] mpp_rkvdec2 fdc38100.rkvdec-core: Looking up vdec-supply property in node /rkvdec-core@fdc38000 failed [ 4.276721] mpp_rkvdec2 fdc38100.rkvdec-core: no regulator, devfreq is disabled [ 4.276776] mpp_rkvdec2 fdc38100.rkvdec-core: core_mask=00010001 [ 4.276779] mpp_rkvdec2 fdc38100.rkvdec-core: attach ccu as core 0 [ 4.276928] mpp_rkvdec2 fdc38100.rkvdec-core: sram_start 0x00000000ff001000 [ 4.276930] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_iova 0x00000000fff00000 [ 4.276933] mpp_rkvdec2 fdc38100.rkvdec-core: sram_size 491520 [ 4.276936] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_size 1048576 [ 4.276940] mpp_rkvdec2 fdc38100.rkvdec-core: min_width 512 [ 4.276944] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_info_count 20 [ 4.276947] mpp_rkvdec2 fdc38100.rkvdec-core: [136, 24576] [ 4.276950] mpp_rkvdec2 fdc38100.rkvdec-core: [137, 49152] [ 4.276953] mpp_rkvdec2 fdc38100.rkvdec-core: [141, 90112] [ 4.276956] mpp_rkvdec2 fdc38100.rkvdec-core: [140, 49152] [ 4.276958] mpp_rkvdec2 fdc38100.rkvdec-core: [139, 180224] [ 4.276961] mpp_rkvdec2 fdc38100.rkvdec-core: [133, 49152] [ 4.276963] mpp_rkvdec2 fdc38100.rkvdec-core: [134, 8192] [ 4.276966] mpp_rkvdec2 fdc38100.rkvdec-core: [135, 4352] [ 4.276969] mpp_rkvdec2 fdc38100.rkvdec-core: [138, 13056] [ 4.276971] mpp_rkvdec2 fdc38100.rkvdec-core: [142, 291584] [ 4.277004] mpp_rkvdec2 fdc38100.rkvdec-core: probing finish [ 4.277095] mpp_rkvdec2 fdc48100.rkvdec-core: Adding to iommu group 13 [ 4.277327] mpp_rkvdec2 fdc48100.rkvdec-core: rkvdec-core, probing start [ 4.277448] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found! [ 4.277451] rkvdec2_init:1022: No niu aclk reset resource define [ 4.277455] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found! [ 4.277457] rkvdec2_init:1025: No niu hclk reset resource define [ 4.277474] mpp_rkvdec2 fdc48100.rkvdec-core: Looking up vdec-supply from device tree [ 4.277480] mpp_rkvdec2 fdc48100.rkvdec-core: Looking up vdec-supply property in node /rkvdec-core@fdc48000 failed [ 4.277485] mpp_rkvdec2 fdc48100.rkvdec-core: no regulator, devfreq is disabled [ 4.277527] mpp_rkvdec2 fdc48100.rkvdec-core: core_mask=00020002 [ 4.277543] mpp_rkvdec2 fdc48100.rkvdec-core: attach ccu as core 1 [ 4.277723] mpp_rkvdec2 fdc48100.rkvdec-core: sram_start 0x00000000ff079000 [ 4.277726] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_iova 0x00000000ffe00000 [ 4.277728] mpp_rkvdec2 fdc48100.rkvdec-core: sram_size 487424 [ 4.277731] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_size 1048576 [ 4.277735] mpp_rkvdec2 fdc48100.rkvdec-core: min_width 512 [ 4.277739] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_info_count 20 [ 4.277742] mpp_rkvdec2 fdc48100.rkvdec-core: [136, 24576] [ 4.277745] mpp_rkvdec2 fdc48100.rkvdec-core: [137, 49152] [ 4.277747] mpp_rkvdec2 fdc48100.rkvdec-core: [141, 90112] [ 4.277750] mpp_rkvdec2 fdc48100.rkvdec-core: [140, 49152] [ 4.277753] mpp_rkvdec2 fdc48100.rkvdec-core: [139, 180224] [ 4.277755] mpp_rkvdec2 fdc48100.rkvdec-core: [133, 49152] [ 4.277758] mpp_rkvdec2 fdc48100.rkvdec-core: [134, 8192] [ 4.277761] mpp_rkvdec2 fdc48100.rkvdec-core: [135, 4352] [ 4.277763] mpp_rkvdec2 fdc48100.rkvdec-core: [138, 13056] [ 4.277765] mpp_rkvdec2 fdc48100.rkvdec-core: [142, 291584] [ 4.277795] mpp_rkvdec2 fdc48100.rkvdec-core: probing finish [ 4.277985] mpp_rkvenc2 rkvenc-ccu: probing start [ 4.277989] mpp_rkvenc2 rkvenc-ccu: probing finish [ 4.278107] mpp_rkvenc2 fdbd0000.rkvenc-core: Adding to iommu group 10 [ 4.278288] mpp_rkvenc2 fdbd0000.rkvenc-core: probing start [ 4.278439] mpp_rkvenc2 fdbd0000.rkvenc-core: Looking up venc-supply from device tree [ 4.278445] mpp_rkvenc2 fdbd0000.rkvenc-core: Looking up venc-supply property in node /rkvenc-core@fdbd0000 failed [ 4.278451] mpp_rkvenc2 fdbd0000.rkvenc-core: dev_pm_opp_set_regulators: no regulator (venc) found: -19 [ 4.278467] rkvenc_init:1814: failed to add venc devfreq [ 4.278496] mpp_rkvenc2 fdbd0000.rkvenc-core: attach ccu as core 0 [ 4.278651] mpp_rkvenc2 fdbd0000.rkvenc-core: probing finish [ 4.278735] mpp_rkvenc2 fdbe0000.rkvenc-core: Adding to iommu group 11 [ 4.278923] mpp_rkvenc2 fdbe0000.rkvenc-core: probing start [ 4.279051] mpp_rkvenc2 fdbe0000.rkvenc-core: Looking up venc-supply from device tree [ 4.279057] mpp_rkvenc2 fdbe0000.rkvenc-core: Looking up venc-supply property in node /rkvenc-core@fdbe0000 failed [ 4.279062] mpp_rkvenc2 fdbe0000.rkvenc-core: dev_pm_opp_set_regulators: no regulator (venc) found: -19 [ 4.279075] rkvenc_init:1814: failed to add venc devfreq [ 4.279125] mpp_rkvenc2 fdbe0000.rkvenc-core: attach ccu as core 1 [ 4.279282] mpp_rkvenc2 fdbe0000.rkvenc-core: probing finish [ 4.279529] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up av1-supply from device tree [ 4.279563] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up av1-supply property in node /power-management@fd8d8000/power-controller failed [ 4.279866] mpp_av1dec: Adding child /av1d@fdc70000 [ 4.279945] mpp_av1dec: register device av1d-master [ 4.279975] mpp_av1dec av1d-master: av1_iommu_of_xlate,784 [ 4.279994] av1_iommu_probe_device,736, consumer : av1d-master, supplier : fdca0000.iommu [ 4.280025] mpp_av1dec av1d-master: Adding to iommu group 18 [ 4.280264] mpp_av1dec av1d-master: probing start [ 4.280529] mpp_av1dec av1d-master: probing finish [ 4.280567] mpp_service mpp-srv: probe success [ 4.291647] dma-pl330 fea10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 4.291653] dma-pl330 fea10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 4.292672] dma-pl330 fea30000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 4.292678] dma-pl330 fea30000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 4.293676] dma-pl330 fed10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 4.293682] dma-pl330 fed10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 4.294179] rockchip-pvtm fda40000.pvtm: pvtm@0 probed [ 4.294242] rockchip-pvtm fda50000.pvtm: pvtm@1 probed [ 4.294301] rockchip-pvtm fda60000.pvtm: pvtm@2 probed [ 4.294362] rockchip-pvtm fdaf0000.pvtm: pvtm@3 probed [ 4.294416] rockchip-pvtm fdb30000.pvtm: pvtm@4 probed [ 4.294998] rockchip-system-monitor rockchip-system-monitor: system monitor probe [ 4.295807] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [ 4.296333] febc0000.serial: ttyS9 at MMIO 0xfebc0000 (irq = 101, base_baud = 1500000) is a 16550A [ 4.297595] random: crng init done [ 4.297640] led_vk2c21_init ============================================= [ 4.298606] rockchip-vop2 fdd90000.vop: Adding to iommu group 17 [ 4.307075] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x5, primary plane phy id: 0 [ 4.307083] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp1 assign plane mask: 0xa, primary plane phy id: 1 [ 4.307088] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x140, primary plane phy id: 6 [ 4.307094] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp3 assign plane mask: 0x280, primary plane phy id: 7 [ 4.307187] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart0-win0 as cursor plane for vp0 [ 4.307280] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart1-win0 as cursor plane for vp1 [ 4.307368] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart2-win0 as cursor plane for vp2 [ 4.307450] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart3-win0 as cursor plane for vp3 [ 4.307469] [drm] failed to init overlay plane Cluster0-win1 [ 4.307472] [drm] failed to init overlay plane Cluster1-win1 [ 4.307474] [drm] failed to init overlay plane Cluster2-win1 [ 4.307477] [drm] failed to init overlay plane Cluster3-win1 [ 4.319094] rockchip-drm display-subsystem: bound fdd90000.vop (ops 0xffff8000091b2620) [ 4.320070] dwhdmi-rockchip fde80000.hdmi: registered ddc I2C bus driver [ 4.320285] rockchip-drm display-subsystem: bound fde80000.hdmi (ops 0xffff8000091c0798) [ 4.320366] rockchip-drm display-subsystem: bound fde50000.dp (ops 0xffff8000091c3278) [ 4.320966] rockchip-drm display-subsystem: failed to parse loader memory [ 4.474062] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x2 [ 4.547503] dwhdmi-rockchip fde80000.hdmi: use tmds mode [ 4.547544] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] Update mode to 1920x1080p60, type: 11(if:800) for vp0 dclk: 148500000 [ 4.547709] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] dclk_out0 div: 0 dclk_core0 div: 2 [ 4.547727] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx_ropll_cmn_config bus_width:16a8c8 rate:1485000 [ 4.548006] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy pll locked! [ 4.548012] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] set dclk_vop0 to 148500000, get 148500000 [ 4.548036] dwhdmi-rockchip fde80000.hdmi: final tmdsclk = 148500000 [ 4.548066] dwhdmi-rockchip fde80000.hdmi: don't use dsc mode [ 4.548069] dwhdmi-rockchip fde80000.hdmi: dw hdmi qp use tmds mode [ 4.548076] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: bus_width:0x16a8c8,bit_rate:1485000 [ 4.548270] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy lane locked! [ 4.556259] rk-pcie fe190000.pcie: PCIe Link up, LTSSM is 0x30011 [ 4.556432] rk-pcie fe190000.pcie: PCI host bridge to bus 0004:40 [ 4.556443] pci_bus 0004:40: root bus resource [bus 40-4f] [ 4.556452] pci_bus 0004:40: root bus resource [??? 0xf4000000-0xf40fffff flags 0x0] [ 4.556461] pci_bus 0004:40: root bus resource [io 0x0000-0xfffff] (bus address [0xf4100000-0xf41fffff]) [ 4.556468] pci_bus 0004:40: root bus resource [mem 0xf4200000-0xf4ffffff] [ 4.556475] pci_bus 0004:40: root bus resource [mem 0xa00000000-0xa3fffffff pref] [ 4.556520] pci 0004:40:00.0: [1d87:3588] type 01 class 0x060400 [ 4.556549] pci 0004:40:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref] [ 4.556629] pci 0004:40:00.0: supports D1 D2 [ 4.556635] pci 0004:40:00.0: PME# supported from D0 D1 D3hot [ 4.569472] pci 0004:40:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 4.569763] pci 0004:41:00.0: [144d:a804] type 00 class 0x010802 [ 4.569863] pci 0004:41:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit] [ 4.570599] pci 0004:41:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x1 link at 0004:40:00.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link) [ 4.591919] pci_bus 0004:41: busn_res: [bus 41-4f] end is updated to 41 [ 4.591949] pci 0004:40:00.0: BAR 8: assigned [mem 0xf4200000-0xf42fffff] [ 4.591961] pci 0004:40:00.0: BAR 6: assigned [mem 0xf4300000-0xf430ffff pref] [ 4.591974] pci 0004:41:00.0: BAR 0: assigned [mem 0xf4200000-0xf4203fff 64bit] [ 4.592014] pci 0004:40:00.0: PCI bridge to [bus 41] [ 4.592023] pci 0004:40:00.0: bridge window [mem 0xf4200000-0xf42fffff] [ 4.595393] pcieport 0004:40:00.0: PME: Signaling with IRQ 125 [ 4.631447] Console: switching to colour frame buffer device 240x67 [ 4.795325] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device [ 4.796581] [drm] Initialized rockchip 3.0.0 20140818 for display-subsystem on minor 0 [ 4.811473] brd: module loaded [ 4.820716] loop: module loaded [ 4.821269] zram: Added device: zram0 [ 4.821626] lkdtm: No crash points registered, enable through debugfs [ 4.821899] system_heap: orders[0] = 6 [ 4.821906] system_heap: orders[1] = 4 [ 4.821912] system_heap: orders[2] = 0 [ 4.824177] nvme nvme0: pci function 0004:41:00.0 [ 4.824247] nvme 0004:41:00.0: enabling device (0000 -> 0002) [ 4.827710] rockchip-spi feb20000.spi: no high_speed pinctrl state [ 4.831240] rk806 spi2.0: chip id: RK806,ver:0x2, 0x1 [ 4.831488] rk806 spi2.0: ON: 0x80 OFF:0x80 [ 4.834820] rk806-regulator rk806-regulator.6.auto: Looking up vcc1-supply from device tree [ 4.834838] vdd_gpu_s0: supplied by vcc5v0_sys [ 4.834851] vcc5v0_sys: could not add device link regulator.8: -ENOENT [ 4.835774] vdd_gpu_s0: 550 <--> 950 mV at 750 mV, enabled [ 4.836670] rk806-regulator rk806-regulator.6.auto: Looking up vcc2-supply from device tree [ 4.836684] vdd_cpu_lit_s0: supplied by vcc5v0_sys [ 4.836698] vcc5v0_sys: could not add device link regulator.9: -ENOENT [ 4.837128] vdd_cpu_lit_s0: 550 <--> 950 mV at 750 mV, enabled [ 4.838187] rk806-regulator rk806-regulator.6.auto: Looking up vcc3-supply from device tree [ 4.838202] vdd_log_s0: supplied by vcc5v0_sys [ 4.838215] vcc5v0_sys: could not add device link regulator.10: -ENOENT [ 4.838673] vdd_log_s0: 675 <--> 750 mV at 750 mV, enabled [ 4.839492] rk806-regulator rk806-regulator.6.auto: Looking up vcc4-supply from device tree [ 4.839501] vdd_vdenc_s0: supplied by vcc5v0_sys [ 4.839508] vcc5v0_sys: could not add device link regulator.11: -ENOENT [ 4.839801] vdd_vdenc_s0: 550 <--> 950 mV at 750 mV, enabled [ 4.840410] rk806-regulator rk806-regulator.6.auto: Looking up vcc5-supply from device tree [ 4.840419] vdd_ddr_s0: supplied by vcc5v0_sys [ 4.840424] vcc5v0_sys: could not add device link regulator.12: -ENOENT [ 4.840671] vdd_ddr_s0: 675 <--> 900 mV at 850 mV, enabled [ 4.840884] rk806-regulator rk806-regulator.6.auto: Looking up vcc6-supply from device tree [ 4.840890] vdd2_ddr_s3: supplied by vcc5v0_sys [ 4.840894] vcc5v0_sys: could not add device link regulator.13: -ENOENT [ 4.841176] vdd2_ddr_s3: at 500 mV, enabled [ 4.841535] rk806-regulator rk806-regulator.6.auto: Looking up vcc7-supply from device tree [ 4.841541] vdd_2v0_pldo_s3: supplied by vcc5v0_sys [ 4.841546] vcc5v0_sys: could not add device link regulator.14: -ENOENT [ 4.841766] vdd_2v0_pldo_s3: 2000 mV, enabled [ 4.842128] rk806-regulator rk806-regulator.6.auto: Looking up vcc8-supply from device tree [ 4.842134] vcc_3v3_s3: supplied by vcc5v0_sys [ 4.842139] vcc5v0_sys: could not add device link regulator.15: -ENOENT [ 4.842359] vcc_3v3_s3: 3300 mV, enabled [ 4.842689] rk806-regulator rk806-regulator.6.auto: Looking up vcc9-supply from device tree [ 4.842695] vddq_ddr_s0: supplied by vcc5v0_sys [ 4.842703] vcc5v0_sys: could not add device link regulator.16: -ENOENT [ 4.842982] vddq_ddr_s0: at 500 mV, enabled [ 4.843337] rk806-regulator rk806-regulator.6.auto: Looking up vcc10-supply from device tree [ 4.843343] vcc_1v8_s3: supplied by vcc5v0_sys [ 4.843348] vcc5v0_sys: could not add device link regulator.17: -ENOENT [ 4.843573] vcc_1v8_s3: 1800 mV, enabled [ 4.843928] rk806-regulator rk806-regulator.6.auto: Looking up vcc13-supply from device tree [ 4.844002] vdd_0v75_s3: supplied by vcc_1v1_nldo_s3 [ 4.844007] vcc_1v1_nldo_s3: could not add device link regulator.18: -ENOENT [ 4.844239] vdd_0v75_s3: 750 mV, enabled [ 4.844662] rk806-regulator rk806-regulator.6.auto: Looking up vcc13-supply from device tree [ 4.844670] vdd_ddr_pll_s0: supplied by vcc_1v1_nldo_s3 [ 4.844675] vcc_1v1_nldo_s3: could not add device link regulator.19: -ENOENT [ 4.844894] vdd_ddr_pll_s0: 850 mV, enabled [ 4.845173] avdd_0v75_s0: Bringing 750000uV into 837500-837500uV [ 4.845300] avdd_0v75_s0: ramp_delay not set [ 4.845370] rk806-regulator rk806-regulator.6.auto: Looking up vcc13-supply from device tree [ 4.845376] avdd_0v75_s0: supplied by vcc_1v1_nldo_s3 [ 4.845381] vcc_1v1_nldo_s3: could not add device link regulator.20: -ENOENT [ 4.845599] avdd_0v75_s0: 837 mV, enabled [ 4.845952] rk806-regulator rk806-regulator.6.auto: Looking up vcc14-supply from device tree [ 4.845959] vdd_0v85_s0: supplied by vcc_1v1_nldo_s3 [ 4.845963] vcc_1v1_nldo_s3: could not add device link regulator.21: -ENOENT [ 4.846180] vdd_0v85_s0: 850 mV, enabled [ 4.846549] rk806-regulator rk806-regulator.6.auto: Looking up vcc14-supply from device tree [ 4.846556] vdd_0v75_s0: supplied by vcc_1v1_nldo_s3 [ 4.846561] vcc_1v1_nldo_s3: could not add device link regulator.22: -ENOENT [ 4.846786] vdd_0v75_s0: 750 mV, enabled [ 4.847199] rk806-regulator rk806-regulator.6.auto: Looking up vcc11-supply from device tree [ 4.847236] avcc_1v8_s0: supplied by vdd_2v0_pldo_s3 [ 4.847241] vdd_2v0_pldo_s3: could not add device link regulator.23: -ENOENT [ 4.847531] avcc_1v8_s0: 1800 mV, enabled [ 4.847946] rk806-regulator rk806-regulator.6.auto: Looking up vcc11-supply from device tree [ 4.847954] vcc_1v8_s0: supplied by vdd_2v0_pldo_s3 [ 4.847959] vdd_2v0_pldo_s3: could not add device link regulator.24: -ENOENT [ 4.848268] vcc_1v8_s0: 1800 mV, enabled [ 4.848619] rk806-regulator rk806-regulator.6.auto: Looking up vcc11-supply from device tree [ 4.848627] avdd_1v2_s0: supplied by vdd_2v0_pldo_s3 [ 4.848632] vdd_2v0_pldo_s3: could not add device link regulator.25: -ENOENT [ 4.848920] avdd_1v2_s0: 1200 mV, enabled [ 4.849263] rk806-regulator rk806-regulator.6.auto: Looking up vcc12-supply from device tree [ 4.849269] vcc_3v3_s0: supplied by vcc5v0_sys [ 4.849274] vcc5v0_sys: could not add device link regulator.26: -ENOENT [ 4.849491] vcc_3v3_s0: 3300 mV, enabled [ 4.849847] rk806-regulator rk806-regulator.6.auto: Looking up vcc12-supply from device tree [ 4.849853] vccio_sd_s0: supplied by vcc5v0_sys [ 4.849858] vcc5v0_sys: could not add device link regulator.27: -ENOENT [ 4.850105] vccio_sd_s0: 1800 <--> 3300 mV at 3300 mV, enabled [ 4.850464] rk806-regulator rk806-regulator.6.auto: Looking up vcca-supply from device tree [ 4.850470] pldo6_s3: supplied by vcc5v0_sys [ 4.850477] vcc5v0_sys: could not add device link regulator.28: -ENOENT [ 4.850698] pldo6_s3: 1800 mV, enabled [ 4.851043] rk806 spi2.0: no sleep-setting state [ 4.851047] rk806 spi2.0: no reset-setting pinctrl state [ 4.851050] rk806 spi2.0: no dvs-setting pinctrl state [ 4.852584] rockchip-spi feb20000.spi: register misc device rkspi-dev2 [ 4.852589] rockchip-spi feb20000.spi: probed, poll=0, rsd=0 [ 4.852686] nvme nvme0: 7/0/0 default/read/poll queues [ 4.854552] spi-nor spi5.0: XM25QU128C (16384 Kbytes) read_data x4 [ 4.854569] 1 fixed-partitions partitions found on MTD device sfc_nor [ 4.854572] Creating 1 MTD partitions on "sfc_nor": [ 4.854576] 0x000000000000-0x000001000000 : "loader" [ 4.856832] rk_gmac-dwmac fe1c0000.ethernet: IRQ eth_lpi not found [ 4.856986] rk_gmac-dwmac fe1c0000.ethernet: Looking up phy-supply from device tree [ 4.856999] rk_gmac-dwmac fe1c0000.ethernet: Looking up phy-supply property in node /ethernet@fe1c0000 failed [ 4.857014] rk_gmac-dwmac fe1c0000.ethernet: no regulator found [ 4.857019] rk_gmac-dwmac fe1c0000.ethernet: clock input or output? (output). [ 4.857024] rk_gmac-dwmac fe1c0000.ethernet: TX delay(0x42). [ 4.857028] rk_gmac-dwmac fe1c0000.ethernet: Can not read property: rx_delay. [ 4.857032] rk_gmac-dwmac fe1c0000.ethernet: set rx_delay to 0xffffffff [ 4.857040] rk_gmac-dwmac fe1c0000.ethernet: integrated PHY? (no). [ 4.857046] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_rx [ 4.857051] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_tx [ 4.857065] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock clk_mac_speed [ 4.857286] rk_gmac-dwmac fe1c0000.ethernet: init for RGMII_RXID [ 4.857380] rk_gmac-dwmac fe1c0000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 4.857385] rk_gmac-dwmac fe1c0000.ethernet: DWMAC4/5 [ 4.857390] rk_gmac-dwmac fe1c0000.ethernet: DMA HW capability register supported [ 4.857393] rk_gmac-dwmac fe1c0000.ethernet: RX Checksum Offload Engine supported [ 4.857396] rk_gmac-dwmac fe1c0000.ethernet: TX Checksum insertion supported [ 4.857399] rk_gmac-dwmac fe1c0000.ethernet: Wake-Up On Lan supported [ 4.857433] rk_gmac-dwmac fe1c0000.ethernet: TSO supported [ 4.857436] rk_gmac-dwmac fe1c0000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 4.857441] rk_gmac-dwmac fe1c0000.ethernet: Enabled Flow TC (entries=2) [ 4.857444] rk_gmac-dwmac fe1c0000.ethernet: TSO feature enabled [ 4.857448] rk_gmac-dwmac fe1c0000.ethernet: Using 32 bits DMA width [ 4.865009] nvme0n1: p1 p2 [ 4.998819] usbcore: registered new interface driver rndis_wlan [ 4.998842] usbcore: registered new interface driver asix [ 4.998858] usbcore: registered new interface driver cdc_ether [ 4.998874] usbcore: registered new interface driver rndis_host [ 4.998896] usbcore: registered new interface driver cdc_ncm [ 5.003606] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up usb-supply from device tree [ 5.003635] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up usb-supply property in node /power-management@fd8d8000/power-controller failed [ 5.005473] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 5.005489] ehci-pci: EHCI PCI platform driver [ 5.005521] ehci-platform: EHCI generic platform driver [ 5.007526] ehci-platform fc800000.usb: EHCI Host Controller [ 5.007541] ehci-platform fc800000.usb: new USB bus registered, assigned bus number 1 [ 5.007617] ehci-platform fc800000.usb: irq 20, io mem 0xfc800000 [ 5.019571] ehci-platform fc800000.usb: USB 2.0 started, EHCI 1.00 [ 5.019689] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 5.019693] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.019697] usb usb1: Product: EHCI Host Controller [ 5.019701] usb usb1: Manufacturer: Linux 5.10.160-rk35xx ehci_hcd [ 5.019704] usb usb1: SerialNumber: fc800000.usb [ 5.020016] hub 1-0:1.0: USB hub found [ 5.020034] hub 1-0:1.0: 1 port detected [ 5.022460] ehci-platform fc880000.usb: EHCI Host Controller [ 5.022473] ehci-platform fc880000.usb: new USB bus registered, assigned bus number 2 [ 5.022529] ehci-platform fc880000.usb: irq 22, io mem 0xfc880000 [ 5.032905] ehci-platform fc880000.usb: USB 2.0 started, EHCI 1.00 [ 5.033007] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 5.033011] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.033015] usb usb2: Product: EHCI Host Controller [ 5.033018] usb usb2: Manufacturer: Linux 5.10.160-rk35xx ehci_hcd [ 5.033021] usb usb2: SerialNumber: fc880000.usb [ 5.033282] hub 2-0:1.0: USB hub found [ 5.033301] hub 2-0:1.0: 1 port detected [ 5.033716] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 5.033726] ohci-platform: OHCI generic platform driver [ 5.033892] ohci-platform fc840000.usb: Generic Platform OHCI controller [ 5.033901] ohci-platform fc840000.usb: new USB bus registered, assigned bus number 3 [ 5.033956] ohci-platform fc840000.usb: irq 21, io mem 0xfc840000 [ 5.093662] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10 [ 5.093667] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.093670] usb usb3: Product: Generic Platform OHCI controller [ 5.093673] usb usb3: Manufacturer: Linux 5.10.160-rk35xx ohci_hcd [ 5.093677] usb usb3: SerialNumber: fc840000.usb [ 5.093939] hub 3-0:1.0: USB hub found [ 5.093957] hub 3-0:1.0: 1 port detected [ 5.094253] ohci-platform fc8c0000.usb: Generic Platform OHCI controller [ 5.094262] ohci-platform fc8c0000.usb: new USB bus registered, assigned bus number 4 [ 5.094318] ohci-platform fc8c0000.usb: irq 23, io mem 0xfc8c0000 [ 5.153665] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10 [ 5.153669] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.153673] usb usb4: Product: Generic Platform OHCI controller [ 5.153676] usb usb4: Manufacturer: Linux 5.10.160-rk35xx ohci_hcd [ 5.153679] usb usb4: SerialNumber: fc8c0000.usb [ 5.153938] hub 4-0:1.0: USB hub found [ 5.153956] hub 4-0:1.0: 1 port detected [ 5.154550] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 5.154561] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 5 [ 5.154640] xhci-hcd xhci-hcd.7.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000200002010010 [ 5.154664] xhci-hcd xhci-hcd.7.auto: irq 139, io mem 0xfcd00000 [ 5.154822] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 5.154827] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.154830] usb usb5: Product: xHCI Host Controller [ 5.154833] usb usb5: Manufacturer: Linux 5.10.160-rk35xx xhci-hcd [ 5.154836] usb usb5: SerialNumber: xhci-hcd.7.auto [ 5.155095] hub 5-0:1.0: USB hub found [ 5.155113] hub 5-0:1.0: 1 port detected [ 5.155267] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 5.155275] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 6 [ 5.155282] xhci-hcd xhci-hcd.7.auto: Host supports USB 3.0 SuperSpeed [ 5.155317] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM. [ 5.155385] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 [ 5.155389] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.155392] usb usb6: Product: xHCI Host Controller [ 5.155396] usb usb6: Manufacturer: Linux 5.10.160-rk35xx xhci-hcd [ 5.155399] usb usb6: SerialNumber: xhci-hcd.7.auto [ 5.155651] hub 6-0:1.0: USB hub found [ 5.155667] hub 6-0:1.0: 1 port detected [ 5.155881] usbcore: registered new interface driver cdc_acm [ 5.155884] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 5.155984] usbcore: registered new interface driver uas [ 5.156044] usbcore: registered new interface driver usb-storage [ 5.156658] Error: Driver 'Goodix-TS' is already registered, aborting... [ 5.156692] usbcore: registered new interface driver usbtouchscreen [ 5.157754] input: rk805 pwrkey as /devices/platform/feb20000.spi/spi_master/spi2/spi2.0/rk805-pwrkey.5.auto/input/input0 [ 5.158086] i2c /dev entries driver [ 5.161778] rk860-regulator 0-0042: Looking up vin-supply from device tree [ 5.161785] vdd_cpu_big0_s0: supplied by vcc5v0_sys [ 5.161792] vcc5v0_sys: could not add device link regulator.29: -ENOENT [ 5.165881] vdd_cpu_big0_s0: 550 <--> 1050 mV at 800 mV, enabled [ 5.170419] rk860-regulator 0-0043: Looking up vin-supply from device tree [ 5.170425] vdd_cpu_big1_s0: supplied by vcc5v0_sys [ 5.170431] vcc5v0_sys: could not add device link regulator.30: -ENOENT [ 5.174520] vdd_cpu_big1_s0: 550 <--> 1050 mV at 800 mV, enabled [ 5.176789] Goodix-TS 2-0014: Looking up AVDD28-supply from device tree [ 5.176798] Goodix-TS 2-0014: Looking up AVDD28-supply property in node /i2c@feaa0000/touchscreen@14 failed [ 5.176809] Goodix-TS 2-0014: supply AVDD28 not found, using dummy regulator [ 5.176865] Goodix-TS 2-0014: Looking up VDDIO-supply from device tree [ 5.176872] Goodix-TS 2-0014: Looking up VDDIO-supply property in node /i2c@feaa0000/touchscreen@14 failed [ 5.176881] Goodix-TS 2-0014: supply VDDIO not found, using dummy regulator [ 5.269734] Goodix-TS 2-0014: i2c test failed attempt 1: -6 [ 5.296409] Goodix-TS 2-0014: i2c test failed attempt 2: -6 [ 5.322925] Goodix-TS 2-0014: I2C communication failure: -6 [ 5.326665] rk860-regulator 2-0042: Looking up vin-supply from device tree [ 5.326680] vdd_npu_s0: supplied by vcc5v0_sys [ 5.326693] vcc5v0_sys: could not add device link regulator.31: -ENOENT [ 5.330940] vdd_npu_s0: 550 <--> 950 mV at 800 mV, enabled [ 5.336149] typec_fusb302 6-0022: Looking up vbus-supply from device tree [ 5.364923] rtc-hym8563 6-0051: rtc information is valid [ 5.370256] rtc-hym8563 6-0051: registered as rtc0 [ 5.371267] rtc-hym8563 6-0051: setting system clock to 2023-08-07T18:00:18 UTC (1691431218) [ 5.373938] Goodix-TS 7-0014: Looking up AVDD28-supply from device tree [ 5.373947] Goodix-TS 7-0014: Looking up AVDD28-supply property in node /i2c@fec90000/touchscreen@14 failed [ 5.373960] Goodix-TS 7-0014: supply AVDD28 not found, using dummy regulator [ 5.374018] Goodix-TS 7-0014: Looking up VDDIO-supply from device tree [ 5.374025] Goodix-TS 7-0014: Looking up VDDIO-supply property in node /i2c@fec90000/touchscreen@14 failed [ 5.374034] Goodix-TS 7-0014: supply VDDIO not found, using dummy regulator [ 5.466378] Goodix-TS 7-0014: i2c test failed attempt 1: -6 [ 5.493041] Goodix-TS 7-0014: i2c test failed attempt 2: -6 [ 5.519561] Goodix-TS 7-0014: I2C communication failure: -6 [ 5.520524] rkcifhw fdce0000.rkcif: Adding to iommu group 16 [ 5.520894] rkcifhw fdce0000.rkcif: No reserved memory region assign to CIF [ 5.522042] rkisp_hw fdcb0000.rkisp: Adding to iommu group 14 [ 5.522155] rkisp_hw fdcb0000.rkisp: is_thunderboot: 0 [ 5.522159] rkisp_hw fdcb0000.rkisp: max input:0x0@0fps [ 5.522164] rkisp_hw fdcb0000.rkisp: Missing rockchip,grf property [ 5.522265] rkisp_hw fdcb0000.rkisp: no find phandle sram [ 5.522336] rkisp_hw fdcc0000.rkisp: Adding to iommu group 15 [ 5.522489] rkisp_hw fdcc0000.rkisp: is_thunderboot: 0 [ 5.522493] rkisp_hw fdcc0000.rkisp: max input:0x0@0fps [ 5.522497] rkisp_hw fdcc0000.rkisp: Missing rockchip,grf property [ 5.522588] rkisp_hw fdcc0000.rkisp: no find phandle sram [ 5.523541] usbcore: registered new interface driver uvcvideo [ 5.523544] USB Video Class driver (1.1.1) [ 5.524968] cpu cpu0: Looking up cpu-supply from device tree [ 5.525463] cpu cpu0: bin=0 [ 5.525638] cpu cpu0: leakage=8 [ 5.525662] cpu cpu0: Looking up cpu-supply from device tree [ 5.527121] cpu cpu0: pvtm=1381 [ 5.527280] cpu cpu0: pvtm-volt-sel=0 [ 5.527317] cpu cpu0: Looking up cpu-supply from device tree [ 5.527543] cpu cpu0: Looking up mem-supply from device tree [ 5.527936] cpu cpu4: Looking up cpu-supply from device tree [ 5.530043] cpu cpu4: bin=0 [ 5.530235] cpu cpu4: leakage=6 [ 5.530276] cpu cpu4: Looking up cpu-supply from device tree [ 5.537094] cpu cpu4: pvtm=1588 [ 5.541325] cpu cpu4: pvtm-volt-sel=0 [ 5.541427] cpu cpu4: Looking up cpu-supply from device tree [ 5.542038] cpu cpu4: Looking up mem-supply from device tree [ 5.542748] cpu cpu6: Looking up cpu-supply from device tree [ 5.544754] cpu cpu6: bin=0 [ 5.544945] cpu cpu6: leakage=6 [ 5.544985] cpu cpu6: Looking up cpu-supply from device tree [ 5.551782] cpu cpu6: pvtm=1589 [ 5.556018] cpu cpu6: pvtm-volt-sel=0 [ 5.556108] cpu cpu6: Looking up cpu-supply from device tree [ 5.556720] cpu cpu6: Looking up mem-supply from device tree [ 5.559048] cpu cpu0: avs=0 [ 5.561147] cpu cpu4: avs=0 [ 5.563233] cpu cpu6: avs=0 [ 5.563641] cpu cpu0: EM: OPP:816000 is inefficient [ 5.563649] cpu cpu0: EM: OPP:600000 is inefficient [ 5.563883] cpu cpu0: EM: created perf domain [ 5.563963] cpu cpu0: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=1608000000 h_table=0 [ 5.565069] cpu cpu4: EM: OPP:816000 is inefficient [ 5.565080] cpu cpu4: EM: OPP:600000 is inefficient [ 5.565451] cpu cpu4: EM: created perf domain [ 5.565534] cpu cpu4: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0 [ 5.572944] usb 3-1: new full-speed USB device number 2 using ohci-platform [ 5.574628] cpu cpu6: EM: OPP:816000 is inefficient [ 5.574639] cpu cpu6: EM: OPP:600000 is inefficient [ 5.575007] cpu cpu6: EM: created perf domain [ 5.575976] cpu cpu6: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0 [ 5.590757] sdhci: Secure Digital Host Controller Interface driver [ 5.590764] sdhci: Copyright(c) Pierre Ossman [ 5.590771] Synopsys Designware Multimedia Card Interface Driver [ 5.591968] sdhci-pltfm: SDHCI platform and OF driver helper [ 5.595259] ledtrig-cpu: registered to indicate activity on CPUs [ 5.595299] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active. [ 5.595359] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 5.596597] cryptodev: driver 1.12 loaded. [ 5.596631] hid: raw HID events driver (C) Jiri Kosina [ 5.596904] usbcore: registered new interface driver usbhid [ 5.596908] usbhid: USB HID core driver [ 5.597153] ashmem: initialized [ 5.600254] rockchip-saradc fec10000.saradc: Looking up vref-supply from device tree [ 5.601303] optee: probing for conduit method. [ 5.601308] optee: api uid mismatch [ 5.601317] optee: probe of firmware:optee failed with error -22 [ 5.601871] usbcore: registered new interface driver snd-usb-audio [ 5.608621] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up audio-supply from device tree [ 5.608674] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up audio-supply property in node /power-management@fd8d8000/power-controller failed [ 5.613826] debugfs: File 'Capture' in directory 'dapm' already present! [ 5.615742] input: rockchip-dp0 rockchip-dp0 as /devices/platform/dp0-sound/sound/card0/input1 [ 5.618298] input: rockchip-hdmi0 rockchip-hdmi0 as /devices/platform/hdmi0-sound/sound/card1/input2 [ 5.620165] input: headset-keys as /devices/platform/es8388-sound/input/input3 [ 5.633960] ES8323 6-0010: ASoC: error at soc_component_write_no_lock on ES8323.6-0010: -5 [ 5.692563] input: rockchip-es8388 Headset as /devices/platform/es8388-sound/sound/card2/input4 [ 5.693389] Initializing XFRM netlink socket [ 5.693405] NET: Registered protocol family 17 [ 5.693828] [BT_RFKILL]: Enter rfkill_rk_init [ 5.693832] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 5.694234] Key type dns_resolver registered [ 5.695713] registered taskstats version 1 [ 5.695720] Loading compiled-in X.509 certificates [ 5.696526] Btrfs loaded, crc32c=crc32c-generic [ 5.696651] pstore: Using crash dump compression: deflate [ 5.696885] rga3_core0 fdb60000.rga: Adding to iommu group 2 [ 5.697067] rga: rga3_core0, irq = 35, match scheduler [ 5.697672] rga: rga3_core0 hardware loaded successfully, hw_version:3.0.76831. [ 5.697719] rga: rga3_core0 probe successfully [ 5.698019] rga3_core1 fdb70000.rga: Adding to iommu group 3 [ 5.698202] rga: rga3_core1, irq = 36, match scheduler [ 5.698744] rga: rga3_core1 hardware loaded successfully, hw_version:3.0.76831. [ 5.698793] rga: rga3_core1 probe successfully [ 5.699127] rga: rga2, irq = 37, match scheduler [ 5.699685] rga: rga2 hardware loaded successfully, hw_version:3.2.63318. [ 5.699694] rga: rga2 probe successfully [ 5.699895] rga_iommu: IOMMU binding successfully, default mapping core[0x1] [ 5.700011] rga: Module initialized. v1.2.25 [ 5.750875] reg-fixed-voltage combophy-avdd0v85: Looking up vin-supply from device tree [ 5.750989] combophy_avdd0v85: supplied by vdd_0v85_s0 [ 5.750997] vdd_0v85_s0: could not add device link regulator.32: -ENOENT [ 5.751065] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up gpu-supply from device tree [ 5.751220] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up gpu-supply property in node /power-management@fd8d8000/power-controller failed [ 5.751421] mali fb000000.gpu: Kernel DDK version g17p0-01eac0 [ 5.751497] mali fb000000.gpu: Looking up mali-supply from device tree [ 5.751502] combophy_avdd0v85: 850 mV, enabled [ 5.751778] mali fb000000.gpu: Looking up mem-supply from device tree [ 5.751793] reg-fixed-voltage combophy-avdd0v85: combophy_avdd0v85 supplying 850000uV [ 5.751919] mali fb000000.gpu: Looking up mali-supply from device tree [ 5.751928] reg-fixed-voltage combophy-avdd1v8: Looking up vin-supply from device tree [ 5.751946] vdd_gpu_s0: could not add device link fb000000.gpu: -EEXIST [ 5.751951] vdd_gpu_s0: Failed to create debugfs directory [ 5.751959] mali fb000000.gpu: Looking up mem-supply from device tree [ 5.751985] combophy_avdd1v8: supplied by avcc_1v8_s0 [ 5.751990] vdd_gpu_s0: could not add device link fb000000.gpu: -EEXIST [ 5.751993] avcc_1v8_s0: could not add device link regulator.33: -ENOENT [ 5.751998] vdd_gpu_s0: Failed to create debugfs directory [ 5.752135] mali fb000000.gpu: Looking up mali-supply from device tree [ 5.752156] vdd_gpu_s0: could not add device link fb000000.gpu: -EEXIST [ 5.752160] vdd_gpu_s0: Failed to create debugfs directory [ 5.752181] combophy_avdd1v8: 1800 mV, enabled [ 5.752349] reg-fixed-voltage combophy-avdd1v8: combophy_avdd1v8 supplying 1800000uV [ 5.752455] vcc_3v3_sd_s0: 3300 mV, disabled [ 5.752474] mali fb000000.gpu: bin=0 [ 5.752528] reg-fixed-voltage vcc-3v3-sd-s0: Looking up vin-supply from device tree [ 5.752535] vcc_3v3_sd_s0: supplied by vcc_3v3_s3 [ 5.752659] mali fb000000.gpu: leakage=13 [ 5.752671] reg-fixed-voltage vcc-3v3-sd-s0: vcc_3v3_sd_s0 supplying 3300000uV [ 5.752695] mali fb000000.gpu: Looking up mali-supply from device tree [ 5.752720] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present! [ 5.753165] rockchip-dmc dmc: Looking up center-supply from device tree [ 5.753673] rockchip-dmc dmc: Looking up mem-supply from device tree [ 5.754149] mali fb000000.gpu: pvtm=847 [ 5.754275] rockchip-dmc dmc: Looking up center-supply from device tree [ 5.754297] vdd_ddr_s0: could not add device link dmc: -EEXIST [ 5.754301] vdd_ddr_s0: Failed to create debugfs directory [ 5.754734] mali fb000000.gpu: pvtm-volt-sel=2 [ 5.754899] rockchip-dmc dmc: Looking up mem-supply from device tree [ 5.754928] vdd_log_s0: could not add device link dmc: -EEXIST [ 5.754931] vdd_log_s0: Failed to create debugfs directory [ 5.755297] rockchip-dmc dmc: leakage=30 [ 5.755305] rockchip-dmc dmc: leakage-volt-sel=0 [ 5.755637] rockchip-dmc dmc: avs=0 [ 5.755649] rockchip-dmc dmc: current ATF version 0x100 [ 5.755745] rockchip-dmc dmc: normal_rate = 1560000000 [ 5.755749] rockchip-dmc dmc: reboot_rate = 2112000000 [ 5.755753] rockchip-dmc dmc: suspend_rate = 528000000 [ 5.755757] rockchip-dmc dmc: video_4k_rate = 1560000000 [ 5.755761] rockchip-dmc dmc: video_4k_10b_rate = 1560000000 [ 5.755765] rockchip-dmc dmc: video_svep_rate = 1560000000 [ 5.755768] rockchip-dmc dmc: boost_rate = 2112000000 [ 5.755772] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 2112000000 [ 5.755776] rockchip-dmc dmc: performance_rate = 2112000000 [ 5.755780] rockchip-dmc dmc: hdmirx_rate = 2112000000 [ 5.755787] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate [ 5.755791] rockchip-dmc dmc: failed to get vop pn to msch rl [ 5.755904] rockchip-dmc dmc: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0 [ 5.755978] mali fb000000.gpu: avs=0 [ 5.756189] rockchip-dmc dmc: could not find power_model node [ 5.756408] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 143; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available. [ 5.756949] input: adc-keys as /devices/platform/adc-keys/input/input5 [ 5.757230] mali fb000000.gpu: GPU hardware issue table may need updating: r0p0 status 5 is unknown; treating as r0p0 status 0 [ 5.757241] mali fb000000.gpu: GPU identified as 0x7 arch 10.8.6 r0p0 status 0 [ 5.757302] mali fb000000.gpu: No priority control manager is configured [ 5.757711] mali fb000000.gpu: No memory group manager is configured [ 5.757749] mali fb000000.gpu: Protected memory allocator not available [ 5.757893] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up sdmmc-supply from device tree [ 5.758087] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up sdmmc-supply property in node /power-management@fd8d8000/power-controller failed [ 5.758118] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up sdio-supply from device tree [ 5.758170] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up sdio-supply property in node /power-management@fd8d8000/power-controller failed [ 5.758193] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up pcie-supply from device tree [ 5.758215] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up pcie-supply property in node /power-management@fd8d8000/power-controller failed [ 5.758247] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu-supply from device tree [ 5.758268] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu-supply property in node /power-management@fd8d8000/power-controller failed [ 5.758546] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode. [ 5.758574] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller. [ 5.758580] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a [ 5.758612] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 90,32 bit host data width,256 deep fifo [ 5.758672] dwmmc_rockchip fe2c0000.mmc: Looking up vmmc-supply from device tree [ 5.758753] mali fb000000.gpu: Capping CSF_FIRMWARE_TIMEOUT to CSF_FIRMWARE_PING_TIMEOUT [ 5.758841] dwmmc_rockchip fe2c0000.mmc: Looking up vqmmc-supply from device tree [ 5.759815] mali fb000000.gpu: Couldn't find power_model DT node matching 'arm,mali-simple-power-model' [ 5.759825] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.static-coefficient = 1*[0] [ 5.760094] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.dynamic-coefficient = 1*[0] [ 5.760346] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.ts = 4*[0] [ 5.760594] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.thermal-zone = '' [ 5.764375] mali fb000000.gpu: Using configured power model mali-lodx-power-model, and fallback mali-simple-power-model [ 5.764598] mali fb000000.gpu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0 [ 5.764680] RKNPU fdab0000.npu: Adding to iommu group 0 [ 5.764804] RKNPU fdab0000.npu: RKNPU: rknpu iommu is enabled, using iommu mode [ 5.764895] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 5.765569] RKNPU fdab0000.npu: Looking up mem-supply from device tree [ 5.765947] mali fb000000.gpu: Probed as mali0 [ 5.766119] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff] [ 5.766139] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff] [ 5.766150] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff] [ 5.766828] [drm] Initialized rknpu 0.8.5 20230202 for fdab0000.npu on minor 1 [ 5.767169] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up nputop-supply from device tree [ 5.767196] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up nputop-supply property in node /power-management@fd8d8000/power-controller failed [ 5.767270] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu1-supply from device tree [ 5.767291] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu1-supply property in node /power-management@fd8d8000/power-controller failed [ 5.767348] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu2-supply from device tree [ 5.767369] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu2-supply property in node /power-management@fd8d8000/power-controller failed [ 5.767506] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 5.767527] vdd_npu_s0: could not add device link fdab0000.npu: -EEXIST [ 5.767530] vdd_npu_s0: Failed to create debugfs directory [ 5.768144] RKNPU fdab0000.npu: Looking up mem-supply from device tree [ 5.768183] vdd_npu_s0: could not add device link fdab0000.npu: -EEXIST [ 5.768187] vdd_npu_s0: Failed to create debugfs directory [ 5.768891] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 5.768925] vdd_npu_s0: could not add device link fdab0000.npu: -EEXIST [ 5.768929] vdd_npu_s0: Failed to create debugfs directory [ 5.770861] RKNPU fdab0000.npu: RKNPU: bin=0 [ 5.771036] RKNPU fdab0000.npu: leakage=7 [ 5.771069] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 5.771098] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present! [ 5.772771] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 5.779048] RKNPU fdab0000.npu: pvtm=846 [ 5.783708] RKNPU fdab0000.npu: pvtm-volt-sel=2 [ 5.784419] RKNPU fdab0000.npu: avs=0 [ 5.784582] RKNPU fdab0000.npu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0 [ 5.797274] RKNPU fdab0000.npu: failed to find power_model node [ 5.797285] RKNPU fdab0000.npu: RKNPU: failed to initialize power model [ 5.797290] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient [ 5.798449] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 5.806360] usb 3-1: New USB device found, idVendor=046d, idProduct=c539, bcdDevice=39.06 [ 5.806381] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 5.806393] usb 3-1: Product: USB Receiver [ 5.806405] usb 3-1: Manufacturer: Logitech [ 5.814861] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 5.815689] input: Logitech USB Receiver as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.0/0003:046D:C539.0001/input/input6 [ 5.821018] rockchip-pm rockchip-suspend: not set pwm-regulator-config [ 5.821042] rockchip-suspend not set sleep-mode-config for mem-lite [ 5.821050] rockchip-suspend not set wakeup-config for mem-lite [ 5.821062] rockchip-suspend not set sleep-mode-config for mem-ultra [ 5.821067] rockchip-suspend not set wakeup-config for mem-ultra [ 5.823256] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 406; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '13:36:29', on 'Jul 6 2023'. [ 5.823763] Mali: [ 5.823768] Mali device driver loaded [ 5.823779] ALSA device list: [ 5.823785] #0: rockchip-dp0 [ 5.823790] #1: rockchip-hdmi0 [ 5.823795] #2: rockchip-es8388 [ 5.829238] Freeing unused kernel memory: 6976K [ 5.850116] Run /init as init process [ 5.850129] with arguments: [ 5.850137] /init [ 5.850145] splash [ 5.850152] with environment: [ 5.850159] HOME=/ [ 5.850166] TERM=linux [ 5.850172] ubootpart= [ 5.850179] cgroup_enable=memory [ 5.850185] cgroup_memory=1 [ 5.870620] hid-generic 0003:046D:C539.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-fc840000.usb-1/input0 [ 5.877978] input: Logitech USB Receiver Mouse as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input7 [ 5.933416] input: Logitech USB Receiver Consumer Control as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input8 [ 5.933995] input: Logitech USB Receiver System Control as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input9 [ 5.935105] hid-generic 0003:046D:C539.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-fc840000.usb-1/input1 [ 5.940362] hid-generic 0003:046D:C539.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-fc840000.usb-1/input2 [ 6.890117] EXT4-fs (nvme0n1p2): mounted filesystem with writeback data mode. Opts: (null) [ 7.153552] NET: Registered protocol family 10 [ 7.155293] Segment Routing with IPv6 [ 7.176996] systemd[1]: systemd 249.11-0ubuntu3.9 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified) [ 7.179176] systemd[1]: Detected architecture arm64. [ 7.180932] systemd[1]: Hostname set to . [ 7.409840] systemd[1]: Queued start job for default target Graphical Interface. [ 7.411446] systemd[1]: Created slice Slice /system/modprobe. [ 7.411945] systemd[1]: Created slice Slice /system/serial-getty. [ 7.412404] systemd[1]: Created slice Slice /system/systemd-fsck. [ 7.412736] systemd[1]: Created slice User and Session Slice. [ 7.412870] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 7.413235] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 7.413376] systemd[1]: Reached target User and Group Name Lookups. [ 7.413434] systemd[1]: Reached target Slice Units. [ 7.413471] systemd[1]: Reached target Swaps. [ 7.413506] systemd[1]: Reached target System Time Set. [ 7.413585] systemd[1]: Reached target Local Verity Protected Volumes. [ 7.427880] systemd[1]: Listening on RPCbind Server Activation Socket. [ 7.428389] systemd[1]: Listening on Syslog Socket. [ 7.428628] systemd[1]: Listening on fsck to fsckd communication Socket. [ 7.428739] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 7.429047] systemd[1]: Listening on Journal Audit Socket. [ 7.429199] systemd[1]: Listening on Journal Socket (/dev/log). [ 7.429398] systemd[1]: Listening on Journal Socket. [ 7.430374] systemd[1]: Listening on udev Control Socket. [ 7.430552] systemd[1]: Listening on udev Kernel Socket. [ 7.431748] systemd[1]: Mounting Huge Pages File System... [ 7.433098] systemd[1]: Mounting POSIX Message Queue File System... [ 7.434610] systemd[1]: Mounting Kernel Debug File System... [ 7.436199] systemd[1]: Mounting Kernel Trace File System... [ 7.436603] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped. [ 7.438508] systemd[1]: Starting Restore / save the current clock... [ 7.440424] systemd[1]: Starting Set the console keyboard layout... [ 7.442296] systemd[1]: Starting Create List of Static Device Nodes... [ 7.444222] systemd[1]: Starting Load Kernel Module chromeos_pstore... [ 7.446145] systemd[1]: Starting Load Kernel Module configfs... [ 7.448368] systemd[1]: Starting Load Kernel Module drm... [ 7.450490] systemd[1]: Starting Load Kernel Module efi_pstore... [ 7.452620] systemd[1]: Starting Load Kernel Module fuse... [ 7.454800] systemd[1]: Starting Load Kernel Module pstore_blk... [ 7.457042] systemd[1]: Starting Load Kernel Module pstore_zone... [ 7.458947] systemd[1]: Starting Load Kernel Module ramoops... [ 7.459682] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 7.460162] fuse: init (API version 7.32) [ 7.462469] systemd[1]: Starting Load Kernel Modules... [ 7.464437] systemd[1]: Starting Remount Root and Kernel File Systems... [ 7.466462] systemd[1]: Starting Coldplug All udev Devices... [ 7.469788] systemd[1]: Mounted Huge Pages File System. [ 7.470287] systemd[1]: Mounted POSIX Message Queue File System. [ 7.470541] systemd[1]: Mounted Kernel Debug File System. [ 7.470742] systemd[1]: Mounted Kernel Trace File System. [ 7.471336] systemd[1]: Finished Restore / save the current clock. [ 7.472078] systemd[1]: Finished Create List of Static Device Nodes. [ 7.472527] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully. [ 7.472844] systemd[1]: Finished Load Kernel Module chromeos_pstore. [ 7.473344] systemd[1]: modprobe@configfs.service: Deactivated successfully. [ 7.473613] systemd[1]: Finished Load Kernel Module configfs. [ 7.473952] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 7.474229] systemd[1]: Finished Load Kernel Module drm. [ 7.474552] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [ 7.474825] systemd[1]: Finished Load Kernel Module efi_pstore. [ 7.475144] systemd[1]: modprobe@fuse.service: Deactivated successfully. [ 7.475406] systemd[1]: Finished Load Kernel Module fuse. [ 7.475722] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully. [ 7.475978] systemd[1]: Finished Load Kernel Module pstore_blk. [ 7.476331] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully. [ 7.476586] systemd[1]: Finished Load Kernel Module pstore_zone. [ 7.477021] systemd[1]: modprobe@ramoops.service: Deactivated successfully. [ 7.477289] systemd[1]: Finished Load Kernel Module ramoops. [ 7.477430] EXT4-fs (nvme0n1p2): re-mounted. Opts: commit=600,errors=remount-ro [ 7.477724] systemd[1]: Finished Load Kernel Modules. [ 7.480238] systemd[1]: Mounting FUSE Control File System... [ 7.481485] systemd[1]: Mounting Kernel Configuration File System... [ 7.483213] systemd[1]: Starting Apply Kernel Variables... [ 7.485250] systemd[1]: Finished Remount Root and Kernel File Systems. [ 7.485650] systemd[1]: Mounted FUSE Control File System. [ 7.485815] systemd[1]: Mounted Kernel Configuration File System. [ 7.487408] systemd[1]: Starting Platform Persistent Storage Archival... [ 7.488823] systemd[1]: Starting Load/Save Random Seed... [ 7.490335] systemd[1]: Starting Create System Users... [ 7.504024] systemd[1]: Finished Create System Users. [ 7.506172] systemd[1]: Starting Create Static Device Nodes in /dev... [ 7.514083] systemd[1]: Finished Apply Kernel Variables. [ 7.527754] systemd[1]: Finished Create Static Device Nodes in /dev. [ 7.529476] systemd[1]: Starting Rule-based Manager for Device Events and Files... [ 7.533746] systemd[1]: Finished Set the console keyboard layout. [ 7.533989] systemd[1]: Reached target Preparation for Local File Systems. [ 7.535221] systemd[1]: Mounting /tmp... [ 7.538045] systemd[1]: Mounted /tmp. [ 7.557664] systemd[1]: Finished Platform Persistent Storage Archival. [ 7.569237] systemd[1]: Finished Load/Save Random Seed. [ 7.569463] systemd[1]: Condition check resulted in First Boot Complete being skipped. [ 7.588104] systemd[1]: Started Rule-based Manager for Device Events and Files. [ 7.639892] systemd[1]: Finished Coldplug All udev Devices. [ 7.641422] systemd[1]: Starting Helper to synchronize boot up for ifupdown... [ 7.642581] systemd[1]: Starting Show Plymouth Boot Screen... [ 7.645637] systemd[1]: Finished Helper to synchronize boot up for ifupdown. [ 7.664411] systemd[1]: Created slice Slice /system/systemd-backlight. [ 7.665453] systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:backlight_1... [ 7.665949] systemd[1]: Started Show Plymouth Boot Screen. [ 7.666150] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 7.666322] systemd[1]: Started Forward Password Requests to Plymouth Directory Watch. [ 7.666369] systemd[1]: Reached target Local Encrypted Volumes. [ 7.671947] systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:backlight_1. [ 7.679875] systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:backlight... [ 7.694555] systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:backlight. [ 7.765730] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 7.765792] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 7.779036] systemd[1]: Found device Samsung SSD 960 EVO 500GB armbi_boot. [ 7.780366] systemd[1]: Starting File System Check on /dev/disk/by-uuid/1BD1-7F33... [ 7.786865] systemd[1]: Started File System Check Daemon to report status. [ 7.806672] systemd[1]: Found device /dev/ttyFIQ0. [ 7.808471] systemd[1]: Finished File System Check on /dev/disk/by-uuid/1BD1-7F33. [ 7.809981] systemd[1]: Mounting /boot... [ 7.811674] FAT-fs (nvme0n1p1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive! [ 7.814617] systemd[1]: Mounted /boot. [ 7.814809] systemd[1]: Reached target Local File Systems. [ 7.816016] systemd[1]: Starting Armbian leds state... [ 7.817216] systemd[1]: Starting Armbian ZRAM config... [ 7.818407] systemd[1]: Starting Set console font and keymap... [ 7.819603] systemd[1]: Starting Raise network interfaces... [ 7.820695] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data... [ 7.820798] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped. [ 7.822461] systemd[1]: Starting Set Up Additional Binary Formats... [ 7.822557] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 7.822606] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 7.823266] systemd[1]: Finished Set console font and keymap. [ 7.831153] systemd[1]: Finished Armbian leds state. [ 7.832042] systemd[1]: Received SIGRTMIN+20 from PID 299 (plymouthd). [ 7.832433] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 493 (systemd-binfmt) [ 7.834007] systemd[1]: Mounting Arbitrary Executable File Formats File System... [ 7.835687] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data. [ 7.841662] systemd[1]: Mounted Arbitrary Executable File Formats File System. [ 7.845986] systemd[1]: Finished Set Up Additional Binary Formats. [ 7.846208] systemd[1]: Reached target Hardware activated USB gadget. [ 7.851822] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 7.851874] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 7.851908] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 7.868440] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 7.916417] zram0: detected capacity change from 0 to 4031107072 [ 7.946245] Adding 3936624k swap on /dev/zram0. Priority:5 extents:1 across:3936624k SS [ 7.953053] zram: Added device: zram1 [ 7.957831] systemd[1]: Finished Raise network interfaces. [ 8.029456] zram1: detected capacity change from 0 to 52428800 [ 8.059347] systemd[1]: Finished Armbian ZRAM config. [ 8.063406] systemd[1]: Starting Armbian memory supported logging... [ 8.112036] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard [ 8.726063] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 8.726241] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 8.726352] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 8.796576] vendor storage:20190527 ret = -1 [ 9.640126] systemd[1]: Finished Armbian memory supported logging. [ 9.653355] systemd[1]: Starting Journal Service... [ 9.800439] systemd[1]: Started Journal Service. [ 9.830723] systemd-journald[725]: Received client request to flush runtime journal. ### armbian-release: # PLEASE DO NOT EDIT THIS FILE BOARD=orangepi5 BOARD_NAME="Orange Pi 5" BOARDFAMILY=rockchip-rk3588 BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=bfc8271 VERSION=23.08.0-trunk LINUXFAMILY=rk35xx ARCH=arm64 IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm64 KERNEL_IMAGE_TYPE=Image FORCE_BOOTSCRIPT_UPDATE= VENDOR=Armbian REVISION=23.08.0-trunk BOOTSCRIPT_FORCE_UPDATE="no" BOOTSCRIPT_DST="boot.cmd" BRANCH=legacy ### boot environment: verbosity=1 bootlogo=true overlay_prefix=rockchip-rk3588 fdtfile=rockchip/rk3588s-orangepi-5.dtb rootdev=UUID=329a3cf7-a8ce-4ea6-a3ef-c2128bda1678 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u ### lsusb: Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 002: ID 046d:c539 Logitech, Inc. USB Receiver Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub ### lscpu: Architecture: aarch64 CPU op-mode(s): 32-bit, 64-bit Byte Order: Little Endian CPU(s): 8 On-line CPU(s) list: 0-7 Vendor ID: ARM Model name: Cortex-A55 Model: 0 Thread(s) per core: 1 Core(s) per socket: 4 Socket(s): 1 Stepping: r2p0 CPU max MHz: 1800.0000 CPU min MHz: 408.0000 BogoMIPS: 48.00 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp Model name: Cortex-A76 Model: 0 Thread(s) per core: 1 Core(s) per socket: 2 Socket(s): 2 Stepping: r4p0 CPU max MHz: 2256.0000 CPU min MHz: 408.0000 BogoMIPS: 48.00 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp L1d cache: 384 KiB (8 instances) L1i cache: 384 KiB (8 instances) L2 cache: 2.5 MiB (8 instances) L3 cache: 3 MiB (1 instance) Vulnerability Itlb multihit: Not affected Vulnerability L1tf: Not affected Vulnerability Mds: Not affected Vulnerability Meltdown: Not affected Vulnerability Mmio stale data: Not affected Vulnerability Retbleed: Not affected Vulnerability Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl Vulnerability Spectre v1: Mitigation; __user pointer sanitization Vulnerability Spectre v2: Vulnerable: Unprivileged eBPF enabled Vulnerability Srbds: Not affected Vulnerability Tsx async abort: Not affected ### cpuinfo: processor : 0 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 1 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 2 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 3 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 4 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 processor : 5 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 processor : 6 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 processor : 7 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 Serial : 2eae2cb9d903d20e ### meminfo: MemTotal: 7873256 kB MemFree: 7561736 kB MemAvailable: 7587744 kB Buffers: 15728 kB Cached: 82968 kB SwapCached: 0 kB Active: 27272 kB Inactive: 107788 kB Active(anon): 620 kB Inactive(anon): 65692 kB Active(file): 26652 kB Inactive(file): 42096 kB Unevictable: 19608 kB Mlocked: 0 kB SwapTotal: 3936624 kB SwapFree: 3936624 kB Dirty: 3360 kB Writeback: 0 kB AnonPages: 56744 kB Mapped: 29200 kB Shmem: 25952 kB KReclaimable: 37952 kB Slab: 79648 kB SReclaimable: 37952 kB SUnreclaim: 41696 kB KernelStack: 3776 kB PageTables: 3120 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 7873252 kB Committed_AS: 135108 kB VmallocTotal: 135290290112 kB VmallocUsed: 36640 kB VmallocChunk: 0 kB Percpu: 2656 kB CmaTotal: 262144 kB CmaAllocated: 4672 kB CmaReleased: 257472 kB CmaFree: 257472 kB HugePages_Total: 0 HugePages_Free: 0 HugePages_Rsvd: 0 HugePages_Surp: 0 Hugepagesize: 2048 kB Hugetlb: 0 kB ### virtual memory: vm.admin_reserve_kbytes = 8192 vm.block_dump = 0 vm.dirty_background_bytes = 0 vm.dirty_background_ratio = 10 vm.dirty_bytes = 0 vm.dirty_expire_centisecs = 3000 vm.dirty_ratio = 20 vm.dirtytime_expire_seconds = 43200 vm.dirty_writeback_centisecs = 500 vm.extra_free_kbytes = 0 vm.hugetlb_shm_group = 0 vm.laptop_mode = 0 vm.legacy_va_layout = 0 vm.lowmem_reserve_ratio = 256 256 32 0 vm.max_map_count = 65530 vm.min_free_kbytes = 11208 vm.mmap_min_addr = 32768 vm.mmap_rnd_bits = 18 vm.mmap_rnd_compat_bits = 11 vm.nr_hugepages = 0 vm.nr_overcommit_hugepages = 0 vm.oom_dump_tasks = 1 vm.oom_kill_allocating_task = 0 vm.overcommit_kbytes = 0 vm.overcommit_memory = 0 vm.overcommit_ratio = 50 vm.page-cluster = 0 vm.page_lock_unfairness = 5 vm.panic_on_oom = 0 vm.percpu_pagelist_fraction = 0 vm.stat_interval = 1 vm.swappiness = 100 vm.user_reserve_kbytes = 131072 vm.vfs_cache_pressure = 100 vm.watermark_boost_factor = 15000 vm.watermark_scale_factor = 10 ### ip addr: 1: lo: mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet XXX.XXX.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: eth0: mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether ae:d8:3f:81:fa:0b brd ff:ff:ff:ff:ff:ff ### partitions: major minor #blocks name 254 0 3936628 zram0 31 0 16384 mtdblock0 259 0 488386584 nvme0n1 259 1 262144 nvme0n1p1 259 2 483213312 nvme0n1p2 254 1 51200 zram1 ### df: tmpfs 769M 9.7M 760M 2% /run /dev/nvme0n1p2 454G 5.0G 444G 2% / tmpfs 3.8G 0 3.8G 0% /dev/shm tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs 3.8G 4.0K 3.8G 1% /tmp /dev/nvme0n1p1 256M 106M 151M 42% /boot /dev/zram1 47M 3.6M 40M 9% /var/log ### lsblk: NAME FSTYPE SIZE MOUNTPOINT UUID mtdblock0 16M zram1 50M /var/log nvme0n1 465.8G ├─nvme0n1p1 vfat 256M /boot 1BD1-7F33 └─nvme0n1p2 ext4 460.8G / 329a3cf7-a8ce-4ea6-a3ef-c2128bda1678 ### zramctl: NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT /dev/zram1 zstd 50M 3.6M 700.4K 1M 8 /var/log /dev/zram0 lzo-rle 3.8G 4K 74B 12K 8 [SWAP] ### mtab: /dev/nvme0n1p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=936,iocharset=utf8,shortname=mixed,errors=remount-ro 0 0 /dev/nvme0n1p2 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0 /dev/nvme0n1p2 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0 ### Boot system health: Time CPU_cl0/CPU_cl1 load %cpu %sys %usr %nice %io %irq Tcpu C.St. 21:00:23 1800/2256 MHz 0.16 21% 12% 7% 0% 1% 0% 46.2 °C 0/7 21:00:24 1800/2256 MHz 0.16 24% 6% 14% 0% 2% 0% 44.4 °C 0/7 21:00:24 1800/2256 MHz 0.16 18% 5% 12% 0% 0% 0% 44.4 °C 0/7 21:00:24 1800/ 816 MHz 0.16 19% 6% 11% 0% 0% 0% 43.5 °C 0/7 21:00:25 1800/ 408 MHz 0.16 17% 3% 12% 0% 0% 0% 42.5 °C 0/7 ### Activated 1 lzo-rle zram swap devices with 3844MB each. ### Activated Armbian ramlog partition with zstd compression Mon Aug 7 09:11:54 PM +03 2023 | Orange Pi 5 | 23.08.0-trunk | arm64 | aarch64 | 5.10.160-rk35xx ### dmesg: [ 1.766824] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [ 1.766849] Linux version 5.10.160-rk35xx (armbian@next) (aarch64-linux-gnu-gcc (Ubuntu 11.3.0-1ubuntu1~22.04) 11.3.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP Thu Jul 6 13:36:29 UTC 2023 [ 1.777660] Machine model: Orange Pi 5 [ 1.777844] efi: UEFI not found. [ 1.781498] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB [ 1.781518] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@00000000': base 0x0000000000000000, size 0 MiB [ 1.781608] Reserved memory: created CMA memory pool at 0x0000000010000000, size 256 MiB [ 1.781613] OF: reserved mem: initialized node cma, compatible id shared-dma-pool [ 1.932168] Zone ranges: [ 1.932176] DMA [mem 0x0000000000200000-0x00000000ffffffff] [ 1.932187] DMA32 empty [ 1.932194] Normal [mem 0x0000000100000000-0x00000001ffffffff] [ 1.932201] Movable zone start for each node [ 1.932205] Early memory node ranges [ 1.932211] node 0: [mem 0x0000000000200000-0x00000000efffffff] [ 1.932219] node 0: [mem 0x0000000100000000-0x00000001ffffffff] [ 1.932227] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff] [ 1.932233] On node 0 totalpages: 2031104 [ 1.932239] DMA zone: 15352 pages used for memmap [ 1.932243] DMA zone: 0 pages reserved [ 1.932249] DMA zone: 982528 pages, LIFO batch:63 [ 1.932254] Normal zone: 16384 pages used for memmap [ 1.932259] Normal zone: 1048576 pages, LIFO batch:63 [ 1.979248] psci: probing for conduit method from DT. [ 1.979260] psci: PSCIv1.1 detected in firmware. [ 1.979264] psci: Using standard PSCI v0.2 function IDs [ 1.979271] psci: MIGRATE_INFO_TYPE not supported. [ 1.979278] psci: SMC Calling Convention v1.2 [ 1.979701] percpu: Embedded 32 pages/cpu s93480 r8192 d29400 u131072 [ 1.979744] pcpu-alloc: s93480 r8192 d29400 u131072 alloc=32*4096 [ 1.979752] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7 [ 1.979895] Detected VIPT I-cache on CPU0 [ 1.979945] CPU features: detected: GIC system register CPU interface [ 1.979950] CPU features: detected: Virtualization Host Extensions [ 1.979961] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 1.979974] alternatives: patching kernel code [ 1.980360] Built 1 zonelists, mobility grouping on. Total pages: 1999368 [ 1.980370] Kernel command line: root=UUID=329a3cf7-a8ce-4ea6-a3ef-c2128bda1678 rootwait rootfstype=ext4 splash plymouth.ignore-serial-consoles console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart= usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 [ 1.981707] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) [ 1.982113] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 1.982121] mem auto-init: stack:off, heap alloc:off, heap free:off [ 1.988616] software IO TLB: mapped [mem 0x00000000ec000000-0x00000000f0000000] (64MB) [ 2.063349] Memory: 7589180K/8124416K available (16832K kernel code, 3506K rwdata, 6500K rodata, 6976K init, 639K bss, 273092K reserved, 262144K cma-reserved) [ 2.063510] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1 [ 2.063546] ftrace: allocating 64539 entries in 253 pages [ 2.173916] ftrace: allocated 253 pages with 7 groups [ 2.174223] rcu: Hierarchical RCU implementation. [ 2.174229] rcu: RCU event tracing is enabled. [ 2.174235] Rude variant of Tasks RCU enabled. [ 2.174238] Tracing variant of Tasks RCU enabled. [ 2.174244] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies. [ 2.179905] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 2.182728] GICv3: GIC: Using split EOI/Deactivate mode [ 2.182734] GICv3: 480 SPIs implemented [ 2.182739] GICv3: 0 Extended SPIs implemented [ 2.182778] GICv3: Distributor has no Range Selector support [ 2.182788] GICv3: 16 PPIs implemented [ 2.182834] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000 [ 2.182962] ITS [mem 0xfe640000-0xfe65ffff] [ 2.183020] ITS@0x00000000fe640000: allocated 8192 Devices @100200000 (indirect, esz 8, psz 64K, shr 0) [ 2.183049] ITS@0x00000000fe640000: allocated 32768 Interrupt Collections @100210000 (flat, esz 2, psz 64K, shr 0) [ 2.183059] ITS: using cache flushing for cmd queue [ 2.183102] ITS [mem 0xfe660000-0xfe67ffff] [ 2.183151] ITS@0x00000000fe660000: allocated 8192 Devices @100230000 (indirect, esz 8, psz 64K, shr 0) [ 2.183179] ITS@0x00000000fe660000: allocated 32768 Interrupt Collections @100240000 (flat, esz 2, psz 64K, shr 0) [ 2.183188] ITS: using cache flushing for cmd queue [ 2.183413] GICv3: using LPI property table @0x0000000100250000 [ 2.183543] GIC: using cache flushing for LPI property table [ 2.183554] GICv3: CPU0: using allocated LPI pending table @0x0000000100260000 [ 2.319910] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 2.319919] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 2.319929] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 2.321306] Console: colour dummy device 80x25 [ 2.321349] printk: console [tty1] enabled [ 2.321380] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000) [ 2.321391] pid_max: default: 32768 minimum: 301 [ 2.321502] LSM: Security Framework initializing [ 2.321574] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 2.321599] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 2.323859] rcu: Hierarchical SRCU implementation. [ 2.324832] Platform MSI: msi-controller@fe640000 domain created [ 2.324855] Platform MSI: msi-controller@fe660000 domain created [ 2.325248] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe640000 domain created [ 2.325274] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe660000 domain created [ 2.325468] EFI services will not be available. [ 2.325920] smp: Bringing up secondary CPUs ... [ 2.326639] Detected VIPT I-cache on CPU1 [ 2.326676] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000 [ 2.326695] GICv3: CPU1: using allocated LPI pending table @0x0000000100270000 [ 2.326740] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [ 2.327510] Detected VIPT I-cache on CPU2 [ 2.327543] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000 [ 2.327561] GICv3: CPU2: using allocated LPI pending table @0x0000000100280000 [ 2.327603] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [ 2.328331] Detected VIPT I-cache on CPU3 [ 2.328360] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000 [ 2.328378] GICv3: CPU3: using allocated LPI pending table @0x0000000100290000 [ 2.328417] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [ 2.329158] CPU features: detected: Spectre-v4 [ 2.329162] CPU features: detected: Spectre-BHB [ 2.329164] Detected PIPT I-cache on CPU4 [ 2.329180] GICv3: CPU4: found redistributor 400 region 0:0x00000000fe700000 [ 2.329190] GICv3: CPU4: using allocated LPI pending table @0x00000001002a0000 [ 2.329216] CPU4: Booted secondary processor 0x0000000400 [0x414fd0b0] [ 2.329942] Detected PIPT I-cache on CPU5 [ 2.329959] GICv3: CPU5: found redistributor 500 region 0:0x00000000fe720000 [ 2.329970] GICv3: CPU5: using allocated LPI pending table @0x00000001002b0000 [ 2.329995] CPU5: Booted secondary processor 0x0000000500 [0x414fd0b0] [ 2.330689] Detected PIPT I-cache on CPU6 [ 2.330705] GICv3: CPU6: found redistributor 600 region 0:0x00000000fe740000 [ 2.330716] GICv3: CPU6: using allocated LPI pending table @0x00000001002c0000 [ 2.330741] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b0] [ 2.331420] Detected PIPT I-cache on CPU7 [ 2.331436] GICv3: CPU7: found redistributor 700 region 0:0x00000000fe760000 [ 2.331447] GICv3: CPU7: using allocated LPI pending table @0x00000001002d0000 [ 2.331472] CPU7: Booted secondary processor 0x0000000700 [0x414fd0b0] [ 2.331551] smp: Brought up 1 node, 8 CPUs [ 2.331571] SMP: Total of 8 processors activated. [ 2.331576] CPU features: detected: Privileged Access Never [ 2.331581] CPU features: detected: User Access Override [ 2.331586] CPU features: detected: 32-bit EL0 Support [ 2.331591] CPU features: detected: Common not Private translations [ 2.331596] CPU features: detected: RAS Extension Support [ 2.331600] CPU features: detected: Data cache clean to the PoU not required for I/D coherence [ 2.331605] CPU features: detected: CRC32 instructions [ 2.331609] CPU features: detected: Speculative Store Bypassing Safe (SSBS) [ 2.331616] CPU features: detected: RCpc load-acquire (LDAPR) [ 2.331704] CPU: All CPU(s) started at EL2 [ 2.334991] devtmpfs: initialized [ 2.349785] Registered cp15_barrier emulation handler [ 2.349795] Registered setend emulation handler [ 2.349799] KASLR disabled due to lack of seed [ 2.349885] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns [ 2.349892] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 2.352643] pinctrl core: initialized pinctrl subsystem [ 2.352764] regulator-dummy: no parameters, enabled [ 2.352882] DMI not present or invalid. [ 2.353188] NET: Registered protocol family 16 [ 2.354289] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations [ 2.354402] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 2.354421] audit: initializing netlink subsys (disabled) [ 2.354506] audit: type=2000 audit(0.033:1): state=initialized audit_enabled=0 res=1 [ 2.355020] Registered FIQ tty driver [ 2.355170] thermal_sys: Registered thermal governor 'fair_share' [ 2.355173] thermal_sys: Registered thermal governor 'step_wise' [ 2.355175] thermal_sys: Registered thermal governor 'user_space' [ 2.355177] thermal_sys: Registered thermal governor 'power_allocator' [ 2.355500] cpuidle: using governor menu [ 2.355729] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 2.355865] ASID allocator initialised with 65536 entries [ 2.357374] ramoops: dmesg-0 0x20000@0x0000000000110000 [ 2.357392] ramoops: console 0x80000@0x0000000000130000 [ 2.357404] ramoops: pmsg 0x50000@0x00000000001b0000 [ 2.357451] printk: console [ramoops-1] enabled [ 2.357453] pstore: Registered ramoops as persistent store backend [ 2.357455] ramoops: using 0xf0000@0x110000, ecc: 0 [ 2.411447] rockchip-gpio fd8a0000.gpio: probed /pinctrl/gpio@fd8a0000 [ 2.411742] rockchip-gpio fec20000.gpio: probed /pinctrl/gpio@fec20000 [ 2.411976] rockchip-gpio fec30000.gpio: probed /pinctrl/gpio@fec30000 [ 2.412246] rockchip-gpio fec40000.gpio: probed /pinctrl/gpio@fec40000 [ 2.412521] rockchip-gpio fec50000.gpio: probed /pinctrl/gpio@fec50000 [ 2.412571] rockchip-pinctrl pinctrl: probed pinctrl [ 2.421252] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 2.421256] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 2.421259] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 2.421262] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 2.483228] raid6: neonx8 gen() 5361 MB/s [ 2.539986] raid6: neonx8 xor() 4163 MB/s [ 2.596749] raid6: neonx4 gen() 5497 MB/s [ 2.653508] raid6: neonx4 xor() 4176 MB/s [ 2.710267] raid6: neonx2 gen() 5041 MB/s [ 2.767029] raid6: neonx2 xor() 3940 MB/s [ 2.823789] raid6: neonx1 gen() 4212 MB/s [ 2.880551] raid6: neonx1 xor() 3247 MB/s [ 2.937325] raid6: int64x8 gen() 1312 MB/s [ 2.994080] raid6: int64x8 xor() 860 MB/s [ 3.050840] raid6: int64x4 gen() 1615 MB/s [ 3.107604] raid6: int64x4 xor() 860 MB/s [ 3.164358] raid6: int64x2 gen() 1887 MB/s [ 3.221118] raid6: int64x2 xor() 1299 MB/s [ 3.277883] raid6: int64x1 gen() 1966 MB/s [ 3.334652] raid6: int64x1 xor() 960 MB/s [ 3.334654] raid6: using algorithm neonx4 gen() 5497 MB/s [ 3.334656] raid6: .... xor() 4176 MB/s, rmw enabled [ 3.334658] raid6: using neon recovery algorithm [ 3.335267] fiq_debugger fiq_debugger.0: IRQ fiq not found [ 3.335274] fiq_debugger fiq_debugger.0: IRQ wakeup not found [ 3.335278] fiq_debugger_probe: could not install nmi irq handler [ 3.335362] printk: console [ttyFIQ0] enabled [ 3.335472] Registered fiq debugger ttyFIQ0 [ 3.335675] vcc12v_dcin: 12000 mV, enabled [ 3.335754] reg-fixed-voltage vcc12v-dcin: vcc12v_dcin supplying 12000000uV [ 3.335804] reg-fixed-voltage vcc5v0-sys: Looking up vin-supply from device tree [ 3.335808] vcc5v0_sys: supplied by vcc12v_dcin [ 3.335813] vcc12v_dcin: could not add device link regulator.2: -ENOENT [ 3.335830] vcc5v0_sys: 5000 mV, enabled [ 3.335896] reg-fixed-voltage vcc5v0-sys: vcc5v0_sys supplying 5000000uV [ 3.335943] reg-fixed-voltage vcc5v0-usbdcin: Looking up vin-supply from device tree [ 3.335947] vcc5v0_usbdcin: supplied by vcc12v_dcin [ 3.335950] vcc12v_dcin: could not add device link regulator.3: -ENOENT [ 3.335965] vcc5v0_usbdcin: 5000 mV, enabled [ 3.336031] reg-fixed-voltage vcc5v0-usbdcin: vcc5v0_usbdcin supplying 5000000uV [ 3.336076] reg-fixed-voltage vcc5v0-usb: Looking up vin-supply from device tree [ 3.336080] vcc5v0_usb: supplied by vcc5v0_usbdcin [ 3.336084] vcc5v0_usbdcin: could not add device link regulator.4: -ENOENT [ 3.336098] vcc5v0_usb: 5000 mV, enabled [ 3.336155] reg-fixed-voltage vcc5v0-usb: vcc5v0_usb supplying 5000000uV [ 3.336259] vbus5v0_typec: 5000 mV, disabled [ 3.336310] reg-fixed-voltage vbus5v0-typec: Looking up vin-supply from device tree [ 3.336314] vbus5v0_typec: supplied by vcc5v0_usb [ 3.336347] reg-fixed-voltage vbus5v0-typec: vbus5v0_typec supplying 5000000uV [ 3.336398] reg-fixed-voltage vcc-1v1-nldo-s3: Looking up vin-supply from device tree [ 3.336402] vcc_1v1_nldo_s3: supplied by vcc5v0_sys [ 3.336405] vcc5v0_sys: could not add device link regulator.6: -ENOENT [ 3.336422] vcc_1v1_nldo_s3: 1100 mV, enabled [ 3.336487] reg-fixed-voltage vcc-1v1-nldo-s3: vcc_1v1_nldo_s3 supplying 1100000uV [ 3.336540] reg-fixed-voltage vcc3v3-pcie2x1l2: Looking up vin-supply from device tree [ 3.336544] vcc3v3_pcie2x1l2: supplied by vcc5v0_sys [ 3.336548] vcc5v0_sys: could not add device link regulator.7: -ENOENT [ 3.392162] vcc3v3_pcie2x1l2: 1800 mV, enabled [ 3.392230] reg-fixed-voltage vcc3v3-pcie2x1l2: vcc3v3_pcie2x1l2 supplying 1800000uV [ 3.392516] iommu: Default domain type: Translated [ 3.392951] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vdpu-supply from device tree [ 3.392971] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vdpu-supply property in node /power-management@fd8d8000/power-controller failed [ 3.393238] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga30-supply from device tree [ 3.393257] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga30-supply property in node /power-management@fd8d8000/power-controller failed [ 3.393437] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga31-supply from device tree [ 3.393455] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga31-supply property in node /power-management@fd8d8000/power-controller failed [ 3.394764] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc0-supply from device tree [ 3.394782] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc0-supply property in node /power-management@fd8d8000/power-controller failed [ 3.394935] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vcodec-supply from device tree [ 3.394953] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vcodec-supply property in node /power-management@fd8d8000/power-controller failed [ 3.395054] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc1-supply from device tree [ 3.395071] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc1-supply property in node /power-management@fd8d8000/power-controller failed [ 3.395348] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec0-supply from device tree [ 3.395365] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec0-supply property in node /power-management@fd8d8000/power-controller failed [ 3.395657] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec1-supply from device tree [ 3.395675] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec1-supply property in node /power-management@fd8d8000/power-controller failed [ 3.395893] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vi-supply from device tree [ 3.395910] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vi-supply property in node /power-management@fd8d8000/power-controller failed [ 3.396143] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up isp1-supply from device tree [ 3.396160] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up isp1-supply property in node /power-management@fd8d8000/power-controller failed [ 3.396865] SCSI subsystem initialized [ 3.396880] libata version 3.00 loaded. [ 3.396955] usbcore: registered new interface driver usbfs [ 3.396972] usbcore: registered new interface driver hub [ 3.396986] usbcore: registered new device driver usb [ 3.397025] mc: Linux media interface: v0.10 [ 3.397036] videodev: Linux video capture interface: v2.00 [ 3.397065] pps_core: LinuxPPS API ver. 1 registered [ 3.397067] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [ 3.397073] PTP clock support registered [ 3.397341] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled. [ 3.397375] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0 [ 3.398589] Advanced Linux Sound Architecture Driver Initialized. [ 3.398852] Bluetooth: Core ver 2.22 [ 3.398867] NET: Registered protocol family 31 [ 3.398869] Bluetooth: HCI device and connection manager initialized [ 3.398874] Bluetooth: HCI socket layer initialized [ 3.398877] Bluetooth: L2CAP socket layer initialized [ 3.398883] Bluetooth: SCO socket layer initialized [ 3.398897] NetLabel: Initializing [ 3.398899] NetLabel: domain hash size = 128 [ 3.398901] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 3.398927] NetLabel: unlabeled traffic allowed by default [ 3.400256] rockchip-cpuinfo cpuinfo: SoC : 35881000 [ 3.400260] rockchip-cpuinfo cpuinfo: Serial : 2eae2cb9d903d20e [ 3.400706] clocksource: Switched to clocksource arch_sys_counter [ 3.817574] VFS: Disk quotas dquot_6.6.0 [ 3.817603] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 3.823372] NET: Registered protocol family 2 [ 3.823495] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 3.825512] tcp_listen_portaddr_hash hash table entries: 4096 (order: 5, 163840 bytes, linear) [ 3.825610] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 3.825958] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear) [ 3.826760] TCP: Hash tables configured (established 65536 bind 65536) [ 3.826871] MPTCP token hash table entries: 8192 (order: 6, 393216 bytes, linear) [ 3.826969] UDP hash table entries: 4096 (order: 6, 393216 bytes, linear) [ 3.827125] UDP-Lite hash table entries: 4096 (order: 6, 393216 bytes, linear) [ 3.827341] NET: Registered protocol family 1 [ 3.827709] RPC: Registered named UNIX socket transport module. [ 3.827711] RPC: Registered udp transport module. [ 3.827713] RPC: Registered tcp transport module. [ 3.827715] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 3.828180] PCI: CLS 0 bytes, default 64 [ 3.828504] Trying to unpack rootfs image as initramfs... [ 4.224136] Freeing initrd memory: 14956K [ 4.224834] rockchip-thermal fec00000.tsadc: Missing rockchip,grf property [ 4.225475] rockchip-thermal fec00000.tsadc: tsadc is probed successfully! [ 4.226421] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 4.227037] kvm [1]: IPA Size Limit: 40 bits [ 4.227048] kvm [1]: GICv3: no GICV resource entry [ 4.227051] kvm [1]: disabling GICv2 emulation [ 4.227054] kvm [1]: GIC system register CPU interface enabled [ 4.227205] kvm [1]: vgic interrupt IRQ9 [ 4.227398] kvm [1]: VHE mode initialized successfully [ 4.230444] Initialise system trusted keyrings [ 4.230562] workingset: timestamp_bits=46 max_order=21 bucket_order=0 [ 4.233609] NFS: Registering the id_resolver key type [ 4.233622] Key type id_resolver registered [ 4.233624] Key type id_legacy registered [ 4.233659] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 4.233662] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 4.233675] ntfs: driver 2.1.32 [Flags: R/W]. [ 4.255230] NET: Registered protocol family 38 [ 4.255235] xor: measuring software checksum speed [ 4.256845] 8regs : 6132 MB/sec [ 4.258068] 32regs : 8129 MB/sec [ 4.259064] arm64_neon : 9907 MB/sec [ 4.259066] xor: using function: arm64_neon (9907 MB/sec) [ 4.259072] Key type asymmetric registered [ 4.259074] Asymmetric key parser 'x509' registered [ 4.259091] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242) [ 4.259219] io scheduler mq-deadline registered [ 4.259224] io scheduler kyber registered [ 4.261107] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up phy-supply from device tree [ 4.261115] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up phy-supply property in node /syscon@fd5d0000/usb2-phy@0/otg-port failed [ 4.261164] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up vbus-supply from device tree [ 4.261171] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up vbus-supply property in node /syscon@fd5d0000/usb2-phy@0/otg-port failed [ 4.262505] phy phy-fd5d8000.syscon:usb2-phy@8000.1: Looking up phy-supply from device tree [ 4.262514] phy phy-fd5d8000.syscon:usb2-phy@8000.1: Looking up phy-supply property in node /syscon@fd5d8000/usb2-phy@8000/host-port failed [ 4.263699] phy phy-fd5dc000.syscon:usb2-phy@c000.2: Looking up phy-supply from device tree [ 4.263707] phy phy-fd5dc000.syscon:usb2-phy@c000.2: Looking up phy-supply property in node /syscon@fd5dc000/usb2-phy@c000/host-port failed [ 4.265579] phy phy-fee00000.phy.3: Looking up phy-supply from device tree [ 4.265586] phy phy-fee00000.phy.3: Looking up phy-supply property in node /phy@fee00000 failed [ 4.265738] phy phy-fee20000.phy.4: Looking up phy-supply from device tree [ 4.265743] phy phy-fee20000.phy.4: Looking up phy-supply property in node /phy@fee20000 failed [ 4.266237] phy phy-feda0000.phy.5: Looking up phy-supply from device tree [ 4.266243] phy phy-feda0000.phy.5: Looking up phy-supply property in node /phy@feda0000 failed [ 4.266378] phy phy-fedb0000.phy.6: Looking up phy-supply from device tree [ 4.266384] phy phy-fedb0000.phy.6: Looking up phy-supply property in node /phy@fedb0000 failed [ 4.266755] phy phy-fed60000.hdmiphy.7: Looking up phy-supply from device tree [ 4.266762] phy phy-fed60000.hdmiphy.7: Looking up phy-supply property in node /hdmiphy@fed60000 failed [ 4.267554] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy init success [ 4.268502] phy phy-fed80000.phy.8: Looking up phy-supply from device tree [ 4.268509] phy phy-fed80000.phy.8: Looking up phy-supply property in node /phy@fed80000/dp-port failed [ 4.268545] phy phy-fed80000.phy.9: Looking up phy-supply from device tree [ 4.268550] phy phy-fed80000.phy.9: Looking up phy-supply property in node /phy@fed80000/u3-port failed [ 4.270013] rk-pcie fe190000.pcie: invalid prsnt-gpios property in node [ 4.270024] rk-pcie fe190000.pcie: Looking up vpcie3v3-supply from device tree [ 4.270254] pwm-backlight backlight: Looking up power-supply from device tree [ 4.270260] pwm-backlight backlight: Looking up power-supply property in node /backlight failed [ 4.270266] pwm-backlight backlight: supply power not found, using dummy regulator [ 4.270538] pwm-backlight backlight_1: Looking up power-supply from device tree [ 4.270543] pwm-backlight backlight_1: Looking up power-supply property in node /backlight_1 failed [ 4.270548] pwm-backlight backlight_1: supply power not found, using dummy regulator [ 4.270738] rk-pcie fe190000.pcie: IRQ msi not found [ 4.270745] rk-pcie fe190000.pcie: use outband MSI support [ 4.270752] rk-pcie fe190000.pcie: Missing *config* reg space [ 4.270770] rk-pcie fe190000.pcie: host bridge /pcie@fe190000 ranges: [ 4.270803] rk-pcie fe190000.pcie: err 0x00f4000000..0x00f40fffff -> 0x00f4000000 [ 4.270833] rk-pcie fe190000.pcie: IO 0x00f4100000..0x00f41fffff -> 0x00f4100000 [ 4.270850] iep: Module initialized. [ 4.270856] rk-pcie fe190000.pcie: MEM 0x00f4200000..0x00f4ffffff -> 0x00f4200000 [ 4.270873] rk-pcie fe190000.pcie: MEM 0x0a00000000..0x0a3fffffff -> 0x0a00000000 [ 4.270893] mpp_service mpp-srv: unknown mpp version for missing VCS info [ 4.270895] mpp_service mpp-srv: probe start [ 4.270905] rk-pcie fe190000.pcie: Missing *config* reg space [ 4.270936] rk-pcie fe190000.pcie: invalid resource [ 4.272853] mpp_vdpu2 fdb50400.vdpu: Adding to iommu group 1 [ 4.273075] mpp_vdpu2 fdb50400.vdpu: probe device [ 4.273196] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0 [ 4.273202] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0 [ 4.273341] mpp_vdpu2 fdb50400.vdpu: probing finish [ 4.273555] mpp_vepu2 jpege-ccu: probing start [ 4.273559] mpp_vepu2 jpege-ccu: probing finish [ 4.273669] mpp_vepu2 fdb50000.vepu: Adding to iommu group 1 [ 4.273751] mpp_vepu2 fdb50000.vepu: probing start [ 4.273847] mpp_vepu2 fdb50000.vepu: reset_group->rw_sem_on=0 [ 4.273850] mpp_vepu2 fdb50000.vepu: reset_group->rw_sem_on=0 [ 4.273998] mpp_vepu2 fdb50000.vepu: probing finish [ 4.274135] mpp_vepu2 fdba0000.jpege-core: Adding to iommu group 5 [ 4.274276] mpp_vepu2 fdba0000.jpege-core: probing start [ 4.274384] mpp_vepu2 fdba0000.jpege-core: attach ccu success [ 4.274524] mpp_vepu2 fdba0000.jpege-core: probing finish [ 4.274633] mpp_vepu2 fdba4000.jpege-core: Adding to iommu group 6 [ 4.274773] mpp_vepu2 fdba4000.jpege-core: probing start [ 4.274881] mpp_vepu2 fdba4000.jpege-core: attach ccu success [ 4.275018] mpp_vepu2 fdba4000.jpege-core: probing finish [ 4.275126] mpp_vepu2 fdba8000.jpege-core: Adding to iommu group 7 [ 4.275263] mpp_vepu2 fdba8000.jpege-core: probing start [ 4.275369] mpp_vepu2 fdba8000.jpege-core: attach ccu success [ 4.275502] mpp_vepu2 fdba8000.jpege-core: probing finish [ 4.275598] mpp_vepu2 fdbac000.jpege-core: Adding to iommu group 8 [ 4.275733] mpp_vepu2 fdbac000.jpege-core: probing start [ 4.275838] mpp_vepu2 fdbac000.jpege-core: attach ccu success [ 4.275984] mpp_vepu2 fdbac000.jpege-core: probing finish [ 4.276258] mpp-iep2 fdbb0000.iep: Adding to iommu group 9 [ 4.276401] mpp-iep2 fdbb0000.iep: probe device [ 4.276528] mpp-iep2 fdbb0000.iep: allocate roi buffer failed [ 4.276652] mpp-iep2 fdbb0000.iep: probing finish [ 4.276872] mpp_jpgdec fdb90000.jpegd: Adding to iommu group 4 [ 4.277077] mpp_jpgdec fdb90000.jpegd: probe device [ 4.277331] mpp_jpgdec fdb90000.jpegd: probing finish [ 4.277709] mpp_rkvdec2 fdc30000.rkvdec-ccu: rkvdec-ccu, probing start [ 4.277770] mpp_rkvdec2 fdc30000.rkvdec-ccu: ccu-mode: 1 [ 4.277773] mpp_rkvdec2 fdc30000.rkvdec-ccu: probing finish [ 4.277870] mpp_rkvdec2 fdc38100.rkvdec-core: Adding to iommu group 12 [ 4.278132] mpp_rkvdec2 fdc38100.rkvdec-core: rkvdec-core, probing start [ 4.278256] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found! [ 4.278259] rkvdec2_init:1022: No niu aclk reset resource define [ 4.278262] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found! [ 4.278265] rkvdec2_init:1025: No niu hclk reset resource define [ 4.278282] mpp_rkvdec2 fdc38100.rkvdec-core: Looking up vdec-supply from device tree [ 4.278288] mpp_rkvdec2 fdc38100.rkvdec-core: Looking up vdec-supply property in node /rkvdec-core@fdc38000 failed [ 4.278294] mpp_rkvdec2 fdc38100.rkvdec-core: no regulator, devfreq is disabled [ 4.278349] mpp_rkvdec2 fdc38100.rkvdec-core: core_mask=00010001 [ 4.278352] mpp_rkvdec2 fdc38100.rkvdec-core: attach ccu as core 0 [ 4.278500] mpp_rkvdec2 fdc38100.rkvdec-core: sram_start 0x00000000ff001000 [ 4.278503] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_iova 0x00000000fff00000 [ 4.278505] mpp_rkvdec2 fdc38100.rkvdec-core: sram_size 491520 [ 4.278508] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_size 1048576 [ 4.278512] mpp_rkvdec2 fdc38100.rkvdec-core: min_width 512 [ 4.278516] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_info_count 20 [ 4.278519] mpp_rkvdec2 fdc38100.rkvdec-core: [136, 24576] [ 4.278521] mpp_rkvdec2 fdc38100.rkvdec-core: [137, 49152] [ 4.278524] mpp_rkvdec2 fdc38100.rkvdec-core: [141, 90112] [ 4.278527] mpp_rkvdec2 fdc38100.rkvdec-core: [140, 49152] [ 4.278530] mpp_rkvdec2 fdc38100.rkvdec-core: [139, 180224] [ 4.278532] mpp_rkvdec2 fdc38100.rkvdec-core: [133, 49152] [ 4.278535] mpp_rkvdec2 fdc38100.rkvdec-core: [134, 8192] [ 4.278537] mpp_rkvdec2 fdc38100.rkvdec-core: [135, 4352] [ 4.278540] mpp_rkvdec2 fdc38100.rkvdec-core: [138, 13056] [ 4.278542] mpp_rkvdec2 fdc38100.rkvdec-core: [142, 291584] [ 4.278576] mpp_rkvdec2 fdc38100.rkvdec-core: probing finish [ 4.278664] mpp_rkvdec2 fdc48100.rkvdec-core: Adding to iommu group 13 [ 4.278897] mpp_rkvdec2 fdc48100.rkvdec-core: rkvdec-core, probing start [ 4.279021] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found! [ 4.279024] rkvdec2_init:1022: No niu aclk reset resource define [ 4.279027] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found! [ 4.279030] rkvdec2_init:1025: No niu hclk reset resource define [ 4.279046] mpp_rkvdec2 fdc48100.rkvdec-core: Looking up vdec-supply from device tree [ 4.279051] mpp_rkvdec2 fdc48100.rkvdec-core: Looking up vdec-supply property in node /rkvdec-core@fdc48000 failed [ 4.279057] mpp_rkvdec2 fdc48100.rkvdec-core: no regulator, devfreq is disabled [ 4.279100] mpp_rkvdec2 fdc48100.rkvdec-core: core_mask=00020002 [ 4.279116] mpp_rkvdec2 fdc48100.rkvdec-core: attach ccu as core 1 [ 4.279295] mpp_rkvdec2 fdc48100.rkvdec-core: sram_start 0x00000000ff079000 [ 4.279298] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_iova 0x00000000ffe00000 [ 4.279300] mpp_rkvdec2 fdc48100.rkvdec-core: sram_size 487424 [ 4.279303] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_size 1048576 [ 4.279307] mpp_rkvdec2 fdc48100.rkvdec-core: min_width 512 [ 4.279311] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_info_count 20 [ 4.279314] mpp_rkvdec2 fdc48100.rkvdec-core: [136, 24576] [ 4.279316] mpp_rkvdec2 fdc48100.rkvdec-core: [137, 49152] [ 4.279319] mpp_rkvdec2 fdc48100.rkvdec-core: [141, 90112] [ 4.279322] mpp_rkvdec2 fdc48100.rkvdec-core: [140, 49152] [ 4.279324] mpp_rkvdec2 fdc48100.rkvdec-core: [139, 180224] [ 4.279327] mpp_rkvdec2 fdc48100.rkvdec-core: [133, 49152] [ 4.279330] mpp_rkvdec2 fdc48100.rkvdec-core: [134, 8192] [ 4.279332] mpp_rkvdec2 fdc48100.rkvdec-core: [135, 4352] [ 4.279335] mpp_rkvdec2 fdc48100.rkvdec-core: [138, 13056] [ 4.279337] mpp_rkvdec2 fdc48100.rkvdec-core: [142, 291584] [ 4.279367] mpp_rkvdec2 fdc48100.rkvdec-core: probing finish [ 4.279557] mpp_rkvenc2 rkvenc-ccu: probing start [ 4.279561] mpp_rkvenc2 rkvenc-ccu: probing finish [ 4.279676] mpp_rkvenc2 fdbd0000.rkvenc-core: Adding to iommu group 10 [ 4.279857] mpp_rkvenc2 fdbd0000.rkvenc-core: probing start [ 4.280010] mpp_rkvenc2 fdbd0000.rkvenc-core: Looking up venc-supply from device tree [ 4.280016] mpp_rkvenc2 fdbd0000.rkvenc-core: Looking up venc-supply property in node /rkvenc-core@fdbd0000 failed [ 4.280022] mpp_rkvenc2 fdbd0000.rkvenc-core: dev_pm_opp_set_regulators: no regulator (venc) found: -19 [ 4.280038] rkvenc_init:1814: failed to add venc devfreq [ 4.280066] mpp_rkvenc2 fdbd0000.rkvenc-core: attach ccu as core 0 [ 4.280213] mpp_rkvenc2 fdbd0000.rkvenc-core: probing finish [ 4.280298] mpp_rkvenc2 fdbe0000.rkvenc-core: Adding to iommu group 11 [ 4.280483] mpp_rkvenc2 fdbe0000.rkvenc-core: probing start [ 4.280616] mpp_rkvenc2 fdbe0000.rkvenc-core: Looking up venc-supply from device tree [ 4.280622] mpp_rkvenc2 fdbe0000.rkvenc-core: Looking up venc-supply property in node /rkvenc-core@fdbe0000 failed [ 4.280627] mpp_rkvenc2 fdbe0000.rkvenc-core: dev_pm_opp_set_regulators: no regulator (venc) found: -19 [ 4.280640] rkvenc_init:1814: failed to add venc devfreq [ 4.280690] mpp_rkvenc2 fdbe0000.rkvenc-core: attach ccu as core 1 [ 4.280840] mpp_rkvenc2 fdbe0000.rkvenc-core: probing finish [ 4.281084] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up av1-supply from device tree [ 4.281107] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up av1-supply property in node /power-management@fd8d8000/power-controller failed [ 4.281403] mpp_av1dec: Adding child /av1d@fdc70000 [ 4.281484] mpp_av1dec: register device av1d-master [ 4.281513] mpp_av1dec av1d-master: av1_iommu_of_xlate,784 [ 4.281532] av1_iommu_probe_device,736, consumer : av1d-master, supplier : fdca0000.iommu [ 4.281565] mpp_av1dec av1d-master: Adding to iommu group 18 [ 4.281802] mpp_av1dec av1d-master: probing start [ 4.282065] mpp_av1dec av1d-master: probing finish [ 4.282103] mpp_service mpp-srv: probe success [ 4.293264] dma-pl330 fea10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 4.293270] dma-pl330 fea10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 4.294308] dma-pl330 fea30000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 4.294314] dma-pl330 fea30000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 4.295290] dma-pl330 fed10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 4.295296] dma-pl330 fed10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 4.295792] rockchip-pvtm fda40000.pvtm: pvtm@0 probed [ 4.295856] rockchip-pvtm fda50000.pvtm: pvtm@1 probed [ 4.295913] rockchip-pvtm fda60000.pvtm: pvtm@2 probed [ 4.295972] rockchip-pvtm fdaf0000.pvtm: pvtm@3 probed [ 4.296027] rockchip-pvtm fdb30000.pvtm: pvtm@4 probed [ 4.296612] rockchip-system-monitor rockchip-system-monitor: system monitor probe [ 4.297460] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [ 4.298022] febc0000.serial: ttyS9 at MMIO 0xfebc0000 (irq = 101, base_baud = 1500000) is a 16550A [ 4.299317] random: crng init done [ 4.299406] led_vk2c21_init ============================================= [ 4.300390] rockchip-vop2 fdd90000.vop: Adding to iommu group 17 [ 4.308867] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x5, primary plane phy id: 0 [ 4.308874] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp1 assign plane mask: 0xa, primary plane phy id: 1 [ 4.308880] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x140, primary plane phy id: 6 [ 4.308886] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp3 assign plane mask: 0x280, primary plane phy id: 7 [ 4.308978] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart0-win0 as cursor plane for vp0 [ 4.309067] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart1-win0 as cursor plane for vp1 [ 4.309155] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart2-win0 as cursor plane for vp2 [ 4.309236] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart3-win0 as cursor plane for vp3 [ 4.309255] [drm] failed to init overlay plane Cluster0-win1 [ 4.309258] [drm] failed to init overlay plane Cluster1-win1 [ 4.309260] [drm] failed to init overlay plane Cluster2-win1 [ 4.309262] [drm] failed to init overlay plane Cluster3-win1 [ 4.320922] rockchip-drm display-subsystem: bound fdd90000.vop (ops 0xffff8000091b2620) [ 4.321891] dwhdmi-rockchip fde80000.hdmi: registered ddc I2C bus driver [ 4.322095] rockchip-drm display-subsystem: bound fde80000.hdmi (ops 0xffff8000091c0798) [ 4.322172] rockchip-drm display-subsystem: bound fde50000.dp (ops 0xffff8000091c3278) [ 4.322784] rockchip-drm display-subsystem: failed to parse loader memory [ 4.478540] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x2 [ 4.549122] dwhdmi-rockchip fde80000.hdmi: use tmds mode [ 4.549162] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] Update mode to 1920x1080p60, type: 11(if:800) for vp0 dclk: 148500000 [ 4.549328] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] dclk_out0 div: 0 dclk_core0 div: 2 [ 4.549346] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx_ropll_cmn_config bus_width:16a8c8 rate:1485000 [ 4.549624] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy pll locked! [ 4.549631] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] set dclk_vop0 to 148500000, get 148500000 [ 4.549654] dwhdmi-rockchip fde80000.hdmi: final tmdsclk = 148500000 [ 4.549683] dwhdmi-rockchip fde80000.hdmi: don't use dsc mode [ 4.549687] dwhdmi-rockchip fde80000.hdmi: dw hdmi qp use tmds mode [ 4.549692] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: bus_width:0x16a8c8,bit_rate:1485000 [ 4.549886] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy lane locked! [ 4.560741] rk-pcie fe190000.pcie: PCIe Link up, LTSSM is 0x30011 [ 4.560919] rk-pcie fe190000.pcie: PCI host bridge to bus 0004:40 [ 4.560930] pci_bus 0004:40: root bus resource [bus 40-4f] [ 4.560938] pci_bus 0004:40: root bus resource [??? 0xf4000000-0xf40fffff flags 0x0] [ 4.560948] pci_bus 0004:40: root bus resource [io 0x0000-0xfffff] (bus address [0xf4100000-0xf41fffff]) [ 4.560955] pci_bus 0004:40: root bus resource [mem 0xf4200000-0xf4ffffff] [ 4.560962] pci_bus 0004:40: root bus resource [mem 0xa00000000-0xa3fffffff pref] [ 4.561006] pci 0004:40:00.0: [1d87:3588] type 01 class 0x060400 [ 4.561034] pci 0004:40:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref] [ 4.561113] pci 0004:40:00.0: supports D1 D2 [ 4.561120] pci 0004:40:00.0: PME# supported from D0 D1 D3hot [ 4.573881] pci 0004:40:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 4.574166] pci 0004:41:00.0: [144d:a804] type 00 class 0x010802 [ 4.574266] pci 0004:41:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit] [ 4.575001] pci 0004:41:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x1 link at 0004:40:00.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link) [ 4.596376] pci_bus 0004:41: busn_res: [bus 41-4f] end is updated to 41 [ 4.596405] pci 0004:40:00.0: BAR 8: assigned [mem 0xf4200000-0xf42fffff] [ 4.596416] pci 0004:40:00.0: BAR 6: assigned [mem 0xf4300000-0xf430ffff pref] [ 4.596429] pci 0004:41:00.0: BAR 0: assigned [mem 0xf4200000-0xf4203fff 64bit] [ 4.596470] pci 0004:40:00.0: PCI bridge to [bus 41] [ 4.596479] pci 0004:40:00.0: bridge window [mem 0xf4200000-0xf42fffff] [ 4.599835] pcieport 0004:40:00.0: PME: Signaling with IRQ 125 [ 4.633071] Console: switching to colour frame buffer device 240x67 [ 4.796985] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device [ 4.798389] [drm] Initialized rockchip 3.0.0 20140818 for display-subsystem on minor 0 [ 4.813268] brd: module loaded [ 4.822436] loop: module loaded [ 4.823006] zram: Added device: zram0 [ 4.823372] lkdtm: No crash points registered, enable through debugfs [ 4.823629] system_heap: orders[0] = 6 [ 4.823636] system_heap: orders[1] = 4 [ 4.823641] system_heap: orders[2] = 0 [ 4.825814] nvme nvme0: pci function 0004:41:00.0 [ 4.825887] nvme 0004:41:00.0: enabling device (0000 -> 0002) [ 4.829471] rockchip-spi feb20000.spi: no high_speed pinctrl state [ 4.832993] rk806 spi2.0: chip id: RK806,ver:0x2, 0x1 [ 4.833223] rk806 spi2.0: ON: 0x80 OFF:0x80 [ 4.836488] rk806-regulator rk806-regulator.6.auto: Looking up vcc1-supply from device tree [ 4.836505] vdd_gpu_s0: supplied by vcc5v0_sys [ 4.836519] vcc5v0_sys: could not add device link regulator.8: -ENOENT [ 4.837442] vdd_gpu_s0: 550 <--> 950 mV at 750 mV, enabled [ 4.838225] rk806-regulator rk806-regulator.6.auto: Looking up vcc2-supply from device tree [ 4.838240] vdd_cpu_lit_s0: supplied by vcc5v0_sys [ 4.838252] vcc5v0_sys: could not add device link regulator.9: -ENOENT [ 4.838685] vdd_cpu_lit_s0: 550 <--> 950 mV at 750 mV, enabled [ 4.839703] rk806-regulator rk806-regulator.6.auto: Looking up vcc3-supply from device tree [ 4.839736] vdd_log_s0: supplied by vcc5v0_sys [ 4.839749] vcc5v0_sys: could not add device link regulator.10: -ENOENT [ 4.840137] vdd_log_s0: 675 <--> 750 mV at 750 mV, enabled [ 4.841087] rk806-regulator rk806-regulator.6.auto: Looking up vcc4-supply from device tree [ 4.841102] vdd_vdenc_s0: supplied by vcc5v0_sys [ 4.841114] vcc5v0_sys: could not add device link regulator.11: -ENOENT [ 4.841519] vdd_vdenc_s0: 550 <--> 950 mV at 750 mV, enabled [ 4.842538] rk806-regulator rk806-regulator.6.auto: Looking up vcc5-supply from device tree [ 4.842552] vdd_ddr_s0: supplied by vcc5v0_sys [ 4.842564] vcc5v0_sys: could not add device link regulator.12: -ENOENT [ 4.842945] vdd_ddr_s0: 675 <--> 900 mV at 850 mV, enabled [ 4.843404] rk806-regulator rk806-regulator.6.auto: Looking up vcc6-supply from device tree [ 4.843418] vdd2_ddr_s3: supplied by vcc5v0_sys [ 4.843430] vcc5v0_sys: could not add device link regulator.13: -ENOENT [ 4.843917] vdd2_ddr_s3: at 500 mV, enabled [ 4.844635] rk806-regulator rk806-regulator.6.auto: Looking up vcc7-supply from device tree [ 4.844650] vdd_2v0_pldo_s3: supplied by vcc5v0_sys [ 4.844663] vcc5v0_sys: could not add device link regulator.14: -ENOENT [ 4.845039] vdd_2v0_pldo_s3: 2000 mV, enabled [ 4.845759] rk806-regulator rk806-regulator.6.auto: Looking up vcc8-supply from device tree [ 4.845773] vcc_3v3_s3: supplied by vcc5v0_sys [ 4.845786] vcc5v0_sys: could not add device link regulator.15: -ENOENT [ 4.846160] vcc_3v3_s3: 3300 mV, enabled [ 4.846788] rk806-regulator rk806-regulator.6.auto: Looking up vcc9-supply from device tree [ 4.846803] vddq_ddr_s0: supplied by vcc5v0_sys [ 4.846815] vcc5v0_sys: could not add device link regulator.16: -ENOENT [ 4.847323] vddq_ddr_s0: at 500 mV, enabled [ 4.848049] rk806-regulator rk806-regulator.6.auto: Looking up vcc10-supply from device tree [ 4.848065] vcc_1v8_s3: supplied by vcc5v0_sys [ 4.848077] vcc5v0_sys: could not add device link regulator.17: -ENOENT [ 4.848470] vcc_1v8_s3: 1800 mV, enabled [ 4.849181] rk806-regulator rk806-regulator.6.auto: Looking up vcc13-supply from device tree [ 4.849309] vdd_0v75_s3: supplied by vcc_1v1_nldo_s3 [ 4.849323] vcc_1v1_nldo_s3: could not add device link regulator.18: -ENOENT [ 4.849736] vdd_0v75_s3: 750 mV, enabled [ 4.850513] rk806-regulator rk806-regulator.6.auto: Looking up vcc13-supply from device tree [ 4.850529] vdd_ddr_pll_s0: supplied by vcc_1v1_nldo_s3 [ 4.850542] vcc_1v1_nldo_s3: could not add device link regulator.19: -ENOENT [ 4.850923] vdd_ddr_pll_s0: 850 mV, enabled [ 4.851505] avdd_0v75_s0: Bringing 750000uV into 837500-837500uV [ 4.851733] avdd_0v75_s0: ramp_delay not set [ 4.851854] rk806-regulator rk806-regulator.6.auto: Looking up vcc13-supply from device tree [ 4.851870] avdd_0v75_s0: supplied by vcc_1v1_nldo_s3 [ 4.851882] vcc_1v1_nldo_s3: could not add device link regulator.20: -ENOENT [ 4.852266] avdd_0v75_s0: 837 mV, enabled [ 4.852954] rk806-regulator rk806-regulator.6.auto: Looking up vcc14-supply from device tree [ 4.852971] vdd_0v85_s0: supplied by vcc_1v1_nldo_s3 [ 4.852983] vcc_1v1_nldo_s3: could not add device link regulator.21: -ENOENT [ 4.853357] vdd_0v85_s0: 850 mV, enabled [ 4.854029] rk806-regulator rk806-regulator.6.auto: Looking up vcc14-supply from device tree [ 4.854069] vdd_0v75_s0: supplied by vcc_1v1_nldo_s3 [ 4.854082] vcc_1v1_nldo_s3: could not add device link regulator.22: -ENOENT [ 4.854484] vdd_0v75_s0: 750 mV, enabled [ 4.854691] nvme nvme0: 7/0/0 default/read/poll queues [ 4.855248] rk806-regulator rk806-regulator.6.auto: Looking up vcc11-supply from device tree [ 4.855334] avcc_1v8_s0: supplied by vdd_2v0_pldo_s3 [ 4.855347] vdd_2v0_pldo_s3: could not add device link regulator.23: -ENOENT [ 4.855852] avcc_1v8_s0: 1800 mV, enabled [ 4.856630] rk806-regulator rk806-regulator.6.auto: Looking up vcc11-supply from device tree [ 4.856642] vcc_1v8_s0: supplied by vdd_2v0_pldo_s3 [ 4.856648] vdd_2v0_pldo_s3: could not add device link regulator.24: -ENOENT [ 4.856980] vcc_1v8_s0: 1800 mV, enabled [ 4.857360] rk806-regulator rk806-regulator.6.auto: Looking up vcc11-supply from device tree [ 4.857381] avdd_1v2_s0: supplied by vdd_2v0_pldo_s3 [ 4.857387] vdd_2v0_pldo_s3: could not add device link regulator.25: -ENOENT [ 4.857689] avdd_1v2_s0: 1200 mV, enabled [ 4.858053] rk806-regulator rk806-regulator.6.auto: Looking up vcc12-supply from device tree [ 4.858061] vcc_3v3_s0: supplied by vcc5v0_sys [ 4.858068] vcc5v0_sys: could not add device link regulator.26: -ENOENT [ 4.858299] vcc_3v3_s0: 3300 mV, enabled [ 4.858665] rk806-regulator rk806-regulator.6.auto: Looking up vcc12-supply from device tree [ 4.858671] vccio_sd_s0: supplied by vcc5v0_sys [ 4.858676] vcc5v0_sys: could not add device link regulator.27: -ENOENT [ 4.858908] vccio_sd_s0: 1800 <--> 3300 mV at 3300 mV, enabled [ 4.859282] rk806-regulator rk806-regulator.6.auto: Looking up vcca-supply from device tree [ 4.859288] pldo6_s3: supplied by vcc5v0_sys [ 4.859293] vcc5v0_sys: could not add device link regulator.28: -ENOENT [ 4.859518] pldo6_s3: 1800 mV, enabled [ 4.859883] rk806 spi2.0: no sleep-setting state [ 4.859888] rk806 spi2.0: no reset-setting pinctrl state [ 4.859891] rk806 spi2.0: no dvs-setting pinctrl state [ 4.861477] rockchip-spi feb20000.spi: register misc device rkspi-dev2 [ 4.861482] rockchip-spi feb20000.spi: probed, poll=0, rsd=0 [ 4.863121] spi-nor spi5.0: XM25QU128C (16384 Kbytes) read_data x4 [ 4.863138] 1 fixed-partitions partitions found on MTD device sfc_nor [ 4.863141] Creating 1 MTD partitions on "sfc_nor": [ 4.863147] 0x000000000000-0x000001000000 : "loader" [ 4.866440] nvme0n1: p1 p2 [ 4.868138] rk_gmac-dwmac fe1c0000.ethernet: IRQ eth_lpi not found [ 4.868441] rk_gmac-dwmac fe1c0000.ethernet: Looking up phy-supply from device tree [ 4.868470] rk_gmac-dwmac fe1c0000.ethernet: Looking up phy-supply property in node /ethernet@fe1c0000 failed [ 4.868499] rk_gmac-dwmac fe1c0000.ethernet: no regulator found [ 4.868509] rk_gmac-dwmac fe1c0000.ethernet: clock input or output? (output). [ 4.868518] rk_gmac-dwmac fe1c0000.ethernet: TX delay(0x42). [ 4.868527] rk_gmac-dwmac fe1c0000.ethernet: Can not read property: rx_delay. [ 4.868534] rk_gmac-dwmac fe1c0000.ethernet: set rx_delay to 0xffffffff [ 4.868551] rk_gmac-dwmac fe1c0000.ethernet: integrated PHY? (no). [ 4.868563] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_rx [ 4.868575] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_tx [ 4.868616] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock clk_mac_speed [ 4.868854] rk_gmac-dwmac fe1c0000.ethernet: init for RGMII_RXID [ 4.868949] rk_gmac-dwmac fe1c0000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 4.868954] rk_gmac-dwmac fe1c0000.ethernet: DWMAC4/5 [ 4.868959] rk_gmac-dwmac fe1c0000.ethernet: DMA HW capability register supported [ 4.868962] rk_gmac-dwmac fe1c0000.ethernet: RX Checksum Offload Engine supported [ 4.868965] rk_gmac-dwmac fe1c0000.ethernet: TX Checksum insertion supported [ 4.868968] rk_gmac-dwmac fe1c0000.ethernet: Wake-Up On Lan supported [ 4.869000] rk_gmac-dwmac fe1c0000.ethernet: TSO supported [ 4.869003] rk_gmac-dwmac fe1c0000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 4.869008] rk_gmac-dwmac fe1c0000.ethernet: Enabled Flow TC (entries=2) [ 4.869011] rk_gmac-dwmac fe1c0000.ethernet: TSO feature enabled [ 4.869015] rk_gmac-dwmac fe1c0000.ethernet: Using 32 bits DMA width [ 5.009911] usbcore: registered new interface driver rndis_wlan [ 5.009934] usbcore: registered new interface driver asix [ 5.009950] usbcore: registered new interface driver cdc_ether [ 5.009965] usbcore: registered new interface driver rndis_host [ 5.009996] usbcore: registered new interface driver cdc_ncm [ 5.014689] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up usb-supply from device tree [ 5.014719] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up usb-supply property in node /power-management@fd8d8000/power-controller failed [ 5.016553] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 5.016563] ehci-pci: EHCI PCI platform driver [ 5.016591] ehci-platform: EHCI generic platform driver [ 5.018598] ehci-platform fc800000.usb: EHCI Host Controller [ 5.018612] ehci-platform fc800000.usb: new USB bus registered, assigned bus number 1 [ 5.018677] ehci-platform fc800000.usb: irq 20, io mem 0xfc800000 [ 5.030720] ehci-platform fc800000.usb: USB 2.0 started, EHCI 1.00 [ 5.030840] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 5.030845] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.030848] usb usb1: Product: EHCI Host Controller [ 5.030852] usb usb1: Manufacturer: Linux 5.10.160-rk35xx ehci_hcd [ 5.030855] usb usb1: SerialNumber: fc800000.usb [ 5.031170] hub 1-0:1.0: USB hub found [ 5.031187] hub 1-0:1.0: 1 port detected [ 5.033604] ehci-platform fc880000.usb: EHCI Host Controller [ 5.033615] ehci-platform fc880000.usb: new USB bus registered, assigned bus number 2 [ 5.033678] ehci-platform fc880000.usb: irq 22, io mem 0xfc880000 [ 5.044052] ehci-platform fc880000.usb: USB 2.0 started, EHCI 1.00 [ 5.044167] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 5.044172] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.044175] usb usb2: Product: EHCI Host Controller [ 5.044179] usb usb2: Manufacturer: Linux 5.10.160-rk35xx ehci_hcd [ 5.044182] usb usb2: SerialNumber: fc880000.usb [ 5.044472] hub 2-0:1.0: USB hub found [ 5.044489] hub 2-0:1.0: 1 port detected [ 5.044907] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 5.044919] ohci-platform: OHCI generic platform driver [ 5.045088] ohci-platform fc840000.usb: Generic Platform OHCI controller [ 5.045098] ohci-platform fc840000.usb: new USB bus registered, assigned bus number 3 [ 5.045148] ohci-platform fc840000.usb: irq 21, io mem 0xfc840000 [ 5.104817] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10 [ 5.104822] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.104826] usb usb3: Product: Generic Platform OHCI controller [ 5.104829] usb usb3: Manufacturer: Linux 5.10.160-rk35xx ohci_hcd [ 5.104832] usb usb3: SerialNumber: fc840000.usb [ 5.105100] hub 3-0:1.0: USB hub found [ 5.105118] hub 3-0:1.0: 1 port detected [ 5.105413] ohci-platform fc8c0000.usb: Generic Platform OHCI controller [ 5.105422] ohci-platform fc8c0000.usb: new USB bus registered, assigned bus number 4 [ 5.105471] ohci-platform fc8c0000.usb: irq 23, io mem 0xfc8c0000 [ 5.164812] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10 [ 5.164817] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.164820] usb usb4: Product: Generic Platform OHCI controller [ 5.164823] usb usb4: Manufacturer: Linux 5.10.160-rk35xx ohci_hcd [ 5.164827] usb usb4: SerialNumber: fc8c0000.usb [ 5.165096] hub 4-0:1.0: USB hub found [ 5.165115] hub 4-0:1.0: 1 port detected [ 5.165712] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 5.165722] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 5 [ 5.165801] xhci-hcd xhci-hcd.7.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000200002010010 [ 5.165828] xhci-hcd xhci-hcd.7.auto: irq 139, io mem 0xfcd00000 [ 5.165991] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 5.165996] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.165999] usb usb5: Product: xHCI Host Controller [ 5.166003] usb usb5: Manufacturer: Linux 5.10.160-rk35xx xhci-hcd [ 5.166006] usb usb5: SerialNumber: xhci-hcd.7.auto [ 5.166267] hub 5-0:1.0: USB hub found [ 5.166288] hub 5-0:1.0: 1 port detected [ 5.166441] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 5.166448] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 6 [ 5.166455] xhci-hcd xhci-hcd.7.auto: Host supports USB 3.0 SuperSpeed [ 5.166491] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM. [ 5.166556] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 [ 5.166560] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.166563] usb usb6: Product: xHCI Host Controller [ 5.166566] usb usb6: Manufacturer: Linux 5.10.160-rk35xx xhci-hcd [ 5.166570] usb usb6: SerialNumber: xhci-hcd.7.auto [ 5.166824] hub 6-0:1.0: USB hub found [ 5.166841] hub 6-0:1.0: 1 port detected [ 5.167056] usbcore: registered new interface driver cdc_acm [ 5.167059] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 5.167158] usbcore: registered new interface driver uas [ 5.167215] usbcore: registered new interface driver usb-storage [ 5.167850] Error: Driver 'Goodix-TS' is already registered, aborting... [ 5.167888] usbcore: registered new interface driver usbtouchscreen [ 5.168974] input: rk805 pwrkey as /devices/platform/feb20000.spi/spi_master/spi2/spi2.0/rk805-pwrkey.5.auto/input/input0 [ 5.169307] i2c /dev entries driver [ 5.173001] rk860-regulator 0-0042: Looking up vin-supply from device tree [ 5.173009] vdd_cpu_big0_s0: supplied by vcc5v0_sys [ 5.173015] vcc5v0_sys: could not add device link regulator.29: -ENOENT [ 5.177113] vdd_cpu_big0_s0: 550 <--> 1050 mV at 800 mV, enabled [ 5.181650] rk860-regulator 0-0043: Looking up vin-supply from device tree [ 5.181656] vdd_cpu_big1_s0: supplied by vcc5v0_sys [ 5.181661] vcc5v0_sys: could not add device link regulator.30: -ENOENT [ 5.185763] vdd_cpu_big1_s0: 550 <--> 1050 mV at 800 mV, enabled [ 5.188038] Goodix-TS 2-0014: Looking up AVDD28-supply from device tree [ 5.188047] Goodix-TS 2-0014: Looking up AVDD28-supply property in node /i2c@feaa0000/touchscreen@14 failed [ 5.188059] Goodix-TS 2-0014: supply AVDD28 not found, using dummy regulator [ 5.188124] Goodix-TS 2-0014: Looking up VDDIO-supply from device tree [ 5.188131] Goodix-TS 2-0014: Looking up VDDIO-supply property in node /i2c@feaa0000/touchscreen@14 failed [ 5.188140] Goodix-TS 2-0014: supply VDDIO not found, using dummy regulator [ 5.280885] Goodix-TS 2-0014: i2c test failed attempt 1: -6 [ 5.307559] Goodix-TS 2-0014: i2c test failed attempt 2: -6 [ 5.334076] Goodix-TS 2-0014: I2C communication failure: -6 [ 5.337830] rk860-regulator 2-0042: Looking up vin-supply from device tree [ 5.337846] vdd_npu_s0: supplied by vcc5v0_sys [ 5.337859] vcc5v0_sys: could not add device link regulator.31: -ENOENT [ 5.342090] vdd_npu_s0: 550 <--> 950 mV at 800 mV, enabled [ 5.347449] typec_fusb302 6-0022: Looking up vbus-supply from device tree [ 5.374826] rtc-hym8563 6-0051: rtc information is valid [ 5.380155] rtc-hym8563 6-0051: registered as rtc0 [ 5.381168] rtc-hym8563 6-0051: setting system clock to 2023-08-07T18:11:49 UTC (1691431909) [ 5.383769] Goodix-TS 7-0014: Looking up AVDD28-supply from device tree [ 5.383779] Goodix-TS 7-0014: Looking up AVDD28-supply property in node /i2c@fec90000/touchscreen@14 failed [ 5.383791] Goodix-TS 7-0014: supply AVDD28 not found, using dummy regulator [ 5.383847] Goodix-TS 7-0014: Looking up VDDIO-supply from device tree [ 5.383854] Goodix-TS 7-0014: Looking up VDDIO-supply property in node /i2c@fec90000/touchscreen@14 failed [ 5.383863] Goodix-TS 7-0014: supply VDDIO not found, using dummy regulator [ 5.474196] Goodix-TS 7-0014: i2c test failed attempt 1: -6 [ 5.500856] Goodix-TS 7-0014: i2c test failed attempt 2: -6 [ 5.527378] Goodix-TS 7-0014: I2C communication failure: -6 [ 5.528335] rkcifhw fdce0000.rkcif: Adding to iommu group 16 [ 5.528700] rkcifhw fdce0000.rkcif: No reserved memory region assign to CIF [ 5.529853] rkisp_hw fdcb0000.rkisp: Adding to iommu group 14 [ 5.529967] rkisp_hw fdcb0000.rkisp: is_thunderboot: 0 [ 5.529971] rkisp_hw fdcb0000.rkisp: max input:0x0@0fps [ 5.529975] rkisp_hw fdcb0000.rkisp: Missing rockchip,grf property [ 5.530079] rkisp_hw fdcb0000.rkisp: no find phandle sram [ 5.530150] rkisp_hw fdcc0000.rkisp: Adding to iommu group 15 [ 5.530304] rkisp_hw fdcc0000.rkisp: is_thunderboot: 0 [ 5.530308] rkisp_hw fdcc0000.rkisp: max input:0x0@0fps [ 5.530312] rkisp_hw fdcc0000.rkisp: Missing rockchip,grf property [ 5.530405] rkisp_hw fdcc0000.rkisp: no find phandle sram [ 5.531359] usbcore: registered new interface driver uvcvideo [ 5.531362] USB Video Class driver (1.1.1) [ 5.532807] cpu cpu0: Looking up cpu-supply from device tree [ 5.533337] cpu cpu0: bin=0 [ 5.533512] cpu cpu0: leakage=8 [ 5.533537] cpu cpu0: Looking up cpu-supply from device tree [ 5.534988] cpu cpu0: pvtm=1381 [ 5.535134] cpu cpu0: pvtm-volt-sel=0 [ 5.535167] cpu cpu0: Looking up cpu-supply from device tree [ 5.535295] cpu cpu0: Looking up mem-supply from device tree [ 5.535466] cpu cpu4: Looking up cpu-supply from device tree [ 5.537178] cpu cpu4: bin=0 [ 5.537349] cpu cpu4: leakage=6 [ 5.537381] cpu cpu4: Looking up cpu-supply from device tree [ 5.543918] cpu cpu4: pvtm=1588 [ 5.547913] cpu cpu4: pvtm-volt-sel=0 [ 5.547955] cpu cpu4: Looking up cpu-supply from device tree [ 5.548457] cpu cpu4: Looking up mem-supply from device tree [ 5.549008] cpu cpu6: Looking up cpu-supply from device tree [ 5.550696] cpu cpu6: bin=0 [ 5.550880] cpu cpu6: leakage=6 [ 5.550899] cpu cpu6: Looking up cpu-supply from device tree [ 5.557371] cpu cpu6: pvtm=1590 [ 5.561337] cpu cpu6: pvtm-volt-sel=0 [ 5.561378] cpu cpu6: Looking up cpu-supply from device tree [ 5.561881] cpu cpu6: Looking up mem-supply from device tree [ 5.563069] cpu cpu0: avs=0 [ 5.563859] cpu cpu4: avs=0 [ 5.564653] cpu cpu6: avs=0 [ 5.564821] cpu cpu0: EM: OPP:816000 is inefficient [ 5.564824] cpu cpu0: EM: OPP:600000 is inefficient [ 5.564917] cpu cpu0: EM: created perf domain [ 5.564956] cpu cpu0: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=1608000000 h_table=0 [ 5.565524] cpu cpu4: EM: OPP:816000 is inefficient [ 5.565528] cpu cpu4: EM: OPP:600000 is inefficient [ 5.565651] cpu cpu4: EM: created perf domain [ 5.565681] cpu cpu4: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0 [ 5.574229] cpu cpu6: EM: OPP:816000 is inefficient [ 5.574234] cpu cpu6: EM: OPP:600000 is inefficient [ 5.574362] cpu cpu6: EM: created perf domain [ 5.574769] cpu cpu6: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0 [ 5.584115] usb 3-1: new full-speed USB device number 2 using ohci-platform [ 5.591043] sdhci: Secure Digital Host Controller Interface driver [ 5.591051] sdhci: Copyright(c) Pierre Ossman [ 5.591057] Synopsys Designware Multimedia Card Interface Driver [ 5.592307] sdhci-pltfm: SDHCI platform and OF driver helper [ 5.596141] ledtrig-cpu: registered to indicate activity on CPUs [ 5.596196] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active. [ 5.596281] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 5.597424] cryptodev: driver 1.12 loaded. [ 5.597471] hid: raw HID events driver (C) Jiri Kosina [ 5.597694] usbcore: registered new interface driver usbhid [ 5.597699] usbhid: USB HID core driver [ 5.597955] ashmem: initialized [ 5.602488] rockchip-saradc fec10000.saradc: Looking up vref-supply from device tree [ 5.603921] optee: probing for conduit method. [ 5.603928] optee: api uid mismatch [ 5.603941] optee: probe of firmware:optee failed with error -22 [ 5.604627] usbcore: registered new interface driver snd-usb-audio [ 5.609774] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up audio-supply from device tree [ 5.609803] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up audio-supply property in node /power-management@fd8d8000/power-controller failed [ 5.612616] debugfs: File 'Capture' in directory 'dapm' already present! [ 5.613656] input: rockchip-dp0 rockchip-dp0 as /devices/platform/dp0-sound/sound/card0/input1 [ 5.614869] input: rockchip-hdmi0 rockchip-hdmi0 as /devices/platform/hdmi0-sound/sound/card1/input2 [ 5.615828] input: headset-keys as /devices/platform/es8388-sound/input/input3 [ 5.626102] ES8323 6-0010: ASoC: error at soc_component_write_no_lock on ES8323.6-0010: -5 [ 5.679496] input: rockchip-es8388 Headset as /devices/platform/es8388-sound/sound/card2/input4 [ 5.680763] Initializing XFRM netlink socket [ 5.680779] NET: Registered protocol family 17 [ 5.681219] [BT_RFKILL]: Enter rfkill_rk_init [ 5.681223] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 5.681629] Key type dns_resolver registered [ 5.683090] registered taskstats version 1 [ 5.683097] Loading compiled-in X.509 certificates [ 5.683887] Btrfs loaded, crc32c=crc32c-generic [ 5.684008] pstore: Using crash dump compression: deflate [ 5.684275] rga3_core0 fdb60000.rga: Adding to iommu group 2 [ 5.684462] rga: rga3_core0, irq = 35, match scheduler [ 5.685069] rga: rga3_core0 hardware loaded successfully, hw_version:3.0.76831. [ 5.685087] rga: rga3_core0 probe successfully [ 5.685384] rga3_core1 fdb70000.rga: Adding to iommu group 3 [ 5.685566] rga: rga3_core1, irq = 36, match scheduler [ 5.686196] rga: rga3_core1 hardware loaded successfully, hw_version:3.0.76831. [ 5.686244] rga: rga3_core1 probe successfully [ 5.686582] rga: rga2, irq = 37, match scheduler [ 5.687172] rga: rga2 hardware loaded successfully, hw_version:3.2.63318. [ 5.687181] rga: rga2 probe successfully [ 5.687399] rga_iommu: IOMMU binding successfully, default mapping core[0x1] [ 5.687652] rga: Module initialized. v1.2.25 [ 5.736209] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up gpu-supply from device tree [ 5.736308] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up gpu-supply property in node /power-management@fd8d8000/power-controller failed [ 5.736521] reg-fixed-voltage combophy-avdd0v85: Looking up vin-supply from device tree [ 5.736527] mali fb000000.gpu: Kernel DDK version g17p0-01eac0 [ 5.736703] combophy_avdd0v85: supplied by vdd_0v85_s0 [ 5.736719] vdd_0v85_s0: could not add device link regulator.32: -ENOENT [ 5.736826] mali fb000000.gpu: Looking up mali-supply from device tree [ 5.737080] mali fb000000.gpu: Looking up mem-supply from device tree [ 5.737149] combophy_avdd0v85: 850 mV, enabled [ 5.737264] mali fb000000.gpu: Looking up mali-supply from device tree [ 5.737297] vdd_gpu_s0: could not add device link fb000000.gpu: -EEXIST [ 5.737305] vdd_gpu_s0: Failed to create debugfs directory [ 5.737316] mali fb000000.gpu: Looking up mem-supply from device tree [ 5.737342] vdd_gpu_s0: could not add device link fb000000.gpu: -EEXIST [ 5.737350] vdd_gpu_s0: Failed to create debugfs directory [ 5.737508] reg-fixed-voltage combophy-avdd0v85: combophy_avdd0v85 supplying 850000uV [ 5.737596] mali fb000000.gpu: Looking up mali-supply from device tree [ 5.737630] vdd_gpu_s0: could not add device link fb000000.gpu: -EEXIST [ 5.737638] vdd_gpu_s0: Failed to create debugfs directory [ 5.737857] reg-fixed-voltage combophy-avdd1v8: Looking up vin-supply from device tree [ 5.737967] combophy_avdd1v8: supplied by avcc_1v8_s0 [ 5.737976] mali fb000000.gpu: bin=0 [ 5.737990] avcc_1v8_s0: could not add device link regulator.33: -ENOENT [ 5.738175] mali fb000000.gpu: leakage=13 [ 5.738225] mali fb000000.gpu: Looking up mali-supply from device tree [ 5.738256] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present! [ 5.738789] combophy_avdd1v8: 1800 mV, enabled [ 5.739078] reg-fixed-voltage combophy-avdd1v8: combophy_avdd1v8 supplying 1800000uV [ 5.739324] vcc_3v3_sd_s0: 3300 mV, disabled [ 5.739545] reg-fixed-voltage vcc-3v3-sd-s0: Looking up vin-supply from device tree [ 5.739565] vcc_3v3_sd_s0: supplied by vcc_3v3_s3 [ 5.739952] reg-fixed-voltage vcc-3v3-sd-s0: vcc_3v3_sd_s0 supplying 3300000uV [ 5.740602] mali fb000000.gpu: pvtm=847 [ 5.741093] mali fb000000.gpu: pvtm-volt-sel=2 [ 5.741223] rockchip-dmc dmc: Looking up center-supply from device tree [ 5.741935] rockchip-dmc dmc: Looking up mem-supply from device tree [ 5.742679] rockchip-dmc dmc: Looking up center-supply from device tree [ 5.742716] vdd_ddr_s0: could not add device link dmc: -EEXIST [ 5.742724] vdd_ddr_s0: Failed to create debugfs directory [ 5.742782] mali fb000000.gpu: avs=0 [ 5.743105] rockchip-dmc dmc: Looking up mem-supply from device tree [ 5.743146] vdd_log_s0: could not add device link dmc: -EEXIST [ 5.743153] vdd_log_s0: Failed to create debugfs directory [ 5.743368] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 143; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available. [ 5.743830] rockchip-dmc dmc: leakage=30 [ 5.743852] rockchip-dmc dmc: leakage-volt-sel=0 [ 5.744524] mali fb000000.gpu: GPU hardware issue table may need updating: r0p0 status 5 is unknown; treating as r0p0 status 0 [ 5.744538] mali fb000000.gpu: GPU identified as 0x7 arch 10.8.6 r0p0 status 0 [ 5.744628] mali fb000000.gpu: No priority control manager is configured [ 5.744781] rockchip-dmc dmc: avs=0 [ 5.744807] rockchip-dmc dmc: current ATF version 0x100 [ 5.744977] rockchip-dmc dmc: normal_rate = 1560000000 [ 5.744989] rockchip-dmc dmc: reboot_rate = 2112000000 [ 5.745000] rockchip-dmc dmc: suspend_rate = 528000000 [ 5.745010] rockchip-dmc dmc: video_4k_rate = 1560000000 [ 5.745020] mali fb000000.gpu: No memory group manager is configured [ 5.745025] rockchip-dmc dmc: video_4k_10b_rate = 1560000000 [ 5.745034] rockchip-dmc dmc: video_svep_rate = 1560000000 [ 5.745044] rockchip-dmc dmc: boost_rate = 2112000000 [ 5.745054] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 2112000000 [ 5.745064] rockchip-dmc dmc: performance_rate = 2112000000 [ 5.745077] mali fb000000.gpu: Protected memory allocator not available [ 5.745081] rockchip-dmc dmc: hdmirx_rate = 2112000000 [ 5.745098] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate [ 5.745107] rockchip-dmc dmc: failed to get vop pn to msch rl [ 5.745334] rockchip-dmc dmc: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0 [ 5.746053] rockchip-dmc dmc: could not find power_model node [ 5.746201] mali fb000000.gpu: Capping CSF_FIRMWARE_TIMEOUT to CSF_FIRMWARE_PING_TIMEOUT [ 5.747235] mali fb000000.gpu: Couldn't find power_model DT node matching 'arm,mali-simple-power-model' [ 5.747246] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.static-coefficient = 1*[0] [ 5.747558] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.dynamic-coefficient = 1*[0] [ 5.747833] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.ts = 4*[0] [ 5.748089] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.thermal-zone = '' [ 5.751916] mali fb000000.gpu: Using configured power model mali-lodx-power-model, and fallback mali-simple-power-model [ 5.752077] input: adc-keys as /devices/platform/adc-keys/input/input5 [ 5.752104] mali fb000000.gpu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0 [ 5.754574] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode. [ 5.754623] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller. [ 5.754634] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a [ 5.754677] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 90,32 bit host data width,256 deep fifo [ 5.754757] dwmmc_rockchip fe2c0000.mmc: Looking up vmmc-supply from device tree [ 5.754967] dwmmc_rockchip fe2c0000.mmc: Looking up vqmmc-supply from device tree [ 5.755999] mali fb000000.gpu: Probed as mali0 [ 5.757113] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up sdio-supply from device tree [ 5.757145] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up sdio-supply property in node /power-management@fd8d8000/power-controller failed [ 5.757179] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up pcie-supply from device tree [ 5.757201] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up pcie-supply property in node /power-management@fd8d8000/power-controller failed [ 5.757233] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu-supply from device tree [ 5.757254] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu-supply property in node /power-management@fd8d8000/power-controller failed [ 5.758424] RKNPU fdab0000.npu: Adding to iommu group 0 [ 5.758545] RKNPU fdab0000.npu: RKNPU: rknpu iommu is enabled, using iommu mode [ 5.758627] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 5.759279] RKNPU fdab0000.npu: Looking up mem-supply from device tree [ 5.759897] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff] [ 5.759917] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff] [ 5.759928] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff] [ 5.760581] [drm] Initialized rknpu 0.8.5 20230202 for fdab0000.npu on minor 1 [ 5.760911] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up nputop-supply from device tree [ 5.760936] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up nputop-supply property in node /power-management@fd8d8000/power-controller failed [ 5.761007] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu1-supply from device tree [ 5.761029] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu1-supply property in node /power-management@fd8d8000/power-controller failed [ 5.761086] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu2-supply from device tree [ 5.761107] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu2-supply property in node /power-management@fd8d8000/power-controller failed [ 5.761245] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 5.761265] vdd_npu_s0: could not add device link fdab0000.npu: -EEXIST [ 5.761268] vdd_npu_s0: Failed to create debugfs directory [ 5.761874] RKNPU fdab0000.npu: Looking up mem-supply from device tree [ 5.761912] vdd_npu_s0: could not add device link fdab0000.npu: -EEXIST [ 5.761916] vdd_npu_s0: Failed to create debugfs directory [ 5.762665] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 5.762698] vdd_npu_s0: could not add device link fdab0000.npu: -EEXIST [ 5.762701] vdd_npu_s0: Failed to create debugfs directory [ 5.764720] RKNPU fdab0000.npu: RKNPU: bin=0 [ 5.764895] RKNPU fdab0000.npu: leakage=7 [ 5.764930] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 5.764960] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present! [ 5.771478] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 5.772418] RKNPU fdab0000.npu: pvtm=846 [ 5.777763] RKNPU fdab0000.npu: pvtm-volt-sel=2 [ 5.778657] RKNPU fdab0000.npu: avs=0 [ 5.778857] RKNPU fdab0000.npu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0 [ 5.790759] RKNPU fdab0000.npu: failed to find power_model node [ 5.790770] RKNPU fdab0000.npu: RKNPU: failed to initialize power model [ 5.790775] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient [ 5.792421] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 5.800470] usb 3-1: New USB device found, idVendor=046d, idProduct=c539, bcdDevice=39.06 [ 5.800480] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 5.800485] usb 3-1: Product: USB Receiver [ 5.800490] usb 3-1: Manufacturer: Logitech [ 5.804559] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 5.809310] input: Logitech USB Receiver as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.0/0003:046D:C539.0001/input/input6 [ 5.810403] rockchip-pm rockchip-suspend: not set pwm-regulator-config [ 5.810430] rockchip-suspend not set sleep-mode-config for mem-lite [ 5.810437] rockchip-suspend not set wakeup-config for mem-lite [ 5.810449] rockchip-suspend not set sleep-mode-config for mem-ultra [ 5.810455] rockchip-suspend not set wakeup-config for mem-ultra [ 5.812315] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 406; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '13:36:29', on 'Jul 6 2023'. [ 5.812856] Mali: [ 5.812862] Mali device driver loaded [ 5.812871] ALSA device list: [ 5.812878] #0: rockchip-dp0 [ 5.812884] #1: rockchip-hdmi0 [ 5.812889] #2: rockchip-es8388 [ 5.821229] Freeing unused kernel memory: 6976K [ 5.857677] Run /init as init process [ 5.857699] with arguments: [ 5.857714] /init [ 5.857727] splash [ 5.857739] with environment: [ 5.857752] HOME=/ [ 5.857764] TERM=linux [ 5.857777] ubootpart= [ 5.857791] cgroup_enable=memory [ 5.857802] cgroup_memory=1 [ 5.865896] hid-generic 0003:046D:C539.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-fc840000.usb-1/input0 [ 5.871748] input: Logitech USB Receiver Mouse as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input7 [ 5.935390] input: Logitech USB Receiver Consumer Control as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input8 [ 5.935887] input: Logitech USB Receiver System Control as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input9 [ 5.936955] hid-generic 0003:046D:C539.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-fc840000.usb-1/input1 [ 5.942581] hid-generic 0003:046D:C539.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-fc840000.usb-1/input2 [ 6.921851] EXT4-fs (nvme0n1p2): mounted filesystem with writeback data mode. Opts: (null) [ 7.157090] NET: Registered protocol family 10 [ 7.158635] Segment Routing with IPv6 [ 7.181090] systemd[1]: systemd 249.11-0ubuntu3.9 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified) [ 7.185113] systemd[1]: Detected architecture arm64. [ 7.188151] systemd[1]: Hostname set to . [ 7.472922] systemd[1]: Queued start job for default target Graphical Interface. [ 7.474858] systemd[1]: Created slice Slice /system/modprobe. [ 7.475590] systemd[1]: Created slice Slice /system/serial-getty. [ 7.476220] systemd[1]: Created slice Slice /system/systemd-fsck. [ 7.476612] systemd[1]: Created slice User and Session Slice. [ 7.476778] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 7.477158] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 7.477321] systemd[1]: Reached target User and Group Name Lookups. [ 7.477501] systemd[1]: Reached target Slice Units. [ 7.477562] systemd[1]: Reached target Swaps. [ 7.477603] systemd[1]: Reached target System Time Set. [ 7.477692] systemd[1]: Reached target Local Verity Protected Volumes. [ 7.486086] systemd[1]: Listening on RPCbind Server Activation Socket. [ 7.486377] systemd[1]: Listening on Syslog Socket. [ 7.486551] systemd[1]: Listening on fsck to fsckd communication Socket. [ 7.486653] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 7.486945] systemd[1]: Listening on Journal Audit Socket. [ 7.487088] systemd[1]: Listening on Journal Socket (/dev/log). [ 7.487292] systemd[1]: Listening on Journal Socket. [ 7.488262] systemd[1]: Listening on udev Control Socket. [ 7.488438] systemd[1]: Listening on udev Kernel Socket. [ 7.489565] systemd[1]: Mounting Huge Pages File System... [ 7.490828] systemd[1]: Mounting POSIX Message Queue File System... [ 7.492408] systemd[1]: Mounting Kernel Debug File System... [ 7.494283] systemd[1]: Mounting Kernel Trace File System... [ 7.494674] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped. [ 7.496820] systemd[1]: Starting Restore / save the current clock... [ 7.498858] systemd[1]: Starting Set the console keyboard layout... [ 7.501050] systemd[1]: Starting Create List of Static Device Nodes... [ 7.503005] systemd[1]: Starting Load Kernel Module chromeos_pstore... [ 7.505074] systemd[1]: Starting Load Kernel Module configfs... [ 7.507127] systemd[1]: Starting Load Kernel Module drm... [ 7.509398] systemd[1]: Starting Load Kernel Module efi_pstore... [ 7.511542] systemd[1]: Starting Load Kernel Module fuse... [ 7.513470] systemd[1]: Starting Load Kernel Module pstore_blk... [ 7.515541] systemd[1]: Starting Load Kernel Module pstore_zone... [ 7.517238] fuse: init (API version 7.32) [ 7.517245] systemd[1]: Starting Load Kernel Module ramoops... [ 7.517660] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 7.520343] systemd[1]: Starting Load Kernel Modules... [ 7.522135] systemd[1]: Starting Remount Root and Kernel File Systems... [ 7.523797] systemd[1]: Starting Coldplug All udev Devices... [ 7.527209] systemd[1]: Mounted Huge Pages File System. [ 7.527863] systemd[1]: Mounted POSIX Message Queue File System. [ 7.528191] systemd[1]: Mounted Kernel Debug File System. [ 7.528424] systemd[1]: Mounted Kernel Trace File System. [ 7.528991] systemd[1]: Finished Restore / save the current clock. [ 7.529702] systemd[1]: Finished Create List of Static Device Nodes. [ 7.530161] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully. [ 7.530519] systemd[1]: Finished Load Kernel Module chromeos_pstore. [ 7.531009] systemd[1]: modprobe@configfs.service: Deactivated successfully. [ 7.531412] systemd[1]: Finished Load Kernel Module configfs. [ 7.531882] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 7.532230] systemd[1]: Finished Load Kernel Module drm. [ 7.532647] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [ 7.532977] systemd[1]: Finished Load Kernel Module efi_pstore. [ 7.533371] systemd[1]: modprobe@fuse.service: Deactivated successfully. [ 7.533699] systemd[1]: Finished Load Kernel Module fuse. [ 7.534277] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully. [ 7.534646] systemd[1]: Finished Load Kernel Module pstore_blk. [ 7.535041] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully. [ 7.535354] systemd[1]: Finished Load Kernel Module pstore_zone. [ 7.535725] systemd[1]: modprobe@ramoops.service: Deactivated successfully. [ 7.536024] systemd[1]: Finished Load Kernel Module ramoops. [ 7.537802] systemd[1]: Mounting FUSE Control File System... [ 7.538725] EXT4-fs (nvme0n1p2): re-mounted. Opts: commit=600,errors=remount-ro [ 7.539408] systemd[1]: Mounting Kernel Configuration File System... [ 7.542078] systemd[1]: Finished Load Kernel Modules. [ 7.542774] systemd[1]: Finished Remount Root and Kernel File Systems. [ 7.543696] systemd[1]: Mounted FUSE Control File System. [ 7.543902] systemd[1]: Mounted Kernel Configuration File System. [ 7.545602] systemd[1]: Starting Platform Persistent Storage Archival... [ 7.547247] systemd[1]: Starting Load/Save Random Seed... [ 7.548917] systemd[1]: Starting Apply Kernel Variables... [ 7.550447] systemd[1]: Starting Create System Users... [ 7.564237] systemd[1]: Finished Apply Kernel Variables. [ 7.565025] systemd[1]: Finished Create System Users. [ 7.566705] systemd[1]: Starting Create Static Device Nodes in /dev... [ 7.587092] systemd[1]: Finished Create Static Device Nodes in /dev. [ 7.589128] systemd[1]: Starting Rule-based Manager for Device Events and Files... [ 7.594863] systemd[1]: Finished Set the console keyboard layout. [ 7.595111] systemd[1]: Reached target Preparation for Local File Systems. [ 7.596341] systemd[1]: Mounting /tmp... [ 7.598666] systemd[1]: Mounted /tmp. [ 7.612366] systemd[1]: Finished Platform Persistent Storage Archival. [ 7.619801] systemd[1]: Finished Load/Save Random Seed. [ 7.620111] systemd[1]: Condition check resulted in First Boot Complete being skipped. [ 7.668826] systemd[1]: Started Rule-based Manager for Device Events and Files. [ 7.741211] systemd[1]: Finished Coldplug All udev Devices. [ 7.746912] systemd[1]: Starting Helper to synchronize boot up for ifupdown... [ 7.751568] systemd[1]: Starting Show Plymouth Boot Screen... [ 7.754595] systemd[1]: Finished Helper to synchronize boot up for ifupdown. [ 7.777024] systemd[1]: Started Show Plymouth Boot Screen. [ 7.779392] systemd[1]: Created slice Slice /system/systemd-backlight. [ 7.779636] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 7.780216] systemd[1]: Started Forward Password Requests to Plymouth Directory Watch. [ 7.780400] systemd[1]: Reached target Local Encrypted Volumes. [ 7.784625] systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:backlight... [ 7.795545] systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:backlight_1... [ 7.803605] systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:backlight_1. [ 7.804811] systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:backlight. [ 7.868199] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 7.868408] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 7.881514] systemd[1]: Found device Samsung SSD 960 EVO 500GB armbi_boot. [ 7.884627] systemd[1]: Starting File System Check on /dev/disk/by-uuid/1BD1-7F33... [ 7.892012] systemd[1]: Found device /dev/ttyFIQ0. [ 7.898664] systemd[1]: Started File System Check Daemon to report status. [ 7.907614] systemd[1]: Reached target Hardware activated USB gadget. [ 7.916574] systemd[1]: Finished File System Check on /dev/disk/by-uuid/1BD1-7F33. [ 7.923471] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 7.926733] systemd[1]: Mounting /boot... [ 7.927088] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 7.928251] FAT-fs (nvme0n1p1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive! [ 7.933840] systemd[1]: Mounted /boot. [ 7.940208] systemd[1]: Reached target Local File Systems. [ 7.940519] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 7.943646] systemd[1]: Starting Armbian leds state... [ 7.946521] systemd[1]: Starting Armbian ZRAM config... [ 7.949483] systemd[1]: Starting Set console font and keymap... [ 7.952599] systemd[1]: Starting Raise network interfaces... [ 7.955931] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data... [ 7.956250] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped. [ 7.962455] systemd[1]: Starting Set Up Additional Binary Formats... [ 7.962549] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 7.962596] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 7.963251] systemd[1]: Finished Armbian leds state. [ 7.963741] systemd[1]: Finished Set console font and keymap. [ 7.967050] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 521 (systemd-binfmt) [ 7.968397] systemd[1]: Mounting Arbitrary Executable File Formats File System... [ 7.968640] systemd[1]: Received SIGRTMIN+20 from PID 291 (plymouthd). [ 7.970297] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data. [ 7.973939] systemd[1]: Mounted Arbitrary Executable File Formats File System. [ 7.975257] systemd[1]: Finished Set Up Additional Binary Formats. [ 8.035959] zram0: detected capacity change from 0 to 4031107072 [ 8.070729] Adding 3936624k swap on /dev/zram0. Priority:5 extents:1 across:3936624k SS [ 8.077337] zram: Added device: zram1 [ 8.084541] systemd[1]: Finished Raise network interfaces. [ 8.200379] zram1: detected capacity change from 0 to 52428800 [ 8.231421] systemd[1]: Finished Armbian ZRAM config. [ 8.236208] systemd[1]: Starting Armbian memory supported logging... [ 8.288222] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard [ 8.684199] vendor storage:20190527 ret = -1 [ 8.848157] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 8.848327] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 8.848447] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 9.834335] systemd[1]: Finished Armbian memory supported logging. [ 9.844005] systemd[1]: Starting Journal Service... [ 9.987748] systemd[1]: Started Journal Service. [ 10.016375] systemd-journald[732]: Received client request to flush runtime journal. ### armbian-release: # PLEASE DO NOT EDIT THIS FILE BOARD=orangepi5 BOARD_NAME="Orange Pi 5" BOARDFAMILY=rockchip-rk3588 BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=bfc8271 VERSION=23.08.0-trunk LINUXFAMILY=rk35xx ARCH=arm64 IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm64 KERNEL_IMAGE_TYPE=Image FORCE_BOOTSCRIPT_UPDATE= VENDOR=Armbian REVISION=23.08.0-trunk BOOTSCRIPT_FORCE_UPDATE="no" BOOTSCRIPT_DST="boot.cmd" BRANCH=legacy ### boot environment: verbosity=1 bootlogo=true overlay_prefix=rockchip-rk3588 fdtfile=rockchip/rk3588s-orangepi-5.dtb rootdev=UUID=329a3cf7-a8ce-4ea6-a3ef-c2128bda1678 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u ### lsusb: Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 002: ID 046d:c539 Logitech, Inc. USB Receiver Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub ### lscpu: Architecture: aarch64 CPU op-mode(s): 32-bit, 64-bit Byte Order: Little Endian CPU(s): 8 On-line CPU(s) list: 0-7 Vendor ID: ARM Model name: Cortex-A55 Model: 0 Thread(s) per core: 1 Core(s) per socket: 4 Socket(s): 1 Stepping: r2p0 CPU max MHz: 1800.0000 CPU min MHz: 408.0000 BogoMIPS: 48.00 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp Model name: Cortex-A76 Model: 0 Thread(s) per core: 1 Core(s) per socket: 2 Socket(s): 2 Stepping: r4p0 CPU max MHz: 2256.0000 CPU min MHz: 408.0000 BogoMIPS: 48.00 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp L1d cache: 384 KiB (8 instances) L1i cache: 384 KiB (8 instances) L2 cache: 2.5 MiB (8 instances) L3 cache: 3 MiB (1 instance) Vulnerability Itlb multihit: Not affected Vulnerability L1tf: Not affected Vulnerability Mds: Not affected Vulnerability Meltdown: Not affected Vulnerability Mmio stale data: Not affected Vulnerability Retbleed: Not affected Vulnerability Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl Vulnerability Spectre v1: Mitigation; __user pointer sanitization Vulnerability Spectre v2: Vulnerable: Unprivileged eBPF enabled Vulnerability Srbds: Not affected Vulnerability Tsx async abort: Not affected ### cpuinfo: processor : 0 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 1 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 2 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 3 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 4 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 processor : 5 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 processor : 6 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 processor : 7 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 Serial : 2eae2cb9d903d20e ### meminfo: MemTotal: 7873256 kB MemFree: 7562396 kB MemAvailable: 7588228 kB Buffers: 15056 kB Cached: 84080 kB SwapCached: 0 kB Active: 26372 kB Inactive: 108776 kB Active(anon): 504 kB Inactive(anon): 65888 kB Active(file): 25868 kB Inactive(file): 42888 kB Unevictable: 19608 kB Mlocked: 0 kB SwapTotal: 3936624 kB SwapFree: 3936624 kB Dirty: 3924 kB Writeback: 0 kB AnonPages: 56916 kB Mapped: 29460 kB Shmem: 25796 kB KReclaimable: 38192 kB Slab: 79372 kB SReclaimable: 38192 kB SUnreclaim: 41180 kB KernelStack: 3856 kB PageTables: 3228 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 7873252 kB Committed_AS: 132940 kB VmallocTotal: 135290290112 kB VmallocUsed: 36656 kB VmallocChunk: 0 kB Percpu: 2656 kB CmaTotal: 262144 kB CmaAllocated: 4672 kB CmaReleased: 257472 kB CmaFree: 257472 kB HugePages_Total: 0 HugePages_Free: 0 HugePages_Rsvd: 0 HugePages_Surp: 0 Hugepagesize: 2048 kB Hugetlb: 0 kB ### virtual memory: vm.admin_reserve_kbytes = 8192 vm.block_dump = 0 vm.dirty_background_bytes = 0 vm.dirty_background_ratio = 10 vm.dirty_bytes = 0 vm.dirty_expire_centisecs = 3000 vm.dirty_ratio = 20 vm.dirtytime_expire_seconds = 43200 vm.dirty_writeback_centisecs = 500 vm.extra_free_kbytes = 0 vm.hugetlb_shm_group = 0 vm.laptop_mode = 0 vm.legacy_va_layout = 0 vm.lowmem_reserve_ratio = 256 256 32 0 vm.max_map_count = 65530 vm.min_free_kbytes = 11208 vm.mmap_min_addr = 32768 vm.mmap_rnd_bits = 18 vm.mmap_rnd_compat_bits = 11 vm.nr_hugepages = 0 vm.nr_overcommit_hugepages = 0 vm.oom_dump_tasks = 1 vm.oom_kill_allocating_task = 0 vm.overcommit_kbytes = 0 vm.overcommit_memory = 0 vm.overcommit_ratio = 50 vm.page-cluster = 0 vm.page_lock_unfairness = 5 vm.panic_on_oom = 0 vm.percpu_pagelist_fraction = 0 vm.stat_interval = 1 vm.swappiness = 100 vm.user_reserve_kbytes = 131072 vm.vfs_cache_pressure = 100 vm.watermark_boost_factor = 15000 vm.watermark_scale_factor = 10 ### ip addr: 1: lo: mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet XXX.XXX.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: eth0: mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether ae:d8:3f:81:fa:0b brd ff:ff:ff:ff:ff:ff ### partitions: major minor #blocks name 254 0 3936628 zram0 259 0 488386584 nvme0n1 259 1 262144 nvme0n1p1 259 2 483213312 nvme0n1p2 31 0 16384 mtdblock0 254 1 51200 zram1 ### df: tmpfs 769M 9.7M 760M 2% /run /dev/nvme0n1p2 454G 5.1G 444G 2% / tmpfs 3.8G 0 3.8G 0% /dev/shm tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs 3.8G 4.0K 3.8G 1% /tmp /dev/nvme0n1p1 256M 106M 151M 42% /boot /dev/zram1 47M 4.1M 40M 10% /var/log ### lsblk: NAME FSTYPE SIZE MOUNTPOINT UUID mtdblock0 16M zram1 50M /var/log nvme0n1 465.8G ├─nvme0n1p1 vfat 256M /boot 1BD1-7F33 └─nvme0n1p2 ext4 460.8G / 329a3cf7-a8ce-4ea6-a3ef-c2128bda1678 ### zramctl: NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT /dev/zram1 zstd 50M 4.1M 834.6K 1.2M 8 /var/log /dev/zram0 lzo-rle 3.8G 4K 74B 12K 8 [SWAP] ### mtab: /dev/nvme0n1p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=936,iocharset=utf8,shortname=mixed,errors=remount-ro 0 0 /dev/nvme0n1p2 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0 /dev/nvme0n1p2 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0 ### Boot system health: Time CPU_cl0/CPU_cl1 load %cpu %sys %usr %nice %io %irq Tcpu C.St. 21:11:54 1800/2256 MHz 0.16 21% 12% 7% 0% 0% 0% 47.2 °C 0/7 21:11:55 1800/ 600 MHz 0.16 25% 7% 17% 0% 0% 0% 46.2 °C 0/7 21:11:55 1800/2256 MHz 0.16 19% 2% 16% 0% 0% 0% 46.2 °C 0/7 21:11:55 1800/2256 MHz 0.16 19% 4% 13% 0% 0% 0% 46.2 °C 0/7 21:11:56 1800/2256 MHz 0.16 15% 1% 13% 0% 0% 0% 45.3 °C 0/7 ### Activated 1 lzo-rle zram swap devices with 3844MB each. ### Activated Armbian ramlog partition with zstd compression Pzt 07 Ağu 2023 21:18:36 +03 | Orange Pi 5 | 23.08.0-trunk | arm64 | aarch64 | 5.10.160-rk35xx ### dmesg: [ 1.765115] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [ 1.765138] Linux version 5.10.160-rk35xx (armbian@next) (aarch64-linux-gnu-gcc (Ubuntu 11.3.0-1ubuntu1~22.04) 11.3.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP Thu Jul 6 13:36:29 UTC 2023 [ 1.775951] Machine model: Orange Pi 5 [ 1.776134] efi: UEFI not found. [ 1.779788] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB [ 1.779807] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@00000000': base 0x0000000000000000, size 0 MiB [ 1.779898] Reserved memory: created CMA memory pool at 0x0000000010000000, size 256 MiB [ 1.779903] OF: reserved mem: initialized node cma, compatible id shared-dma-pool [ 1.930499] Zone ranges: [ 1.930506] DMA [mem 0x0000000000200000-0x00000000ffffffff] [ 1.930517] DMA32 empty [ 1.930524] Normal [mem 0x0000000100000000-0x00000001ffffffff] [ 1.930532] Movable zone start for each node [ 1.930535] Early memory node ranges [ 1.930541] node 0: [mem 0x0000000000200000-0x00000000efffffff] [ 1.930549] node 0: [mem 0x0000000100000000-0x00000001ffffffff] [ 1.930557] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff] [ 1.930563] On node 0 totalpages: 2031104 [ 1.930569] DMA zone: 15352 pages used for memmap [ 1.930573] DMA zone: 0 pages reserved [ 1.930579] DMA zone: 982528 pages, LIFO batch:63 [ 1.930584] Normal zone: 16384 pages used for memmap [ 1.930588] Normal zone: 1048576 pages, LIFO batch:63 [ 1.977572] psci: probing for conduit method from DT. [ 1.977584] psci: PSCIv1.1 detected in firmware. [ 1.977588] psci: Using standard PSCI v0.2 function IDs [ 1.977595] psci: MIGRATE_INFO_TYPE not supported. [ 1.977601] psci: SMC Calling Convention v1.2 [ 1.978046] percpu: Embedded 32 pages/cpu s93480 r8192 d29400 u131072 [ 1.978089] pcpu-alloc: s93480 r8192 d29400 u131072 alloc=32*4096 [ 1.978097] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7 [ 1.978238] Detected VIPT I-cache on CPU0 [ 1.978286] CPU features: detected: GIC system register CPU interface [ 1.978291] CPU features: detected: Virtualization Host Extensions [ 1.978302] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 1.978315] alternatives: patching kernel code [ 1.978699] Built 1 zonelists, mobility grouping on. Total pages: 1999368 [ 1.978709] Kernel command line: root=UUID=329a3cf7-a8ce-4ea6-a3ef-c2128bda1678 rootwait rootfstype=ext4 splash plymouth.ignore-serial-consoles console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart= usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 [ 1.980046] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) [ 1.980453] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 1.980461] mem auto-init: stack:off, heap alloc:off, heap free:off [ 1.986966] software IO TLB: mapped [mem 0x00000000ec000000-0x00000000f0000000] (64MB) [ 2.061436] Memory: 7589180K/8124416K available (16832K kernel code, 3506K rwdata, 6500K rodata, 6976K init, 639K bss, 273092K reserved, 262144K cma-reserved) [ 2.061593] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1 [ 2.061630] ftrace: allocating 64539 entries in 253 pages [ 2.172076] ftrace: allocated 253 pages with 7 groups [ 2.172382] rcu: Hierarchical RCU implementation. [ 2.172387] rcu: RCU event tracing is enabled. [ 2.172393] Rude variant of Tasks RCU enabled. [ 2.172396] Tracing variant of Tasks RCU enabled. [ 2.172402] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies. [ 2.178058] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 2.180862] GICv3: GIC: Using split EOI/Deactivate mode [ 2.180870] GICv3: 480 SPIs implemented [ 2.180874] GICv3: 0 Extended SPIs implemented [ 2.180914] GICv3: Distributor has no Range Selector support [ 2.180924] GICv3: 16 PPIs implemented [ 2.180969] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000 [ 2.181097] ITS [mem 0xfe640000-0xfe65ffff] [ 2.181153] ITS@0x00000000fe640000: allocated 8192 Devices @100200000 (indirect, esz 8, psz 64K, shr 0) [ 2.181181] ITS@0x00000000fe640000: allocated 32768 Interrupt Collections @100210000 (flat, esz 2, psz 64K, shr 0) [ 2.181191] ITS: using cache flushing for cmd queue [ 2.181233] ITS [mem 0xfe660000-0xfe67ffff] [ 2.181282] ITS@0x00000000fe660000: allocated 8192 Devices @100230000 (indirect, esz 8, psz 64K, shr 0) [ 2.181310] ITS@0x00000000fe660000: allocated 32768 Interrupt Collections @100240000 (flat, esz 2, psz 64K, shr 0) [ 2.181320] ITS: using cache flushing for cmd queue [ 2.181546] GICv3: using LPI property table @0x0000000100250000 [ 2.181678] GIC: using cache flushing for LPI property table [ 2.181689] GICv3: CPU0: using allocated LPI pending table @0x0000000100260000 [ 2.318069] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 2.318078] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 2.318089] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 2.319464] Console: colour dummy device 80x25 [ 2.319507] printk: console [tty1] enabled [ 2.319537] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000) [ 2.319549] pid_max: default: 32768 minimum: 301 [ 2.319661] LSM: Security Framework initializing [ 2.319733] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 2.319760] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 2.322026] rcu: Hierarchical SRCU implementation. [ 2.323003] Platform MSI: msi-controller@fe640000 domain created [ 2.323025] Platform MSI: msi-controller@fe660000 domain created [ 2.323409] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe640000 domain created [ 2.323435] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe660000 domain created [ 2.323624] EFI services will not be available. [ 2.324078] smp: Bringing up secondary CPUs ... [ 2.324803] Detected VIPT I-cache on CPU1 [ 2.324840] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000 [ 2.324860] GICv3: CPU1: using allocated LPI pending table @0x0000000100270000 [ 2.324905] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [ 2.325682] Detected VIPT I-cache on CPU2 [ 2.325715] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000 [ 2.325735] GICv3: CPU2: using allocated LPI pending table @0x0000000100280000 [ 2.325776] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [ 2.326506] Detected VIPT I-cache on CPU3 [ 2.326536] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000 [ 2.326555] GICv3: CPU3: using allocated LPI pending table @0x0000000100290000 [ 2.326593] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [ 2.327335] CPU features: detected: Spectre-v4 [ 2.327339] CPU features: detected: Spectre-BHB [ 2.327341] Detected PIPT I-cache on CPU4 [ 2.327357] GICv3: CPU4: found redistributor 400 region 0:0x00000000fe700000 [ 2.327368] GICv3: CPU4: using allocated LPI pending table @0x00000001002a0000 [ 2.327393] CPU4: Booted secondary processor 0x0000000400 [0x414fd0b0] [ 2.328118] Detected PIPT I-cache on CPU5 [ 2.328134] GICv3: CPU5: found redistributor 500 region 0:0x00000000fe720000 [ 2.328145] GICv3: CPU5: using allocated LPI pending table @0x00000001002b0000 [ 2.328171] CPU5: Booted secondary processor 0x0000000500 [0x414fd0b0] [ 2.328865] Detected PIPT I-cache on CPU6 [ 2.328880] GICv3: CPU6: found redistributor 600 region 0:0x00000000fe740000 [ 2.328891] GICv3: CPU6: using allocated LPI pending table @0x00000001002c0000 [ 2.328916] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b0] [ 2.329593] Detected PIPT I-cache on CPU7 [ 2.329609] GICv3: CPU7: found redistributor 700 region 0:0x00000000fe760000 [ 2.329620] GICv3: CPU7: using allocated LPI pending table @0x00000001002d0000 [ 2.329645] CPU7: Booted secondary processor 0x0000000700 [0x414fd0b0] [ 2.329723] smp: Brought up 1 node, 8 CPUs [ 2.329743] SMP: Total of 8 processors activated. [ 2.329748] CPU features: detected: Privileged Access Never [ 2.329753] CPU features: detected: User Access Override [ 2.329758] CPU features: detected: 32-bit EL0 Support [ 2.329763] CPU features: detected: Common not Private translations [ 2.329767] CPU features: detected: RAS Extension Support [ 2.329772] CPU features: detected: Data cache clean to the PoU not required for I/D coherence [ 2.329777] CPU features: detected: CRC32 instructions [ 2.329781] CPU features: detected: Speculative Store Bypassing Safe (SSBS) [ 2.329787] CPU features: detected: RCpc load-acquire (LDAPR) [ 2.329874] CPU: All CPU(s) started at EL2 [ 2.333086] devtmpfs: initialized [ 2.347876] Registered cp15_barrier emulation handler [ 2.347885] Registered setend emulation handler [ 2.347890] KASLR disabled due to lack of seed [ 2.347977] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns [ 2.347983] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 2.350739] pinctrl core: initialized pinctrl subsystem [ 2.350874] regulator-dummy: no parameters, enabled [ 2.350992] DMI not present or invalid. [ 2.351299] NET: Registered protocol family 16 [ 2.352392] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations [ 2.352515] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 2.352534] audit: initializing netlink subsys (disabled) [ 2.352625] audit: type=2000 audit(0.033:1): state=initialized audit_enabled=0 res=1 [ 2.353135] Registered FIQ tty driver [ 2.353284] thermal_sys: Registered thermal governor 'fair_share' [ 2.353287] thermal_sys: Registered thermal governor 'step_wise' [ 2.353289] thermal_sys: Registered thermal governor 'user_space' [ 2.353291] thermal_sys: Registered thermal governor 'power_allocator' [ 2.353614] cpuidle: using governor menu [ 2.353843] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 2.353979] ASID allocator initialised with 65536 entries [ 2.355480] ramoops: dmesg-0 0x20000@0x0000000000110000 [ 2.355499] ramoops: console 0x80000@0x0000000000130000 [ 2.355509] ramoops: pmsg 0x50000@0x00000000001b0000 [ 2.355558] printk: console [ramoops-1] enabled [ 2.355560] pstore: Registered ramoops as persistent store backend [ 2.355563] ramoops: using 0xf0000@0x110000, ecc: 0 [ 2.409545] rockchip-gpio fd8a0000.gpio: probed /pinctrl/gpio@fd8a0000 [ 2.409827] rockchip-gpio fec20000.gpio: probed /pinctrl/gpio@fec20000 [ 2.410059] rockchip-gpio fec30000.gpio: probed /pinctrl/gpio@fec30000 [ 2.410336] rockchip-gpio fec40000.gpio: probed /pinctrl/gpio@fec40000 [ 2.410605] rockchip-gpio fec50000.gpio: probed /pinctrl/gpio@fec50000 [ 2.410654] rockchip-pinctrl pinctrl: probed pinctrl [ 2.419348] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 2.419352] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 2.419355] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 2.419358] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 2.481386] raid6: neonx8 gen() 5362 MB/s [ 2.538132] raid6: neonx8 xor() 4164 MB/s [ 2.594883] raid6: neonx4 gen() 5497 MB/s [ 2.651633] raid6: neonx4 xor() 4177 MB/s [ 2.708384] raid6: neonx2 gen() 5042 MB/s [ 2.765130] raid6: neonx2 xor() 3941 MB/s [ 2.821883] raid6: neonx1 gen() 4214 MB/s [ 2.878628] raid6: neonx1 xor() 3247 MB/s [ 2.935394] raid6: int64x8 gen() 1310 MB/s [ 2.992135] raid6: int64x8 xor() 865 MB/s [ 3.048882] raid6: int64x4 gen() 1616 MB/s [ 3.105625] raid6: int64x4 xor() 846 MB/s [ 3.162380] raid6: int64x2 gen() 1882 MB/s [ 3.219126] raid6: int64x2 xor() 1297 MB/s [ 3.275873] raid6: int64x1 gen() 1966 MB/s [ 3.332637] raid6: int64x1 xor() 960 MB/s [ 3.332639] raid6: using algorithm neonx4 gen() 5497 MB/s [ 3.332641] raid6: .... xor() 4177 MB/s, rmw enabled [ 3.332644] raid6: using neon recovery algorithm [ 3.333258] fiq_debugger fiq_debugger.0: IRQ fiq not found [ 3.333265] fiq_debugger fiq_debugger.0: IRQ wakeup not found [ 3.333269] fiq_debugger_probe: could not install nmi irq handler [ 3.333353] printk: console [ttyFIQ0] enabled [ 3.333456] Registered fiq debugger ttyFIQ0 [ 3.333671] vcc12v_dcin: 12000 mV, enabled [ 3.333749] reg-fixed-voltage vcc12v-dcin: vcc12v_dcin supplying 12000000uV [ 3.333801] reg-fixed-voltage vcc5v0-sys: Looking up vin-supply from device tree [ 3.333806] vcc5v0_sys: supplied by vcc12v_dcin [ 3.333810] vcc12v_dcin: could not add device link regulator.2: -ENOENT [ 3.333826] vcc5v0_sys: 5000 mV, enabled [ 3.333892] reg-fixed-voltage vcc5v0-sys: vcc5v0_sys supplying 5000000uV [ 3.333940] reg-fixed-voltage vcc5v0-usbdcin: Looking up vin-supply from device tree [ 3.333944] vcc5v0_usbdcin: supplied by vcc12v_dcin [ 3.333947] vcc12v_dcin: could not add device link regulator.3: -ENOENT [ 3.333962] vcc5v0_usbdcin: 5000 mV, enabled [ 3.334028] reg-fixed-voltage vcc5v0-usbdcin: vcc5v0_usbdcin supplying 5000000uV [ 3.334073] reg-fixed-voltage vcc5v0-usb: Looking up vin-supply from device tree [ 3.334077] vcc5v0_usb: supplied by vcc5v0_usbdcin [ 3.334081] vcc5v0_usbdcin: could not add device link regulator.4: -ENOENT [ 3.334095] vcc5v0_usb: 5000 mV, enabled [ 3.334154] reg-fixed-voltage vcc5v0-usb: vcc5v0_usb supplying 5000000uV [ 3.334256] vbus5v0_typec: 5000 mV, disabled [ 3.334306] reg-fixed-voltage vbus5v0-typec: Looking up vin-supply from device tree [ 3.334310] vbus5v0_typec: supplied by vcc5v0_usb [ 3.334344] reg-fixed-voltage vbus5v0-typec: vbus5v0_typec supplying 5000000uV [ 3.334396] reg-fixed-voltage vcc-1v1-nldo-s3: Looking up vin-supply from device tree [ 3.334399] vcc_1v1_nldo_s3: supplied by vcc5v0_sys [ 3.334403] vcc5v0_sys: could not add device link regulator.6: -ENOENT [ 3.334420] vcc_1v1_nldo_s3: 1100 mV, enabled [ 3.334484] reg-fixed-voltage vcc-1v1-nldo-s3: vcc_1v1_nldo_s3 supplying 1100000uV [ 3.334536] reg-fixed-voltage vcc3v3-pcie2x1l2: Looking up vin-supply from device tree [ 3.334541] vcc3v3_pcie2x1l2: supplied by vcc5v0_sys [ 3.334544] vcc5v0_sys: could not add device link regulator.7: -ENOENT [ 3.390345] vcc3v3_pcie2x1l2: 1800 mV, enabled [ 3.390412] reg-fixed-voltage vcc3v3-pcie2x1l2: vcc3v3_pcie2x1l2 supplying 1800000uV [ 3.390694] iommu: Default domain type: Translated [ 3.391130] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vdpu-supply from device tree [ 3.391150] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vdpu-supply property in node /power-management@fd8d8000/power-controller failed [ 3.391419] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga30-supply from device tree [ 3.391437] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga30-supply property in node /power-management@fd8d8000/power-controller failed [ 3.391615] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga31-supply from device tree [ 3.391633] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga31-supply property in node /power-management@fd8d8000/power-controller failed [ 3.392939] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc0-supply from device tree [ 3.392958] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc0-supply property in node /power-management@fd8d8000/power-controller failed [ 3.393110] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vcodec-supply from device tree [ 3.393128] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vcodec-supply property in node /power-management@fd8d8000/power-controller failed [ 3.393230] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc1-supply from device tree [ 3.393248] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc1-supply property in node /power-management@fd8d8000/power-controller failed [ 3.393523] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec0-supply from device tree [ 3.393540] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec0-supply property in node /power-management@fd8d8000/power-controller failed [ 3.393831] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec1-supply from device tree [ 3.393849] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec1-supply property in node /power-management@fd8d8000/power-controller failed [ 3.394067] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vi-supply from device tree [ 3.394084] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vi-supply property in node /power-management@fd8d8000/power-controller failed [ 3.394319] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up isp1-supply from device tree [ 3.394336] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up isp1-supply property in node /power-management@fd8d8000/power-controller failed [ 3.395037] SCSI subsystem initialized [ 3.395051] libata version 3.00 loaded. [ 3.395124] usbcore: registered new interface driver usbfs [ 3.395142] usbcore: registered new interface driver hub [ 3.395156] usbcore: registered new device driver usb [ 3.395195] mc: Linux media interface: v0.10 [ 3.395207] videodev: Linux video capture interface: v2.00 [ 3.395236] pps_core: LinuxPPS API ver. 1 registered [ 3.395238] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [ 3.395244] PTP clock support registered [ 3.395511] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled. [ 3.395544] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0 [ 3.396752] Advanced Linux Sound Architecture Driver Initialized. [ 3.397018] Bluetooth: Core ver 2.22 [ 3.397032] NET: Registered protocol family 31 [ 3.397035] Bluetooth: HCI device and connection manager initialized [ 3.397039] Bluetooth: HCI socket layer initialized [ 3.397043] Bluetooth: L2CAP socket layer initialized [ 3.397049] Bluetooth: SCO socket layer initialized [ 3.397062] NetLabel: Initializing [ 3.397064] NetLabel: domain hash size = 128 [ 3.397066] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 3.397093] NetLabel: unlabeled traffic allowed by default [ 3.398422] rockchip-cpuinfo cpuinfo: SoC : 35881000 [ 3.398426] rockchip-cpuinfo cpuinfo: Serial : 2eae2cb9d903d20e [ 3.398871] clocksource: Switched to clocksource arch_sys_counter [ 3.815926] VFS: Disk quotas dquot_6.6.0 [ 3.815954] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 3.821682] NET: Registered protocol family 2 [ 3.821807] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 3.823840] tcp_listen_portaddr_hash hash table entries: 4096 (order: 5, 163840 bytes, linear) [ 3.823938] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 3.824286] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear) [ 3.825090] TCP: Hash tables configured (established 65536 bind 65536) [ 3.825198] MPTCP token hash table entries: 8192 (order: 6, 393216 bytes, linear) [ 3.825297] UDP hash table entries: 4096 (order: 6, 393216 bytes, linear) [ 3.825453] UDP-Lite hash table entries: 4096 (order: 6, 393216 bytes, linear) [ 3.825684] NET: Registered protocol family 1 [ 3.826057] RPC: Registered named UNIX socket transport module. [ 3.826060] RPC: Registered udp transport module. [ 3.826061] RPC: Registered tcp transport module. [ 3.826063] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 3.826510] PCI: CLS 0 bytes, default 64 [ 3.826804] Trying to unpack rootfs image as initramfs... [ 4.222137] Freeing initrd memory: 14956K [ 4.222834] rockchip-thermal fec00000.tsadc: Missing rockchip,grf property [ 4.223482] rockchip-thermal fec00000.tsadc: tsadc is probed successfully! [ 4.224417] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 4.225018] kvm [1]: IPA Size Limit: 40 bits [ 4.225029] kvm [1]: GICv3: no GICV resource entry [ 4.225032] kvm [1]: disabling GICv2 emulation [ 4.225034] kvm [1]: GIC system register CPU interface enabled [ 4.225188] kvm [1]: vgic interrupt IRQ9 [ 4.225371] kvm [1]: VHE mode initialized successfully [ 4.228476] Initialise system trusted keyrings [ 4.228607] workingset: timestamp_bits=46 max_order=21 bucket_order=0 [ 4.231648] NFS: Registering the id_resolver key type [ 4.231661] Key type id_resolver registered [ 4.231663] Key type id_legacy registered [ 4.231699] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 4.231702] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 4.231715] ntfs: driver 2.1.32 [Flags: R/W]. [ 4.253811] NET: Registered protocol family 38 [ 4.253816] xor: measuring software checksum speed [ 4.255428] 8regs : 6125 MB/sec [ 4.256646] 32regs : 8135 MB/sec [ 4.257642] arm64_neon : 9915 MB/sec [ 4.257644] xor: using function: arm64_neon (9915 MB/sec) [ 4.257649] Key type asymmetric registered [ 4.257652] Asymmetric key parser 'x509' registered [ 4.257668] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242) [ 4.257773] io scheduler mq-deadline registered [ 4.257778] io scheduler kyber registered [ 4.259586] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up phy-supply from device tree [ 4.259596] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up phy-supply property in node /syscon@fd5d0000/usb2-phy@0/otg-port failed [ 4.259645] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up vbus-supply from device tree [ 4.259652] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up vbus-supply property in node /syscon@fd5d0000/usb2-phy@0/otg-port failed [ 4.260977] phy phy-fd5d8000.syscon:usb2-phy@8000.1: Looking up phy-supply from device tree [ 4.260985] phy phy-fd5d8000.syscon:usb2-phy@8000.1: Looking up phy-supply property in node /syscon@fd5d8000/usb2-phy@8000/host-port failed [ 4.262181] phy phy-fd5dc000.syscon:usb2-phy@c000.2: Looking up phy-supply from device tree [ 4.262190] phy phy-fd5dc000.syscon:usb2-phy@c000.2: Looking up phy-supply property in node /syscon@fd5dc000/usb2-phy@c000/host-port failed [ 4.264044] phy phy-fee00000.phy.3: Looking up phy-supply from device tree [ 4.264050] phy phy-fee00000.phy.3: Looking up phy-supply property in node /phy@fee00000 failed [ 4.264202] phy phy-fee20000.phy.4: Looking up phy-supply from device tree [ 4.264208] phy phy-fee20000.phy.4: Looking up phy-supply property in node /phy@fee20000 failed [ 4.264700] phy phy-feda0000.phy.5: Looking up phy-supply from device tree [ 4.264706] phy phy-feda0000.phy.5: Looking up phy-supply property in node /phy@feda0000 failed [ 4.264840] phy phy-fedb0000.phy.6: Looking up phy-supply from device tree [ 4.264845] phy phy-fedb0000.phy.6: Looking up phy-supply property in node /phy@fedb0000 failed [ 4.265220] phy phy-fed60000.hdmiphy.7: Looking up phy-supply from device tree [ 4.265227] phy phy-fed60000.hdmiphy.7: Looking up phy-supply property in node /hdmiphy@fed60000 failed [ 4.266018] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy init success [ 4.266966] phy phy-fed80000.phy.8: Looking up phy-supply from device tree [ 4.266974] phy phy-fed80000.phy.8: Looking up phy-supply property in node /phy@fed80000/dp-port failed [ 4.267009] phy phy-fed80000.phy.9: Looking up phy-supply from device tree [ 4.267014] phy phy-fed80000.phy.9: Looking up phy-supply property in node /phy@fed80000/u3-port failed [ 4.268464] rk-pcie fe190000.pcie: invalid prsnt-gpios property in node [ 4.268475] rk-pcie fe190000.pcie: Looking up vpcie3v3-supply from device tree [ 4.268712] pwm-backlight backlight: Looking up power-supply from device tree [ 4.268719] pwm-backlight backlight: Looking up power-supply property in node /backlight failed [ 4.268724] pwm-backlight backlight: supply power not found, using dummy regulator [ 4.269007] pwm-backlight backlight_1: Looking up power-supply from device tree [ 4.269013] pwm-backlight backlight_1: Looking up power-supply property in node /backlight_1 failed [ 4.269018] pwm-backlight backlight_1: supply power not found, using dummy regulator [ 4.269195] rk-pcie fe190000.pcie: IRQ msi not found [ 4.269202] rk-pcie fe190000.pcie: use outband MSI support [ 4.269209] rk-pcie fe190000.pcie: Missing *config* reg space [ 4.269225] rk-pcie fe190000.pcie: host bridge /pcie@fe190000 ranges: [ 4.269258] rk-pcie fe190000.pcie: err 0x00f4000000..0x00f40fffff -> 0x00f4000000 [ 4.269281] rk-pcie fe190000.pcie: IO 0x00f4100000..0x00f41fffff -> 0x00f4100000 [ 4.269306] rk-pcie fe190000.pcie: MEM 0x00f4200000..0x00f4ffffff -> 0x00f4200000 [ 4.269319] rk-pcie fe190000.pcie: MEM 0x0a00000000..0x0a3fffffff -> 0x0a00000000 [ 4.269321] iep: Module initialized. [ 4.269359] mpp_service mpp-srv: unknown mpp version for missing VCS info [ 4.269362] rk-pcie fe190000.pcie: Missing *config* reg space [ 4.269365] mpp_service mpp-srv: probe start [ 4.269392] rk-pcie fe190000.pcie: invalid resource [ 4.271274] mpp_vdpu2 fdb50400.vdpu: Adding to iommu group 1 [ 4.271491] mpp_vdpu2 fdb50400.vdpu: probe device [ 4.271610] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0 [ 4.271617] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0 [ 4.271763] mpp_vdpu2 fdb50400.vdpu: probing finish [ 4.271976] mpp_vepu2 jpege-ccu: probing start [ 4.271979] mpp_vepu2 jpege-ccu: probing finish [ 4.272088] mpp_vepu2 fdb50000.vepu: Adding to iommu group 1 [ 4.272170] mpp_vepu2 fdb50000.vepu: probing start [ 4.272280] mpp_vepu2 fdb50000.vepu: reset_group->rw_sem_on=0 [ 4.272283] mpp_vepu2 fdb50000.vepu: reset_group->rw_sem_on=0 [ 4.272436] mpp_vepu2 fdb50000.vepu: probing finish [ 4.272555] mpp_vepu2 fdba0000.jpege-core: Adding to iommu group 5 [ 4.272697] mpp_vepu2 fdba0000.jpege-core: probing start [ 4.272804] mpp_vepu2 fdba0000.jpege-core: attach ccu success [ 4.272941] mpp_vepu2 fdba0000.jpege-core: probing finish [ 4.273052] mpp_vepu2 fdba4000.jpege-core: Adding to iommu group 6 [ 4.273189] mpp_vepu2 fdba4000.jpege-core: probing start [ 4.273298] mpp_vepu2 fdba4000.jpege-core: attach ccu success [ 4.273434] mpp_vepu2 fdba4000.jpege-core: probing finish [ 4.273542] mpp_vepu2 fdba8000.jpege-core: Adding to iommu group 7 [ 4.273676] mpp_vepu2 fdba8000.jpege-core: probing start [ 4.273782] mpp_vepu2 fdba8000.jpege-core: attach ccu success [ 4.273920] mpp_vepu2 fdba8000.jpege-core: probing finish [ 4.274016] mpp_vepu2 fdbac000.jpege-core: Adding to iommu group 8 [ 4.274153] mpp_vepu2 fdbac000.jpege-core: probing start [ 4.274258] mpp_vepu2 fdbac000.jpege-core: attach ccu success [ 4.274393] mpp_vepu2 fdbac000.jpege-core: probing finish [ 4.274666] mpp-iep2 fdbb0000.iep: Adding to iommu group 9 [ 4.274808] mpp-iep2 fdbb0000.iep: probe device [ 4.274935] mpp-iep2 fdbb0000.iep: allocate roi buffer failed [ 4.275061] mpp-iep2 fdbb0000.iep: probing finish [ 4.275281] mpp_jpgdec fdb90000.jpegd: Adding to iommu group 4 [ 4.275489] mpp_jpgdec fdb90000.jpegd: probe device [ 4.275756] mpp_jpgdec fdb90000.jpegd: probing finish [ 4.276120] mpp_rkvdec2 fdc30000.rkvdec-ccu: rkvdec-ccu, probing start [ 4.276181] mpp_rkvdec2 fdc30000.rkvdec-ccu: ccu-mode: 1 [ 4.276183] mpp_rkvdec2 fdc30000.rkvdec-ccu: probing finish [ 4.276279] mpp_rkvdec2 fdc38100.rkvdec-core: Adding to iommu group 12 [ 4.276543] mpp_rkvdec2 fdc38100.rkvdec-core: rkvdec-core, probing start [ 4.276666] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found! [ 4.276669] rkvdec2_init:1022: No niu aclk reset resource define [ 4.276673] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found! [ 4.276675] rkvdec2_init:1025: No niu hclk reset resource define [ 4.276690] mpp_rkvdec2 fdc38100.rkvdec-core: Looking up vdec-supply from device tree [ 4.276695] mpp_rkvdec2 fdc38100.rkvdec-core: Looking up vdec-supply property in node /rkvdec-core@fdc38000 failed [ 4.276701] mpp_rkvdec2 fdc38100.rkvdec-core: no regulator, devfreq is disabled [ 4.276757] mpp_rkvdec2 fdc38100.rkvdec-core: core_mask=00010001 [ 4.276760] mpp_rkvdec2 fdc38100.rkvdec-core: attach ccu as core 0 [ 4.276907] mpp_rkvdec2 fdc38100.rkvdec-core: sram_start 0x00000000ff001000 [ 4.276910] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_iova 0x00000000fff00000 [ 4.276913] mpp_rkvdec2 fdc38100.rkvdec-core: sram_size 491520 [ 4.276916] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_size 1048576 [ 4.276920] mpp_rkvdec2 fdc38100.rkvdec-core: min_width 512 [ 4.276924] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_info_count 20 [ 4.276927] mpp_rkvdec2 fdc38100.rkvdec-core: [136, 24576] [ 4.276930] mpp_rkvdec2 fdc38100.rkvdec-core: [137, 49152] [ 4.276932] mpp_rkvdec2 fdc38100.rkvdec-core: [141, 90112] [ 4.276935] mpp_rkvdec2 fdc38100.rkvdec-core: [140, 49152] [ 4.276938] mpp_rkvdec2 fdc38100.rkvdec-core: [139, 180224] [ 4.276940] mpp_rkvdec2 fdc38100.rkvdec-core: [133, 49152] [ 4.276943] mpp_rkvdec2 fdc38100.rkvdec-core: [134, 8192] [ 4.276945] mpp_rkvdec2 fdc38100.rkvdec-core: [135, 4352] [ 4.276948] mpp_rkvdec2 fdc38100.rkvdec-core: [138, 13056] [ 4.276951] mpp_rkvdec2 fdc38100.rkvdec-core: [142, 291584] [ 4.276986] mpp_rkvdec2 fdc38100.rkvdec-core: probing finish [ 4.277077] mpp_rkvdec2 fdc48100.rkvdec-core: Adding to iommu group 13 [ 4.277309] mpp_rkvdec2 fdc48100.rkvdec-core: rkvdec-core, probing start [ 4.277435] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found! [ 4.277438] rkvdec2_init:1022: No niu aclk reset resource define [ 4.277441] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found! [ 4.277443] rkvdec2_init:1025: No niu hclk reset resource define [ 4.277460] mpp_rkvdec2 fdc48100.rkvdec-core: Looking up vdec-supply from device tree [ 4.277465] mpp_rkvdec2 fdc48100.rkvdec-core: Looking up vdec-supply property in node /rkvdec-core@fdc48000 failed [ 4.277471] mpp_rkvdec2 fdc48100.rkvdec-core: no regulator, devfreq is disabled [ 4.277513] mpp_rkvdec2 fdc48100.rkvdec-core: core_mask=00020002 [ 4.277530] mpp_rkvdec2 fdc48100.rkvdec-core: attach ccu as core 1 [ 4.277709] mpp_rkvdec2 fdc48100.rkvdec-core: sram_start 0x00000000ff079000 [ 4.277712] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_iova 0x00000000ffe00000 [ 4.277715] mpp_rkvdec2 fdc48100.rkvdec-core: sram_size 487424 [ 4.277717] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_size 1048576 [ 4.277721] mpp_rkvdec2 fdc48100.rkvdec-core: min_width 512 [ 4.277726] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_info_count 20 [ 4.277728] mpp_rkvdec2 fdc48100.rkvdec-core: [136, 24576] [ 4.277731] mpp_rkvdec2 fdc48100.rkvdec-core: [137, 49152] [ 4.277733] mpp_rkvdec2 fdc48100.rkvdec-core: [141, 90112] [ 4.277736] mpp_rkvdec2 fdc48100.rkvdec-core: [140, 49152] [ 4.277739] mpp_rkvdec2 fdc48100.rkvdec-core: [139, 180224] [ 4.277741] mpp_rkvdec2 fdc48100.rkvdec-core: [133, 49152] [ 4.277744] mpp_rkvdec2 fdc48100.rkvdec-core: [134, 8192] [ 4.277747] mpp_rkvdec2 fdc48100.rkvdec-core: [135, 4352] [ 4.277749] mpp_rkvdec2 fdc48100.rkvdec-core: [138, 13056] [ 4.277752] mpp_rkvdec2 fdc48100.rkvdec-core: [142, 291584] [ 4.277782] mpp_rkvdec2 fdc48100.rkvdec-core: probing finish [ 4.277971] mpp_rkvenc2 rkvenc-ccu: probing start [ 4.277974] mpp_rkvenc2 rkvenc-ccu: probing finish [ 4.278090] mpp_rkvenc2 fdbd0000.rkvenc-core: Adding to iommu group 10 [ 4.278270] mpp_rkvenc2 fdbd0000.rkvenc-core: probing start [ 4.278421] mpp_rkvenc2 fdbd0000.rkvenc-core: Looking up venc-supply from device tree [ 4.278427] mpp_rkvenc2 fdbd0000.rkvenc-core: Looking up venc-supply property in node /rkvenc-core@fdbd0000 failed [ 4.278433] mpp_rkvenc2 fdbd0000.rkvenc-core: dev_pm_opp_set_regulators: no regulator (venc) found: -19 [ 4.278449] rkvenc_init:1814: failed to add venc devfreq [ 4.278478] mpp_rkvenc2 fdbd0000.rkvenc-core: attach ccu as core 0 [ 4.278621] mpp_rkvenc2 fdbd0000.rkvenc-core: probing finish [ 4.278704] mpp_rkvenc2 fdbe0000.rkvenc-core: Adding to iommu group 11 [ 4.278890] mpp_rkvenc2 fdbe0000.rkvenc-core: probing start [ 4.279023] mpp_rkvenc2 fdbe0000.rkvenc-core: Looking up venc-supply from device tree [ 4.279028] mpp_rkvenc2 fdbe0000.rkvenc-core: Looking up venc-supply property in node /rkvenc-core@fdbe0000 failed [ 4.279034] mpp_rkvenc2 fdbe0000.rkvenc-core: dev_pm_opp_set_regulators: no regulator (venc) found: -19 [ 4.279047] rkvenc_init:1814: failed to add venc devfreq [ 4.279096] mpp_rkvenc2 fdbe0000.rkvenc-core: attach ccu as core 1 [ 4.279241] mpp_rkvenc2 fdbe0000.rkvenc-core: probing finish [ 4.279486] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up av1-supply from device tree [ 4.279507] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up av1-supply property in node /power-management@fd8d8000/power-controller failed [ 4.279804] mpp_av1dec: Adding child /av1d@fdc70000 [ 4.279883] mpp_av1dec: register device av1d-master [ 4.279914] mpp_av1dec av1d-master: av1_iommu_of_xlate,784 [ 4.279932] av1_iommu_probe_device,736, consumer : av1d-master, supplier : fdca0000.iommu [ 4.279966] mpp_av1dec av1d-master: Adding to iommu group 18 [ 4.280204] mpp_av1dec av1d-master: probing start [ 4.280466] mpp_av1dec av1d-master: probing finish [ 4.280505] mpp_service mpp-srv: probe success [ 4.291588] dma-pl330 fea10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 4.291594] dma-pl330 fea10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 4.292638] dma-pl330 fea30000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 4.292644] dma-pl330 fea30000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 4.293622] dma-pl330 fed10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 4.293627] dma-pl330 fed10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 4.294123] rockchip-pvtm fda40000.pvtm: pvtm@0 probed [ 4.294188] rockchip-pvtm fda50000.pvtm: pvtm@1 probed [ 4.294245] rockchip-pvtm fda60000.pvtm: pvtm@2 probed [ 4.294305] rockchip-pvtm fdaf0000.pvtm: pvtm@3 probed [ 4.294359] rockchip-pvtm fdb30000.pvtm: pvtm@4 probed [ 4.294945] rockchip-system-monitor rockchip-system-monitor: system monitor probe [ 4.295783] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [ 4.296295] febc0000.serial: ttyS9 at MMIO 0xfebc0000 (irq = 101, base_baud = 1500000) is a 16550A [ 4.297541] random: crng init done [ 4.297631] led_vk2c21_init ============================================= [ 4.298595] rockchip-vop2 fdd90000.vop: Adding to iommu group 17 [ 4.307073] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x5, primary plane phy id: 0 [ 4.307080] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp1 assign plane mask: 0xa, primary plane phy id: 1 [ 4.307086] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x140, primary plane phy id: 6 [ 4.307092] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp3 assign plane mask: 0x280, primary plane phy id: 7 [ 4.307185] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart0-win0 as cursor plane for vp0 [ 4.307288] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart1-win0 as cursor plane for vp1 [ 4.307374] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart2-win0 as cursor plane for vp2 [ 4.307455] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart3-win0 as cursor plane for vp3 [ 4.307474] [drm] failed to init overlay plane Cluster0-win1 [ 4.307477] [drm] failed to init overlay plane Cluster1-win1 [ 4.307479] [drm] failed to init overlay plane Cluster2-win1 [ 4.307481] [drm] failed to init overlay plane Cluster3-win1 [ 4.319152] rockchip-drm display-subsystem: bound fdd90000.vop (ops 0xffff8000091b2620) [ 4.320128] dwhdmi-rockchip fde80000.hdmi: registered ddc I2C bus driver [ 4.320343] rockchip-drm display-subsystem: bound fde80000.hdmi (ops 0xffff8000091c0798) [ 4.320421] rockchip-drm display-subsystem: bound fde50000.dp (ops 0xffff8000091c3278) [ 4.320893] rockchip-drm display-subsystem: failed to parse loader memory [ 4.476704] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x2 [ 4.547780] dwhdmi-rockchip fde80000.hdmi: use tmds mode [ 4.547819] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] Update mode to 1920x1080p60, type: 11(if:800) for vp0 dclk: 148500000 [ 4.547983] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] dclk_out0 div: 0 dclk_core0 div: 2 [ 4.548000] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx_ropll_cmn_config bus_width:16a8c8 rate:1485000 [ 4.548279] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy pll locked! [ 4.548285] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] set dclk_vop0 to 148500000, get 148500000 [ 4.548308] dwhdmi-rockchip fde80000.hdmi: final tmdsclk = 148500000 [ 4.548338] dwhdmi-rockchip fde80000.hdmi: don't use dsc mode [ 4.548341] dwhdmi-rockchip fde80000.hdmi: dw hdmi qp use tmds mode [ 4.548347] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: bus_width:0x16a8c8,bit_rate:1485000 [ 4.548541] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy lane locked! [ 4.558905] rk-pcie fe190000.pcie: PCIe Link up, LTSSM is 0x30011 [ 4.559084] rk-pcie fe190000.pcie: PCI host bridge to bus 0004:40 [ 4.559095] pci_bus 0004:40: root bus resource [bus 40-4f] [ 4.559104] pci_bus 0004:40: root bus resource [??? 0xf4000000-0xf40fffff flags 0x0] [ 4.559113] pci_bus 0004:40: root bus resource [io 0x0000-0xfffff] (bus address [0xf4100000-0xf41fffff]) [ 4.559120] pci_bus 0004:40: root bus resource [mem 0xf4200000-0xf4ffffff] [ 4.559127] pci_bus 0004:40: root bus resource [mem 0xa00000000-0xa3fffffff pref] [ 4.559172] pci 0004:40:00.0: [1d87:3588] type 01 class 0x060400 [ 4.559201] pci 0004:40:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref] [ 4.559280] pci 0004:40:00.0: supports D1 D2 [ 4.559286] pci 0004:40:00.0: PME# supported from D0 D1 D3hot [ 4.572096] pci 0004:40:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 4.572390] pci 0004:41:00.0: [144d:a804] type 00 class 0x010802 [ 4.572489] pci 0004:41:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit] [ 4.573225] pci 0004:41:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x1 link at 0004:40:00.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link) [ 4.594542] pci_bus 0004:41: busn_res: [bus 41-4f] end is updated to 41 [ 4.594571] pci 0004:40:00.0: BAR 8: assigned [mem 0xf4200000-0xf42fffff] [ 4.594582] pci 0004:40:00.0: BAR 6: assigned [mem 0xf4300000-0xf430ffff pref] [ 4.594595] pci 0004:41:00.0: BAR 0: assigned [mem 0xf4200000-0xf4203fff 64bit] [ 4.594636] pci 0004:40:00.0: PCI bridge to [bus 41] [ 4.594646] pci 0004:40:00.0: bridge window [mem 0xf4200000-0xf42fffff] [ 4.597999] pcieport 0004:40:00.0: PME: Signaling with IRQ 125 [ 4.631720] Console: switching to colour frame buffer device 240x67 [ 4.795640] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device [ 4.796345] [drm] Initialized rockchip 3.0.0 20140818 for display-subsystem on minor 0 [ 4.803390] brd: module loaded [ 4.806860] loop: module loaded [ 4.807080] zram: Added device: zram0 [ 4.807237] lkdtm: No crash points registered, enable through debugfs [ 4.807404] system_heap: orders[0] = 6 [ 4.807407] system_heap: orders[1] = 4 [ 4.807409] system_heap: orders[2] = 0 [ 4.808427] nvme nvme0: pci function 0004:41:00.0 [ 4.808464] nvme 0004:41:00.0: enabling device (0000 -> 0002) [ 4.810084] rockchip-spi feb20000.spi: no high_speed pinctrl state [ 4.811827] rk806 spi2.0: chip id: RK806,ver:0x2, 0x1 [ 4.811972] rk806 spi2.0: ON: 0x80 OFF:0x80 [ 4.814409] rk806-regulator rk806-regulator.6.auto: Looking up vcc1-supply from device tree [ 4.814419] vdd_gpu_s0: supplied by vcc5v0_sys [ 4.814425] vcc5v0_sys: could not add device link regulator.8: -ENOENT [ 4.815169] vdd_gpu_s0: 550 <--> 950 mV at 750 mV, enabled [ 4.815573] rk806-regulator rk806-regulator.6.auto: Looking up vcc2-supply from device tree [ 4.815580] vdd_cpu_lit_s0: supplied by vcc5v0_sys [ 4.815585] vcc5v0_sys: could not add device link regulator.9: -ENOENT [ 4.815850] vdd_cpu_lit_s0: 550 <--> 950 mV at 750 mV, enabled [ 4.816547] rk806-regulator rk806-regulator.6.auto: Looking up vcc3-supply from device tree [ 4.816553] vdd_log_s0: supplied by vcc5v0_sys [ 4.816559] vcc5v0_sys: could not add device link regulator.10: -ENOENT [ 4.816831] vdd_log_s0: 675 <--> 750 mV at 750 mV, enabled [ 4.817293] rk806-regulator rk806-regulator.6.auto: Looking up vcc4-supply from device tree [ 4.817299] vdd_vdenc_s0: supplied by vcc5v0_sys [ 4.817304] vcc5v0_sys: could not add device link regulator.11: -ENOENT [ 4.817568] vdd_vdenc_s0: 550 <--> 950 mV at 750 mV, enabled [ 4.818092] rk806-regulator rk806-regulator.6.auto: Looking up vcc5-supply from device tree [ 4.818098] vdd_ddr_s0: supplied by vcc5v0_sys [ 4.818102] vcc5v0_sys: could not add device link regulator.12: -ENOENT [ 4.818367] vdd_ddr_s0: 675 <--> 900 mV at 850 mV, enabled [ 4.818577] rk806-regulator rk806-regulator.6.auto: Looking up vcc6-supply from device tree [ 4.818584] vdd2_ddr_s3: supplied by vcc5v0_sys [ 4.818588] vcc5v0_sys: could not add device link regulator.13: -ENOENT [ 4.818920] vdd2_ddr_s3: at 500 mV, enabled [ 4.819280] rk806-regulator rk806-regulator.6.auto: Looking up vcc7-supply from device tree [ 4.819287] vdd_2v0_pldo_s3: supplied by vcc5v0_sys [ 4.819291] vcc5v0_sys: could not add device link regulator.14: -ENOENT [ 4.819555] vdd_2v0_pldo_s3: 2000 mV, enabled [ 4.819911] rk806-regulator rk806-regulator.6.auto: Looking up vcc8-supply from device tree [ 4.819917] vcc_3v3_s3: supplied by vcc5v0_sys [ 4.819922] vcc5v0_sys: could not add device link regulator.15: -ENOENT [ 4.820141] vcc_3v3_s3: 3300 mV, enabled [ 4.820611] rk806-regulator rk806-regulator.6.auto: Looking up vcc9-supply from device tree [ 4.820617] vddq_ddr_s0: supplied by vcc5v0_sys [ 4.820621] vcc5v0_sys: could not add device link regulator.16: -ENOENT [ 4.820951] vddq_ddr_s0: at 500 mV, enabled [ 4.821315] rk806-regulator rk806-regulator.6.auto: Looking up vcc10-supply from device tree [ 4.821321] vcc_1v8_s3: supplied by vcc5v0_sys [ 4.821326] vcc5v0_sys: could not add device link regulator.17: -ENOENT [ 4.821613] vcc_1v8_s3: 1800 mV, enabled [ 4.821970] rk806-regulator rk806-regulator.6.auto: Looking up vcc13-supply from device tree [ 4.822051] vdd_0v75_s3: supplied by vcc_1v1_nldo_s3 [ 4.822059] vcc_1v1_nldo_s3: could not add device link regulator.18: -ENOENT [ 4.822372] vdd_0v75_s3: 750 mV, enabled [ 4.822803] rk806-regulator rk806-regulator.6.auto: Looking up vcc13-supply from device tree [ 4.822811] vdd_ddr_pll_s0: supplied by vcc_1v1_nldo_s3 [ 4.822816] vcc_1v1_nldo_s3: could not add device link regulator.19: -ENOENT [ 4.823081] vdd_ddr_pll_s0: 850 mV, enabled [ 4.823393] avdd_0v75_s0: Bringing 750000uV into 837500-837500uV [ 4.823567] avdd_0v75_s0: ramp_delay not set [ 4.823644] rk806-regulator rk806-regulator.6.auto: Looking up vcc13-supply from device tree [ 4.823654] avdd_0v75_s0: supplied by vcc_1v1_nldo_s3 [ 4.823661] vcc_1v1_nldo_s3: could not add device link regulator.20: -ENOENT [ 4.823918] avdd_0v75_s0: 837 mV, enabled [ 4.824340] rk806-regulator rk806-regulator.6.auto: Looking up vcc14-supply from device tree [ 4.824349] vdd_0v85_s0: supplied by vcc_1v1_nldo_s3 [ 4.824355] vcc_1v1_nldo_s3: could not add device link regulator.21: -ENOENT [ 4.824598] vdd_0v85_s0: 850 mV, enabled [ 4.824961] rk806-regulator rk806-regulator.6.auto: Looking up vcc14-supply from device tree [ 4.824968] vdd_0v75_s0: supplied by vcc_1v1_nldo_s3 [ 4.824973] vcc_1v1_nldo_s3: could not add device link regulator.22: -ENOENT [ 4.825206] vdd_0v75_s0: 750 mV, enabled [ 4.825626] rk806-regulator rk806-regulator.6.auto: Looking up vcc11-supply from device tree [ 4.825668] avcc_1v8_s0: supplied by vdd_2v0_pldo_s3 [ 4.825675] vdd_2v0_pldo_s3: could not add device link regulator.23: -ENOENT [ 4.825976] avcc_1v8_s0: 1800 mV, enabled [ 4.826398] rk806-regulator rk806-regulator.6.auto: Looking up vcc11-supply from device tree [ 4.826406] vcc_1v8_s0: supplied by vdd_2v0_pldo_s3 [ 4.826411] vdd_2v0_pldo_s3: could not add device link regulator.24: -ENOENT [ 4.826702] vcc_1v8_s0: 1800 mV, enabled [ 4.827052] rk806-regulator rk806-regulator.6.auto: Looking up vcc11-supply from device tree [ 4.827060] avdd_1v2_s0: supplied by vdd_2v0_pldo_s3 [ 4.827064] vdd_2v0_pldo_s3: could not add device link regulator.25: -ENOENT [ 4.827356] avdd_1v2_s0: 1200 mV, enabled [ 4.827704] rk806-regulator rk806-regulator.6.auto: Looking up vcc12-supply from device tree [ 4.827710] vcc_3v3_s0: supplied by vcc5v0_sys [ 4.827715] vcc5v0_sys: could not add device link regulator.26: -ENOENT [ 4.827937] vcc_3v3_s0: 3300 mV, enabled [ 4.828279] rk806-regulator rk806-regulator.6.auto: Looking up vcc12-supply from device tree [ 4.828285] vccio_sd_s0: supplied by vcc5v0_sys [ 4.828290] vcc5v0_sys: could not add device link regulator.27: -ENOENT [ 4.828534] vccio_sd_s0: 1800 <--> 3300 mV at 3300 mV, enabled [ 4.828897] rk806-regulator rk806-regulator.6.auto: Looking up vcca-supply from device tree [ 4.828903] pldo6_s3: supplied by vcc5v0_sys [ 4.828908] vcc5v0_sys: could not add device link regulator.28: -ENOENT [ 4.829131] pldo6_s3: 1800 mV, enabled [ 4.829481] rk806 spi2.0: no sleep-setting state [ 4.829485] rk806 spi2.0: no reset-setting pinctrl state [ 4.829488] rk806 spi2.0: no dvs-setting pinctrl state [ 4.831009] rockchip-spi feb20000.spi: register misc device rkspi-dev2 [ 4.831014] rockchip-spi feb20000.spi: probed, poll=0, rsd=0 [ 4.832648] spi-nor spi5.0: XM25QU128C (16384 Kbytes) read_data x4 [ 4.832665] 1 fixed-partitions partitions found on MTD device sfc_nor [ 4.832668] Creating 1 MTD partitions on "sfc_nor": [ 4.832673] 0x000000000000-0x000001000000 : "loader" [ 4.834713] rk_gmac-dwmac fe1c0000.ethernet: IRQ eth_lpi not found [ 4.834860] rk_gmac-dwmac fe1c0000.ethernet: Looking up phy-supply from device tree [ 4.834873] rk_gmac-dwmac fe1c0000.ethernet: Looking up phy-supply property in node /ethernet@fe1c0000 failed [ 4.834885] rk_gmac-dwmac fe1c0000.ethernet: no regulator found [ 4.834890] rk_gmac-dwmac fe1c0000.ethernet: clock input or output? (output). [ 4.834894] rk_gmac-dwmac fe1c0000.ethernet: TX delay(0x42). [ 4.834898] rk_gmac-dwmac fe1c0000.ethernet: Can not read property: rx_delay. [ 4.834902] rk_gmac-dwmac fe1c0000.ethernet: set rx_delay to 0xffffffff [ 4.834910] rk_gmac-dwmac fe1c0000.ethernet: integrated PHY? (no). [ 4.834915] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_rx [ 4.834920] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_tx [ 4.834937] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock clk_mac_speed [ 4.835158] rk_gmac-dwmac fe1c0000.ethernet: init for RGMII_RXID [ 4.835254] rk_gmac-dwmac fe1c0000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 4.835259] rk_gmac-dwmac fe1c0000.ethernet: DWMAC4/5 [ 4.835264] rk_gmac-dwmac fe1c0000.ethernet: DMA HW capability register supported [ 4.835267] rk_gmac-dwmac fe1c0000.ethernet: RX Checksum Offload Engine supported [ 4.835270] rk_gmac-dwmac fe1c0000.ethernet: TX Checksum insertion supported [ 4.835273] rk_gmac-dwmac fe1c0000.ethernet: Wake-Up On Lan supported [ 4.835307] rk_gmac-dwmac fe1c0000.ethernet: TSO supported [ 4.835311] rk_gmac-dwmac fe1c0000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 4.835316] rk_gmac-dwmac fe1c0000.ethernet: Enabled Flow TC (entries=2) [ 4.835319] rk_gmac-dwmac fe1c0000.ethernet: TSO feature enabled [ 4.835323] rk_gmac-dwmac fe1c0000.ethernet: Using 32 bits DMA width [ 4.835814] nvme nvme0: 7/0/0 default/read/poll queues [ 4.848168] nvme0n1: p1 p2 [ 4.978218] usbcore: registered new interface driver rndis_wlan [ 4.978239] usbcore: registered new interface driver asix [ 4.978254] usbcore: registered new interface driver cdc_ether [ 4.978272] usbcore: registered new interface driver rndis_host [ 4.978293] usbcore: registered new interface driver cdc_ncm [ 4.983673] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up usb-supply from device tree [ 4.983702] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up usb-supply property in node /power-management@fd8d8000/power-controller failed [ 4.985650] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 4.985660] ehci-pci: EHCI PCI platform driver [ 4.985693] ehci-platform: EHCI generic platform driver [ 4.987955] ehci-platform fc800000.usb: EHCI Host Controller [ 4.987968] ehci-platform fc800000.usb: new USB bus registered, assigned bus number 1 [ 4.988037] ehci-platform fc800000.usb: irq 20, io mem 0xfc800000 [ 4.998884] ehci-platform fc800000.usb: USB 2.0 started, EHCI 1.00 [ 4.999000] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 4.999005] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.999008] usb usb1: Product: EHCI Host Controller [ 4.999012] usb usb1: Manufacturer: Linux 5.10.160-rk35xx ehci_hcd [ 4.999014] usb usb1: SerialNumber: fc800000.usb [ 4.999517] hub 1-0:1.0: USB hub found [ 4.999566] hub 1-0:1.0: 1 port detected [ 5.002542] ehci-platform fc880000.usb: EHCI Host Controller [ 5.002567] ehci-platform fc880000.usb: new USB bus registered, assigned bus number 2 [ 5.002707] ehci-platform fc880000.usb: irq 22, io mem 0xfc880000 [ 5.015584] ehci-platform fc880000.usb: USB 2.0 started, EHCI 1.00 [ 5.015868] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 5.015878] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.015886] usb usb2: Product: EHCI Host Controller [ 5.015894] usb usb2: Manufacturer: Linux 5.10.160-rk35xx ehci_hcd [ 5.015901] usb usb2: SerialNumber: fc880000.usb [ 5.016432] hub 2-0:1.0: USB hub found [ 5.016480] hub 2-0:1.0: 1 port detected [ 5.017538] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 5.017560] ohci-platform: OHCI generic platform driver [ 5.017913] ohci-platform fc840000.usb: Generic Platform OHCI controller [ 5.017935] ohci-platform fc840000.usb: new USB bus registered, assigned bus number 3 [ 5.018051] ohci-platform fc840000.usb: irq 21, io mem 0xfc840000 [ 5.076475] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10 [ 5.076486] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.076495] usb usb3: Product: Generic Platform OHCI controller [ 5.076502] usb usb3: Manufacturer: Linux 5.10.160-rk35xx ohci_hcd [ 5.076510] usb usb3: SerialNumber: fc840000.usb [ 5.077039] hub 3-0:1.0: USB hub found [ 5.077089] hub 3-0:1.0: 1 port detected [ 5.077801] ohci-platform fc8c0000.usb: Generic Platform OHCI controller [ 5.077822] ohci-platform fc8c0000.usb: new USB bus registered, assigned bus number 4 [ 5.077939] ohci-platform fc8c0000.usb: irq 23, io mem 0xfc8c0000 [ 5.136465] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10 [ 5.136476] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.136484] usb usb4: Product: Generic Platform OHCI controller [ 5.136492] usb usb4: Manufacturer: Linux 5.10.160-rk35xx ohci_hcd [ 5.136500] usb usb4: SerialNumber: fc8c0000.usb [ 5.137025] hub 4-0:1.0: USB hub found [ 5.137073] hub 4-0:1.0: 1 port detected [ 5.138638] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 5.138660] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 5 [ 5.138806] xhci-hcd xhci-hcd.7.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000200002010010 [ 5.138855] xhci-hcd xhci-hcd.7.auto: irq 139, io mem 0xfcd00000 [ 5.139285] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 5.139295] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.139303] usb usb5: Product: xHCI Host Controller [ 5.139311] usb usb5: Manufacturer: Linux 5.10.160-rk35xx xhci-hcd [ 5.139318] usb usb5: SerialNumber: xhci-hcd.7.auto [ 5.139844] hub 5-0:1.0: USB hub found [ 5.139894] hub 5-0:1.0: 1 port detected [ 5.140301] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 5.140318] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 6 [ 5.140334] xhci-hcd xhci-hcd.7.auto: Host supports USB 3.0 SuperSpeed [ 5.140444] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM. [ 5.140626] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 [ 5.140637] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.140645] usb usb6: Product: xHCI Host Controller [ 5.140652] usb usb6: Manufacturer: Linux 5.10.160-rk35xx xhci-hcd [ 5.140660] usb usb6: SerialNumber: xhci-hcd.7.auto [ 5.141204] hub 6-0:1.0: USB hub found [ 5.141251] hub 6-0:1.0: 1 port detected [ 5.141808] usbcore: registered new interface driver cdc_acm [ 5.141815] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 5.142017] usbcore: registered new interface driver uas [ 5.142172] usbcore: registered new interface driver usb-storage [ 5.143691] Error: Driver 'Goodix-TS' is already registered, aborting... [ 5.143788] usbcore: registered new interface driver usbtouchscreen [ 5.145832] input: rk805 pwrkey as /devices/platform/feb20000.spi/spi_master/spi2/spi2.0/rk805-pwrkey.5.auto/input/input0 [ 5.146515] i2c /dev entries driver [ 5.151193] rk860-regulator 0-0042: Looking up vin-supply from device tree [ 5.151209] vdd_cpu_big0_s0: supplied by vcc5v0_sys [ 5.151223] vcc5v0_sys: could not add device link regulator.29: -ENOENT [ 5.155487] vdd_cpu_big0_s0: 550 <--> 1050 mV at 800 mV, enabled [ 5.160604] rk860-regulator 0-0043: Looking up vin-supply from device tree [ 5.160618] vdd_cpu_big1_s0: supplied by vcc5v0_sys [ 5.160630] vcc5v0_sys: could not add device link regulator.30: -ENOENT [ 5.164890] vdd_cpu_big1_s0: 550 <--> 1050 mV at 800 mV, enabled [ 5.168320] Goodix-TS 2-0014: Looking up AVDD28-supply from device tree [ 5.168339] Goodix-TS 2-0014: Looking up AVDD28-supply property in node /i2c@feaa0000/touchscreen@14 failed [ 5.168366] Goodix-TS 2-0014: supply AVDD28 not found, using dummy regulator [ 5.168503] Goodix-TS 2-0014: Looking up VDDIO-supply from device tree [ 5.168522] Goodix-TS 2-0014: Looking up VDDIO-supply property in node /i2c@feaa0000/touchscreen@14 failed [ 5.168545] Goodix-TS 2-0014: supply VDDIO not found, using dummy regulator [ 5.259072] Goodix-TS 2-0014: i2c test failed attempt 1: -6 [ 5.285734] Goodix-TS 2-0014: i2c test failed attempt 2: -6 [ 5.312238] Goodix-TS 2-0014: I2C communication failure: -6 [ 5.315848] rk860-regulator 2-0042: Looking up vin-supply from device tree [ 5.315863] vdd_npu_s0: supplied by vcc5v0_sys [ 5.315875] vcc5v0_sys: could not add device link regulator.31: -ENOENT [ 5.320113] vdd_npu_s0: 550 <--> 950 mV at 800 mV, enabled [ 5.325334] typec_fusb302 6-0022: Looking up vbus-supply from device tree [ 5.353518] rtc-hym8563 6-0051: rtc information is valid [ 5.358856] rtc-hym8563 6-0051: registered as rtc0 [ 5.359889] rtc-hym8563 6-0051: setting system clock to 2023-08-07T18:18:31 UTC (1691432311) [ 5.362495] Goodix-TS 7-0014: Looking up AVDD28-supply from device tree [ 5.362504] Goodix-TS 7-0014: Looking up AVDD28-supply property in node /i2c@fec90000/touchscreen@14 failed [ 5.362518] Goodix-TS 7-0014: supply AVDD28 not found, using dummy regulator [ 5.362581] Goodix-TS 7-0014: Looking up VDDIO-supply from device tree [ 5.362588] Goodix-TS 7-0014: Looking up VDDIO-supply property in node /i2c@fec90000/touchscreen@14 failed [ 5.362597] Goodix-TS 7-0014: supply VDDIO not found, using dummy regulator [ 5.455692] Goodix-TS 7-0014: i2c test failed attempt 1: -6 [ 5.482354] Goodix-TS 7-0014: i2c test failed attempt 2: -6 [ 5.508875] Goodix-TS 7-0014: I2C communication failure: -6 [ 5.509877] rkcifhw fdce0000.rkcif: Adding to iommu group 16 [ 5.510224] rkcifhw fdce0000.rkcif: No reserved memory region assign to CIF [ 5.511373] rkisp_hw fdcb0000.rkisp: Adding to iommu group 14 [ 5.511487] rkisp_hw fdcb0000.rkisp: is_thunderboot: 0 [ 5.511491] rkisp_hw fdcb0000.rkisp: max input:0x0@0fps [ 5.511495] rkisp_hw fdcb0000.rkisp: Missing rockchip,grf property [ 5.511596] rkisp_hw fdcb0000.rkisp: no find phandle sram [ 5.511665] rkisp_hw fdcc0000.rkisp: Adding to iommu group 15 [ 5.511819] rkisp_hw fdcc0000.rkisp: is_thunderboot: 0 [ 5.511823] rkisp_hw fdcc0000.rkisp: max input:0x0@0fps [ 5.511827] rkisp_hw fdcc0000.rkisp: Missing rockchip,grf property [ 5.511919] rkisp_hw fdcc0000.rkisp: no find phandle sram [ 5.512880] usbcore: registered new interface driver uvcvideo [ 5.512883] USB Video Class driver (1.1.1) [ 5.514756] cpu cpu0: Looking up cpu-supply from device tree [ 5.515750] cpu cpu0: bin=0 [ 5.515950] cpu cpu0: leakage=8 [ 5.515994] cpu cpu0: Looking up cpu-supply from device tree [ 5.517622] cpu cpu0: pvtm=1380 [ 5.517947] cpu cpu0: pvtm-volt-sel=0 [ 5.518110] cpu cpu0: Looking up cpu-supply from device tree [ 5.518385] cpu cpu0: Looking up mem-supply from device tree [ 5.518727] cpu cpu4: Looking up cpu-supply from device tree [ 5.520698] cpu cpu4: bin=0 [ 5.520889] cpu cpu4: leakage=6 [ 5.520929] cpu cpu4: Looking up cpu-supply from device tree [ 5.527738] cpu cpu4: pvtm=1588 [ 5.531912] cpu cpu4: pvtm-volt-sel=0 [ 5.532003] cpu cpu4: Looking up cpu-supply from device tree [ 5.532615] cpu cpu4: Looking up mem-supply from device tree [ 5.533319] cpu cpu6: Looking up cpu-supply from device tree [ 5.535291] cpu cpu6: bin=0 [ 5.535482] cpu cpu6: leakage=6 [ 5.535522] cpu cpu6: Looking up cpu-supply from device tree [ 5.542358] cpu cpu6: pvtm=1590 [ 5.546634] cpu cpu6: pvtm-volt-sel=0 [ 5.546726] cpu cpu6: Looking up cpu-supply from device tree [ 5.547336] cpu cpu6: Looking up mem-supply from device tree [ 5.549809] cpu cpu0: avs=0 [ 5.551869] cpu cpu4: avs=0 [ 5.552253] usb 3-1: new full-speed USB device number 2 using ohci-platform [ 5.554109] cpu cpu6: avs=0 [ 5.554511] cpu cpu0: EM: OPP:816000 is inefficient [ 5.554519] cpu cpu0: EM: OPP:600000 is inefficient [ 5.554783] cpu cpu0: EM: created perf domain [ 5.554867] cpu cpu0: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=1608000000 h_table=0 [ 5.555964] cpu cpu4: EM: OPP:816000 is inefficient [ 5.555973] cpu cpu4: EM: OPP:600000 is inefficient [ 5.556158] cpu cpu4: EM: created perf domain [ 5.556192] cpu cpu4: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0 [ 5.564531] cpu cpu6: EM: OPP:816000 is inefficient [ 5.564535] cpu cpu6: EM: OPP:600000 is inefficient [ 5.564704] cpu cpu6: EM: created perf domain [ 5.565199] cpu cpu6: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0 [ 5.581845] sdhci: Secure Digital Host Controller Interface driver [ 5.581852] sdhci: Copyright(c) Pierre Ossman [ 5.581859] Synopsys Designware Multimedia Card Interface Driver [ 5.583106] sdhci-pltfm: SDHCI platform and OF driver helper [ 5.586982] ledtrig-cpu: registered to indicate activity on CPUs [ 5.587034] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active. [ 5.587112] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 5.588813] cryptodev: driver 1.12 loaded. [ 5.588886] hid: raw HID events driver (C) Jiri Kosina [ 5.589109] usbcore: registered new interface driver usbhid [ 5.589113] usbhid: USB HID core driver [ 5.589308] ashmem: initialized [ 5.592355] rockchip-saradc fec10000.saradc: Looking up vref-supply from device tree [ 5.593406] optee: probing for conduit method. [ 5.593411] optee: api uid mismatch [ 5.593420] optee: probe of firmware:optee failed with error -22 [ 5.594129] usbcore: registered new interface driver snd-usb-audio [ 5.598744] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up audio-supply from device tree [ 5.598774] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up audio-supply property in node /power-management@fd8d8000/power-controller failed [ 5.603717] debugfs: File 'Capture' in directory 'dapm' already present! [ 5.605586] input: rockchip-dp0 rockchip-dp0 as /devices/platform/dp0-sound/sound/card0/input1 [ 5.608066] input: rockchip-hdmi0 rockchip-hdmi0 as /devices/platform/hdmi0-sound/sound/card1/input2 [ 5.609936] input: headset-keys as /devices/platform/es8388-sound/input/input3 [ 5.623802] ES8323 6-0010: ASoC: error at soc_component_write_no_lock on ES8323.6-0010: -5 [ 5.678548] input: rockchip-es8388 Headset as /devices/platform/es8388-sound/sound/card2/input4 [ 5.679279] Initializing XFRM netlink socket [ 5.679294] NET: Registered protocol family 17 [ 5.679676] [BT_RFKILL]: Enter rfkill_rk_init [ 5.679680] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 5.680072] Key type dns_resolver registered [ 5.681440] registered taskstats version 1 [ 5.681448] Loading compiled-in X.509 certificates [ 5.682212] Btrfs loaded, crc32c=crc32c-generic [ 5.682336] pstore: Using crash dump compression: deflate [ 5.682555] rga3_core0 fdb60000.rga: Adding to iommu group 2 [ 5.682740] rga: rga3_core0, irq = 35, match scheduler [ 5.683265] rga: rga3_core0 hardware loaded successfully, hw_version:3.0.76831. [ 5.683315] rga: rga3_core0 probe successfully [ 5.683615] rga3_core1 fdb70000.rga: Adding to iommu group 3 [ 5.683799] rga: rga3_core1, irq = 36, match scheduler [ 5.684353] rga: rga3_core1 hardware loaded successfully, hw_version:3.0.76831. [ 5.684401] rga: rga3_core1 probe successfully [ 5.684740] rga: rga2, irq = 37, match scheduler [ 5.685283] rga: rga2 hardware loaded successfully, hw_version:3.2.63318. [ 5.685292] rga: rga2 probe successfully [ 5.685497] rga_iommu: IOMMU binding successfully, default mapping core[0x1] [ 5.685785] rga: Module initialized. v1.2.25 [ 5.735242] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up gpu-supply from device tree [ 5.735419] reg-fixed-voltage combophy-avdd0v85: Looking up vin-supply from device tree [ 5.735607] combophy_avdd0v85: supplied by vdd_0v85_s0 [ 5.735622] vdd_0v85_s0: could not add device link regulator.32: -ENOENT [ 5.735670] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up gpu-supply property in node /power-management@fd8d8000/power-controller failed [ 5.735874] mali fb000000.gpu: Kernel DDK version g17p0-01eac0 [ 5.736045] mali fb000000.gpu: Looking up mali-supply from device tree [ 5.736316] mali fb000000.gpu: Looking up mem-supply from device tree [ 5.736594] combophy_avdd0v85: 850 mV, enabled [ 5.736813] mali fb000000.gpu: Looking up mali-supply from device tree [ 5.736843] vdd_gpu_s0: could not add device link fb000000.gpu: -EEXIST [ 5.736849] vdd_gpu_s0: Failed to create debugfs directory [ 5.736859] mali fb000000.gpu: Looking up mem-supply from device tree [ 5.736882] vdd_gpu_s0: could not add device link fb000000.gpu: -EEXIST [ 5.736888] vdd_gpu_s0: Failed to create debugfs directory [ 5.736943] reg-fixed-voltage combophy-avdd0v85: combophy_avdd0v85 supplying 850000uV [ 5.737097] mali fb000000.gpu: Looking up mali-supply from device tree [ 5.737128] vdd_gpu_s0: could not add device link fb000000.gpu: -EEXIST [ 5.737134] vdd_gpu_s0: Failed to create debugfs directory [ 5.737191] reg-fixed-voltage combophy-avdd1v8: Looking up vin-supply from device tree [ 5.737412] combophy_avdd1v8: supplied by avcc_1v8_s0 [ 5.737425] avcc_1v8_s0: could not add device link regulator.33: -ENOENT [ 5.737587] mali fb000000.gpu: bin=0 [ 5.737779] mali fb000000.gpu: leakage=13 [ 5.737820] mali fb000000.gpu: Looking up mali-supply from device tree [ 5.737827] combophy_avdd1v8: 1800 mV, enabled [ 5.737860] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present! [ 5.738107] reg-fixed-voltage combophy-avdd1v8: combophy_avdd1v8 supplying 1800000uV [ 5.738366] vcc_3v3_sd_s0: 3300 mV, disabled [ 5.738540] reg-fixed-voltage vcc-3v3-sd-s0: Looking up vin-supply from device tree [ 5.738558] vcc_3v3_sd_s0: supplied by vcc_3v3_s3 [ 5.739048] reg-fixed-voltage vcc-3v3-sd-s0: vcc_3v3_sd_s0 supplying 3300000uV [ 5.739296] mali fb000000.gpu: pvtm=847 [ 5.739832] mali fb000000.gpu: pvtm-volt-sel=2 [ 5.740114] rockchip-dmc dmc: Looking up center-supply from device tree [ 5.740758] rockchip-dmc dmc: Looking up mem-supply from device tree [ 5.741258] mali fb000000.gpu: avs=0 [ 5.741303] rockchip-dmc dmc: Looking up center-supply from device tree [ 5.741336] vdd_ddr_s0: could not add device link dmc: -EEXIST [ 5.741343] vdd_ddr_s0: Failed to create debugfs directory [ 5.741551] rockchip-dmc dmc: Looking up mem-supply from device tree [ 5.741576] vdd_log_s0: could not add device link dmc: -EEXIST [ 5.741582] vdd_log_s0: Failed to create debugfs directory [ 5.741750] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 143; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available. [ 5.742243] rockchip-dmc dmc: leakage=30 [ 5.742265] rockchip-dmc dmc: leakage-volt-sel=0 [ 5.742389] mali fb000000.gpu: GPU hardware issue table may need updating: r0p0 status 5 is unknown; treating as r0p0 status 0 [ 5.742402] mali fb000000.gpu: GPU identified as 0x7 arch 10.8.6 r0p0 status 0 [ 5.742477] mali fb000000.gpu: No priority control manager is configured [ 5.742924] mali fb000000.gpu: No memory group manager is configured [ 5.742958] rockchip-dmc dmc: avs=0 [ 5.742967] mali fb000000.gpu: Protected memory allocator not available [ 5.742981] rockchip-dmc dmc: current ATF version 0x100 [ 5.743155] rockchip-dmc dmc: normal_rate = 1560000000 [ 5.743165] rockchip-dmc dmc: reboot_rate = 2112000000 [ 5.743173] rockchip-dmc dmc: suspend_rate = 528000000 [ 5.743183] rockchip-dmc dmc: video_4k_rate = 1560000000 [ 5.743192] rockchip-dmc dmc: video_4k_10b_rate = 1560000000 [ 5.743200] rockchip-dmc dmc: video_svep_rate = 1560000000 [ 5.743208] rockchip-dmc dmc: boost_rate = 2112000000 [ 5.743218] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 2112000000 [ 5.743226] rockchip-dmc dmc: performance_rate = 2112000000 [ 5.743236] rockchip-dmc dmc: hdmirx_rate = 2112000000 [ 5.743252] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate [ 5.743260] rockchip-dmc dmc: failed to get vop pn to msch rl [ 5.743483] rockchip-dmc dmc: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0 [ 5.744193] mali fb000000.gpu: Capping CSF_FIRMWARE_TIMEOUT to CSF_FIRMWARE_PING_TIMEOUT [ 5.744559] rockchip-dmc dmc: could not find power_model node [ 5.745473] mali fb000000.gpu: Couldn't find power_model DT node matching 'arm,mali-simple-power-model' [ 5.745489] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.static-coefficient = 1*[0] [ 5.745860] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.dynamic-coefficient = 1*[0] [ 5.746165] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.ts = 4*[0] [ 5.746376] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.thermal-zone = '' [ 5.749061] mali fb000000.gpu: Using configured power model mali-lodx-power-model, and fallback mali-simple-power-model [ 5.749248] mali fb000000.gpu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0 [ 5.749838] input: adc-keys as /devices/platform/adc-keys/input/input5 [ 5.750480] mali fb000000.gpu: Probed as mali0 [ 5.752113] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode. [ 5.752148] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller. [ 5.752155] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a [ 5.752186] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up sdio-supply from device tree [ 5.752191] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 90,32 bit host data width,256 deep fifo [ 5.752231] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up sdio-supply property in node /power-management@fd8d8000/power-controller failed [ 5.752268] dwmmc_rockchip fe2c0000.mmc: Looking up vmmc-supply from device tree [ 5.752271] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up pcie-supply from device tree [ 5.752361] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up pcie-supply property in node /power-management@fd8d8000/power-controller failed [ 5.752396] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu-supply from device tree [ 5.752417] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu-supply property in node /power-management@fd8d8000/power-controller failed [ 5.752448] dwmmc_rockchip fe2c0000.mmc: Looking up vqmmc-supply from device tree [ 5.753591] RKNPU fdab0000.npu: Adding to iommu group 0 [ 5.753710] RKNPU fdab0000.npu: RKNPU: rknpu iommu is enabled, using iommu mode [ 5.753790] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 5.754441] RKNPU fdab0000.npu: Looking up mem-supply from device tree [ 5.755059] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff] [ 5.755083] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff] [ 5.755097] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff] [ 5.755608] [drm] Initialized rknpu 0.8.5 20230202 for fdab0000.npu on minor 1 [ 5.756078] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up nputop-supply from device tree [ 5.756115] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up nputop-supply property in node /power-management@fd8d8000/power-controller failed [ 5.756206] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu1-supply from device tree [ 5.756240] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu1-supply property in node /power-management@fd8d8000/power-controller failed [ 5.756308] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu2-supply from device tree [ 5.756341] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu2-supply property in node /power-management@fd8d8000/power-controller failed [ 5.756526] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 5.756556] vdd_npu_s0: could not add device link fdab0000.npu: -EEXIST [ 5.756561] vdd_npu_s0: Failed to create debugfs directory [ 5.757148] RKNPU fdab0000.npu: Looking up mem-supply from device tree [ 5.757182] vdd_npu_s0: could not add device link fdab0000.npu: -EEXIST [ 5.757186] vdd_npu_s0: Failed to create debugfs directory [ 5.757850] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 5.757876] vdd_npu_s0: could not add device link fdab0000.npu: -EEXIST [ 5.757880] vdd_npu_s0: Failed to create debugfs directory [ 5.759900] RKNPU fdab0000.npu: RKNPU: bin=0 [ 5.760081] RKNPU fdab0000.npu: leakage=7 [ 5.760109] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 5.760134] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present! [ 5.767612] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 5.768779] RKNPU fdab0000.npu: pvtm=846 [ 5.772738] usb 3-1: New USB device found, idVendor=046d, idProduct=c539, bcdDevice=39.06 [ 5.772749] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 5.772754] usb 3-1: Product: USB Receiver [ 5.772759] usb 3-1: Manufacturer: Logitech [ 5.774004] RKNPU fdab0000.npu: pvtm-volt-sel=2 [ 5.774913] RKNPU fdab0000.npu: avs=0 [ 5.775074] RKNPU fdab0000.npu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0 [ 5.781541] input: Logitech USB Receiver as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.0/0003:046D:C539.0001/input/input6 [ 5.786329] RKNPU fdab0000.npu: failed to find power_model node [ 5.786338] RKNPU fdab0000.npu: RKNPU: failed to initialize power model [ 5.786345] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient [ 5.788984] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 5.801837] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 5.808379] rockchip-pm rockchip-suspend: not set pwm-regulator-config [ 5.808403] rockchip-suspend not set sleep-mode-config for mem-lite [ 5.808410] rockchip-suspend not set wakeup-config for mem-lite [ 5.808423] rockchip-suspend not set sleep-mode-config for mem-ultra [ 5.808429] rockchip-suspend not set wakeup-config for mem-ultra [ 5.810931] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 406; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '13:36:29', on 'Jul 6 2023'. [ 5.811606] Mali: [ 5.811612] Mali device driver loaded [ 5.811624] ALSA device list: [ 5.811632] #0: rockchip-dp0 [ 5.811639] #1: rockchip-hdmi0 [ 5.811646] #2: rockchip-es8388 [ 5.817827] Freeing unused kernel memory: 6976K [ 5.837080] hid-generic 0003:046D:C539.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-fc840000.usb-1/input0 [ 5.843877] input: Logitech USB Receiver Mouse as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input7 [ 5.869503] Run /init as init process [ 5.869523] with arguments: [ 5.869536] /init [ 5.869548] splash [ 5.869555] with environment: [ 5.869562] HOME=/ [ 5.869568] TERM=linux [ 5.869575] ubootpart= [ 5.869582] cgroup_enable=memory [ 5.869589] cgroup_memory=1 [ 5.902479] input: Logitech USB Receiver Consumer Control as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input8 [ 5.902764] input: Logitech USB Receiver System Control as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input9 [ 5.903212] hid-generic 0003:046D:C539.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-fc840000.usb-1/input1 [ 5.911691] hid-generic 0003:046D:C539.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-fc840000.usb-1/input2 [ 6.949430] EXT4-fs (nvme0n1p2): mounted filesystem with writeback data mode. Opts: (null) [ 7.179151] NET: Registered protocol family 10 [ 7.180510] Segment Routing with IPv6 [ 7.197803] systemd[1]: systemd 249.11-0ubuntu3.9 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified) [ 7.199167] systemd[1]: Detected architecture arm64. [ 7.200120] systemd[1]: Hostname set to . [ 7.517128] systemd[1]: Queued start job for default target Graphical Interface. [ 7.518709] systemd[1]: Created slice Slice /system/modprobe. [ 7.519423] systemd[1]: Created slice Slice /system/serial-getty. [ 7.519924] systemd[1]: Created slice Slice /system/systemd-fsck. [ 7.520212] systemd[1]: Created slice User and Session Slice. [ 7.520336] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 7.520649] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 7.520765] systemd[1]: Reached target User and Group Name Lookups. [ 7.520812] systemd[1]: Reached target Slice Units. [ 7.520845] systemd[1]: Reached target Swaps. [ 7.520877] systemd[1]: Reached target System Time Set. [ 7.520940] systemd[1]: Reached target Local Verity Protected Volumes. [ 7.530945] systemd[1]: Listening on RPCbind Server Activation Socket. [ 7.531289] systemd[1]: Listening on Syslog Socket. [ 7.531516] systemd[1]: Listening on fsck to fsckd communication Socket. [ 7.531678] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 7.532040] systemd[1]: Listening on Journal Audit Socket. [ 7.532255] systemd[1]: Listening on Journal Socket (/dev/log). [ 7.532499] systemd[1]: Listening on Journal Socket. [ 7.533488] systemd[1]: Listening on udev Control Socket. [ 7.533705] systemd[1]: Listening on udev Kernel Socket. [ 7.535129] systemd[1]: Mounting Huge Pages File System... [ 7.536811] systemd[1]: Mounting POSIX Message Queue File System... [ 7.538583] systemd[1]: Mounting Kernel Debug File System... [ 7.540705] systemd[1]: Mounting Kernel Trace File System... [ 7.541084] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped. [ 7.543264] systemd[1]: Starting Restore / save the current clock... [ 7.545355] systemd[1]: Starting Set the console keyboard layout... [ 7.547408] systemd[1]: Starting Create List of Static Device Nodes... [ 7.549442] systemd[1]: Starting Load Kernel Module chromeos_pstore... [ 7.551486] systemd[1]: Starting Load Kernel Module configfs... [ 7.553803] systemd[1]: Starting Load Kernel Module drm... [ 7.556041] systemd[1]: Starting Load Kernel Module efi_pstore... [ 7.558203] systemd[1]: Starting Load Kernel Module fuse... [ 7.561036] systemd[1]: Starting Load Kernel Module pstore_blk... [ 7.563275] systemd[1]: Starting Load Kernel Module pstore_zone... [ 7.564594] fuse: init (API version 7.32) [ 7.565791] systemd[1]: Starting Load Kernel Module ramoops... [ 7.566178] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 7.568979] systemd[1]: Starting Load Kernel Modules... [ 7.570674] systemd[1]: Starting Remount Root and Kernel File Systems... [ 7.572780] systemd[1]: Starting Coldplug All udev Devices... [ 7.575708] systemd[1]: Mounted Huge Pages File System. [ 7.576026] systemd[1]: Mounted POSIX Message Queue File System. [ 7.576228] systemd[1]: Mounted Kernel Debug File System. [ 7.576405] systemd[1]: Mounted Kernel Trace File System. [ 7.576963] systemd[1]: Finished Restore / save the current clock. [ 7.577704] systemd[1]: Finished Create List of Static Device Nodes. [ 7.578121] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully. [ 7.578457] systemd[1]: Finished Load Kernel Module chromeos_pstore. [ 7.578898] systemd[1]: modprobe@configfs.service: Deactivated successfully. [ 7.579237] systemd[1]: Finished Load Kernel Module configfs. [ 7.579686] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 7.580032] systemd[1]: Finished Load Kernel Module drm. [ 7.580437] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [ 7.580757] systemd[1]: Finished Load Kernel Module efi_pstore. [ 7.581146] systemd[1]: modprobe@fuse.service: Deactivated successfully. [ 7.581458] systemd[1]: Finished Load Kernel Module fuse. [ 7.581830] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully. [ 7.582157] systemd[1]: Finished Load Kernel Module pstore_blk. [ 7.582608] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully. [ 7.582933] systemd[1]: Finished Load Kernel Module pstore_zone. [ 7.583298] systemd[1]: modprobe@ramoops.service: Deactivated successfully. [ 7.583603] systemd[1]: Finished Load Kernel Module ramoops. [ 7.584094] systemd[1]: Finished Load Kernel Modules. [ 7.585898] systemd[1]: Mounting FUSE Control File System... [ 7.587458] systemd[1]: Mounting Kernel Configuration File System... [ 7.589386] systemd[1]: Starting Apply Kernel Variables... [ 7.591735] EXT4-fs (nvme0n1p2): re-mounted. Opts: commit=600,errors=remount-ro [ 7.592662] systemd[1]: Mounted FUSE Control File System. [ 7.592897] systemd[1]: Mounted Kernel Configuration File System. [ 7.594469] systemd[1]: Finished Remount Root and Kernel File Systems. [ 7.596276] systemd[1]: Starting Platform Persistent Storage Archival... [ 7.597957] systemd[1]: Starting Load/Save Random Seed... [ 7.599562] systemd[1]: Starting Create System Users... [ 7.612047] systemd[1]: Finished Create System Users. [ 7.614569] systemd[1]: Starting Create Static Device Nodes in /dev... [ 7.615582] systemd[1]: Finished Apply Kernel Variables. [ 7.632107] systemd[1]: Finished Set the console keyboard layout. [ 7.638596] systemd[1]: Finished Create Static Device Nodes in /dev. [ 7.638777] systemd[1]: Reached target Preparation for Local File Systems. [ 7.639967] systemd[1]: Mounting /tmp... [ 7.641756] systemd[1]: Starting Rule-based Manager for Device Events and Files... [ 7.645302] systemd[1]: Mounted /tmp. [ 7.655687] systemd[1]: Finished Platform Persistent Storage Archival. [ 7.667459] systemd[1]: Finished Load/Save Random Seed. [ 7.668362] systemd[1]: Condition check resulted in First Boot Complete being skipped. [ 7.694666] systemd[1]: Started Rule-based Manager for Device Events and Files. [ 7.738300] systemd[1]: Finished Coldplug All udev Devices. [ 7.739918] systemd[1]: Starting Helper to synchronize boot up for ifupdown... [ 7.741123] systemd[1]: Starting Show Plymouth Boot Screen... [ 7.746263] systemd[1]: Finished Helper to synchronize boot up for ifupdown. [ 7.763915] systemd[1]: Started Show Plymouth Boot Screen. [ 7.764410] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 7.764875] systemd[1]: Started Forward Password Requests to Plymouth Directory Watch. [ 7.765014] systemd[1]: Reached target Local Encrypted Volumes. [ 7.780822] systemd[1]: Created slice Slice /system/systemd-backlight. [ 7.783977] systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:backlight... [ 7.786908] systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:backlight_1... [ 7.791015] systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:backlight. [ 7.792524] systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:backlight_1. [ 7.872556] systemd[1]: Found device Samsung SSD 960 EVO 500GB armbi_boot. [ 7.874985] systemd[1]: Found device /dev/ttyFIQ0. [ 7.885168] systemd[1]: Reached target Hardware activated USB gadget. [ 7.888244] systemd[1]: Starting File System Check on /dev/disk/by-uuid/1BD1-7F33... [ 7.896349] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 7.896409] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 7.900073] systemd[1]: Started File System Check Daemon to report status. [ 7.905112] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 7.929350] systemd[1]: Finished File System Check on /dev/disk/by-uuid/1BD1-7F33. [ 7.931001] systemd[1]: Mounting /boot... [ 7.932881] FAT-fs (nvme0n1p1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive! [ 7.938917] systemd[1]: Mounted /boot. [ 7.939079] systemd[1]: Reached target Local File Systems. [ 7.940232] systemd[1]: Starting Armbian leds state... [ 7.941357] systemd[1]: Starting Armbian ZRAM config... [ 7.942497] systemd[1]: Starting Set console font and keymap... [ 7.943576] systemd[1]: Starting Raise network interfaces... [ 7.944705] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data... [ 7.944803] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped. [ 7.946258] systemd[1]: Starting Set Up Additional Binary Formats... [ 7.946347] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 7.946392] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 7.948945] systemd[1]: Finished Set console font and keymap. [ 7.949732] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 558 (systemd-binfmt) [ 7.950884] systemd[1]: Mounting Arbitrary Executable File Formats File System... [ 7.955776] systemd[1]: Received SIGRTMIN+20 from PID 295 (plymouthd). [ 7.956742] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data. [ 7.958139] systemd[1]: Mounted Arbitrary Executable File Formats File System. [ 7.959454] systemd[1]: Finished Set Up Additional Binary Formats. [ 7.961479] systemd[1]: Finished Armbian leds state. [ 8.056561] zram0: detected capacity change from 0 to 4031107072 [ 8.077084] systemd[1]: Finished Raise network interfaces. [ 8.092500] Adding 3936624k swap on /dev/zram0. Priority:5 extents:1 across:3936624k SS [ 8.105438] zram: Added device: zram1 [ 8.205513] zram1: detected capacity change from 0 to 52428800 [ 8.237436] systemd[1]: Finished Armbian ZRAM config. [ 8.243665] systemd[1]: Starting Armbian memory supported logging... [ 8.302277] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard [ 8.779094] vendor storage:20190527 ret = -1 [ 9.893809] systemd[1]: Finished Armbian memory supported logging. [ 9.902599] systemd[1]: Starting Journal Service... [ 10.044432] systemd[1]: Started Journal Service. [ 10.064139] systemd-journald[737]: Received client request to flush runtime journal. ### armbian-release: # PLEASE DO NOT EDIT THIS FILE BOARD=orangepi5 BOARD_NAME="Orange Pi 5" BOARDFAMILY=rockchip-rk3588 BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=bfc8271 VERSION=23.08.0-trunk LINUXFAMILY=rk35xx ARCH=arm64 IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm64 KERNEL_IMAGE_TYPE=Image FORCE_BOOTSCRIPT_UPDATE= VENDOR=Armbian REVISION=23.08.0-trunk BOOTSCRIPT_FORCE_UPDATE="no" BOOTSCRIPT_DST="boot.cmd" BRANCH=legacy ### boot environment: verbosity=1 bootlogo=true overlay_prefix=rockchip-rk3588 fdtfile=rockchip/rk3588s-orangepi-5.dtb rootdev=UUID=329a3cf7-a8ce-4ea6-a3ef-c2128bda1678 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u ### lsusb: Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 002: ID 046d:c539 Logitech, Inc. USB Receiver Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub ### lscpu: Architecture: aarch64 CPU op-mode(s): 32-bit, 64-bit Byte Order: Little Endian CPU(s): 8 On-line CPU(s) list: 0-7 Vendor ID: ARM Model name: Cortex-A55 Model: 0 Thread(s) per core: 1 Core(s) per socket: 4 Socket(s): 1 Stepping: r2p0 CPU max MHz: 1800,0000 CPU min MHz: 408,0000 BogoMIPS: 48.00 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp Model name: Cortex-A76 Model: 0 Thread(s) per core: 1 Core(s) per socket: 2 Socket(s): 2 Stepping: r4p0 CPU max MHz: 2256,0000 CPU min MHz: 408,0000 BogoMIPS: 48.00 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp L1d cache: 384 KiB (8 instances) L1i cache: 384 KiB (8 instances) L2 cache: 2,5 MiB (8 instances) L3 cache: 3 MiB (1 instance) Vulnerability L1tf: Not affected Vulnerability Mds: Not affected Vulnerability Meltdown: Not affected Vulnerability Mmio stale data: Not affected Vulnerability Retbleed: Not affected Vulnerability Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl Vulnerability Spectre v1: Mitigation; __user pointer sanitization Vulnerability Spectre v2: Vulnerable: Unprivileged eBPF enabled Vulnerability Srbds: Not affected Vulnerability Tsx async abort: Not affected Vulnerability itlb multihit: Not affected ### cpuinfo: processor : 0 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 1 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 2 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 3 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 4 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 processor : 5 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 processor : 6 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 processor : 7 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 Serial : 2eae2cb9d903d20e ### meminfo: MemTotal: 7873256 kB MemFree: 7557020 kB MemAvailable: 7584992 kB Buffers: 14948 kB Cached: 86088 kB SwapCached: 0 kB Active: 26396 kB Inactive: 112008 kB Active(anon): 524 kB Inactive(anon): 67236 kB Active(file): 25872 kB Inactive(file): 44772 kB Unevictable: 19604 kB Mlocked: 0 kB SwapTotal: 3936624 kB SwapFree: 3936624 kB Dirty: 4544 kB Writeback: 0 kB AnonPages: 58016 kB Mapped: 30132 kB Shmem: 25988 kB KReclaimable: 38088 kB Slab: 79192 kB SReclaimable: 38088 kB SUnreclaim: 41104 kB KernelStack: 3904 kB PageTables: 3656 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 7873252 kB Committed_AS: 131504 kB VmallocTotal: 135290290112 kB VmallocUsed: 36736 kB VmallocChunk: 0 kB Percpu: 2816 kB CmaTotal: 262144 kB CmaAllocated: 4672 kB CmaReleased: 257472 kB CmaFree: 257472 kB HugePages_Total: 0 HugePages_Free: 0 HugePages_Rsvd: 0 HugePages_Surp: 0 Hugepagesize: 2048 kB Hugetlb: 0 kB ### virtual memory: vm.admin_reserve_kbytes = 8192 vm.block_dump = 0 vm.dirty_background_bytes = 0 vm.dirty_background_ratio = 10 vm.dirty_bytes = 0 vm.dirty_expire_centisecs = 3000 vm.dirty_ratio = 20 vm.dirtytime_expire_seconds = 43200 vm.dirty_writeback_centisecs = 500 vm.extra_free_kbytes = 0 vm.hugetlb_shm_group = 0 vm.laptop_mode = 0 vm.legacy_va_layout = 0 vm.lowmem_reserve_ratio = 256 256 32 0 vm.max_map_count = 65530 vm.min_free_kbytes = 11208 vm.mmap_min_addr = 32768 vm.mmap_rnd_bits = 18 vm.mmap_rnd_compat_bits = 11 vm.nr_hugepages = 0 vm.nr_overcommit_hugepages = 0 vm.oom_dump_tasks = 1 vm.oom_kill_allocating_task = 0 vm.overcommit_kbytes = 0 vm.overcommit_memory = 0 vm.overcommit_ratio = 50 vm.page-cluster = 0 vm.page_lock_unfairness = 5 vm.panic_on_oom = 0 vm.percpu_pagelist_fraction = 0 vm.stat_interval = 1 vm.swappiness = 100 vm.user_reserve_kbytes = 131072 vm.vfs_cache_pressure = 100 vm.watermark_boost_factor = 15000 vm.watermark_scale_factor = 10 ### ip addr: 1: lo: mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet XXX.XXX.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: eth0: mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether ae:d8:3f:81:fa:0b brd ff:ff:ff:ff:ff:ff ### partitions: major minor #blocks name 254 0 3936628 zram0 31 0 16384 mtdblock0 259 0 488386584 nvme0n1 259 1 262144 nvme0n1p1 259 2 483213312 nvme0n1p2 254 1 51200 zram1 ### df: tmpfs 769M 9,7M 760M 2% /run /dev/nvme0n1p2 454G 5,1G 444G 2% / tmpfs 3,8G 0 3,8G 0% /dev/shm tmpfs 5,0M 0 5,0M 0% /run/lock tmpfs 3,8G 120K 3,8G 1% /tmp /dev/nvme0n1p1 256M 106M 151M 42% /boot /dev/zram1 47M 4,8M 39M 11% /var/log ### lsblk: NAME FSTYPE SIZE MOUNTPOINT UUID mtdblock0 16M zram1 50M /var/log nvme0n1 465,8G ├─nvme0n1p1 vfat 256M /boot 1BD1-7F33 └─nvme0n1p2 ext4 460,8G / 329a3cf7-a8ce-4ea6-a3ef-c2128bda1678 ### zramctl: NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT /dev/zram1 zstd 50M 4,5M 929,6K 1,3M 8 /var/log /dev/zram0 lzo-rle 3,8G 4K 74B 12K 8 [SWAP] ### mtab: /dev/nvme0n1p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=936,iocharset=utf8,shortname=mixed,errors=remount-ro 0 0 /dev/nvme0n1p2 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0 /dev/nvme0n1p2 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0 ### Boot system health: Time CPU_cl0/CPU_cl1 load %cpu %sys %usr %nice %io %irq Tcpu C.St. 21:18:36 1800/2256 MHz 0.16 20% 12% 7% 0% 1% 0% 46,2 °C 0/7 21:18:37 1800/2256 MHz 0.16 22% 10% 6% 0% 4% 0% 44,4 °C 0/7 21:18:37 1800/2256 MHz 0.16 18% 2% 14% 0% 0% 0% 43,5 °C 0/7 21:18:38 1800/2256 MHz 0.16 22% 3% 17% 0% 0% 0% 43,5 °C 0/7 21:18:38 1800/2256 MHz 0.16 17% 2% 13% 0% 0% 0% 43,5 °C 0/7 ### Activated 1 lzo-rle zram swap devices with 3844MB each. ### Activated Armbian ramlog partition with zstd compression Pzt 07 Ağu 2023 21:23:23 +03 | Orange Pi 5 | 23.08.0-trunk | arm64 | aarch64 | 5.10.160-rk35xx ### dmesg: [ 1.766677] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [ 1.766701] Linux version 5.10.160-rk35xx (armbian@next) (aarch64-linux-gnu-gcc (Ubuntu 11.3.0-1ubuntu1~22.04) 11.3.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP Thu Jul 6 13:36:29 UTC 2023 [ 1.777517] Machine model: Orange Pi 5 [ 1.777700] efi: UEFI not found. [ 1.781355] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB [ 1.781374] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@00000000': base 0x0000000000000000, size 0 MiB [ 1.781465] Reserved memory: created CMA memory pool at 0x0000000010000000, size 256 MiB [ 1.781470] OF: reserved mem: initialized node cma, compatible id shared-dma-pool [ 1.932070] Zone ranges: [ 1.932077] DMA [mem 0x0000000000200000-0x00000000ffffffff] [ 1.932089] DMA32 empty [ 1.932096] Normal [mem 0x0000000100000000-0x00000001ffffffff] [ 1.932103] Movable zone start for each node [ 1.932107] Early memory node ranges [ 1.932112] node 0: [mem 0x0000000000200000-0x00000000efffffff] [ 1.932121] node 0: [mem 0x0000000100000000-0x00000001ffffffff] [ 1.932128] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff] [ 1.932136] On node 0 totalpages: 2031104 [ 1.932142] DMA zone: 15352 pages used for memmap [ 1.932146] DMA zone: 0 pages reserved [ 1.932151] DMA zone: 982528 pages, LIFO batch:63 [ 1.932156] Normal zone: 16384 pages used for memmap [ 1.932161] Normal zone: 1048576 pages, LIFO batch:63 [ 1.979147] psci: probing for conduit method from DT. [ 1.979160] psci: PSCIv1.1 detected in firmware. [ 1.979165] psci: Using standard PSCI v0.2 function IDs [ 1.979172] psci: MIGRATE_INFO_TYPE not supported. [ 1.979179] psci: SMC Calling Convention v1.2 [ 1.979622] percpu: Embedded 32 pages/cpu s93480 r8192 d29400 u131072 [ 1.979665] pcpu-alloc: s93480 r8192 d29400 u131072 alloc=32*4096 [ 1.979673] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7 [ 1.979816] Detected VIPT I-cache on CPU0 [ 1.979866] CPU features: detected: GIC system register CPU interface [ 1.979871] CPU features: detected: Virtualization Host Extensions [ 1.979882] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 1.979895] alternatives: patching kernel code [ 1.980282] Built 1 zonelists, mobility grouping on. Total pages: 1999368 [ 1.980293] Kernel command line: root=UUID=329a3cf7-a8ce-4ea6-a3ef-c2128bda1678 rootwait rootfstype=ext4 splash plymouth.ignore-serial-consoles console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart= usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 [ 1.981627] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) [ 1.982034] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 1.982041] mem auto-init: stack:off, heap alloc:off, heap free:off [ 1.988545] software IO TLB: mapped [mem 0x00000000ec000000-0x00000000f0000000] (64MB) [ 2.063110] Memory: 7589180K/8124416K available (16832K kernel code, 3506K rwdata, 6500K rodata, 6976K init, 639K bss, 273092K reserved, 262144K cma-reserved) [ 2.063270] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1 [ 2.063307] ftrace: allocating 64539 entries in 253 pages [ 2.173711] ftrace: allocated 253 pages with 7 groups [ 2.174020] rcu: Hierarchical RCU implementation. [ 2.174026] rcu: RCU event tracing is enabled. [ 2.174031] Rude variant of Tasks RCU enabled. [ 2.174035] Tracing variant of Tasks RCU enabled. [ 2.174041] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies. [ 2.179695] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 2.182534] GICv3: GIC: Using split EOI/Deactivate mode [ 2.182541] GICv3: 480 SPIs implemented [ 2.182546] GICv3: 0 Extended SPIs implemented [ 2.182586] GICv3: Distributor has no Range Selector support [ 2.182596] GICv3: 16 PPIs implemented [ 2.182641] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000 [ 2.182768] ITS [mem 0xfe640000-0xfe65ffff] [ 2.182825] ITS@0x00000000fe640000: allocated 8192 Devices @100200000 (indirect, esz 8, psz 64K, shr 0) [ 2.182853] ITS@0x00000000fe640000: allocated 32768 Interrupt Collections @100210000 (flat, esz 2, psz 64K, shr 0) [ 2.182863] ITS: using cache flushing for cmd queue [ 2.182906] ITS [mem 0xfe660000-0xfe67ffff] [ 2.182955] ITS@0x00000000fe660000: allocated 8192 Devices @100230000 (indirect, esz 8, psz 64K, shr 0) [ 2.182983] ITS@0x00000000fe660000: allocated 32768 Interrupt Collections @100240000 (flat, esz 2, psz 64K, shr 0) [ 2.182992] ITS: using cache flushing for cmd queue [ 2.183218] GICv3: using LPI property table @0x0000000100250000 [ 2.183349] GIC: using cache flushing for LPI property table [ 2.183360] GICv3: CPU0: using allocated LPI pending table @0x0000000100260000 [ 2.319768] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 2.319777] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 2.319787] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 2.321160] Console: colour dummy device 80x25 [ 2.321203] printk: console [tty1] enabled [ 2.321233] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000) [ 2.321245] pid_max: default: 32768 minimum: 301 [ 2.321356] LSM: Security Framework initializing [ 2.321428] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 2.321453] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 2.323708] rcu: Hierarchical SRCU implementation. [ 2.324681] Platform MSI: msi-controller@fe640000 domain created [ 2.324703] Platform MSI: msi-controller@fe660000 domain created [ 2.325081] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe640000 domain created [ 2.325107] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe660000 domain created [ 2.325294] EFI services will not be available. [ 2.325747] smp: Bringing up secondary CPUs ... [ 2.326468] Detected VIPT I-cache on CPU1 [ 2.326505] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000 [ 2.326525] GICv3: CPU1: using allocated LPI pending table @0x0000000100270000 [ 2.326570] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [ 2.327352] Detected VIPT I-cache on CPU2 [ 2.327385] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000 [ 2.327404] GICv3: CPU2: using allocated LPI pending table @0x0000000100280000 [ 2.327445] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [ 2.328175] Detected VIPT I-cache on CPU3 [ 2.328205] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000 [ 2.328223] GICv3: CPU3: using allocated LPI pending table @0x0000000100290000 [ 2.328262] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [ 2.329004] CPU features: detected: Spectre-v4 [ 2.329008] CPU features: detected: Spectre-BHB [ 2.329010] Detected PIPT I-cache on CPU4 [ 2.329026] GICv3: CPU4: found redistributor 400 region 0:0x00000000fe700000 [ 2.329037] GICv3: CPU4: using allocated LPI pending table @0x00000001002a0000 [ 2.329062] CPU4: Booted secondary processor 0x0000000400 [0x414fd0b0] [ 2.329786] Detected PIPT I-cache on CPU5 [ 2.329803] GICv3: CPU5: found redistributor 500 region 0:0x00000000fe720000 [ 2.329814] GICv3: CPU5: using allocated LPI pending table @0x00000001002b0000 [ 2.329840] CPU5: Booted secondary processor 0x0000000500 [0x414fd0b0] [ 2.330533] Detected PIPT I-cache on CPU6 [ 2.330549] GICv3: CPU6: found redistributor 600 region 0:0x00000000fe740000 [ 2.330560] GICv3: CPU6: using allocated LPI pending table @0x00000001002c0000 [ 2.330585] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b0] [ 2.331261] Detected PIPT I-cache on CPU7 [ 2.331278] GICv3: CPU7: found redistributor 700 region 0:0x00000000fe760000 [ 2.331288] GICv3: CPU7: using allocated LPI pending table @0x00000001002d0000 [ 2.331314] CPU7: Booted secondary processor 0x0000000700 [0x414fd0b0] [ 2.331393] smp: Brought up 1 node, 8 CPUs [ 2.331413] SMP: Total of 8 processors activated. [ 2.331418] CPU features: detected: Privileged Access Never [ 2.331423] CPU features: detected: User Access Override [ 2.331428] CPU features: detected: 32-bit EL0 Support [ 2.331433] CPU features: detected: Common not Private translations [ 2.331437] CPU features: detected: RAS Extension Support [ 2.331442] CPU features: detected: Data cache clean to the PoU not required for I/D coherence [ 2.331446] CPU features: detected: CRC32 instructions [ 2.331450] CPU features: detected: Speculative Store Bypassing Safe (SSBS) [ 2.331457] CPU features: detected: RCpc load-acquire (LDAPR) [ 2.331545] CPU: All CPU(s) started at EL2 [ 2.334764] devtmpfs: initialized [ 2.349555] Registered cp15_barrier emulation handler [ 2.349564] Registered setend emulation handler [ 2.349569] KASLR disabled due to lack of seed [ 2.349654] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns [ 2.349662] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 2.352383] pinctrl core: initialized pinctrl subsystem [ 2.352525] regulator-dummy: no parameters, enabled [ 2.352644] DMI not present or invalid. [ 2.352950] NET: Registered protocol family 16 [ 2.354045] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations [ 2.354168] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 2.354191] audit: initializing netlink subsys (disabled) [ 2.354285] audit: type=2000 audit(0.033:1): state=initialized audit_enabled=0 res=1 [ 2.354806] Registered FIQ tty driver [ 2.354964] thermal_sys: Registered thermal governor 'fair_share' [ 2.354966] thermal_sys: Registered thermal governor 'step_wise' [ 2.354969] thermal_sys: Registered thermal governor 'user_space' [ 2.354971] thermal_sys: Registered thermal governor 'power_allocator' [ 2.355299] cpuidle: using governor menu [ 2.355532] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 2.355668] ASID allocator initialised with 65536 entries [ 2.357239] ramoops: dmesg-0 0x20000@0x0000000000110000 [ 2.357258] ramoops: console 0x80000@0x0000000000130000 [ 2.357268] ramoops: pmsg 0x50000@0x00000000001b0000 [ 2.357316] printk: console [ramoops-1] enabled [ 2.357319] pstore: Registered ramoops as persistent store backend [ 2.357321] ramoops: using 0xf0000@0x110000, ecc: 0 [ 2.411379] rockchip-gpio fd8a0000.gpio: probed /pinctrl/gpio@fd8a0000 [ 2.411673] rockchip-gpio fec20000.gpio: probed /pinctrl/gpio@fec20000 [ 2.411903] rockchip-gpio fec30000.gpio: probed /pinctrl/gpio@fec30000 [ 2.412179] rockchip-gpio fec40000.gpio: probed /pinctrl/gpio@fec40000 [ 2.412448] rockchip-gpio fec50000.gpio: probed /pinctrl/gpio@fec50000 [ 2.412497] rockchip-pinctrl pinctrl: probed pinctrl [ 2.421177] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 2.421182] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 2.421185] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 2.421187] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 2.483083] raid6: neonx8 gen() 5362 MB/s [ 2.539831] raid6: neonx8 xor() 4163 MB/s [ 2.596580] raid6: neonx4 gen() 5497 MB/s [ 2.653332] raid6: neonx4 xor() 4177 MB/s [ 2.710083] raid6: neonx2 gen() 5041 MB/s [ 2.766828] raid6: neonx2 xor() 3940 MB/s [ 2.823583] raid6: neonx1 gen() 4214 MB/s [ 2.880329] raid6: neonx1 xor() 3247 MB/s [ 2.937079] raid6: int64x8 gen() 1313 MB/s [ 2.993837] raid6: int64x8 xor() 866 MB/s [ 3.050581] raid6: int64x4 gen() 1615 MB/s [ 3.107334] raid6: int64x4 xor() 880 MB/s [ 3.164078] raid6: int64x2 gen() 1885 MB/s [ 3.220826] raid6: int64x2 xor() 1299 MB/s [ 3.277573] raid6: int64x1 gen() 1969 MB/s [ 3.334331] raid6: int64x1 xor() 960 MB/s [ 3.334333] raid6: using algorithm neonx4 gen() 5497 MB/s [ 3.334335] raid6: .... xor() 4177 MB/s, rmw enabled [ 3.334338] raid6: using neon recovery algorithm [ 3.334945] fiq_debugger fiq_debugger.0: IRQ fiq not found [ 3.334953] fiq_debugger fiq_debugger.0: IRQ wakeup not found [ 3.334956] fiq_debugger_probe: could not install nmi irq handler [ 3.335040] printk: console [ttyFIQ0] enabled [ 3.335141] Registered fiq debugger ttyFIQ0 [ 3.335356] vcc12v_dcin: 12000 mV, enabled [ 3.335435] reg-fixed-voltage vcc12v-dcin: vcc12v_dcin supplying 12000000uV [ 3.335486] reg-fixed-voltage vcc5v0-sys: Looking up vin-supply from device tree [ 3.335490] vcc5v0_sys: supplied by vcc12v_dcin [ 3.335495] vcc12v_dcin: could not add device link regulator.2: -ENOENT [ 3.335511] vcc5v0_sys: 5000 mV, enabled [ 3.335577] reg-fixed-voltage vcc5v0-sys: vcc5v0_sys supplying 5000000uV [ 3.335624] reg-fixed-voltage vcc5v0-usbdcin: Looking up vin-supply from device tree [ 3.335628] vcc5v0_usbdcin: supplied by vcc12v_dcin [ 3.335632] vcc12v_dcin: could not add device link regulator.3: -ENOENT [ 3.335646] vcc5v0_usbdcin: 5000 mV, enabled [ 3.335711] reg-fixed-voltage vcc5v0-usbdcin: vcc5v0_usbdcin supplying 5000000uV [ 3.335757] reg-fixed-voltage vcc5v0-usb: Looking up vin-supply from device tree [ 3.335760] vcc5v0_usb: supplied by vcc5v0_usbdcin [ 3.335764] vcc5v0_usbdcin: could not add device link regulator.4: -ENOENT [ 3.335779] vcc5v0_usb: 5000 mV, enabled [ 3.335836] reg-fixed-voltage vcc5v0-usb: vcc5v0_usb supplying 5000000uV [ 3.335940] vbus5v0_typec: 5000 mV, disabled [ 3.335991] reg-fixed-voltage vbus5v0-typec: Looking up vin-supply from device tree [ 3.335995] vbus5v0_typec: supplied by vcc5v0_usb [ 3.336029] reg-fixed-voltage vbus5v0-typec: vbus5v0_typec supplying 5000000uV [ 3.336081] reg-fixed-voltage vcc-1v1-nldo-s3: Looking up vin-supply from device tree [ 3.336085] vcc_1v1_nldo_s3: supplied by vcc5v0_sys [ 3.336088] vcc5v0_sys: could not add device link regulator.6: -ENOENT [ 3.336106] vcc_1v1_nldo_s3: 1100 mV, enabled [ 3.336171] reg-fixed-voltage vcc-1v1-nldo-s3: vcc_1v1_nldo_s3 supplying 1100000uV [ 3.336224] reg-fixed-voltage vcc3v3-pcie2x1l2: Looking up vin-supply from device tree [ 3.336228] vcc3v3_pcie2x1l2: supplied by vcc5v0_sys [ 3.336232] vcc5v0_sys: could not add device link regulator.7: -ENOENT [ 3.392005] vcc3v3_pcie2x1l2: 1800 mV, enabled [ 3.392072] reg-fixed-voltage vcc3v3-pcie2x1l2: vcc3v3_pcie2x1l2 supplying 1800000uV [ 3.392354] iommu: Default domain type: Translated [ 3.392786] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vdpu-supply from device tree [ 3.392808] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vdpu-supply property in node /power-management@fd8d8000/power-controller failed [ 3.393077] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga30-supply from device tree [ 3.393095] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga30-supply property in node /power-management@fd8d8000/power-controller failed [ 3.393273] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga31-supply from device tree [ 3.393291] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga31-supply property in node /power-management@fd8d8000/power-controller failed [ 3.394599] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc0-supply from device tree [ 3.394617] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc0-supply property in node /power-management@fd8d8000/power-controller failed [ 3.394770] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vcodec-supply from device tree [ 3.394789] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vcodec-supply property in node /power-management@fd8d8000/power-controller failed [ 3.394890] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc1-supply from device tree [ 3.394907] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc1-supply property in node /power-management@fd8d8000/power-controller failed [ 3.395182] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec0-supply from device tree [ 3.395200] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec0-supply property in node /power-management@fd8d8000/power-controller failed [ 3.395491] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec1-supply from device tree [ 3.395509] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec1-supply property in node /power-management@fd8d8000/power-controller failed [ 3.395728] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vi-supply from device tree [ 3.395745] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vi-supply property in node /power-management@fd8d8000/power-controller failed [ 3.395980] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up isp1-supply from device tree [ 3.395996] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up isp1-supply property in node /power-management@fd8d8000/power-controller failed [ 3.396699] SCSI subsystem initialized [ 3.396713] libata version 3.00 loaded. [ 3.396787] usbcore: registered new interface driver usbfs [ 3.396804] usbcore: registered new interface driver hub [ 3.396818] usbcore: registered new device driver usb [ 3.396858] mc: Linux media interface: v0.10 [ 3.396869] videodev: Linux video capture interface: v2.00 [ 3.396898] pps_core: LinuxPPS API ver. 1 registered [ 3.396900] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [ 3.396906] PTP clock support registered [ 3.397175] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled. [ 3.397207] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0 [ 3.398420] Advanced Linux Sound Architecture Driver Initialized. [ 3.398683] Bluetooth: Core ver 2.22 [ 3.398698] NET: Registered protocol family 31 [ 3.398701] Bluetooth: HCI device and connection manager initialized [ 3.398705] Bluetooth: HCI socket layer initialized [ 3.398708] Bluetooth: L2CAP socket layer initialized [ 3.398715] Bluetooth: SCO socket layer initialized [ 3.398727] NetLabel: Initializing [ 3.398729] NetLabel: domain hash size = 128 [ 3.398731] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 3.398758] NetLabel: unlabeled traffic allowed by default [ 3.400089] rockchip-cpuinfo cpuinfo: SoC : 35881000 [ 3.400093] rockchip-cpuinfo cpuinfo: Serial : 2eae2cb9d903d20e [ 3.400536] clocksource: Switched to clocksource arch_sys_counter [ 3.817546] VFS: Disk quotas dquot_6.6.0 [ 3.817575] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 3.823250] NET: Registered protocol family 2 [ 3.823376] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 3.825404] tcp_listen_portaddr_hash hash table entries: 4096 (order: 5, 163840 bytes, linear) [ 3.825504] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 3.825852] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear) [ 3.826656] TCP: Hash tables configured (established 65536 bind 65536) [ 3.826767] MPTCP token hash table entries: 8192 (order: 6, 393216 bytes, linear) [ 3.826865] UDP hash table entries: 4096 (order: 6, 393216 bytes, linear) [ 3.827021] UDP-Lite hash table entries: 4096 (order: 6, 393216 bytes, linear) [ 3.827251] NET: Registered protocol family 1 [ 3.827619] RPC: Registered named UNIX socket transport module. [ 3.827621] RPC: Registered udp transport module. [ 3.827623] RPC: Registered tcp transport module. [ 3.827625] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 3.828071] PCI: CLS 0 bytes, default 64 [ 3.828365] Trying to unpack rootfs image as initramfs... [ 4.223891] Freeing initrd memory: 14956K [ 4.224574] rockchip-thermal fec00000.tsadc: Missing rockchip,grf property [ 4.225216] rockchip-thermal fec00000.tsadc: tsadc is probed successfully! [ 4.226155] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 4.226759] kvm [1]: IPA Size Limit: 40 bits [ 4.226769] kvm [1]: GICv3: no GICV resource entry [ 4.226772] kvm [1]: disabling GICv2 emulation [ 4.226775] kvm [1]: GIC system register CPU interface enabled [ 4.226928] kvm [1]: vgic interrupt IRQ9 [ 4.227110] kvm [1]: VHE mode initialized successfully [ 4.230230] Initialise system trusted keyrings [ 4.230347] workingset: timestamp_bits=46 max_order=21 bucket_order=0 [ 4.233413] NFS: Registering the id_resolver key type [ 4.233426] Key type id_resolver registered [ 4.233428] Key type id_legacy registered [ 4.233464] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 4.233467] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 4.233479] ntfs: driver 2.1.32 [Flags: R/W]. [ 4.254564] NET: Registered protocol family 38 [ 4.254570] xor: measuring software checksum speed [ 4.256181] 8regs : 6125 MB/sec [ 4.257400] 32regs : 8135 MB/sec [ 4.258390] arm64_neon : 9977 MB/sec [ 4.258392] xor: using function: arm64_neon (9977 MB/sec) [ 4.258397] Key type asymmetric registered [ 4.258400] Asymmetric key parser 'x509' registered [ 4.258417] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242) [ 4.258521] io scheduler mq-deadline registered [ 4.258526] io scheduler kyber registered [ 4.260337] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up phy-supply from device tree [ 4.260345] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up phy-supply property in node /syscon@fd5d0000/usb2-phy@0/otg-port failed [ 4.260395] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up vbus-supply from device tree [ 4.260402] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up vbus-supply property in node /syscon@fd5d0000/usb2-phy@0/otg-port failed [ 4.261742] phy phy-fd5d8000.syscon:usb2-phy@8000.1: Looking up phy-supply from device tree [ 4.261751] phy phy-fd5d8000.syscon:usb2-phy@8000.1: Looking up phy-supply property in node /syscon@fd5d8000/usb2-phy@8000/host-port failed [ 4.262930] phy phy-fd5dc000.syscon:usb2-phy@c000.2: Looking up phy-supply from device tree [ 4.262938] phy phy-fd5dc000.syscon:usb2-phy@c000.2: Looking up phy-supply property in node /syscon@fd5dc000/usb2-phy@c000/host-port failed [ 4.264783] phy phy-fee00000.phy.3: Looking up phy-supply from device tree [ 4.264790] phy phy-fee00000.phy.3: Looking up phy-supply property in node /phy@fee00000 failed [ 4.264940] phy phy-fee20000.phy.4: Looking up phy-supply from device tree [ 4.264945] phy phy-fee20000.phy.4: Looking up phy-supply property in node /phy@fee20000 failed [ 4.265434] phy phy-feda0000.phy.5: Looking up phy-supply from device tree [ 4.265439] phy phy-feda0000.phy.5: Looking up phy-supply property in node /phy@feda0000 failed [ 4.265574] phy phy-fedb0000.phy.6: Looking up phy-supply from device tree [ 4.265579] phy phy-fedb0000.phy.6: Looking up phy-supply property in node /phy@fedb0000 failed [ 4.265951] phy phy-fed60000.hdmiphy.7: Looking up phy-supply from device tree [ 4.265957] phy phy-fed60000.hdmiphy.7: Looking up phy-supply property in node /hdmiphy@fed60000 failed [ 4.266729] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy init success [ 4.267686] phy phy-fed80000.phy.8: Looking up phy-supply from device tree [ 4.267693] phy phy-fed80000.phy.8: Looking up phy-supply property in node /phy@fed80000/dp-port failed [ 4.267728] phy phy-fed80000.phy.9: Looking up phy-supply from device tree [ 4.267734] phy phy-fed80000.phy.9: Looking up phy-supply property in node /phy@fed80000/u3-port failed [ 4.269188] rk-pcie fe190000.pcie: invalid prsnt-gpios property in node [ 4.269200] rk-pcie fe190000.pcie: Looking up vpcie3v3-supply from device tree [ 4.269442] pwm-backlight backlight: Looking up power-supply from device tree [ 4.269448] pwm-backlight backlight: Looking up power-supply property in node /backlight failed [ 4.269453] pwm-backlight backlight: supply power not found, using dummy regulator [ 4.269718] pwm-backlight backlight_1: Looking up power-supply from device tree [ 4.269724] pwm-backlight backlight_1: Looking up power-supply property in node /backlight_1 failed [ 4.269729] pwm-backlight backlight_1: supply power not found, using dummy regulator [ 4.269900] rk-pcie fe190000.pcie: IRQ msi not found [ 4.269907] rk-pcie fe190000.pcie: use outband MSI support [ 4.269914] rk-pcie fe190000.pcie: Missing *config* reg space [ 4.269930] rk-pcie fe190000.pcie: host bridge /pcie@fe190000 ranges: [ 4.269962] rk-pcie fe190000.pcie: err 0x00f4000000..0x00f40fffff -> 0x00f4000000 [ 4.269986] rk-pcie fe190000.pcie: IO 0x00f4100000..0x00f41fffff -> 0x00f4100000 [ 4.270010] rk-pcie fe190000.pcie: MEM 0x00f4200000..0x00f4ffffff -> 0x00f4200000 [ 4.270023] rk-pcie fe190000.pcie: MEM 0x0a00000000..0x0a3fffffff -> 0x0a00000000 [ 4.270025] iep: Module initialized. [ 4.270063] mpp_service mpp-srv: unknown mpp version for missing VCS info [ 4.270065] rk-pcie fe190000.pcie: Missing *config* reg space [ 4.270069] mpp_service mpp-srv: probe start [ 4.270096] rk-pcie fe190000.pcie: invalid resource [ 4.272034] mpp_vdpu2 fdb50400.vdpu: Adding to iommu group 1 [ 4.272254] mpp_vdpu2 fdb50400.vdpu: probe device [ 4.272373] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0 [ 4.272381] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0 [ 4.272532] mpp_vdpu2 fdb50400.vdpu: probing finish [ 4.272745] mpp_vepu2 jpege-ccu: probing start [ 4.272749] mpp_vepu2 jpege-ccu: probing finish [ 4.272858] mpp_vepu2 fdb50000.vepu: Adding to iommu group 1 [ 4.272939] mpp_vepu2 fdb50000.vepu: probing start [ 4.273035] mpp_vepu2 fdb50000.vepu: reset_group->rw_sem_on=0 [ 4.273039] mpp_vepu2 fdb50000.vepu: reset_group->rw_sem_on=0 [ 4.273185] mpp_vepu2 fdb50000.vepu: probing finish [ 4.273304] mpp_vepu2 fdba0000.jpege-core: Adding to iommu group 5 [ 4.273444] mpp_vepu2 fdba0000.jpege-core: probing start [ 4.273549] mpp_vepu2 fdba0000.jpege-core: attach ccu success [ 4.273685] mpp_vepu2 fdba0000.jpege-core: probing finish [ 4.273792] mpp_vepu2 fdba4000.jpege-core: Adding to iommu group 6 [ 4.273938] mpp_vepu2 fdba4000.jpege-core: probing start [ 4.274049] mpp_vepu2 fdba4000.jpege-core: attach ccu success [ 4.274190] mpp_vepu2 fdba4000.jpege-core: probing finish [ 4.274299] mpp_vepu2 fdba8000.jpege-core: Adding to iommu group 7 [ 4.274434] mpp_vepu2 fdba8000.jpege-core: probing start [ 4.274539] mpp_vepu2 fdba8000.jpege-core: attach ccu success [ 4.274681] mpp_vepu2 fdba8000.jpege-core: probing finish [ 4.274776] mpp_vepu2 fdbac000.jpege-core: Adding to iommu group 8 [ 4.274912] mpp_vepu2 fdbac000.jpege-core: probing start [ 4.275017] mpp_vepu2 fdbac000.jpege-core: attach ccu success [ 4.275154] mpp_vepu2 fdbac000.jpege-core: probing finish [ 4.275425] mpp-iep2 fdbb0000.iep: Adding to iommu group 9 [ 4.275568] mpp-iep2 fdbb0000.iep: probe device [ 4.275692] mpp-iep2 fdbb0000.iep: allocate roi buffer failed [ 4.275818] mpp-iep2 fdbb0000.iep: probing finish [ 4.276036] mpp_jpgdec fdb90000.jpegd: Adding to iommu group 4 [ 4.276242] mpp_jpgdec fdb90000.jpegd: probe device [ 4.276496] mpp_jpgdec fdb90000.jpegd: probing finish [ 4.276861] mpp_rkvdec2 fdc30000.rkvdec-ccu: rkvdec-ccu, probing start [ 4.276922] mpp_rkvdec2 fdc30000.rkvdec-ccu: ccu-mode: 1 [ 4.276925] mpp_rkvdec2 fdc30000.rkvdec-ccu: probing finish [ 4.277020] mpp_rkvdec2 fdc38100.rkvdec-core: Adding to iommu group 12 [ 4.277299] mpp_rkvdec2 fdc38100.rkvdec-core: rkvdec-core, probing start [ 4.277423] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found! [ 4.277426] rkvdec2_init:1022: No niu aclk reset resource define [ 4.277429] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found! [ 4.277432] rkvdec2_init:1025: No niu hclk reset resource define [ 4.277447] mpp_rkvdec2 fdc38100.rkvdec-core: Looking up vdec-supply from device tree [ 4.277453] mpp_rkvdec2 fdc38100.rkvdec-core: Looking up vdec-supply property in node /rkvdec-core@fdc38000 failed [ 4.277458] mpp_rkvdec2 fdc38100.rkvdec-core: no regulator, devfreq is disabled [ 4.277515] mpp_rkvdec2 fdc38100.rkvdec-core: core_mask=00010001 [ 4.277518] mpp_rkvdec2 fdc38100.rkvdec-core: attach ccu as core 0 [ 4.277666] mpp_rkvdec2 fdc38100.rkvdec-core: sram_start 0x00000000ff001000 [ 4.277669] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_iova 0x00000000fff00000 [ 4.277672] mpp_rkvdec2 fdc38100.rkvdec-core: sram_size 491520 [ 4.277674] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_size 1048576 [ 4.277678] mpp_rkvdec2 fdc38100.rkvdec-core: min_width 512 [ 4.277682] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_info_count 20 [ 4.277685] mpp_rkvdec2 fdc38100.rkvdec-core: [136, 24576] [ 4.277688] mpp_rkvdec2 fdc38100.rkvdec-core: [137, 49152] [ 4.277691] mpp_rkvdec2 fdc38100.rkvdec-core: [141, 90112] [ 4.277693] mpp_rkvdec2 fdc38100.rkvdec-core: [140, 49152] [ 4.277696] mpp_rkvdec2 fdc38100.rkvdec-core: [139, 180224] [ 4.277699] mpp_rkvdec2 fdc38100.rkvdec-core: [133, 49152] [ 4.277701] mpp_rkvdec2 fdc38100.rkvdec-core: [134, 8192] [ 4.277704] mpp_rkvdec2 fdc38100.rkvdec-core: [135, 4352] [ 4.277707] mpp_rkvdec2 fdc38100.rkvdec-core: [138, 13056] [ 4.277709] mpp_rkvdec2 fdc38100.rkvdec-core: [142, 291584] [ 4.277744] mpp_rkvdec2 fdc38100.rkvdec-core: probing finish [ 4.277835] mpp_rkvdec2 fdc48100.rkvdec-core: Adding to iommu group 13 [ 4.278066] mpp_rkvdec2 fdc48100.rkvdec-core: rkvdec-core, probing start [ 4.278191] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found! [ 4.278193] rkvdec2_init:1022: No niu aclk reset resource define [ 4.278197] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found! [ 4.278199] rkvdec2_init:1025: No niu hclk reset resource define [ 4.278215] mpp_rkvdec2 fdc48100.rkvdec-core: Looking up vdec-supply from device tree [ 4.278220] mpp_rkvdec2 fdc48100.rkvdec-core: Looking up vdec-supply property in node /rkvdec-core@fdc48000 failed [ 4.278226] mpp_rkvdec2 fdc48100.rkvdec-core: no regulator, devfreq is disabled [ 4.278268] mpp_rkvdec2 fdc48100.rkvdec-core: core_mask=00020002 [ 4.278285] mpp_rkvdec2 fdc48100.rkvdec-core: attach ccu as core 1 [ 4.278465] mpp_rkvdec2 fdc48100.rkvdec-core: sram_start 0x00000000ff079000 [ 4.278468] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_iova 0x00000000ffe00000 [ 4.278471] mpp_rkvdec2 fdc48100.rkvdec-core: sram_size 487424 [ 4.278473] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_size 1048576 [ 4.278477] mpp_rkvdec2 fdc48100.rkvdec-core: min_width 512 [ 4.278482] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_info_count 20 [ 4.278484] mpp_rkvdec2 fdc48100.rkvdec-core: [136, 24576] [ 4.278487] mpp_rkvdec2 fdc48100.rkvdec-core: [137, 49152] [ 4.278490] mpp_rkvdec2 fdc48100.rkvdec-core: [141, 90112] [ 4.278492] mpp_rkvdec2 fdc48100.rkvdec-core: [140, 49152] [ 4.278495] mpp_rkvdec2 fdc48100.rkvdec-core: [139, 180224] [ 4.278497] mpp_rkvdec2 fdc48100.rkvdec-core: [133, 49152] [ 4.278500] mpp_rkvdec2 fdc48100.rkvdec-core: [134, 8192] [ 4.278503] mpp_rkvdec2 fdc48100.rkvdec-core: [135, 4352] [ 4.278505] mpp_rkvdec2 fdc48100.rkvdec-core: [138, 13056] [ 4.278508] mpp_rkvdec2 fdc48100.rkvdec-core: [142, 291584] [ 4.278538] mpp_rkvdec2 fdc48100.rkvdec-core: probing finish [ 4.278728] mpp_rkvenc2 rkvenc-ccu: probing start [ 4.278731] mpp_rkvenc2 rkvenc-ccu: probing finish [ 4.278848] mpp_rkvenc2 fdbd0000.rkvenc-core: Adding to iommu group 10 [ 4.279029] mpp_rkvenc2 fdbd0000.rkvenc-core: probing start [ 4.279179] mpp_rkvenc2 fdbd0000.rkvenc-core: Looking up venc-supply from device tree [ 4.279185] mpp_rkvenc2 fdbd0000.rkvenc-core: Looking up venc-supply property in node /rkvenc-core@fdbd0000 failed [ 4.279191] mpp_rkvenc2 fdbd0000.rkvenc-core: dev_pm_opp_set_regulators: no regulator (venc) found: -19 [ 4.279207] rkvenc_init:1814: failed to add venc devfreq [ 4.279236] mpp_rkvenc2 fdbd0000.rkvenc-core: attach ccu as core 0 [ 4.279387] mpp_rkvenc2 fdbd0000.rkvenc-core: probing finish [ 4.279470] mpp_rkvenc2 fdbe0000.rkvenc-core: Adding to iommu group 11 [ 4.279654] mpp_rkvenc2 fdbe0000.rkvenc-core: probing start [ 4.279784] mpp_rkvenc2 fdbe0000.rkvenc-core: Looking up venc-supply from device tree [ 4.279790] mpp_rkvenc2 fdbe0000.rkvenc-core: Looking up venc-supply property in node /rkvenc-core@fdbe0000 failed [ 4.279795] mpp_rkvenc2 fdbe0000.rkvenc-core: dev_pm_opp_set_regulators: no regulator (venc) found: -19 [ 4.279809] rkvenc_init:1814: failed to add venc devfreq [ 4.279858] mpp_rkvenc2 fdbe0000.rkvenc-core: attach ccu as core 1 [ 4.280001] mpp_rkvenc2 fdbe0000.rkvenc-core: probing finish [ 4.280246] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up av1-supply from device tree [ 4.280267] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up av1-supply property in node /power-management@fd8d8000/power-controller failed [ 4.280573] mpp_av1dec: Adding child /av1d@fdc70000 [ 4.280654] mpp_av1dec: register device av1d-master [ 4.280683] mpp_av1dec av1d-master: av1_iommu_of_xlate,784 [ 4.280702] av1_iommu_probe_device,736, consumer : av1d-master, supplier : fdca0000.iommu [ 4.280735] mpp_av1dec av1d-master: Adding to iommu group 18 [ 4.280973] mpp_av1dec av1d-master: probing start [ 4.281238] mpp_av1dec av1d-master: probing finish [ 4.281277] mpp_service mpp-srv: probe success [ 4.292348] dma-pl330 fea10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 4.292354] dma-pl330 fea10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 4.293377] dma-pl330 fea30000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 4.293382] dma-pl330 fea30000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 4.294375] dma-pl330 fed10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 4.294380] dma-pl330 fed10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 4.294880] rockchip-pvtm fda40000.pvtm: pvtm@0 probed [ 4.294944] rockchip-pvtm fda50000.pvtm: pvtm@1 probed [ 4.295002] rockchip-pvtm fda60000.pvtm: pvtm@2 probed [ 4.295062] rockchip-pvtm fdaf0000.pvtm: pvtm@3 probed [ 4.295116] rockchip-pvtm fdb30000.pvtm: pvtm@4 probed [ 4.295701] rockchip-system-monitor rockchip-system-monitor: system monitor probe [ 4.296566] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [ 4.297075] febc0000.serial: ttyS9 at MMIO 0xfebc0000 (irq = 101, base_baud = 1500000) is a 16550A [ 4.298408] random: crng init done [ 4.298499] led_vk2c21_init ============================================= [ 4.299461] rockchip-vop2 fdd90000.vop: Adding to iommu group 17 [ 4.307998] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x5, primary plane phy id: 0 [ 4.308005] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp1 assign plane mask: 0xa, primary plane phy id: 1 [ 4.308011] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x140, primary plane phy id: 6 [ 4.308017] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp3 assign plane mask: 0x280, primary plane phy id: 7 [ 4.308110] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart0-win0 as cursor plane for vp0 [ 4.308213] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart1-win0 as cursor plane for vp1 [ 4.308299] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart2-win0 as cursor plane for vp2 [ 4.308381] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart3-win0 as cursor plane for vp3 [ 4.308401] [drm] failed to init overlay plane Cluster0-win1 [ 4.308404] [drm] failed to init overlay plane Cluster1-win1 [ 4.308406] [drm] failed to init overlay plane Cluster2-win1 [ 4.308408] [drm] failed to init overlay plane Cluster3-win1 [ 4.320025] rockchip-drm display-subsystem: bound fdd90000.vop (ops 0xffff8000091b2620) [ 4.321022] dwhdmi-rockchip fde80000.hdmi: registered ddc I2C bus driver [ 4.321236] rockchip-drm display-subsystem: bound fde80000.hdmi (ops 0xffff8000091c0798) [ 4.321316] rockchip-drm display-subsystem: bound fde50000.dp (ops 0xffff8000091c3278) [ 4.321787] rockchip-drm display-subsystem: failed to parse loader memory [ 4.475041] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x2 [ 4.548369] dwhdmi-rockchip fde80000.hdmi: use tmds mode [ 4.548409] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] Update mode to 1920x1080p60, type: 11(if:800) for vp0 dclk: 148500000 [ 4.548574] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] dclk_out0 div: 0 dclk_core0 div: 2 [ 4.548591] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx_ropll_cmn_config bus_width:16a8c8 rate:1485000 [ 4.548869] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy pll locked! [ 4.548875] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] set dclk_vop0 to 148500000, get 148500000 [ 4.548899] dwhdmi-rockchip fde80000.hdmi: final tmdsclk = 148500000 [ 4.548928] dwhdmi-rockchip fde80000.hdmi: don't use dsc mode [ 4.548931] dwhdmi-rockchip fde80000.hdmi: dw hdmi qp use tmds mode [ 4.548938] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: bus_width:0x16a8c8,bit_rate:1485000 [ 4.549132] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy lane locked! [ 4.557236] rk-pcie fe190000.pcie: PCIe Link up, LTSSM is 0x30011 [ 4.557413] rk-pcie fe190000.pcie: PCI host bridge to bus 0004:40 [ 4.557424] pci_bus 0004:40: root bus resource [bus 40-4f] [ 4.557433] pci_bus 0004:40: root bus resource [??? 0xf4000000-0xf40fffff flags 0x0] [ 4.557443] pci_bus 0004:40: root bus resource [io 0x0000-0xfffff] (bus address [0xf4100000-0xf41fffff]) [ 4.557450] pci_bus 0004:40: root bus resource [mem 0xf4200000-0xf4ffffff] [ 4.557457] pci_bus 0004:40: root bus resource [mem 0xa00000000-0xa3fffffff pref] [ 4.557501] pci 0004:40:00.0: [1d87:3588] type 01 class 0x060400 [ 4.557530] pci 0004:40:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref] [ 4.557609] pci 0004:40:00.0: supports D1 D2 [ 4.557616] pci 0004:40:00.0: PME# supported from D0 D1 D3hot [ 4.570381] pci 0004:40:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 4.570670] pci 0004:41:00.0: [144d:a804] type 00 class 0x010802 [ 4.570768] pci 0004:41:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit] [ 4.571503] pci 0004:41:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x1 link at 0004:40:00.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link) [ 4.592879] pci_bus 0004:41: busn_res: [bus 41-4f] end is updated to 41 [ 4.592908] pci 0004:40:00.0: BAR 8: assigned [mem 0xf4200000-0xf42fffff] [ 4.592919] pci 0004:40:00.0: BAR 6: assigned [mem 0xf4300000-0xf430ffff pref] [ 4.592933] pci 0004:41:00.0: BAR 0: assigned [mem 0xf4200000-0xf4203fff 64bit] [ 4.592973] pci 0004:40:00.0: PCI bridge to [bus 41] [ 4.592982] pci 0004:40:00.0: bridge window [mem 0xf4200000-0xf42fffff] [ 4.596339] pcieport 0004:40:00.0: PME: Signaling with IRQ 125 [ 4.632314] Console: switching to colour frame buffer device 240x67 [ 4.796193] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device [ 4.797485] [drm] Initialized rockchip 3.0.0 20140818 for display-subsystem on minor 0 [ 4.812343] brd: module loaded [ 4.821572] loop: module loaded [ 4.822125] zram: Added device: zram0 [ 4.822489] lkdtm: No crash points registered, enable through debugfs [ 4.822697] system_heap: orders[0] = 6 [ 4.822704] system_heap: orders[1] = 4 [ 4.822710] system_heap: orders[2] = 0 [ 4.824573] nvme nvme0: pci function 0004:41:00.0 [ 4.824643] nvme 0004:41:00.0: enabling device (0000 -> 0002) [ 4.826264] rockchip-spi feb20000.spi: no high_speed pinctrl state [ 4.827962] rk806 spi2.0: chip id: RK806,ver:0x2, 0x1 [ 4.828128] rk806 spi2.0: ON: 0x80 OFF:0x80 [ 4.830170] rk806-regulator rk806-regulator.6.auto: Looking up vcc1-supply from device tree [ 4.830180] vdd_gpu_s0: supplied by vcc5v0_sys [ 4.830186] vcc5v0_sys: could not add device link regulator.8: -ENOENT [ 4.830939] vdd_gpu_s0: 550 <--> 950 mV at 750 mV, enabled [ 4.831361] rk806-regulator rk806-regulator.6.auto: Looking up vcc2-supply from device tree [ 4.831368] vdd_cpu_lit_s0: supplied by vcc5v0_sys [ 4.831373] vcc5v0_sys: could not add device link regulator.9: -ENOENT [ 4.831641] vdd_cpu_lit_s0: 550 <--> 950 mV at 750 mV, enabled [ 4.832193] rk806-regulator rk806-regulator.6.auto: Looking up vcc3-supply from device tree [ 4.832199] vdd_log_s0: supplied by vcc5v0_sys [ 4.832204] vcc5v0_sys: could not add device link regulator.10: -ENOENT [ 4.832431] vdd_log_s0: 675 <--> 750 mV at 750 mV, enabled [ 4.832892] rk806-regulator rk806-regulator.6.auto: Looking up vcc4-supply from device tree [ 4.832898] vdd_vdenc_s0: supplied by vcc5v0_sys [ 4.832903] vcc5v0_sys: could not add device link regulator.11: -ENOENT [ 4.833128] vdd_vdenc_s0: 550 <--> 950 mV at 750 mV, enabled [ 4.833662] rk806-regulator rk806-regulator.6.auto: Looking up vcc5-supply from device tree [ 4.833668] vdd_ddr_s0: supplied by vcc5v0_sys [ 4.833673] vcc5v0_sys: could not add device link regulator.12: -ENOENT [ 4.833895] vdd_ddr_s0: 675 <--> 900 mV at 850 mV, enabled [ 4.834095] rk806-regulator rk806-regulator.6.auto: Looking up vcc6-supply from device tree [ 4.834101] vdd2_ddr_s3: supplied by vcc5v0_sys [ 4.834105] vcc5v0_sys: could not add device link regulator.13: -ENOENT [ 4.834396] vdd2_ddr_s3: at 500 mV, enabled [ 4.834743] rk806-regulator rk806-regulator.6.auto: Looking up vcc7-supply from device tree [ 4.834749] vdd_2v0_pldo_s3: supplied by vcc5v0_sys [ 4.834754] vcc5v0_sys: could not add device link regulator.14: -ENOENT [ 4.834981] vdd_2v0_pldo_s3: 2000 mV, enabled [ 4.835332] rk806-regulator rk806-regulator.6.auto: Looking up vcc8-supply from device tree [ 4.835338] vcc_3v3_s3: supplied by vcc5v0_sys [ 4.835343] vcc5v0_sys: could not add device link regulator.15: -ENOENT [ 4.835564] vcc_3v3_s3: 3300 mV, enabled [ 4.835895] rk806-regulator rk806-regulator.6.auto: Looking up vcc9-supply from device tree [ 4.835901] vddq_ddr_s0: supplied by vcc5v0_sys [ 4.835905] vcc5v0_sys: could not add device link regulator.16: -ENOENT [ 4.836198] vddq_ddr_s0: at 500 mV, enabled [ 4.836614] rk806-regulator rk806-regulator.6.auto: Looking up vcc10-supply from device tree [ 4.836621] vcc_1v8_s3: supplied by vcc5v0_sys [ 4.836626] vcc5v0_sys: could not add device link regulator.17: -ENOENT [ 4.836857] vcc_1v8_s3: 1800 mV, enabled [ 4.837237] rk806-regulator rk806-regulator.6.auto: Looking up vcc13-supply from device tree [ 4.837320] vdd_0v75_s3: supplied by vcc_1v1_nldo_s3 [ 4.837325] vcc_1v1_nldo_s3: could not add device link regulator.18: -ENOENT [ 4.837588] vdd_0v75_s3: 750 mV, enabled [ 4.838106] rk806-regulator rk806-regulator.6.auto: Looking up vcc13-supply from device tree [ 4.838116] vdd_ddr_pll_s0: supplied by vcc_1v1_nldo_s3 [ 4.838122] vcc_1v1_nldo_s3: could not add device link regulator.19: -ENOENT [ 4.838347] vdd_ddr_pll_s0: 850 mV, enabled [ 4.838691] avdd_0v75_s0: Bringing 750000uV into 837500-837500uV [ 4.838884] avdd_0v75_s0: ramp_delay not set [ 4.838986] rk806-regulator rk806-regulator.6.auto: Looking up vcc13-supply from device tree [ 4.838995] avdd_0v75_s0: supplied by vcc_1v1_nldo_s3 [ 4.839001] vcc_1v1_nldo_s3: could not add device link regulator.20: -ENOENT [ 4.839304] avdd_0v75_s0: 837 mV, enabled [ 4.839775] rk806-regulator rk806-regulator.6.auto: Looking up vcc14-supply from device tree [ 4.839783] vdd_0v85_s0: supplied by vcc_1v1_nldo_s3 [ 4.839788] vcc_1v1_nldo_s3: could not add device link regulator.21: -ENOENT [ 4.840093] vdd_0v85_s0: 850 mV, enabled [ 4.840543] rk806-regulator rk806-regulator.6.auto: Looking up vcc14-supply from device tree [ 4.840550] vdd_0v75_s0: supplied by vcc_1v1_nldo_s3 [ 4.840555] vcc_1v1_nldo_s3: could not add device link regulator.22: -ENOENT [ 4.840791] vdd_0v75_s0: 750 mV, enabled [ 4.841307] rk806-regulator rk806-regulator.6.auto: Looking up vcc11-supply from device tree [ 4.841366] avcc_1v8_s0: supplied by vdd_2v0_pldo_s3 [ 4.841372] vdd_2v0_pldo_s3: could not add device link regulator.23: -ENOENT [ 4.841754] avcc_1v8_s0: 1800 mV, enabled [ 4.842308] rk806-regulator rk806-regulator.6.auto: Looking up vcc11-supply from device tree [ 4.842316] vcc_1v8_s0: supplied by vdd_2v0_pldo_s3 [ 4.842321] vdd_2v0_pldo_s3: could not add device link regulator.24: -ENOENT [ 4.842685] vcc_1v8_s0: 1800 mV, enabled [ 4.843028] rk806-regulator rk806-regulator.6.auto: Looking up vcc11-supply from device tree [ 4.843036] avdd_1v2_s0: supplied by vdd_2v0_pldo_s3 [ 4.843043] vdd_2v0_pldo_s3: could not add device link regulator.25: -ENOENT [ 4.843327] avdd_1v2_s0: 1200 mV, enabled [ 4.843667] rk806-regulator rk806-regulator.6.auto: Looking up vcc12-supply from device tree [ 4.843673] vcc_3v3_s0: supplied by vcc5v0_sys [ 4.843678] vcc5v0_sys: could not add device link regulator.26: -ENOENT [ 4.843897] vcc_3v3_s0: 3300 mV, enabled [ 4.844235] rk806-regulator rk806-regulator.6.auto: Looking up vcc12-supply from device tree [ 4.844241] vccio_sd_s0: supplied by vcc5v0_sys [ 4.844246] vcc5v0_sys: could not add device link regulator.27: -ENOENT [ 4.844471] vccio_sd_s0: 1800 <--> 3300 mV at 3300 mV, enabled [ 4.844819] rk806-regulator rk806-regulator.6.auto: Looking up vcca-supply from device tree [ 4.844826] pldo6_s3: supplied by vcc5v0_sys [ 4.844831] vcc5v0_sys: could not add device link regulator.28: -ENOENT [ 4.845071] pldo6_s3: 1800 mV, enabled [ 4.845427] rk806 spi2.0: no sleep-setting state [ 4.845431] rk806 spi2.0: no reset-setting pinctrl state [ 4.845434] rk806 spi2.0: no dvs-setting pinctrl state [ 4.847339] rockchip-spi feb20000.spi: register misc device rkspi-dev2 [ 4.847344] rockchip-spi feb20000.spi: probed, poll=0, rsd=0 [ 4.848905] spi-nor spi5.0: XM25QU128C (16384 Kbytes) read_data x4 [ 4.848921] 1 fixed-partitions partitions found on MTD device sfc_nor [ 4.848924] Creating 1 MTD partitions on "sfc_nor": [ 4.848929] 0x000000000000-0x000001000000 : "loader" [ 4.851017] rk_gmac-dwmac fe1c0000.ethernet: IRQ eth_lpi not found [ 4.851167] rk_gmac-dwmac fe1c0000.ethernet: Looking up phy-supply from device tree [ 4.851181] rk_gmac-dwmac fe1c0000.ethernet: Looking up phy-supply property in node /ethernet@fe1c0000 failed [ 4.851193] rk_gmac-dwmac fe1c0000.ethernet: no regulator found [ 4.851197] rk_gmac-dwmac fe1c0000.ethernet: clock input or output? (output). [ 4.851202] rk_gmac-dwmac fe1c0000.ethernet: TX delay(0x42). [ 4.851205] rk_gmac-dwmac fe1c0000.ethernet: Can not read property: rx_delay. [ 4.851209] rk_gmac-dwmac fe1c0000.ethernet: set rx_delay to 0xffffffff [ 4.851218] rk_gmac-dwmac fe1c0000.ethernet: integrated PHY? (no). [ 4.851223] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_rx [ 4.851227] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_tx [ 4.851241] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock clk_mac_speed [ 4.851463] rk_gmac-dwmac fe1c0000.ethernet: init for RGMII_RXID [ 4.851563] rk_gmac-dwmac fe1c0000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 4.851568] rk_gmac-dwmac fe1c0000.ethernet: DWMAC4/5 [ 4.851573] rk_gmac-dwmac fe1c0000.ethernet: DMA HW capability register supported [ 4.851577] rk_gmac-dwmac fe1c0000.ethernet: RX Checksum Offload Engine supported [ 4.851580] rk_gmac-dwmac fe1c0000.ethernet: TX Checksum insertion supported [ 4.851583] rk_gmac-dwmac fe1c0000.ethernet: Wake-Up On Lan supported [ 4.851616] rk_gmac-dwmac fe1c0000.ethernet: TSO supported [ 4.851619] rk_gmac-dwmac fe1c0000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 4.851624] rk_gmac-dwmac fe1c0000.ethernet: Enabled Flow TC (entries=2) [ 4.851627] rk_gmac-dwmac fe1c0000.ethernet: TSO feature enabled [ 4.851631] rk_gmac-dwmac fe1c0000.ethernet: Using 32 bits DMA width [ 4.854792] nvme nvme0: 7/0/0 default/read/poll queues [ 4.866763] nvme0n1: p1 p2 [ 4.993095] usbcore: registered new interface driver rndis_wlan [ 4.993116] usbcore: registered new interface driver asix [ 4.993135] usbcore: registered new interface driver cdc_ether [ 4.993151] usbcore: registered new interface driver rndis_host [ 4.993172] usbcore: registered new interface driver cdc_ncm [ 4.998536] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up usb-supply from device tree [ 4.998567] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up usb-supply property in node /power-management@fd8d8000/power-controller failed [ 5.000526] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 5.000553] ehci-pci: EHCI PCI platform driver [ 5.000585] ehci-platform: EHCI generic platform driver [ 5.002861] ehci-platform fc800000.usb: EHCI Host Controller [ 5.002874] ehci-platform fc800000.usb: new USB bus registered, assigned bus number 1 [ 5.002944] ehci-platform fc800000.usb: irq 20, io mem 0xfc800000 [ 5.013883] ehci-platform fc800000.usb: USB 2.0 started, EHCI 1.00 [ 5.014006] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 5.014011] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.014014] usb usb1: Product: EHCI Host Controller [ 5.014018] usb usb1: Manufacturer: Linux 5.10.160-rk35xx ehci_hcd [ 5.014021] usb usb1: SerialNumber: fc800000.usb [ 5.014273] hub 1-0:1.0: USB hub found [ 5.014294] hub 1-0:1.0: 1 port detected [ 5.016708] ehci-platform fc880000.usb: EHCI Host Controller [ 5.016719] ehci-platform fc880000.usb: new USB bus registered, assigned bus number 2 [ 5.016778] ehci-platform fc880000.usb: irq 22, io mem 0xfc880000 [ 5.027214] ehci-platform fc880000.usb: USB 2.0 started, EHCI 1.00 [ 5.027321] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 5.027325] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.027329] usb usb2: Product: EHCI Host Controller [ 5.027332] usb usb2: Manufacturer: Linux 5.10.160-rk35xx ehci_hcd [ 5.027335] usb usb2: SerialNumber: fc880000.usb [ 5.027552] hub 2-0:1.0: USB hub found [ 5.027570] hub 2-0:1.0: 1 port detected [ 5.027987] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 5.027997] ohci-platform: OHCI generic platform driver [ 5.028169] ohci-platform fc840000.usb: Generic Platform OHCI controller [ 5.028179] ohci-platform fc840000.usb: new USB bus registered, assigned bus number 3 [ 5.028227] ohci-platform fc840000.usb: irq 21, io mem 0xfc840000 [ 5.087980] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10 [ 5.087985] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.087989] usb usb3: Product: Generic Platform OHCI controller [ 5.087992] usb usb3: Manufacturer: Linux 5.10.160-rk35xx ohci_hcd [ 5.087996] usb usb3: SerialNumber: fc840000.usb [ 5.088206] hub 3-0:1.0: USB hub found [ 5.088224] hub 3-0:1.0: 1 port detected [ 5.088520] ohci-platform fc8c0000.usb: Generic Platform OHCI controller [ 5.088529] ohci-platform fc8c0000.usb: new USB bus registered, assigned bus number 4 [ 5.088575] ohci-platform fc8c0000.usb: irq 23, io mem 0xfc8c0000 [ 5.147973] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10 [ 5.147978] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.147981] usb usb4: Product: Generic Platform OHCI controller [ 5.147985] usb usb4: Manufacturer: Linux 5.10.160-rk35xx ohci_hcd [ 5.147988] usb usb4: SerialNumber: fc8c0000.usb [ 5.148192] hub 4-0:1.0: USB hub found [ 5.148212] hub 4-0:1.0: 1 port detected [ 5.148798] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 5.148808] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 5 [ 5.148889] xhci-hcd xhci-hcd.7.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000200002010010 [ 5.148915] xhci-hcd xhci-hcd.7.auto: irq 139, io mem 0xfcd00000 [ 5.149073] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 5.149078] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.149081] usb usb5: Product: xHCI Host Controller [ 5.149085] usb usb5: Manufacturer: Linux 5.10.160-rk35xx xhci-hcd [ 5.149088] usb usb5: SerialNumber: xhci-hcd.7.auto [ 5.149305] hub 5-0:1.0: USB hub found [ 5.149323] hub 5-0:1.0: 1 port detected [ 5.149479] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 5.149486] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 6 [ 5.149493] xhci-hcd xhci-hcd.7.auto: Host supports USB 3.0 SuperSpeed [ 5.149531] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM. [ 5.149595] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 [ 5.149599] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.149602] usb usb6: Product: xHCI Host Controller [ 5.149606] usb usb6: Manufacturer: Linux 5.10.160-rk35xx xhci-hcd [ 5.149609] usb usb6: SerialNumber: xhci-hcd.7.auto [ 5.149816] hub 6-0:1.0: USB hub found [ 5.149833] hub 6-0:1.0: 1 port detected [ 5.150045] usbcore: registered new interface driver cdc_acm [ 5.150049] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 5.150157] usbcore: registered new interface driver uas [ 5.150216] usbcore: registered new interface driver usb-storage [ 5.150846] Error: Driver 'Goodix-TS' is already registered, aborting... [ 5.150882] usbcore: registered new interface driver usbtouchscreen [ 5.152160] input: rk805 pwrkey as /devices/platform/feb20000.spi/spi_master/spi2/spi2.0/rk805-pwrkey.5.auto/input/input0 [ 5.152435] i2c /dev entries driver [ 5.156065] rk860-regulator 0-0042: Looking up vin-supply from device tree [ 5.156073] vdd_cpu_big0_s0: supplied by vcc5v0_sys [ 5.156083] vcc5v0_sys: could not add device link regulator.29: -ENOENT [ 5.160180] vdd_cpu_big0_s0: 550 <--> 1050 mV at 800 mV, enabled [ 5.164710] rk860-regulator 0-0043: Looking up vin-supply from device tree [ 5.164716] vdd_cpu_big1_s0: supplied by vcc5v0_sys [ 5.164721] vcc5v0_sys: could not add device link regulator.30: -ENOENT [ 5.168813] vdd_cpu_big1_s0: 550 <--> 1050 mV at 800 mV, enabled [ 5.171036] Goodix-TS 2-0014: Looking up AVDD28-supply from device tree [ 5.171044] Goodix-TS 2-0014: Looking up AVDD28-supply property in node /i2c@feaa0000/touchscreen@14 failed [ 5.171057] Goodix-TS 2-0014: supply AVDD28 not found, using dummy regulator [ 5.171114] Goodix-TS 2-0014: Looking up VDDIO-supply from device tree [ 5.171121] Goodix-TS 2-0014: Looking up VDDIO-supply property in node /i2c@feaa0000/touchscreen@14 failed [ 5.171129] Goodix-TS 2-0014: supply VDDIO not found, using dummy regulator [ 5.264024] Goodix-TS 2-0014: i2c test failed attempt 1: -6 [ 5.290687] Goodix-TS 2-0014: i2c test failed attempt 2: -6 [ 5.317206] Goodix-TS 2-0014: I2C communication failure: -6 [ 5.320387] rk860-regulator 2-0042: Looking up vin-supply from device tree [ 5.320394] vdd_npu_s0: supplied by vcc5v0_sys [ 5.320399] vcc5v0_sys: could not add device link regulator.31: -ENOENT [ 5.324472] vdd_npu_s0: 550 <--> 950 mV at 800 mV, enabled [ 5.327436] typec_fusb302 6-0022: Looking up vbus-supply from device tree [ 5.354902] rtc-hym8563 6-0051: rtc information is valid [ 5.360210] rtc-hym8563 6-0051: registered as rtc0 [ 5.361222] rtc-hym8563 6-0051: setting system clock to 2023-08-07T18:23:18 UTC (1691432598) [ 5.363837] Goodix-TS 7-0014: Looking up AVDD28-supply from device tree [ 5.363846] Goodix-TS 7-0014: Looking up AVDD28-supply property in node /i2c@fec90000/touchscreen@14 failed [ 5.363873] Goodix-TS 7-0014: supply AVDD28 not found, using dummy regulator [ 5.363935] Goodix-TS 7-0014: Looking up VDDIO-supply from device tree [ 5.363942] Goodix-TS 7-0014: Looking up VDDIO-supply property in node /i2c@fec90000/touchscreen@14 failed [ 5.363951] Goodix-TS 7-0014: supply VDDIO not found, using dummy regulator [ 5.457363] Goodix-TS 7-0014: i2c test failed attempt 1: -6 [ 5.484021] Goodix-TS 7-0014: i2c test failed attempt 2: -6 [ 5.510540] Goodix-TS 7-0014: I2C communication failure: -6 [ 5.511613] rkcifhw fdce0000.rkcif: Adding to iommu group 16 [ 5.511980] rkcifhw fdce0000.rkcif: No reserved memory region assign to CIF [ 5.513138] rkisp_hw fdcb0000.rkisp: Adding to iommu group 14 [ 5.513251] rkisp_hw fdcb0000.rkisp: is_thunderboot: 0 [ 5.513255] rkisp_hw fdcb0000.rkisp: max input:0x0@0fps [ 5.513260] rkisp_hw fdcb0000.rkisp: Missing rockchip,grf property [ 5.513363] rkisp_hw fdcb0000.rkisp: no find phandle sram [ 5.513431] rkisp_hw fdcc0000.rkisp: Adding to iommu group 15 [ 5.513582] rkisp_hw fdcc0000.rkisp: is_thunderboot: 0 [ 5.513586] rkisp_hw fdcc0000.rkisp: max input:0x0@0fps [ 5.513589] rkisp_hw fdcc0000.rkisp: Missing rockchip,grf property [ 5.513682] rkisp_hw fdcc0000.rkisp: no find phandle sram [ 5.514634] usbcore: registered new interface driver uvcvideo [ 5.514638] USB Video Class driver (1.1.1) [ 5.516049] cpu cpu0: Looking up cpu-supply from device tree [ 5.516551] cpu cpu0: bin=0 [ 5.516726] cpu cpu0: leakage=8 [ 5.516751] cpu cpu0: Looking up cpu-supply from device tree [ 5.518219] cpu cpu0: pvtm=1380 [ 5.518377] cpu cpu0: pvtm-volt-sel=0 [ 5.518418] cpu cpu0: Looking up cpu-supply from device tree [ 5.518557] cpu cpu0: Looking up mem-supply from device tree [ 5.518742] cpu cpu4: Looking up cpu-supply from device tree [ 5.520422] cpu cpu4: bin=0 [ 5.520593] cpu cpu4: leakage=6 [ 5.520614] cpu cpu4: Looking up cpu-supply from device tree [ 5.527147] cpu cpu4: pvtm=1588 [ 5.531116] cpu cpu4: pvtm-volt-sel=0 [ 5.531159] cpu cpu4: Looking up cpu-supply from device tree [ 5.531661] cpu cpu4: Looking up mem-supply from device tree [ 5.532214] cpu cpu6: Looking up cpu-supply from device tree [ 5.533879] cpu cpu6: bin=0 [ 5.534050] cpu cpu6: leakage=6 [ 5.534068] cpu cpu6: Looking up cpu-supply from device tree [ 5.540533] cpu cpu6: pvtm=1590 [ 5.544471] cpu cpu6: pvtm-volt-sel=0 [ 5.544511] cpu cpu6: Looking up cpu-supply from device tree [ 5.545020] cpu cpu6: Looking up mem-supply from device tree [ 5.546199] cpu cpu0: avs=0 [ 5.546980] cpu cpu4: avs=0 [ 5.547777] cpu cpu6: avs=0 [ 5.547948] cpu cpu0: EM: OPP:816000 is inefficient [ 5.547952] cpu cpu0: EM: OPP:600000 is inefficient [ 5.548045] cpu cpu0: EM: created perf domain [ 5.548083] cpu cpu0: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=1608000000 h_table=0 [ 5.548658] cpu cpu4: EM: OPP:816000 is inefficient [ 5.548662] cpu cpu4: EM: OPP:600000 is inefficient [ 5.548781] cpu cpu4: EM: created perf domain [ 5.548811] cpu cpu4: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0 [ 5.557076] cpu cpu6: EM: OPP:816000 is inefficient [ 5.557080] cpu cpu6: EM: OPP:600000 is inefficient [ 5.557217] cpu cpu6: EM: created perf domain [ 5.557620] cpu cpu6: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0 [ 5.567245] usb 3-1: new full-speed USB device number 2 using ohci-platform [ 5.571143] sdhci: Secure Digital Host Controller Interface driver [ 5.571148] sdhci: Copyright(c) Pierre Ossman [ 5.571153] Synopsys Designware Multimedia Card Interface Driver [ 5.572115] sdhci-pltfm: SDHCI platform and OF driver helper [ 5.576450] ledtrig-cpu: registered to indicate activity on CPUs [ 5.576507] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active. [ 5.576590] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 5.578352] cryptodev: driver 1.12 loaded. [ 5.578433] hid: raw HID events driver (C) Jiri Kosina [ 5.579037] usbcore: registered new interface driver usbhid [ 5.579044] usbhid: USB HID core driver [ 5.579710] ashmem: initialized [ 5.587025] rockchip-saradc fec10000.saradc: Looking up vref-supply from device tree [ 5.591839] optee: probing for conduit method. [ 5.591848] optee: api uid mismatch [ 5.591863] optee: probe of firmware:optee failed with error -22 [ 5.593072] usbcore: registered new interface driver snd-usb-audio [ 5.601447] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up audio-supply from device tree [ 5.601501] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up audio-supply property in node /power-management@fd8d8000/power-controller failed [ 5.606036] debugfs: File 'Capture' in directory 'dapm' already present! [ 5.607889] input: rockchip-dp0 rockchip-dp0 as /devices/platform/dp0-sound/sound/card0/input1 [ 5.610335] input: rockchip-hdmi0 rockchip-hdmi0 as /devices/platform/hdmi0-sound/sound/card1/input2 [ 5.612079] input: headset-keys as /devices/platform/es8388-sound/input/input3 [ 5.623570] ES8323 6-0010: ASoC: error at soc_component_write_no_lock on ES8323.6-0010: -5 [ 5.679735] input: rockchip-es8388 Headset as /devices/platform/es8388-sound/sound/card2/input4 [ 5.680333] Initializing XFRM netlink socket [ 5.680346] NET: Registered protocol family 17 [ 5.680744] [BT_RFKILL]: Enter rfkill_rk_init [ 5.680748] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 5.681145] Key type dns_resolver registered [ 5.682538] registered taskstats version 1 [ 5.682545] Loading compiled-in X.509 certificates [ 5.683307] Btrfs loaded, crc32c=crc32c-generic [ 5.683434] pstore: Using crash dump compression: deflate [ 5.683675] rga3_core0 fdb60000.rga: Adding to iommu group 2 [ 5.683859] rga: rga3_core0, irq = 35, match scheduler [ 5.684505] rga: rga3_core0 hardware loaded successfully, hw_version:3.0.76831. [ 5.684553] rga: rga3_core0 probe successfully [ 5.684855] rga3_core1 fdb70000.rga: Adding to iommu group 3 [ 5.685044] rga: rga3_core1, irq = 36, match scheduler [ 5.685590] rga: rga3_core1 hardware loaded successfully, hw_version:3.0.76831. [ 5.685639] rga: rga3_core1 probe successfully [ 5.685973] rga: rga2, irq = 37, match scheduler [ 5.686502] rga: rga2 hardware loaded successfully, hw_version:3.2.63318. [ 5.686511] rga: rga2 probe successfully [ 5.686714] rga_iommu: IOMMU binding successfully, default mapping core[0x1] [ 5.686915] rga: Module initialized. v1.2.25 [ 5.734021] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up gpu-supply from device tree [ 5.734048] reg-fixed-voltage combophy-avdd0v85: Looking up vin-supply from device tree [ 5.734233] combophy_avdd0v85: supplied by vdd_0v85_s0 [ 5.734243] vdd_0v85_s0: could not add device link regulator.32: -ENOENT [ 5.734282] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up gpu-supply property in node /power-management@fd8d8000/power-controller failed [ 5.734470] mali fb000000.gpu: Kernel DDK version g17p0-01eac0 [ 5.734564] mali fb000000.gpu: Looking up mali-supply from device tree [ 5.734717] combophy_avdd0v85: 850 mV, enabled [ 5.734905] reg-fixed-voltage combophy-avdd0v85: combophy_avdd0v85 supplying 850000uV [ 5.734959] mali fb000000.gpu: Looking up mem-supply from device tree [ 5.735063] mali fb000000.gpu: Looking up mali-supply from device tree [ 5.735081] vdd_gpu_s0: could not add device link fb000000.gpu: -EEXIST [ 5.735085] vdd_gpu_s0: Failed to create debugfs directory [ 5.735092] mali fb000000.gpu: Looking up mem-supply from device tree [ 5.735103] reg-fixed-voltage combophy-avdd1v8: Looking up vin-supply from device tree [ 5.735106] vdd_gpu_s0: could not add device link fb000000.gpu: -EEXIST [ 5.735110] vdd_gpu_s0: Failed to create debugfs directory [ 5.735170] combophy_avdd1v8: supplied by avcc_1v8_s0 [ 5.735179] avcc_1v8_s0: could not add device link regulator.33: -ENOENT [ 5.735315] mali fb000000.gpu: Looking up mali-supply from device tree [ 5.735341] vdd_gpu_s0: could not add device link fb000000.gpu: -EEXIST [ 5.735347] vdd_gpu_s0: Failed to create debugfs directory [ 5.735878] combophy_avdd1v8: 1800 mV, enabled [ 5.736184] reg-fixed-voltage combophy-avdd1v8: combophy_avdd1v8 supplying 1800000uV [ 5.736236] mali fb000000.gpu: bin=0 [ 5.736397] vcc_3v3_sd_s0: 3300 mV, disabled [ 5.736436] mali fb000000.gpu: leakage=13 [ 5.736479] mali fb000000.gpu: Looking up mali-supply from device tree [ 5.736508] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present! [ 5.736557] reg-fixed-voltage vcc-3v3-sd-s0: Looking up vin-supply from device tree [ 5.736573] vcc_3v3_sd_s0: supplied by vcc_3v3_s3 [ 5.737101] reg-fixed-voltage vcc-3v3-sd-s0: vcc_3v3_sd_s0 supplying 3300000uV [ 5.738109] rockchip-dmc dmc: Looking up center-supply from device tree [ 5.738131] mali fb000000.gpu: pvtm=847 [ 5.738641] mali fb000000.gpu: pvtm-volt-sel=2 [ 5.739010] rockchip-dmc dmc: Looking up mem-supply from device tree [ 5.739626] rockchip-dmc dmc: Looking up center-supply from device tree [ 5.739654] vdd_ddr_s0: could not add device link dmc: -EEXIST [ 5.739660] vdd_ddr_s0: Failed to create debugfs directory [ 5.739975] mali fb000000.gpu: avs=0 [ 5.740128] rockchip-dmc dmc: Looking up mem-supply from device tree [ 5.740161] vdd_log_s0: could not add device link dmc: -EEXIST [ 5.740167] vdd_log_s0: Failed to create debugfs directory [ 5.740467] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 143; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available. [ 5.740616] rockchip-dmc dmc: leakage=30 [ 5.740634] rockchip-dmc dmc: leakage-volt-sel=0 [ 5.741343] rockchip-dmc dmc: avs=0 [ 5.741364] rockchip-dmc dmc: current ATF version 0x100 [ 5.741534] rockchip-dmc dmc: normal_rate = 1560000000 [ 5.741544] rockchip-dmc dmc: reboot_rate = 2112000000 [ 5.741552] rockchip-dmc dmc: suspend_rate = 528000000 [ 5.741560] rockchip-dmc dmc: video_4k_rate = 1560000000 [ 5.741568] rockchip-dmc dmc: video_4k_10b_rate = 1560000000 [ 5.741576] rockchip-dmc dmc: video_svep_rate = 1560000000 [ 5.741584] rockchip-dmc dmc: boost_rate = 2112000000 [ 5.741592] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 2112000000 [ 5.741600] rockchip-dmc dmc: performance_rate = 2112000000 [ 5.741610] rockchip-dmc dmc: hdmirx_rate = 2112000000 [ 5.741622] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate [ 5.741629] rockchip-dmc dmc: failed to get vop pn to msch rl [ 5.741714] mali fb000000.gpu: GPU hardware issue table may need updating: r0p0 status 5 is unknown; treating as r0p0 status 0 [ 5.741731] mali fb000000.gpu: GPU identified as 0x7 arch 10.8.6 r0p0 status 0 [ 5.741807] mali fb000000.gpu: No priority control manager is configured [ 5.741829] rockchip-dmc dmc: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0 [ 5.742299] mali fb000000.gpu: No memory group manager is configured [ 5.742344] mali fb000000.gpu: Protected memory allocator not available [ 5.742372] rockchip-dmc dmc: could not find power_model node [ 5.743562] mali fb000000.gpu: Capping CSF_FIRMWARE_TIMEOUT to CSF_FIRMWARE_PING_TIMEOUT [ 5.744598] mali fb000000.gpu: Couldn't find power_model DT node matching 'arm,mali-simple-power-model' [ 5.744612] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.static-coefficient = 1*[0] [ 5.744984] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.dynamic-coefficient = 1*[0] [ 5.745334] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.ts = 4*[0] [ 5.745681] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.thermal-zone = '' [ 5.750938] mali fb000000.gpu: Using configured power model mali-lodx-power-model, and fallback mali-simple-power-model [ 5.751136] mali fb000000.gpu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0 [ 5.752267] input: adc-keys as /devices/platform/adc-keys/input/input5 [ 5.753699] mali fb000000.gpu: Probed as mali0 [ 5.754938] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up sdmmc-supply from device tree [ 5.754996] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up sdmmc-supply property in node /power-management@fd8d8000/power-controller failed [ 5.755036] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up sdio-supply from device tree [ 5.755084] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up sdio-supply property in node /power-management@fd8d8000/power-controller failed [ 5.755137] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up pcie-supply from device tree [ 5.755187] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up pcie-supply property in node /power-management@fd8d8000/power-controller failed [ 5.755235] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu-supply from device tree [ 5.755289] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu-supply property in node /power-management@fd8d8000/power-controller failed [ 5.755449] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode. [ 5.755487] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller. [ 5.755500] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a [ 5.755558] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 90,32 bit host data width,256 deep fifo [ 5.755667] dwmmc_rockchip fe2c0000.mmc: Looking up vmmc-supply from device tree [ 5.755951] dwmmc_rockchip fe2c0000.mmc: Looking up vqmmc-supply from device tree [ 5.757349] RKNPU fdab0000.npu: Adding to iommu group 0 [ 5.757539] RKNPU fdab0000.npu: RKNPU: rknpu iommu is enabled, using iommu mode [ 5.757661] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 5.758547] RKNPU fdab0000.npu: Looking up mem-supply from device tree [ 5.759400] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff] [ 5.759434] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff] [ 5.759451] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff] [ 5.759890] [drm] Initialized rknpu 0.8.5 20230202 for fdab0000.npu on minor 1 [ 5.760324] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up nputop-supply from device tree [ 5.760364] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up nputop-supply property in node /power-management@fd8d8000/power-controller failed [ 5.760448] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu1-supply from device tree [ 5.760481] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu1-supply property in node /power-management@fd8d8000/power-controller failed [ 5.760561] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu2-supply from device tree [ 5.760595] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu2-supply property in node /power-management@fd8d8000/power-controller failed [ 5.760778] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 5.760809] vdd_npu_s0: could not add device link fdab0000.npu: -EEXIST [ 5.760814] vdd_npu_s0: Failed to create debugfs directory [ 5.761494] RKNPU fdab0000.npu: Looking up mem-supply from device tree [ 5.761547] vdd_npu_s0: could not add device link fdab0000.npu: -EEXIST [ 5.761551] vdd_npu_s0: Failed to create debugfs directory [ 5.762485] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 5.762531] vdd_npu_s0: could not add device link fdab0000.npu: -EEXIST [ 5.762536] vdd_npu_s0: Failed to create debugfs directory [ 5.764621] RKNPU fdab0000.npu: RKNPU: bin=0 [ 5.764802] RKNPU fdab0000.npu: leakage=7 [ 5.764848] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 5.764890] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present! [ 5.772107] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 5.773275] RKNPU fdab0000.npu: pvtm=846 [ 5.778929] RKNPU fdab0000.npu: pvtm-volt-sel=2 [ 5.780664] RKNPU fdab0000.npu: avs=0 [ 5.781006] RKNPU fdab0000.npu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0 [ 5.787788] usb 3-1: New USB device found, idVendor=046d, idProduct=c539, bcdDevice=39.06 [ 5.787804] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 5.787816] usb 3-1: Product: USB Receiver [ 5.787827] usb 3-1: Manufacturer: Logitech [ 5.795347] RKNPU fdab0000.npu: failed to find power_model node [ 5.795364] RKNPU fdab0000.npu: RKNPU: failed to initialize power model [ 5.795375] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient [ 5.796638] input: Logitech USB Receiver as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.0/0003:046D:C539.0001/input/input6 [ 5.802638] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 5.815491] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 5.820053] rockchip-pm rockchip-suspend: not set pwm-regulator-config [ 5.820068] rockchip-suspend not set sleep-mode-config for mem-lite [ 5.820072] rockchip-suspend not set wakeup-config for mem-lite [ 5.820080] rockchip-suspend not set sleep-mode-config for mem-ultra [ 5.820084] rockchip-suspend not set wakeup-config for mem-ultra [ 5.821509] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 406; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '13:36:29', on 'Jul 6 2023'. [ 5.821915] Mali: [ 5.821918] Mali device driver loaded [ 5.821928] ALSA device list: [ 5.821933] #0: rockchip-dp0 [ 5.821937] #1: rockchip-hdmi0 [ 5.821942] #2: rockchip-es8388 [ 5.826511] Freeing unused kernel memory: 6976K [ 5.850994] Run /init as init process [ 5.851014] with arguments: [ 5.851027] /init [ 5.851039] splash [ 5.851051] with environment: [ 5.851062] HOME=/ [ 5.851074] TERM=linux [ 5.851086] ubootpart= [ 5.851098] cgroup_enable=memory [ 5.851109] cgroup_memory=1 [ 5.853002] hid-generic 0003:046D:C539.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-fc840000.usb-1/input0 [ 5.861363] input: Logitech USB Receiver Mouse as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input7 [ 5.917388] input: Logitech USB Receiver Consumer Control as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input8 [ 5.917744] input: Logitech USB Receiver System Control as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input9 [ 5.918121] hid-generic 0003:046D:C539.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-fc840000.usb-1/input1 [ 5.923323] hid-generic 0003:046D:C539.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-fc840000.usb-1/input2 [ 6.942248] EXT4-fs (nvme0n1p2): mounted filesystem with writeback data mode. Opts: (null) [ 7.179856] NET: Registered protocol family 10 [ 7.181689] Segment Routing with IPv6 [ 7.199346] systemd[1]: systemd 249.11-0ubuntu3.9 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified) [ 7.200732] systemd[1]: Detected architecture arm64. [ 7.201736] systemd[1]: Hostname set to . [ 7.496061] systemd[1]: Queued start job for default target Graphical Interface. [ 7.497651] systemd[1]: Created slice Slice /system/modprobe. [ 7.498183] systemd[1]: Created slice Slice /system/serial-getty. [ 7.498642] systemd[1]: Created slice Slice /system/systemd-fsck. [ 7.498934] systemd[1]: Created slice User and Session Slice. [ 7.499054] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 7.499369] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 7.499485] systemd[1]: Reached target User and Group Name Lookups. [ 7.499536] systemd[1]: Reached target Slice Units. [ 7.499571] systemd[1]: Reached target Swaps. [ 7.499600] systemd[1]: Reached target System Time Set. [ 7.499671] systemd[1]: Reached target Local Verity Protected Volumes. [ 7.508369] systemd[1]: Listening on RPCbind Server Activation Socket. [ 7.508630] systemd[1]: Listening on Syslog Socket. [ 7.508797] systemd[1]: Listening on fsck to fsckd communication Socket. [ 7.508895] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 7.509185] systemd[1]: Listening on Journal Audit Socket. [ 7.509326] systemd[1]: Listening on Journal Socket (/dev/log). [ 7.509524] systemd[1]: Listening on Journal Socket. [ 7.510407] systemd[1]: Listening on udev Control Socket. [ 7.510570] systemd[1]: Listening on udev Kernel Socket. [ 7.511647] systemd[1]: Mounting Huge Pages File System... [ 7.512784] systemd[1]: Mounting POSIX Message Queue File System... [ 7.513987] systemd[1]: Mounting Kernel Debug File System... [ 7.515371] systemd[1]: Mounting Kernel Trace File System... [ 7.515687] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped. [ 7.517579] systemd[1]: Starting Restore / save the current clock... [ 7.519355] systemd[1]: Starting Set the console keyboard layout... [ 7.521026] systemd[1]: Starting Create List of Static Device Nodes... [ 7.522677] systemd[1]: Starting Load Kernel Module chromeos_pstore... [ 7.524264] systemd[1]: Starting Load Kernel Module configfs... [ 7.526353] systemd[1]: Starting Load Kernel Module drm... [ 7.528564] systemd[1]: Starting Load Kernel Module efi_pstore... [ 7.531182] systemd[1]: Starting Load Kernel Module fuse... [ 7.533183] systemd[1]: Starting Load Kernel Module pstore_blk... [ 7.534893] systemd[1]: Starting Load Kernel Module pstore_zone... [ 7.536859] systemd[1]: Starting Load Kernel Module ramoops... [ 7.537295] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 7.540142] systemd[1]: Starting Load Kernel Modules... [ 7.542070] systemd[1]: Starting Remount Root and Kernel File Systems... [ 7.542437] fuse: init (API version 7.32) [ 7.543824] systemd[1]: Starting Coldplug All udev Devices... [ 7.547029] systemd[1]: Mounted Huge Pages File System. [ 7.547392] systemd[1]: Mounted POSIX Message Queue File System. [ 7.547565] systemd[1]: Mounted Kernel Debug File System. [ 7.547718] systemd[1]: Mounted Kernel Trace File System. [ 7.548227] systemd[1]: Finished Restore / save the current clock. [ 7.548950] systemd[1]: Finished Create List of Static Device Nodes. [ 7.549414] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully. [ 7.549764] systemd[1]: Finished Load Kernel Module chromeos_pstore. [ 7.550187] systemd[1]: modprobe@configfs.service: Deactivated successfully. [ 7.550523] systemd[1]: Finished Load Kernel Module configfs. [ 7.551240] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 7.551555] systemd[1]: Finished Load Kernel Module drm. [ 7.551944] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [ 7.552261] systemd[1]: Finished Load Kernel Module efi_pstore. [ 7.552647] systemd[1]: modprobe@fuse.service: Deactivated successfully. [ 7.552965] systemd[1]: Finished Load Kernel Module fuse. [ 7.553339] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully. [ 7.553653] systemd[1]: Finished Load Kernel Module pstore_blk. [ 7.554055] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully. [ 7.554378] systemd[1]: Finished Load Kernel Module pstore_zone. [ 7.554748] systemd[1]: modprobe@ramoops.service: Deactivated successfully. [ 7.555050] systemd[1]: Finished Load Kernel Module ramoops. [ 7.555547] systemd[1]: Finished Load Kernel Modules. [ 7.557378] systemd[1]: Mounting FUSE Control File System... [ 7.558706] systemd[1]: Mounting Kernel Configuration File System... [ 7.559250] EXT4-fs (nvme0n1p2): re-mounted. Opts: commit=600,errors=remount-ro [ 7.560192] systemd[1]: Starting Apply Kernel Variables... [ 7.562762] systemd[1]: Finished Remount Root and Kernel File Systems. [ 7.563769] systemd[1]: Mounted FUSE Control File System. [ 7.564150] systemd[1]: Mounted Kernel Configuration File System. [ 7.565786] systemd[1]: Starting Platform Persistent Storage Archival... [ 7.567273] systemd[1]: Starting Load/Save Random Seed... [ 7.568898] systemd[1]: Starting Create System Users... [ 7.587975] systemd[1]: Finished Apply Kernel Variables. [ 7.588507] systemd[1]: Finished Create System Users. [ 7.589566] systemd[1]: Starting Create Static Device Nodes in /dev... [ 7.598995] systemd[1]: Finished Create Static Device Nodes in /dev. [ 7.600815] systemd[1]: Starting Rule-based Manager for Device Events and Files... [ 7.601331] systemd[1]: Finished Set the console keyboard layout. [ 7.601550] systemd[1]: Reached target Preparation for Local File Systems. [ 7.602714] systemd[1]: Mounting /tmp... [ 7.607333] systemd[1]: Mounted /tmp. [ 7.614081] systemd[1]: Finished Platform Persistent Storage Archival. [ 7.620311] systemd[1]: Finished Load/Save Random Seed. [ 7.620663] systemd[1]: Condition check resulted in First Boot Complete being skipped. [ 7.639936] systemd[1]: Started Rule-based Manager for Device Events and Files. [ 7.755872] systemd[1]: Created slice Slice /system/systemd-backlight. [ 7.756926] systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:backlight_1... [ 7.762902] systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:backlight_1. [ 7.766235] systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:backlight... [ 7.767964] systemd[1]: Finished Coldplug All udev Devices. [ 7.769709] systemd[1]: Starting Helper to synchronize boot up for ifupdown... [ 7.771051] systemd[1]: Starting Show Plymouth Boot Screen... [ 7.772241] systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:backlight. [ 7.774756] systemd[1]: Finished Helper to synchronize boot up for ifupdown. [ 7.790643] systemd[1]: Started Show Plymouth Boot Screen. [ 7.790868] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 7.791053] systemd[1]: Started Forward Password Requests to Plymouth Directory Watch. [ 7.791099] systemd[1]: Reached target Local Encrypted Volumes. [ 7.870345] systemd[1]: Found device /dev/ttyFIQ0. [ 7.881819] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 7.881940] systemd[1]: Reached target Hardware activated USB gadget. [ 7.882214] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 7.890085] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 7.897325] systemd[1]: Found device Samsung SSD 960 EVO 500GB armbi_boot. [ 7.899318] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 7.899372] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 7.900597] systemd[1]: Starting File System Check on /dev/disk/by-uuid/1BD1-7F33... [ 7.906573] systemd[1]: Started File System Check Daemon to report status. [ 7.928517] systemd[1]: Finished File System Check on /dev/disk/by-uuid/1BD1-7F33. [ 7.929924] systemd[1]: Mounting /boot... [ 7.931537] FAT-fs (nvme0n1p1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive! [ 7.936872] systemd[1]: Mounted /boot. [ 7.937047] systemd[1]: Reached target Local File Systems. [ 7.938323] systemd[1]: Starting Armbian leds state... [ 7.939551] systemd[1]: Starting Armbian ZRAM config... [ 7.940979] systemd[1]: Starting Set console font and keymap... [ 7.942252] systemd[1]: Starting Raise network interfaces... [ 7.943494] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data... [ 7.943592] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped. [ 7.945224] systemd[1]: Starting Set Up Additional Binary Formats... [ 7.945327] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 7.945387] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 7.947834] systemd[1]: Finished Set console font and keymap. [ 7.949170] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 549 (systemd-binfmt) [ 7.950607] systemd[1]: Mounting Arbitrary Executable File Formats File System... [ 7.954710] systemd[1]: Received SIGRTMIN+20 from PID 288 (plymouthd). [ 7.956739] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data. [ 7.958722] systemd[1]: Mounted Arbitrary Executable File Formats File System. [ 7.960020] systemd[1]: Finished Armbian leds state. [ 7.960463] systemd[1]: Finished Set Up Additional Binary Formats. [ 8.027339] zram0: detected capacity change from 0 to 4031107072 [ 8.070618] Adding 3936624k swap on /dev/zram0. Priority:5 extents:1 across:3936624k SS [ 8.080943] zram: Added device: zram1 [ 8.090087] systemd[1]: Finished Raise network interfaces. [ 8.181368] zram1: detected capacity change from 0 to 52428800 [ 8.213475] systemd[1]: Finished Armbian ZRAM config. [ 8.220874] systemd[1]: Starting Armbian memory supported logging... [ 8.270025] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard [ 8.783890] vendor storage:20190527 ret = -1 [ 8.806533] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 8.806707] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 8.806827] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 9.858947] systemd[1]: Finished Armbian memory supported logging. [ 9.867756] systemd[1]: Starting Journal Service... [ 10.007191] systemd[1]: Started Journal Service. [ 10.036776] systemd-journald[727]: Received client request to flush runtime journal. ### armbian-release: # PLEASE DO NOT EDIT THIS FILE BOARD=orangepi5 BOARD_NAME="Orange Pi 5" BOARDFAMILY=rockchip-rk3588 BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=bfc8271 VERSION=23.08.0-trunk LINUXFAMILY=rk35xx ARCH=arm64 IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm64 KERNEL_IMAGE_TYPE=Image FORCE_BOOTSCRIPT_UPDATE= VENDOR=Armbian REVISION=23.08.0-trunk BOOTSCRIPT_FORCE_UPDATE="no" BOOTSCRIPT_DST="boot.cmd" BRANCH=legacy ### boot environment: verbosity=1 bootlogo=true overlay_prefix=rockchip-rk3588 fdtfile=rockchip/rk3588s-orangepi-5.dtb rootdev=UUID=329a3cf7-a8ce-4ea6-a3ef-c2128bda1678 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u ### lsusb: Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 002: ID 046d:c539 Logitech, Inc. USB Receiver Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub ### lscpu: Architecture: aarch64 CPU op-mode(s): 32-bit, 64-bit Byte Order: Little Endian CPU(s): 8 On-line CPU(s) list: 0-7 Vendor ID: ARM Model name: Cortex-A55 Model: 0 Thread(s) per core: 1 Core(s) per socket: 4 Socket(s): 1 Stepping: r2p0 CPU max MHz: 1800,0000 CPU min MHz: 408,0000 BogoMIPS: 48.00 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp Model name: Cortex-A76 Model: 0 Thread(s) per core: 1 Core(s) per socket: 2 Socket(s): 2 Stepping: r4p0 CPU max MHz: 2256,0000 CPU min MHz: 408,0000 BogoMIPS: 48.00 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp L1d cache: 384 KiB (8 instances) L1i cache: 384 KiB (8 instances) L2 cache: 2,5 MiB (8 instances) L3 cache: 3 MiB (1 instance) Vulnerability L1tf: Not affected Vulnerability Mds: Not affected Vulnerability Meltdown: Not affected Vulnerability Mmio stale data: Not affected Vulnerability Retbleed: Not affected Vulnerability Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl Vulnerability Spectre v1: Mitigation; __user pointer sanitization Vulnerability Spectre v2: Vulnerable: Unprivileged eBPF enabled Vulnerability Srbds: Not affected Vulnerability Tsx async abort: Not affected Vulnerability itlb multihit: Not affected ### cpuinfo: processor : 0 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 1 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 2 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 3 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 4 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 processor : 5 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 processor : 6 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 processor : 7 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 Serial : 2eae2cb9d903d20e ### meminfo: MemTotal: 7873256 kB MemFree: 7559776 kB MemAvailable: 7589284 kB Buffers: 14684 kB Cached: 87204 kB SwapCached: 0 kB Active: 26736 kB Inactive: 111096 kB Active(anon): 480 kB Inactive(anon): 65060 kB Active(file): 26256 kB Inactive(file): 46036 kB Unevictable: 19604 kB Mlocked: 0 kB SwapTotal: 3936624 kB SwapFree: 3936624 kB Dirty: 6496 kB Writeback: 0 kB AnonPages: 56140 kB Mapped: 29512 kB Shmem: 25988 kB KReclaimable: 37864 kB Slab: 79216 kB SReclaimable: 37864 kB SUnreclaim: 41352 kB KernelStack: 3648 kB PageTables: 3180 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 7873252 kB Committed_AS: 128840 kB VmallocTotal: 135290290112 kB VmallocUsed: 36544 kB VmallocChunk: 0 kB Percpu: 2656 kB CmaTotal: 262144 kB CmaAllocated: 4672 kB CmaReleased: 257472 kB CmaFree: 257472 kB HugePages_Total: 0 HugePages_Free: 0 HugePages_Rsvd: 0 HugePages_Surp: 0 Hugepagesize: 2048 kB Hugetlb: 0 kB ### virtual memory: vm.admin_reserve_kbytes = 8192 vm.block_dump = 0 vm.dirty_background_bytes = 0 vm.dirty_background_ratio = 10 vm.dirty_bytes = 0 vm.dirty_expire_centisecs = 3000 vm.dirty_ratio = 20 vm.dirtytime_expire_seconds = 43200 vm.dirty_writeback_centisecs = 500 vm.extra_free_kbytes = 0 vm.hugetlb_shm_group = 0 vm.laptop_mode = 0 vm.legacy_va_layout = 0 vm.lowmem_reserve_ratio = 256 256 32 0 vm.max_map_count = 65530 vm.min_free_kbytes = 11208 vm.mmap_min_addr = 32768 vm.mmap_rnd_bits = 18 vm.mmap_rnd_compat_bits = 11 vm.nr_hugepages = 0 vm.nr_overcommit_hugepages = 0 vm.oom_dump_tasks = 1 vm.oom_kill_allocating_task = 0 vm.overcommit_kbytes = 0 vm.overcommit_memory = 0 vm.overcommit_ratio = 50 vm.page-cluster = 0 vm.page_lock_unfairness = 5 vm.panic_on_oom = 0 vm.percpu_pagelist_fraction = 0 vm.stat_interval = 1 vm.swappiness = 100 vm.user_reserve_kbytes = 131072 vm.vfs_cache_pressure = 100 vm.watermark_boost_factor = 15000 vm.watermark_scale_factor = 10 ### ip addr: 1: lo: mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet XXX.XXX.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: eth0: mtu 1500 qdisc mq state DOWN group default qlen 1000 link/ether ae:d8:3f:81:fa:0b brd ff:ff:ff:ff:ff:ff ### partitions: major minor #blocks name 254 0 3936628 zram0 31 0 16384 mtdblock0 259 0 488386584 nvme0n1 259 1 262144 nvme0n1p1 259 2 483213312 nvme0n1p2 254 1 51200 zram1 ### df: tmpfs 769M 9,7M 760M 2% /run /dev/nvme0n1p2 454G 5,1G 444G 2% / tmpfs 3,8G 0 3,8G 0% /dev/shm tmpfs 5,0M 0 5,0M 0% /run/lock tmpfs 3,8G 8,0K 3,8G 1% /tmp /dev/nvme0n1p1 256M 106M 151M 42% /boot /dev/zram1 47M 6,4M 37M 15% /var/log ### lsblk: NAME FSTYPE SIZE MOUNTPOINT UUID mtdblock0 16M zram1 50M /var/log nvme0n1 465,8G ├─nvme0n1p1 vfat 256M /boot 1BD1-7F33 └─nvme0n1p2 ext4 460,8G / 329a3cf7-a8ce-4ea6-a3ef-c2128bda1678 ### zramctl: NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT /dev/zram1 zstd 50M 6,4M 1,3M 1,8M 8 /var/log /dev/zram0 lzo-rle 3,8G 4K 74B 12K 8 [SWAP] ### mtab: /dev/nvme0n1p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=936,iocharset=utf8,shortname=mixed,errors=remount-ro 0 0 /dev/nvme0n1p2 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0 /dev/nvme0n1p2 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0 ### Boot system health: Time CPU_cl0/CPU_cl1 load %cpu %sys %usr %nice %io %irq Tcpu C.St. 21:23:24 1800/2256 MHz 0.16 20% 12% 7% 0% 0% 0% 45,3 °C 0/7 21:23:24 1800/ 600 MHz 0.16 20% 5% 14% 0% 0% 0% 44,4 °C 0/7 21:23:24 1800/ 408 MHz 0.16 19% 3% 15% 0% 0% 0% 44,4 °C 0/7 21:23:25 1800/2256 MHz 0.16 19% 4% 14% 0% 0% 0% 43,5 °C 0/7 21:23:25 1800/2256 MHz 0.16 20% 5% 13% 0% 0% 0% 44,4 °C 0/7 ### Activated 1 lzo-rle zram swap devices with 3844MB each. ### Activated Armbian ramlog partition with zstd compression Pzt 07 Ağu 2023 21:25:42 +03 | Orange Pi 5 | 23.08.0-trunk | arm64 | aarch64 | 5.10.160-rk35xx ### dmesg: [ 1.766464] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [ 1.766487] Linux version 5.10.160-rk35xx (armbian@next) (aarch64-linux-gnu-gcc (Ubuntu 11.3.0-1ubuntu1~22.04) 11.3.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP Thu Jul 6 13:36:29 UTC 2023 [ 1.777302] Machine model: Orange Pi 5 [ 1.777486] efi: UEFI not found. [ 1.781141] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB [ 1.781161] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@00000000': base 0x0000000000000000, size 0 MiB [ 1.781251] Reserved memory: created CMA memory pool at 0x0000000010000000, size 256 MiB [ 1.781256] OF: reserved mem: initialized node cma, compatible id shared-dma-pool [ 1.931826] Zone ranges: [ 1.931834] DMA [mem 0x0000000000200000-0x00000000ffffffff] [ 1.931845] DMA32 empty [ 1.931851] Normal [mem 0x0000000100000000-0x00000001ffffffff] [ 1.931859] Movable zone start for each node [ 1.931862] Early memory node ranges [ 1.931868] node 0: [mem 0x0000000000200000-0x00000000efffffff] [ 1.931876] node 0: [mem 0x0000000100000000-0x00000001ffffffff] [ 1.931885] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff] [ 1.931891] On node 0 totalpages: 2031104 [ 1.931897] DMA zone: 15352 pages used for memmap [ 1.931901] DMA zone: 0 pages reserved [ 1.931907] DMA zone: 982528 pages, LIFO batch:63 [ 1.931912] Normal zone: 16384 pages used for memmap [ 1.931916] Normal zone: 1048576 pages, LIFO batch:63 [ 1.978895] psci: probing for conduit method from DT. [ 1.978908] psci: PSCIv1.1 detected in firmware. [ 1.978913] psci: Using standard PSCI v0.2 function IDs [ 1.978919] psci: MIGRATE_INFO_TYPE not supported. [ 1.978927] psci: SMC Calling Convention v1.2 [ 1.979347] percpu: Embedded 32 pages/cpu s93480 r8192 d29400 u131072 [ 1.979389] pcpu-alloc: s93480 r8192 d29400 u131072 alloc=32*4096 [ 1.979397] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7 [ 1.979540] Detected VIPT I-cache on CPU0 [ 1.979588] CPU features: detected: GIC system register CPU interface [ 1.979593] CPU features: detected: Virtualization Host Extensions [ 1.979604] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 1.979617] alternatives: patching kernel code [ 1.980003] Built 1 zonelists, mobility grouping on. Total pages: 1999368 [ 1.980013] Kernel command line: root=UUID=329a3cf7-a8ce-4ea6-a3ef-c2128bda1678 rootwait rootfstype=ext4 splash plymouth.ignore-serial-consoles console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart= usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 [ 1.981350] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) [ 1.981758] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 1.981765] mem auto-init: stack:off, heap alloc:off, heap free:off [ 1.988273] software IO TLB: mapped [mem 0x00000000ec000000-0x00000000f0000000] (64MB) [ 2.062268] Memory: 7589180K/8124416K available (16832K kernel code, 3506K rwdata, 6500K rodata, 6976K init, 639K bss, 273092K reserved, 262144K cma-reserved) [ 2.062428] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1 [ 2.062466] ftrace: allocating 64539 entries in 253 pages [ 2.172872] ftrace: allocated 253 pages with 7 groups [ 2.173173] rcu: Hierarchical RCU implementation. [ 2.173179] rcu: RCU event tracing is enabled. [ 2.173185] Rude variant of Tasks RCU enabled. [ 2.173188] Tracing variant of Tasks RCU enabled. [ 2.173194] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies. [ 2.178831] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 2.181665] GICv3: GIC: Using split EOI/Deactivate mode [ 2.181671] GICv3: 480 SPIs implemented [ 2.181676] GICv3: 0 Extended SPIs implemented [ 2.181716] GICv3: Distributor has no Range Selector support [ 2.181726] GICv3: 16 PPIs implemented [ 2.181772] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000 [ 2.181899] ITS [mem 0xfe640000-0xfe65ffff] [ 2.181956] ITS@0x00000000fe640000: allocated 8192 Devices @100200000 (indirect, esz 8, psz 64K, shr 0) [ 2.181985] ITS@0x00000000fe640000: allocated 32768 Interrupt Collections @100210000 (flat, esz 2, psz 64K, shr 0) [ 2.181995] ITS: using cache flushing for cmd queue [ 2.182037] ITS [mem 0xfe660000-0xfe67ffff] [ 2.182085] ITS@0x00000000fe660000: allocated 8192 Devices @100230000 (indirect, esz 8, psz 64K, shr 0) [ 2.182113] ITS@0x00000000fe660000: allocated 32768 Interrupt Collections @100240000 (flat, esz 2, psz 64K, shr 0) [ 2.182122] ITS: using cache flushing for cmd queue [ 2.182346] GICv3: using LPI property table @0x0000000100250000 [ 2.182477] GIC: using cache flushing for LPI property table [ 2.182488] GICv3: CPU0: using allocated LPI pending table @0x0000000100260000 [ 2.318859] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 2.318868] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 2.318878] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 2.320246] Console: colour dummy device 80x25 [ 2.320288] printk: console [tty1] enabled [ 2.320319] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000) [ 2.320331] pid_max: default: 32768 minimum: 301 [ 2.320442] LSM: Security Framework initializing [ 2.320514] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 2.320540] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 2.322789] rcu: Hierarchical SRCU implementation. [ 2.323767] Platform MSI: msi-controller@fe640000 domain created [ 2.323789] Platform MSI: msi-controller@fe660000 domain created [ 2.324170] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe640000 domain created [ 2.324196] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe660000 domain created [ 2.324383] EFI services will not be available. [ 2.324835] smp: Bringing up secondary CPUs ... [ 2.325554] Detected VIPT I-cache on CPU1 [ 2.325590] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000 [ 2.325610] GICv3: CPU1: using allocated LPI pending table @0x0000000100270000 [ 2.325656] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [ 2.326434] Detected VIPT I-cache on CPU2 [ 2.326466] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000 [ 2.326484] GICv3: CPU2: using allocated LPI pending table @0x0000000100280000 [ 2.326526] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [ 2.327255] Detected VIPT I-cache on CPU3 [ 2.327285] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000 [ 2.327303] GICv3: CPU3: using allocated LPI pending table @0x0000000100290000 [ 2.327342] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [ 2.328082] CPU features: detected: Spectre-v4 [ 2.328086] CPU features: detected: Spectre-BHB [ 2.328088] Detected PIPT I-cache on CPU4 [ 2.328104] GICv3: CPU4: found redistributor 400 region 0:0x00000000fe700000 [ 2.328114] GICv3: CPU4: using allocated LPI pending table @0x00000001002a0000 [ 2.328139] CPU4: Booted secondary processor 0x0000000400 [0x414fd0b0] [ 2.328861] Detected PIPT I-cache on CPU5 [ 2.328878] GICv3: CPU5: found redistributor 500 region 0:0x00000000fe720000 [ 2.328889] GICv3: CPU5: using allocated LPI pending table @0x00000001002b0000 [ 2.328916] CPU5: Booted secondary processor 0x0000000500 [0x414fd0b0] [ 2.329609] Detected PIPT I-cache on CPU6 [ 2.329626] GICv3: CPU6: found redistributor 600 region 0:0x00000000fe740000 [ 2.329636] GICv3: CPU6: using allocated LPI pending table @0x00000001002c0000 [ 2.329662] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b0] [ 2.330339] Detected PIPT I-cache on CPU7 [ 2.330355] GICv3: CPU7: found redistributor 700 region 0:0x00000000fe760000 [ 2.330366] GICv3: CPU7: using allocated LPI pending table @0x00000001002d0000 [ 2.330391] CPU7: Booted secondary processor 0x0000000700 [0x414fd0b0] [ 2.330470] smp: Brought up 1 node, 8 CPUs [ 2.330490] SMP: Total of 8 processors activated. [ 2.330495] CPU features: detected: Privileged Access Never [ 2.330500] CPU features: detected: User Access Override [ 2.330505] CPU features: detected: 32-bit EL0 Support [ 2.330510] CPU features: detected: Common not Private translations [ 2.330514] CPU features: detected: RAS Extension Support [ 2.330519] CPU features: detected: Data cache clean to the PoU not required for I/D coherence [ 2.330524] CPU features: detected: CRC32 instructions [ 2.330528] CPU features: detected: Speculative Store Bypassing Safe (SSBS) [ 2.330534] CPU features: detected: RCpc load-acquire (LDAPR) [ 2.330619] CPU: All CPU(s) started at EL2 [ 2.333844] devtmpfs: initialized [ 2.348756] Registered cp15_barrier emulation handler [ 2.348765] Registered setend emulation handler [ 2.348769] KASLR disabled due to lack of seed [ 2.348855] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns [ 2.348862] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 2.351613] pinctrl core: initialized pinctrl subsystem [ 2.351733] regulator-dummy: no parameters, enabled [ 2.351852] DMI not present or invalid. [ 2.352158] NET: Registered protocol family 16 [ 2.353262] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations [ 2.353386] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 2.353406] audit: initializing netlink subsys (disabled) [ 2.353498] audit: type=2000 audit(0.033:1): state=initialized audit_enabled=0 res=1 [ 2.354009] Registered FIQ tty driver [ 2.354159] thermal_sys: Registered thermal governor 'fair_share' [ 2.354161] thermal_sys: Registered thermal governor 'step_wise' [ 2.354164] thermal_sys: Registered thermal governor 'user_space' [ 2.354166] thermal_sys: Registered thermal governor 'power_allocator' [ 2.354492] cpuidle: using governor menu [ 2.354721] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 2.354863] ASID allocator initialised with 65536 entries [ 2.356371] ramoops: dmesg-0 0x20000@0x0000000000110000 [ 2.356390] ramoops: console 0x80000@0x0000000000130000 [ 2.356401] ramoops: pmsg 0x50000@0x00000000001b0000 [ 2.356447] printk: console [ramoops-1] enabled [ 2.356450] pstore: Registered ramoops as persistent store backend [ 2.356452] ramoops: using 0xf0000@0x110000, ecc: 0 [ 2.410397] rockchip-gpio fd8a0000.gpio: probed /pinctrl/gpio@fd8a0000 [ 2.410691] rockchip-gpio fec20000.gpio: probed /pinctrl/gpio@fec20000 [ 2.410922] rockchip-gpio fec30000.gpio: probed /pinctrl/gpio@fec30000 [ 2.411200] rockchip-gpio fec40000.gpio: probed /pinctrl/gpio@fec40000 [ 2.411470] rockchip-gpio fec50000.gpio: probed /pinctrl/gpio@fec50000 [ 2.411520] rockchip-pinctrl pinctrl: probed pinctrl [ 2.420192] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 2.420196] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 2.420199] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 2.420202] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 2.482175] raid6: neonx8 gen() 5363 MB/s [ 2.538932] raid6: neonx8 xor() 4165 MB/s [ 2.595692] raid6: neonx4 gen() 5499 MB/s [ 2.652454] raid6: neonx4 xor() 4178 MB/s [ 2.709214] raid6: neonx2 gen() 5044 MB/s [ 2.765975] raid6: neonx2 xor() 3875 MB/s [ 2.822734] raid6: neonx1 gen() 4214 MB/s [ 2.879494] raid6: neonx1 xor() 3248 MB/s [ 2.936258] raid6: int64x8 gen() 1299 MB/s [ 2.993027] raid6: int64x8 xor() 868 MB/s [ 3.049776] raid6: int64x4 gen() 1608 MB/s [ 3.106546] raid6: int64x4 xor() 879 MB/s [ 3.163300] raid6: int64x2 gen() 1884 MB/s [ 3.220064] raid6: int64x2 xor() 1300 MB/s [ 3.276819] raid6: int64x1 gen() 1969 MB/s [ 3.333585] raid6: int64x1 xor() 960 MB/s [ 3.333588] raid6: using algorithm neonx4 gen() 5499 MB/s [ 3.333590] raid6: .... xor() 4178 MB/s, rmw enabled [ 3.333592] raid6: using neon recovery algorithm [ 3.334202] fiq_debugger fiq_debugger.0: IRQ fiq not found [ 3.334210] fiq_debugger fiq_debugger.0: IRQ wakeup not found [ 3.334214] fiq_debugger_probe: could not install nmi irq handler [ 3.334297] printk: console [ttyFIQ0] enabled [ 3.334402] Registered fiq debugger ttyFIQ0 [ 3.334606] vcc12v_dcin: 12000 mV, enabled [ 3.334686] reg-fixed-voltage vcc12v-dcin: vcc12v_dcin supplying 12000000uV [ 3.334737] reg-fixed-voltage vcc5v0-sys: Looking up vin-supply from device tree [ 3.334741] vcc5v0_sys: supplied by vcc12v_dcin [ 3.334746] vcc12v_dcin: could not add device link regulator.2: -ENOENT [ 3.334762] vcc5v0_sys: 5000 mV, enabled [ 3.334827] reg-fixed-voltage vcc5v0-sys: vcc5v0_sys supplying 5000000uV [ 3.334874] reg-fixed-voltage vcc5v0-usbdcin: Looking up vin-supply from device tree [ 3.334878] vcc5v0_usbdcin: supplied by vcc12v_dcin [ 3.334881] vcc12v_dcin: could not add device link regulator.3: -ENOENT [ 3.334896] vcc5v0_usbdcin: 5000 mV, enabled [ 3.334962] reg-fixed-voltage vcc5v0-usbdcin: vcc5v0_usbdcin supplying 5000000uV [ 3.335007] reg-fixed-voltage vcc5v0-usb: Looking up vin-supply from device tree [ 3.335011] vcc5v0_usb: supplied by vcc5v0_usbdcin [ 3.335015] vcc5v0_usbdcin: could not add device link regulator.4: -ENOENT [ 3.335029] vcc5v0_usb: 5000 mV, enabled [ 3.335086] reg-fixed-voltage vcc5v0-usb: vcc5v0_usb supplying 5000000uV [ 3.335190] vbus5v0_typec: 5000 mV, disabled [ 3.335241] reg-fixed-voltage vbus5v0-typec: Looking up vin-supply from device tree [ 3.335245] vbus5v0_typec: supplied by vcc5v0_usb [ 3.335278] reg-fixed-voltage vbus5v0-typec: vbus5v0_typec supplying 5000000uV [ 3.335330] reg-fixed-voltage vcc-1v1-nldo-s3: Looking up vin-supply from device tree [ 3.335334] vcc_1v1_nldo_s3: supplied by vcc5v0_sys [ 3.335337] vcc5v0_sys: could not add device link regulator.6: -ENOENT [ 3.335354] vcc_1v1_nldo_s3: 1100 mV, enabled [ 3.335418] reg-fixed-voltage vcc-1v1-nldo-s3: vcc_1v1_nldo_s3 supplying 1100000uV [ 3.335471] reg-fixed-voltage vcc3v3-pcie2x1l2: Looking up vin-supply from device tree [ 3.335475] vcc3v3_pcie2x1l2: supplied by vcc5v0_sys [ 3.335478] vcc5v0_sys: could not add device link regulator.7: -ENOENT [ 3.391086] vcc3v3_pcie2x1l2: 1800 mV, enabled [ 3.391154] reg-fixed-voltage vcc3v3-pcie2x1l2: vcc3v3_pcie2x1l2 supplying 1800000uV [ 3.391438] iommu: Default domain type: Translated [ 3.391870] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vdpu-supply from device tree [ 3.391890] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vdpu-supply property in node /power-management@fd8d8000/power-controller failed [ 3.392159] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga30-supply from device tree [ 3.392178] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga30-supply property in node /power-management@fd8d8000/power-controller failed [ 3.392358] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga31-supply from device tree [ 3.392375] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga31-supply property in node /power-management@fd8d8000/power-controller failed [ 3.393687] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc0-supply from device tree [ 3.393705] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc0-supply property in node /power-management@fd8d8000/power-controller failed [ 3.393858] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vcodec-supply from device tree [ 3.393876] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vcodec-supply property in node /power-management@fd8d8000/power-controller failed [ 3.393977] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc1-supply from device tree [ 3.393994] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc1-supply property in node /power-management@fd8d8000/power-controller failed [ 3.394272] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec0-supply from device tree [ 3.394289] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec0-supply property in node /power-management@fd8d8000/power-controller failed [ 3.394580] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec1-supply from device tree [ 3.394598] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec1-supply property in node /power-management@fd8d8000/power-controller failed [ 3.394817] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vi-supply from device tree [ 3.394834] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vi-supply property in node /power-management@fd8d8000/power-controller failed [ 3.395067] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up isp1-supply from device tree [ 3.395084] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up isp1-supply property in node /power-management@fd8d8000/power-controller failed [ 3.395786] SCSI subsystem initialized [ 3.395801] libata version 3.00 loaded. [ 3.395873] usbcore: registered new interface driver usbfs [ 3.395890] usbcore: registered new interface driver hub [ 3.395905] usbcore: registered new device driver usb [ 3.395944] mc: Linux media interface: v0.10 [ 3.395956] videodev: Linux video capture interface: v2.00 [ 3.395984] pps_core: LinuxPPS API ver. 1 registered [ 3.395987] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [ 3.395992] PTP clock support registered [ 3.396262] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled. [ 3.396294] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0 [ 3.397498] Advanced Linux Sound Architecture Driver Initialized. [ 3.397760] Bluetooth: Core ver 2.22 [ 3.397774] NET: Registered protocol family 31 [ 3.397776] Bluetooth: HCI device and connection manager initialized [ 3.397781] Bluetooth: HCI socket layer initialized [ 3.397784] Bluetooth: L2CAP socket layer initialized [ 3.397790] Bluetooth: SCO socket layer initialized [ 3.397803] NetLabel: Initializing [ 3.397805] NetLabel: domain hash size = 128 [ 3.397807] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 3.397833] NetLabel: unlabeled traffic allowed by default [ 3.399163] rockchip-cpuinfo cpuinfo: SoC : 35881000 [ 3.399167] rockchip-cpuinfo cpuinfo: Serial : 2eae2cb9d903d20e [ 3.399608] clocksource: Switched to clocksource arch_sys_counter [ 3.816594] VFS: Disk quotas dquot_6.6.0 [ 3.816623] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 3.822303] NET: Registered protocol family 2 [ 3.822427] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 3.824457] tcp_listen_portaddr_hash hash table entries: 4096 (order: 5, 163840 bytes, linear) [ 3.824556] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 3.824904] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear) [ 3.825708] TCP: Hash tables configured (established 65536 bind 65536) [ 3.825817] MPTCP token hash table entries: 8192 (order: 6, 393216 bytes, linear) [ 3.825915] UDP hash table entries: 4096 (order: 6, 393216 bytes, linear) [ 3.826071] UDP-Lite hash table entries: 4096 (order: 6, 393216 bytes, linear) [ 3.826305] NET: Registered protocol family 1 [ 3.826680] RPC: Registered named UNIX socket transport module. [ 3.826682] RPC: Registered udp transport module. [ 3.826685] RPC: Registered tcp transport module. [ 3.826686] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 3.827126] PCI: CLS 0 bytes, default 64 [ 3.827419] Trying to unpack rootfs image as initramfs... [ 4.222984] Freeing initrd memory: 14956K [ 4.223663] rockchip-thermal fec00000.tsadc: Missing rockchip,grf property [ 4.224301] rockchip-thermal fec00000.tsadc: tsadc is probed successfully! [ 4.225243] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 4.225849] kvm [1]: IPA Size Limit: 40 bits [ 4.225860] kvm [1]: GICv3: no GICV resource entry [ 4.225863] kvm [1]: disabling GICv2 emulation [ 4.225865] kvm [1]: GIC system register CPU interface enabled [ 4.226018] kvm [1]: vgic interrupt IRQ9 [ 4.226201] kvm [1]: VHE mode initialized successfully [ 4.229260] Initialise system trusted keyrings [ 4.229382] workingset: timestamp_bits=46 max_order=21 bucket_order=0 [ 4.232411] NFS: Registering the id_resolver key type [ 4.232424] Key type id_resolver registered [ 4.232426] Key type id_legacy registered [ 4.232462] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 4.232465] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 4.232477] ntfs: driver 2.1.32 [Flags: R/W]. [ 4.254923] NET: Registered protocol family 38 [ 4.254928] xor: measuring software checksum speed [ 4.256551] 8regs : 6102 MB/sec [ 4.257762] 32regs : 8129 MB/sec [ 4.258756] arm64_neon : 9924 MB/sec [ 4.258758] xor: using function: arm64_neon (9924 MB/sec) [ 4.258763] Key type asymmetric registered [ 4.258766] Asymmetric key parser 'x509' registered [ 4.258782] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242) [ 4.258894] io scheduler mq-deadline registered [ 4.258899] io scheduler kyber registered [ 4.260723] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up phy-supply from device tree [ 4.260732] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up phy-supply property in node /syscon@fd5d0000/usb2-phy@0/otg-port failed [ 4.260782] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up vbus-supply from device tree [ 4.260788] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up vbus-supply property in node /syscon@fd5d0000/usb2-phy@0/otg-port failed [ 4.262115] phy phy-fd5d8000.syscon:usb2-phy@8000.1: Looking up phy-supply from device tree [ 4.262123] phy phy-fd5d8000.syscon:usb2-phy@8000.1: Looking up phy-supply property in node /syscon@fd5d8000/usb2-phy@8000/host-port failed [ 4.263382] phy phy-fd5dc000.syscon:usb2-phy@c000.2: Looking up phy-supply from device tree [ 4.263391] phy phy-fd5dc000.syscon:usb2-phy@c000.2: Looking up phy-supply property in node /syscon@fd5dc000/usb2-phy@c000/host-port failed [ 4.265240] phy phy-fee00000.phy.3: Looking up phy-supply from device tree [ 4.265247] phy phy-fee00000.phy.3: Looking up phy-supply property in node /phy@fee00000 failed [ 4.265397] phy phy-fee20000.phy.4: Looking up phy-supply from device tree [ 4.265403] phy phy-fee20000.phy.4: Looking up phy-supply property in node /phy@fee20000 failed [ 4.265893] phy phy-feda0000.phy.5: Looking up phy-supply from device tree [ 4.265898] phy phy-feda0000.phy.5: Looking up phy-supply property in node /phy@feda0000 failed [ 4.266031] phy phy-fedb0000.phy.6: Looking up phy-supply from device tree [ 4.266037] phy phy-fedb0000.phy.6: Looking up phy-supply property in node /phy@fedb0000 failed [ 4.266424] phy phy-fed60000.hdmiphy.7: Looking up phy-supply from device tree [ 4.266431] phy phy-fed60000.hdmiphy.7: Looking up phy-supply property in node /hdmiphy@fed60000 failed [ 4.267211] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy init success [ 4.268151] phy phy-fed80000.phy.8: Looking up phy-supply from device tree [ 4.268158] phy phy-fed80000.phy.8: Looking up phy-supply property in node /phy@fed80000/dp-port failed [ 4.268193] phy phy-fed80000.phy.9: Looking up phy-supply from device tree [ 4.268198] phy phy-fed80000.phy.9: Looking up phy-supply property in node /phy@fed80000/u3-port failed [ 4.269589] rk-pcie fe190000.pcie: invalid prsnt-gpios property in node [ 4.269596] rk-pcie fe190000.pcie: Looking up vpcie3v3-supply from device tree [ 4.269849] pwm-backlight backlight: Looking up power-supply from device tree [ 4.269856] pwm-backlight backlight: Looking up power-supply property in node /backlight failed [ 4.269861] pwm-backlight backlight: supply power not found, using dummy regulator [ 4.269947] rk-pcie fe190000.pcie: IRQ msi not found [ 4.269951] rk-pcie fe190000.pcie: use outband MSI support [ 4.269953] rk-pcie fe190000.pcie: Missing *config* reg space [ 4.269960] rk-pcie fe190000.pcie: host bridge /pcie@fe190000 ranges: [ 4.269973] rk-pcie fe190000.pcie: err 0x00f4000000..0x00f40fffff -> 0x00f4000000 [ 4.269980] rk-pcie fe190000.pcie: IO 0x00f4100000..0x00f41fffff -> 0x00f4100000 [ 4.269988] rk-pcie fe190000.pcie: MEM 0x00f4200000..0x00f4ffffff -> 0x00f4200000 [ 4.269993] rk-pcie fe190000.pcie: MEM 0x0a00000000..0x0a3fffffff -> 0x0a00000000 [ 4.270019] rk-pcie fe190000.pcie: Missing *config* reg space [ 4.270033] pwm-backlight backlight_1: Looking up power-supply from device tree [ 4.270038] pwm-backlight backlight_1: Looking up power-supply property in node /backlight_1 failed [ 4.270043] rk-pcie fe190000.pcie: invalid resource [ 4.270044] pwm-backlight backlight_1: supply power not found, using dummy regulator [ 4.270308] iep: Module initialized. [ 4.270346] mpp_service mpp-srv: unknown mpp version for missing VCS info [ 4.270348] mpp_service mpp-srv: probe start [ 4.272340] mpp_vdpu2 fdb50400.vdpu: Adding to iommu group 1 [ 4.272560] mpp_vdpu2 fdb50400.vdpu: probe device [ 4.272681] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0 [ 4.272689] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0 [ 4.272845] mpp_vdpu2 fdb50400.vdpu: probing finish [ 4.273072] mpp_vepu2 jpege-ccu: probing start [ 4.273076] mpp_vepu2 jpege-ccu: probing finish [ 4.273187] mpp_vepu2 fdb50000.vepu: Adding to iommu group 1 [ 4.273271] mpp_vepu2 fdb50000.vepu: probing start [ 4.273367] mpp_vepu2 fdb50000.vepu: reset_group->rw_sem_on=0 [ 4.273371] mpp_vepu2 fdb50000.vepu: reset_group->rw_sem_on=0 [ 4.273521] mpp_vepu2 fdb50000.vepu: probing finish [ 4.273640] mpp_vepu2 fdba0000.jpege-core: Adding to iommu group 5 [ 4.273780] mpp_vepu2 fdba0000.jpege-core: probing start [ 4.273886] mpp_vepu2 fdba0000.jpege-core: attach ccu success [ 4.274025] mpp_vepu2 fdba0000.jpege-core: probing finish [ 4.274134] mpp_vepu2 fdba4000.jpege-core: Adding to iommu group 6 [ 4.274270] mpp_vepu2 fdba4000.jpege-core: probing start [ 4.274380] mpp_vepu2 fdba4000.jpege-core: attach ccu success [ 4.274517] mpp_vepu2 fdba4000.jpege-core: probing finish [ 4.274625] mpp_vepu2 fdba8000.jpege-core: Adding to iommu group 7 [ 4.274761] mpp_vepu2 fdba8000.jpege-core: probing start [ 4.274866] mpp_vepu2 fdba8000.jpege-core: attach ccu success [ 4.275008] mpp_vepu2 fdba8000.jpege-core: probing finish [ 4.275103] mpp_vepu2 fdbac000.jpege-core: Adding to iommu group 8 [ 4.275238] mpp_vepu2 fdbac000.jpege-core: probing start [ 4.275342] mpp_vepu2 fdbac000.jpege-core: attach ccu success [ 4.275484] mpp_vepu2 fdbac000.jpege-core: probing finish [ 4.275759] mpp-iep2 fdbb0000.iep: Adding to iommu group 9 [ 4.275902] mpp-iep2 fdbb0000.iep: probe device [ 4.276027] mpp-iep2 fdbb0000.iep: allocate roi buffer failed [ 4.276158] mpp-iep2 fdbb0000.iep: probing finish [ 4.276386] mpp_jpgdec fdb90000.jpegd: Adding to iommu group 4 [ 4.276592] mpp_jpgdec fdb90000.jpegd: probe device [ 4.276846] mpp_jpgdec fdb90000.jpegd: probing finish [ 4.277209] mpp_rkvdec2 fdc30000.rkvdec-ccu: rkvdec-ccu, probing start [ 4.277269] mpp_rkvdec2 fdc30000.rkvdec-ccu: ccu-mode: 1 [ 4.277272] mpp_rkvdec2 fdc30000.rkvdec-ccu: probing finish [ 4.277367] mpp_rkvdec2 fdc38100.rkvdec-core: Adding to iommu group 12 [ 4.277626] mpp_rkvdec2 fdc38100.rkvdec-core: rkvdec-core, probing start [ 4.277749] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found! [ 4.277752] rkvdec2_init:1022: No niu aclk reset resource define [ 4.277755] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found! [ 4.277758] rkvdec2_init:1025: No niu hclk reset resource define [ 4.277772] mpp_rkvdec2 fdc38100.rkvdec-core: Looking up vdec-supply from device tree [ 4.277778] mpp_rkvdec2 fdc38100.rkvdec-core: Looking up vdec-supply property in node /rkvdec-core@fdc38000 failed [ 4.277784] mpp_rkvdec2 fdc38100.rkvdec-core: no regulator, devfreq is disabled [ 4.277841] mpp_rkvdec2 fdc38100.rkvdec-core: core_mask=00010001 [ 4.277844] mpp_rkvdec2 fdc38100.rkvdec-core: attach ccu as core 0 [ 4.277992] mpp_rkvdec2 fdc38100.rkvdec-core: sram_start 0x00000000ff001000 [ 4.277995] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_iova 0x00000000fff00000 [ 4.277998] mpp_rkvdec2 fdc38100.rkvdec-core: sram_size 491520 [ 4.278000] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_size 1048576 [ 4.278004] mpp_rkvdec2 fdc38100.rkvdec-core: min_width 512 [ 4.278008] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_info_count 20 [ 4.278011] mpp_rkvdec2 fdc38100.rkvdec-core: [136, 24576] [ 4.278014] mpp_rkvdec2 fdc38100.rkvdec-core: [137, 49152] [ 4.278017] mpp_rkvdec2 fdc38100.rkvdec-core: [141, 90112] [ 4.278020] mpp_rkvdec2 fdc38100.rkvdec-core: [140, 49152] [ 4.278022] mpp_rkvdec2 fdc38100.rkvdec-core: [139, 180224] [ 4.278025] mpp_rkvdec2 fdc38100.rkvdec-core: [133, 49152] [ 4.278027] mpp_rkvdec2 fdc38100.rkvdec-core: [134, 8192] [ 4.278030] mpp_rkvdec2 fdc38100.rkvdec-core: [135, 4352] [ 4.278032] mpp_rkvdec2 fdc38100.rkvdec-core: [138, 13056] [ 4.278035] mpp_rkvdec2 fdc38100.rkvdec-core: [142, 291584] [ 4.278070] mpp_rkvdec2 fdc38100.rkvdec-core: probing finish [ 4.278160] mpp_rkvdec2 fdc48100.rkvdec-core: Adding to iommu group 13 [ 4.278389] mpp_rkvdec2 fdc48100.rkvdec-core: rkvdec-core, probing start [ 4.278512] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found! [ 4.278514] rkvdec2_init:1022: No niu aclk reset resource define [ 4.278518] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found! [ 4.278520] rkvdec2_init:1025: No niu hclk reset resource define [ 4.278536] mpp_rkvdec2 fdc48100.rkvdec-core: Looking up vdec-supply from device tree [ 4.278542] mpp_rkvdec2 fdc48100.rkvdec-core: Looking up vdec-supply property in node /rkvdec-core@fdc48000 failed [ 4.278547] mpp_rkvdec2 fdc48100.rkvdec-core: no regulator, devfreq is disabled [ 4.278590] mpp_rkvdec2 fdc48100.rkvdec-core: core_mask=00020002 [ 4.278607] mpp_rkvdec2 fdc48100.rkvdec-core: attach ccu as core 1 [ 4.278785] mpp_rkvdec2 fdc48100.rkvdec-core: sram_start 0x00000000ff079000 [ 4.278787] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_iova 0x00000000ffe00000 [ 4.278790] mpp_rkvdec2 fdc48100.rkvdec-core: sram_size 487424 [ 4.278793] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_size 1048576 [ 4.278797] mpp_rkvdec2 fdc48100.rkvdec-core: min_width 512 [ 4.278801] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_info_count 20 [ 4.278804] mpp_rkvdec2 fdc48100.rkvdec-core: [136, 24576] [ 4.278806] mpp_rkvdec2 fdc48100.rkvdec-core: [137, 49152] [ 4.278809] mpp_rkvdec2 fdc48100.rkvdec-core: [141, 90112] [ 4.278811] mpp_rkvdec2 fdc48100.rkvdec-core: [140, 49152] [ 4.278814] mpp_rkvdec2 fdc48100.rkvdec-core: [139, 180224] [ 4.278817] mpp_rkvdec2 fdc48100.rkvdec-core: [133, 49152] [ 4.278819] mpp_rkvdec2 fdc48100.rkvdec-core: [134, 8192] [ 4.278822] mpp_rkvdec2 fdc48100.rkvdec-core: [135, 4352] [ 4.278825] mpp_rkvdec2 fdc48100.rkvdec-core: [138, 13056] [ 4.278827] mpp_rkvdec2 fdc48100.rkvdec-core: [142, 291584] [ 4.278857] mpp_rkvdec2 fdc48100.rkvdec-core: probing finish [ 4.279049] mpp_rkvenc2 rkvenc-ccu: probing start [ 4.279052] mpp_rkvenc2 rkvenc-ccu: probing finish [ 4.279168] mpp_rkvenc2 fdbd0000.rkvenc-core: Adding to iommu group 10 [ 4.279346] mpp_rkvenc2 fdbd0000.rkvenc-core: probing start [ 4.279498] mpp_rkvenc2 fdbd0000.rkvenc-core: Looking up venc-supply from device tree [ 4.279504] mpp_rkvenc2 fdbd0000.rkvenc-core: Looking up venc-supply property in node /rkvenc-core@fdbd0000 failed [ 4.279510] mpp_rkvenc2 fdbd0000.rkvenc-core: dev_pm_opp_set_regulators: no regulator (venc) found: -19 [ 4.279526] rkvenc_init:1814: failed to add venc devfreq [ 4.279554] mpp_rkvenc2 fdbd0000.rkvenc-core: attach ccu as core 0 [ 4.279735] mpp_rkvenc2 fdbd0000.rkvenc-core: probing finish [ 4.279845] mpp_rkvenc2 fdbe0000.rkvenc-core: Adding to iommu group 11 [ 4.280057] mpp_rkvenc2 fdbe0000.rkvenc-core: probing start [ 4.280201] mpp_rkvenc2 fdbe0000.rkvenc-core: Looking up venc-supply from device tree [ 4.280207] mpp_rkvenc2 fdbe0000.rkvenc-core: Looking up venc-supply property in node /rkvenc-core@fdbe0000 failed [ 4.280214] mpp_rkvenc2 fdbe0000.rkvenc-core: dev_pm_opp_set_regulators: no regulator (venc) found: -19 [ 4.280227] rkvenc_init:1814: failed to add venc devfreq [ 4.280278] mpp_rkvenc2 fdbe0000.rkvenc-core: attach ccu as core 1 [ 4.280424] mpp_rkvenc2 fdbe0000.rkvenc-core: probing finish [ 4.280676] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up av1-supply from device tree [ 4.280697] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up av1-supply property in node /power-management@fd8d8000/power-controller failed [ 4.280991] mpp_av1dec: Adding child /av1d@fdc70000 [ 4.281072] mpp_av1dec: register device av1d-master [ 4.281101] mpp_av1dec av1d-master: av1_iommu_of_xlate,784 [ 4.281120] av1_iommu_probe_device,736, consumer : av1d-master, supplier : fdca0000.iommu [ 4.281153] mpp_av1dec av1d-master: Adding to iommu group 18 [ 4.281395] mpp_av1dec av1d-master: probing start [ 4.281665] mpp_av1dec av1d-master: probing finish [ 4.281704] mpp_service mpp-srv: probe success [ 4.292822] dma-pl330 fea10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 4.292828] dma-pl330 fea10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 4.293869] dma-pl330 fea30000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 4.293875] dma-pl330 fea30000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 4.294851] dma-pl330 fed10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 4.294856] dma-pl330 fed10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 4.295355] rockchip-pvtm fda40000.pvtm: pvtm@0 probed [ 4.295420] rockchip-pvtm fda50000.pvtm: pvtm@1 probed [ 4.295479] rockchip-pvtm fda60000.pvtm: pvtm@2 probed [ 4.295535] rockchip-pvtm fdaf0000.pvtm: pvtm@3 probed [ 4.295592] rockchip-pvtm fdb30000.pvtm: pvtm@4 probed [ 4.296175] rockchip-system-monitor rockchip-system-monitor: system monitor probe [ 4.297069] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [ 4.297609] febc0000.serial: ttyS9 at MMIO 0xfebc0000 (irq = 101, base_baud = 1500000) is a 16550A [ 4.298940] random: crng init done [ 4.299028] led_vk2c21_init ============================================= [ 4.300027] rockchip-vop2 fdd90000.vop: Adding to iommu group 17 [ 4.308557] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x5, primary plane phy id: 0 [ 4.308564] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp1 assign plane mask: 0xa, primary plane phy id: 1 [ 4.308570] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x140, primary plane phy id: 6 [ 4.308576] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp3 assign plane mask: 0x280, primary plane phy id: 7 [ 4.308669] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart0-win0 as cursor plane for vp0 [ 4.308760] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart1-win0 as cursor plane for vp1 [ 4.308847] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart2-win0 as cursor plane for vp2 [ 4.308931] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart3-win0 as cursor plane for vp3 [ 4.308951] [drm] failed to init overlay plane Cluster0-win1 [ 4.308953] [drm] failed to init overlay plane Cluster1-win1 [ 4.308956] [drm] failed to init overlay plane Cluster2-win1 [ 4.308958] [drm] failed to init overlay plane Cluster3-win1 [ 4.320535] rockchip-drm display-subsystem: bound fdd90000.vop (ops 0xffff8000091b2620) [ 4.321479] dwhdmi-rockchip fde80000.hdmi: registered ddc I2C bus driver [ 4.321689] rockchip-drm display-subsystem: bound fde80000.hdmi (ops 0xffff8000091c0798) [ 4.321768] rockchip-drm display-subsystem: bound fde50000.dp (ops 0xffff8000091c3278) [ 4.322389] rockchip-drm display-subsystem: failed to parse loader memory [ 4.477396] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x2 [ 4.548965] dwhdmi-rockchip fde80000.hdmi: use tmds mode [ 4.549007] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] Update mode to 1920x1080p60, type: 11(if:800) for vp0 dclk: 148500000 [ 4.549173] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] dclk_out0 div: 0 dclk_core0 div: 2 [ 4.549191] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx_ropll_cmn_config bus_width:16a8c8 rate:1485000 [ 4.549469] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy pll locked! [ 4.549475] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] set dclk_vop0 to 148500000, get 148500000 [ 4.549498] dwhdmi-rockchip fde80000.hdmi: final tmdsclk = 148500000 [ 4.549527] dwhdmi-rockchip fde80000.hdmi: don't use dsc mode [ 4.549531] dwhdmi-rockchip fde80000.hdmi: dw hdmi qp use tmds mode [ 4.549537] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: bus_width:0x16a8c8,bit_rate:1485000 [ 4.549746] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy lane locked! [ 4.559614] rk-pcie fe190000.pcie: PCIe Link up, LTSSM is 0x30011 [ 4.559696] rk-pcie fe190000.pcie: PCI host bridge to bus 0004:40 [ 4.559701] pci_bus 0004:40: root bus resource [bus 40-4f] [ 4.559706] pci_bus 0004:40: root bus resource [??? 0xf4000000-0xf40fffff flags 0x0] [ 4.559710] pci_bus 0004:40: root bus resource [io 0x0000-0xfffff] (bus address [0xf4100000-0xf41fffff]) [ 4.559713] pci_bus 0004:40: root bus resource [mem 0xf4200000-0xf4ffffff] [ 4.559716] pci_bus 0004:40: root bus resource [mem 0xa00000000-0xa3fffffff pref] [ 4.559740] pci 0004:40:00.0: [1d87:3588] type 01 class 0x060400 [ 4.559757] pci 0004:40:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref] [ 4.559804] pci 0004:40:00.0: supports D1 D2 [ 4.559807] pci 0004:40:00.0: PME# supported from D0 D1 D3hot [ 4.565601] pci 0004:40:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 4.565770] pci 0004:41:00.0: [144d:a804] type 00 class 0x010802 [ 4.565854] pci 0004:41:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit] [ 4.566530] pci 0004:41:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x1 link at 0004:40:00.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link) [ 4.581870] pci_bus 0004:41: busn_res: [bus 41-4f] end is updated to 41 [ 4.581885] pci 0004:40:00.0: BAR 8: assigned [mem 0xf4200000-0xf42fffff] [ 4.581890] pci 0004:40:00.0: BAR 6: assigned [mem 0xf4300000-0xf430ffff pref] [ 4.581896] pci 0004:41:00.0: BAR 0: assigned [mem 0xf4200000-0xf4203fff 64bit] [ 4.581928] pci 0004:40:00.0: PCI bridge to [bus 41] [ 4.581932] pci 0004:40:00.0: bridge window [mem 0xf4200000-0xf42fffff] [ 4.583450] pcieport 0004:40:00.0: PME: Signaling with IRQ 125 [ 4.632914] Console: switching to colour frame buffer device 240x67 [ 4.796803] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device [ 4.798063] [drm] Initialized rockchip 3.0.0 20140818 for display-subsystem on minor 0 [ 4.813008] brd: module loaded [ 4.822263] loop: module loaded [ 4.822819] zram: Added device: zram0 [ 4.823205] lkdtm: No crash points registered, enable through debugfs [ 4.823456] system_heap: orders[0] = 6 [ 4.823463] system_heap: orders[1] = 4 [ 4.823469] system_heap: orders[2] = 0 [ 4.825677] nvme nvme0: pci function 0004:41:00.0 [ 4.825724] nvme 0004:41:00.0: enabling device (0000 -> 0002) [ 4.829176] rockchip-spi feb20000.spi: no high_speed pinctrl state [ 4.832740] rk806 spi2.0: chip id: RK806,ver:0x2, 0x1 [ 4.832971] rk806 spi2.0: ON: 0x80 OFF:0x80 [ 4.835222] rk806-regulator rk806-regulator.6.auto: Looking up vcc1-supply from device tree [ 4.835232] vdd_gpu_s0: supplied by vcc5v0_sys [ 4.835238] vcc5v0_sys: could not add device link regulator.8: -ENOENT [ 4.835988] vdd_gpu_s0: 550 <--> 950 mV at 750 mV, enabled [ 4.836431] rk806-regulator rk806-regulator.6.auto: Looking up vcc2-supply from device tree [ 4.836437] vdd_cpu_lit_s0: supplied by vcc5v0_sys [ 4.836442] vcc5v0_sys: could not add device link regulator.9: -ENOENT [ 4.836665] vdd_cpu_lit_s0: 550 <--> 950 mV at 750 mV, enabled [ 4.837197] rk806-regulator rk806-regulator.6.auto: Looking up vcc3-supply from device tree [ 4.837203] vdd_log_s0: supplied by vcc5v0_sys [ 4.837208] vcc5v0_sys: could not add device link regulator.10: -ENOENT [ 4.837442] vdd_log_s0: 675 <--> 750 mV at 750 mV, enabled [ 4.837958] rk806-regulator rk806-regulator.6.auto: Looking up vcc4-supply from device tree [ 4.837965] vdd_vdenc_s0: supplied by vcc5v0_sys [ 4.837970] vcc5v0_sys: could not add device link regulator.11: -ENOENT [ 4.838203] vdd_vdenc_s0: 550 <--> 950 mV at 750 mV, enabled [ 4.838770] rk806-regulator rk806-regulator.6.auto: Looking up vcc5-supply from device tree [ 4.838776] vdd_ddr_s0: supplied by vcc5v0_sys [ 4.838784] vcc5v0_sys: could not add device link regulator.12: -ENOENT [ 4.839034] vdd_ddr_s0: 675 <--> 900 mV at 850 mV, enabled [ 4.839246] rk806-regulator rk806-regulator.6.auto: Looking up vcc6-supply from device tree [ 4.839251] vdd2_ddr_s3: supplied by vcc5v0_sys [ 4.839256] vcc5v0_sys: could not add device link regulator.13: -ENOENT [ 4.839559] vdd2_ddr_s3: at 500 mV, enabled [ 4.839952] rk806-regulator rk806-regulator.6.auto: Looking up vcc7-supply from device tree [ 4.839958] vdd_2v0_pldo_s3: supplied by vcc5v0_sys [ 4.839963] vcc5v0_sys: could not add device link regulator.14: -ENOENT [ 4.840192] vdd_2v0_pldo_s3: 2000 mV, enabled [ 4.840795] rk806-regulator rk806-regulator.6.auto: Looking up vcc8-supply from device tree [ 4.840814] vcc_3v3_s3: supplied by vcc5v0_sys [ 4.840827] vcc5v0_sys: could not add device link regulator.15: -ENOENT [ 4.841259] vcc_3v3_s3: 3300 mV, enabled [ 4.841941] rk806-regulator rk806-regulator.6.auto: Looking up vcc9-supply from device tree [ 4.841956] vddq_ddr_s0: supplied by vcc5v0_sys [ 4.841968] vcc5v0_sys: could not add device link regulator.16: -ENOENT [ 4.842427] vddq_ddr_s0: at 500 mV, enabled [ 4.843133] rk806-regulator rk806-regulator.6.auto: Looking up vcc10-supply from device tree [ 4.843148] vcc_1v8_s3: supplied by vcc5v0_sys [ 4.843161] vcc5v0_sys: could not add device link regulator.17: -ENOENT [ 4.843532] vcc_1v8_s3: 1800 mV, enabled [ 4.844249] rk806-regulator rk806-regulator.6.auto: Looking up vcc13-supply from device tree [ 4.844382] vdd_0v75_s3: supplied by vcc_1v1_nldo_s3 [ 4.844395] vcc_1v1_nldo_s3: could not add device link regulator.18: -ENOENT [ 4.844771] vdd_0v75_s3: 750 mV, enabled [ 4.845569] rk806-regulator rk806-regulator.6.auto: Looking up vcc13-supply from device tree [ 4.845586] vdd_ddr_pll_s0: supplied by vcc_1v1_nldo_s3 [ 4.845599] vcc_1v1_nldo_s3: could not add device link regulator.19: -ENOENT [ 4.845968] vdd_ddr_pll_s0: 850 mV, enabled [ 4.846629] avdd_0v75_s0: Bringing 750000uV into 837500-837500uV [ 4.846837] avdd_0v75_s0: ramp_delay not set [ 4.846956] rk806-regulator rk806-regulator.6.auto: Looking up vcc13-supply from device tree [ 4.846972] avdd_0v75_s0: supplied by vcc_1v1_nldo_s3 [ 4.846985] vcc_1v1_nldo_s3: could not add device link regulator.20: -ENOENT [ 4.847316] avdd_0v75_s0: 837 mV, enabled [ 4.847700] rk806-regulator rk806-regulator.6.auto: Looking up vcc14-supply from device tree [ 4.847708] vdd_0v85_s0: supplied by vcc_1v1_nldo_s3 [ 4.847714] vcc_1v1_nldo_s3: could not add device link regulator.21: -ENOENT [ 4.847952] vdd_0v85_s0: 850 mV, enabled [ 4.848306] rk806-regulator rk806-regulator.6.auto: Looking up vcc14-supply from device tree [ 4.848313] vdd_0v75_s0: supplied by vcc_1v1_nldo_s3 [ 4.848318] vcc_1v1_nldo_s3: could not add device link regulator.22: -ENOENT [ 4.848544] vdd_0v75_s0: 750 mV, enabled [ 4.848964] rk806-regulator rk806-regulator.6.auto: Looking up vcc11-supply from device tree [ 4.849004] avcc_1v8_s0: supplied by vdd_2v0_pldo_s3 [ 4.849009] vdd_2v0_pldo_s3: could not add device link regulator.23: -ENOENT [ 4.849310] avcc_1v8_s0: 1800 mV, enabled [ 4.849772] rk806-regulator rk806-regulator.6.auto: Looking up vcc11-supply from device tree [ 4.849781] vcc_1v8_s0: supplied by vdd_2v0_pldo_s3 [ 4.849786] vdd_2v0_pldo_s3: could not add device link regulator.24: -ENOENT [ 4.850088] vcc_1v8_s0: 1800 mV, enabled [ 4.850442] rk806-regulator rk806-regulator.6.auto: Looking up vcc11-supply from device tree [ 4.850450] avdd_1v2_s0: supplied by vdd_2v0_pldo_s3 [ 4.850455] vdd_2v0_pldo_s3: could not add device link regulator.25: -ENOENT [ 4.850758] avdd_1v2_s0: 1200 mV, enabled [ 4.851104] rk806-regulator rk806-regulator.6.auto: Looking up vcc12-supply from device tree [ 4.851110] vcc_3v3_s0: supplied by vcc5v0_sys [ 4.851115] vcc5v0_sys: could not add device link regulator.26: -ENOENT [ 4.851349] vcc_3v3_s0: 3300 mV, enabled [ 4.851694] rk806-regulator rk806-regulator.6.auto: Looking up vcc12-supply from device tree [ 4.851701] vccio_sd_s0: supplied by vcc5v0_sys [ 4.851705] vcc5v0_sys: could not add device link regulator.27: -ENOENT [ 4.851937] vccio_sd_s0: 1800 <--> 3300 mV at 3300 mV, enabled [ 4.852303] rk806-regulator rk806-regulator.6.auto: Looking up vcca-supply from device tree [ 4.852309] pldo6_s3: supplied by vcc5v0_sys [ 4.852314] vcc5v0_sys: could not add device link regulator.28: -ENOENT [ 4.852542] pldo6_s3: 1800 mV, enabled [ 4.852892] rk806 spi2.0: no sleep-setting state [ 4.852896] rk806 spi2.0: no reset-setting pinctrl state [ 4.852900] rk806 spi2.0: no dvs-setting pinctrl state [ 4.852987] nvme nvme0: 7/0/0 default/read/poll queues [ 4.854794] rockchip-spi feb20000.spi: register misc device rkspi-dev2 [ 4.854799] rockchip-spi feb20000.spi: probed, poll=0, rsd=0 [ 4.856625] spi-nor spi5.0: XM25QU128C (16384 Kbytes) read_data x4 [ 4.856669] 1 fixed-partitions partitions found on MTD device sfc_nor [ 4.856676] Creating 1 MTD partitions on "sfc_nor": [ 4.856685] 0x000000000000-0x000001000000 : "loader" [ 4.858856] rk_gmac-dwmac fe1c0000.ethernet: IRQ eth_lpi not found [ 4.859002] rk_gmac-dwmac fe1c0000.ethernet: Looking up phy-supply from device tree [ 4.859015] rk_gmac-dwmac fe1c0000.ethernet: Looking up phy-supply property in node /ethernet@fe1c0000 failed [ 4.859031] rk_gmac-dwmac fe1c0000.ethernet: no regulator found [ 4.859035] rk_gmac-dwmac fe1c0000.ethernet: clock input or output? (output). [ 4.859040] rk_gmac-dwmac fe1c0000.ethernet: TX delay(0x42). [ 4.859043] rk_gmac-dwmac fe1c0000.ethernet: Can not read property: rx_delay. [ 4.859047] rk_gmac-dwmac fe1c0000.ethernet: set rx_delay to 0xffffffff [ 4.859055] rk_gmac-dwmac fe1c0000.ethernet: integrated PHY? (no). [ 4.859060] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_rx [ 4.859065] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_tx [ 4.859081] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock clk_mac_speed [ 4.859302] rk_gmac-dwmac fe1c0000.ethernet: init for RGMII_RXID [ 4.859403] rk_gmac-dwmac fe1c0000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 4.859408] rk_gmac-dwmac fe1c0000.ethernet: DWMAC4/5 [ 4.859412] rk_gmac-dwmac fe1c0000.ethernet: DMA HW capability register supported [ 4.859415] rk_gmac-dwmac fe1c0000.ethernet: RX Checksum Offload Engine supported [ 4.859419] rk_gmac-dwmac fe1c0000.ethernet: TX Checksum insertion supported [ 4.859422] rk_gmac-dwmac fe1c0000.ethernet: Wake-Up On Lan supported [ 4.859454] rk_gmac-dwmac fe1c0000.ethernet: TSO supported [ 4.859457] rk_gmac-dwmac fe1c0000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 4.859462] rk_gmac-dwmac fe1c0000.ethernet: Enabled Flow TC (entries=2) [ 4.859465] rk_gmac-dwmac fe1c0000.ethernet: TSO feature enabled [ 4.859469] rk_gmac-dwmac fe1c0000.ethernet: Using 32 bits DMA width [ 4.865574] nvme0n1: p1 p2 [ 5.002117] usbcore: registered new interface driver rndis_wlan [ 5.002136] usbcore: registered new interface driver asix [ 5.002154] usbcore: registered new interface driver cdc_ether [ 5.002171] usbcore: registered new interface driver rndis_host [ 5.002193] usbcore: registered new interface driver cdc_ncm [ 5.008588] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up usb-supply from device tree [ 5.008647] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up usb-supply property in node /power-management@fd8d8000/power-controller failed [ 5.012905] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 5.012926] ehci-pci: EHCI PCI platform driver [ 5.013018] ehci-platform: EHCI generic platform driver [ 5.015572] ehci-platform fc800000.usb: EHCI Host Controller [ 5.015639] ehci-platform fc800000.usb: new USB bus registered, assigned bus number 1 [ 5.015773] ehci-platform fc800000.usb: irq 20, io mem 0xfc800000 [ 5.026318] ehci-platform fc800000.usb: USB 2.0 started, EHCI 1.00 [ 5.026618] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 5.026629] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.026637] usb usb1: Product: EHCI Host Controller [ 5.026644] usb usb1: Manufacturer: Linux 5.10.160-rk35xx ehci_hcd [ 5.026652] usb usb1: SerialNumber: fc800000.usb [ 5.027168] hub 1-0:1.0: USB hub found [ 5.027222] hub 1-0:1.0: 1 port detected [ 5.030140] ehci-platform fc880000.usb: EHCI Host Controller [ 5.030168] ehci-platform fc880000.usb: new USB bus registered, assigned bus number 2 [ 5.030309] ehci-platform fc880000.usb: irq 22, io mem 0xfc880000 [ 5.042983] ehci-platform fc880000.usb: USB 2.0 started, EHCI 1.00 [ 5.043284] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 5.043295] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.043304] usb usb2: Product: EHCI Host Controller [ 5.043311] usb usb2: Manufacturer: Linux 5.10.160-rk35xx ehci_hcd [ 5.043319] usb usb2: SerialNumber: fc880000.usb [ 5.043804] hub 2-0:1.0: USB hub found [ 5.043852] hub 2-0:1.0: 1 port detected [ 5.044845] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 5.044866] ohci-platform: OHCI generic platform driver [ 5.045221] ohci-platform fc840000.usb: Generic Platform OHCI controller [ 5.045242] ohci-platform fc840000.usb: new USB bus registered, assigned bus number 3 [ 5.045357] ohci-platform fc840000.usb: irq 21, io mem 0xfc840000 [ 5.103885] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10 [ 5.103896] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.103904] usb usb3: Product: Generic Platform OHCI controller [ 5.103912] usb usb3: Manufacturer: Linux 5.10.160-rk35xx ohci_hcd [ 5.103919] usb usb3: SerialNumber: fc840000.usb [ 5.104400] hub 3-0:1.0: USB hub found [ 5.104449] hub 3-0:1.0: 1 port detected [ 5.105147] ohci-platform fc8c0000.usb: Generic Platform OHCI controller [ 5.105169] ohci-platform fc8c0000.usb: new USB bus registered, assigned bus number 4 [ 5.105275] ohci-platform fc8c0000.usb: irq 23, io mem 0xfc8c0000 [ 5.163873] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10 [ 5.163885] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.163893] usb usb4: Product: Generic Platform OHCI controller [ 5.163901] usb usb4: Manufacturer: Linux 5.10.160-rk35xx ohci_hcd [ 5.163908] usb usb4: SerialNumber: fc8c0000.usb [ 5.164382] hub 4-0:1.0: USB hub found [ 5.164430] hub 4-0:1.0: 1 port detected [ 5.165924] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 5.165946] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 5 [ 5.166091] xhci-hcd xhci-hcd.7.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000200002010010 [ 5.166143] xhci-hcd xhci-hcd.7.auto: irq 139, io mem 0xfcd00000 [ 5.166597] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 5.166608] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.166616] usb usb5: Product: xHCI Host Controller [ 5.166623] usb usb5: Manufacturer: Linux 5.10.160-rk35xx xhci-hcd [ 5.166631] usb usb5: SerialNumber: xhci-hcd.7.auto [ 5.167116] hub 5-0:1.0: USB hub found [ 5.167166] hub 5-0:1.0: 1 port detected [ 5.167581] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 5.167599] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 6 [ 5.167616] xhci-hcd xhci-hcd.7.auto: Host supports USB 3.0 SuperSpeed [ 5.167723] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM. [ 5.167915] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 [ 5.167926] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.167933] usb usb6: Product: xHCI Host Controller [ 5.167941] usb usb6: Manufacturer: Linux 5.10.160-rk35xx xhci-hcd [ 5.167948] usb usb6: SerialNumber: xhci-hcd.7.auto [ 5.168455] hub 6-0:1.0: USB hub found [ 5.168502] hub 6-0:1.0: 1 port detected [ 5.169050] usbcore: registered new interface driver cdc_acm [ 5.169057] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 5.169255] usbcore: registered new interface driver uas [ 5.169415] usbcore: registered new interface driver usb-storage [ 5.170897] Error: Driver 'Goodix-TS' is already registered, aborting... [ 5.170991] usbcore: registered new interface driver usbtouchscreen [ 5.172994] input: rk805 pwrkey as /devices/platform/feb20000.spi/spi_master/spi2/spi2.0/rk805-pwrkey.5.auto/input/input0 [ 5.173629] i2c /dev entries driver [ 5.178242] rk860-regulator 0-0042: Looking up vin-supply from device tree [ 5.178258] vdd_cpu_big0_s0: supplied by vcc5v0_sys [ 5.178270] vcc5v0_sys: could not add device link regulator.29: -ENOENT [ 5.182533] vdd_cpu_big0_s0: 550 <--> 1050 mV at 800 mV, enabled [ 5.187628] rk860-regulator 0-0043: Looking up vin-supply from device tree [ 5.187642] vdd_cpu_big1_s0: supplied by vcc5v0_sys [ 5.187655] vcc5v0_sys: could not add device link regulator.30: -ENOENT [ 5.191919] vdd_cpu_big1_s0: 550 <--> 1050 mV at 800 mV, enabled [ 5.195334] Goodix-TS 2-0014: Looking up AVDD28-supply from device tree [ 5.195353] Goodix-TS 2-0014: Looking up AVDD28-supply property in node /i2c@feaa0000/touchscreen@14 failed [ 5.195380] Goodix-TS 2-0014: supply AVDD28 not found, using dummy regulator [ 5.195507] Goodix-TS 2-0014: Looking up VDDIO-supply from device tree [ 5.195525] Goodix-TS 2-0014: Looking up VDDIO-supply property in node /i2c@feaa0000/touchscreen@14 failed [ 5.195548] Goodix-TS 2-0014: supply VDDIO not found, using dummy regulator [ 5.286478] Goodix-TS 2-0014: i2c test failed attempt 1: -6 [ 5.313140] Goodix-TS 2-0014: i2c test failed attempt 2: -6 [ 5.339643] Goodix-TS 2-0014: I2C communication failure: -6 [ 5.343260] rk860-regulator 2-0042: Looking up vin-supply from device tree [ 5.343274] vdd_npu_s0: supplied by vcc5v0_sys [ 5.343286] vcc5v0_sys: could not add device link regulator.31: -ENOENT [ 5.347506] vdd_npu_s0: 550 <--> 950 mV at 800 mV, enabled [ 5.352866] typec_fusb302 6-0022: Looking up vbus-supply from device tree [ 5.381911] rtc-hym8563 6-0051: rtc information is valid [ 5.387214] rtc-hym8563 6-0051: registered as rtc0 [ 5.388225] rtc-hym8563 6-0051: setting system clock to 2023-08-07T18:25:37 UTC (1691432737) [ 5.390856] Goodix-TS 7-0014: Looking up AVDD28-supply from device tree [ 5.390865] Goodix-TS 7-0014: Looking up AVDD28-supply property in node /i2c@fec90000/touchscreen@14 failed [ 5.390879] Goodix-TS 7-0014: supply AVDD28 not found, using dummy regulator [ 5.390940] Goodix-TS 7-0014: Looking up VDDIO-supply from device tree [ 5.390947] Goodix-TS 7-0014: Looking up VDDIO-supply property in node /i2c@fec90000/touchscreen@14 failed [ 5.390956] Goodix-TS 7-0014: supply VDDIO not found, using dummy regulator [ 5.483098] Goodix-TS 7-0014: i2c test failed attempt 1: -6 [ 5.509762] Goodix-TS 7-0014: i2c test failed attempt 2: -6 [ 5.536280] Goodix-TS 7-0014: I2C communication failure: -6 [ 5.537276] rkcifhw fdce0000.rkcif: Adding to iommu group 16 [ 5.537633] rkcifhw fdce0000.rkcif: No reserved memory region assign to CIF [ 5.538818] rkisp_hw fdcb0000.rkisp: Adding to iommu group 14 [ 5.538983] rkisp_hw fdcb0000.rkisp: is_thunderboot: 0 [ 5.538987] rkisp_hw fdcb0000.rkisp: max input:0x0@0fps [ 5.538992] rkisp_hw fdcb0000.rkisp: Missing rockchip,grf property [ 5.539096] rkisp_hw fdcb0000.rkisp: no find phandle sram [ 5.539200] rkisp_hw fdcc0000.rkisp: Adding to iommu group 15 [ 5.539406] rkisp_hw fdcc0000.rkisp: is_thunderboot: 0 [ 5.539410] rkisp_hw fdcc0000.rkisp: max input:0x0@0fps [ 5.539414] rkisp_hw fdcc0000.rkisp: Missing rockchip,grf property [ 5.539507] rkisp_hw fdcc0000.rkisp: no find phandle sram [ 5.540501] usbcore: registered new interface driver uvcvideo [ 5.540504] USB Video Class driver (1.1.1) [ 5.541829] cpu cpu0: Looking up cpu-supply from device tree [ 5.542340] cpu cpu0: bin=0 [ 5.542515] cpu cpu0: leakage=8 [ 5.542540] cpu cpu0: Looking up cpu-supply from device tree [ 5.543982] cpu cpu0: pvtm=1381 [ 5.544148] cpu cpu0: pvtm-volt-sel=0 [ 5.544182] cpu cpu0: Looking up cpu-supply from device tree [ 5.544315] cpu cpu0: Looking up mem-supply from device tree [ 5.544490] cpu cpu4: Looking up cpu-supply from device tree [ 5.546194] cpu cpu4: bin=0 [ 5.546366] cpu cpu4: leakage=6 [ 5.546387] cpu cpu4: Looking up cpu-supply from device tree [ 5.552917] cpu cpu4: pvtm=1588 [ 5.556912] cpu cpu4: pvtm-volt-sel=0 [ 5.556954] cpu cpu4: Looking up cpu-supply from device tree [ 5.557458] cpu cpu4: Looking up mem-supply from device tree [ 5.558000] cpu cpu6: Looking up cpu-supply from device tree [ 5.559693] cpu cpu6: bin=0 [ 5.559864] cpu cpu6: leakage=6 [ 5.559883] cpu cpu6: Looking up cpu-supply from device tree [ 5.566274] cpu cpu6: pvtm=1590 [ 5.570240] cpu cpu6: pvtm-volt-sel=0 [ 5.570282] cpu cpu6: Looking up cpu-supply from device tree [ 5.570784] cpu cpu6: Looking up mem-supply from device tree [ 5.571961] cpu cpu0: avs=0 [ 5.572744] cpu cpu4: avs=0 [ 5.573524] cpu cpu6: avs=0 [ 5.573691] cpu cpu0: EM: OPP:816000 is inefficient [ 5.573695] cpu cpu0: EM: OPP:600000 is inefficient [ 5.573786] cpu cpu0: EM: created perf domain [ 5.573824] cpu cpu0: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=1608000000 h_table=0 [ 5.574409] cpu cpu4: EM: OPP:816000 is inefficient [ 5.574414] cpu cpu4: EM: OPP:600000 is inefficient [ 5.574536] cpu cpu4: EM: created perf domain [ 5.574565] cpu cpu4: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0 [ 5.579687] usb 3-1: new full-speed USB device number 2 using ohci-platform [ 5.583047] cpu cpu6: EM: OPP:816000 is inefficient [ 5.583052] cpu cpu6: EM: OPP:600000 is inefficient [ 5.583181] cpu cpu6: EM: created perf domain [ 5.583613] cpu cpu6: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0 [ 5.599254] sdhci: Secure Digital Host Controller Interface driver [ 5.599261] sdhci: Copyright(c) Pierre Ossman [ 5.599266] Synopsys Designware Multimedia Card Interface Driver [ 5.600447] sdhci-pltfm: SDHCI platform and OF driver helper [ 5.604402] ledtrig-cpu: registered to indicate activity on CPUs [ 5.604453] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active. [ 5.604532] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 5.605950] cryptodev: driver 1.12 loaded. [ 5.606031] hid: raw HID events driver (C) Jiri Kosina [ 5.606376] usbcore: registered new interface driver usbhid [ 5.606383] usbhid: USB HID core driver [ 5.606882] ashmem: initialized [ 5.613995] rockchip-saradc fec10000.saradc: Looking up vref-supply from device tree [ 5.616430] optee: probing for conduit method. [ 5.616441] optee: api uid mismatch [ 5.616461] optee: probe of firmware:optee failed with error -22 [ 5.618040] usbcore: registered new interface driver snd-usb-audio [ 5.628276] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up audio-supply from device tree [ 5.628342] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up audio-supply property in node /power-management@fd8d8000/power-controller failed [ 5.631795] debugfs: File 'Capture' in directory 'dapm' already present! [ 5.632985] input: rockchip-dp0 rockchip-dp0 as /devices/platform/dp0-sound/sound/card0/input1 [ 5.634879] input: rockchip-hdmi0 rockchip-hdmi0 as /devices/platform/hdmi0-sound/sound/card1/input2 [ 5.635873] input: headset-keys as /devices/platform/es8388-sound/input/input3 [ 5.648002] ES8323 6-0010: ASoC: error at soc_component_write_no_lock on ES8323.6-0010: -5 [ 5.702529] input: rockchip-es8388 Headset as /devices/platform/es8388-sound/sound/card2/input4 [ 5.703604] Initializing XFRM netlink socket [ 5.703618] NET: Registered protocol family 17 [ 5.703861] [BT_RFKILL]: Enter rfkill_rk_init [ 5.703864] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 5.704259] Key type dns_resolver registered [ 5.705625] registered taskstats version 1 [ 5.705633] Loading compiled-in X.509 certificates [ 5.706588] Btrfs loaded, crc32c=crc32c-generic [ 5.706718] pstore: Using crash dump compression: deflate [ 5.706951] rga3_core0 fdb60000.rga: Adding to iommu group 2 [ 5.707133] rga: rga3_core0, irq = 35, match scheduler [ 5.707591] rga: rga3_core0 hardware loaded successfully, hw_version:3.0.76831. [ 5.707639] rga: rga3_core0 probe successfully [ 5.707947] rga3_core1 fdb70000.rga: Adding to iommu group 3 [ 5.708127] rga: rga3_core1, irq = 36, match scheduler [ 5.708555] rga: rga3_core1 hardware loaded successfully, hw_version:3.0.76831. [ 5.708604] rga: rga3_core1 probe successfully [ 5.708935] rga: rga2, irq = 37, match scheduler [ 5.709292] rga: rga2 hardware loaded successfully, hw_version:3.2.63318. [ 5.709301] rga: rga2 probe successfully [ 5.709504] rga_iommu: IOMMU binding successfully, default mapping core[0x1] [ 5.709880] rga: Module initialized. v1.2.25 [ 5.763469] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up gpu-supply from device tree [ 5.763643] reg-fixed-voltage combophy-avdd0v85: Looking up vin-supply from device tree [ 5.763749] combophy_avdd0v85: supplied by vdd_0v85_s0 [ 5.763764] vdd_0v85_s0: could not add device link regulator.32: -ENOENT [ 5.763811] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up gpu-supply property in node /power-management@fd8d8000/power-controller failed [ 5.764012] mali fb000000.gpu: Kernel DDK version g17p0-01eac0 [ 5.764090] mali fb000000.gpu: Looking up mali-supply from device tree [ 5.764362] mali fb000000.gpu: Looking up mem-supply from device tree [ 5.764430] combophy_avdd0v85: 850 mV, enabled [ 5.764484] mali fb000000.gpu: Looking up mali-supply from device tree [ 5.764511] vdd_gpu_s0: could not add device link fb000000.gpu: -EEXIST [ 5.764518] vdd_gpu_s0: Failed to create debugfs directory [ 5.764527] mali fb000000.gpu: Looking up mem-supply from device tree [ 5.764549] vdd_gpu_s0: could not add device link fb000000.gpu: -EEXIST [ 5.764554] vdd_gpu_s0: Failed to create debugfs directory [ 5.764701] mali fb000000.gpu: Looking up mali-supply from device tree [ 5.764712] reg-fixed-voltage combophy-avdd0v85: combophy_avdd0v85 supplying 850000uV [ 5.764724] vdd_gpu_s0: could not add device link fb000000.gpu: -EEXIST [ 5.764730] vdd_gpu_s0: Failed to create debugfs directory [ 5.764981] reg-fixed-voltage combophy-avdd1v8: Looking up vin-supply from device tree [ 5.765016] mali fb000000.gpu: bin=0 [ 5.765090] combophy_avdd1v8: supplied by avcc_1v8_s0 [ 5.765103] avcc_1v8_s0: could not add device link regulator.33: -ENOENT [ 5.765257] mali fb000000.gpu: leakage=13 [ 5.765303] mali fb000000.gpu: Looking up mali-supply from device tree [ 5.765327] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present! [ 5.765825] combophy_avdd1v8: 1800 mV, enabled [ 5.766095] reg-fixed-voltage combophy-avdd1v8: combophy_avdd1v8 supplying 1800000uV [ 5.766372] vcc_3v3_sd_s0: 3300 mV, disabled [ 5.766540] reg-fixed-voltage vcc-3v3-sd-s0: Looking up vin-supply from device tree [ 5.766558] vcc_3v3_sd_s0: supplied by vcc_3v3_s3 [ 5.767183] reg-fixed-voltage vcc-3v3-sd-s0: vcc_3v3_sd_s0 supplying 3300000uV [ 5.767361] mali fb000000.gpu: pvtm=846 [ 5.767993] mali fb000000.gpu: pvtm-volt-sel=2 [ 5.768243] rockchip-dmc dmc: Looking up center-supply from device tree [ 5.768831] rockchip-dmc dmc: Looking up mem-supply from device tree [ 5.769219] rockchip-dmc dmc: Looking up center-supply from device tree [ 5.769258] vdd_ddr_s0: could not add device link dmc: -EEXIST [ 5.769266] vdd_ddr_s0: Failed to create debugfs directory [ 5.769307] mali fb000000.gpu: avs=0 [ 5.769563] rockchip-dmc dmc: Looking up mem-supply from device tree [ 5.769638] vdd_log_s0: could not add device link dmc: -EEXIST [ 5.769646] vdd_log_s0: Failed to create debugfs directory [ 5.769766] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 143; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available. [ 5.770525] rockchip-dmc dmc: leakage=30 [ 5.770547] rockchip-dmc dmc: leakage-volt-sel=0 [ 5.771236] rockchip-dmc dmc: avs=0 [ 5.771258] rockchip-dmc dmc: current ATF version 0x100 [ 5.771430] rockchip-dmc dmc: normal_rate = 1560000000 [ 5.771439] rockchip-dmc dmc: reboot_rate = 2112000000 [ 5.771448] rockchip-dmc dmc: suspend_rate = 528000000 [ 5.771457] rockchip-dmc dmc: video_4k_rate = 1560000000 [ 5.771466] rockchip-dmc dmc: video_4k_10b_rate = 1560000000 [ 5.771474] rockchip-dmc dmc: video_svep_rate = 1560000000 [ 5.771483] rockchip-dmc dmc: boost_rate = 2112000000 [ 5.771492] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 2112000000 [ 5.771501] rockchip-dmc dmc: performance_rate = 2112000000 [ 5.771516] rockchip-dmc dmc: hdmirx_rate = 2112000000 [ 5.771529] mali fb000000.gpu: GPU hardware issue table may need updating: r0p0 status 5 is unknown; treating as r0p0 status 0 [ 5.771542] mali fb000000.gpu: GPU identified as 0x7 arch 10.8.6 r0p0 status 0 [ 5.771546] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate [ 5.771554] rockchip-dmc dmc: failed to get vop pn to msch rl [ 5.771638] mali fb000000.gpu: No priority control manager is configured [ 5.771775] rockchip-dmc dmc: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0 [ 5.771809] mali fb000000.gpu: No memory group manager is configured [ 5.771844] mali fb000000.gpu: Protected memory allocator not available [ 5.772818] rockchip-dmc dmc: could not find power_model node [ 5.773088] mali fb000000.gpu: Capping CSF_FIRMWARE_TIMEOUT to CSF_FIRMWARE_PING_TIMEOUT [ 5.774236] mali fb000000.gpu: Couldn't find power_model DT node matching 'arm,mali-simple-power-model' [ 5.774250] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.static-coefficient = 1*[0] [ 5.774605] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.dynamic-coefficient = 1*[0] [ 5.774950] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.ts = 4*[0] [ 5.775303] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.thermal-zone = '' [ 5.780620] mali fb000000.gpu: Using configured power model mali-lodx-power-model, and fallback mali-simple-power-model [ 5.780898] mali fb000000.gpu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0 [ 5.781181] input: adc-keys as /devices/platform/adc-keys/input/input5 [ 5.782276] mali fb000000.gpu: Probed as mali0 [ 5.784003] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode. [ 5.784039] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller. [ 5.784048] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a [ 5.784087] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 90,32 bit host data width,256 deep fifo [ 5.784168] dwmmc_rockchip fe2c0000.mmc: Looking up vmmc-supply from device tree [ 5.784369] dwmmc_rockchip fe2c0000.mmc: Looking up vqmmc-supply from device tree [ 5.784416] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up sdio-supply from device tree [ 5.784460] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up sdio-supply property in node /power-management@fd8d8000/power-controller failed [ 5.784512] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up pcie-supply from device tree [ 5.784546] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up pcie-supply property in node /power-management@fd8d8000/power-controller failed [ 5.784590] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu-supply from device tree [ 5.784623] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu-supply property in node /power-management@fd8d8000/power-controller failed [ 5.786413] RKNPU fdab0000.npu: Adding to iommu group 0 [ 5.786587] RKNPU fdab0000.npu: RKNPU: rknpu iommu is enabled, using iommu mode [ 5.786704] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 5.787544] RKNPU fdab0000.npu: Looking up mem-supply from device tree [ 5.788265] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff] [ 5.788294] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff] [ 5.788311] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff] [ 5.789276] [drm] Initialized rknpu 0.8.5 20230202 for fdab0000.npu on minor 1 [ 5.789760] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up nputop-supply from device tree [ 5.789802] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up nputop-supply property in node /power-management@fd8d8000/power-controller failed [ 5.789886] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu1-supply from device tree [ 5.789919] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu1-supply property in node /power-management@fd8d8000/power-controller failed [ 5.789985] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu2-supply from device tree [ 5.790018] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu2-supply property in node /power-management@fd8d8000/power-controller failed [ 5.790191] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 5.790220] vdd_npu_s0: could not add device link fdab0000.npu: -EEXIST [ 5.790225] vdd_npu_s0: Failed to create debugfs directory [ 5.790902] RKNPU fdab0000.npu: Looking up mem-supply from device tree [ 5.790953] vdd_npu_s0: could not add device link fdab0000.npu: -EEXIST [ 5.790959] vdd_npu_s0: Failed to create debugfs directory [ 5.791819] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 5.791865] vdd_npu_s0: could not add device link fdab0000.npu: -EEXIST [ 5.791870] vdd_npu_s0: Failed to create debugfs directory [ 5.794401] RKNPU fdab0000.npu: RKNPU: bin=0 [ 5.794581] RKNPU fdab0000.npu: leakage=7 [ 5.794627] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 5.794663] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present! [ 5.796073] usb 3-1: New USB device found, idVendor=046d, idProduct=c539, bcdDevice=39.06 [ 5.796088] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 5.796098] usb 3-1: Product: USB Receiver [ 5.796107] usb 3-1: Manufacturer: Logitech [ 5.797146] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 5.803368] RKNPU fdab0000.npu: pvtm=846 [ 5.805339] input: Logitech USB Receiver as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.0/0003:046D:C539.0001/input/input6 [ 5.809748] RKNPU fdab0000.npu: pvtm-volt-sel=2 [ 5.811823] RKNPU fdab0000.npu: avs=0 [ 5.812197] RKNPU fdab0000.npu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0 [ 5.822283] RKNPU fdab0000.npu: failed to find power_model node [ 5.822298] RKNPU fdab0000.npu: RKNPU: failed to initialize power model [ 5.822309] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient [ 5.824438] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 5.839436] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 5.840787] rockchip-pm rockchip-suspend: not set pwm-regulator-config [ 5.840810] rockchip-suspend not set sleep-mode-config for mem-lite [ 5.840817] rockchip-suspend not set wakeup-config for mem-lite [ 5.840829] rockchip-suspend not set sleep-mode-config for mem-ultra [ 5.840836] rockchip-suspend not set wakeup-config for mem-ultra [ 5.842986] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 406; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '13:36:29', on 'Jul 6 2023'. [ 5.843657] Mali: [ 5.843663] Mali device driver loaded [ 5.843676] ALSA device list: [ 5.843684] #0: rockchip-dp0 [ 5.843691] #1: rockchip-hdmi0 [ 5.843698] #2: rockchip-es8388 [ 5.851443] Freeing unused kernel memory: 6976K [ 5.860870] hid-generic 0003:046D:C539.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-fc840000.usb-1/input0 [ 5.867118] input: Logitech USB Receiver Mouse as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input7 [ 5.897211] Run /init as init process [ 5.897231] with arguments: [ 5.897245] /init [ 5.897257] splash [ 5.897270] with environment: [ 5.897283] HOME=/ [ 5.897297] TERM=linux [ 5.897311] ubootpart= [ 5.897324] cgroup_enable=memory [ 5.897337] cgroup_memory=1 [ 5.923187] input: Logitech USB Receiver Consumer Control as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input8 [ 5.923837] input: Logitech USB Receiver System Control as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input9 [ 5.924957] hid-generic 0003:046D:C539.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-fc840000.usb-1/input1 [ 5.930612] hid-generic 0003:046D:C539.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-fc840000.usb-1/input2 [ 6.997087] EXT4-fs (nvme0n1p2): mounted filesystem with writeback data mode. Opts: (null) [ 7.272157] NET: Registered protocol family 10 [ 7.273880] Segment Routing with IPv6 [ 7.293943] systemd[1]: systemd 249.11-0ubuntu3.9 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified) [ 7.296105] systemd[1]: Detected architecture arm64. [ 7.297988] systemd[1]: Hostname set to . [ 7.590457] systemd[1]: Queued start job for default target Graphical Interface. [ 7.592120] systemd[1]: Created slice Slice /system/modprobe. [ 7.592666] systemd[1]: Created slice Slice /system/serial-getty. [ 7.593202] systemd[1]: Created slice Slice /system/systemd-fsck. [ 7.593512] systemd[1]: Created slice User and Session Slice. [ 7.593641] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 7.593969] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 7.594088] systemd[1]: Reached target User and Group Name Lookups. [ 7.594138] systemd[1]: Reached target Slice Units. [ 7.594172] systemd[1]: Reached target Swaps. [ 7.594210] systemd[1]: Reached target System Time Set. [ 7.594282] systemd[1]: Reached target Local Verity Protected Volumes. [ 7.602682] systemd[1]: Listening on RPCbind Server Activation Socket. [ 7.603018] systemd[1]: Listening on Syslog Socket. [ 7.603195] systemd[1]: Listening on fsck to fsckd communication Socket. [ 7.603297] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 7.603571] systemd[1]: Listening on Journal Audit Socket. [ 7.603694] systemd[1]: Listening on Journal Socket (/dev/log). [ 7.603869] systemd[1]: Listening on Journal Socket. [ 7.604727] systemd[1]: Listening on udev Control Socket. [ 7.604871] systemd[1]: Listening on udev Kernel Socket. [ 7.605874] systemd[1]: Mounting Huge Pages File System... [ 7.606972] systemd[1]: Mounting POSIX Message Queue File System... [ 7.608197] systemd[1]: Mounting Kernel Debug File System... [ 7.609555] systemd[1]: Mounting Kernel Trace File System... [ 7.609907] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped. [ 7.611753] systemd[1]: Starting Restore / save the current clock... [ 7.613498] systemd[1]: Starting Set the console keyboard layout... [ 7.615109] systemd[1]: Starting Create List of Static Device Nodes... [ 7.616791] systemd[1]: Starting Load Kernel Module chromeos_pstore... [ 7.618514] systemd[1]: Starting Load Kernel Module configfs... [ 7.620282] systemd[1]: Starting Load Kernel Module drm... [ 7.622313] systemd[1]: Starting Load Kernel Module efi_pstore... [ 7.624682] systemd[1]: Starting Load Kernel Module fuse... [ 7.627279] systemd[1]: Starting Load Kernel Module pstore_blk... [ 7.629159] systemd[1]: Starting Load Kernel Module pstore_zone... [ 7.631304] systemd[1]: Starting Load Kernel Module ramoops... [ 7.631511] fuse: init (API version 7.32) [ 7.631724] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 7.634052] systemd[1]: Starting Load Kernel Modules... [ 7.635597] systemd[1]: Starting Remount Root and Kernel File Systems... [ 7.637413] systemd[1]: Starting Coldplug All udev Devices... [ 7.640501] systemd[1]: Mounted Huge Pages File System. [ 7.640786] systemd[1]: Mounted POSIX Message Queue File System. [ 7.640972] systemd[1]: Mounted Kernel Debug File System. [ 7.641136] systemd[1]: Mounted Kernel Trace File System. [ 7.641660] systemd[1]: Finished Restore / save the current clock. [ 7.642293] systemd[1]: Finished Create List of Static Device Nodes. [ 7.642663] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully. [ 7.642988] systemd[1]: Finished Load Kernel Module chromeos_pstore. [ 7.643418] systemd[1]: modprobe@configfs.service: Deactivated successfully. [ 7.643712] systemd[1]: Finished Load Kernel Module configfs. [ 7.644132] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 7.644462] systemd[1]: Finished Load Kernel Module drm. [ 7.644855] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [ 7.645170] systemd[1]: Finished Load Kernel Module efi_pstore. [ 7.645546] systemd[1]: modprobe@fuse.service: Deactivated successfully. [ 7.645857] systemd[1]: Finished Load Kernel Module fuse. [ 7.646219] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully. [ 7.646959] systemd[1]: Finished Load Kernel Module pstore_blk. [ 7.647332] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully. [ 7.647625] systemd[1]: Finished Load Kernel Module pstore_zone. [ 7.647995] systemd[1]: modprobe@ramoops.service: Deactivated successfully. [ 7.648293] systemd[1]: Finished Load Kernel Module ramoops. [ 7.648778] systemd[1]: Finished Load Kernel Modules. [ 7.650550] systemd[1]: Mounting FUSE Control File System... [ 7.651976] systemd[1]: Mounting Kernel Configuration File System... [ 7.653702] systemd[1]: Starting Apply Kernel Variables... [ 7.655261] systemd[1]: Mounted FUSE Control File System. [ 7.655504] systemd[1]: Mounted Kernel Configuration File System. [ 7.659476] EXT4-fs (nvme0n1p2): re-mounted. Opts: commit=600,errors=remount-ro [ 7.661753] systemd[1]: Finished Remount Root and Kernel File Systems. [ 7.663733] systemd[1]: Starting Platform Persistent Storage Archival... [ 7.665525] systemd[1]: Starting Load/Save Random Seed... [ 7.667334] systemd[1]: Starting Create System Users... [ 7.673911] systemd[1]: Finished Apply Kernel Variables. [ 7.686014] systemd[1]: Finished Create System Users. [ 7.691521] systemd[1]: Starting Create Static Device Nodes in /dev... [ 7.710135] systemd[1]: Finished Set the console keyboard layout. [ 7.710716] systemd[1]: Finished Create Static Device Nodes in /dev. [ 7.710913] systemd[1]: Reached target Preparation for Local File Systems. [ 7.712195] systemd[1]: Mounting /tmp... [ 7.714317] systemd[1]: Starting Rule-based Manager for Device Events and Files... [ 7.715759] systemd[1]: Finished Platform Persistent Storage Archival. [ 7.717995] systemd[1]: Mounted /tmp. [ 7.723161] systemd[1]: Finished Load/Save Random Seed. [ 7.723423] systemd[1]: Condition check resulted in First Boot Complete being skipped. [ 7.788169] systemd[1]: Started Rule-based Manager for Device Events and Files. [ 7.864787] systemd[1]: Finished Coldplug All udev Devices. [ 7.865837] systemd[1]: Created slice Slice /system/systemd-backlight. [ 7.869056] systemd[1]: Starting Helper to synchronize boot up for ifupdown... [ 7.871355] systemd[1]: Starting Show Plymouth Boot Screen... [ 7.874409] systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:backlight_1... [ 7.880211] systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:backlight... [ 7.883481] systemd[1]: Finished Helper to synchronize boot up for ifupdown. [ 7.884638] systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:backlight_1. [ 7.890277] systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:backlight. [ 7.902082] systemd[1]: Started Show Plymouth Boot Screen. [ 7.902812] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 7.903457] systemd[1]: Started Forward Password Requests to Plymouth Directory Watch. [ 7.903655] systemd[1]: Reached target Local Encrypted Volumes. [ 7.995463] systemd[1]: Found device Samsung SSD 960 EVO 500GB armbi_boot. [ 8.001753] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 8.001962] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 8.004805] systemd[1]: Starting File System Check on /dev/disk/by-uuid/1BD1-7F33... [ 8.009763] systemd[1]: Found device /dev/ttyFIQ0. [ 8.012782] systemd[1]: Started File System Check Daemon to report status. [ 8.024700] systemd[1]: Reached target Hardware activated USB gadget. [ 8.047447] systemd[1]: Finished File System Check on /dev/disk/by-uuid/1BD1-7F33. [ 8.047660] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 8.048937] systemd[1]: Mounting /boot... [ 8.049090] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 8.051812] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 8.052724] FAT-fs (nvme0n1p1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive! [ 8.057808] systemd[1]: Mounted /boot. [ 8.058271] systemd[1]: Reached target Local File Systems. [ 8.061443] systemd[1]: Starting Armbian leds state... [ 8.064569] systemd[1]: Starting Armbian ZRAM config... [ 8.067571] systemd[1]: Starting Set console font and keymap... [ 8.070879] systemd[1]: Starting Raise network interfaces... [ 8.073898] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data... [ 8.074134] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped. [ 8.075892] systemd[1]: Starting Set Up Additional Binary Formats... [ 8.075981] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 8.076024] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 8.076694] systemd[1]: Finished Armbian leds state. [ 8.077207] systemd[1]: Finished Set console font and keymap. [ 8.083311] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 536 (systemd-binfmt) [ 8.086410] systemd[1]: Mounting Arbitrary Executable File Formats File System... [ 8.087858] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data. [ 8.088337] systemd[1]: Received SIGRTMIN+20 from PID 293 (plymouthd). [ 8.093871] systemd[1]: Mounted Arbitrary Executable File Formats File System. [ 8.095092] systemd[1]: Finished Set Up Additional Binary Formats. [ 8.171386] zram0: detected capacity change from 0 to 4031107072 [ 8.185178] systemd[1]: Finished Raise network interfaces. [ 8.216496] Adding 3936624k swap on /dev/zram0. Priority:5 extents:1 across:3936624k SS [ 8.229367] zram: Added device: zram1 [ 8.372874] zram1: detected capacity change from 0 to 52428800 [ 8.418493] systemd[1]: Finished Armbian ZRAM config. [ 8.423537] systemd[1]: Starting Armbian memory supported logging... [ 8.472140] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard [ 8.799932] vendor storage:20190527 ret = -1 [ 8.913353] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 8.913530] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 8.913652] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 10.049416] systemd[1]: Finished Armbian memory supported logging. [ 10.058161] systemd[1]: Starting Journal Service... [ 10.203671] systemd[1]: Started Journal Service. [ 10.222931] systemd-journald[734]: Received client request to flush runtime journal. ### armbian-release: # PLEASE DO NOT EDIT THIS FILE BOARD=orangepi5 BOARD_NAME="Orange Pi 5" BOARDFAMILY=rockchip-rk3588 BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=bfc8271 VERSION=23.08.0-trunk LINUXFAMILY=rk35xx ARCH=arm64 IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm64 KERNEL_IMAGE_TYPE=Image FORCE_BOOTSCRIPT_UPDATE= VENDOR=Armbian REVISION=23.08.0-trunk BOOTSCRIPT_FORCE_UPDATE="no" BOOTSCRIPT_DST="boot.cmd" BRANCH=legacy ### boot environment: verbosity=1 bootlogo=true overlay_prefix=rockchip-rk3588 fdtfile=rockchip/rk3588s-orangepi-5.dtb rootdev=UUID=329a3cf7-a8ce-4ea6-a3ef-c2128bda1678 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u ### lsusb: Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 002: ID 046d:c539 Logitech, Inc. USB Receiver Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub ### lscpu: Architecture: aarch64 CPU op-mode(s): 32-bit, 64-bit Byte Order: Little Endian CPU(s): 8 On-line CPU(s) list: 0-7 Vendor ID: ARM Model name: Cortex-A55 Model: 0 Thread(s) per core: 1 Core(s) per socket: 4 Socket(s): 1 Stepping: r2p0 CPU max MHz: 1800,0000 CPU min MHz: 408,0000 BogoMIPS: 48.00 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp Model name: Cortex-A76 Model: 0 Thread(s) per core: 1 Core(s) per socket: 2 Socket(s): 2 Stepping: r4p0 CPU max MHz: 2256,0000 CPU min MHz: 408,0000 BogoMIPS: 48.00 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp L1d cache: 384 KiB (8 instances) L1i cache: 384 KiB (8 instances) L2 cache: 2,5 MiB (8 instances) L3 cache: 3 MiB (1 instance) Vulnerability L1tf: Not affected Vulnerability Mds: Not affected Vulnerability Meltdown: Not affected Vulnerability Mmio stale data: Not affected Vulnerability Retbleed: Not affected Vulnerability Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl Vulnerability Spectre v1: Mitigation; __user pointer sanitization Vulnerability Spectre v2: Vulnerable: Unprivileged eBPF enabled Vulnerability Srbds: Not affected Vulnerability Tsx async abort: Not affected Vulnerability itlb multihit: Not affected ### cpuinfo: processor : 0 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 1 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 2 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 3 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 4 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 processor : 5 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 processor : 6 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 processor : 7 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 Serial : 2eae2cb9d903d20e ### meminfo: MemTotal: 7873256 kB MemFree: 7552588 kB MemAvailable: 7583308 kB Buffers: 15040 kB Cached: 88576 kB SwapCached: 0 kB Active: 26768 kB Inactive: 117180 kB Active(anon): 640 kB Inactive(anon): 69868 kB Active(file): 26128 kB Inactive(file): 47312 kB Unevictable: 19604 kB Mlocked: 0 kB SwapTotal: 3936624 kB SwapFree: 3936624 kB Dirty: 7192 kB Writeback: 0 kB AnonPages: 60456 kB Mapped: 29352 kB Shmem: 25968 kB KReclaimable: 37988 kB Slab: 79520 kB SReclaimable: 37988 kB SUnreclaim: 41532 kB KernelStack: 3760 kB PageTables: 3312 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 7873252 kB Committed_AS: 156044 kB VmallocTotal: 135290290112 kB VmallocUsed: 36672 kB VmallocChunk: 0 kB Percpu: 2656 kB CmaTotal: 262144 kB CmaAllocated: 4672 kB CmaReleased: 257472 kB CmaFree: 257472 kB HugePages_Total: 0 HugePages_Free: 0 HugePages_Rsvd: 0 HugePages_Surp: 0 Hugepagesize: 2048 kB Hugetlb: 0 kB ### virtual memory: vm.admin_reserve_kbytes = 8192 vm.block_dump = 0 vm.dirty_background_bytes = 0 vm.dirty_background_ratio = 10 vm.dirty_bytes = 0 vm.dirty_expire_centisecs = 3000 vm.dirty_ratio = 20 vm.dirtytime_expire_seconds = 43200 vm.dirty_writeback_centisecs = 500 vm.extra_free_kbytes = 0 vm.hugetlb_shm_group = 0 vm.laptop_mode = 0 vm.legacy_va_layout = 0 vm.lowmem_reserve_ratio = 256 256 32 0 vm.max_map_count = 65530 vm.min_free_kbytes = 11208 vm.mmap_min_addr = 32768 vm.mmap_rnd_bits = 18 vm.mmap_rnd_compat_bits = 11 vm.nr_hugepages = 0 vm.nr_overcommit_hugepages = 0 vm.oom_dump_tasks = 1 vm.oom_kill_allocating_task = 0 vm.overcommit_kbytes = 0 vm.overcommit_memory = 0 vm.overcommit_ratio = 50 vm.page-cluster = 0 vm.page_lock_unfairness = 5 vm.panic_on_oom = 0 vm.percpu_pagelist_fraction = 0 vm.stat_interval = 1 vm.swappiness = 100 vm.user_reserve_kbytes = 131072 vm.vfs_cache_pressure = 100 vm.watermark_boost_factor = 15000 vm.watermark_scale_factor = 10 ### ip addr: 1: lo: mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet XXX.XXX.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: eth0: mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether ae:d8:3f:81:fa:0b brd ff:ff:ff:ff:ff:ff ### partitions: major minor #blocks name 254 0 3936628 zram0 31 0 16384 mtdblock0 259 0 488386584 nvme0n1 259 1 262144 nvme0n1p1 259 2 483213312 nvme0n1p2 254 1 51200 zram1 ### df: tmpfs 769M 9,7M 760M 2% /run /dev/nvme0n1p2 454G 5,1G 444G 2% / tmpfs 3,8G 0 3,8G 0% /dev/shm tmpfs 5,0M 0 5,0M 0% /run/lock tmpfs 3,8G 4,0K 3,8G 1% /tmp /dev/nvme0n1p1 256M 106M 151M 42% /boot /dev/zram1 47M 7,3M 37M 17% /var/log ### lsblk: NAME FSTYPE SIZE MOUNTPOINT UUID mtdblock0 16M zram1 50M /var/log nvme0n1 465,8G ├─nvme0n1p1 vfat 256M /boot 1BD1-7F33 └─nvme0n1p2 ext4 460,8G / 329a3cf7-a8ce-4ea6-a3ef-c2128bda1678 ### zramctl: NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT /dev/zram1 zstd 50M 7,3M 1,6M 2M 8 /var/log /dev/zram0 lzo-rle 3,8G 4K 74B 12K 8 [SWAP] ### mtab: /dev/nvme0n1p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=936,iocharset=utf8,shortname=mixed,errors=remount-ro 0 0 /dev/nvme0n1p2 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0 /dev/nvme0n1p2 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0 ### Boot system health: Time CPU_cl0/CPU_cl1 load %cpu %sys %usr %nice %io %irq Tcpu C.St. 21:25:43 1800/2256 MHz 0.24 20% 12% 6% 0% 0% 0% 47,2 °C 0/7 21:25:43 1800/ 600 MHz 0.24 23% 6% 15% 0% 1% 0% 45,3 °C 0/7 21:25:43 1800/ 600 MHz 0.24 15% 2% 12% 0% 0% 0% 44,4 °C 0/7 21:25:44 1800/2256 MHz 0.24 23% 6% 16% 0% 0% 0% 44,4 °C 0/7 21:25:44 1800/2256 MHz 0.24 16% 1% 13% 0% 0% 0% 43,5 °C 0/7 ### Activated 1 lzo-rle zram swap devices with 3844MB each. ### Activated Armbian ramlog partition with zstd compression Pzt 07 Ağu 2023 21:57:05 +03 | Orange Pi 5 | 23.08.0-trunk | arm64 | aarch64 | 5.10.160-rk35xx ### dmesg: [ 1.765798] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [ 1.765822] Linux version 5.10.160-rk35xx (armbian@next) (aarch64-linux-gnu-gcc (Ubuntu 11.3.0-1ubuntu1~22.04) 11.3.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP Thu Jul 6 13:36:29 UTC 2023 [ 1.776632] Machine model: Orange Pi 5 [ 1.776814] efi: UEFI not found. [ 1.780468] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB [ 1.780487] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@00000000': base 0x0000000000000000, size 0 MiB [ 1.780578] Reserved memory: created CMA memory pool at 0x0000000010000000, size 256 MiB [ 1.780583] OF: reserved mem: initialized node cma, compatible id shared-dma-pool [ 1.931146] Zone ranges: [ 1.931153] DMA [mem 0x0000000000200000-0x00000000ffffffff] [ 1.931165] DMA32 empty [ 1.931171] Normal [mem 0x0000000100000000-0x00000001ffffffff] [ 1.931179] Movable zone start for each node [ 1.931183] Early memory node ranges [ 1.931188] node 0: [mem 0x0000000000200000-0x00000000efffffff] [ 1.931197] node 0: [mem 0x0000000100000000-0x00000001ffffffff] [ 1.931205] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff] [ 1.931212] On node 0 totalpages: 2031104 [ 1.931218] DMA zone: 15352 pages used for memmap [ 1.931222] DMA zone: 0 pages reserved [ 1.931227] DMA zone: 982528 pages, LIFO batch:63 [ 1.931232] Normal zone: 16384 pages used for memmap [ 1.931237] Normal zone: 1048576 pages, LIFO batch:63 [ 1.978209] psci: probing for conduit method from DT. [ 1.978221] psci: PSCIv1.1 detected in firmware. [ 1.978225] psci: Using standard PSCI v0.2 function IDs [ 1.978232] psci: MIGRATE_INFO_TYPE not supported. [ 1.978238] psci: SMC Calling Convention v1.2 [ 1.978659] percpu: Embedded 32 pages/cpu s93480 r8192 d29400 u131072 [ 1.978702] pcpu-alloc: s93480 r8192 d29400 u131072 alloc=32*4096 [ 1.978710] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7 [ 1.978853] Detected VIPT I-cache on CPU0 [ 1.978904] CPU features: detected: GIC system register CPU interface [ 1.978909] CPU features: detected: Virtualization Host Extensions [ 1.978919] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 1.978933] alternatives: patching kernel code [ 1.979318] Built 1 zonelists, mobility grouping on. Total pages: 1999368 [ 1.979328] Kernel command line: root=UUID=329a3cf7-a8ce-4ea6-a3ef-c2128bda1678 rootwait rootfstype=ext4 splash plymouth.ignore-serial-consoles console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart= usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 [ 1.980661] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) [ 1.981067] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 1.981074] mem auto-init: stack:off, heap alloc:off, heap free:off [ 1.987579] software IO TLB: mapped [mem 0x00000000ec000000-0x00000000f0000000] (64MB) [ 2.060773] Memory: 7589180K/8124416K available (16832K kernel code, 3506K rwdata, 6500K rodata, 6976K init, 639K bss, 273092K reserved, 262144K cma-reserved) [ 2.060932] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1 [ 2.060968] ftrace: allocating 64539 entries in 253 pages [ 2.171480] ftrace: allocated 253 pages with 7 groups [ 2.171788] rcu: Hierarchical RCU implementation. [ 2.171794] rcu: RCU event tracing is enabled. [ 2.171800] Rude variant of Tasks RCU enabled. [ 2.171803] Tracing variant of Tasks RCU enabled. [ 2.171810] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies. [ 2.177451] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 2.180280] GICv3: GIC: Using split EOI/Deactivate mode [ 2.180286] GICv3: 480 SPIs implemented [ 2.180291] GICv3: 0 Extended SPIs implemented [ 2.180331] GICv3: Distributor has no Range Selector support [ 2.180341] GICv3: 16 PPIs implemented [ 2.180387] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000 [ 2.180514] ITS [mem 0xfe640000-0xfe65ffff] [ 2.180571] ITS@0x00000000fe640000: allocated 8192 Devices @100200000 (indirect, esz 8, psz 64K, shr 0) [ 2.180600] ITS@0x00000000fe640000: allocated 32768 Interrupt Collections @100210000 (flat, esz 2, psz 64K, shr 0) [ 2.180610] ITS: using cache flushing for cmd queue [ 2.180652] ITS [mem 0xfe660000-0xfe67ffff] [ 2.180702] ITS@0x00000000fe660000: allocated 8192 Devices @100230000 (indirect, esz 8, psz 64K, shr 0) [ 2.180729] ITS@0x00000000fe660000: allocated 32768 Interrupt Collections @100240000 (flat, esz 2, psz 64K, shr 0) [ 2.180739] ITS: using cache flushing for cmd queue [ 2.180966] GICv3: using LPI property table @0x0000000100250000 [ 2.181096] GIC: using cache flushing for LPI property table [ 2.181107] GICv3: CPU0: using allocated LPI pending table @0x0000000100260000 [ 2.317458] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 2.317468] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 2.317478] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 2.318853] Console: colour dummy device 80x25 [ 2.318896] printk: console [tty1] enabled [ 2.318927] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000) [ 2.318938] pid_max: default: 32768 minimum: 301 [ 2.319049] LSM: Security Framework initializing [ 2.319120] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 2.319146] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 2.321403] rcu: Hierarchical SRCU implementation. [ 2.322376] Platform MSI: msi-controller@fe640000 domain created [ 2.322399] Platform MSI: msi-controller@fe660000 domain created [ 2.322784] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe640000 domain created [ 2.322809] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe660000 domain created [ 2.322997] EFI services will not be available. [ 2.323454] smp: Bringing up secondary CPUs ... [ 2.324173] Detected VIPT I-cache on CPU1 [ 2.324210] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000 [ 2.324229] GICv3: CPU1: using allocated LPI pending table @0x0000000100270000 [ 2.324274] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [ 2.325049] Detected VIPT I-cache on CPU2 [ 2.325080] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000 [ 2.325099] GICv3: CPU2: using allocated LPI pending table @0x0000000100280000 [ 2.325139] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [ 2.325869] Detected VIPT I-cache on CPU3 [ 2.325899] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000 [ 2.325917] GICv3: CPU3: using allocated LPI pending table @0x0000000100290000 [ 2.325955] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [ 2.326695] CPU features: detected: Spectre-v4 [ 2.326699] CPU features: detected: Spectre-BHB [ 2.326701] Detected PIPT I-cache on CPU4 [ 2.326716] GICv3: CPU4: found redistributor 400 region 0:0x00000000fe700000 [ 2.326727] GICv3: CPU4: using allocated LPI pending table @0x00000001002a0000 [ 2.326753] CPU4: Booted secondary processor 0x0000000400 [0x414fd0b0] [ 2.327471] Detected PIPT I-cache on CPU5 [ 2.327488] GICv3: CPU5: found redistributor 500 region 0:0x00000000fe720000 [ 2.327499] GICv3: CPU5: using allocated LPI pending table @0x00000001002b0000 [ 2.327525] CPU5: Booted secondary processor 0x0000000500 [0x414fd0b0] [ 2.328218] Detected PIPT I-cache on CPU6 [ 2.328235] GICv3: CPU6: found redistributor 600 region 0:0x00000000fe740000 [ 2.328245] GICv3: CPU6: using allocated LPI pending table @0x00000001002c0000 [ 2.328270] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b0] [ 2.328949] Detected PIPT I-cache on CPU7 [ 2.328965] GICv3: CPU7: found redistributor 700 region 0:0x00000000fe760000 [ 2.328976] GICv3: CPU7: using allocated LPI pending table @0x00000001002d0000 [ 2.329001] CPU7: Booted secondary processor 0x0000000700 [0x414fd0b0] [ 2.329080] smp: Brought up 1 node, 8 CPUs [ 2.329099] SMP: Total of 8 processors activated. [ 2.329105] CPU features: detected: Privileged Access Never [ 2.329109] CPU features: detected: User Access Override [ 2.329115] CPU features: detected: 32-bit EL0 Support [ 2.329119] CPU features: detected: Common not Private translations [ 2.329124] CPU features: detected: RAS Extension Support [ 2.329128] CPU features: detected: Data cache clean to the PoU not required for I/D coherence [ 2.329133] CPU features: detected: CRC32 instructions [ 2.329137] CPU features: detected: Speculative Store Bypassing Safe (SSBS) [ 2.329144] CPU features: detected: RCpc load-acquire (LDAPR) [ 2.329230] CPU: All CPU(s) started at EL2 [ 2.332450] devtmpfs: initialized [ 2.347256] Registered cp15_barrier emulation handler [ 2.347265] Registered setend emulation handler [ 2.347270] KASLR disabled due to lack of seed [ 2.347355] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns [ 2.347362] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 2.350122] pinctrl core: initialized pinctrl subsystem [ 2.350241] regulator-dummy: no parameters, enabled [ 2.350360] DMI not present or invalid. [ 2.350665] NET: Registered protocol family 16 [ 2.351752] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations [ 2.351875] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 2.351895] audit: initializing netlink subsys (disabled) [ 2.351986] audit: type=2000 audit(0.033:1): state=initialized audit_enabled=0 res=1 [ 2.352496] Registered FIQ tty driver [ 2.352646] thermal_sys: Registered thermal governor 'fair_share' [ 2.352649] thermal_sys: Registered thermal governor 'step_wise' [ 2.352651] thermal_sys: Registered thermal governor 'user_space' [ 2.352653] thermal_sys: Registered thermal governor 'power_allocator' [ 2.352975] cpuidle: using governor menu [ 2.353202] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 2.353338] ASID allocator initialised with 65536 entries [ 2.354809] ramoops: dmesg-0 0x20000@0x0000000000110000 [ 2.354832] ramoops: console 0x80000@0x0000000000130000 [ 2.354842] ramoops: pmsg 0x50000@0x00000000001b0000 [ 2.354887] printk: console [ramoops-1] enabled [ 2.354890] pstore: Registered ramoops as persistent store backend [ 2.354892] ramoops: using 0xf0000@0x110000, ecc: 0 [ 2.408870] rockchip-gpio fd8a0000.gpio: probed /pinctrl/gpio@fd8a0000 [ 2.409158] rockchip-gpio fec20000.gpio: probed /pinctrl/gpio@fec20000 [ 2.409390] rockchip-gpio fec30000.gpio: probed /pinctrl/gpio@fec30000 [ 2.409667] rockchip-gpio fec40000.gpio: probed /pinctrl/gpio@fec40000 [ 2.409935] rockchip-gpio fec50000.gpio: probed /pinctrl/gpio@fec50000 [ 2.409985] rockchip-pinctrl pinctrl: probed pinctrl [ 2.418683] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 2.418687] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 2.418690] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 2.418693] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 2.480779] raid6: neonx8 gen() 5361 MB/s [ 2.537523] raid6: neonx8 xor() 4163 MB/s [ 2.594272] raid6: neonx4 gen() 5496 MB/s [ 2.651021] raid6: neonx4 xor() 4175 MB/s [ 2.707772] raid6: neonx2 gen() 5041 MB/s [ 2.764520] raid6: neonx2 xor() 3940 MB/s [ 2.821268] raid6: neonx1 gen() 4213 MB/s [ 2.878021] raid6: neonx1 xor() 3247 MB/s [ 2.934783] raid6: int64x8 gen() 1297 MB/s [ 2.991518] raid6: int64x8 xor() 856 MB/s [ 3.048277] raid6: int64x4 gen() 1615 MB/s [ 3.105025] raid6: int64x4 xor() 866 MB/s [ 3.161771] raid6: int64x2 gen() 1886 MB/s [ 3.218518] raid6: int64x2 xor() 1299 MB/s [ 3.275266] raid6: int64x1 gen() 1969 MB/s [ 3.332025] raid6: int64x1 xor() 960 MB/s [ 3.332027] raid6: using algorithm neonx4 gen() 5496 MB/s [ 3.332030] raid6: .... xor() 4175 MB/s, rmw enabled [ 3.332032] raid6: using neon recovery algorithm [ 3.332650] fiq_debugger fiq_debugger.0: IRQ fiq not found [ 3.332658] fiq_debugger fiq_debugger.0: IRQ wakeup not found [ 3.332662] fiq_debugger_probe: could not install nmi irq handler [ 3.332747] printk: console [ttyFIQ0] enabled [ 3.332849] Registered fiq debugger ttyFIQ0 [ 3.333067] vcc12v_dcin: 12000 mV, enabled [ 3.333146] reg-fixed-voltage vcc12v-dcin: vcc12v_dcin supplying 12000000uV [ 3.333197] reg-fixed-voltage vcc5v0-sys: Looking up vin-supply from device tree [ 3.333202] vcc5v0_sys: supplied by vcc12v_dcin [ 3.333207] vcc12v_dcin: could not add device link regulator.2: -ENOENT [ 3.333223] vcc5v0_sys: 5000 mV, enabled [ 3.333291] reg-fixed-voltage vcc5v0-sys: vcc5v0_sys supplying 5000000uV [ 3.333339] reg-fixed-voltage vcc5v0-usbdcin: Looking up vin-supply from device tree [ 3.333343] vcc5v0_usbdcin: supplied by vcc12v_dcin [ 3.333346] vcc12v_dcin: could not add device link regulator.3: -ENOENT [ 3.333361] vcc5v0_usbdcin: 5000 mV, enabled [ 3.333427] reg-fixed-voltage vcc5v0-usbdcin: vcc5v0_usbdcin supplying 5000000uV [ 3.333473] reg-fixed-voltage vcc5v0-usb: Looking up vin-supply from device tree [ 3.333477] vcc5v0_usb: supplied by vcc5v0_usbdcin [ 3.333481] vcc5v0_usbdcin: could not add device link regulator.4: -ENOENT [ 3.333495] vcc5v0_usb: 5000 mV, enabled [ 3.333552] reg-fixed-voltage vcc5v0-usb: vcc5v0_usb supplying 5000000uV [ 3.333657] vbus5v0_typec: 5000 mV, disabled [ 3.333708] reg-fixed-voltage vbus5v0-typec: Looking up vin-supply from device tree [ 3.333712] vbus5v0_typec: supplied by vcc5v0_usb [ 3.333745] reg-fixed-voltage vbus5v0-typec: vbus5v0_typec supplying 5000000uV [ 3.333797] reg-fixed-voltage vcc-1v1-nldo-s3: Looking up vin-supply from device tree [ 3.333801] vcc_1v1_nldo_s3: supplied by vcc5v0_sys [ 3.333804] vcc5v0_sys: could not add device link regulator.6: -ENOENT [ 3.333821] vcc_1v1_nldo_s3: 1100 mV, enabled [ 3.333887] reg-fixed-voltage vcc-1v1-nldo-s3: vcc_1v1_nldo_s3 supplying 1100000uV [ 3.333940] reg-fixed-voltage vcc3v3-pcie2x1l2: Looking up vin-supply from device tree [ 3.333944] vcc3v3_pcie2x1l2: supplied by vcc5v0_sys [ 3.333947] vcc5v0_sys: could not add device link regulator.7: -ENOENT [ 3.389699] vcc3v3_pcie2x1l2: 1800 mV, enabled [ 3.389767] reg-fixed-voltage vcc3v3-pcie2x1l2: vcc3v3_pcie2x1l2 supplying 1800000uV [ 3.390054] iommu: Default domain type: Translated [ 3.390488] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vdpu-supply from device tree [ 3.390509] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vdpu-supply property in node /power-management@fd8d8000/power-controller failed [ 3.390778] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga30-supply from device tree [ 3.390796] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga30-supply property in node /power-management@fd8d8000/power-controller failed [ 3.390976] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga31-supply from device tree [ 3.390993] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga31-supply property in node /power-management@fd8d8000/power-controller failed [ 3.392305] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc0-supply from device tree [ 3.392324] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc0-supply property in node /power-management@fd8d8000/power-controller failed [ 3.392478] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vcodec-supply from device tree [ 3.392495] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vcodec-supply property in node /power-management@fd8d8000/power-controller failed [ 3.392595] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc1-supply from device tree [ 3.392612] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc1-supply property in node /power-management@fd8d8000/power-controller failed [ 3.392891] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec0-supply from device tree [ 3.392909] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec0-supply property in node /power-management@fd8d8000/power-controller failed [ 3.393201] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec1-supply from device tree [ 3.393218] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec1-supply property in node /power-management@fd8d8000/power-controller failed [ 3.393437] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vi-supply from device tree [ 3.393454] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vi-supply property in node /power-management@fd8d8000/power-controller failed [ 3.393687] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up isp1-supply from device tree [ 3.393704] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up isp1-supply property in node /power-management@fd8d8000/power-controller failed [ 3.394405] SCSI subsystem initialized [ 3.394420] libata version 3.00 loaded. [ 3.394493] usbcore: registered new interface driver usbfs [ 3.394509] usbcore: registered new interface driver hub [ 3.394525] usbcore: registered new device driver usb [ 3.394564] mc: Linux media interface: v0.10 [ 3.394576] videodev: Linux video capture interface: v2.00 [ 3.394604] pps_core: LinuxPPS API ver. 1 registered [ 3.394606] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [ 3.394612] PTP clock support registered [ 3.394881] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled. [ 3.394913] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0 [ 3.396120] Advanced Linux Sound Architecture Driver Initialized. [ 3.396384] Bluetooth: Core ver 2.22 [ 3.396399] NET: Registered protocol family 31 [ 3.396401] Bluetooth: HCI device and connection manager initialized [ 3.396405] Bluetooth: HCI socket layer initialized [ 3.396409] Bluetooth: L2CAP socket layer initialized [ 3.396415] Bluetooth: SCO socket layer initialized [ 3.396428] NetLabel: Initializing [ 3.396430] NetLabel: domain hash size = 128 [ 3.396432] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 3.396460] NetLabel: unlabeled traffic allowed by default [ 3.397788] rockchip-cpuinfo cpuinfo: SoC : 35881000 [ 3.397793] rockchip-cpuinfo cpuinfo: Serial : 2eae2cb9d903d20e [ 3.398237] clocksource: Switched to clocksource arch_sys_counter [ 3.815321] VFS: Disk quotas dquot_6.6.0 [ 3.815350] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 3.821022] NET: Registered protocol family 2 [ 3.821148] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 3.823175] tcp_listen_portaddr_hash hash table entries: 4096 (order: 5, 163840 bytes, linear) [ 3.823274] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 3.823621] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear) [ 3.824424] TCP: Hash tables configured (established 65536 bind 65536) [ 3.824533] MPTCP token hash table entries: 8192 (order: 6, 393216 bytes, linear) [ 3.824633] UDP hash table entries: 4096 (order: 6, 393216 bytes, linear) [ 3.824789] UDP-Lite hash table entries: 4096 (order: 6, 393216 bytes, linear) [ 3.825021] NET: Registered protocol family 1 [ 3.825388] RPC: Registered named UNIX socket transport module. [ 3.825390] RPC: Registered udp transport module. [ 3.825392] RPC: Registered tcp transport module. [ 3.825394] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 3.825834] PCI: CLS 0 bytes, default 64 [ 3.826129] Trying to unpack rootfs image as initramfs... [ 4.221648] Freeing initrd memory: 14956K [ 4.222336] rockchip-thermal fec00000.tsadc: Missing rockchip,grf property [ 4.222974] rockchip-thermal fec00000.tsadc: tsadc is probed successfully! [ 4.223894] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 4.224497] kvm [1]: IPA Size Limit: 40 bits [ 4.224508] kvm [1]: GICv3: no GICV resource entry [ 4.224511] kvm [1]: disabling GICv2 emulation [ 4.224513] kvm [1]: GIC system register CPU interface enabled [ 4.224665] kvm [1]: vgic interrupt IRQ9 [ 4.224847] kvm [1]: VHE mode initialized successfully [ 4.227720] Initialise system trusted keyrings [ 4.227845] workingset: timestamp_bits=46 max_order=21 bucket_order=0 [ 4.230882] NFS: Registering the id_resolver key type [ 4.230901] Key type id_resolver registered [ 4.230903] Key type id_legacy registered [ 4.230939] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 4.230942] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 4.230954] ntfs: driver 2.1.32 [Flags: R/W]. [ 4.252633] NET: Registered protocol family 38 [ 4.252638] xor: measuring software checksum speed [ 4.254259] 8regs : 6105 MB/sec [ 4.255480] 32regs : 8117 MB/sec [ 4.256509] arm64_neon : 9872 MB/sec [ 4.256512] xor: using function: arm64_neon (9872 MB/sec) [ 4.256517] Key type asymmetric registered [ 4.256519] Asymmetric key parser 'x509' registered [ 4.256535] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242) [ 4.256649] io scheduler mq-deadline registered [ 4.256653] io scheduler kyber registered [ 4.258466] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up phy-supply from device tree [ 4.258476] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up phy-supply property in node /syscon@fd5d0000/usb2-phy@0/otg-port failed [ 4.258525] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up vbus-supply from device tree [ 4.258532] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up vbus-supply property in node /syscon@fd5d0000/usb2-phy@0/otg-port failed [ 4.259858] phy phy-fd5d8000.syscon:usb2-phy@8000.1: Looking up phy-supply from device tree [ 4.259866] phy phy-fd5d8000.syscon:usb2-phy@8000.1: Looking up phy-supply property in node /syscon@fd5d8000/usb2-phy@8000/host-port failed [ 4.261045] phy phy-fd5dc000.syscon:usb2-phy@c000.2: Looking up phy-supply from device tree [ 4.261053] phy phy-fd5dc000.syscon:usb2-phy@c000.2: Looking up phy-supply property in node /syscon@fd5dc000/usb2-phy@c000/host-port failed [ 4.262979] phy phy-fee00000.phy.3: Looking up phy-supply from device tree [ 4.262985] phy phy-fee00000.phy.3: Looking up phy-supply property in node /phy@fee00000 failed [ 4.263136] phy phy-fee20000.phy.4: Looking up phy-supply from device tree [ 4.263142] phy phy-fee20000.phy.4: Looking up phy-supply property in node /phy@fee20000 failed [ 4.263633] phy phy-feda0000.phy.5: Looking up phy-supply from device tree [ 4.263639] phy phy-feda0000.phy.5: Looking up phy-supply property in node /phy@feda0000 failed [ 4.263772] phy phy-fedb0000.phy.6: Looking up phy-supply from device tree [ 4.263777] phy phy-fedb0000.phy.6: Looking up phy-supply property in node /phy@fedb0000 failed [ 4.264148] phy phy-fed60000.hdmiphy.7: Looking up phy-supply from device tree [ 4.264154] phy phy-fed60000.hdmiphy.7: Looking up phy-supply property in node /hdmiphy@fed60000 failed [ 4.264937] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy init success [ 4.265879] phy phy-fed80000.phy.8: Looking up phy-supply from device tree [ 4.265886] phy phy-fed80000.phy.8: Looking up phy-supply property in node /phy@fed80000/dp-port failed [ 4.265921] phy phy-fed80000.phy.9: Looking up phy-supply from device tree [ 4.265926] phy phy-fed80000.phy.9: Looking up phy-supply property in node /phy@fed80000/u3-port failed [ 4.267380] rk-pcie fe190000.pcie: invalid prsnt-gpios property in node [ 4.267391] rk-pcie fe190000.pcie: Looking up vpcie3v3-supply from device tree [ 4.267625] pwm-backlight backlight: Looking up power-supply from device tree [ 4.267631] pwm-backlight backlight: Looking up power-supply property in node /backlight failed [ 4.267636] pwm-backlight backlight: supply power not found, using dummy regulator [ 4.267902] pwm-backlight backlight_1: Looking up power-supply from device tree [ 4.267909] pwm-backlight backlight_1: Looking up power-supply property in node /backlight_1 failed [ 4.267913] pwm-backlight backlight_1: supply power not found, using dummy regulator [ 4.268087] rk-pcie fe190000.pcie: IRQ msi not found [ 4.268094] rk-pcie fe190000.pcie: use outband MSI support [ 4.268100] rk-pcie fe190000.pcie: Missing *config* reg space [ 4.268116] rk-pcie fe190000.pcie: host bridge /pcie@fe190000 ranges: [ 4.268149] rk-pcie fe190000.pcie: err 0x00f4000000..0x00f40fffff -> 0x00f4000000 [ 4.268172] rk-pcie fe190000.pcie: IO 0x00f4100000..0x00f41fffff -> 0x00f4100000 [ 4.268201] rk-pcie fe190000.pcie: MEM 0x00f4200000..0x00f4ffffff -> 0x00f4200000 [ 4.268210] iep: Module initialized. [ 4.268215] rk-pcie fe190000.pcie: MEM 0x0a00000000..0x0a3fffffff -> 0x0a00000000 [ 4.268268] rk-pcie fe190000.pcie: Missing *config* reg space [ 4.268271] mpp_service mpp-srv: unknown mpp version for missing VCS info [ 4.268274] mpp_service mpp-srv: probe start [ 4.268305] rk-pcie fe190000.pcie: invalid resource [ 4.270264] mpp_vdpu2 fdb50400.vdpu: Adding to iommu group 1 [ 4.270485] mpp_vdpu2 fdb50400.vdpu: probe device [ 4.270606] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0 [ 4.270614] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0 [ 4.270755] mpp_vdpu2 fdb50400.vdpu: probing finish [ 4.270967] mpp_vepu2 jpege-ccu: probing start [ 4.270970] mpp_vepu2 jpege-ccu: probing finish [ 4.271079] mpp_vepu2 fdb50000.vepu: Adding to iommu group 1 [ 4.271162] mpp_vepu2 fdb50000.vepu: probing start [ 4.271257] mpp_vepu2 fdb50000.vepu: reset_group->rw_sem_on=0 [ 4.271261] mpp_vepu2 fdb50000.vepu: reset_group->rw_sem_on=0 [ 4.271404] mpp_vepu2 fdb50000.vepu: probing finish [ 4.271522] mpp_vepu2 fdba0000.jpege-core: Adding to iommu group 5 [ 4.271674] mpp_vepu2 fdba0000.jpege-core: probing start [ 4.271794] mpp_vepu2 fdba0000.jpege-core: attach ccu success [ 4.271940] mpp_vepu2 fdba0000.jpege-core: probing finish [ 4.272049] mpp_vepu2 fdba4000.jpege-core: Adding to iommu group 6 [ 4.272185] mpp_vepu2 fdba4000.jpege-core: probing start [ 4.272295] mpp_vepu2 fdba4000.jpege-core: attach ccu success [ 4.272439] mpp_vepu2 fdba4000.jpege-core: probing finish [ 4.272545] mpp_vepu2 fdba8000.jpege-core: Adding to iommu group 7 [ 4.272681] mpp_vepu2 fdba8000.jpege-core: probing start [ 4.272784] mpp_vepu2 fdba8000.jpege-core: attach ccu success [ 4.272925] mpp_vepu2 fdba8000.jpege-core: probing finish [ 4.273021] mpp_vepu2 fdbac000.jpege-core: Adding to iommu group 8 [ 4.273156] mpp_vepu2 fdbac000.jpege-core: probing start [ 4.273260] mpp_vepu2 fdbac000.jpege-core: attach ccu success [ 4.273406] mpp_vepu2 fdbac000.jpege-core: probing finish [ 4.273680] mpp-iep2 fdbb0000.iep: Adding to iommu group 9 [ 4.273821] mpp-iep2 fdbb0000.iep: probe device [ 4.273946] mpp-iep2 fdbb0000.iep: allocate roi buffer failed [ 4.274087] mpp-iep2 fdbb0000.iep: probing finish [ 4.274306] mpp_jpgdec fdb90000.jpegd: Adding to iommu group 4 [ 4.274512] mpp_jpgdec fdb90000.jpegd: probe device [ 4.274772] mpp_jpgdec fdb90000.jpegd: probing finish [ 4.275149] mpp_rkvdec2 fdc30000.rkvdec-ccu: rkvdec-ccu, probing start [ 4.275210] mpp_rkvdec2 fdc30000.rkvdec-ccu: ccu-mode: 1 [ 4.275213] mpp_rkvdec2 fdc30000.rkvdec-ccu: probing finish [ 4.275310] mpp_rkvdec2 fdc38100.rkvdec-core: Adding to iommu group 12 [ 4.275571] mpp_rkvdec2 fdc38100.rkvdec-core: rkvdec-core, probing start [ 4.275693] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found! [ 4.275696] rkvdec2_init:1022: No niu aclk reset resource define [ 4.275700] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found! [ 4.275702] rkvdec2_init:1025: No niu hclk reset resource define [ 4.275718] mpp_rkvdec2 fdc38100.rkvdec-core: Looking up vdec-supply from device tree [ 4.275724] mpp_rkvdec2 fdc38100.rkvdec-core: Looking up vdec-supply property in node /rkvdec-core@fdc38000 failed [ 4.275730] mpp_rkvdec2 fdc38100.rkvdec-core: no regulator, devfreq is disabled [ 4.275785] mpp_rkvdec2 fdc38100.rkvdec-core: core_mask=00010001 [ 4.275788] mpp_rkvdec2 fdc38100.rkvdec-core: attach ccu as core 0 [ 4.275936] mpp_rkvdec2 fdc38100.rkvdec-core: sram_start 0x00000000ff001000 [ 4.275939] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_iova 0x00000000fff00000 [ 4.275941] mpp_rkvdec2 fdc38100.rkvdec-core: sram_size 491520 [ 4.275944] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_size 1048576 [ 4.275948] mpp_rkvdec2 fdc38100.rkvdec-core: min_width 512 [ 4.275952] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_info_count 20 [ 4.275955] mpp_rkvdec2 fdc38100.rkvdec-core: [136, 24576] [ 4.275957] mpp_rkvdec2 fdc38100.rkvdec-core: [137, 49152] [ 4.275960] mpp_rkvdec2 fdc38100.rkvdec-core: [141, 90112] [ 4.275963] mpp_rkvdec2 fdc38100.rkvdec-core: [140, 49152] [ 4.275966] mpp_rkvdec2 fdc38100.rkvdec-core: [139, 180224] [ 4.275968] mpp_rkvdec2 fdc38100.rkvdec-core: [133, 49152] [ 4.275971] mpp_rkvdec2 fdc38100.rkvdec-core: [134, 8192] [ 4.275973] mpp_rkvdec2 fdc38100.rkvdec-core: [135, 4352] [ 4.275976] mpp_rkvdec2 fdc38100.rkvdec-core: [138, 13056] [ 4.275978] mpp_rkvdec2 fdc38100.rkvdec-core: [142, 291584] [ 4.276014] mpp_rkvdec2 fdc38100.rkvdec-core: probing finish [ 4.276105] mpp_rkvdec2 fdc48100.rkvdec-core: Adding to iommu group 13 [ 4.276336] mpp_rkvdec2 fdc48100.rkvdec-core: rkvdec-core, probing start [ 4.276460] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found! [ 4.276463] rkvdec2_init:1022: No niu aclk reset resource define [ 4.276466] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found! [ 4.276468] rkvdec2_init:1025: No niu hclk reset resource define [ 4.276485] mpp_rkvdec2 fdc48100.rkvdec-core: Looking up vdec-supply from device tree [ 4.276490] mpp_rkvdec2 fdc48100.rkvdec-core: Looking up vdec-supply property in node /rkvdec-core@fdc48000 failed [ 4.276496] mpp_rkvdec2 fdc48100.rkvdec-core: no regulator, devfreq is disabled [ 4.276538] mpp_rkvdec2 fdc48100.rkvdec-core: core_mask=00020002 [ 4.276555] mpp_rkvdec2 fdc48100.rkvdec-core: attach ccu as core 1 [ 4.276733] mpp_rkvdec2 fdc48100.rkvdec-core: sram_start 0x00000000ff079000 [ 4.276736] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_iova 0x00000000ffe00000 [ 4.276739] mpp_rkvdec2 fdc48100.rkvdec-core: sram_size 487424 [ 4.276741] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_size 1048576 [ 4.276745] mpp_rkvdec2 fdc48100.rkvdec-core: min_width 512 [ 4.276750] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_info_count 20 [ 4.276752] mpp_rkvdec2 fdc48100.rkvdec-core: [136, 24576] [ 4.276755] mpp_rkvdec2 fdc48100.rkvdec-core: [137, 49152] [ 4.276757] mpp_rkvdec2 fdc48100.rkvdec-core: [141, 90112] [ 4.276760] mpp_rkvdec2 fdc48100.rkvdec-core: [140, 49152] [ 4.276762] mpp_rkvdec2 fdc48100.rkvdec-core: [139, 180224] [ 4.276765] mpp_rkvdec2 fdc48100.rkvdec-core: [133, 49152] [ 4.276768] mpp_rkvdec2 fdc48100.rkvdec-core: [134, 8192] [ 4.276770] mpp_rkvdec2 fdc48100.rkvdec-core: [135, 4352] [ 4.276773] mpp_rkvdec2 fdc48100.rkvdec-core: [138, 13056] [ 4.276776] mpp_rkvdec2 fdc48100.rkvdec-core: [142, 291584] [ 4.276806] mpp_rkvdec2 fdc48100.rkvdec-core: probing finish [ 4.276996] mpp_rkvenc2 rkvenc-ccu: probing start [ 4.277000] mpp_rkvenc2 rkvenc-ccu: probing finish [ 4.277116] mpp_rkvenc2 fdbd0000.rkvenc-core: Adding to iommu group 10 [ 4.277294] mpp_rkvenc2 fdbd0000.rkvenc-core: probing start [ 4.277445] mpp_rkvenc2 fdbd0000.rkvenc-core: Looking up venc-supply from device tree [ 4.277450] mpp_rkvenc2 fdbd0000.rkvenc-core: Looking up venc-supply property in node /rkvenc-core@fdbd0000 failed [ 4.277457] mpp_rkvenc2 fdbd0000.rkvenc-core: dev_pm_opp_set_regulators: no regulator (venc) found: -19 [ 4.277473] rkvenc_init:1814: failed to add venc devfreq [ 4.277502] mpp_rkvenc2 fdbd0000.rkvenc-core: attach ccu as core 0 [ 4.277667] mpp_rkvenc2 fdbd0000.rkvenc-core: probing finish [ 4.277751] mpp_rkvenc2 fdbe0000.rkvenc-core: Adding to iommu group 11 [ 4.277934] mpp_rkvenc2 fdbe0000.rkvenc-core: probing start [ 4.278066] mpp_rkvenc2 fdbe0000.rkvenc-core: Looking up venc-supply from device tree [ 4.278072] mpp_rkvenc2 fdbe0000.rkvenc-core: Looking up venc-supply property in node /rkvenc-core@fdbe0000 failed [ 4.278078] mpp_rkvenc2 fdbe0000.rkvenc-core: dev_pm_opp_set_regulators: no regulator (venc) found: -19 [ 4.278091] rkvenc_init:1814: failed to add venc devfreq [ 4.278141] mpp_rkvenc2 fdbe0000.rkvenc-core: attach ccu as core 1 [ 4.278306] mpp_rkvenc2 fdbe0000.rkvenc-core: probing finish [ 4.278587] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up av1-supply from device tree [ 4.278612] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up av1-supply property in node /power-management@fd8d8000/power-controller failed [ 4.278915] mpp_av1dec: Adding child /av1d@fdc70000 [ 4.278993] mpp_av1dec: register device av1d-master [ 4.279024] mpp_av1dec av1d-master: av1_iommu_of_xlate,784 [ 4.279043] av1_iommu_probe_device,736, consumer : av1d-master, supplier : fdca0000.iommu [ 4.279078] mpp_av1dec av1d-master: Adding to iommu group 18 [ 4.279334] mpp_av1dec av1d-master: probing start [ 4.279609] mpp_av1dec av1d-master: probing finish [ 4.279651] mpp_service mpp-srv: probe success [ 4.290750] dma-pl330 fea10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 4.290757] dma-pl330 fea10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 4.291791] dma-pl330 fea30000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 4.291797] dma-pl330 fea30000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 4.292775] dma-pl330 fed10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 4.292780] dma-pl330 fed10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 4.293274] rockchip-pvtm fda40000.pvtm: pvtm@0 probed [ 4.293337] rockchip-pvtm fda50000.pvtm: pvtm@1 probed [ 4.293398] rockchip-pvtm fda60000.pvtm: pvtm@2 probed [ 4.293454] rockchip-pvtm fdaf0000.pvtm: pvtm@3 probed [ 4.293508] rockchip-pvtm fdb30000.pvtm: pvtm@4 probed [ 4.294093] rockchip-system-monitor rockchip-system-monitor: system monitor probe [ 4.294958] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [ 4.295468] febc0000.serial: ttyS9 at MMIO 0xfebc0000 (irq = 101, base_baud = 1500000) is a 16550A [ 4.296713] random: crng init done [ 4.296800] led_vk2c21_init ============================================= [ 4.297774] rockchip-vop2 fdd90000.vop: Adding to iommu group 17 [ 4.306259] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x5, primary plane phy id: 0 [ 4.306266] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp1 assign plane mask: 0xa, primary plane phy id: 1 [ 4.306272] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x140, primary plane phy id: 6 [ 4.306278] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp3 assign plane mask: 0x280, primary plane phy id: 7 [ 4.306374] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart0-win0 as cursor plane for vp0 [ 4.306463] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart1-win0 as cursor plane for vp1 [ 4.306548] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart2-win0 as cursor plane for vp2 [ 4.306630] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart3-win0 as cursor plane for vp3 [ 4.306655] [drm] failed to init overlay plane Cluster0-win1 [ 4.306657] [drm] failed to init overlay plane Cluster1-win1 [ 4.306659] [drm] failed to init overlay plane Cluster2-win1 [ 4.306662] [drm] failed to init overlay plane Cluster3-win1 [ 4.318283] rockchip-drm display-subsystem: bound fdd90000.vop (ops 0xffff8000091b2620) [ 4.319235] dwhdmi-rockchip fde80000.hdmi: registered ddc I2C bus driver [ 4.319439] rockchip-drm display-subsystem: bound fde80000.hdmi (ops 0xffff8000091c0798) [ 4.319516] rockchip-drm display-subsystem: bound fde50000.dp (ops 0xffff8000091c3278) [ 4.320154] rockchip-drm display-subsystem: failed to parse loader memory [ 4.476073] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x2 [ 4.540066] dwhdmi-rockchip fde80000.hdmi: use tmds mode [ 4.540108] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] Update mode to 1920x1080p60, type: 11(if:800) for vp0 dclk: 148500000 [ 4.540275] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] dclk_out0 div: 0 dclk_core0 div: 2 [ 4.540292] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx_ropll_cmn_config bus_width:16a8c8 rate:1485000 [ 4.540570] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy pll locked! [ 4.540576] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] set dclk_vop0 to 148500000, get 148500000 [ 4.540599] dwhdmi-rockchip fde80000.hdmi: final tmdsclk = 148500000 [ 4.540630] dwhdmi-rockchip fde80000.hdmi: don't use dsc mode [ 4.540633] dwhdmi-rockchip fde80000.hdmi: dw hdmi qp use tmds mode [ 4.540639] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: bus_width:0x16a8c8,bit_rate:1485000 [ 4.540833] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy lane locked! [ 4.558272] rk-pcie fe190000.pcie: PCIe Link up, LTSSM is 0x30011 [ 4.558452] rk-pcie fe190000.pcie: PCI host bridge to bus 0004:40 [ 4.558463] pci_bus 0004:40: root bus resource [bus 40-4f] [ 4.558472] pci_bus 0004:40: root bus resource [??? 0xf4000000-0xf40fffff flags 0x0] [ 4.558481] pci_bus 0004:40: root bus resource [io 0x0000-0xfffff] (bus address [0xf4100000-0xf41fffff]) [ 4.558488] pci_bus 0004:40: root bus resource [mem 0xf4200000-0xf4ffffff] [ 4.558495] pci_bus 0004:40: root bus resource [mem 0xa00000000-0xa3fffffff pref] [ 4.558540] pci 0004:40:00.0: [1d87:3588] type 01 class 0x060400 [ 4.558569] pci 0004:40:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref] [ 4.558648] pci 0004:40:00.0: supports D1 D2 [ 4.558655] pci 0004:40:00.0: PME# supported from D0 D1 D3hot [ 4.571359] pci 0004:40:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 4.571647] pci 0004:41:00.0: [144d:a804] type 00 class 0x010802 [ 4.571746] pci 0004:41:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit] [ 4.572484] pci 0004:41:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x1 link at 0004:40:00.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link) [ 4.593884] pci_bus 0004:41: busn_res: [bus 41-4f] end is updated to 41 [ 4.593913] pci 0004:40:00.0: BAR 8: assigned [mem 0xf4200000-0xf42fffff] [ 4.593924] pci 0004:40:00.0: BAR 6: assigned [mem 0xf4300000-0xf430ffff pref] [ 4.593938] pci 0004:41:00.0: BAR 0: assigned [mem 0xf4200000-0xf4203fff 64bit] [ 4.593978] pci 0004:40:00.0: PCI bridge to [bus 41] [ 4.593988] pci 0004:40:00.0: bridge window [mem 0xf4200000-0xf42fffff] [ 4.597346] pcieport 0004:40:00.0: PME: Signaling with IRQ 125 [ 4.623967] Console: switching to colour frame buffer device 240x67 [ 4.787908] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device [ 4.789119] [drm] Initialized rockchip 3.0.0 20140818 for display-subsystem on minor 0 [ 4.803980] brd: module loaded [ 4.813064] loop: module loaded [ 4.813599] zram: Added device: zram0 [ 4.813956] lkdtm: No crash points registered, enable through debugfs [ 4.814210] system_heap: orders[0] = 6 [ 4.814217] system_heap: orders[1] = 4 [ 4.814223] system_heap: orders[2] = 0 [ 4.816187] nvme nvme0: pci function 0004:41:00.0 [ 4.816255] nvme 0004:41:00.0: enabling device (0000 -> 0002) [ 4.819701] rockchip-spi feb20000.spi: no high_speed pinctrl state [ 4.823250] rk806 spi2.0: chip id: RK806,ver:0x2, 0x1 [ 4.823473] rk806 spi2.0: ON: 0x80 OFF:0x80 [ 4.826803] rk806-regulator rk806-regulator.6.auto: Looking up vcc1-supply from device tree [ 4.826821] vdd_gpu_s0: supplied by vcc5v0_sys [ 4.826834] vcc5v0_sys: could not add device link regulator.8: -ENOENT [ 4.827760] vdd_gpu_s0: 550 <--> 950 mV at 750 mV, enabled [ 4.828609] rk806-regulator rk806-regulator.6.auto: Looking up vcc2-supply from device tree [ 4.828625] vdd_cpu_lit_s0: supplied by vcc5v0_sys [ 4.828638] vcc5v0_sys: could not add device link regulator.9: -ENOENT [ 4.829123] vdd_cpu_lit_s0: 550 <--> 950 mV at 750 mV, enabled [ 4.830012] rk806-regulator rk806-regulator.6.auto: Looking up vcc3-supply from device tree [ 4.830020] vdd_log_s0: supplied by vcc5v0_sys [ 4.830026] vcc5v0_sys: could not add device link regulator.10: -ENOENT [ 4.830256] vdd_log_s0: 675 <--> 750 mV at 750 mV, enabled [ 4.830734] rk806-regulator rk806-regulator.6.auto: Looking up vcc4-supply from device tree [ 4.830741] vdd_vdenc_s0: supplied by vcc5v0_sys [ 4.830746] vcc5v0_sys: could not add device link regulator.11: -ENOENT [ 4.830988] vdd_vdenc_s0: 550 <--> 950 mV at 750 mV, enabled [ 4.831530] rk806-regulator rk806-regulator.6.auto: Looking up vcc5-supply from device tree [ 4.831536] vdd_ddr_s0: supplied by vcc5v0_sys [ 4.831544] vcc5v0_sys: could not add device link regulator.12: -ENOENT [ 4.831791] vdd_ddr_s0: 675 <--> 900 mV at 850 mV, enabled [ 4.832005] rk806-regulator rk806-regulator.6.auto: Looking up vcc6-supply from device tree [ 4.832011] vdd2_ddr_s3: supplied by vcc5v0_sys [ 4.832015] vcc5v0_sys: could not add device link regulator.13: -ENOENT [ 4.832297] vdd2_ddr_s3: at 500 mV, enabled [ 4.832661] rk806-regulator rk806-regulator.6.auto: Looking up vcc7-supply from device tree [ 4.832668] vdd_2v0_pldo_s3: supplied by vcc5v0_sys [ 4.832672] vcc5v0_sys: could not add device link regulator.14: -ENOENT [ 4.832902] vdd_2v0_pldo_s3: 2000 mV, enabled [ 4.833263] rk806-regulator rk806-regulator.6.auto: Looking up vcc8-supply from device tree [ 4.833269] vcc_3v3_s3: supplied by vcc5v0_sys [ 4.833274] vcc5v0_sys: could not add device link regulator.15: -ENOENT [ 4.833495] vcc_3v3_s3: 3300 mV, enabled [ 4.833826] rk806-regulator rk806-regulator.6.auto: Looking up vcc9-supply from device tree [ 4.833832] vddq_ddr_s0: supplied by vcc5v0_sys [ 4.833837] vcc5v0_sys: could not add device link regulator.16: -ENOENT [ 4.833844] nvme nvme0: 7/0/0 default/read/poll queues [ 4.834127] vddq_ddr_s0: at 500 mV, enabled [ 4.834497] rk806-regulator rk806-regulator.6.auto: Looking up vcc10-supply from device tree [ 4.834504] vcc_1v8_s3: supplied by vcc5v0_sys [ 4.834509] vcc5v0_sys: could not add device link regulator.17: -ENOENT [ 4.834733] vcc_1v8_s3: 1800 mV, enabled [ 4.835101] rk806-regulator rk806-regulator.6.auto: Looking up vcc13-supply from device tree [ 4.835243] vdd_0v75_s3: supplied by vcc_1v1_nldo_s3 [ 4.835249] vcc_1v1_nldo_s3: could not add device link regulator.18: -ENOENT [ 4.835488] vdd_0v75_s3: 750 mV, enabled [ 4.835910] rk806-regulator rk806-regulator.6.auto: Looking up vcc13-supply from device tree [ 4.835918] vdd_ddr_pll_s0: supplied by vcc_1v1_nldo_s3 [ 4.835923] vcc_1v1_nldo_s3: could not add device link regulator.19: -ENOENT [ 4.836136] vdd_ddr_pll_s0: 850 mV, enabled [ 4.836411] avdd_0v75_s0: Bringing 750000uV into 837500-837500uV [ 4.836535] avdd_0v75_s0: ramp_delay not set [ 4.836603] rk806-regulator rk806-regulator.6.auto: Looking up vcc13-supply from device tree [ 4.836609] avdd_0v75_s0: supplied by vcc_1v1_nldo_s3 [ 4.836614] vcc_1v1_nldo_s3: could not add device link regulator.20: -ENOENT [ 4.836824] avdd_0v75_s0: 837 mV, enabled [ 4.837167] rk806-regulator rk806-regulator.6.auto: Looking up vcc14-supply from device tree [ 4.837175] vdd_0v85_s0: supplied by vcc_1v1_nldo_s3 [ 4.837179] vcc_1v1_nldo_s3: could not add device link regulator.21: -ENOENT [ 4.837390] vdd_0v85_s0: 850 mV, enabled [ 4.837741] rk806-regulator rk806-regulator.6.auto: Looking up vcc14-supply from device tree [ 4.837748] vdd_0v75_s0: supplied by vcc_1v1_nldo_s3 [ 4.837753] vcc_1v1_nldo_s3: could not add device link regulator.22: -ENOENT [ 4.837965] vdd_0v75_s0: 750 mV, enabled [ 4.838387] rk806-regulator rk806-regulator.6.auto: Looking up vcc11-supply from device tree [ 4.838446] avcc_1v8_s0: supplied by vdd_2v0_pldo_s3 [ 4.838451] vdd_2v0_pldo_s3: could not add device link regulator.23: -ENOENT [ 4.838763] avcc_1v8_s0: 1800 mV, enabled [ 4.839182] rk806-regulator rk806-regulator.6.auto: Looking up vcc11-supply from device tree [ 4.839190] vcc_1v8_s0: supplied by vdd_2v0_pldo_s3 [ 4.839195] vdd_2v0_pldo_s3: could not add device link regulator.24: -ENOENT [ 4.839490] vcc_1v8_s0: 1800 mV, enabled [ 4.839844] rk806-regulator rk806-regulator.6.auto: Looking up vcc11-supply from device tree [ 4.839852] avdd_1v2_s0: supplied by vdd_2v0_pldo_s3 [ 4.839857] vdd_2v0_pldo_s3: could not add device link regulator.25: -ENOENT [ 4.840146] avdd_1v2_s0: 1200 mV, enabled [ 4.840502] rk806-regulator rk806-regulator.6.auto: Looking up vcc12-supply from device tree [ 4.840508] vcc_3v3_s0: supplied by vcc5v0_sys [ 4.840513] vcc5v0_sys: could not add device link regulator.26: -ENOENT [ 4.840756] vcc_3v3_s0: 3300 mV, enabled [ 4.841109] rk806-regulator rk806-regulator.6.auto: Looking up vcc12-supply from device tree [ 4.841116] vccio_sd_s0: supplied by vcc5v0_sys [ 4.841121] vcc5v0_sys: could not add device link regulator.27: -ENOENT [ 4.841341] vccio_sd_s0: 1800 <--> 3300 mV at 3300 mV, enabled [ 4.841712] rk806-regulator rk806-regulator.6.auto: Looking up vcca-supply from device tree [ 4.841718] pldo6_s3: supplied by vcc5v0_sys [ 4.841723] vcc5v0_sys: could not add device link regulator.28: -ENOENT [ 4.841954] pldo6_s3: 1800 mV, enabled [ 4.842335] rk806 spi2.0: no sleep-setting state [ 4.842339] rk806 spi2.0: no reset-setting pinctrl state [ 4.842343] rk806 spi2.0: no dvs-setting pinctrl state [ 4.843846] rockchip-spi feb20000.spi: register misc device rkspi-dev2 [ 4.843850] rockchip-spi feb20000.spi: probed, poll=0, rsd=0 [ 4.844875] nvme0n1: p1 p2 [ 4.845509] spi-nor spi5.0: XM25QU128C (16384 Kbytes) read_data x4 [ 4.845525] 1 fixed-partitions partitions found on MTD device sfc_nor [ 4.845528] Creating 1 MTD partitions on "sfc_nor": [ 4.845532] 0x000000000000-0x000001000000 : "loader" [ 4.847742] rk_gmac-dwmac fe1c0000.ethernet: IRQ eth_lpi not found [ 4.847893] rk_gmac-dwmac fe1c0000.ethernet: Looking up phy-supply from device tree [ 4.847907] rk_gmac-dwmac fe1c0000.ethernet: Looking up phy-supply property in node /ethernet@fe1c0000 failed [ 4.847921] rk_gmac-dwmac fe1c0000.ethernet: no regulator found [ 4.847925] rk_gmac-dwmac fe1c0000.ethernet: clock input or output? (output). [ 4.847930] rk_gmac-dwmac fe1c0000.ethernet: TX delay(0x42). [ 4.847933] rk_gmac-dwmac fe1c0000.ethernet: Can not read property: rx_delay. [ 4.847937] rk_gmac-dwmac fe1c0000.ethernet: set rx_delay to 0xffffffff [ 4.847945] rk_gmac-dwmac fe1c0000.ethernet: integrated PHY? (no). [ 4.847951] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_rx [ 4.847955] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_tx [ 4.847970] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock clk_mac_speed [ 4.848192] rk_gmac-dwmac fe1c0000.ethernet: init for RGMII_RXID [ 4.848312] rk_gmac-dwmac fe1c0000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 4.848318] rk_gmac-dwmac fe1c0000.ethernet: DWMAC4/5 [ 4.848323] rk_gmac-dwmac fe1c0000.ethernet: DMA HW capability register supported [ 4.848326] rk_gmac-dwmac fe1c0000.ethernet: RX Checksum Offload Engine supported [ 4.848329] rk_gmac-dwmac fe1c0000.ethernet: TX Checksum insertion supported [ 4.848332] rk_gmac-dwmac fe1c0000.ethernet: Wake-Up On Lan supported [ 4.848366] rk_gmac-dwmac fe1c0000.ethernet: TSO supported [ 4.848369] rk_gmac-dwmac fe1c0000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 4.848374] rk_gmac-dwmac fe1c0000.ethernet: Enabled Flow TC (entries=2) [ 4.848377] rk_gmac-dwmac fe1c0000.ethernet: TSO feature enabled [ 4.848381] rk_gmac-dwmac fe1c0000.ethernet: Using 32 bits DMA width [ 4.990720] usbcore: registered new interface driver rndis_wlan [ 4.990743] usbcore: registered new interface driver asix [ 4.990759] usbcore: registered new interface driver cdc_ether [ 4.990775] usbcore: registered new interface driver rndis_host [ 4.990795] usbcore: registered new interface driver cdc_ncm [ 4.996171] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up usb-supply from device tree [ 4.996201] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up usb-supply property in node /power-management@fd8d8000/power-controller failed [ 4.998166] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 4.998176] ehci-pci: EHCI PCI platform driver [ 4.998211] ehci-platform: EHCI generic platform driver [ 5.000493] ehci-platform fc800000.usb: EHCI Host Controller [ 5.000506] ehci-platform fc800000.usb: new USB bus registered, assigned bus number 1 [ 5.000572] ehci-platform fc800000.usb: irq 20, io mem 0xfc800000 [ 5.014908] ehci-platform fc800000.usb: USB 2.0 started, EHCI 1.00 [ 5.015026] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 5.015030] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.015034] usb usb1: Product: EHCI Host Controller [ 5.015037] usb usb1: Manufacturer: Linux 5.10.160-rk35xx ehci_hcd [ 5.015040] usb usb1: SerialNumber: fc800000.usb [ 5.015296] hub 1-0:1.0: USB hub found [ 5.015315] hub 1-0:1.0: 1 port detected [ 5.017720] ehci-platform fc880000.usb: EHCI Host Controller [ 5.017731] ehci-platform fc880000.usb: new USB bus registered, assigned bus number 2 [ 5.017791] ehci-platform fc880000.usb: irq 22, io mem 0xfc880000 [ 5.028250] ehci-platform fc880000.usb: USB 2.0 started, EHCI 1.00 [ 5.028361] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 5.028365] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.028368] usb usb2: Product: EHCI Host Controller [ 5.028372] usb usb2: Manufacturer: Linux 5.10.160-rk35xx ehci_hcd [ 5.028375] usb usb2: SerialNumber: fc880000.usb [ 5.028597] hub 2-0:1.0: USB hub found [ 5.028615] hub 2-0:1.0: 1 port detected [ 5.029035] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 5.029044] ohci-platform: OHCI generic platform driver [ 5.029212] ohci-platform fc840000.usb: Generic Platform OHCI controller [ 5.029221] ohci-platform fc840000.usb: new USB bus registered, assigned bus number 3 [ 5.029271] ohci-platform fc840000.usb: irq 21, io mem 0xfc840000 [ 5.089013] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10 [ 5.089018] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.089022] usb usb3: Product: Generic Platform OHCI controller [ 5.089025] usb usb3: Manufacturer: Linux 5.10.160-rk35xx ohci_hcd [ 5.089028] usb usb3: SerialNumber: fc840000.usb [ 5.089245] hub 3-0:1.0: USB hub found [ 5.089263] hub 3-0:1.0: 1 port detected [ 5.089555] ohci-platform fc8c0000.usb: Generic Platform OHCI controller [ 5.089563] ohci-platform fc8c0000.usb: new USB bus registered, assigned bus number 4 [ 5.089617] ohci-platform fc8c0000.usb: irq 23, io mem 0xfc8c0000 [ 5.149015] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10 [ 5.149020] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.149023] usb usb4: Product: Generic Platform OHCI controller [ 5.149026] usb usb4: Manufacturer: Linux 5.10.160-rk35xx ohci_hcd [ 5.149030] usb usb4: SerialNumber: fc8c0000.usb [ 5.149241] hub 4-0:1.0: USB hub found [ 5.149258] hub 4-0:1.0: 1 port detected [ 5.149853] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 5.149863] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 5 [ 5.149939] xhci-hcd xhci-hcd.7.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000200002010010 [ 5.149964] xhci-hcd xhci-hcd.7.auto: irq 139, io mem 0xfcd00000 [ 5.150127] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 5.150131] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.150135] usb usb5: Product: xHCI Host Controller [ 5.150138] usb usb5: Manufacturer: Linux 5.10.160-rk35xx xhci-hcd [ 5.150141] usb usb5: SerialNumber: xhci-hcd.7.auto [ 5.150354] hub 5-0:1.0: USB hub found [ 5.150372] hub 5-0:1.0: 1 port detected [ 5.150527] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 5.150533] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 6 [ 5.150540] xhci-hcd xhci-hcd.7.auto: Host supports USB 3.0 SuperSpeed [ 5.150576] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM. [ 5.150643] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 [ 5.150647] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.150651] usb usb6: Product: xHCI Host Controller [ 5.150654] usb usb6: Manufacturer: Linux 5.10.160-rk35xx xhci-hcd [ 5.150657] usb usb6: SerialNumber: xhci-hcd.7.auto [ 5.150862] hub 6-0:1.0: USB hub found [ 5.150879] hub 6-0:1.0: 1 port detected [ 5.151095] usbcore: registered new interface driver cdc_acm [ 5.151098] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 5.151300] usbcore: registered new interface driver uas [ 5.151455] usbcore: registered new interface driver usb-storage [ 5.152968] Error: Driver 'Goodix-TS' is already registered, aborting... [ 5.153063] usbcore: registered new interface driver usbtouchscreen [ 5.155120] input: rk805 pwrkey as /devices/platform/feb20000.spi/spi_master/spi2/spi2.0/rk805-pwrkey.5.auto/input/input0 [ 5.155765] i2c /dev entries driver [ 5.160406] rk860-regulator 0-0042: Looking up vin-supply from device tree [ 5.160422] vdd_cpu_big0_s0: supplied by vcc5v0_sys [ 5.160435] vcc5v0_sys: could not add device link regulator.29: -ENOENT [ 5.164700] vdd_cpu_big0_s0: 550 <--> 1050 mV at 800 mV, enabled [ 5.169822] rk860-regulator 0-0043: Looking up vin-supply from device tree [ 5.169837] vdd_cpu_big1_s0: supplied by vcc5v0_sys [ 5.169850] vcc5v0_sys: could not add device link regulator.30: -ENOENT [ 5.174112] vdd_cpu_big1_s0: 550 <--> 1050 mV at 800 mV, enabled [ 5.177531] Goodix-TS 2-0014: Looking up AVDD28-supply from device tree [ 5.177550] Goodix-TS 2-0014: Looking up AVDD28-supply property in node /i2c@feaa0000/touchscreen@14 failed [ 5.177578] Goodix-TS 2-0014: supply AVDD28 not found, using dummy regulator [ 5.177705] Goodix-TS 2-0014: Looking up VDDIO-supply from device tree [ 5.177723] Goodix-TS 2-0014: Looking up VDDIO-supply property in node /i2c@feaa0000/touchscreen@14 failed [ 5.177746] Goodix-TS 2-0014: supply VDDIO not found, using dummy regulator [ 5.268421] Goodix-TS 2-0014: i2c test failed attempt 1: -6 [ 5.295091] Goodix-TS 2-0014: i2c test failed attempt 2: -6 [ 5.321608] Goodix-TS 2-0014: I2C communication failure: -6 [ 5.325354] rk860-regulator 2-0042: Looking up vin-supply from device tree [ 5.325369] vdd_npu_s0: supplied by vcc5v0_sys [ 5.325382] vcc5v0_sys: could not add device link regulator.31: -ENOENT [ 5.329592] vdd_npu_s0: 550 <--> 950 mV at 800 mV, enabled [ 5.334783] typec_fusb302 6-0022: Looking up vbus-supply from device tree [ 5.363607] rtc-hym8563 6-0051: rtc information is valid [ 5.368915] rtc-hym8563 6-0051: registered as rtc0 [ 5.369925] rtc-hym8563 6-0051: setting system clock to 2023-08-07T18:57:00 UTC (1691434620) [ 5.372554] Goodix-TS 7-0014: Looking up AVDD28-supply from device tree [ 5.372563] Goodix-TS 7-0014: Looking up AVDD28-supply property in node /i2c@fec90000/touchscreen@14 failed [ 5.372576] Goodix-TS 7-0014: supply AVDD28 not found, using dummy regulator [ 5.372633] Goodix-TS 7-0014: Looking up VDDIO-supply from device tree [ 5.372640] Goodix-TS 7-0014: Looking up VDDIO-supply property in node /i2c@fec90000/touchscreen@14 failed [ 5.372649] Goodix-TS 7-0014: supply VDDIO not found, using dummy regulator [ 5.465060] Goodix-TS 7-0014: i2c test failed attempt 1: -6 [ 5.491720] Goodix-TS 7-0014: i2c test failed attempt 2: -6 [ 5.518241] Goodix-TS 7-0014: I2C communication failure: -6 [ 5.519230] rkcifhw fdce0000.rkcif: Adding to iommu group 16 [ 5.519596] rkcifhw fdce0000.rkcif: No reserved memory region assign to CIF [ 5.520789] rkisp_hw fdcb0000.rkisp: Adding to iommu group 14 [ 5.520955] rkisp_hw fdcb0000.rkisp: is_thunderboot: 0 [ 5.520960] rkisp_hw fdcb0000.rkisp: max input:0x0@0fps [ 5.520964] rkisp_hw fdcb0000.rkisp: Missing rockchip,grf property [ 5.521065] rkisp_hw fdcb0000.rkisp: no find phandle sram [ 5.521172] rkisp_hw fdcc0000.rkisp: Adding to iommu group 15 [ 5.521378] rkisp_hw fdcc0000.rkisp: is_thunderboot: 0 [ 5.521382] rkisp_hw fdcc0000.rkisp: max input:0x0@0fps [ 5.521386] rkisp_hw fdcc0000.rkisp: Missing rockchip,grf property [ 5.521481] rkisp_hw fdcc0000.rkisp: no find phandle sram [ 5.522475] usbcore: registered new interface driver uvcvideo [ 5.522478] USB Video Class driver (1.1.1) [ 5.523807] cpu cpu0: Looking up cpu-supply from device tree [ 5.524331] cpu cpu0: bin=0 [ 5.524505] cpu cpu0: leakage=8 [ 5.524530] cpu cpu0: Looking up cpu-supply from device tree [ 5.525975] cpu cpu0: pvtm=1381 [ 5.526143] cpu cpu0: pvtm-volt-sel=0 [ 5.526176] cpu cpu0: Looking up cpu-supply from device tree [ 5.526306] cpu cpu0: Looking up mem-supply from device tree [ 5.526484] cpu cpu4: Looking up cpu-supply from device tree [ 5.528192] cpu cpu4: bin=0 [ 5.528364] cpu cpu4: leakage=6 [ 5.528387] cpu cpu4: Looking up cpu-supply from device tree [ 5.534886] cpu cpu4: pvtm=1588 [ 5.538854] cpu cpu4: pvtm-volt-sel=0 [ 5.538897] cpu cpu4: Looking up cpu-supply from device tree [ 5.539402] cpu cpu4: Looking up mem-supply from device tree [ 5.539956] cpu cpu6: Looking up cpu-supply from device tree [ 5.541643] cpu cpu6: bin=0 [ 5.541815] cpu cpu6: leakage=6 [ 5.541834] cpu cpu6: Looking up cpu-supply from device tree [ 5.548361] cpu cpu6: pvtm=1590 [ 5.552355] cpu cpu6: pvtm-volt-sel=0 [ 5.552398] cpu cpu6: Looking up cpu-supply from device tree [ 5.552900] cpu cpu6: Looking up mem-supply from device tree [ 5.554086] cpu cpu0: avs=0 [ 5.554869] cpu cpu4: avs=0 [ 5.555666] cpu cpu6: avs=0 [ 5.555835] cpu cpu0: EM: OPP:816000 is inefficient [ 5.555839] cpu cpu0: EM: OPP:600000 is inefficient [ 5.555926] cpu cpu0: EM: created perf domain [ 5.555965] cpu cpu0: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=1608000000 h_table=0 [ 5.556747] cpu cpu4: EM: OPP:816000 is inefficient [ 5.556752] cpu cpu4: EM: OPP:600000 is inefficient [ 5.556882] cpu cpu4: EM: created perf domain [ 5.556915] cpu cpu4: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0 [ 5.565432] cpu cpu6: EM: OPP:816000 is inefficient [ 5.565438] cpu cpu6: EM: OPP:600000 is inefficient [ 5.565596] cpu cpu6: EM: created perf domain [ 5.566112] cpu cpu6: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0 [ 5.568330] usb 3-1: new full-speed USB device number 2 using ohci-platform [ 5.583931] sdhci: Secure Digital Host Controller Interface driver [ 5.583939] sdhci: Copyright(c) Pierre Ossman [ 5.583946] Synopsys Designware Multimedia Card Interface Driver [ 5.585209] sdhci-pltfm: SDHCI platform and OF driver helper [ 5.589102] ledtrig-cpu: registered to indicate activity on CPUs [ 5.589137] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active. [ 5.589195] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 5.590466] cryptodev: driver 1.12 loaded. [ 5.590515] hid: raw HID events driver (C) Jiri Kosina [ 5.590851] usbcore: registered new interface driver usbhid [ 5.590856] usbhid: USB HID core driver [ 5.591397] ashmem: initialized [ 5.598058] rockchip-saradc fec10000.saradc: Looking up vref-supply from device tree [ 5.600454] optee: probing for conduit method. [ 5.600465] optee: api uid mismatch [ 5.600484] optee: probe of firmware:optee failed with error -22 [ 5.601905] usbcore: registered new interface driver snd-usb-audio [ 5.607808] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up audio-supply from device tree [ 5.607836] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up audio-supply property in node /power-management@fd8d8000/power-controller failed [ 5.610612] debugfs: File 'Capture' in directory 'dapm' already present! [ 5.612211] input: rockchip-dp0 rockchip-dp0 as /devices/platform/dp0-sound/sound/card0/input1 [ 5.614349] input: rockchip-hdmi0 rockchip-hdmi0 as /devices/platform/hdmi0-sound/sound/card1/input2 [ 5.616219] input: headset-keys as /devices/platform/es8388-sound/input/input3 [ 5.630529] ES8323 6-0010: ASoC: error at soc_component_write_no_lock on ES8323.6-0010: -5 [ 5.688932] input: rockchip-es8388 Headset as /devices/platform/es8388-sound/sound/card2/input4 [ 5.689987] Initializing XFRM netlink socket [ 5.690004] NET: Registered protocol family 17 [ 5.690382] [BT_RFKILL]: Enter rfkill_rk_init [ 5.690386] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 5.690790] Key type dns_resolver registered [ 5.692360] registered taskstats version 1 [ 5.692368] Loading compiled-in X.509 certificates [ 5.693277] Btrfs loaded, crc32c=crc32c-generic [ 5.693399] pstore: Using crash dump compression: deflate [ 5.693631] rga3_core0 fdb60000.rga: Adding to iommu group 2 [ 5.693817] rga: rga3_core0, irq = 35, match scheduler [ 5.694345] rga: rga3_core0 hardware loaded successfully, hw_version:3.0.76831. [ 5.694393] rga: rga3_core0 probe successfully [ 5.694717] rga3_core1 fdb70000.rga: Adding to iommu group 3 [ 5.694895] rga: rga3_core1, irq = 36, match scheduler [ 5.695525] rga: rga3_core1 hardware loaded successfully, hw_version:3.0.76831. [ 5.695575] rga: rga3_core1 probe successfully [ 5.695921] rga: rga2, irq = 37, match scheduler [ 5.696527] rga: rga2 hardware loaded successfully, hw_version:3.2.63318. [ 5.696536] rga: rga2 probe successfully [ 5.696748] rga_iommu: IOMMU binding successfully, default mapping core[0x1] [ 5.697051] rga: Module initialized. v1.2.25 [ 5.748632] reg-fixed-voltage combophy-avdd0v85: Looking up vin-supply from device tree [ 5.748669] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up gpu-supply from device tree [ 5.748748] combophy_avdd0v85: supplied by vdd_0v85_s0 [ 5.748762] vdd_0v85_s0: could not add device link regulator.32: -ENOENT [ 5.749023] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up gpu-supply property in node /power-management@fd8d8000/power-controller failed [ 5.749229] mali fb000000.gpu: Kernel DDK version g17p0-01eac0 [ 5.749339] mali fb000000.gpu: Looking up mali-supply from device tree [ 5.754730] combophy_avdd0v85: 850 mV, enabled [ 5.754966] mali fb000000.gpu: Looking up mem-supply from device tree [ 5.755113] mali fb000000.gpu: Looking up mali-supply from device tree [ 5.755126] reg-fixed-voltage combophy-avdd0v85: combophy_avdd0v85 supplying 850000uV [ 5.755143] vdd_gpu_s0: could not add device link fb000000.gpu: -EEXIST [ 5.755149] vdd_gpu_s0: Failed to create debugfs directory [ 5.755159] mali fb000000.gpu: Looking up mem-supply from device tree [ 5.755180] vdd_gpu_s0: could not add device link fb000000.gpu: -EEXIST [ 5.755186] vdd_gpu_s0: Failed to create debugfs directory [ 5.755378] reg-fixed-voltage combophy-avdd1v8: Looking up vin-supply from device tree [ 5.755387] mali fb000000.gpu: Looking up mali-supply from device tree [ 5.755488] combophy_avdd1v8: supplied by avcc_1v8_s0 [ 5.755495] vdd_gpu_s0: could not add device link fb000000.gpu: -EEXIST [ 5.755502] vdd_gpu_s0: Failed to create debugfs directory [ 5.755509] avcc_1v8_s0: could not add device link regulator.33: -ENOENT [ 5.758035] mali fb000000.gpu: bin=0 [ 5.758226] mali fb000000.gpu: leakage=13 [ 5.758297] combophy_avdd1v8: 1800 mV, enabled [ 5.758302] mali fb000000.gpu: Looking up mali-supply from device tree [ 5.758330] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present! [ 5.758833] reg-fixed-voltage combophy-avdd1v8: combophy_avdd1v8 supplying 1800000uV [ 5.759120] vcc_3v3_sd_s0: 3300 mV, disabled [ 5.759303] reg-fixed-voltage vcc-3v3-sd-s0: Looking up vin-supply from device tree [ 5.759321] vcc_3v3_sd_s0: supplied by vcc_3v3_s3 [ 5.759619] reg-fixed-voltage vcc-3v3-sd-s0: vcc_3v3_sd_s0 supplying 3300000uV [ 5.760001] mali fb000000.gpu: pvtm=847 [ 5.760618] rockchip-dmc dmc: Looking up center-supply from device tree [ 5.761962] mali fb000000.gpu: pvtm-volt-sel=2 [ 5.762472] rockchip-dmc dmc: Looking up mem-supply from device tree [ 5.763104] rockchip-dmc dmc: Looking up center-supply from device tree [ 5.763147] vdd_ddr_s0: could not add device link dmc: -EEXIST [ 5.763154] vdd_ddr_s0: Failed to create debugfs directory [ 5.763206] mali fb000000.gpu: avs=0 [ 5.763524] rockchip-dmc dmc: Looking up mem-supply from device tree [ 5.763576] vdd_log_s0: could not add device link dmc: -EEXIST [ 5.763583] vdd_log_s0: Failed to create debugfs directory [ 5.763685] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 143; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available. [ 5.764319] rockchip-dmc dmc: leakage=30 [ 5.764341] rockchip-dmc dmc: leakage-volt-sel=0 [ 5.765053] rockchip-dmc dmc: avs=0 [ 5.765076] rockchip-dmc dmc: current ATF version 0x100 [ 5.765235] rockchip-dmc dmc: normal_rate = 1560000000 [ 5.765244] rockchip-dmc dmc: reboot_rate = 2112000000 [ 5.765253] rockchip-dmc dmc: suspend_rate = 528000000 [ 5.765262] rockchip-dmc dmc: video_4k_rate = 1560000000 [ 5.765271] rockchip-dmc dmc: video_4k_10b_rate = 1560000000 [ 5.765279] rockchip-dmc dmc: video_svep_rate = 1560000000 [ 5.765288] rockchip-dmc dmc: boost_rate = 2112000000 [ 5.765297] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 2112000000 [ 5.765306] rockchip-dmc dmc: performance_rate = 2112000000 [ 5.765315] rockchip-dmc dmc: hdmirx_rate = 2112000000 [ 5.765331] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate [ 5.765339] rockchip-dmc dmc: failed to get vop pn to msch rl [ 5.765557] rockchip-dmc dmc: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0 [ 5.768235] mali fb000000.gpu: GPU hardware issue table may need updating: r0p0 status 5 is unknown; treating as r0p0 status 0 [ 5.768276] mali fb000000.gpu: GPU identified as 0x7 arch 10.8.6 r0p0 status 0 [ 5.768353] mali fb000000.gpu: No priority control manager is configured [ 5.768771] mali fb000000.gpu: No memory group manager is configured [ 5.768807] mali fb000000.gpu: Protected memory allocator not available [ 5.769090] rockchip-dmc dmc: could not find power_model node [ 5.770017] mali fb000000.gpu: Capping CSF_FIRMWARE_TIMEOUT to CSF_FIRMWARE_PING_TIMEOUT [ 5.771087] mali fb000000.gpu: Couldn't find power_model DT node matching 'arm,mali-simple-power-model' [ 5.771100] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.static-coefficient = 1*[0] [ 5.771406] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.dynamic-coefficient = 1*[0] [ 5.771736] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.ts = 4*[0] [ 5.772046] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.thermal-zone = '' [ 5.776872] mali fb000000.gpu: Using configured power model mali-lodx-power-model, and fallback mali-simple-power-model [ 5.777225] mali fb000000.gpu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0 [ 5.777939] input: adc-keys as /devices/platform/adc-keys/input/input5 [ 5.779447] mali fb000000.gpu: Probed as mali0 [ 5.781180] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode. [ 5.781193] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up sdio-supply from device tree [ 5.781222] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up sdio-supply property in node /power-management@fd8d8000/power-controller failed [ 5.781246] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller. [ 5.781256] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a [ 5.781286] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up pcie-supply from device tree [ 5.781302] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 90,32 bit host data width,256 deep fifo [ 5.781314] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up pcie-supply property in node /power-management@fd8d8000/power-controller failed [ 5.781358] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu-supply from device tree [ 5.781377] dwmmc_rockchip fe2c0000.mmc: Looking up vmmc-supply from device tree [ 5.781382] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu-supply property in node /power-management@fd8d8000/power-controller failed [ 5.781649] dwmmc_rockchip fe2c0000.mmc: Looking up vqmmc-supply from device tree [ 5.782869] RKNPU fdab0000.npu: Adding to iommu group 0 [ 5.783053] RKNPU fdab0000.npu: RKNPU: rknpu iommu is enabled, using iommu mode [ 5.783160] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 5.783938] RKNPU fdab0000.npu: Looking up mem-supply from device tree [ 5.784671] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff] [ 5.784704] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff] [ 5.784721] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff] [ 5.786022] [drm] Initialized rknpu 0.8.5 20230202 for fdab0000.npu on minor 1 [ 5.786409] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up nputop-supply from device tree [ 5.786436] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up nputop-supply property in node /power-management@fd8d8000/power-controller failed [ 5.786515] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu1-supply from device tree [ 5.786536] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu1-supply property in node /power-management@fd8d8000/power-controller failed [ 5.786597] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu2-supply from device tree [ 5.786619] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu2-supply property in node /power-management@fd8d8000/power-controller failed [ 5.786789] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 5.786813] vdd_npu_s0: could not add device link fdab0000.npu: -EEXIST [ 5.786816] vdd_npu_s0: Failed to create debugfs directory [ 5.787354] RKNPU fdab0000.npu: Looking up mem-supply from device tree [ 5.787444] vdd_npu_s0: could not add device link fdab0000.npu: -EEXIST [ 5.787450] vdd_npu_s0: Failed to create debugfs directory [ 5.788259] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 5.788357] vdd_npu_s0: could not add device link fdab0000.npu: -EEXIST [ 5.788362] vdd_npu_s0: Failed to create debugfs directory [ 5.790368] RKNPU fdab0000.npu: RKNPU: bin=0 [ 5.790554] RKNPU fdab0000.npu: leakage=7 [ 5.790649] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 5.790683] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present! [ 5.797219] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 5.798150] RKNPU fdab0000.npu: pvtm=846 [ 5.803096] RKNPU fdab0000.npu: pvtm-volt-sel=2 [ 5.804745] RKNPU fdab0000.npu: avs=0 [ 5.805078] RKNPU fdab0000.npu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0 [ 5.805725] usb 3-1: New USB device found, idVendor=046d, idProduct=c539, bcdDevice=39.06 [ 5.805735] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 5.805745] usb 3-1: Product: USB Receiver [ 5.805753] usb 3-1: Manufacturer: Logitech [ 5.815343] input: Logitech USB Receiver as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.0/0003:046D:C539.0001/input/input6 [ 5.819362] RKNPU fdab0000.npu: failed to find power_model node [ 5.819374] RKNPU fdab0000.npu: RKNPU: failed to initialize power model [ 5.819379] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient [ 5.821121] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 5.834229] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 5.835930] rockchip-pm rockchip-suspend: not set pwm-regulator-config [ 5.835944] rockchip-suspend not set sleep-mode-config for mem-lite [ 5.835948] rockchip-suspend not set wakeup-config for mem-lite [ 5.835955] rockchip-suspend not set sleep-mode-config for mem-ultra [ 5.835958] rockchip-suspend not set wakeup-config for mem-ultra [ 5.837314] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 406; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '13:36:29', on 'Jul 6 2023'. [ 5.837645] Mali: [ 5.837648] Mali device driver loaded [ 5.837656] ALSA device list: [ 5.837661] #0: rockchip-dp0 [ 5.837665] #1: rockchip-hdmi0 [ 5.837669] #2: rockchip-es8388 [ 5.842720] Freeing unused kernel memory: 6976K [ 5.873660] hid-generic 0003:046D:C539.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-fc840000.usb-1/input0 [ 5.880234] input: Logitech USB Receiver Mouse as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input7 [ 5.882041] Run /init as init process [ 5.882055] with arguments: [ 5.882064] /init [ 5.882074] splash [ 5.882084] with environment: [ 5.882093] HOME=/ [ 5.882102] TERM=linux [ 5.882111] ubootpart= [ 5.882120] cgroup_enable=memory [ 5.882128] cgroup_memory=1 [ 5.935201] input: Logitech USB Receiver Consumer Control as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input8 [ 5.935744] input: Logitech USB Receiver System Control as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input9 [ 5.936704] hid-generic 0003:046D:C539.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-fc840000.usb-1/input1 [ 5.951944] hid-generic 0003:046D:C539.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-fc840000.usb-1/input2 [ 6.950754] EXT4-fs (nvme0n1p2): mounted filesystem with writeback data mode. Opts: (null) [ 7.232544] NET: Registered protocol family 10 [ 7.234036] Segment Routing with IPv6 [ 7.253835] systemd[1]: systemd 249.11-0ubuntu3.9 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified) [ 7.255726] systemd[1]: Detected architecture arm64. [ 7.257191] systemd[1]: Hostname set to . [ 7.581727] systemd[1]: Queued start job for default target Graphical Interface. [ 7.583237] systemd[1]: Created slice Slice /system/modprobe. [ 7.583732] systemd[1]: Created slice Slice /system/serial-getty. [ 7.584145] systemd[1]: Created slice Slice /system/systemd-fsck. [ 7.584413] systemd[1]: Created slice User and Session Slice. [ 7.584523] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 7.584823] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 7.584944] systemd[1]: Reached target User and Group Name Lookups. [ 7.584990] systemd[1]: Reached target Slice Units. [ 7.585020] systemd[1]: Reached target Swaps. [ 7.585053] systemd[1]: Reached target System Time Set. [ 7.585115] systemd[1]: Reached target Local Verity Protected Volumes. [ 7.592984] systemd[1]: Listening on RPCbind Server Activation Socket. [ 7.593342] systemd[1]: Listening on Syslog Socket. [ 7.593563] systemd[1]: Listening on fsck to fsckd communication Socket. [ 7.593680] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 7.594006] systemd[1]: Listening on Journal Audit Socket. [ 7.594174] systemd[1]: Listening on Journal Socket (/dev/log). [ 7.594400] systemd[1]: Listening on Journal Socket. [ 7.595386] systemd[1]: Listening on udev Control Socket. [ 7.595635] systemd[1]: Listening on udev Kernel Socket. [ 7.597005] systemd[1]: Mounting Huge Pages File System... [ 7.598511] systemd[1]: Mounting POSIX Message Queue File System... [ 7.600098] systemd[1]: Mounting Kernel Debug File System... [ 7.601514] systemd[1]: Mounting Kernel Trace File System... [ 7.602017] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped. [ 7.603817] systemd[1]: Starting Restore / save the current clock... [ 7.605734] systemd[1]: Starting Set the console keyboard layout... [ 7.607529] systemd[1]: Starting Create List of Static Device Nodes... [ 7.609221] systemd[1]: Starting Load Kernel Module chromeos_pstore... [ 7.611394] systemd[1]: Starting Load Kernel Module configfs... [ 7.613294] systemd[1]: Starting Load Kernel Module drm... [ 7.615561] systemd[1]: Starting Load Kernel Module efi_pstore... [ 7.617393] systemd[1]: Starting Load Kernel Module fuse... [ 7.619276] systemd[1]: Starting Load Kernel Module pstore_blk... [ 7.621176] systemd[1]: Starting Load Kernel Module pstore_zone... [ 7.623011] fuse: init (API version 7.32) [ 7.623148] systemd[1]: Starting Load Kernel Module ramoops... [ 7.623597] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 7.626731] systemd[1]: Starting Load Kernel Modules... [ 7.628501] systemd[1]: Starting Remount Root and Kernel File Systems... [ 7.630091] systemd[1]: Starting Coldplug All udev Devices... [ 7.633093] systemd[1]: Mounted Huge Pages File System. [ 7.633444] systemd[1]: Mounted POSIX Message Queue File System. [ 7.633651] systemd[1]: Mounted Kernel Debug File System. [ 7.633824] systemd[1]: Mounted Kernel Trace File System. [ 7.634446] systemd[1]: Finished Restore / save the current clock. [ 7.635242] systemd[1]: Finished Create List of Static Device Nodes. [ 7.635721] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully. [ 7.636066] systemd[1]: Finished Load Kernel Module chromeos_pstore. [ 7.636490] systemd[1]: modprobe@configfs.service: Deactivated successfully. [ 7.636813] systemd[1]: Finished Load Kernel Module configfs. [ 7.637203] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 7.637525] systemd[1]: Finished Load Kernel Module drm. [ 7.637993] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [ 7.638370] systemd[1]: Finished Load Kernel Module efi_pstore. [ 7.638735] systemd[1]: modprobe@fuse.service: Deactivated successfully. [ 7.639032] systemd[1]: Finished Load Kernel Module fuse. [ 7.639384] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully. [ 7.639670] systemd[1]: Finished Load Kernel Module pstore_blk. [ 7.640019] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully. [ 7.640306] systemd[1]: Finished Load Kernel Module pstore_zone. [ 7.640675] systemd[1]: modprobe@ramoops.service: Deactivated successfully. [ 7.640957] systemd[1]: Finished Load Kernel Module ramoops. [ 7.642733] systemd[1]: Mounting FUSE Control File System... [ 7.644226] systemd[1]: Mounting Kernel Configuration File System... [ 7.645058] systemd[1]: Finished Load Kernel Modules. [ 7.645853] EXT4-fs (nvme0n1p2): re-mounted. Opts: commit=600,errors=remount-ro [ 7.646865] systemd[1]: Starting Apply Kernel Variables... [ 7.649260] systemd[1]: Finished Remount Root and Kernel File Systems. [ 7.650250] systemd[1]: Mounted FUSE Control File System. [ 7.650441] systemd[1]: Mounted Kernel Configuration File System. [ 7.652342] systemd[1]: Starting Platform Persistent Storage Archival... [ 7.653873] systemd[1]: Starting Load/Save Random Seed... [ 7.655365] systemd[1]: Starting Create System Users... [ 7.662998] systemd[1]: Finished Apply Kernel Variables. [ 7.674783] systemd[1]: Finished Create System Users. [ 7.676953] systemd[1]: Starting Create Static Device Nodes in /dev... [ 7.683462] systemd[1]: Finished Set the console keyboard layout. [ 7.698968] systemd[1]: Finished Create Static Device Nodes in /dev. [ 7.699767] systemd[1]: Reached target Preparation for Local File Systems. [ 7.704130] systemd[1]: Mounting /tmp... [ 7.711938] systemd[1]: Starting Rule-based Manager for Device Events and Files... [ 7.716118] systemd[1]: Mounted /tmp. [ 7.721130] systemd[1]: Finished Platform Persistent Storage Archival. [ 7.727152] systemd[1]: Finished Load/Save Random Seed. [ 7.727455] systemd[1]: Condition check resulted in First Boot Complete being skipped. [ 7.790932] systemd[1]: Started Rule-based Manager for Device Events and Files. [ 7.805552] systemd[1]: Finished Coldplug All udev Devices. [ 7.809386] systemd[1]: Starting Helper to synchronize boot up for ifupdown... [ 7.812705] systemd[1]: Starting Show Plymouth Boot Screen... [ 7.814768] systemd[1]: Finished Helper to synchronize boot up for ifupdown. [ 7.835371] systemd[1]: Started Show Plymouth Boot Screen. [ 7.835677] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 7.835874] systemd[1]: Started Forward Password Requests to Plymouth Directory Watch. [ 7.835930] systemd[1]: Reached target Local Encrypted Volumes. [ 7.867154] systemd[1]: Created slice Slice /system/systemd-backlight. [ 7.870843] systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:backlight... [ 7.880008] systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:backlight_1... [ 7.881529] systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:backlight. [ 7.886824] systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:backlight_1. [ 7.967035] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 7.967099] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 7.968527] systemd[1]: Found device /dev/ttyFIQ0. [ 7.982093] systemd[1]: Found device Samsung SSD 960 EVO 500GB armbi_boot. [ 7.989448] systemd[1]: Starting File System Check on /dev/disk/by-uuid/1BD1-7F33... [ 7.995246] systemd[1]: Reached target Hardware activated USB gadget. [ 7.996826] systemd[1]: Started File System Check Daemon to report status. [ 8.019359] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 8.019578] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 8.028901] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 8.033481] systemd[1]: Finished File System Check on /dev/disk/by-uuid/1BD1-7F33. [ 8.037439] systemd[1]: Mounting /boot... [ 8.039285] FAT-fs (nvme0n1p1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive! [ 8.042634] systemd[1]: Mounted /boot. [ 8.042847] systemd[1]: Reached target Local File Systems. [ 8.044428] systemd[1]: Starting Armbian leds state... [ 8.046070] systemd[1]: Starting Armbian ZRAM config... [ 8.047616] systemd[1]: Starting Set console font and keymap... [ 8.049297] systemd[1]: Starting Raise network interfaces... [ 8.050939] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data... [ 8.051075] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped. [ 8.055660] systemd[1]: Starting Set Up Additional Binary Formats... [ 8.055932] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 8.056073] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 8.057872] systemd[1]: Finished Set console font and keymap. [ 8.062678] systemd[1]: Received SIGRTMIN+20 from PID 297 (plymouthd). [ 8.064035] systemd[1]: Finished Armbian leds state. [ 8.065646] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data. [ 8.066234] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 542 (systemd-binfmt) [ 8.068955] systemd[1]: Mounting Arbitrary Executable File Formats File System... [ 8.077246] systemd[1]: Mounted Arbitrary Executable File Formats File System. [ 8.079949] systemd[1]: Finished Set Up Additional Binary Formats. [ 8.135794] zram0: detected capacity change from 0 to 4031107072 [ 8.178324] Adding 3936624k swap on /dev/zram0. Priority:5 extents:1 across:3936624k SS [ 8.185763] systemd[1]: Finished Raise network interfaces. [ 8.189238] zram: Added device: zram1 [ 8.309758] zram1: detected capacity change from 0 to 52428800 [ 8.346501] systemd[1]: Finished Armbian ZRAM config. [ 8.351798] systemd[1]: Starting Armbian memory supported logging... [ 8.414270] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard [ 8.691595] vendor storage:20190527 ret = -1 [ 8.922713] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 8.922882] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 8.922998] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 10.007597] systemd[1]: Finished Armbian memory supported logging. [ 10.019029] systemd[1]: Starting Journal Service... [ 10.166317] systemd[1]: Started Journal Service. [ 10.196341] systemd-journald[737]: Received client request to flush runtime journal. ### armbian-release: # PLEASE DO NOT EDIT THIS FILE BOARD=orangepi5 BOARD_NAME="Orange Pi 5" BOARDFAMILY=rockchip-rk3588 BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=bfc8271 VERSION=23.08.0-trunk LINUXFAMILY=rk35xx ARCH=arm64 IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm64 KERNEL_IMAGE_TYPE=Image FORCE_BOOTSCRIPT_UPDATE= VENDOR=Armbian REVISION=23.08.0-trunk BOOTSCRIPT_FORCE_UPDATE="no" BOOTSCRIPT_DST="boot.cmd" BRANCH=legacy ### boot environment: verbosity=1 bootlogo=true overlay_prefix=rockchip-rk3588 fdtfile=rockchip/rk3588s-orangepi-5.dtb rootdev=UUID=329a3cf7-a8ce-4ea6-a3ef-c2128bda1678 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u ### lsusb: Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 002: ID 046d:c539 Logitech, Inc. USB Receiver Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub ### lscpu: Architecture: aarch64 CPU op-mode(s): 32-bit, 64-bit Byte Order: Little Endian CPU(s): 8 On-line CPU(s) list: 0-7 Vendor ID: ARM Model name: Cortex-A55 Model: 0 Thread(s) per core: 1 Core(s) per socket: 4 Socket(s): 1 Stepping: r2p0 CPU max MHz: 1800,0000 CPU min MHz: 408,0000 BogoMIPS: 48.00 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp Model name: Cortex-A76 Model: 0 Thread(s) per core: 1 Core(s) per socket: 2 Socket(s): 2 Stepping: r4p0 CPU max MHz: 2256,0000 CPU min MHz: 408,0000 BogoMIPS: 48.00 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp L1d cache: 384 KiB (8 instances) L1i cache: 384 KiB (8 instances) L2 cache: 2,5 MiB (8 instances) L3 cache: 3 MiB (1 instance) Vulnerability L1tf: Not affected Vulnerability Mds: Not affected Vulnerability Meltdown: Not affected Vulnerability Mmio stale data: Not affected Vulnerability Retbleed: Not affected Vulnerability Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl Vulnerability Spectre v1: Mitigation; __user pointer sanitization Vulnerability Spectre v2: Vulnerable: Unprivileged eBPF enabled Vulnerability Srbds: Not affected Vulnerability Tsx async abort: Not affected Vulnerability itlb multihit: Not affected ### cpuinfo: processor : 0 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 1 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 2 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 3 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x2 CPU part : 0xd05 CPU revision : 0 processor : 4 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 processor : 5 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 processor : 6 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 processor : 7 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x4 CPU part : 0xd0b CPU revision : 0 Serial : 2eae2cb9d903d20e ### meminfo: MemTotal: 7873256 kB MemFree: 7549276 kB MemAvailable: 7583660 kB Buffers: 15204 kB Cached: 91304 kB SwapCached: 0 kB Active: 26688 kB Inactive: 120596 kB Active(anon): 512 kB Inactive(anon): 70048 kB Active(file): 26176 kB Inactive(file): 50548 kB Unevictable: 19604 kB Mlocked: 0 kB SwapTotal: 3936624 kB SwapFree: 3936624 kB Dirty: 7760 kB Writeback: 0 kB AnonPages: 61036 kB Mapped: 31576 kB Shmem: 25792 kB KReclaimable: 38428 kB Slab: 80208 kB SReclaimable: 38428 kB SUnreclaim: 41780 kB KernelStack: 3792 kB PageTables: 2860 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 7873252 kB Committed_AS: 140152 kB VmallocTotal: 135290290112 kB VmallocUsed: 36624 kB VmallocChunk: 0 kB Percpu: 2816 kB CmaTotal: 262144 kB CmaAllocated: 4672 kB CmaReleased: 257472 kB CmaFree: 257472 kB HugePages_Total: 0 HugePages_Free: 0 HugePages_Rsvd: 0 HugePages_Surp: 0 Hugepagesize: 2048 kB Hugetlb: 0 kB ### virtual memory: vm.admin_reserve_kbytes = 8192 vm.block_dump = 0 vm.dirty_background_bytes = 0 vm.dirty_background_ratio = 10 vm.dirty_bytes = 0 vm.dirty_expire_centisecs = 3000 vm.dirty_ratio = 20 vm.dirtytime_expire_seconds = 43200 vm.dirty_writeback_centisecs = 500 vm.extra_free_kbytes = 0 vm.hugetlb_shm_group = 0 vm.laptop_mode = 0 vm.legacy_va_layout = 0 vm.lowmem_reserve_ratio = 256 256 32 0 vm.max_map_count = 65530 vm.min_free_kbytes = 11208 vm.mmap_min_addr = 32768 vm.mmap_rnd_bits = 18 vm.mmap_rnd_compat_bits = 11 vm.nr_hugepages = 0 vm.nr_overcommit_hugepages = 0 vm.oom_dump_tasks = 1 vm.oom_kill_allocating_task = 0 vm.overcommit_kbytes = 0 vm.overcommit_memory = 0 vm.overcommit_ratio = 50 vm.page-cluster = 0 vm.page_lock_unfairness = 5 vm.panic_on_oom = 0 vm.percpu_pagelist_fraction = 0 vm.stat_interval = 1 vm.swappiness = 100 vm.user_reserve_kbytes = 131072 vm.vfs_cache_pressure = 100 vm.watermark_boost_factor = 15000 vm.watermark_scale_factor = 10 ### ip addr: 1: lo: mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet XXX.XXX.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: eth0: mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether ae:d8:3f:81:fa:0b brd ff:ff:ff:ff:ff:ff ### partitions: major minor #blocks name 254 0 3936628 zram0 259 0 488386584 nvme0n1 259 1 262144 nvme0n1p1 259 2 483213312 nvme0n1p2 31 0 16384 mtdblock0 254 1 51200 zram1 ### df: tmpfs 769M 9,7M 760M 2% /run /dev/nvme0n1p2 454G 5,1G 444G 2% / tmpfs 3,8G 0 3,8G 0% /dev/shm tmpfs 5,0M 0 5,0M 0% /run/lock tmpfs 3,8G 120K 3,8G 1% /tmp /dev/nvme0n1p1 256M 106M 151M 42% /boot /dev/zram1 47M 7,9M 36M 19% /var/log ### lsblk: NAME FSTYPE SIZE MOUNTPOINT UUID mtdblock0 16M zram1 50M /var/log nvme0n1 465,8G ├─nvme0n1p1 vfat 256M /boot 1BD1-7F33 └─nvme0n1p2 ext4 460,8G / 329a3cf7-a8ce-4ea6-a3ef-c2128bda1678 ### zramctl: NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT /dev/zram1 zstd 50M 7,9M 1,7M 2,2M 8 /var/log /dev/zram0 lzo-rle 3,8G 4K 74B 12K 8 [SWAP] ### mtab: /dev/nvme0n1p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=936,iocharset=utf8,shortname=mixed,errors=remount-ro 0 0 /dev/nvme0n1p2 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0 /dev/nvme0n1p2 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0 ### Boot system health: Time CPU_cl0/CPU_cl1 load %cpu %sys %usr %nice %io %irq Tcpu C.St. 21:57:06 1800/2208 MHz 1.20 20% 12% 6% 0% 0% 0% 47,2 °C 0/7 21:57:06 1800/2256 MHz 1.20 26% 8% 17% 0% 0% 0% 46,2 °C 0/7 21:57:06 1800/2256 MHz 1.20 17% 2% 13% 0% 0% 0% 45,3 °C 0/7 21:57:07 1608/2016 MHz 1.20 23% 6% 14% 0% 1% 0% 44,4 °C 0/7 21:57:07 1800/2256 MHz 1.20 17% 2% 14% 0% 0% 0% 45,3 °C 0/7 ### lsusb: Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 007 Device 002: ID 046d:c336 Logitech, Inc. Gaming Keyboard G213 Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 002: ID 046d:c539 Logitech, Inc. USB Receiver Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub /: Bus 08.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M /: Bus 07.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M |__ Port 1: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 12M |__ Port 1: Dev 2, If 1, Class=Human Interface Device, Driver=usbhid, 12M /: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M /: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M /: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M |__ Port 1: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 12M |__ Port 1: Dev 2, If 1, Class=Human Interface Device, Driver=usbhid, 12M |__ Port 1: Dev 2, If 2, Class=Human Interface Device, Driver=usbhid, 12M /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M ### lspci: 0004:40:00.0 PCI bridge: Rockchip Electronics Co., Ltd Device 3588 (rev 01) 0004:41:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM961/PM961/SM963 ### Userland: PRETTY_NAME="Armbian 23.08.0-trunk jammy" ARMBIAN_PRETTY_NAME="Armbian 23.08.0-trunk jammy" ### Installed packages: ii armbian-bsp-cli-orangepi5-legacy 23.08.0-trunk--1-PCc73b-Vdc2a-Hf77c-B122f arm64 Armbian CLI BSP for board 'orangepi5' branch 'legacy' ii armbian-bsp-desktop-orangepi5-legacy 23.08.0-trunk--1-B3c0c arm64 Armbian bsp-desktop for release jammy, common for all desktop environments on arm64 orangepi5 machines on legacy branch ii armbian-config 23.08.0-trunk--1-SAaa37-Baeda all Armbian configuration utility ii armbian-firmware-full 23.02.2 all Linux firmware-full ii armbian-jammy-desktop-cinnamon 23.08.0-trunk--1-Vcf74-B4c8e all Armbian desktop for Ubuntu jammy cinnamon ii armbian-plymouth-theme 23.08.0-trunk---B4822 all boot animation, logger and I/O multiplexer - Armbian theme ii armbian-zsh 23.08.0-trunk--1-SAbfee-Baf88 all Armbian improved ZShell (oh-my-zsh...) ii base-files 23.08.0-trunk--jammy-1armbian1-B9e4a arm64 Armbian base system miscellaneous files ii linux-base 4.5ubuntu9 all Linux image base package ii linux-dtb-legacy-rk35xx 23.08.0-trunk--5.10.160-S2c1d-Df1ec-P0000-C2d32Hfe66-HK01ba-Vc222-Be693 arm64 Armbian Linux legacy DTBs version "5.10.160" git revision "2c1dcd460b945317d5f0fb9f929b01f46f4e2ca9" codename "Dare mighty things" drivers hash "f1ec859bd80e169d" patches hash "0000000000000000" .config hash "2d32937fec29a52a" .config hook hash "fe661159ee64825e" variables hash "" framework bash hash "e693c7b4dae91f2e" in /boot/dtb-5.10.160-rk35xx ii linux-image-legacy-rk35xx 23.08.0-trunk--5.10.160-S2c1d-Df1ec-P0000-C2d32Hfe66-HK01ba-Vc222-Be693 arm64 Armbian Linux legacy kernel image version "5.10.160" git revision "2c1dcd460b945317d5f0fb9f929b01f46f4e2ca9" codename "Dare mighty things" drivers hash "f1ec859bd80e169d" patches hash "0000000000000000" .config hash "2d32937fec29a52a" .config hook hash "fe661159ee64825e" variables hash "" framework bash hash "e693c7b4dae91f2e" ii linux-libc-dev:arm64 23.02.2 arm64 Armbian Linux support headers for userspace development ii linux-u-boot-orangepi5-legacy 23.08.0-trunk--2017.09-S1f70-P1496-Hdd6c-V2903-Be848 arm64 Das U-Boot for orangepi5 version "2017.09" git revision "1f70ac3a968d121d86350092a7eff0dbd56114b7" patches hash "14960d44ca96f9a5" Extension hooks hash "dceb0f2913378bb5e88ad06afae03e5119114c25579b24e9ce620ebf443b7778" uboot functions hash "f80ff4bf3c7ab2a0f0fa1bd4b9adb2e8bef915f875c6ceb02d2720c9fd0a58ac" variables hash "" framework bash hash "e84825f971a79d88" ### Loaded modules: Module Size Used by tls 90112 0 overlay 110592 1 bnep 24576 2 zstd 16384 8 binfmt_misc 20480 1 joydev 20480 0 sch_fq_codel 20480 3 fuse 110592 1 ip_tables 28672 0 ipv6 438272 108 panfrost 57344 0 gpu_sched 28672 1 panfrost ### Current system health: Time CPU_cl0/CPU_cl1 load %cpu %sys %usr %nice %io %irq Tcpu C.St. 22:07:46 1416/ 408 MHz 1.13 13% 3% 9% 0% 0% 0% 39,8 °C 0/7 22:07:46 1416/ 408 MHz 1.13 2% 2% 0% 0% 0% 0% 38,8 °C 0/7 22:07:46 1200/ 408 MHz 1.13 3% 2% 0% 0% 0% 0% 38,8 °C 0/7 22:07:47 1416/ 408 MHz 1.13 2% 1% 0% 0% 0% 0% 38,8 °C 0/7 22:07:47 1416/ 408 MHz 1.13 2% 2% 0% 0% 0% 0% 38,8 °C 0/7 22:07:47 1800/ 408 MHz 1.13 13% 3% 9% 0% 0% 0% 40,7 °C 0/7 22:07:50 1800/2256 MHz 2.08 99% 0% 98% 0% 0% 0% 49,9 °C 0/7 22:07:51 408/ 408 MHz 2.08 59% 1% 57% 0% 0% 0% 44,4 °C 0/7 22:07:51 408/ 408 MHz 2.08 2% 1% 0% 0% 0% 0% 42,5 °C 0/7 22:07:51 1416/ 408 MHz 2.08 5% 2% 2% 0% 0% 0% 41,6 °C 0/7 ### resolv.conf -rw-r--r-- 1 root root 87 Ağu 7 21:57 /etc/resolv.conf # Generated by NetworkManager nameserver XXX.XXX.8.8 nameserver XXX.XXX.4.4 nameserver XXX.XXX.2.5 ### Current sysinfo: Linux 5.10.160-rk35xx (bilonemsi) 07-08-2023 _aarch64_ (8 CPU) avg-cpu: %user %nice %system %iowait %steal %idle 9,58 0,16 4,40 0,06 0,00 85,80 Device tps kB_read/s kB_wrtn/s kB_dscd/s kB_read kB_wrtn kB_dscd ram0 0,00 0,00 0,00 0,00 0 0 0 zram0 0,86 3,43 0,01 0,00 2248 4 0 nvme0n1 40,07 1113,52 2199,69 0,00 729581 1441237 0 nvme0n1p1 0,48 10,81 0,01 0,00 7082 5 0 nvme0n1p2 34,52 1099,32 2199,68 0,00 720275 1441232 0 mtdblock0 0,05 0,51 0,00 0,00 336 0 0 zram1 1,15 0,61 25,21 0,00 400 16516 0 --procs-- -----------------------memory---------------------- ---swap-- -----io---- -system-- --------cpu-------- r b swpd free buff cache si so bi bo in cs us sy id wa st 0 0 0 4270648 48240 2300280 0 0 141 282 615 757 10 4 86 0 0 total used free shared buff/cache available Mem: 7,5Gi 1,2Gi 4,1Gi 193Mi 2,2Gi 6,0Gi Swap: 3,8Gi 0B 3,8Gi NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT /dev/zram1 zstd 50M 13,6M 3M 3,6M 8 /var/log /dev/zram0 lzo-rle 3,8G 4K 74B 12K 8 [SWAP] 22:07:52 up 10 min, 1 user, load average: 2,08, 1,92, 1,17 [ 5.790649] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree [ 5.790683] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present! [ 5.797219] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 5.798150] RKNPU fdab0000.npu: pvtm=846 [ 5.803096] RKNPU fdab0000.npu: pvtm-volt-sel=2 [ 5.804745] RKNPU fdab0000.npu: avs=0 [ 5.805078] RKNPU fdab0000.npu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0 [ 5.805725] usb 3-1: New USB device found, idVendor=046d, idProduct=c539, bcdDevice=39.06 [ 5.805735] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 5.805745] usb 3-1: Product: USB Receiver [ 5.805753] usb 3-1: Manufacturer: Logitech [ 5.815343] input: Logitech USB Receiver as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.0/0003:046D:C539.0001/input/input6 [ 5.819362] RKNPU fdab0000.npu: failed to find power_model node [ 5.819374] RKNPU fdab0000.npu: RKNPU: failed to initialize power model [ 5.819379] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient [ 5.821121] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 5.834229] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 5.835930] rockchip-pm rockchip-suspend: not set pwm-regulator-config [ 5.835944] rockchip-suspend not set sleep-mode-config for mem-lite [ 5.835948] rockchip-suspend not set wakeup-config for mem-lite [ 5.835955] rockchip-suspend not set sleep-mode-config for mem-ultra [ 5.835958] rockchip-suspend not set wakeup-config for mem-ultra [ 5.837314] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 406; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '13:36:29', on 'Jul 6 2023'. [ 5.837645] Mali: [ 5.837648] Mali device driver loaded [ 5.837656] ALSA device list: [ 5.837661] #0: rockchip-dp0 [ 5.837665] #1: rockchip-hdmi0 [ 5.837669] #2: rockchip-es8388 [ 5.842720] Freeing unused kernel memory: 6976K [ 5.873660] hid-generic 0003:046D:C539.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-fc840000.usb-1/input0 [ 5.880234] input: Logitech USB Receiver Mouse as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input7 [ 5.882041] Run /init as init process [ 5.882055] with arguments: [ 5.882064] /init [ 5.882074] splash [ 5.882084] with environment: [ 5.882093] HOME=/ [ 5.882102] TERM=linux [ 5.882111] ubootpart= [ 5.882120] cgroup_enable=memory [ 5.882128] cgroup_memory=1 [ 5.935201] input: Logitech USB Receiver Consumer Control as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input8 [ 5.935744] input: Logitech USB Receiver System Control as /devices/platform/fc840000.usb/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input9 [ 5.936704] hid-generic 0003:046D:C539.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-fc840000.usb-1/input1 [ 5.951944] hid-generic 0003:046D:C539.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-fc840000.usb-1/input2 [ 6.950754] EXT4-fs (nvme0n1p2): mounted filesystem with writeback data mode. Opts: (null) [ 7.232544] NET: Registered protocol family 10 [ 7.234036] Segment Routing with IPv6 [ 7.253835] systemd[1]: systemd 249.11-0ubuntu3.9 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified) [ 7.255726] systemd[1]: Detected architecture arm64. [ 7.257191] systemd[1]: Hostname set to . [ 7.581727] systemd[1]: Queued start job for default target Graphical Interface. [ 7.583237] systemd[1]: Created slice Slice /system/modprobe. [ 7.583732] systemd[1]: Created slice Slice /system/serial-getty. [ 7.584145] systemd[1]: Created slice Slice /system/systemd-fsck. [ 7.584413] systemd[1]: Created slice User and Session Slice. [ 7.584523] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 7.584823] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 7.584944] systemd[1]: Reached target User and Group Name Lookups. [ 7.584990] systemd[1]: Reached target Slice Units. [ 7.585020] systemd[1]: Reached target Swaps. [ 7.585053] systemd[1]: Reached target System Time Set. [ 7.585115] systemd[1]: Reached target Local Verity Protected Volumes. [ 7.592984] systemd[1]: Listening on RPCbind Server Activation Socket. [ 7.593342] systemd[1]: Listening on Syslog Socket. [ 7.593563] systemd[1]: Listening on fsck to fsckd communication Socket. [ 7.593680] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 7.594006] systemd[1]: Listening on Journal Audit Socket. [ 7.594174] systemd[1]: Listening on Journal Socket (/dev/log). [ 7.594400] systemd[1]: Listening on Journal Socket. [ 7.595386] systemd[1]: Listening on udev Control Socket. [ 7.595635] systemd[1]: Listening on udev Kernel Socket. [ 7.597005] systemd[1]: Mounting Huge Pages File System... [ 7.598511] systemd[1]: Mounting POSIX Message Queue File System... [ 7.600098] systemd[1]: Mounting Kernel Debug File System... [ 7.601514] systemd[1]: Mounting Kernel Trace File System... [ 7.602017] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped. [ 7.603817] systemd[1]: Starting Restore / save the current clock... [ 7.605734] systemd[1]: Starting Set the console keyboard layout... [ 7.607529] systemd[1]: Starting Create List of Static Device Nodes... [ 7.609221] systemd[1]: Starting Load Kernel Module chromeos_pstore... [ 7.611394] systemd[1]: Starting Load Kernel Module configfs... [ 7.613294] systemd[1]: Starting Load Kernel Module drm... [ 7.615561] systemd[1]: Starting Load Kernel Module efi_pstore... [ 7.617393] systemd[1]: Starting Load Kernel Module fuse... [ 7.619276] systemd[1]: Starting Load Kernel Module pstore_blk... [ 7.621176] systemd[1]: Starting Load Kernel Module pstore_zone... [ 7.623011] fuse: init (API version 7.32) [ 7.623148] systemd[1]: Starting Load Kernel Module ramoops... [ 7.623597] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 7.626731] systemd[1]: Starting Load Kernel Modules... [ 7.628501] systemd[1]: Starting Remount Root and Kernel File Systems... [ 7.630091] systemd[1]: Starting Coldplug All udev Devices... [ 7.633093] systemd[1]: Mounted Huge Pages File System. [ 7.633444] systemd[1]: Mounted POSIX Message Queue File System. [ 7.633651] systemd[1]: Mounted Kernel Debug File System. [ 7.633824] systemd[1]: Mounted Kernel Trace File System. [ 7.634446] systemd[1]: Finished Restore / save the current clock. [ 7.635242] systemd[1]: Finished Create List of Static Device Nodes. [ 7.635721] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully. [ 7.636066] systemd[1]: Finished Load Kernel Module chromeos_pstore. [ 7.636490] systemd[1]: modprobe@configfs.service: Deactivated successfully. [ 7.636813] systemd[1]: Finished Load Kernel Module configfs. [ 7.637203] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 7.637525] systemd[1]: Finished Load Kernel Module drm. [ 7.637993] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [ 7.638370] systemd[1]: Finished Load Kernel Module efi_pstore. [ 7.638735] systemd[1]: modprobe@fuse.service: Deactivated successfully. [ 7.639032] systemd[1]: Finished Load Kernel Module fuse. [ 7.639384] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully. [ 7.639670] systemd[1]: Finished Load Kernel Module pstore_blk. [ 7.640019] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully. [ 7.640306] systemd[1]: Finished Load Kernel Module pstore_zone. [ 7.640675] systemd[1]: modprobe@ramoops.service: Deactivated successfully. [ 7.640957] systemd[1]: Finished Load Kernel Module ramoops. [ 7.642733] systemd[1]: Mounting FUSE Control File System... [ 7.644226] systemd[1]: Mounting Kernel Configuration File System... [ 7.645058] systemd[1]: Finished Load Kernel Modules. [ 7.645853] EXT4-fs (nvme0n1p2): re-mounted. Opts: commit=600,errors=remount-ro [ 7.646865] systemd[1]: Starting Apply Kernel Variables... [ 7.649260] systemd[1]: Finished Remount Root and Kernel File Systems. [ 7.650250] systemd[1]: Mounted FUSE Control File System. [ 7.650441] systemd[1]: Mounted Kernel Configuration File System. [ 7.652342] systemd[1]: Starting Platform Persistent Storage Archival... [ 7.653873] systemd[1]: Starting Load/Save Random Seed... [ 7.655365] systemd[1]: Starting Create System Users... [ 7.662998] systemd[1]: Finished Apply Kernel Variables. [ 7.674783] systemd[1]: Finished Create System Users. [ 7.676953] systemd[1]: Starting Create Static Device Nodes in /dev... [ 7.683462] systemd[1]: Finished Set the console keyboard layout. [ 7.698968] systemd[1]: Finished Create Static Device Nodes in /dev. [ 7.699767] systemd[1]: Reached target Preparation for Local File Systems. [ 7.704130] systemd[1]: Mounting /tmp... [ 7.711938] systemd[1]: Starting Rule-based Manager for Device Events and Files... [ 7.716118] systemd[1]: Mounted /tmp. [ 7.721130] systemd[1]: Finished Platform Persistent Storage Archival. [ 7.727152] systemd[1]: Finished Load/Save Random Seed. [ 7.727455] systemd[1]: Condition check resulted in First Boot Complete being skipped. [ 7.790932] systemd[1]: Started Rule-based Manager for Device Events and Files. [ 7.805552] systemd[1]: Finished Coldplug All udev Devices. [ 7.809386] systemd[1]: Starting Helper to synchronize boot up for ifupdown... [ 7.812705] systemd[1]: Starting Show Plymouth Boot Screen... [ 7.814768] systemd[1]: Finished Helper to synchronize boot up for ifupdown. [ 7.835371] systemd[1]: Started Show Plymouth Boot Screen. [ 7.835677] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 7.835874] systemd[1]: Started Forward Password Requests to Plymouth Directory Watch. [ 7.835930] systemd[1]: Reached target Local Encrypted Volumes. [ 7.867154] systemd[1]: Created slice Slice /system/systemd-backlight. [ 7.870843] systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:backlight... [ 7.880008] systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:backlight_1... [ 7.881529] systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:backlight. [ 7.886824] systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:backlight_1. [ 7.967035] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 7.967099] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 7.968527] systemd[1]: Found device /dev/ttyFIQ0. [ 7.982093] systemd[1]: Found device Samsung SSD 960 EVO 500GB armbi_boot. [ 7.989448] systemd[1]: Starting File System Check on /dev/disk/by-uuid/1BD1-7F33... [ 7.995246] systemd[1]: Reached target Hardware activated USB gadget. [ 7.996826] systemd[1]: Started File System Check Daemon to report status. [ 8.019359] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 8.019578] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 8.028901] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 8.033481] systemd[1]: Finished File System Check on /dev/disk/by-uuid/1BD1-7F33. [ 8.037439] systemd[1]: Mounting /boot... [ 8.039285] FAT-fs (nvme0n1p1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive! [ 8.042634] systemd[1]: Mounted /boot. [ 8.042847] systemd[1]: Reached target Local File Systems. [ 8.044428] systemd[1]: Starting Armbian leds state... [ 8.046070] systemd[1]: Starting Armbian ZRAM config... [ 8.047616] systemd[1]: Starting Set console font and keymap... [ 8.049297] systemd[1]: Starting Raise network interfaces... [ 8.050939] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data... [ 8.051075] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped. [ 8.055660] systemd[1]: Starting Set Up Additional Binary Formats... [ 8.055932] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 8.056073] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 8.057872] systemd[1]: Finished Set console font and keymap. [ 8.062678] systemd[1]: Received SIGRTMIN+20 from PID 297 (plymouthd). [ 8.064035] systemd[1]: Finished Armbian leds state. [ 8.065646] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data. [ 8.066234] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 542 (systemd-binfmt) [ 8.068955] systemd[1]: Mounting Arbitrary Executable File Formats File System... [ 8.077246] systemd[1]: Mounted Arbitrary Executable File Formats File System. [ 8.079949] systemd[1]: Finished Set Up Additional Binary Formats. [ 8.135794] zram0: detected capacity change from 0 to 4031107072 [ 8.178324] Adding 3936624k swap on /dev/zram0. Priority:5 extents:1 across:3936624k SS [ 8.185763] systemd[1]: Finished Raise network interfaces. [ 8.189238] zram: Added device: zram1 [ 8.309758] zram1: detected capacity change from 0 to 52428800 [ 8.346501] systemd[1]: Finished Armbian ZRAM config. [ 8.351798] systemd[1]: Starting Armbian memory supported logging... [ 8.414270] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard [ 8.691595] vendor storage:20190527 ret = -1 [ 8.922713] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 8.922882] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 8.922998] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 10.007597] systemd[1]: Finished Armbian memory supported logging. [ 10.019029] systemd[1]: Starting Journal Service... [ 10.166317] systemd[1]: Started Journal Service. [ 10.196341] systemd-journald[737]: Received client request to flush runtime journal. [ 10.538805] of_dma_request_slave_channel: dma-names property of node '/serial@febc0000' missing or empty [ 10.538897] dw-apb-uart febc0000.serial: failed to request DMA, use interrupt mode [ 10.568503] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller [ 10.568511] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 7 [ 10.568588] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000202002010010 [ 10.568609] xhci-hcd xhci-hcd.9.auto: irq 138, io mem 0xfc000000 [ 10.568737] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 10.568739] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 10.568741] usb usb7: Product: xHCI Host Controller [ 10.568742] usb usb7: Manufacturer: Linux 5.10.160-rk35xx xhci-hcd [ 10.568744] usb usb7: SerialNumber: xhci-hcd.9.auto [ 10.570070] hub 7-0:1.0: USB hub found [ 10.570082] hub 7-0:1.0: 1 port detected [ 10.570180] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller [ 10.570184] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 8 [ 10.570189] xhci-hcd xhci-hcd.9.auto: Host supports USB 3.0 SuperSpeed [ 10.570213] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM. [ 10.570250] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 [ 10.570252] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 10.570254] usb usb8: Product: xHCI Host Controller [ 10.570255] usb usb8: Manufacturer: Linux 5.10.160-rk35xx xhci-hcd [ 10.570257] usb usb8: SerialNumber: xhci-hcd.9.auto [ 10.570384] hub 8-0:1.0: USB hub found [ 10.570395] hub 8-0:1.0: 1 port detected [ 10.725820] rk_gmac-dwmac fe1c0000.ethernet eth0: PHY [stmmac-1:01] driver [YT8531 Gigabit Ethernet] (irq=POLL) [ 10.728005] dwmac4: Master AXI performs any burst length [ 10.728026] rk_gmac-dwmac fe1c0000.ethernet eth0: No Safety Features support found [ 10.728044] rk_gmac-dwmac fe1c0000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported [ 10.728402] rk_gmac-dwmac fe1c0000.ethernet eth0: registered PTP clock [ 10.728752] rk_gmac-dwmac fe1c0000.ethernet eth0: configuring for phy/rgmii-rxid link mode [ 10.818307] usb 7-1: new full-speed USB device number 2 using xhci-hcd [ 10.963111] usb 7-1: New USB device found, idVendor=046d, idProduct=c336, bcdDevice= 9.00 [ 10.963121] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 10.963125] usb 7-1: Product: Gaming Keyboard G213 [ 10.963129] usb 7-1: Manufacturer: Logitech [ 10.963133] usb 7-1: SerialNumber: 0F5B30783330 [ 10.974026] input: Logitech Gaming Keyboard G213 as /devices/platform/usbdrd3_0/fc000000.usb/xhci-hcd.9.auto/usb7/7-1/7-1:1.0/0003:046D:C336.0004/input/input11 [ 10.978577] ttyFIQ ttyFIQ0: tty_port_close_start: tty->count = 1 port count = 2 [ 10.990543] mali fb000000.gpu: Loading Mali firmware 0x1010000 [ 10.992466] mali fb000000.gpu: Mali firmware git_sha: a9b9d413d30169284dfbc5c68e8c65fdaeca28b7 [ 11.028764] hid-generic 0003:046D:C336.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech Gaming Keyboard G213] on usb-xhci-hcd.9.auto-1/input0 [ 11.030480] input: Logitech Gaming Keyboard G213 Keyboard as /devices/platform/usbdrd3_0/fc000000.usb/xhci-hcd.9.auto/usb7/7-1/7-1:1.1/0003:046D:C336.0005/input/input12 [ 11.085343] input: Logitech Gaming Keyboard G213 Consumer Control as /devices/platform/usbdrd3_0/fc000000.usb/xhci-hcd.9.auto/usb7/7-1/7-1:1.1/0003:046D:C336.0005/input/input13 [ 11.085659] hid-generic 0003:046D:C336.0005: input,hiddev98,hidraw4: USB HID v1.11 Keyboard [Logitech Gaming Keyboard G213] on usb-xhci-hcd.9.auto-1/input1 [ 13.015584] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 13.015593] Bluetooth: BNEP filters: protocol multicast [ 13.015609] Bluetooth: BNEP socket layer initialized [ 13.767228] rk_gmac-dwmac fe1c0000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx [ 13.767260] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready ### interrupts: CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7 9: 0 0 0 0 0 0 0 0 GICv3 25 Level vgic 11: 0 0 0 0 0 0 0 0 GICv3 30 Level kvm guest ptimer 12: 0 0 0 0 0 0 0 0 GICv3 27 Level kvm guest vtimer 13: 124155 75513 62643 51254 37579 33646 35915 40835 GICv3 26 Level arch_timer 14: 34015 26335 19281 14524 5901 8624 6424 10406 GICv3 321 Level rk_timer 15: 0 0 0 0 0 0 0 0 GICv3 23 Level arm-pmu 16: 654 0 0 0 0 0 0 0 GICv3 105 Level dmc 17: 36480 0 0 0 0 0 0 0 GICv3 126 Level fb000000.gpu 18: 1 0 0 0 0 0 0 0 GICv3 125 Level fb000000.gpu 19: 102469 0 0 0 0 0 0 0 GICv3 124 Level fb000000.gpu 20: 2 0 0 0 0 0 0 0 GICv3 247 Level ehci_hcd:usb1 21: 21290 0 0 0 0 0 0 0 GICv3 248 Level ohci_hcd:usb3 22: 0 0 0 0 0 0 0 0 GICv3 250 Level ehci_hcd:usb2 23: 0 0 0 0 0 0 0 0 GICv3 251 Level ohci_hcd:usb4 24: 0 0 0 0 0 0 0 0 GICv3 425 Level rockchip_usb2phy 25: 17 0 0 0 0 0 0 0 GICv3 423 Level rockchip_usb2phy 26: 2 0 0 0 0 0 0 0 GICv3 424 Level rockchip_usb2phy 27: 124968 0 0 0 0 0 0 0 GICv3 349 Level fd880000.i2c 29: 0 0 0 0 0 0 0 0 GICv3 142 Level fdab9000.iommu, fdab0000.npu 30: 0 0 0 0 0 0 0 0 GICv3 143 Level fdab9000.iommu, fdab0000.npu 31: 0 0 0 0 0 0 0 0 GICv3 144 Level fdab9000.iommu, fdab0000.npu 32: 0 0 0 0 0 0 0 0 GICv3 152 Level fdb50000.vepu 33: 0 0 0 0 0 0 0 0 GICv3 151 Level fdb50400.vdpu 34: 0 0 0 0 0 0 0 0 GICv3 150 Level fdb50800.iommu 35: 0 0 0 0 0 0 0 0 GICv3 146 Level fdb60f00.iommu, rga3_core0 36: 0 0 0 0 0 0 0 0 GICv3 147 Level fdb70f00.iommu, rga3_core1 37: 0 0 0 0 0 0 0 0 GICv3 148 Level rga2 38: 0 0 0 0 0 0 0 0 GICv3 161 Level fdb90000.jpegd 39: 0 0 0 0 0 0 0 0 GICv3 162 Level fdb90480.iommu 40: 0 0 0 0 0 0 0 0 GICv3 154 Level fdba0000.jpege-core 41: 0 0 0 0 0 0 0 0 GICv3 153 Level fdba0800.iommu 42: 0 0 0 0 0 0 0 0 GICv3 156 Level fdba4000.jpege-core 43: 0 0 0 0 0 0 0 0 GICv3 155 Level fdba4800.iommu 44: 0 0 0 0 0 0 0 0 GICv3 158 Level fdba8000.jpege-core 45: 0 0 0 0 0 0 0 0 GICv3 157 Level fdba8800.iommu 46: 0 0 0 0 0 0 0 0 GICv3 160 Level fdbac000.jpege-core 47: 0 0 0 0 0 0 0 0 GICv3 159 Level fdbac800.iommu 48: 0 0 0 0 0 0 0 0 GICv3 149 Level fdbb0800.iommu, fdbb0000.iep 49: 0 0 0 0 0 0 0 0 GICv3 133 Level fdbd0000.rkvenc-core 50: 0 0 0 0 0 0 0 0 GICv3 131 Level fdbdf000.iommu 51: 0 0 0 0 0 0 0 0 GICv3 132 Level fdbdf000.iommu 52: 0 0 0 0 0 0 0 0 GICv3 136 Level fdbe0000.rkvenc-core 53: 0 0 0 0 0 0 0 0 GICv3 134 Level fdbef000.iommu 54: 0 0 0 0 0 0 0 0 GICv3 135 Level fdbef000.iommu 55: 0 0 0 0 0 0 0 0 GICv3 127 Level fdc38100.rkvdec-core 56: 0 0 0 0 0 0 0 0 GICv3 128 Level fdc38700.iommu 57: 0 0 0 0 0 0 0 0 GICv3 129 Level fdc48100.rkvdec-core 58: 0 0 0 0 0 0 0 0 GICv3 130 Level fdc48700.iommu 59: 0 0 0 0 0 0 0 0 GICv3 140 Level av1d-master 62: 0 0 0 0 0 0 0 0 GICv3 141 Level fdca0000.iommu 63: 0 0 0 0 0 0 0 0 GICv3 163 Level rkisp_hw 64: 0 0 0 0 0 0 0 0 GICv3 165 Level rkisp_hw 65: 0 0 0 0 0 0 0 0 GICv3 166 Level rkisp_hw 66: 0 0 0 0 0 0 0 0 GICv3 164 Level fdcb7f00.iommu 67: 0 0 0 0 0 0 0 0 GICv3 167 Level rkisp_hw 68: 0 0 0 0 0 0 0 0 GICv3 169 Level rkisp_hw 69: 0 0 0 0 0 0 0 0 GICv3 170 Level rkisp_hw 70: 0 0 0 0 0 0 0 0 GICv3 168 Level fdcc7f00.iommu 71: 0 0 0 0 0 0 0 0 GICv3 187 Level rkcifhw 72: 0 0 0 0 0 0 0 0 GICv3 145 Level fdce0800.iommu 73: 37932 0 0 0 0 0 0 0 GICv3 188 Level fdd97e00.iommu, fdd90000.vop 75: 0 0 0 0 0 0 0 0 GICv3 217 Level i2s 76: 0 0 0 0 0 0 0 0 GICv3 193 Level fde50000.dp 77: 0 0 0 0 0 0 0 0 GICv3 201 Level fde80000.hdmi 78: 0 0 0 0 0 0 0 0 GICv3 202 Level dw-hdmi-qp-cec 79: 0 0 0 0 0 0 0 0 GICv3 203 Level fde80000.hdmi 80: 431760 0 0 0 0 0 0 0 GICv3 204 Level fde80000.hdmi 81: 0 0 0 0 0 0 0 0 GICv3 392 Level dw-hdmi-qp-hpd 82: 1 0 0 0 0 0 0 0 GICv3 285 Level pcie-sys 87: 258740 0 0 0 0 0 0 0 GICv3 266 Level eth0 88: 0 0 0 0 0 0 0 0 GICv3 265 Level eth0 89: 673 0 0 0 0 0 0 0 GICv3 238 Level fe2b0000.spi 90: 0 0 0 0 0 0 0 0 GICv3 235 Level dw-mci 92: 0 0 0 0 0 0 0 0 GICv3 212 Level i2s 93: 0 0 0 0 0 0 0 0 GICv3 213 Level i2s 94: 414 0 0 0 0 0 0 0 GICv3 118 Level fea10000.dma-controller 95: 0 0 0 0 0 0 0 0 GICv3 119 Level fea10000.dma-controller 96: 421 0 0 0 0 0 0 0 GICv3 120 Level fea30000.dma-controller 97: 0 0 0 0 0 0 0 0 GICv3 121 Level fea30000.dma-controller 98: 68 0 0 0 0 0 0 0 GICv3 351 Level feaa0000.i2c 99: 0 0 0 0 0 0 0 0 GICv3 347 Edge feaf0000.watchdog 100: 51552 0 0 0 0 0 0 0 GICv3 360 Level feb20000.spi 101: 1 0 0 0 0 0 0 0 GICv3 372 Level 103: 0 0 0 0 0 0 0 0 GICv3 429 Level rockchip_thermal 104: 6303 0 0 0 0 0 0 0 GICv3 430 Level fec10000.saradc 105: 442 0 0 0 0 0 0 0 GICv3 355 Level fec80000.i2c 106: 2 0 0 0 0 0 0 0 GICv3 356 Level fec90000.i2c 107: 1689 0 0 0 0 0 0 0 GICv3 122 Level fed10000.dma-controller 108: 0 0 0 0 0 0 0 0 GICv3 123 Level fed10000.dma-controller 114: 0 0 0 0 0 0 0 0 GICv3 455 Edge debug-signal 115: 0 0 0 0 0 0 0 0 GICv3 365 Level debug 125: 0 0 0 0 0 0 0 0 ITS-MSI 570425352 Edge PCIe PME 126: 0 16 0 0 0 0 0 0 ITS-MSI 570949632 Edge nvme0q0 127: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 7 Level rk806 128: 0 0 0 0 0 0 0 0 rk806 0 Edge rk805_pwrkey_fall 129: 0 0 0 0 0 0 0 0 rk806 1 Edge rk805_pwrkey_rise 130: 5308 0 0 0 0 0 0 0 ITS-MSI 570949633 Edge nvme0q1 131: 0 0 3810 0 0 0 0 0 ITS-MSI 570949634 Edge nvme0q2 132: 0 0 0 2207 0 0 0 0 ITS-MSI 570949635 Edge nvme0q3 133: 0 0 0 0 4086 0 0 0 ITS-MSI 570949636 Edge nvme0q4 134: 0 0 0 0 0 3157 0 0 ITS-MSI 570949637 Edge nvme0q5 135: 0 0 0 0 0 0 2924 0 ITS-MSI 570949638 Edge nvme0q6 136: 0 0 0 0 0 0 0 3994 ITS-MSI 570949639 Edge nvme0q7 137: 0 0 0 0 0 0 0 0 rk806 7 Level rk806_vb_low 138: 376 0 0 0 0 0 0 0 GICv3 252 Level xhci-hcd:usb7 139: 0 0 0 0 0 0 0 0 GICv3 254 Level xhci-hcd:usb5 141: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 27 Level fsc_interrupt_int_n 142: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 8 Level hym8563 144: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 29 Edge headset_detect IPI0: 61649 199095 181561 147772 22462 16781 21565 20768 Rescheduling interrupts IPI1: 68082 51616 48234 44404 170756 92563 170198 97217 Function call interrupts IPI2: 0 0 0 0 0 0 0 0 CPU stop interrupts IPI3: 0 0 0 0 0 0 0 0 CPU stop (for crash dump) interrupts IPI4: 2562 7808 7168 7068 3454 4775 3914 4950 Timer broadcast interrupts IPI5: 10294 4581 3679 3251 4602 3376 4526 3533 IRQ work interrupts IPI6: 0 0 0 0 0 0 0 0 CPU wake-up interrupts Err: 0 Edited August 8, 2023 by Werner add spoiler 0 Quote
obiwantoby Posted August 8, 2023 Posted August 8, 2023 The normal apt-get update cycle this time around also caused issues. For me my networking was unstable. Remote SSH would time out and keystrokes would be 5 - 30 seconds delayed. Not sure what happened here. 0 Quote
- Posted August 8, 2023 Posted August 8, 2023 probably related but on a fresh install of 23.5 jammy, hardware acceleration is enabled but hardware video decode isnt in chromium - this solves the hw video decode problem with sd videos having a green screen. in your glxinfos it says "Accelerated: yes". i just assumed a developer disabled the hw video decode becuz i doubt the ppa video drivers will ever get updated so that green screen bug is there forever until mainline video drivers happen (which i imagine will also take forever). 0 Quote
