Hardik Gohil Posted August 10, 2023 Posted August 10, 2023 Hello All, root:# hwclock --systohc root:# while true; do date; hwclock -r; sleep 60; done observing drift of 1 sec. even tried this https://github.com/armbian/build/pull/2352/commits/59cdf431ef691d67d649adbfaf973f9d451823bc#diff-dc13c5522aed383d1b20662d765c5be9f2635553256069dce64f29be94f89b69 specs: Armada 38x RTC driver ARM_GLOBAL_TIMER Board : Marvell Armada A385 DB AP Kernel : 4.14 community help will be grateful Regards Hardik 0 Quote
ag123 Posted August 10, 2023 Posted August 10, 2023 1 sec every 60 sec? that's a pretty big drift. oh and btw hwclock seemed to have some ways to adjust for drift, but that'd probably means you need to sync your time to NTP Quote Usage: hwclock [function] [option...] Time clocks utility. Functions: -r, --show display the RTC time --get display drift corrected RTC time --set set the RTC according to --date -s, --hctosys set the system time from the RTC -w, --systohc set the RTC from the system time --systz send timescale configurations to the kernel -a, --adjust adjust the RTC to account for systematic drift --param-get <param> display the RTC parameter --param-set <param>=<value> set the RTC parameter --predict predict the drifted RTC time according to --date Options: -u, --utc the RTC timescale is UTC -l, --localtime the RTC timescale is Local -f, --rtc <file> use an alternate file to /dev/rtc0 --directisa use the ISA bus instead of /dev/rtc0 access --date <time> date/time input for --set and --predict --delay <sec> delay used when set new RTC time --update-drift update the RTC drift factor --noadjfile do not use /etc/adjtime --adjfile <file> use an alternate file to /etc/adjtime --test dry run; implies --verbose -v, --verbose display more details -h, --help display this help -V, --version display version Arguments: <param> is either a numeric RTC parameter value or one of these aliases: - features: supported features (0x0) - correction: time correction (0x1) - bsm: backup switch mode (0x2) See Kernel's include/uapi/linux/rtc.h for parameters and values. <param> and <value> accept hexadecimal values if prefixed with 0x, otherwise decimal. For more details see hwclock(8). Expand 0 Quote
Hardik Gohil Posted August 10, 2023 Author Posted August 10, 2023 NTP sync is already enabled. 0 Quote
ag123 Posted August 10, 2023 Posted August 10, 2023 (edited) for some reasons I didn't find related docs in the company's web site https://www.marvell.com/products/infrastructure-processors/armada-38x.html those docs links are apparently not accessible but instead stumbled into a copy elsewhere in a web search https://ulli-kroll.de/Downloads/NAS326/A38x-Functional-Spec-PU0A.pdf the interesting section is chapter 26 Real time clock pages 303 accordingly, the real time clock runs on a 32khz crystal, so check your board to see if it is there. if it isn't there, maybe it isn't using the real time clock after all. And that if it is there, find in the source codes for the real time clock implementation, apparently some details about the RTC registers are documented, so those should after all match the func spec. And perhaps you may find your way around the code to 'tweak' the register settings etc. if it is a 'pseudo RTC' i.e. didn't exist, then it is probably a 'simulated' h/w clock which may be written in s/w, it'd take reading the codes to find out that curious facts hope that helps Edited August 10, 2023 by ag123 0 Quote
Hardik Gohil Posted August 10, 2023 Author Posted August 10, 2023 (edited) The board is using armada 38x RTC driver and it can be found in kernel logs. Still I am not able to figure out the fix Edited August 11, 2023 by Hardik Gohil 0 Quote
Heisath Posted August 15, 2023 Posted August 15, 2023 Are you using dvfs on the board? IIRC changing the CPU core speed did lead to some problems with timekeeping. I think we had a patch for that years ago. Maybe try a newer kernel? 0 Quote
Hardik Gohil Posted August 17, 2023 Author Posted August 17, 2023 I am not using dvfs. did you mean this patch https://github.com/armbian/build/pull/2352/commits/59cdf431ef691d67d649adbfaf973f9d451823bc#diff-dc13c5522aed383d1b20662d765c5be9f2635553256069dce64f29be94f89b69. I have tried that too which kernel version to try ? 0 Quote
Hardik Gohil Posted September 26, 2023 Author Posted September 26, 2023 I have tried with new version too still issue is there 0 Quote
