Peter Gregory Posted August 12, 2023 Posted August 12, 2023 I got my 320x240 ILI9341 touchscreen to work with the image from the OrangePI site: Armbian_23.5.2_Orangepizero2_bookworm_legacy_4.9.318_minimal The display is one I bought from Amazon Hosyond 2.8 Inches TFT LCD Touch Screen Shield Display Module 320x240 SPI Serial ILI9341 with Touch Pen Compatible with Arduino R3/Mega2560 Development Board This document was very helpful getting the display set up on the OPZero 2: https://tienda.tettsa.gt/wp-content/uploads/2022/08/OrangePi_Zero2_H616_User-manual_v3.7.pdf I still don't have the touch part working. If anyone has success getting 2 selects working with SPI1 on OPZero2 and touch working, let me know. The basic steps to getting the SPI LCD to work are: 1) wire up the display to the OPZero2 2.8 Inch TFT SPI 240x320 => OPZero2 1 - VCC => (1) 3.3v 2 - GND => (6) Gnd 3 - CS => (24) Spi1 CS 4 - RESET => (7) GPIO 6 5 - DC => (11) GPIO 1 6 - SDI (MOSI) => (19) Spi1 MOSI 7 - SCLK => (23) Spi1 CLK 8 - LED => (13) GPIO 0 9 - SDO (MISO) => (21) Spi1 MISO 10 - T_CLK 11 - T_CS 12 - T_DIN 13 - T_DO 14 - T_IRQ 2) Install Armbian_23.5.2_Orangepizero2_bookworm_legacy_4.9.318_minimal - must be legacy kernel to work 4.9 is OK 3) sudo apt install fbi kbd armbian-config 4) sudo armbian-config set up desktop now to make the LCD work and start on boot 5) sudo nano /boot/armbianEnv.txt overlays=spi-spidev param_spidev_spi_bus=1 param_spidev_spi_cs=1 extraargs=fbcon=map:1 6) sudo nano /etc/modules-load.d/fbtft.conf fbtft fbtft_device 7) sudo nano etc/modprobe.d/fbtft.conf options fbtft_device custom name=fb_ili9341 gpios=dc:70,reset:73,led:69 speed=16000000 busnum=1 cs=1 bgr=1 txtbuflen-32768 fps=10 rotate=90 😎 sudo dpkg-reconfigure console-setup select UTF-8 select Guess optimal character set select terminus select 6/12 9) sudo nano /usr/share/X11/xorg.conf.d/99-fbdev.conf Section "Device" Identifier "myfb" Driver "fbdev" Option "fbdev" "/dev/fb1" EndSection Now when it boots it should boot to the SPI LCD Display 0 Quote
joaopaulo98 Posted September 15, 2023 Posted September 15, 2023 Thank you. Im using orange pi zero 2 too. it worked well on this 1.77 tft lcd display with driver st7735 using this code: options fbtft_device custom name=fb_st7735r busnum=1 cs=1 gpios=reset:73,dc:70 rotate=90 speed=16000000 bgr=1 txbuflen=65536 Ps: The pin 7 (reset) GPIO is PC9 and pin 11 (dc) is PC6 0 Quote
Prze87mo Posted November 29, 2023 Posted November 29, 2023 Hello I use this same orangepizero 2 diffrent screen but working and I don't know how I can configuration Touch on this screen? anyone can help? 0 Quote
robertoj Posted July 16, 2024 Posted July 16, 2024 From the Amazon and page, it looks like the lcd panel have a digitizer chip (instead of bare connection to the panel’s analog XY outputs, like others). Can you see the model of that chip U2? definitely needs a second SPI interface in the orange pi, or bitbanging. 0 Quote
