I got my 320x240 ILI9341 touchscreen to work with the image from the OrangePI site:
Armbian_23.5.2_Orangepizero2_bookworm_legacy_4.9.318_minimal
The display is one I bought from Amazon
Hosyond 2.8 Inches TFT LCD Touch Screen Shield Display Module 320x240 SPI Serial ILI9341 with Touch Pen Compatible with Arduino R3/Mega2560 Development Board
This document was very helpful getting the display set up on the OPZero 2:
https://tienda.tettsa.gt/wp-content/uploads/2022/08/OrangePi_Zero2_H616_User-manual_v3.7.pdf
I still don't have the touch part working.  If anyone has success getting 2 selects working with SPI1 on OPZero2 and touch working, let me know.
The basic steps to getting the SPI LCD to work are:
1) wire up the display to the OPZero2
2.8 Inch TFT SPI 240x320 => OPZero2
1 - VCC   =>  (1) 3.3v
2 - GND  =>   (6) Gnd
3 - CS      =>   (24) Spi1 CS
4 - RESET  =>   (7) GPIO 6
5 - DC    =>     (11) GPIO 1
6 - SDI (MOSI) =>    (19) Spi1 MOSI
7 - SCLK  =>  (23) Spi1 CLK
8 - LED    =>    (13) GPIO 0
9 - SDO (MISO) =>    (21) Spi1 MISO
10 - T_CLK
11 - T_CS
12 - T_DIN
13 - T_DO
14 - T_IRQ
2) Install Armbian_23.5.2_Orangepizero2_bookworm_legacy_4.9.318_minimal - must be legacy kernel to work 4.9 is OK
3) sudo apt install fbi kbd armbian-config
4) sudo armbian-config
set up desktop
now to make the LCD work and start on boot
5) sudo nano /boot/armbianEnv.txt
overlays=spi-spidev
param_spidev_spi_bus=1
param_spidev_spi_cs=1
extraargs=fbcon=map:1
6) sudo nano /etc/modules-load.d/fbtft.conf
fbtft
fbtft_device
7) sudo nano etc/modprobe.d/fbtft.conf
options fbtft_device custom name=fb_ili9341 gpios=dc:70,reset:73,led:69 speed=16000000 busnum=1 cs=1 bgr=1 txtbuflen-32768 fps=10 rotate=90
😎 sudo dpkg-reconfigure console-setup
select UTF-8
select Guess optimal character set
select terminus
select 6/12
9) sudo nano /usr/share/X11/xorg.conf.d/99-fbdev.conf
Section "Device"
  Identifier "myfb"
  Driver "fbdev"
  Option "fbdev" "/dev/fb1"
EndSection
Now when it boots it should boot to the SPI LCD Display
Thank you. Im using orange pi zero 2 too. it worked well on this 1.77 tft lcd display with driver st7735 using this code:
options fbtft_device custom name=fb_st7735r busnum=1 cs=1 gpios=reset:73,dc:70 rotate=90 speed=16000000 bgr=1 txbuflen=65536
Ps:  The pin 7 (reset) GPIO is PC9 and pin 11 (dc) is PC6
From the Amazon and page, it looks like the lcd panel have a digitizer chip (instead of bare connection to the panel’s analog XY outputs, like others).
Can you see the model of that chip U2?
definitely needs a second SPI interface in the orange pi, or bitbanging.
