I'm running armbian 23.08 bookworm on an orange pi 5 plus.  I'm trying to run VMs that boot with UEFI, but these are hanging.  I suspect a bug in the vendor kernel (5.10.160-rk35xx), since this works fine on an AWS bare metal arm64 host.
Example:
$ sudo apt install qemu-system qemu-efi-aarch64
$ cp /usr/share/AAVMF/AAVMF_VARS.fd ./aavmf_efivars.fd
$ qemu-system-aarch64 \
    -machine virt \
    -cpu max \
    -drive if=pflash,unit=0,format=raw,readonly=on,file=/usr/share/AAVMF/AAVMF_CODE.fd \
    -drive file=aavmf_efivars.fd,format=raw,if=pflash
    -net none \
    -nographic \
    -enable-kvm
This hangs for me (to exit press C-a x).  If I remove `-enable-kvm`, the UEFI shell loads.
Yes. Vendor kernels are traditionally a pile of sh*, as cheap production as possible. We provide images with experimental kernels v6.5 to try out (at the end of download page). There it might work, but don't complain about several non/badly working things - its not production quality / stability. We are running several GitHub runners on two devices. With vendor kernel, this job was very fragile, while here, so far, it just work.
Oh awesome - I had to dig through the github artifacts to find the OrangePi 5 Plus trixie image.  I can confirm this fixes the issue: the UEFI firmware boots up as expected with kvm.
Thanks!
