I have this tvbox model as per the attached photos. I tried to run the image: Armbian_23.5.2_Orangepizero2_bookworm_current_6.1.30
but the error appeared:
U-Boot SPL 2021.04 (May 25 2023 - 13:06:08 +0200)
DRAM:This DRAM setup is currently not supported.
I was able to extract the dtb files along with the  boot.img and bootloader.img. but I'm
sending the files that I dumped. The link is below because I couldn't
attach it here.from this tvbox. can anybody help me?
dumped dtb and boot.img and bootloader.img: https://we.tl/t-xp8WGoP80f
bootik316.txtUnavailable
Posted (edited)
well, after many attempts I managed to boot Armbian on the TVbox with emcp chip, you really have to change the parameters in defconfig and recompile to generate ou-boot-sunxi-with-spl.bin,but the internal network card still doesn't work from the ik316 which is the same h616 used network usb and the HDMI output doesn't work.
The latest version of Armbian: Armbian_23.8.3_Orangepizero2_b gives error after u-boot:
starting systemd-udevd version 252.12-1~deb12u1
[    2.600465] thermal thermal_zone0: gpu-thermal: critical temperature reached, shutting down
[    2.608985] reboot: HARDWARE PROTECTION shutdown (Temperature too high)
I used the version Armbian 22.08.6 Jammy with bleeding edge Linux 5.19.16-sunxi64 and with modified spl.bin
Edited by javaxsousa
  On 10/6/2023 at 11:59 PM, javaxsousa said:
The latest version of Armbian: Armbian_23.8.3_Orangepizero2_b gives error after u-boot: starting systemd-udevd version 252.12-1~deb12u1 [ 2.600465] thermal thermal_zone0: gpu-thermal: critical temperature reached, shutting down [ 2.608985] reboot: HARDWARE PROTECTION shutdown (Temperature too high)
Expand
You didn't mention what was the kernel you used that gave you the issue. The error message is simply stating that your gpu overheated and hence the system is shutting down. May be your dtb needs some adjustment to make proper use of thermal subsystem and frequency scaling for gpu.
Posted (edited)
i used kernel: Linux version 5.19.16-sunxi64  with Armbian_22.08.7_Orangepizero2_jammy_edge_5.19.16.img, this version works  but HDMI ,network and audio not work
Hello! @javaxsousa Could you please share the image you manage to boot with your TV Box? I have an IK316-EMCP_V4.1 and I've tried several images and none of them seem to work.
I'd like to to try the one you built since the hardware seem to be quite similar.
Thank you in advance!
Posted (edited)
@andre2b sorry my delay of answer this question , but I used image from armbian but I compile u-boot-sunxi-with-spl.bin and make this command:
dd if=u-boot-sunxi-with-spl.bin of=/dev/yourcard bs=1k seek=8 conv=fsync on sd card with armbian installed.
I attached a copy of u-boot-sunxi-with-spl.bin here, try it and see if it works
I didn't send the complete image because I still haven't been able to recompile it with the complete Armbian.
u-boot-sunxi-with-spl.binFetching info...
Thanks for the reply @javaxsousa, but unfortunately it didn´t work.
I Downloaded the image from https://armbian.hosthatch.com/archive/orangepizero2/archive/Armbian_22.08.7_Orangepizero2_jammy_edge_5.19.16.img.xz , burned it to the sd card and run your command but I still have a blank screen :(
I'll keep checking the forum for any progress you or some one else makes, and if I can make it work I'll also leave a message.
Thanks
@andre2b
From what I could see, your TV box does not have the EMC chip, so I suggest testing with other images, because despite showing Ik316, the chip is actually an H313/H616.
Test is below too
https://github.com/warpme/miniarch
  On 1/30/2024 at 1:22 PM, javaxsousa said:
sorry my delay of answer this question, but above i put my config, i used "u-boot-2021.07" version
Expand
I get this error:
make[2]: *** No rule to make target 'dts/upstream/src/arm64/allwinner/sun50i-h616-tanix-tx6s.dtb', needed by 'dtbs'.  Stop.
Where can I get this file sun50i-h616-tanix-tx6s.dts? I use the sources from the official repository u-boot.
Posted (edited)
It's there. You just need to remove the "+".
I used this shell script command. Editing it by hand would take forever. This removes the first character on each line.
sed 's/^.\{1\}//' 152-add-tanix-tx6s-defconfig.patch > output.patch
/dts/upstream/src/arm64/allwinner/sun50i-h616-tanix-tx6s.dts
// SPDX-License-Identifier: (GPL-2.0+ or MIT)
 * Copyright (C) 2021 Arm Ltd.
/dts-v1/;
#include "sun50i-h616.dtsi"
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/interrupt-controller/arm-gic.h>
#include <dt-bindings/leds/common.h>
	model = "Tanix TX6s";
	compatible = "tanix,tx6s", "allwinner,sun50i-h616";
	aliases {
		mmc0 = &mmc0;
		mmc1 = &mmc1;
		mmc2 = &mmc2;
		ethernet0 = &emac1;
		serial0 = &uart0;
	chosen {
		stdout-path = "serial0:115200n8";
	reg_vcc5v: vcc5v {
		/* board wide 5V supply directly from the DC input */
		compatible = "regulator-fixed";
		regulator-name = "vcc-5v";
		regulator-min-microvolt = <5000000>;
		regulator-max-microvolt = <5000000>;
		regulator-always-on;
&ehci0 {
	status = "okay";
&ehci2 {
	status = "okay";
&ir {
	status = "okay";
&emac1 {
	pinctrl-names = "default";
	pinctrl-0 = <&rmii_pins>;
	phy-mode = "rmii";
	phy-handle = <&rmii_phy>;
	phy-supply = <&reg_aldo1>;
	allwinner,rx-delay-ps = <3100>;
	allwinner,tx-delay-ps = <700>;
	status = "okay";
&mdio1 {
	rmii_phy: ethernet-phy@1 {
		compatible = "ethernet-phy-ieee802.3-c22";
		reg = <1>;
&r_i2c {
	status = "okay";
	axp305_1: pmic@36 {
		compatible = "x-powers,axp305", "x-powers,axp805",
		"x-powers,axp806";
		reg = <0x36>;
		/* dummy interrupt to appease the driver for now */
		interrupts = <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>;
		interrupt-controller;
		#interrupt-cells = <1>;
&mmc0 {
	vmmc-supply = <&reg_dcdce>;
	//cd-gpios = <&pio 8 16 GPIO_ACTIVE_LOW>;	/* PI16 */
	broken-cd;
	bus-width = <4>;
	status = "okay";
&mmc1 {
	broken-cd;
	bus-width = <4>;
	status = "okay";
&mmc2 {
	bus-width = <8>;
	non-removable;
	cap-mmc-hw-reset;
	status = "okay";
&ohci0 {
	status = "okay";
&ohci2 {
	status = "okay";
&r_rsb {
	status = "okay";
	axp305: pmic@745 {
			     "x-powers,axp806";
		reg = <0x745>;
		x-powers,self-working-mode;
		vina-supply = <&reg_vcc5v>;
		vinb-supply = <&reg_vcc5v>;
		vinc-supply = <&reg_vcc5v>;
		vind-supply = <&reg_vcc5v>;
		vine-supply = <&reg_vcc5v>;
		aldoin-supply = <&reg_vcc5v>;
		bldoin-supply = <&reg_vcc5v>;
		cldoin-supply = <&reg_vcc5v>;
		regulators {
			reg_aldo1: aldo1 {
				regulator-min-microvolt = <3300000>;
				regulator-max-microvolt = <3300000>;
				regulator-name = "vcc-sys";
			reg_aldo2: aldo2 {
				regulator-name = "vcc3v3-ext";
				status = "disabled";
			reg_aldo3: aldo3 {
				regulator-name = "vcc3v3-ext2";
			reg_bldo1: bldo1 {
				regulator-min-microvolt = <1800000>;
				regulator-max-microvolt = <1800000>;
				regulator-name = "vcc1v8";
			reg_bldo2: bldo2 {
				regulator-name = "vcc1v8-2";
			bldo3 {
				/* unused */
			bldo4 {
				/* unused */
			cldo1 {
				regulator-min-microvolt = <2500000>;
				regulator-max-microvolt = <2500000>;
				regulator-name = "vcc2v5";
			cldo2 {
				/* unused */
			cldo3 {
				/* unused */
			reg_dcdca: dcdca {
				regulator-min-microvolt = <810000>;
				regulator-max-microvolt = <1080000>;
				regulator-name = "vdd-cpu";
			reg_dcdcc: dcdcc {
				regulator-name = "vdd-gpu-sys";
			reg_dcdcd: dcdcd {
				regulator-min-microvolt = <1360000>;
				regulator-max-microvolt = <1360000>;
				regulator-name = "vdd-dram";
			reg_dcdce: dcdce {
				regulator-boot-on;
				regulator-name = "vcc-eth-mmc";
			sw {
				/* unused */
&uart0 {
	pinctrl-0 = <&uart0_ph_pins>;
	status = "okay";
&usbotg {
	dr_mode = "host";	/* USB A type receptable */
	status = "okay";
&usbphy {
	status = "okay";
/configs/tanix_tx6s_defconfig
CONFIG_ARM=y
CONFIG_ARCH_SUNXI=y
CONFIG_DEFAULT_DEVICE_TREE="allwinner/sun50i-h616-tanix-tx6s"
CONFIG_SPL=y
CONFIG_SUNXI_DRAM_H616_DDR3_1333=y
CONFIG_DRAM_CLK=648
CONFIG_DRAM_ODT_EN=y
CONFIG_DRAM_SUN50I_H616_UNKNOWN_FEATURE=y
CONFIG_DRAM_SUN50I_H616_BIT_DELAY_COMPENSATION=y
CONFIG_DRAM_SUN50I_H616_READ_CALIBRATION=y
CONFIG_DRAM_SUN50I_H616_DX_ODT=0x03030303
CONFIG_DRAM_SUN50I_H616_DX_DRI=0x0e0e0e0e
CONFIG_DRAM_SUN50I_H616_CA_DRI=0x00001c12
CONFIG_DRAM_SUN50I_H616_ODT_EN=0x00000001
CONFIG_DRAM_SUN50I_H616_TPR0=0xc0000c05
CONFIG_DRAM_SUN50I_H616_TPR2=0x00000000
CONFIG_DRAM_SUN50I_H616_TPR10=0x2f0007
CONFIG_DRAM_SUN50I_H616_TPR11=0xffffdddd
CONFIG_DRAM_SUN50I_H616_TPR12=0xfedf7557
CONFIG_MACH_SUN50I_H616=y
CONFIG_R_I2C_ENABLE=y
CONFIG_SPL_I2C=y
CONFIG_SPL_I2C_SUPPORT=y
CONFIG_SPL_SYS_I2C_LEGACY=y
CONFIG_SYS_I2C_MVTWSI=y
CONFIG_SYS_I2C_SLAVE=0x7f
CONFIG_SYS_I2C_SPEED=100000
CONFIG_PHY_REALTEK=y
CONFIG_SUN8I_EMAC=y
CONFIG_I2C3_ENABLE=y
CONFIG_USB_EHCI_HCD=y
CONFIG_USB_OHCI_HCD=y
CONFIG_USB_MUSB_GADGET=y
CONFIG_SUPPORT_EMMC_BOOT=y
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x40
CONFIG_MMC_SUNXI_SLOT_EXTRA=2
Edited by Nick A
Posted (edited)
@Gustavo Gurgel You need an image with h616,  LPDDR3 and AXP305
@javaxsousa used tanix tx6s because it already had H616 and AXP305. He just needed to change u-boot's tanix tx6s defconfig to support LPDDR3
Android boot log
[3140]DRAM CLK =720 MHZ
[3142]DRAM Type =7 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
So he added these lines
CONFIG_SUNXI_DRAM_LPDDR3=y
CONFIG_SUNXI_DRAM_H616_LPDDR3=y
He should of changed the CLK to 720
CONFIG_DRAM_CLK=258
So the new tanix_tx6s_defconfig for uboot should be
CONFIG_ARM=y
CONFIG_ARCH_SUNXI=y
CONFIG_SPL=y
CONFIG_DRAM_SUN50I_H616_ZQ=0x3f3fdd
CONFIG_DRAM_SUN50I_H616_CA_DRI=0x1f12
CONFIG_DRAM_SUN50I_H616_TPR0=0xc0001002
CONFIG_DRAM_SUN50I_H616_TPR6=0x33808080
CONFIG_DRAM_SUN50I_H616_TPR10=0x2f1107
CONFIG_DRAM_SUN50I_H616_TPR11=0xddddcccc
CONFIG_DRAM_SUN50I_H616_TPR12=0xeddc7665
CONFIG_DRAM_SUN50I_H616_TPR13=0x40
CONFIG_DRAM_CLK=720
CONFIG_SPL_I2C=y
CONFIG_SUN8I_EMAC=y
#CONFIG_USB_EHCI_HCD=y
#CONFIG_USB_OHCI_HCD=y
I have an Armbian build with miniarch patches.
https://github.com/NickAlilovic/build/tree/v20250306
git clone https://github.com/NickAlilovic/build.git --branch v20250306
You need to make an Armbian board config for your box.
build/config/boards/ik316-lpddr3.tvb
# Allwinner H616 TVBox with 1GB of RAM and EMMC
BOARD_NAME="ik316 LPDDR3"
BOARDFAMILY="sun50iw9"
BOARD_MAINTAINER=""
BOOTCONFIG="tanix_tx6s_defconfig"
BOOT_LOGO="desktop"
KERNEL_TARGET="edge"
KERNEL_TEST_TARGET="edge"
FORCE_BOOTSCRIPT_UPDATE="yes"
OVERLAY_PREFIX="sun50i-h616"
You should be able to edit the defconfig patch at the bottom of this file and add your changes.
build/patch/u-boot/u-boot-h616/152-add-tanix-tx6s-defconfig.patch
Also change this line
@@ -0,0 +1,36 @@
to
@@ -0,0 +1,32 @@
This new defconfig is only 32 lines instead of 36.
Edited by Nick A
@Nick A Can you give me a step-by-step guide on how to install Linux on the ik316? I tried using the ISO you provided and u-boot, but it gives me a black screen.
Posted (edited)
Can you provide a picture of your board? I need the AXP chip number.
Write the image to your card. Insert a toothpick into your A/V port you’ll feel a button. Hold it down then plugin your power cord release after a few seconds
Edited by Nick A
Still can't see... can you just read it out to me. It's the very tiny black chip. Between your IK316 and wifi chip SV6256P.
