Peter Andersson Posted August 29, 2023 Posted August 29, 2023 The rock pi 4 is no longer on the download page? https://www.armbian.com/download/?device_support=Supported&tx_maker=radxa&arch=aarch64 There is no rock pi 4 link any more? 0 Quote
Igor Posted August 29, 2023 Posted August 29, 2023 2 hours ago, Peter Andersson said: The rock pi 4 is no longer on the download page? https://www.armbian.com/download/?tx_maker=radxa It is there, just default link from forum goes to "Supported" by default. Probably better to change to all ... Supported download list = 1st class Armbian community support, where we have a dedicated maintainer. If there is none and if vendor doesn't help team of developers that maintains this code, support is declassified into community support. Which means images are assembled, but nobody dedicated look or care to fix troubles. Anyone can submit a fix and it will be integrated at once. If you don't know how but you need something to be fixed, we can help you find someone that will help you in exchange for something ... This is the same as most of other Linux distributions "supports" those boards. We takes "support" more serious. If Armbian Linux can boot on some device, this doesn't mean "Armbian supports it". Usability and quality of working has many different areas. 0 Quote
