Chromium keep asking for consent when doing a search on google, have to re-login after restarting chromium ....
Go to solution Solved by Tony3,
Every time I stop and then start Chromium, do a search on google, or on youtube, there seems to be a deletion of the cookies, and it asks consent again, login again ....
I found lots of possible  solutions on internet about that issue, but none work for me!
I wonder what this is due to, any ideas?
You probably already disabled the automatic deletion in the Chromium settings...
It could be a website setting in Chromium
Because of automatic login? Although I think this only affects access to the the keyring
No user rights to the cookies folder:
sudo chown -R username:username ~/.config/chromium
Some flag set in Chromium: chrome://flags or at /etc/chromium-browser/default
Otherwise just remove it with apt purge ... and check if everything is deleted and reinstall.
  • Solution
I created a new user and it works fine with it.
Then I inpected the user not working and noticed:
   - the .config/chromium is a link to /run/user/1000/tony-chromium
   - df command is showing:
 tmpfs             787428    20416    767012   3% /run/user/1000
overlaid          787428    20416    767012   3% /run/user/1000/chromium-chromium
What is this /run/user/1000 ? It seems to be a temporary directory, thus a good reason what I seem to loose cookies.
Of course for the user working there is no such link for .config/chromium
Waiting forward for some light on this setup that was not made by me!
I removed the link .config/chromium   rerun chromium, and no issue anymore.
thanks again.
Edited by Tony3
