obiwantoby Posted September 19, 2023 Posted September 19, 2023 (edited) Standard install - Armbian Bookworm, full 'firmware install'. I am getting some packet loss over the LAN. A raspberry pi, Synology NAS and Deban x86 install on the same LAN do not seem to exhibit the same loss. Anyone have experience or ideas? Oddly enough this never seems to occur on fresh installs. This is a docker host for pihole and home assistance, no other packages are really installed at all. I've not really tried much, but since this is a standard install, apt-get update & upgrade are about the only modifications outside of docker install that has occurred. 1. This plugs directly in to a Ubiquiti switch 2. I have tried a few different ethernet cables. 3. dmesg does not really show disconnects on the regular Edited September 19, 2023 by obiwantoby 0 Quote
royk Posted September 20, 2023 Posted September 20, 2023 It could be about anything, but what did help for LinuxCNC was setting the smp affinity of the Ethernet adapter to another CPU cat /proc/interrupts | grep eth Then you'll see 2 IRQs then set these to other CPU(s). In HEX format. Convert from binary to HEX, the binary is reversed. So 00001111 is the first 4 and to HEX is F. To set them to the 5th CPU (CPU4) for example: 0001 0000 -> 10 (change the IRQ numbers) echo 10 | sudo tee /proc/irq/82/smp_affinity && echo 10 | sudo tee /proc/irq/81/smp_affinity If that does help you could set it at boot in rc.local or crontab with 10 seconds delay. 0 Quote
obiwantoby Posted September 21, 2023 Author Posted September 21, 2023 I played around with affinity, no change. It got so bad that via SSH I'd be kicked off or my commands would partially input. I did a restore from backup, and since I do use docker, back up and running perfectly again. I wish I knew what was tainting the system though. Could it be this or similar? https://community.home-assistant.io/t/home-assistant-in-docker-causes-network-packet-loss-on-host/520067 Unknown, as I am not running anything privileged. I am not sure *if* this is a hint as well. There has to be an explanation but as to what still at a loss. Especially since I can restore like I did, and everything is working perfectly. Perhaps I should just avoid apt-get upgrades 0 Quote
royk Posted September 21, 2023 Posted September 21, 2023 Stop and disable Docker and you'll know. Did you check the temperature while this happens? "armbianmonitor -m" Tried another network cable, another place (interference), power supply, cpu governor "echo performance | sudo tee /sys/bus/cpu/devices/cpu[0-7]/cpufreq/scaling_governor". Did you install another network manager? Does dmesg show you something? Other devices connected to the OPi 5? 0 Quote
