Orange Pi 5b 16 GiB / 256 GB: Which system to install, how to transfer my sustem to eMMC?
Hello guys!
I bought https://aliexpress.ru/item/1005005675856892.html.
As I know, there is no 3D acceleration in Debian Bookworm.
So, my desigion is to install Armbian Jammy Gnome desktop.
My questions are:
1) In what moment should I perform trick
If you are having a Orange Pi 5B variant, replace
fdtfile=rockchip/rk3588s-orangepi-5.dtb
in
/boot/armbianEnv.txt
with
fdtfile=rockchip/rk3588s-orangepi-5b.dtb
2) Legacy is the only system I can install, or is it any way to install current system? I wish kernel v6 to be installed, but not the RC kernel.
My experience with SMB is Rapberry Pi 3 B and 4 B.
I used to install only Raspbian on that boards.
Wish me luck guys :-))
Best to use a Linux system to read the sd-card after writing the image. Then open the sd-card and do what's mentioned.
Then you can boot the image.
For adding GPU and VPU drivers in Jammy.
sudo add-apt-repository ppa:liujianfeng1994/panfork-mesa
sudo add-apt-repository ppa:liujianfeng1994/rockchip-multimedia
sudo apt update
sudo apt dist-upgrade
sudo apt install mali-g610-firmware rockchip-multimedia-config
To write the image to eMMC use
sudo armbian-install
It can boot mainline but its not realy usable. Last time I checked HDMI wasn't working. It will take a few months to year for mainline to mature.
NicoD, has this situation improved since then?
