silencer Posted October 2, 2023 Posted October 2, 2023 Hi guys. I installed the Armbian image without the desktop. But now I need the desktop and it's not available in the software list in Armbian-config. What should I do? Thank you in advance. 0 Quote
Werner Posted October 2, 2023 Posted October 2, 2023 Usually installing DE should be available via armbian-config. However since this tool is kind of neglected due to major rewrite is WIP this might not work. Anyway you can try to use userspace tutorials available here or start from scratch with pre-configured Armbian desktop image. 0 Quote
Solution silencer Posted October 6, 2023 Author Solution Posted October 6, 2023 I am so sorry and I am an idiot. To anyone else seeing this, this is the solution: In armbian-config, goto System -> Desktop Then use Remmina on your other computer to access the Armbian desktop. Thank you devs and @Werner 0 Quote
dynamichael Posted Friday at 08:59 AM Posted Friday at 08:59 AM Same problem here except there's no Desktop option. Only these: - Kernel - Storage - Access - User - Updates Got any other solutions? 0 Quote
eselarm Posted Friday at 05:54 PM Posted Friday at 05:54 PM 8 hours ago, dynamichael said: Got any other solutions? Standard Debian; select what you want when you run: sudo tasksel 0 Quote
max_brenn Posted Sunday at 12:58 PM Posted Sunday at 12:58 PM I experience the same problem: I installed Armbian without desktop (both the Debian and Ubuntu version) to install a minimalistic desktop setup afterwards. However, in the armbian-config tool I do not find the "Desktop" option when entering the "System" menu. The installation instructions mentioned in the documentation (Desktop Environments - Armbian Documentation) are not working either. I'm using Armbian 25.11.1 dzsnlr 6.12.58-current-bcm2711 (Debian trixie) on a Raspberry Pi 4 8Gb. Thanks a lot for any hints how to get a minimal desktop installed without relying on the images with desktop included! 0 Quote
Michael Robinson Posted Sunday at 05:46 PM Posted Sunday at 05:46 PM if you are not seeing option to enable in armbian-config you can try: sudo apt install xfce4 xfce4-terminal lightdm -y or sudo apt install xfce4-goodies -y 0 Quote
