Running the command below I have the issue below:
I work with armbian-build git repo, tag 23.02.0-trunk.0256 and I run this command to build a armbian .img for my orangepi zero lts
It used to work well in february but now maybe the armbian repositories do not work anymore with this tag version ?
./armbian-build/compile.sh docker USE_MAINLINE_GOOGLE_MIRROR=yes BOARD=orangepizero BRANCH=current BUILD_KSRC=no RELEASE=bullseye BUILD_DESKTOP=no BUILD_MINIMAL=yes  KERNEL_ONLY=no KERNEL_CONFIGURE=no ROOTFS_TYPE=ext4 BOOTFS_TYPE=fat COMPRESS_OUTPUTIMAGE=sha,img '
Processing triggers for resolvconf (1.87) ...
[ o.k. ] Checking MD5 sum of installed packages [ debsums ]
debsums: changed file /usr/share/doc/base-files/changelog.gz (from base-files package)
debsums: changed file /etc/os-release (from base-files package)
debsums: changed file /etc/issue.net (from base-files package)
debsums: changed file /etc/issue (from base-files package)
[ error ] ERROR in function create_rootfs_cache [ functions/cli/cli-entrypoint.sh:109 -> functions/main/build-tasks.sh:302 -> functions/main/build-tasks.sh:225 -> functions/main/rootfs-image.sh:66 -> functions/rootfs/create-cache.sh:229 -> functions/logging/traps.sh:0 ]
[ error ] MD5 sums check of installed packages failed
[ o.k. ] Process terminated
[ error ] unmount_on_exit() called! [ functions/cli/cli-entrypoint.sh:109 -> functions/main/build-tasks.sh:302 -> functions/main/build-tasks.sh:225 -> functions/main/rootfs-image.sh:66 -> functions/rootfs/create-cache.sh:229 -> functions/logging/traps.sh:1 -> functions/main/rootfs-image.sh:0 ]
[ o.k. ] Unmounting [ /root/armbian/.tmp/rootfs-329b560e-4e99-40c7-bad2-3ddabd8752c8/ ]
[ error ] ERROR in function unmount_on_exit [ functions/cli/cli-entrypoint.sh:109 -> functions/main/build-tasks.sh:302 -> functions/main/build-tasks.sh:225 -> functions/main/rootfs-image.sh:66 -> functions/rootfs/create-cache.sh:229 -> functions/logging/traps.sh:1 -> functions/main/rootfs-image.sh:27 -> functions/logging/traps.sh:0 ]
[ error ] debootstrap-ng was interrupted
Thank you for your help
