ril3y Posted October 3, 2015 Posted October 3, 2015 Hey all, I have been fighting this for 2 days now thought I would reach out for some help. I have a Intel Wireless 7260 PCIe in my Hummingboard Pro board. I can run iwlist wlan0 scanning and see my wifi access point no problem. However when I run dhcpclient wlan0 I never can connect to my access point. This is my /etc/network/interfaces file. # Wireless adapter #1 auto wlan0 allow-hotplug wlan0 iface wlan0 inet dhcp wpa-ssid "myssid" wpa-psk "mypassword" auto lo iface lo inet loopback I have also tried a USB wifi adapter to attempt to rule out the PCIe bus being the issue. However neither will connect. If anyone knows what to do from here I would be extremely grateful. Thanks! ril3y
Igor Posted October 4, 2015 Posted October 4, 2015 How do you generate password? This is not a plain text! Example:your name is HOME and your password is 12345678 wpa_passphrase HOME 12345678 This is the output: network={ ssid="HOME" #psk="12345678" psk=58ff5ae3edf5058ad2635b2344120768d903d971cde278754d32c0c20ae2045a } Use the big number / code for the password and you should be fine. P.S.I am having exactly the same hardware (HB Pro + 7260) and it's performing very good. Actually it's best combination.
ril3y Posted October 5, 2015 Author Posted October 5, 2015 In the past I have not used wpa_supplicant for this just the interfaces file. Can you tell me how your wpa_supplicant.conf file gets called? What does your /etc/networks/interfaces file look like?
Igor Posted October 6, 2015 Posted October 6, 2015 You either have this in separate file or directly inside interfaces file. If I want to connect to my router I use such config for wlan0 adapter. The code was generated with previously mentioned tool (which is actually generates wpa_supplicant conf) and it works. auto wlan0 iface wlan0 inet dhcp wpa-ssid HOME wpa-psk 58ff5ae3edf5058ad2635b2344120768d903d971cde278754d32c0c20ae2045a For advanced configuration modes: http://manpages.ubuntu.com/manpages/hardy/man5/wpa_supplicant.conf.5.html
