CPU temperature over 100C on Armbain image. (Bananpi cm4)
陳柏儒
hello,
I found default armbian image will cause the CPU temperature very high.
My cpu freq is setting 1Ghz and usage is around 20%, This should not cause the cpu to overheat.
This is my armbianmonitor -m :
Time    CPU_cl0/CPU_cl1  load %cpu %sys %usr %nice %io %irq   Tcpu  C.St.
18:55:22  1000/1000 MHz  0.88  17%   6%   9%   0%   0%   1%  103.0 °C  8/8
18:55:27  1000/1000 MHz  0.89  17%   5%   9%   0%   0%   1%  103.0 °C  8/8
18:55:32  1000/1000 MHz  0.90  17%   5%   9%   0%   0%   1%  103.1 °C  8/8
18:55:37  1000/1000 MHz  0.83  17%   5%   9%   0%   0%   1%  103.2 °C  8/8
18:55:42  1000/1000 MHz  0.76  17%   6%   9%   0%   0%   1%  103.1 °C  8/8
18:55:47  1000/1000 MHz  0.86  17%   5%   9%   0%   0%   1%  103.2 °C  8/8
18:55:52  1000/1000 MHz  0.87  17%   5%   9%   0%   0%   1%  103.0 °C  8/8
My cpu's governor is `powersave` and I also see  gpu usage, my gpu governor is setting `simple_ondemand`.
I also use bananapi officical image (ubuntu mate) No overheating issues. How can I solve this problem?
Thanks
Wifi and bluetooth should work out of the box. You also appear to be using the wrong img;
591    Thu Aug 31 03:17:42 PM UTC 2023 | Banana Pi M2S | 23.8.1 | arm64 | aarch64 | 6.1.50-current-meson64
14736    fdtfile=amlogic/meson-g12b-a311d-bananapi-m2s.dtb
Aren't you using a CM4?
