TobiMuc Posted October 15, 2023 Posted October 15, 2023 (edited) Hi, I installed armbian_23.8.1_Radxa-zero_bookworm-current_6.1.50 on Radxa Pi Zero eMMC and I have an USB SSD drive connected as storage. Everything worked fine using it as a NAS but if I reboot there is an endless loop of reboots with the core message "scanning bus usb0ff5000000 for devices... Synchronous Abort handler, err 0x56000010". If I disconnect the USB drive it boots fine and when reconnect it after the boot process, the drive works fine. But I really need a system that is able to boot without temporarely disconnecting USB. I tried different combinations of USB with two different hubs or without hub. There are no boot flags on the partitions. I completely deleted all partitions on the drive and tried different kind of partitions and file systems. It does not change anything. Even without any partition it has the same error. I have another USB SSD that also causes a few pages of error messages but after that it does boot (from eMMC). Unfortunately that is the wrong USB drive and does not help. Switching too the newest kernel with armbian-setup also does not work. Finally I installed Radxa Ubuntu 20 and it boots without any issues while the USB SSD is connected. What can I do to solve this when using Armbian? Thanks Tobi Edited October 15, 2023 by TobiMuc 0 Quote
Solution c0rnelius Posted October 15, 2023 Solution Posted October 15, 2023 It is more than likely a u-boot issue caused by a specific patch; https://github.com/armbian/build/blob/main/patch/u-boot/v2022.10/meson64-boot-usb-nvme-scsi-first.patch https://github.com/armbian/build/blob/main/config/boards/radxa-zero.conf#L17 You would need to build u-boot with this patch disabled, flash it to the unit and see if it solves the problem. 0 Quote
TobiMuc Posted October 15, 2023 Author Posted October 15, 2023 Thanks, that really looks like the reason for this. I don't get it... why do people buy a much more expensive Pi Zero with eMMC? Because they want the system on a relyable eMMC instead of USB or SD. I don't understand why there is a patch that boots from USB first. Isn't there a way to configure the order or to disable USB during the boot process? Sorry but whenever I try to find information about u-boot it is a complete mess what I get and nothing works. Compiling it sounds like many hours of try and error. 0 Quote
c0rnelius Posted October 15, 2023 Posted October 15, 2023 I'm not 100% on this, but I don't believe there is an easy way to change the order as its hard coded now. Maybe someone else knows better? 0 Quote
TobiMuc Posted October 24, 2023 Author Posted October 24, 2023 (edited) I was able to solve it here. My Radxa Pi Zero boots from eMMC with USB drive attached. If someone has the same issue, here is a quick walkthrough: # login as a non-root user # Clone git from https://github.com/armbian/build#build-tools-overview git clone https://github.com/armbian/build.git # Some info: https://docs.armbian.com/Developer-Guide\_Build-Options/ # Remove the patch that we don't want: rm build/patch/u-boot/v2022.10/meson64-boot-usb-nvme-scsi-first.patch # Compile u-boot ./compile.sh build BOARD=radxa-zero BRANCH=current BUILD_DESKTOP=no BUILD_MINIMAL=no BUILD_ONLY=u-boot KERNEL_CONFIGURE=no RELEASE=bookworm # Somehow it compiles more than u-boot but less than without BUILD_ONLY=u-boot # Optional backup of the deb packages to a mounted drive: # sudo cp -a build/output/debs/* /mnt/radxa # install sudo dpkg -i build/output/debs/*.deb /home/tobi/build/output/debs/bookwork/*.deb # install u-boot sudo armbian-config # Select system -> Install -> Install .. on ..eMMC.. # Reboot with fingers crossed Edited October 24, 2023 by TobiMuc 0 Quote
rpardini Posted October 24, 2023 Posted October 24, 2023 @c0rnelius graciously submitted GitHub PR to upgrade u-boot that effectively removed the patch in question from the equation for the Radxa Zero. While it was nice to "boot USB first", since it enabled a few interesting scenarios (boot non-Armbian EFI OSes in USB disk), it's not worth having it if normal Armbian operation is impacted. I've advocated for this usb-first style to be default around u-boot 2022, but we're now moving to board-specific support (and removing completely in the case of the Zero) for 2023+. 1 Quote
Sab44 Posted April 7 Posted April 7 I'm having the exact same issue with my ODroid N2+, Armbian installed on SD card. System runs totally fine without USB HDD attached (or if attached after boot). But when rebooting it'll fail to start-up properly. I'll look into compiling u-boot without the patch mentioned here. Any chance to remove this patch in the official builds? Citing the previous statement "it's not worth having it if normal Armbian operation is impacted" I think that's the case here, as I would consider connecting a USB HDD normal everyday operation. Thanks in advance. 0 Quote
Sab44 Posted April 8 Posted April 8 After following the steps TobiMuc provided (thanks!) I can confirm it is working now. Pretty inconvenient, but happy it's working now. Highly suggest to remove this patch for default builds. 0 Quote
