I had working Banana Pi -> I compiled latest kernel (all config were default) and installed it -> Banana Pi did not boot, it was stucked on "Raising network interfaces" -> I downloaded latest image (Debian Jessie) and flashed it on SD card -> Banana Pi still stucked on "Raising network interfaces".
Banana Pi is connected via normal cable directly to the router with DHCP. I have also tested cable and router and tried to use different cable. I have not changed anything else.
Is this resolved? I don't see any warning on armbian.com. I would really like to use the vanilla kernel as it has CAN bus support built in as far as I can see.
The latest image doesn't boot for me. I have excluded the SD card as source of fault. I'm a bit surprised I can't mount the image on my laptop, however.
EDIT: Nevermind, the SD card must've gotten corrupted while dd'ing the image onto it (or somewhere else between card check and boot). works on a different SD card.
