Hi Igor can you provide your u-boot config for BananaPro?
if i add
CONFIG_VIDEO_LCD_BL_PWM_ACTIVE_LOW=n
CONFIG_VIDEO_LCD_MODE=“x:1024,y:600,depth:24,pclk_khz:55000,le:100,ri:170,up:10,lo:15,hs:50,vs:10,sync:3,vmode:0â€
CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_VIDEO_LCD_POWER=“PH12†
CONFIG_VIDEO_LCD_BL_EN=“PH8†CONFIG_VIDEO_LCD_BL_PWM=“PB2â€
Banana didnt start right.
These settings needed at startup to add the 7" at boot
after rebuild u-boot , screen stay black and kernel doesnt start
1801 bytes read in 207 ms (7.8 KiB/s)
** File not found /boot/.next **
50500 bytes read in 480 ms (102.5 KiB/s)
5607544 bytes read in 517 ms (10.3 MiB/s)
Kernel image @ 0x48000000 [ 0x000000 - 0x559078 ]
Starting kernel ...
thats all :/
my images under piptojects.net runs with 4.* kernel and work with touch . vga output at boot,
the line above needed in u-boot because these only for 7"
if someone use smaller like 3,5" or 5" x and y must be changed
at lemaker i discribe with bruce how to change the dts file and xorg.conf for that
http://www.lemaker.org/forum.php?mod=viewthread&tid=15482&highlight=lvds
edit: your line added to u-boot now it boots
edit2: http://linux-sunxi.org/LCDhere some more lines for lvds lcd
sometimes CONFIG_VIDEO_LCD_BL_PWM_ACTIVE_LOW=n
this line is needed
