i use a Rock Pi 4b with a external USB3 Seagate 4TB HDD on USB3 Port on RockPi 4B.
Der HardDisk ist ext4 formatet und mounted via fstab
The maximum troughput over Samba Share is around 11 Mbit
The same USB HDD on a Odroid with same samba settings has an troughput over 100 MBit
Any Ideas ?
Thanks Ingo
I used iperf3 to monitor the LAN perferomance so I've seen this is no USB Problem.
It seems the LAN Port only runs on 100 Mbit
Accepted connection from 192.168.xxx.xxx, port 64266
[  5] local 192.168.xxx.xxx port 5201 connected to 192.168.xxx.xxx port 64267
[ ID] Interval           Transfer     Bitrate
[  5]   0.00-1.00   sec  10.7 MBytes  90.1 Mbits/sec
[  5]   1.00-2.00   sec  11.3 MBytes  94.8 Mbits/sec
[  5]   2.00-3.00   sec  11.3 MBytes  94.7 Mbits/sec
[  5]   3.00-4.00   sec  11.3 MBytes  94.9 Mbits/sec
[  5]   4.00-5.00   sec  11.3 MBytes  94.8 Mbits/sec
[  5]   5.00-6.00   sec  11.3 MBytes  94.7 Mbits/sec
[  5]   6.00-7.00   sec  11.3 MBytes  94.7 Mbits/sec
[  5]   7.00-8.00   sec  11.3 MBytes  94.9 Mbits/sec
[  5]   8.00-9.00   sec  11.3 MBytes  94.8 Mbits/sec
[  5]   9.00-10.00  sec  11.3 MBytes  94.9 Mbits/sec
[  5]  10.00-10.04  sec   441 KBytes  95.0 Mbits/sec
[  5]   0.00-10.04  sec   113 MBytes  94.3 Mbits/sec                  receiver
