Hubär Posted November 23, 2023 Posted November 23, 2023 I used iperf3 to monitor the LAN perferomance. It seems the LAN Port only runs on 100 Mbit how can I get a 1GBit speed ? Accepted connection from 192.168.xxx.xxx, port 64266 [ 5] local 192.168.xxx.xxx port 5201 connected to 192.168.xxx.xxx port 64267 [ ID] Interval Transfer Bitrate [ 5] 0.00-1.00 sec 10.7 MBytes 90.1 Mbits/sec [ 5] 1.00-2.00 sec 11.3 MBytes 94.8 Mbits/sec [ 5] 2.00-3.00 sec 11.3 MBytes 94.7 Mbits/sec [ 5] 3.00-4.00 sec 11.3 MBytes 94.9 Mbits/sec [ 5] 4.00-5.00 sec 11.3 MBytes 94.8 Mbits/sec [ 5] 5.00-6.00 sec 11.3 MBytes 94.7 Mbits/sec [ 5] 6.00-7.00 sec 11.3 MBytes 94.7 Mbits/sec [ 5] 7.00-8.00 sec 11.3 MBytes 94.9 Mbits/sec [ 5] 8.00-9.00 sec 11.3 MBytes 94.8 Mbits/sec [ 5] 9.00-10.00 sec 11.3 MBytes 94.9 Mbits/sec [ 5] 10.00-10.04 sec 441 KBytes 95.0 Mbits/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate [ 5] 0.00-10.04 sec 113 MBytes 94.3 Mbits/sec receiver 0 Quote
Igor Posted December 19, 2023 Posted December 19, 2023 On 11/23/2023 at 7:48 AM, Hubär said: I used iperf3 to monitor the LAN perferomance. We measure this automatically every day: https://github.com/armbian/os?tab=readme-ov-file#latest-smoke-tests-results 970Mbit/sec 0 Quote
helios Posted January 9, 2024 Posted January 9, 2024 (edited) Hello! I am facing the same 100M ethernet speed issue. The TP-Link switch I have auto-negotiates the Rockpi 4B to 100M link speed instead of 1000M. If I manually set it to 1000M in my switch, the link stays down. From ethtool The internet speed is affected too. It used to be around 98 ~ 104 Mbits/s I noticed this behaviour after upgrading from 23.8.1 to 23.11.1 EDIT: A combination of a new ethernet cable and Switch firmware update resolved the issue for me. Edited January 10, 2024 by helios 0 Quote
