  • 0
Orange Pi Zero Kernel SPI & GPIO
Ribster
Question
Hey everybody.
I'm quite new to allwinner, my first experience was with the A13 (sun4i) from olimex.
I wrote a kernel driver for the sunxi kernel, which uses the spi and some GPIO.
It talks to an SPI RF chip and works just fine.
I want to port my kernel driver for the Orange Pi Zero, but have some issues.
My main question is: how do i access the fex file, how do i manipulate the gpio and spi ?
In the sun4i there are helper functions in the arch/arm/mach-sun4i/sys_config.c file.
#define PIN_DIR(handler,dir) gpio_set_one_pin_io_status(handler, dir, NULL)
#define PIN_SET(handler,val) gpio_write_one_pin_value(handler, val, NULL)
#define PIN_GET(handler) gpio_read_one_pin_value(handler, NULL)
I don't seem to get them in the sun8i sys_config.c file that is located in #include <mach/sys_config.h>
I normally get the gpio pins as such:
my_sx1272_data->pin_led = gpio_request_ex("sx1272_para", "pin_led");
And i manipulate the IO with these defines, that also use the functions from sys_config.
PIN_DIR(my_sx1272_data->pin_led, PIN_DIR_OUT);
PIN_SET(my_sx1272_data->pin_led, 0);
For the SPI i use this way of setup, i guess this will work, but i need to get rid of the sys_config implicit function compilation error first.
struct spi_board_info spi_device_info = {
    .modalias = "DURALINK",
    .max_speed_hz = 350*1000, //speed your device (slave) can handle
    .bus_num = 2,
    .chip_select = 0,
    .mode = 0,
      master = spi_busnum_to_master( spi_device_info.bus_num );
      if( !master ){
          printk(KERN_ERR "[LoRa] MASTER not found.\n");
              return -ENODEV;
      // create a new slave device, given the master and device info
      spi_device = spi_new_device( master, &spi_device_info );
      if( !spi_device ) {
          printk(KERN_ERR "[LoRa] FAILED to create slave.\n");
          return -ENODEV;
      spi_device->bits_per_word = 8;
      ret = spi_setup( spi_device );
    if( ret ){
        printk(KERN_ERR "[LoRa] FAILED to setup slave.\n");
        spi_unregister_device( spi_device );
        return -ENODEV;
Currently using Linux OPI-3.4.113 3.4.113-sun8i #50 SMP PREEMPT Mon Nov 14 08:41:55 CET 2016 armv7l GNU/Linux
So it's the Debian armbian image 3.4.113.
Thanks in advance.
Link to comment
Share on other sites
11 answers to this question
  • 0
Yes, i've got the python blinky sketch working.
Changed the mapping.h for the correct io and was up and running.
i've tried a simple c file, but i've got some errors.
Once i get this up and running, i can port it to my kernel module...
my test.c
#include <stdlib.h>
#include <stdio.h>
#include "gpio_lib.h"
sunxi_gpio_init();
sunxi_gpio_set_cfgpin(SUNXI_GPA(17), SUNXI_GPIO_OUTPUT);
while(1) {
    sunxi_gpio_output(SUNXI_GPA(17), 1);
    sleep(1);
    sunxi_gpio_output(SUNXI_GPA(17), 0);
    sleep(1);
and the shell output
root@OPI-3:~/git/orangepi_PC_gpio_pyH3/pyA20/gpio# gcc -O test.c
test.c:5:1: warning: data definition has no type or storage class
 sunxi_gpio_init();
In file included from test.c:3:0:
gpio_lib.h:122:24: error: expected declaration specifiers or ‘...’ before ‘(’ token
 #define SUNXI_GPA(_nr) (SUNXI_GPIO_A_START + (_nr))
test.c:6:23: note: in expansion of macro ‘SUNXI_GPA’
gpio_lib.h:143:27: error: expected declaration specifiers or ‘...’ before ‘(’ token
 #define SUNXI_GPIO_OUTPUT (1)
test.c:6:38: note: in expansion of macro ‘SUNXI_GPIO_OUTPUT’
test.c:7:1: error: expected identifier or ‘(’ before ‘while’
 while(1) {
Link to comment
  • 0
So i'm stupid as fuck... Why did i not add the main function....
Got it working! For future reference:
test.c file:
#include <stdlib.h>
#include <stdio.h>
#include <time.h>
int main(){
int ret;
ret = sunxi_gpio_init();
ret = sunxi_gpio_set_cfgpin(SUNXI_GPA(17), SUNXI_GPIO_OUTPUT);
while(1) {
    usleep(100000);
    usleep(100000);
    usleep(100000);
    usleep(600000);
the command line compile:
gcc test.c gpio_lib.c -o test
Then just ./test and the red led will blink!!
Next step: get this working in the kernel driver...
Link to comment
  • 0
I found the implementation here (It's for arduino but should work also on orangepi with some modifications):
https://github.com/RowlandTechnology/MULTIUART
or maybe to use MAX14830 (https://www.maximintegrated.com/en/products/interface/controllers-expanders/MAX14830.html) 4 uarts to SPI
http://www.spinics.net/lists/linux-serial/msg10232.html
I'm working on scientific project where we must acquire datas over 5 uarts. Each uart is connected to specific sensor (oxygen, temp, salinity, pressure, chlorophile,..)..
Link to comment
  • 0
Hi, need some help.. I'am familar with Java but with c/c++ not :)
So.. have downloaded source from:  https://github.com/duxingkei33/orangepi_PC_gpio_pyH3  to my orangepi..
Than I have installed the library with python and all is ok..
On the remote PC I have setup Netbeans IDE and now want to include gpio_lib.h
The problem is that IDE can't find header files in directories listed below...
So.. what is the procedure to use orangepi_PC_gpio_pyH3 library?  Can I only copy/paste files to /usr/include folder on my OP?
Link to comment
