Vcoder Posted January 8, 2017 Share Posted January 8, 2017 Hi all and many thanks to armbian team - it is a great distro. I installed armbian to my orange pi pc (just pc, not pc+) and it works. TV out works too. But no one of my usb wi-fi adapters are supported by default kernel 3.4. This is why I go to "kernel" tab at page https://www.armbian.com/orange-pi-pc/and follow instructions to switch to development kernel. Also I follow instruction at "Nighty releases" tab in order to get the newest versions of software. After installing new kernel I edit symlik /boot/script.bin to point to "bin/orangepipc.bin" instead of default "bin/orangepipcplus.bin" and reboot. Orange pi boots successfully and I can log in via ssh, but tv signal was disappeared: my TV just says "no signal". Then I put to /boot/bin my old "orangepipc.bin" file, with which tv out works with 3.4 kernel and reboot, but there is still no tv signal. After that I edit "orangepipc.bin" provided with 4.9 kernel in order to enable tv out, but tv signal did not appear... The record "tv" in "/etc/modules" is present. This is part of my orangepipc.fex file: [disp_init] disp_init_enable = 1 disp_mode = 1 screen0_output_type = 3 screen0_output_mode = 10 screen1_output_type = 2 screen1_output_mode = 11 fb0_format = 0 fb0_width = 0 fb0_height = 0 fb1_format = 0 fb1_width = 0 fb1_height = 0 [hdmi_para] hdmi_used = 0 hdmi_power = "vcc-hdmi-18" [tv_para] tv_used = 1 tv_dac_used = 1 tv_dac_src0 = 0 Is it possible to use analog tv out with 4.9 kernel? If yes, what shold I do to enable it? Link to comment Share on other sites More sharing options...
zador.blood.stained Posted January 8, 2017 Share Posted January 8, 2017 Is it possible to use analog tv out with 4.9 kernel? No Link to comment Share on other sites More sharing options...
Vcoder Posted January 8, 2017 Author Share Posted January 8, 2017 Thank You for reply. Is there something else not working with 4.9 kernel that works with 3.4? Is there a list of that? Link to comment Share on other sites More sharing options...
zador.blood.stained Posted January 8, 2017 Share Posted January 8, 2017 Is there something else not working with 4.9 kernel that works with 3.4? Is there a list of that? There is an official status matrix: https://linux-sunxi.org/Linux_mainlining_effort#Status_Matrix Kernel used in Armbian may contain some of features marked WIP but it's meant mainly for developers and only development-related support is provided for it. Link to comment Share on other sites More sharing options...
