I initially tried the instructions in the original post and it didn't work for me. On an allwinner h618 box with a mali-G31. I then spent pretty much all day today trying to find a fix. I came across a post on here stating the version of mpv that works with v4l2 needs to be compiled with the same package versions as ffmpeg or something along those lines. When I first tried the instructions I already had mpv installed and I remember it stating that it didn't update it.
So for a hail mary I ran apt remove ffmpeg and apt remove mpv. Then I ran the instructions again and noticed first one didn't actually run successfully which could have been why they didn't work this morning.... When I copy pasted into the terminal it left the $ signs in there and caused errors. So I manually typed it out and got everything to run successfully.
Now everything works. mpv is buttery smooth.
Previously mpv stated drm was unsupported now it says "using hardware decoding (drm)".
I had checked ffmpeg and it did list v4l2 as supported so maybe that didn't need to be reinstalled.
Anyway, if it hasn't worked for you maybe try uninstalling ffmpeg and mpv and running the commands again.
Posted (edited)
On 1/31/2026 at 3:45 AM, jock said:
the problem is not ffmpeg, which already is works totally fine on debian Trixie (and backwards), the problem is within mpv that changed in v0.4.0 carried by debian Trixie,  and at the moment I don't have enough motivation to carry on a custom mpv package for Debian Trixie.
Thank you for the comment Jock :)
Yes, I know that Trixie's mpv made some changes that made it incompatible with your ffmpeg+v4lrequest package.
I tried to compile mpv, and I wasn't sure of how to do it.
I asked for help in the mpv github, and someone told me to wait for ffmpeg to merge this function.
https://github.com/mpv-player/mpv/pull/14690#issuecomment-3369553163
Recently, I got more suggestions to build ffmpeg for Trixie :) https://github.com/mpv-player/mpv/pull/14690#issuecomment-3828170966
Boringname... can you specify which Debian version, Linux kernel and graphical desktop (kde, xfce, gnome, plasma, labwc, sway)?
Edited by robertoj
It's this image from @Nick A github.
Armbian-unofficial_25.05.0-trunk_X98h_bookworm_edge_6.12.11_xfce_desktop.img
I had to copy over a few firmware files to get wifi/bluetooth working but otherwise it's unchanged.
Posted (edited)
Just a feedback.
Device: Orange Pi 5 Plus
OS Image: Armbian_26.2.0-trunk.370_Orangepi5-plus_noble_current_6.18.8_gnome_desktop.img.xz
media-player: mpv-.37.0-1ubuntu4
Following the gudide on the first page and added "profile=fast" (in order to have smooth 4K/60 playback) in /etc/mpv/mpv.conf.
mpv-.37.0-1ubuntu4 playback 8bit 4K/60 h264 and h265 (hevc) video with vpu hardware accceleration.  10bit h265 or any vp9 and av1 video NO vpu hardware acceleration as far as I can tell.
10bit 4k/60 hevc video -- No vpu hw acceleration
Quote
$ mpv '/media/jfl/writable/home/jfl/Videos/jellyfish-120-mbps-4k-uhd-hevc-10bit.mkv'
 (+) Video --vid=1 (*) (hevc 3840x2160 29.970fps)
[ffmpeg/video] hevc: Failed setup for format drm_prime: hwaccel initialisation returned error.
VO: [gpu] 3840x2160 yuv420p10
Exiting... (Quit)
4K/60 hevc -- with vpu hw acceleration. Error messages.
Quote
$ mpv https://lafibre.info/videos/test/201411_blender_big_buck_bunny_60fps_2160p_hevc.mp4
 (+) Video --vid=1 (*) (hevc 3840x2160 60.000fps)
 (+) Audio --aid=1 (*) (aac 2ch 48000Hz)
File tags:
 Artist: CC-BY Fondation Blender
 Album: https://LaFibre.info Vivien GUEANT
 Date: 2022
 Genre: Court métrage d'animation néerlandais
 Title: Big Buck Bunny, 10min00sec version
[ffmpeg/video] hevc: ff_v4l2_request_query_control: query control failed, Invalid argument (22)
Using hardware decoding (drm).
AO: [pulse] 48000Hz stereo 2ch float
VO: [gpu] 3840x2160 drm_prime[nv12]
Exiting... (Quit)
Full HD av1 -- No vpu hw acceleration
Quote
$ mpv https://lafibre.info/videos/test/201411_blender_big_buck_bunny_60fps_1080p_av1.mp4
 (+) Video --vid=1 (*) (av1 1920x1080 60.000fps)
 (+) Audio --aid=1 (*) (opus 2ch 48000Hz)
File tags:
 Date: 2022
VO: [gpu] 1920x1080 yuv420p
Exiting... (Quit)
Full HD vp9 -- No vpu hw acceleration
Quote
$ mpv '/media/jfl/writable/home/jfl/Videos/Big_Buck_Bunny_1080_10s_30MB.webm'
 (+) Video --vid=1 (*) (vp9 1920x1080 30.000fps)
File tags:
 Artist: Blender Foundation 2008, Janus Bager Kristensen 2013
 Comment: Creative Commons Attribution 3.0 - http://bbb3d.renderfarming.net
 Composer: Sacha Goedegebure
 Genre: Animation
 Title: Big Buck Bunny, Sunflower version
[ffmpeg/video] vp9: Failed setup for format drm_prime: hwaccel initialisation returned error.
Exiting... (End of file)
Edit:  Chromium_v144 can play 8bit 4K/60 h264, h265 and av1 videos with vpu hw acceleration.  No vpu hw acceleration with vp9 videos.  If not mistaken the current kernel-6.18.8-current-rockchip64 or 6.19-rc8-edge-rockchip64 do not support vpu hw acceleration with vp9 codec.
Edited by JFL
JFL, can you check the Ubuntu gnome is running under wayland? ($ echo $XDG_SESSION_TYPE)
Can you check the labwc availability in Ubuntu Noble? ($ apt list labwc)
I never tested H265... I am glad it is working
Quote
Yes running on gnome-wayland session.
jfl@orangepi5-plus:~$ apt list labwc
Listing... Done
labwc/noble 0.7.1-1build1 arm64
On 2/4/2026 at 11:25 PM, JFL said:
Just a feedback.
I'm very new to Armbian so I could be off track here but I noticed your running MPV version 37. When I ran the instructions for the first time I already had mpv installed (version 40 or something) so it didn't get updated. I ended up uninstalling MPV and running the instructions again. Now I have version 35.1 which fixed the drm_prime errors for me.
The version difference could be because you are on 26.2 of Armbian and I'm on 25.05, I haven't got my head around all the different versions of things yet.
Maybe try uninstalling MPV and trying the commands again and see what version it gives you.
I was surprised when mine played H265 10 bit. I thought I'd read somewhere v4l2 was limited to 8 bit. Obviously that was incorrect.
Quote
Was running Ubuntu Noble and mpv-0.37 is from Noble-repo.  On Trixie the mpv is version 0.40 (Debian Trixie repo) which somehow does not seem work with the ffmpeg-v4l2request.
Quote
Are you running Trixie or Bookworn?
Quote
Is your device Opi5-Plus or RK3588? So far on my Opi5-Plus no luck with 10Bit Hevc or any 10Bit video on mpv with mainline kernel.
The drm_prime error is somehow "normal": AFAIR mpv was trying each hardware decoder in turn and, if it does not support the codec, prints the error and tries the next hardware decoder in line. If you try to decode h.265, perhaps it first picks an hardware decoder which does not support such codec with such parameters and prints the error, then tries another decoder which is capable and everything works. Usually rockchip devices have two hardware decoders, Hantro and rkvdec; Hantro does not support h.265 at all on older chips, but rkvdec does.
Bookworm. But my point was the version 35.1 is what got installed when I ran the scripts in the first post. If the script installed 37 for you because you're on Ubuntu then I probably am on the wrong track.
Yes I believe it does this. I was just pointing out that drm_prime works for me but I guess that could just be due to different hardware on the device. I'm not using an Orange Pi.
I don't like my chances of any resolution to this problem but here goes.
I'll start off by saying thanks for providing this repository, I recently went on holidays and was able to use my little magcubic box to watch content off my nas remotely. It was mostly great.
One issue I have come across is most of my SD content (ripped from DVD) just displays a black screen. I encode it to 10 bit x265 the same as I do for blurays. Blurays at 1080p play fine, the DVD rips at 480p and 576p just display a black screen, audio works. When comparing them with MediaInfo the only real difference (aside from resolution) is the color primaries, transfer characteristics and matrix coefficient tags. Blurays are bt.709 and the DVD rips are bt.601. Also NTSC vs PAL for the blurays.
I've also come across some files that I believe I downloaded at some point that are DVD resolutions, 10 bit x265 PAL that play ok. In MediaInfo these files are missing the all the tags mentioned above. I don't know how this is possible...
To troubleshoot I've tried converting a non working file to 25 FPS (PAL) and setting the elements above to bt.709 but no dice.
I've run mpv from the terminal in verbose mode and tried to compare a working file to non working file and nothing is really standing out. I think ffmpeg is just serving up black frames with v4l2 in certain circumstances, maybe when the color primaries are bt.601. I'm not overly confident the method I used above to set the bt.709 values would actually work.
I installed mplayer and this plays the files ok but doesn't have hardware acceleration. This is why I think the issue is ffmpeg and v4l2.
Probably not relevant but 2160p content plays (bt.2020). It really struggles with it but it displays an image.
Any ideas would be great. At this stage I'm probably going to take a 10 second clip of a non working file and just run it through bunch of different encode settings until I get something that displays and work backwards from there.
With a lot of trial and error I figured out the issue but not the cause.
This seems to only effect HEVC (x265) videos when drm is successfully enabled with MPV from this repository. If I try a different player, they play fine but no hardware acceleration. If I encode the videos to x264 they play but hardware acceleration fails with the following error
[ffmpeg/video] h264: v4l2_request_probe_video_device: set controls failed. Invalid argument (22)
The issue is the width of the video. Outside of certain ranges it will display a black video (audio works). It doesn't seem to matter what the height is set to.
Eg) 704x480, 704x960 image is displayed. 706x480, 706x960 black screen
The ranges go for 14 pixels and each range is separated by 50 pixels.
eg) widths in the range of 690 to 704 display an image. Widths between 706 and 752 display a black screen. 754 to 768 display an image.
It's a strange one....
Here is a list of ranges that work. Any widths outside of these ranges produces a black screen. It only goes up to 1984 but I'm sure the same rules would apply above this value.
Spoiler
114-128
178-192
242-256
306-320
370-384
434-448
498-512
562-576
626-640
690-704
754-768
818-832
882-896
946-960
1010-1024
1074-1088
1138-1152
1202-1216
1266-1280
1330-1344
1394-1408
1458-1472
1522-1536
1586-1600
1650-1664
1714-1728
1778-1792
1842-1856
1906-1920
1970-1984
Can you repeat your amrbian OS version, Linux, and hardware?
I can't give a confident advice for you, but have you tried:
extraargs=cma=256M in armbianEnv.txt
* turn off compositor, if using xfce (others have suggested it, and I found it unnecessary)
In mpv, turn on verbosity by adding -v to the command. Then while it is running, close it and copy all the mpv text in a text editor.
Search for the words h264, ffmpeg, v4l2, hardware, software
Posted (edited)
Thanks but they didn't make any difference.
I have confirmed it's an issue with the ffmpeg output when drm is enabled. I used the following to extract a single frame from a video using drm.
ffmpeg -hwaccel drm -hwaccel_device /dev/dri/renderD128 -ss 00:00:10 -i "input.mkv" -frames:v 1 -q:v 2 "output%03d.jpg"
It produces an image but it's nearly all green. If I remove the -hwaccel drm option the image produced is correct. I tried PNG format as well to rule out a format issue and got the same result.
After the above result I tried
ffmpeg -hwaccel drm -hwaccel_device /dev/dri/renderD128 -i "input.mkv" "output.mkv"
As it's using default settings this converts the video to x264
output.mkv still plays as a black screen in mpv but when I play it with ffplay I get a video covered in green with splashes of purple here and there. Edit: I should clarify you can still make out the video contents, it's just the colours are messed up. It's mainly all green with purple flickers occasionally.
So I guess I need to play around with ffmpeg.... the last time I tried to build my own it wasn't a fun time.
Also unrelated to this issue but I found the cause of the invalid argument 22 error I mentioned earlier when playing x264 videos. 10 bit x264 videos are unsupported. Using -pix_fmt yuv420p when encoding changes it to an 8bit video which plays successfully in mpv with drm. I don't normally have 10bit x264 but when I was testing I converted a x265 to x264 and it must have maintained the pixel format.
Edit: By adding the --vf=format=rgba to the mpv command line I can get mpv to play the file like ffplay does. Lots of green and purple but at least it displays an image instead of a black screen. I tried a bunch of different formats but they all come out exactly the same, except for --vf=format=gray. This plays a perfect black and white version of the video. For some frames the colours are correct in places but there is a lot of green blocky squares everywhere. So I don't think it's a format issue, I think ffmpeg is just screwing up the colour space for parts of the frame for certain width videos when drm is used.
Edited by BoringName
A bit more info.
I updated the mesa drivers with backport drivers to 25.0.7. Now videos outside of the ranges I listed earlier produce an error when trying to play with mpv.
Mesa: error: panfrost: rejecting image due to unsupported offset or stride alignment
Of course googling that error comes up with nada.
All videos inside the ranges continue to play fine.
If I scale the video down (from 706x480 to 704x480) when encoding to bring it within the working ranges.
ffmpeg -hwaccel drm -hwaccel_device /dev/dri/renderD128 -i "input.mkv" -pix_fmt yuv420p -vf scale=704x480 "output.mkv"
The video will play in mpv but still has the green/purple issue.
This command produces a playable video with no green/purple issue
ffmpeg -i "input.mkv" -vf scale=704x480 "output.mkv"
Whatever the issue seems to be effecting both ffmpeg and mpv with certain video widths. Fmmpeg is outputting video with screwed up colours and mpv causes a driver error. mpv uses ffmpeg under the hood so it makes sense it's effecting both of them.
I don't suppose anyone using this repository with a mali-g31 gpu could try and play a 706x480 file to see if it works ok and confirm I'm not crazy? You need to make sure it says "Using hardware decoding (drm)" in the terminal when mpv is launched. I guess there is a chance it's just a driver issue and not related to this repository at all.
Sorry for filling this thread with my issues. I'm calling it quits on this one and I'll just put up with it. It seems the v4l2request/drmprime stuff is a slow moving beast with ffmpeg/mpv and I have no interest in dealing with the dependency rabbit hole building my own versions. I found some references on the mpv github mentioning possible frame size issues so that's probably what causing my problems. I don't expect it will be fixed until ffmpeg upstream is sorted out. Going by current progress rates that's probably 2 years away....
I did find using --hwdec=drm-copy will play the files without producing the driver error but the green issue is still there. Using drm-copy with 1080p videos would be a little choppy though. I did a grep search on the mpv and mesa driver source code and couldn't find any reference to the "rejecting image due to unsupported offset" error so that must be coming from an external library.
I did have a small win as installing the backported Mesa driver did fix some slight screen tearing issues I was encountering on 1080p content.
Just some more info I forgot to mention that might help others.
I found other repositories for mpv for bookworm that were greater than the version in this repository (35.1) but none of them worked with drm. I believe it's because drm support gets skipped if mpv is built without libdrm being installed.
Run mpv --hwdec=help
If drm is not listed as one of the options it will not work. You need to find a build with drm support.
mpv_--hwdec=help.logis what I get, and everything works as expected, but I am on current mainline releases with in-flight patches for mpv and ffmpeg on top. Gstreamer framework based applications work out-of-the-box.
The log entries that contain the 'request' component are the ones that matter.
But you're right, it can still take a while before current mainline releases are declared stable by some distributions and adopted. But this is not the fault of mainline development, which continues to progress and does not take outdated versions into account any longer.
This repo is a bit behind what you are running. drm has been changed to v4l2request.
I'm going to assume you have hwdec=v4l2request in your mpv.conf file.
