robertoj Posted October 5, 2025 Posted October 5, 2025 (edited) 1 hour ago, jock said: I compiled mpv 0.40.0 on Debian Trixie with the patches for v4l2request, but the outcome is messy at best. There is a new hwdec v4l2request, but also two new gpu-hwdec-interop v4l2request and v4l2request-overlay. It works with acceleration when launched from a terminal, but in wayland/weston v4l2request refuses to work. I don't know what happened, but it looks like a big regression from 0.39. Better use the old mpv version IMHO. I thought that v4l2request was exclusively in this github project and branch: https://github.com/philipl/mpv/tree/v4l2request Which github project and branch/release are you trying? I successfully compiled and installed the mpv from https://github.com/philipl/mpv/tree/v4l2request I made the /etc/mpv.conf as per the original post Result: 50% cpu in 4 cores, about half dropped frames: Spoiler roberto@orangepizero3:~/mpv-philippl-v4l2request/mpv$ DISPLAY=:0.0 mpv -v ~/donde\ venderan\ buen\ trago\ 720p.mp4 [cplayer] Command line options: '-v' '/home/roberto/donde venderan buen trago 720p.mp4' [cplayer] mpv v0.1.0-18356-g17a8ef7e8 Copyright © 2000-2025 mpv/MPlayer/mplayer2 projects [cplayer] built on Oct 5 2025 18:48:33 [cplayer] libplacebo version: v7.349.0 [cplayer] FFmpeg version: 7.1.1-1 [cplayer] FFmpeg library versions: [cplayer] libavcodec 61.19.101 [cplayer] libavdevice 61.3.100 [cplayer] libavfilter 10.4.100 [cplayer] libavformat 61.7.100 [cplayer] libavutil 59.39.100 [cplayer] libswresample 5.3.100 [cplayer] libswscale 8.3.100 [cplayer] Configuration: [cplayer] List of enabled features: alsa build-date caca cdda cplugins debug dmabuf-interop-gl dmabuf-wayland drm dvbin dvdnav egl egl-drm egl-wayland egl-x11 ffmpeg gbm gl glibc-thread-name glob glob-posix gpl iconv jack javascript jpeg lcms2 libarchive libass libavdevice libbluray libdl libplacebo linux-fstatfs lua52 memfd-create memrchr pipewire posix posix-shm ppoll pthread-condattr-setclock pulse rubberband rubberband-3 sixel sndio sndio-1-9 uchardet v4l2request vaapi vaapi-drm vaapi-wayland vaapi-x11 vdpau vector vk-khr-display vt.h vulkan wayland wayland-protocols-1-32 wayland-protocols-1-38 wayland-protocols-1-39 wayland-protocols-1-41 wayland-protocols-1-44 x11 xv zlib [cplayer] Setting option 'v' = '' (flags = 😎 [clipboard] Initialized vo clipboard backend. [cplayer] Waiting for scripts... [cplayer] Set property: user-data/osc/visibility="auto" -> 1 [cplayer] Set property: user-data/osc/margins={"l":0,"b":0,"r":0,"t":0} -> 1 [cplayer] Done loading scripts. [cplayer] Running hook: auto_profiles/on_before_start_file [cplayer] Failed sending hook command auto_profiles/on_before_start_file. Removing hook. [cplayer] Running hook: auto_profiles/on_load [cplayer] Failed sending hook command auto_profiles/on_load. Removing hook. [cplayer] Running hook: ytdl_hook/on_load [cplayer] Running hook: ytdl_hook/on_load [ytdl_hook] playlist hook [ifo_dvdnav] Opening /home/roberto/donde venderan buen trago 720p.mp4 [bdmv/bluray] Opening /home/roberto/donde venderan buen trago 720p.mp4 [file] Opening /home/roberto/donde venderan buen trago 720p.mp4 [demux] Trying demuxers for level=normal. [cplayer] Set property: user-data/osc/margins={"l":0,"b":0,"r":0,"t":0} -> 1 [cplayer] Set property: user-data/osc/margins={"l":0,"b":0,"r":0,"t":0} -> 1 [osd/libass] libass API version: 0x1703000 [osd/libass] libass source: tarball: 0.17.3 [osd/libass] Shaper: FriBidi 1.0.15 (SIMPLE) HarfBuzz-ng 10.2.0 (COMPLEX) [osd/libass] Setting up fonts... [lavf] Found 'mov,mp4,m4a,3gp,3g2,mj2' at score=100 size=2048. [demux] Detected file format: mov,mp4,m4a,3gp,3g2,mj2 (libavformat) [cplayer] Opening done: /home/roberto/donde venderan buen trago 720p.mp4 [osd/libass] Using font provider fontconfig [osd/libass] Done. [find_files] Loading external files in /home/roberto/ [cplayer] Running hook: auto_profiles/on_preloaded [cplayer] Failed sending hook command auto_profiles/on_preloaded. Removing hook. [cplayer] Running hook: ytdl_hook/on_preloaded [lavf] select track 0 [lavf] select track 1 [cplayer] ● Video --vid=1 (h264 1280x720 29.97 fps) [default] [cplayer] ● Audio --aid=1 --alang=eng (aac 2ch 44100 Hz 128 kbps) [default] [vo/gpu-next] Probing for best GPU context. [vo/gpu-next/auto] Initializing GPU context 'auto' [vo/gpu-next/vulkan] Initializing GPU context 'waylandvk' [vo/gpu-next/libplacebo] Initialized libplacebo v7.349.0 (API v349) [vo/gpu-next/libplacebo] Creating vulkan instance with extensions: [vo/gpu-next/libplacebo] VK_KHR_get_physical_device_properties2 [vo/gpu-next/libplacebo] VK_KHR_portability_enumeration [vo/gpu-next/libplacebo] VK_KHR_surface [vo/gpu-next/libplacebo] VK_KHR_wayland_surface [vo/gpu-next/libplacebo] Failed creating instance: VK_ERROR_INCOMPATIBLE_DRIVER [vo/gpu-next/libplacebo] Failed initializing vulkan instance [vo/gpu-next/vulkan] Initializing GPU context 'x11vk' [vo/gpu-next/libplacebo] Initialized libplacebo v7.349.0 (API v349) [vo/gpu-next/libplacebo] Creating vulkan instance with extensions: [vo/gpu-next/libplacebo] VK_KHR_get_physical_device_properties2 [vo/gpu-next/libplacebo] VK_KHR_portability_enumeration [vo/gpu-next/libplacebo] VK_KHR_surface [vo/gpu-next/libplacebo] VK_KHR_xlib_surface [vo/gpu-next/libplacebo] Failed creating instance: VK_ERROR_INCOMPATIBLE_DRIVER [vo/gpu-next/libplacebo] Failed initializing vulkan instance [vo/gpu-next/opengl] Initializing GPU context 'wayland' [vo/gpu-next/opengl] Initializing GPU context 'x11egl' [vo/gpu-next/x11] X11 opening display: :0.0 [vo/gpu-next/x11] Display 0 (HDMI-1): [0, 0, 1920, 1080] @ 60.000000 FPS [vo/gpu-next/x11] Current display FPS: 60.000000 [vo/gpu-next/opengl] EGL_VERSION=1.5 [vo/gpu-next/opengl] EGL_VENDOR=Mesa Project [vo/gpu-next/opengl] EGL_CLIENT_APIS=OpenGL OpenGL_ES [vo/gpu-next/opengl] Trying to create Desktop OpenGL context. [vo/gpu-next/opengl] Choosing visual EGL config 0x9, visual ID 0x21 [vo/gpu-next/x11] The XPresent extension was found. [vo/gpu-next/x11] XPresent enabled. [vo/gpu-next/opengl] GL_VERSION='3.1 Mesa 25.0.7-2' [vo/gpu-next/opengl] Detected desktop OpenGL 3.1. [vo/gpu-next/opengl] GL_VENDOR='Mesa' [vo/gpu-next/opengl] GL_RENDERER='Mali-G31 (Panfrost)' [vo/gpu-next/opengl] GL_SHADING_LANGUAGE_VERSION='1.40' [vo/gpu-next/opengl] Loaded extension GL_ARB_sync. [vo/gpu-next/opengl] Loaded extension GL_ARB_timer_query. [vo/gpu-next/opengl] Loaded extension GL_ARB_invalidate_subdata. [vo/gpu-next/opengl] Loaded extension GL_ARB_get_program_binary. [vo/gpu-next/opengl] Loaded extension GL_ARB_buffer_storage. [vo/gpu-next/opengl] Loaded extension GL_ARB_shader_image_load_store. [vo/gpu-next/opengl] Loaded extension GL_ARB_shader_storage_buffer_object. [vo/gpu-next/opengl] Loaded extension GL_ARB_arrays_of_arrays. [vo/gpu-next/opengl] Loaded extension GL_ARB_debug_output. [vo/gpu-next/opengl] Loaded extension GL_KHR_debug. [vo/gpu-next/libplacebo] Initialized libplacebo v7.349.0 (API v349) [vo/gpu-next/libplacebo] Detected OpenGL version strings: [vo/gpu-next/libplacebo] GL_VERSION: 3.1 Mesa 25.0.7-2 [vo/gpu-next/libplacebo] GL_VENDOR: Mesa [vo/gpu-next/libplacebo] GL_RENDERER: Mali-G31 (Panfrost) [vo/gpu-next/libplacebo] GL_SHADING_LANGUAGE_VERSION: 1.40 [vo/gpu-next/libplacebo] GPU information: [vo/gpu-next/libplacebo] GLSL version: 140 [vo/gpu-next/libplacebo] subgroup_size: 0 [vo/gpu-next/libplacebo] min_gather_offset: 0 [vo/gpu-next/libplacebo] max_gather_offset: 0 [vo/gpu-next/libplacebo] Limits: [vo/gpu-next/libplacebo] thread_safe: 0 [vo/gpu-next/libplacebo] callbacks: 1 [vo/gpu-next/libplacebo] max_buf_size: 18446744073709551615 [vo/gpu-next/libplacebo] max_ubo_size: 65536 [vo/gpu-next/libplacebo] max_ssbo_size: 134217728 [vo/gpu-next/libplacebo] max_vbo_size: 18446744073709551615 [vo/gpu-next/libplacebo] max_mapped_size: 18446744073709551615 [vo/gpu-next/libplacebo] max_buffer_texels: 0 [vo/gpu-next/libplacebo] align_host_ptr: 0 [vo/gpu-next/libplacebo] host_cached: 0 [vo/gpu-next/libplacebo] max_tex_1d_dim: 16384 [vo/gpu-next/libplacebo] max_tex_2d_dim: 16384 [vo/gpu-next/libplacebo] max_tex_3d_dim: 16384 [vo/gpu-next/libplacebo] blittable_1d_3d: 0 [vo/gpu-next/libplacebo] buf_transfer: 1 [vo/gpu-next/libplacebo] align_tex_xfer_pitch: 4 [vo/gpu-next/libplacebo] align_tex_xfer_offset: 32 [vo/gpu-next/libplacebo] max_variable_comps: 16380 [vo/gpu-next/libplacebo] max_constants: 0 [vo/gpu-next/libplacebo] max_pushc_size: 0 [vo/gpu-next/libplacebo] align_vertex_stride: 1 [vo/gpu-next/libplacebo] fragment_queues: 1 [vo/gpu-next/libplacebo] compute_queues: 0 [vo/gpu-next/libplacebo] External API interop: [vo/gpu-next/libplacebo] UUID: 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00 [vo/gpu-next/libplacebo] PCI: 0000:00:00:0 [vo/gpu-next/libplacebo] buf export caps: 0x0 [vo/gpu-next/libplacebo] buf import caps: 0x0 [vo/gpu-next/libplacebo] tex export caps: 0x8 [vo/gpu-next/libplacebo] tex import caps: 0x8 [vo/gpu-next/libplacebo] sync export caps: 0x0 [vo/gpu-next/libplacebo] sync import caps: 0x0 [vo/gpu-next] Assuming 60.000000 FPS for display sync. [vd] Container reported FPS: 29.970030 [vd] Codec list: [vd] h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [vd] h264_v4l2m2m (h264) - V4L2 mem2mem H.264 decoder wrapper [vd] h264_cuvid (h264) - Nvidia CUVID H264 decoder [vd] Opening decoder h264 [vd] No hardware decoding requested. [vd] Using software decoding. [vd] Detected 4 logical cores. [vd] Requesting 5 threads for decoding. [vd] Selected decoder: h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [vf] User filter list: [vf] (empty) [ad] Codec list: [ad] aac - AAC (Advanced Audio Coding) [ad] aac_fixed (aac) - AAC (Advanced Audio Coding) [ad] Opening decoder aac [ad] Requesting 1 threads for decoding. [ad] Selected decoder: aac - AAC (Advanced Audio Coding) [af] User filter list: [af] (empty) [cplayer] Starting playback... [af] [in] 44100Hz stereo 2ch floatp [af] [userspeed] 44100Hz stereo 2ch floatp [af] [userspeed] (disabled) [af] [convert] 44100Hz stereo 2ch floatp [vd] DR failed - disabling. [vd] Using software decoding. [vd] Decoder format: 1280x720 yuv420p bt.709/bt.709/bt.1886/limited/auto CL=mpeg2/4/h264 crop=1280x720+0+0 A=none [vd] Using container aspect ratio. [vf] [in] 1280x720 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1280x720+0+0 A=none [vf] [userdeint] 1280x720 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1280x720+0+0 A=none [vf] [userdeint] (disabled) [vf] [autovflip] 1280x720 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1280x720+0+0 A=none [vf] [autovflip] (disabled) [vf] [autorotate] 1280x720 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1280x720+0+0 A=none [vf] [autorotate] (disabled) [vf] [convert] 1280x720 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1280x720+0+0 A=none [vf] [convert] (disabled) [vf] [out] 1280x720 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1280x720+0+0 A=none [osd/libass] libass API version: 0x1703000 [osd/libass] libass source: tarball: 0.17.3 [osd/libass] Shaper: FriBidi 1.0.15 (SIMPLE) HarfBuzz-ng 10.2.0 (COMPLEX) [osd/libass] Setting up fonts... [osd/libass] Using font provider fontconfig [osd/libass] Done. [ao] Trying audio driver 'pipewire' [ao/pipewire] requested format: 44100 Hz, stereo channels, floatp [ao/pipewire] Headers version: 1.4.2 [ao/pipewire] Library version: 1.4.2 [W][19:21:30.962233] pw.conf | [ conf.c: 1182 try_load_conf()] can't load config client.conf: No such file or directory [E][19:21:30.962448] pw.conf | [ conf.c: 1215 pw_conf_load_conf_for_context()] can't load config client.conf: No such file or directory [ao] Trying audio driver 'pulse' [ao/pulse] requested format: 44100 Hz, stereo channels, floatp [ao/pulse] Library version: 17.0.0 [ao/pulse] Proto: 35 [ao/pulse] Server proto: 35 [ao/pulse] Channel layouts: [ao/pulse] - #fl [ao/pulse] - #fr [ao/pulse] - #fc [ao/pulse] - #lfe [ao/pulse] - #bl [ao/pulse] - #br [ao/pulse] - #flc [ao/pulse] - #frc [ao/pulse] - #bc [ao/pulse] - #sl [ao/pulse] - #sr [ao/pulse] - #tc [ao/pulse] - #tfl [ao/pulse] - #tfc [ao/pulse] - #tfr [ao/pulse] - #tbl [ao/pulse] - #tbc [ao/pulse] - #tbr [ao/pulse] result: stereo [ao/pulse] device buffer: 6172 samples. [ao/pulse] using soft-buffer of 8820 samples. [cplayer] AO: [pulse] 44100Hz stereo 2ch float [cplayer] AO: Description: PulseAudio audio output [autoconvert] inserting resampler [swresample] format change, reinitializing resampler [swresample] 44100Hz stereo floatp -> 44100Hz stereo float [af] [out] 44100Hz stereo 2ch float [cplayer] VO: [gpu-next] 1280x720 yuv420p [cplayer] VO: Description: Video output based on libplacebo [vo/gpu-next] reconfig to 1280x720 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1280x720+0+0 A=none [vo/gpu-next] Window size: 1280x720 (Borders: l=0 t=0 r=0 b=0) [vo/gpu-next] Video source: 1280x720 (1:1) [vo/gpu-next] Video display: (0, 0) 1280x720 -> (0, 0) 1280x720 [vo/gpu-next] Video scale: 1.000000/1.000000 [vo/gpu-next] OSD borders: l=0 t=0 r=0 b=0 [vo/gpu-next] Video borders: l=0 t=0 r=0 b=0 [vo/gpu-next/libplacebo] Dithering to 8 bit depth [cplayer] first video frame after restart shown [cplayer] audio ready [cplayer] starting audio playback [vo/gpu-next/x11] Disabling screensaver. [cplayer] playback restart complete @ 0.000000, audio=playing, video=playing [ao/pulse] starting AO [vo/gpu-next/libplacebo] Detected fps ratio 0.0000 below threshold 0.0100, disabling interpolation [cplayer] Set property: user-data/osc/margins={"l":0,"b":0,"r":0,"t":0} -> 1 [vo/gpu-next/libplacebo] Detected fps ratio 0.5000 exceeds threshold 0.0100, re-enabling interpolation [vo/gpu-next/libplacebo] Estimated source FPS: 29.970, display FPS: 9.990 [vo/gpu-next/libplacebo] Estimated source FPS: 29.970, display FPS: 14.985 [vo/gpu-next/libplacebo] Estimated source FPS: 29.970, display FPS: 9.990 [vo/gpu-next/libplacebo] Estimated source FPS: 29.970, display FPS: 14.985 [cplayer] EOF code: 5 [statusline] AV: 00:00:15 / 00:04:18 (6%) A-V: 0.000 Dropped: 283 [cplayer] finished playback, success (reason 3) [cplayer] Running hook: ytdl_hook/on_after_end_file [vo/gpu-next/x11] Enabling screensaver. [cplayer] Exiting... (Quit) roberto@orangepizero3:~/mpv-philippl-v4l2request/mpv$ I don't see any mention of hwdec=drm in the mpv log I used the libplacebo from Trixie, not compiled on my own... I can try that next. <- final update for this post: libplacebo downloaded and built by myself did not help... but now I will try mpv 0.3.9 Edited October 5, 2025 by robertoj 0 Quote
jock Posted October 5, 2025 Author Posted October 5, 2025 39 minutes ago, robertoj said: Which github project and branch/release are you trying? mpv official github repo. v4l2request commits are in a pull request. 0 Quote
robertoj Posted October 5, 2025 Posted October 5, 2025 (edited) I am not sure if I am using the git command correctly to get mpv-0.3.9 with PR14690.. Please help roberto@orangepizero3:~$ mkdir mpv-official roberto@orangepizero3:~$ cd mpv-official/ roberto@orangepizero3:~/mpv-official$ git clone https://github.com/mpv-player/mpv roberto@orangepizero3:~/mpv-official$ cd mpv roberto@orangepizero3:~/mpv-official/mpv$ git checkout -b release/0.39 roberto@orangepizero3:~/mpv-official/mpv$ gh pr checkout 14690 <- downloads and applies the v4l2request changes roberto@orangepizero3:~/mpv-official/mpv$ nano video/out/gpu/hwdec.c <-- I see the added changes in the hwdec.c file roberto@orangepizero3:~/mpv-official/mpv$ meson setup build <-- everything configures ok, but at the end, it shows that I got mpv-0.40 I asked in the mpv github and a contributor said they are waiting for ffmpeg first incorporate v4l2request, then they will add the feature in mpv Ref: https://github.com/mpv-player/mpv/pull/14690#issuecomment-3369829206 Applying the pr14690 manually on top of mpv 0.3.9 is something that i could do, if there’s no choice For later: Use something like https://github.com/foo/bar/commit/${SHA}.patch , to try to get the PR14690 https://stackoverflow.com/questions/21903805/how-to-download-a-single-commit-diff-from-github Patches to apply: https://github.com/mpv-player/mpv/commit/d9bb7241bbc8dfdf1c76293d28cb162c2688e2b6.patch https://github.com/mpv-player/mpv/commit/17a8ef7e8752e39f8c5284127b5d7ba1cce64f48.patch Previous discussions and ffmpeg too: https://github.com/mpv-player/mpv/pull/14511 https://ffmpeg.org/pipermail/ffmpeg-devel/2024-August/332034.html https://ffmpeg.org/pipermail/ffmpeg-devel/2024-August/332035.html How to patch. Spoiler * download the 2 patch files above $ cd mpv $ patch -p1 < 17a8ef7e8752e39f8c5284127b5d7ba1cce64f48.patch patching file video/hwdec.c patching file video/hwdec.h Hunk #1 succeeded at 108 (offset -13 lines). patching file video/out/gpu/hwdec.c patching file video/out/hwdec/hwdec_drmprime.c patching file video/out/hwdec/hwdec_drmprime_overlay.c patching file video/out/vo_dmabuf_wayland.c Hunk #1 FAILED at 857. 1 out of 1 hunk FAILED -- saving rejects to file video/out/vo_dmabuf_wayland.c.rej patching file video/v4l2request.c $ patch -p1 < d9bb7241bbc8dfdf1c76293d28cb162c2688e2b6.patch patching file meson.build Hunk #1 succeeded at 1406 (offset 1 line). Hunk #2 succeeded at 1865 (offset -4 lines). can't find file to patch at input line 44 Perhaps you used the wrong -p or --strip option? The text leading up to this was: -------------------------- |diff --git a/meson.options b/meson.options |index dae0a333ef71b..3dba7a1451dab 100644 |--- a/meson.options |+++ b/meson.options -------------------------- File to patch: meson_options.txt patching file meson_options.txt Hunk #1 succeeded at 101 (offset 2 lines). Finally, I got this error since the first linking action [307/310] Linking target mpv FAILED: mpv cc -o mpv libmpv.so.2.3.0.p/aud... (and over a thousand linking errors) Edited October 8, 2025 by robertoj 0 Quote
robertoj Posted October 8, 2025 Posted October 8, 2025 (edited) Anyone trying to compile mpv 0.3.9, is it possible to do it with Linux 6.15? With the libraries in Debian Trixie? (considering mpv 0.3.9 is from sept 2024, and Trixie came with mpv-0.4.0) https://github.com/mpv-player/mpv/releases I think I am failing the compilation's linking stage, because I had a different mpv and its libraries already installed. Probably I need to format my microSD and re-image. Edited October 9, 2025 by robertoj 0 Quote
robertoj Posted October 10, 2025 Posted October 10, 2025 (edited) I was successful in compiling mpv-0.3.9 + the 2 patches from PR14690. I downloaded the release mpv as a tar.gz, expanded it, and applied the 2 patches. One hunk failed but it wasnt needed A 720p h264 video played with 10% CPU: (note that the options are --hwdec=v4l2request --drm-drmprime-video-plane=primary --drm-draw-plane=overlay -v Spoiler roberto@orangepizero3:~/mpv-official/mpv-0.39.0$ DISPLAY=:0.0 ./build/mpv --hwdec=v4l2request --drm-drmprime-video-plane=primary --drm-draw-plane=overlay -v ~/donde\ venderan\ buen\ trago\ 720p.mp4 [cplayer] Command line options: '--hwdec=v4l2request' '--drm-drmprime-video-plane=primary' '--drm-draw-plane=overlay' '-v' '/home/roberto/donde venderan buen trago 720p.mp4' [cplayer] mpv 0.39.0 Copyright © 2000-2024 mpv/MPlayer/mplayer2 projects [cplayer] built on Oct 10 2025 10:05:25 [cplayer] libplacebo version: v7.349.0 [cplayer] FFmpeg version: 7.1.2-0+deb13u1 [cplayer] FFmpeg library versions: [cplayer] libavcodec 61.19.101 [cplayer] libavdevice 61.3.100 [cplayer] libavfilter 10.4.100 [cplayer] libavformat 61.7.100 [cplayer] libavutil 59.39.100 [cplayer] libswresample 5.3.100 [cplayer] libswscale 8.3.100 [cplayer] Configuration: [cplayer] List of enabled features: alsa build-date caca cplugins debug dmabuf-interop-gl dmabuf-wayland drm dvbin egl egl-drm egl-wayland egl-x11 ffmpeg gbm gl glibc-thread-name glob glob-posix gpl iconv jack javascript jpeg lcms2 libarchive libass libavdevice libbluray libdl libplacebo linux-fstatfs lua52 memfd-create memrchr pipewire posix posix-shm ppoll pthread-condattr-setclock pulse rubberband rubberband-3 sixel sndio sndio-1-9 uchardet v4l2request vaapi vaapi-drm vaapi-wayland vaapi-x11 vdpau vector vk-khr-display vt.h vulkan wayland wayland-protocols-1-32 x11 xv zlib [cplayer] Setting option 'hwdec' = 'v4l2request' (flags = 😎 [cplayer] Setting option 'drm-drmprime-video-plane' = 'primary' (flags = 😎 [cplayer] Setting option 'drm-draw-plane' = 'overlay' (flags = 😎 [cplayer] Setting option 'v' = '' (flags = 😎 [cplayer] Waiting for scripts... [cplayer] Set property: user-data/osc/visibility="auto" -> 1 [cplayer] Set property: user-data/osc/margins={"b":0,"l":0,"t":0,"r":0} -> 1 [cplayer] Done loading scripts. [cplayer] Running hook: auto_profiles/on_before_start_file [cplayer] Running hook: ytdl_hook/on_load [cplayer] Set property: user-data/osc/margins={"b":0,"l":0,"t":0,"r":0} -> 1 [cplayer] Running hook: ytdl_hook/on_load [ytdl_hook] playlist hook [cplayer] Running hook: auto_profiles/on_load [bdmv/bluray] Opening /home/roberto/donde venderan buen trago 720p.mp4 [file] Opening /home/roberto/donde venderan buen trago 720p.mp4 [demux] Trying demuxers for level=normal. [cplayer] Set property: user-data/osc/margins={"b":0,"l":0,"t":0,"r":0} -> 1 [osd/libass] libass API version: 0x1703000 [osd/libass] libass source: tarball: 0.17.3 [osd/libass] Shaper: FriBidi 1.0.15 (SIMPLE) HarfBuzz-ng 10.2.0 (COMPLEX) [osd/libass] Setting up fonts... [lavf] Found 'mov,mp4,m4a,3gp,3g2,mj2' at score=100 size=2048. [osd/libass] Using font provider fontconfig [osd/libass] Done. [demux] Detected file format: mov,mp4,m4a,3gp,3g2,mj2 (libavformat) [cplayer] Opening done: /home/roberto/donde venderan buen trago 720p.mp4 [find_files] Loading external files in /home/roberto/ [cplayer] Running hook: ytdl_hook/on_preloaded [cplayer] Running hook: auto_profiles/on_preloaded [lavf] select track 0 [lavf] select track 1 [cplayer] ● Video --vid=1 (h264 1280x720 29.97 fps) [default] [cplayer] ● Audio --aid=1 --alang=eng (aac 2ch 44100 Hz 128 kbps) [default] [vo/gpu] Probing for best GPU context. [vo/gpu/auto] Initializing GPU context 'auto' [vo/gpu/opengl] Initializing GPU context 'wayland' [vo/gpu/opengl] Initializing GPU context 'x11egl' [vo/gpu/x11] X11 opening display: :0.0 [vo/gpu/x11] Display 0 (HDMI-1): [0, 0, 1920, 1080] @ 60.000000 FPS [vo/gpu/x11] Current display FPS: 60.000000 [vo/gpu/opengl] EGL_VERSION=1.5 [vo/gpu/opengl] EGL_VENDOR=Mesa Project [vo/gpu/opengl] EGL_CLIENT_APIS=OpenGL OpenGL_ES [vo/gpu/opengl] Trying to create Desktop OpenGL context. [vo/gpu/opengl] Choosing visual EGL config 0x9, visual ID 0x21 [vo/gpu/x11] The XPresent extension was found. [vo/gpu/x11] XPresent enabled. [vo/gpu/opengl] GL_VERSION='3.1 Mesa 25.0.7-2' [vo/gpu/opengl] Detected desktop OpenGL 3.1. [vo/gpu/opengl] GL_VENDOR='Mesa' [vo/gpu/opengl] GL_RENDERER='Mali-G31 (Panfrost)' [vo/gpu/opengl] GL_SHADING_LANGUAGE_VERSION='1.40' [vo/gpu/opengl] Loaded extension GL_ARB_sync. [vo/gpu/opengl] Loaded extension GL_ARB_timer_query. [vo/gpu/opengl] Loaded extension GL_ARB_invalidate_subdata. [vo/gpu/opengl] Loaded extension GL_ARB_get_program_binary. [vo/gpu/opengl] Loaded extension GL_ARB_buffer_storage. [vo/gpu/opengl] Loaded extension GL_ARB_shader_image_load_store. [vo/gpu/opengl] Loaded extension GL_ARB_shader_storage_buffer_object. [vo/gpu/opengl] Loaded extension GL_ARB_arrays_of_arrays. [vo/gpu/opengl] Loaded extension GL_ARB_debug_output. [vo/gpu/opengl] Loaded extension GL_KHR_debug. [vo/gpu] Testing FBO format rgba16f [vo/gpu] Using FBO format rgba16f. [vo/gpu] Disabling HDR peak computation (one or more of the following is not supported: compute shaders=0, SSBO=1). [vo/gpu] Assuming 60.000000 FPS for display sync. [vd] Container reported FPS: 29.970030 [vd] Codec list: [vd] h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [vd] h264_v4l2m2m (h264) - V4L2 mem2mem H.264 decoder wrapper [vd] h264_cuvid (h264) - Nvidia CUVID H264 decoder [vd] Opening decoder h264 [vd] Looking at hwdec h264-v4l2request... [vo/gpu] Loading hwdec drivers for format: 'drm_prime' [vo/gpu] Loading hwdec driver 'drmprime' [vo/gpu/drmprime] Using EGL dmabuf interop via GL_EXT_EGL_image_storage [vo/gpu/drmprime] Using DRM device: /dev/dri/renderD128 [vo/gpu] Loading hwdec driver 'drmprime-overlay' [vo/gpu/drmprime-overlay] Failed to retrieve DRM fd from native display. [vo/gpu] Loading failed. [vo/gpu] Loading hwdec driver 'v4l2request' [vo/gpu/v4l2request] Using EGL dmabuf interop via GL_EXT_EGL_image_storage [vo/gpu] Loading hwdec driver 'v4l2request-overlay' [vo/gpu/v4l2request-overlay] Failed to retrieve DRM fd from native display. [vo/gpu] Loading failed. [vd] Trying hardware decoding via h264-v4l2request. [vd] Selected decoder: h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [vf] User filter list: [vf] (empty) [ad] Codec list: [ad] aac - AAC (Advanced Audio Coding) [ad] aac_fixed (aac) - AAC (Advanced Audio Coding) [ad] Opening decoder aac [ad] Requesting 1 threads for decoding. [ad] Selected decoder: aac - AAC (Advanced Audio Coding) [af] User filter list: [af] (empty) [cplayer] Starting playback... [af] [in] 44100Hz stereo 2ch floatp [af] [userspeed] 44100Hz stereo 2ch floatp [af] [userspeed] (disabled) [af] [convert] 44100Hz stereo 2ch floatp [vd] Pixel formats supported by decoder: vdpau vulkan cuda drm_prime vaapi yuv420p [vd] Codec profile: Main (0x4d) [vd] Requesting pixfmt 'drm_prime' from decoder. [ffmpeg/video] h264: Using V4L2 media driver cedrus (6.15.4) for S264 [vd] Using hardware decoding (v4l2request). [vd] Decoder format: 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/auto CL=mpeg2/4/h264 crop=1280x720+0+0 [vd] Using container aspect ratio. [vf] [in] 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1280x720+0+0 [vf] [userdeint] 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1280x720+0+0 [vf] [userdeint] (disabled) [vf] [autorotate] 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1280x720+0+0 [vf] [autorotate] (disabled) [vf] [convert] 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1280x720+0+0 [vo/gpu] Loading hwdec drivers for format: 'drm_prime' [vo/gpu] Loading hwdec driver 'drmprime-overlay' [vo/gpu/drmprime-overlay] Failed to retrieve DRM fd from native display. [vo/gpu] Loading failed. [vo/gpu] Loading hwdec driver 'v4l2request-overlay' [vo/gpu/v4l2request-overlay] Failed to retrieve DRM fd from native display. [vo/gpu] Loading failed. [hwupload] hwdec 'drmprime' does not report hwframe constraints. Using static metadata. [vf] [out] 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1280x720+0+0 [ao] Trying audio driver 'pipewire' [ao/pipewire] requested format: 44100 Hz, stereo channels, floatp [ao/pipewire] Headers version: 1.4.2 [ao/pipewire] Library version: 1.4.2 [W][10:19:43.740112] pw.conf | [ conf.c: 1204 pw_conf_load_conf_for_context()] setting config.name to client-rt.conf is deprecated, using client.conf [W][10:19:43.740371] pw.conf | [ conf.c: 1182 try_load_conf()] can't load config client.conf: No such file or directory [E][10:19:43.740422] pw.conf | [ conf.c: 1215 pw_conf_load_conf_for_context()] can't load config client.conf: No such file or directory [ao] Trying audio driver 'pulse' [ao/pulse] requested format: 44100 Hz, stereo channels, floatp [ao/pulse] Library version: 17.0.0 [ao/pulse] Proto: 35 [ao/pulse] Server proto: 4294967295 [ao/pulse] Channel layouts: [ao/pulse] - #fl [ao/pulse] - #fr [ao/pulse] - #fc [ao/pulse] - #lfe [ao/pulse] - #bl [ao/pulse] - #br [ao/pulse] - #flc [ao/pulse] - #frc [ao/pulse] - #bc [ao/pulse] - #sl [ao/pulse] - #sr [ao/pulse] - #tc [ao/pulse] - #tfl [ao/pulse] - #tfc [ao/pulse] - #tfr [ao/pulse] - #tbl [ao/pulse] - #tbc [ao/pulse] - #tbr [ao/pulse] result: stereo [ao/pulse] device buffer: 6172 samples. [ao/pulse] using soft-buffer of 8820 samples. [cplayer] AO: [pulse] 44100Hz stereo 2ch float [cplayer] AO: Description: PulseAudio audio output [autoconvert] inserting resampler [swresample] format change, reinitializing resampler [swresample] 44100Hz stereo floatp -> 44100Hz stereo float [af] [out] 44100Hz stereo 2ch float [cplayer] VO: [gpu] 1280x720 drm_prime[nv12] [cplayer] VO: Description: Shader-based GPU Renderer [vo/gpu] reconfig to 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1280x720+0+0 [vo/gpu] Resize: 1280x720 [vo/gpu] Window size: 1280x720 (Borders: l=0 t=0 r=0 b=0) [vo/gpu] Video source: 1280x720 (1:1) [vo/gpu] Video display: (0, 0) 1280x720 -> (0, 0) 1280x720 [vo/gpu] Video scale: 1.000000/1.000000 [vo/gpu] OSD borders: l=0 t=0 r=0 b=0 [vo/gpu] Video borders: l=0 t=0 r=0 b=0 [vo/gpu] Reported display depth: 8 [vo/gpu] Testing FBO format rgba16f [vo/gpu] Using FBO format rgba16f. [vo/gpu] Dither to 8. [cplayer] first video frame after restart shown [osd/libass] libass API version: 0x1703000 [osd/libass] libass source: tarball: 0.17.3 [osd/libass] Shaper: FriBidi 1.0.15 (SIMPLE) HarfBuzz-ng 10.2.0 (COMPLEX) [osd/libass] Setting up fonts... [osd/libass] Using font provider fontconfig [osd/libass] Done. [cplayer] Set property: user-data/osc/margins={"b":0,"l":0,"t":0,"r":0} -> 1 [cplayer] audio ready [cplayer] starting audio playback [cplayer] playback restart complete @ 0.000000, audio=playing, video=playing [vo/gpu/x11] Disabling screensaver. [ao/pulse] starting AO [cplayer] Set property: user-data/osc/margins={"b":0,"l":0,"t":0,"r":0} -> 1 [cplayer] EOF code: 5 [vo/gpu/x11] Enabling screensaver. [statusline] AV: 00:00:29 / 00:04:18 (11%) A-V: 0.000 [cplayer] finished playback, success (reason 3) [cplayer] Running hook: ytdl_hook/on_after_end_file [cplayer] Exiting... (Quit) [cplayer] Set property: user-data/osc/margins={"b":0,"l":0,"t":0,"r":0} -> 1 roberto@orangepizero3:~/mpv-official/mpv-0.39.0$ Next, I tried with a 1080p h264... in this case, I needed the extraargs=cma=256M line in armbianEnv.txt. Result, low CPU usage, but dropped frames (choppy video) I didn't need to install mpv, because I ran it from within the build directory Removing the --drm-drmprime-video-plane=primary --drm-draw-plane=overlay from the options didn't make any positive or negative difference Spoiler roberto@orangepizero3:~/mpv-official/mpv-0.39.0$ DISPLAY=:0.0 ./build/mpv --hwdec=v4l2request --drm-drmprime-video-plane=primary --drm-draw-plane=overlay -v ~/concert.mp4 [cplayer] Command line options: '--hwdec=v4l2request' '--drm-drmprime-video-plane=primary' '--drm-draw-plane=overlay' '-v' '/home/roberto/concert.mp4' [cplayer] mpv 0.39.0 Copyright © 2000-2024 mpv/MPlayer/mplayer2 projects [cplayer] built on Oct 10 2025 10:05:25 [cplayer] libplacebo version: v7.349.0 [cplayer] FFmpeg version: 7.1.2-0+deb13u1 [cplayer] FFmpeg library versions: [cplayer] libavcodec 61.19.101 [cplayer] libavdevice 61.3.100 [cplayer] libavfilter 10.4.100 [cplayer] libavformat 61.7.100 [cplayer] libavutil 59.39.100 [cplayer] libswresample 5.3.100 [cplayer] libswscale 8.3.100 [cplayer] Configuration: [cplayer] List of enabled features: alsa build-date caca cplugins debug dmabuf-interop-gl dmabuf-wayland drm dvbin egl egl-drm egl-wayland egl-x11 ffmpeg gbm gl glibc-thread-name glob glob-posix gpl iconv jack javascript jpeg lcms2 libarchive libass libavdevice libbluray libdl libplacebo linux-fstatfs lua52 memfd-create memrchr pipewire posix posix-shm ppoll pthread-condattr-setclock pulse rubberband rubberband-3 sixel sndio sndio-1-9 uchardet v4l2request vaapi vaapi-drm vaapi-wayland vaapi-x11 vdpau vector vk-khr-display vt.h vulkan wayland wayland-protocols-1-32 x11 xv zlib [cplayer] Setting option 'hwdec' = 'v4l2request' (flags = 😎 [cplayer] Setting option 'drm-drmprime-video-plane' = 'primary' (flags = 😎 [cplayer] Setting option 'drm-draw-plane' = 'overlay' (flags = 😎 [cplayer] Setting option 'v' = '' (flags = 😎 [cplayer] Waiting for scripts... [cplayer] Set property: user-data/osc/visibility="auto" -> 1 [cplayer] Set property: user-data/osc/margins={"l":0,"b":0,"r":0,"t":0} -> 1 [cplayer] Done loading scripts. [cplayer] Running hook: auto_profiles/on_before_start_file [cplayer] Running hook: ytdl_hook/on_load [cplayer] Set property: user-data/osc/margins={"l":0,"b":0,"r":0,"t":0} -> 1 [cplayer] Running hook: ytdl_hook/on_load [ytdl_hook] playlist hook [cplayer] Running hook: auto_profiles/on_load [bdmv/bluray] Opening /home/roberto/concert.mp4 [file] Opening /home/roberto/concert.mp4 [demux] Trying demuxers for level=normal. [cplayer] Set property: user-data/osc/margins={"l":0,"b":0,"r":0,"t":0} -> 1 [osd/libass] libass API version: 0x1703000 [osd/libass] libass source: tarball: 0.17.3 [osd/libass] Shaper: FriBidi 1.0.15 (SIMPLE) HarfBuzz-ng 10.2.0 (COMPLEX) [osd/libass] Setting up fonts... [lavf] Found 'mov,mp4,m4a,3gp,3g2,mj2' at score=100 size=2048. [demux] Detected file format: mov,mp4,m4a,3gp,3g2,mj2 (libavformat) [cplayer] Opening done: /home/roberto/concert.mp4 [osd/libass] Using font provider fontconfig [osd/libass] Done. [find_files] Loading external files in /home/roberto/ [cplayer] Running hook: ytdl_hook/on_preloaded [cplayer] Running hook: auto_profiles/on_preloaded [lavf] select track 0 [cplayer] ● Video --vid=1 (h264 1920x1080 30 fps) [default] [vo/gpu] Probing for best GPU context. [vo/gpu/auto] Initializing GPU context 'auto' [vo/gpu/opengl] Initializing GPU context 'wayland' [vo/gpu/opengl] Initializing GPU context 'x11egl' [vo/gpu/x11] X11 opening display: :0.0 [vo/gpu/x11] Display 0 (HDMI-1): [0, 0, 1920, 1080] @ 60.000000 FPS [vo/gpu/x11] Current display FPS: 60.000000 [vo/gpu/opengl] EGL_VERSION=1.5 [vo/gpu/opengl] EGL_VENDOR=Mesa Project [vo/gpu/opengl] EGL_CLIENT_APIS=OpenGL OpenGL_ES [vo/gpu/opengl] Trying to create Desktop OpenGL context. [vo/gpu/opengl] Choosing visual EGL config 0x9, visual ID 0x21 [vo/gpu/x11] The XPresent extension was found. [vo/gpu/x11] XPresent enabled. [vo/gpu/opengl] GL_VERSION='3.1 Mesa 25.0.7-2' [vo/gpu/opengl] Detected desktop OpenGL 3.1. [vo/gpu/opengl] GL_VENDOR='Mesa' [vo/gpu/opengl] GL_RENDERER='Mali-G31 (Panfrost)' [vo/gpu/opengl] GL_SHADING_LANGUAGE_VERSION='1.40' [vo/gpu/opengl] Loaded extension GL_ARB_sync. [vo/gpu/opengl] Loaded extension GL_ARB_timer_query. [vo/gpu/opengl] Loaded extension GL_ARB_invalidate_subdata. [vo/gpu/opengl] Loaded extension GL_ARB_get_program_binary. [vo/gpu/opengl] Loaded extension GL_ARB_buffer_storage. [vo/gpu/opengl] Loaded extension GL_ARB_shader_image_load_store. [vo/gpu/opengl] Loaded extension GL_ARB_shader_storage_buffer_object. [vo/gpu/opengl] Loaded extension GL_ARB_arrays_of_arrays. [vo/gpu/opengl] Loaded extension GL_ARB_debug_output. [vo/gpu/opengl] Loaded extension GL_KHR_debug. [vo/gpu] Testing FBO format rgba16f [vo/gpu] Using FBO format rgba16f. [vo/gpu] Disabling HDR peak computation (one or more of the following is not supported: compute shaders=0, SSBO=1). [vo/gpu] Assuming 60.000000 FPS for display sync. [vd] Container reported FPS: 30.000000 [vd] Codec list: [vd] h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [vd] h264_v4l2m2m (h264) - V4L2 mem2mem H.264 decoder wrapper [vd] h264_cuvid (h264) - Nvidia CUVID H264 decoder [vd] Opening decoder h264 [vd] Looking at hwdec h264-v4l2request... [vo/gpu] Loading hwdec drivers for format: 'drm_prime' [vo/gpu] Loading hwdec driver 'drmprime' [vo/gpu/drmprime] Using EGL dmabuf interop via GL_EXT_EGL_image_storage [vo/gpu/drmprime] Using DRM device: /dev/dri/renderD128 [vo/gpu] Loading hwdec driver 'drmprime-overlay' [vo/gpu/drmprime-overlay] Failed to retrieve DRM fd from native display. [vo/gpu] Loading failed. [vo/gpu] Loading hwdec driver 'v4l2request' [vo/gpu/v4l2request] Using EGL dmabuf interop via GL_EXT_EGL_image_storage [vo/gpu] Loading hwdec driver 'v4l2request-overlay' [vo/gpu/v4l2request-overlay] Failed to retrieve DRM fd from native display. [vo/gpu] Loading failed. [vd] Trying hardware decoding via h264-v4l2request. [vd] Selected decoder: h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [vf] User filter list: [vf] (empty) [cplayer] Starting playback... [vd] Pixel formats supported by decoder: vdpau vulkan cuda drm_prime vaapi yuv420p [vd] Codec profile: High (0x64) [vd] Requesting pixfmt 'drm_prime' from decoder. [ffmpeg/video] h264: Using V4L2 media driver cedrus (6.15.4) for S264 [vd] Using hardware decoding (v4l2request). [vd] Decoder format: 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/auto CL=mpeg2/4/h264 crop=1920x1080+0+0 [vf] [in] 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0 [vf] [userdeint] 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0 [vf] [userdeint] (disabled) [vf] [autorotate] 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0 [vf] [autorotate] (disabled) [vf] [convert] 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0 [vo/gpu] Loading hwdec drivers for format: 'drm_prime' [vo/gpu] Loading hwdec driver 'drmprime-overlay' [vo/gpu/drmprime-overlay] Failed to retrieve DRM fd from native display. [vo/gpu] Loading failed. [vo/gpu] Loading hwdec driver 'v4l2request-overlay' [vo/gpu/v4l2request-overlay] Failed to retrieve DRM fd from native display. [vo/gpu] Loading failed. [hwupload] hwdec 'drmprime' does not report hwframe constraints. Using static metadata. [vf] [out] 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0 [osd/libass] libass API version: 0x1703000 [osd/libass] libass source: tarball: 0.17.3 [osd/libass] Shaper: FriBidi 1.0.15 (SIMPLE) HarfBuzz-ng 10.2.0 (COMPLEX) [osd/libass] Setting up fonts... [osd/libass] Using font provider fontconfig [osd/libass] Done. [cplayer] VO: [gpu] 1920x1080 drm_prime[nv12] [cplayer] VO: Description: Shader-based GPU Renderer [vo/gpu] reconfig to 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0 [vo/gpu/x11] not waiting for MapNotify [vo/gpu] Resize: 1920x1025 [vo/gpu] Window size: 1920x1025 (Borders: l=0 t=0 r=0 b=0) [vo/gpu] Video source: 1920x1080 (1:1) [vo/gpu] Video display: (0, 0) 1920x1080 -> (49, 0) 1822x1025 [vo/gpu] Video scale: 0.948958/0.949074 [vo/gpu] OSD borders: l=49 t=0 r=49 b=0 [vo/gpu] Video borders: l=49 t=0 r=49 b=0 [vo/gpu] Reported display depth: 8 [vo/gpu] Testing FBO format rgba16f [vo/gpu] Using FBO format rgba16f. [vo/gpu] Resize: 1920x1025 [vo/gpu] Window size: 1920x1025 (Borders: l=0 t=0 r=0 b=0) [vo/gpu] Video source: 1920x1080 (1:1) [vo/gpu] Video display: (0, 0) 1920x1080 -> (49, 0) 1822x1025 [vo/gpu] Video scale: 0.948958/0.949074 [vo/gpu] OSD borders: l=49 t=0 r=49 b=0 [vo/gpu] Video borders: l=49 t=0 r=49 b=0 [vo/gpu] Reported display depth: 8 [vo/gpu] Dither to 8. [cplayer] first video frame after restart shown [cplayer] playback restart complete @ 0.000000, audio=eof, video=playing [vo/gpu/x11] Disabling screensaver. [cplayer] Set property: user-data/osc/margins={"l":0,"b":0,"r":0,"t":0} -> 1 [cplayer] Set property: user-data/osc/margins={"l":0,"b":0,"r":0,"t":0} -> 1 [cplayer] EOF code: 5 [statusline] V: 00:00:20 / 00:04:49 (7%) Dropped: 415 [cplayer] finished playback, success (reason 3) [cplayer] Running hook: ytdl_hook/on_after_end_file [vo/gpu/x11] Enabling screensaver. [cplayer] Exiting... (Quit) [cplayer] Set property: user-data/osc/margins={"l":0,"b":0,"r":0,"t":0} -> 1 roberto@orangepizero3:~/mpv-official/mpv-0.39.0$ I repeated the test with mpv-0.4.0 and the result was the same. I am using linux 6.15.4... tomorrow I will re-test with linux 6.16.8 and again with labwc (wayland) UPDATE: with labwc-0.8.3-1 (from Trixie repo), 720p playback is fine, and 1080p playback drops 220 frames over 10 seconds. However it seems that it activates an X11 renderer, and XWayland appears in the htop list. <-- only if started from SSH session, with "DISPLAY=:0" How can I ensure that pure wayland is used? <-- answer: start mpv from within a terminal in labwc, like foot mpv log: Spoiler roberto@orangepizero3:~/mpv-official/mpv-0.40.0$ DISPLAY=:0 ./build/mpv --hwdec=v4l2request --loop -v ~/concert.mp4 [cplayer] Command line options: '--hwdec=v4l2request' '--loop' '-v' '/home/roberto/concert.mp4' [cplayer] mpv v0.40.0 Copyright © 2000-2025 mpv/MPlayer/mplayer2 projects [cplayer] built on Oct 10 2025 10:50:55 [cplayer] libplacebo version: v7.349.0 [cplayer] FFmpeg version: 7.1.2-0+deb13u1 [cplayer] FFmpeg library versions: [cplayer] libavcodec 61.19.101 [cplayer] libavdevice 61.3.100 [cplayer] libavfilter 10.4.100 [cplayer] libavformat 61.7.100 [cplayer] libavutil 59.39.100 [cplayer] libswresample 5.3.100 [cplayer] libswscale 8.3.100 [cplayer] Configuration: [cplayer] List of enabled features: alsa build-date caca cdda cplugins debug dmabuf-interop-gl dmabuf-wayland drm dvbin dvdnav egl egl-drm egl-wayland egl-x11 ffmpeg gbm gl glibc-thread-name glob glob-posix gpl iconv jack javascript jpeg lcms2 libarchive libass libavdevice libbluray libdl libplacebo linux-fstatfs lua52 memfd-create memrchr pipewire posix posix-shm ppoll pthread-condattr-setclock pulse rubberband rubberband-3 sixel sndio sndio-1-9 uchardet v4l2request vaapi vaapi-drm vaapi-wayland vaapi-x11 vdpau vector vk-khr-display vt.h vulkan wayland wayland-protocols-1-32 wayland-protocols-1-38 wayland-protocols-1-39 wayland-protocols-1-41 x11 xv zlib [cplayer] Setting option 'hwdec' = 'v4l2request' (flags = 😎 [cplayer] Setting option 'loop' = '' (flags = 😎 [cplayer] Setting option 'v' = '' (flags = 😎 [clipboard] Initialized vo clipboard backend. [cplayer] Waiting for scripts... [cplayer] Set property: user-data/osc/visibility="auto" -> 1 [cplayer] Set property: user-data/osc/margins={"l":0,"b":0,"r":0,"t":0} -> 1 [cplayer] Done loading scripts. [cplayer] Running hook: auto_profiles/on_before_start_file [cplayer] Failed sending hook command auto_profiles/on_before_start_file. Removing hook. [cplayer] Running hook: auto_profiles/on_load [cplayer] Failed sending hook command auto_profiles/on_load. Removing hook. [cplayer] Running hook: ytdl_hook/on_load [cplayer] Running hook: ytdl_hook/on_load [ytdl_hook] playlist hook [ifo_dvdnav] Opening /home/roberto/concert.mp4 [bdmv/bluray] Opening /home/roberto/concert.mp4 [file] Opening /home/roberto/concert.mp4 [demux] Trying demuxers for level=normal. [cplayer] Set property: user-data/osc/margins={"l":0,"b":0,"r":0,"t":0} -> 1 [cplayer] Set property: user-data/osc/margins={"l":0,"b":0,"r":0,"t":0} -> 1 [osd/libass] libass API version: 0x1703000 [osd/libass] libass source: tarball: 0.17.3 [osd/libass] Shaper: FriBidi 1.0.15 (SIMPLE) HarfBuzz-ng 10.2.0 (COMPLEX) [osd/libass] Setting up fonts... [lavf] Found 'mov,mp4,m4a,3gp,3g2,mj2' at score=100 size=2048. [demux] Detected file format: mov,mp4,m4a,3gp,3g2,mj2 (libavformat) [cplayer] Opening done: /home/roberto/concert.mp4 [osd/libass] Using font provider fontconfig [osd/libass] Done. [find_files] Loading external files in /home/roberto/ [cplayer] Running hook: auto_profiles/on_preloaded [cplayer] Failed sending hook command auto_profiles/on_preloaded. Removing hook. [cplayer] Running hook: ytdl_hook/on_preloaded [lavf] select track 0 [cplayer] ● Video --vid=1 (h264 1920x1080 30 fps) [default] [vo/gpu] Probing for best GPU context. [vo/gpu/auto] Initializing GPU context 'auto' [vo/gpu/vulkan] Initializing GPU context 'waylandvk' [vo/gpu/libplacebo] Initialized libplacebo v7.349.0 (API v349) [vo/gpu/libplacebo] Creating vulkan instance with extensions: [vo/gpu/libplacebo] VK_KHR_get_physical_device_properties2 [vo/gpu/libplacebo] VK_KHR_portability_enumeration [vo/gpu/libplacebo] VK_KHR_surface [vo/gpu/libplacebo] VK_KHR_wayland_surface [vo/gpu/libplacebo] Failed creating instance: VK_ERROR_INCOMPATIBLE_DRIVER [vo/gpu/libplacebo] Failed initializing vulkan instance [vo/gpu/vulkan] Initializing GPU context 'x11vk' [vo/gpu/libplacebo] Initialized libplacebo v7.349.0 (API v349) [vo/gpu/libplacebo] Creating vulkan instance with extensions: [vo/gpu/libplacebo] VK_KHR_get_physical_device_properties2 [vo/gpu/libplacebo] VK_KHR_portability_enumeration [vo/gpu/libplacebo] VK_KHR_surface [vo/gpu/libplacebo] VK_KHR_xlib_surface [vo/gpu/libplacebo] Failed creating instance: VK_ERROR_INCOMPATIBLE_DRIVER [vo/gpu/libplacebo] Failed initializing vulkan instance [vo/gpu/opengl] Initializing GPU context 'wayland' [vo/gpu/opengl] Initializing GPU context 'x11egl' [vo/gpu/x11] X11 opening display: :0 [vo/gpu/x11] Display 0 (HDMI-A-1): [0, 0, 1920, 1080] @ 59.962844 FPS [vo/gpu/x11] Current display FPS: 59.962844 [vo/gpu/opengl] EGL_VERSION=1.5 [vo/gpu/opengl] EGL_VENDOR=Mesa Project [vo/gpu/opengl] EGL_CLIENT_APIS=OpenGL OpenGL_ES [vo/gpu/opengl] Trying to create Desktop OpenGL context. [vo/gpu/opengl] Choosing visual EGL config 0x9, visual ID 0x40 [vo/gpu/x11] The XPresent extension was found. [vo/gpu/x11] XPresent disabled. [vo/gpu/opengl] GL_VERSION='3.1 Mesa 25.0.7-2' [vo/gpu/opengl] Detected desktop OpenGL 3.1. [vo/gpu/opengl] GL_VENDOR='Mesa' [vo/gpu/opengl] GL_RENDERER='Mali-G31 (Panfrost)' [vo/gpu/opengl] GL_SHADING_LANGUAGE_VERSION='1.40' [vo/gpu/opengl] Loaded extension GL_ARB_sync. [vo/gpu/opengl] Loaded extension GL_ARB_timer_query. [vo/gpu/opengl] Loaded extension GL_ARB_invalidate_subdata. [vo/gpu/opengl] Loaded extension GL_ARB_get_program_binary. [vo/gpu/opengl] Loaded extension GL_ARB_buffer_storage. [vo/gpu/opengl] Loaded extension GL_ARB_shader_image_load_store. [vo/gpu/opengl] Loaded extension GL_ARB_shader_storage_buffer_object. [vo/gpu/opengl] Loaded extension GL_ARB_arrays_of_arrays. [vo/gpu/opengl] Loaded extension GL_ARB_debug_output. [vo/gpu/opengl] Loaded extension GL_KHR_debug. [vo/gpu] Testing FBO format rgba16f [vo/gpu] Using FBO format rgba16f. [vo/gpu] Disabling HDR peak computation (one or more of the following is not supported: compute shaders=0, SSBO=1). [vo/gpu] Assuming 59.962844 FPS for display sync. [vd] Container reported FPS: 30.000000 [vd] Codec list: [vd] h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [vd] h264_v4l2m2m (h264) - V4L2 mem2mem H.264 decoder wrapper [vd] h264_cuvid (h264) - Nvidia CUVID H264 decoder [vd] Opening decoder h264 [vd] Looking at hwdec h264-v4l2request... [vo/gpu] Loading hwdec drivers for format: 'drm_prime' [vo/gpu] Loading hwdec driver 'drmprime' [vo/gpu/drmprime] Using EGL dmabuf interop via GL_EXT_EGL_image_storage [vo/gpu/drmprime] Using DRM device: /dev/dri/renderD128 [vo/gpu] Loading hwdec driver 'drmprime-overlay' [vo/gpu/drmprime-overlay] Failed to retrieve DRM fd from native display. [vo/gpu] Loading failed. [vo/gpu] Loading hwdec driver 'v4l2request' [vo/gpu/v4l2request] Using EGL dmabuf interop via GL_EXT_EGL_image_storage [vo/gpu] Loading hwdec driver 'v4l2request-overlay' [vo/gpu/v4l2request-overlay] Failed to retrieve DRM fd from native display. [vo/gpu] Loading failed. [vd] Trying hardware decoding via h264-v4l2request. [vd] Selected decoder: h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [vf] User filter list: [vf] (empty) [cplayer] Starting playback... [vd] Pixel formats supported by decoder: vdpau vulkan cuda drm_prime vaapi yuv420p [vd] Codec profile: High (0x64) [vd] Requesting pixfmt 'drm_prime' from decoder. [ffmpeg/video] h264: Using V4L2 media driver cedrus (6.15.4) for S264 [vd] Using hardware decoding (v4l2request). [vd] Decoder format: 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/auto CL=mpeg2/4/h264 crop=1920x1080+0+0 [vf] [in] 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0 [vf] [userdeint] 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0 [vf] [userdeint] (disabled) [vf] [autorotate] 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0 [vf] [autorotate] (disabled) [vf] [convert] 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0 [vo/gpu] Loading hwdec drivers for format: 'drm_prime' [vo/gpu] Loading hwdec driver 'drmprime-overlay' [vo/gpu/drmprime-overlay] Failed to retrieve DRM fd from native display. [vo/gpu] Loading failed. [vo/gpu] Loading hwdec driver 'v4l2request-overlay' [vo/gpu/v4l2request-overlay] Failed to retrieve DRM fd from native display. [vo/gpu] Loading failed. [hwupload] hwdec 'drmprime' does not report hwframe constraints. Using static metadata. [vf] [out] 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0 [osd/libass] libass API version: 0x1703000 [osd/libass] libass source: tarball: 0.17.3 [osd/libass] Shaper: FriBidi 1.0.15 (SIMPLE) HarfBuzz-ng 10.2.0 (COMPLEX) [osd/libass] Setting up fonts... [osd/libass] Using font provider fontconfig [osd/libass] Done. [cplayer] VO: [gpu] 1920x1080 drm_prime[nv12] [cplayer] VO: Description: Shader-based GPU Renderer [vo/gpu] reconfig to 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0 [vo/gpu] Resize: 1920x1080 [vo/gpu] Window size: 1920x1080 (Borders: l=0 t=0 r=0 b=0) [vo/gpu] Video source: 1920x1080 (1:1) [vo/gpu] Video display: (0, 0) 1920x1080 -> (0, 0) 1920x1080 [vo/gpu] Video scale: 1.000000/1.000000 [vo/gpu] OSD borders: l=0 t=0 r=0 b=0 [vo/gpu] Video borders: l=0 t=0 r=0 b=0 [vo/gpu] Reported display depth: 8 [vo/gpu] Testing FBO format rgba16f [vo/gpu] Using FBO format rgba16f. [vo/gpu] Dither to 8. [cplayer] first video frame after restart shown [cplayer] playback restart complete @ 0.000000, audio=eof, video=playing [vo/gpu/x11] Disabling screensaver. [cplayer] Set property: user-data/osc/margins={"l":0,"b":0,"r":0,"t":0} -> 1 [cplayer] Set property: user-data/osc/margins={"l":0,"b":0,"r":0,"t":0} -> 1 [vo/gpu] Resize: 1918x1052 [vo/gpu] Window size: 1918x1052 (Borders: l=0 t=0 r=0 b=0) [vo/gpu] Video source: 1920x1080 (1:1) [vo/gpu] Video display: (0, 0) 1920x1080 -> (24, 0) 1870x1052 [vo/gpu] Video scale: 0.973958/0.974074 [vo/gpu] OSD borders: l=24 t=0 r=24 b=0 [vo/gpu] Video borders: l=24 t=0 r=24 b=0 [vo/gpu] Reported display depth: 8 [cplayer] Set property: user-data/osc/margins={"l":0,"b":0,"r":0,"t":0} -> 1 [cplayer] EOF code: 5 [statusline] V: 00:00:10 / 00:04:49 (4%) Dropped: 220 [cplayer] finished playback, success (reason 3) [cplayer] Running hook: ytdl_hook/on_after_end_file [vo/gpu/x11] Enabling screensaver. [cplayer] Exiting... (Quit) [cplayer] Set property: user-data/osc/margins={"l":0,"b":0,"r":0,"t":0} -> 1 roberto@orangepizero3:~/mpv-official/mpv-0.40.0$ When I try mpv-0.3.9 (from the source folder, so I dont need to install it), I get the same result: v4l2request works perfectly in 720p, but choppy in 1080p Edited October 11, 2025 by robertoj 0 Quote
robertoj Posted October 11, 2025 Posted October 11, 2025 (edited) On 10/5/2025 at 12:34 PM, jock said: mpv official github repo. v4l2request commits are in a pull request. Hello Jock, Can you confirm that you use the patch in mpv PR1460, or something else? --vo=gpu or -vo=gpu-next? I installed mesa-vulkan-drivers today, with some difference in the mpv log, but same performance I also get: [vo/gpu-next/libplacebo] Found no suitable device, giving up. [vo/gpu-next/libplacebo] Failed initializing vulkan device and ... Spoiler ... [vo/gpu-next] Assuming 59.962844 FPS for display sync. [vd] Container reported FPS: 29.970030 [vd] Codec list: [vd] h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [vd] h264_v4l2m2m (h264) - V4L2 mem2mem H.264 decoder wrapper [vd] h264_cuvid (h264) - Nvidia CUVID H264 decoder [vd] Opening decoder h264 [vd] Looking at hwdec h264-v4l2request... [vo/gpu-next] Loading hwdec drivers for format: 'drm_prime' [vo/gpu-next] Loading hwdec driver 'drmprime' [vo/gpu-next/drmprime] Using EGL dmabuf interop via GL_EXT_EGL_image_storage [vo/gpu-next/drmprime] Using DRM device: /dev/dri/renderD128 [vo/gpu-next] Loading hwdec driver 'drmprime-overlay' [vo/gpu-next/drmprime-overlay] Failed to retrieve DRM fd from native display. [vo/gpu-next] Loading failed. [vo/gpu-next] Loading hwdec driver 'v4l2request' [vo/gpu-next/v4l2request] Using EGL dmabuf interop via GL_EXT_EGL_image_storage [vo/gpu-next] Loading hwdec driver 'v4l2request-overlay' [vo/gpu-next/v4l2request-overlay] Failed to retrieve DRM fd from native display. [vo/gpu-next] Loading failed. [vd] Trying hardware decoding via h264-v4l2request. [vd] Requesting 4 threads for decoding. [vd] Selected decoder: h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [vf] User filter list: [vf] (empty) [ad] Codec list: [ad] aac - AAC (Advanced Audio Coding) [ad] aac_fixed (aac) - AAC (Advanced Audio Coding) [ad] Opening decoder aac [ad] Requesting 1 threads for decoding. [ad] Selected decoder: aac - AAC (Advanced Audio Coding) [af] User filter list: [af] (empty) [cplayer] Starting playback... Does it matter? If I want to test the latest libplacebo route (with git clone https://code.videolan.org/videolan/libplacebo.git...) do I need to uninstall libplacebo and libplacebo-dev? Edited October 12, 2025 by robertoj 0 Quote
jock Posted October 12, 2025 Author Posted October 12, 2025 13 hours ago, robertoj said: Can you confirm that you use the patch in mpv PR1460, or something else? I compiled mpv 0.40.0 and the commits from this PR. Results are mixed and situation is messier than before, so if you need hardware acceleration, it is better to go gstreamer or revert to debian bookworm for now. 0 Quote
robertoj Posted October 12, 2025 Posted October 12, 2025 Thank you. I meant to ask about that PR14690 I would rather stay with trixie and low fps, because it seems easier to solve my other problem: need 100% wayland and 0% X11 due to a LCD driver problem. 0 Quote
jock Posted October 12, 2025 Author Posted October 12, 2025 2 hours ago, robertoj said: I would rather stay with trixie and low fps, because it seems easier to solve my other problem: need 100% wayland and 0% X11 due to a LCD driver problem. AFAIK bookworm is fine with wayland (weston, kde, ...) 1 Quote
robertoj Posted October 16, 2025 Posted October 16, 2025 (edited) Has anybody tried compiling mpv-0.35 + PR14690 within Trixie and ffmpeg 7.x.x? If anyone is curious... mpv-0.37 fails in the compilation step in ad-spdif.c due to an incompatible pointer But mpv-0.38 (without patches) compiles successfully Edited October 16, 2025 by robertoj 0 Quote
robertoj Posted November 9, 2025 Posted November 9, 2025 (edited) There's a new version of the kwiboo ffmpeg+v4l2request function https://code.ffmpeg.org/Kwiboo/FFmpeg/src/branch/v4l2request-v3 And it was shown as a work in progress in the ffmpeg community https://code.ffmpeg.org/FFmpeg/FFmpeg/pulls/20847 Then, it was noticed in the mpv community https://github.com/mpv-player/mpv/pull/14690#issuecomment-3500141427 They previously said that v4l2request first needs to be integrated in ffmpeg officially, then mpv would start working on v4l2request This is needed, to have mpv+v4l2request compiling successfully and working under Debian Trixie (my experience) Edited November 9, 2025 by robertoj 1 Quote
JFL Posted November 11, 2025 Posted November 11, 2025 On 11/10/2025 at 2:26 AM, robertoj said: This is needed, to have mpv+v4l2request compiling successfully and working under Debian Trixie (my experience) You managed to build mpv with v4l2request for Debian Trixie that has vpu hardware acceleration? Care to share? 0 Quote
usual user Posted November 11, 2025 Posted November 11, 2025 FWIW, HEVC support is queued for 6.19. With WIP patches on top, rkvdec2 is also available to me. With the gstreamer framework, this works for me out-of-the-box, as the necessary support has been available in mainline for quite some time. See video-pipeline.pdffor reference. I have already rebuilt the Huffman package with the patches mentioned above, but currently the developers of the distribution of my choice are busy rebuilding all packages that depend on it. As soon as the Huffman package is rolled out, I will start to see how HEVC performs with the FFMPEG framework. 0 Quote
robertoj Posted November 11, 2025 Posted November 11, 2025 (edited) 9 hours ago, JFL said: You managed to build mpv with v4l2request for Debian Trixie that has vpu hardware acceleration? Care to share? No. I haven't tried anything new. My previous attempts compiling mpv in Trixie were unsuccessful. I want to try it again by compiling and installing this new ffmpeg+v4l2 first, then trying compiling mpv again. You should try it too Edited November 11, 2025 by robertoj 0 Quote
usual user Posted November 15, 2025 Posted November 15, 2025 Just for posterity. fluster-run-odroid-m2-summary 0 Quote
robertoj Posted November 18, 2025 Posted November 18, 2025 (edited) The ffmpeg discussion posted a way to test the code (at the bottom of https://code.ffmpeg.org/FFmpeg/FFmpeg/pulls/20847 ) *install all the ffmpeg dependencies, then: $ git fetch -u https://code.ffmpeg.org/Kwiboo/FFmpeg v4l2request-v3:Kwiboo-v4l2request-v3 $ git switch Kwiboo-v4l2request-v3 * compile and install Then rebuild mpv+PR14690 (https://forum.armbian.com/topic/32449-repository-for-v4l2request-hardware-video-decoding-rockchip-allwinner/page/5/#findComment-226567) Edited November 18, 2025 by robertoj 0 Quote
usual user Posted November 18, 2025 Posted November 18, 2025 4 hours ago, robertoj said: Then rebuild mpv+PR14690 Just out of curiosity, why are you trying to backport the v4l2request support? Why not build the pull request tree directly: git clone --branch v4l2request https://github.com/philipl/mpv.git mpv-player-v4l2request 0 Quote
robertoj Posted November 18, 2025 Posted November 18, 2025 6 minutes ago, usual user said: Just out of curiosity, why are you trying to backport the v4l2request support? Why not build the pull request tree directly: I thought this was the best way: official latest mpv + pull request i am not trying to backport it. I want to make it work in trixie. 0 Quote
usual user Posted November 18, 2025 Posted November 18, 2025 2 hours ago, robertoj said: i am not trying to backport it. Official development for inclusion in upstream are carried out by working on the project's main branch. That's exactly what this pull request branch does by tracking the project's master tree. Applying commits to anything else is backporting. 2 hours ago, robertoj said: I want to make it work in trixie. Backporting is possible, but you will have to deal with the consequences yourself that arise from your outdated versions lacking the functions required for your backport, and you may need to backport those as well. Since this project is a user program and not a framework with libraries that other programs depend on, it is solely the user who has to deal with it as a dependency in its use. At first, I also tried to use the sources of the current release version as a base, but since the commits couldn't be applied without errors, I simply built the current master branch. For the FFMPEG framework, this is already a whole different ballgame. There are many programs, which mpv is just one, that depend on the libraries and need to be rebuilt accordingly in case of an upgrade. Since my chosen distribution recently released ffmpeg 8.0 and thus made all dependent programs available accordingly, I just had to rebuild the ffmpeg package with the v4l2request support commits and put that in place. And since the commits could be applied to the current release sources without any errors, I didn't even need to switch to the master branch. 0 Quote
robertoj Posted November 18, 2025 Posted November 18, 2025 (edited) Oh I get it. Since you are using another distro with newer versions of everything, my effort to build ffmpeg and mpv in Debian Trixie LOOKS like a backport to you XD upon reading your comment again, I understand the consequences of upgrading ffmpeg from source (Debian Trixie's ffmpeg is version 7.1.2) According to: https://forums.linuxmint.com/viewtopic.php?t=457495, I would need to check with "apt-rdepends -r ffmpeg" Edited November 21, 2025 by robertoj 0 Quote
Antom Posted November 24, 2025 Posted November 24, 2025 Hi, I have a TV box with an RK322x chip. I want to use FFmpeg and process video using FFmpeg hardware decoding. Please tell me: do I need to recompile the system/distro build, or does it work out of the box right now? If not, which distribution is better to choose? Please tell me. 0 Quote
jock Posted November 24, 2025 Author Posted November 24, 2025 3 hours ago, Antom said: If not, which distribution is better to choose? Please tell me. I tell you to read the first post of the thread. 1 Quote
Antom Posted November 24, 2025 Posted November 24, 2025 44 minutes ago, jock said: I tell you to read the first post of the thread. I did it, so, you say that edge Ubuntu 24.04 have all required drivers for VPU ? that was my question 0 Quote
robertoj Posted November 24, 2025 Posted November 24, 2025 (edited) The first post reads "your mileage may vary" and "the latest kernel will work best" Start by recompiling armbian for your Rockchip SBC, with the edge kernel option, then follow the ffmpeg install instructions If it doesn't work, try the older Ubuntu, and both Debian options Edited November 24, 2025 by robertoj 1 Quote
jock Posted November 25, 2025 Author Posted November 25, 2025 17 hours ago, robertoj said: Start by recompiling armbian for your Rockchip SBC, with the edge kernel option, then follow the ffmpeg install instructions No need to recompile, rk322x already have had all the right bits in the right place for years. Everything is written down in the first page of the thread for rk332x tv boxes (What works: ---> Hardware video acceleration) in the hope people read it. 1 Quote
Skuld Posted December 28, 2025 Posted December 28, 2025 Good afternoon. I'm trying to stream video to my orange pi zero 2w. I am using Gstreamer and while testing I saw that v4l2slh264dec fails. When using autosink, only a transparent window is shown and when using a specific sink, no window is opened. My intention is to take advantage of the VPU with Gstreamer but that failure has caused me headaches. I tried using MVP and it works fine but it's not what I need. Maybe I will choose other options for what I want to do but first I would like to ask here about the topic- Thank you very much to whoever takes the trouble to read this and thanks in advance to whoever responds ❤️ By.: Google Translate 0 Quote
robertoj Posted January 5 Posted January 5 mpv has the correct code to use the ffmpeg for cedrus hardware acceleration AND the correct code to display it on screen with minimal CPU usage. If you want gstreamer as a video pipeline, can you try using ffmpeg (the v4l2request version) and gstreamer together? 0 Quote
robertoj Posted January 6 Posted January 6 The ffmpeg conversation in https://code.ffmpeg.org/FFmpeg/FFmpeg/pulls/20847 suddenly stopped 2 weeks ago. Does it seem like there's a big obstacle suddenly, or just a well deserved engineer vacation going on? 0 Quote
