Video overscan
bolet75
When connected to some PC monitors, the image is larger than the physical screen: about 20 pixels at the top and bottom sides, and 50 pixels at the right and left sides are missing.
This happens as soon as the board boots (without logo), the start of lines are truncated, and this also happens on text ttys (Ctrl + Alt + F1..6).
I guess it's about a boot env variable, but I could not find it.
i live with that on samsung old 26 led tv. It doesnt have image adjust  / auto  settings in tv menu, so its menu option.
 in sway or gnome i dont see upper bar with time and volume settings , but i can click on edge and menu shows up. On sway also setting floating windows for apps is usefull.
Edited by nihilowy
Quote
Have you redirected the sound to hdmi in the settings? Default send to the jack.
Contrary to 5.1.160, the sound output menu is empty when booting with 6.7.0-rc4
On 12/28/2023 at 12:44 AM, royk said:
I had the same issue with an old Samsung TV/monitor and use a HDMI->VGA adapter as workaround.
I was considering a DVI adapter to stay "digital". But your solution is bolder!
The overscan doesn't happen on another 1080p hdmi monitor.
I looked in the edid informations which appear in:
/sys/devices/platform/display-subsystem/drm/card0/*/edid
I found "wxedid" to decode and edit the edid (it's a tricky binary format).
The relevant "timing" informations are identical between the two monitors.
I tried editing the edid and writing it back: no change.
Nor does it seem to change anything when given as a boot parameter.
@bolet75 Yeah HDMI -> DVI didn't work for me either. About the audio, HDMI audio doesn't work yet on the mainline kernel, jack input/output would need to be set correctly in the dtb, last time I checked it didn't work either:
https://gitlab.collabora.com/hardware-enablement/rockchip-3588/notes-for-rockchip-3588/-/blob/main/mainline-status.md
Edited by royk
correction
