Dear friends, I have a problem with the ethernet connection of my orange pi plus 2e. The connection was working normally and stopped, I can only access through the wi-fi. I already researched it and found no solution. Open the connections and pressing ifupdown (eth0) the following error appeared: (1) Creating object for path 'org / freedesktop / NetworkManager / ActiveConnection / 14' failed in libnm-glib. Is there a connection to this error with a lack of ethernet connection?
Which version do you use?
And it's clearly something wrong with network manager or a driver. Reboot doesn't help?
I am using Armbian 5.20 Orange pi plus2e Debian jessie 3.4.112 desktop. I have restarted but it does not change. The ethernet connection stopped working only with ethernet access using usb dongle wifi.
