Hello @lampra,
Is this a self build image? I tried yesterday with Armbian_5.04_Cubietruck_Ubuntu_trusty_4.4.3 and I did not manage to boot from usb.
It is a Vanilla Jessie Cubieboard2 image taken from armbian.com website, not self-built.
Though, I don't remember the initial version I downloaded. There have been some updates since then.
  ____      _     _      _                         _
 / ___|   _| |__ (_) ___| |__   ___   __ _ _ __ __| |
| |  | | | | '_ \| |/ _ \ '_ \ / _ \ / _` | '__/ _` |
| |__| |_| | |_) | |  __/ |_) | (_) | (_| | | | (_| |
 \____\__,_|_.__/|_|\___|_.__/ \___/ \__,_|_|  \__,_|
Welcome to ARMBIAN Debian GNU/Linux 8 (jessie) 4.4.1-sunxi
$ uname -a
Linux local 4.4.1-sunxi #10 SMP Wed Feb 17 17:57:20 CET 2016 armv7l GNU/Linux
Than we would need some more info to diagnose where is the problem. Can you provide boot log and boot script content.
dmesg (booting from mmc)
root@cubietruck:~# dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.3-sunxi (root@production) (gcc version 4.8.2 (Ubuntu/Linaro 4.8.2-16ubuntu4) ) #3 SMP Sun Feb 28 15:02:23 CET 2016
[    0.000000] CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: Cubietech Cubietruck
[    0.000000] cma: Reserved 16 MiB at 0xbe800000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 522263
[    0.000000] free_area_init_node: node 0, pgdat c08fd2c0, node_mem_map eee01000
[    0.000000]   Normal zone: 1728 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 196608 pages, LIFO batch:31
[    0.000000]   HighMem zone: 325655 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: Using PSCI v0.1 Function IDs from DT
[    0.000000] PERCPU: Embedded 12 pages/cpu @eedc7000 s19008 r8192 d21952 u49152
[    0.000000] pcpu-alloc: s19008 r8192 d21952 u49152 alloc=12*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 520535
[    0.000000] Kernel command line: console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 cgroup-enable=memory swapaccount=1 sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 #sunxi_no_mali_mem_reserve sunxi_fb_mem_reserve=16 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 enforcing=0 loglevel=7
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 2043712K/2089052K available (6827K kernel code, 256K rwdata, 1764K rodata, 328K init, 280K bss, 28956K reserved, 16384K cma-reserved, 1286236K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc086bf0c   (8592 kB)
[    0.000000]       .init : 0xc086c000 - 0xc08be000   ( 328 kB)
[    0.000000]       .data : 0xc08be000 - 0xc08fe220   ( 257 kB)
[    0.000000]        .bss : 0xc0901000 - 0xc0947340   ( 281 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 32.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=2
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000017] Switching to timer-based delay loop, resolution 41ns
[    0.000404] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000589] clocksource: hstimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 12741736309 ns
[    0.000782] Console: colour dummy device 80x30
[    0.001397] console [tty1] enabled
[    0.001434] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.001473] pid_max: default: 32768 minimum: 301
[    0.001630] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001658] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002415] Initializing cgroup subsys io
[    0.002472] Initializing cgroup subsys memory
[    0.002518] Initializing cgroup subsys devices
[    0.002546] Initializing cgroup subsys freezer
[    0.002572] Initializing cgroup subsys net_cls
[    0.002596] Initializing cgroup subsys perf_event
[    0.002634] Initializing cgroup subsys net_prio
[    0.002707] CPU: Testing write buffer coherency: ok
[    0.003108] /cpus/cpu@0 missing clock-frequency property
[    0.003152] /cpus/cpu@1 missing clock-frequency property
[    0.003179] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.003262] Setting up static identity map for 0x400082c0 - 0x40008318
[    0.005346] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.005441] Brought up 2 CPUs
[    0.005501] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[    0.005521] CPU: All CPU(s) started in HYP mode.
[    0.005538] CPU: Virtualization extensions available.
[    0.006489] devtmpfs: initialized
[    0.015153] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 4
[    0.015647] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.016576] xor: measuring software checksum speed
[    0.109991]    arm4regs  :  1243.600 MB/sec
[    0.210047]    8regs     :   772.000 MB/sec
[    0.310103]    32regs    :   792.400 MB/sec
[    0.410163]    neon      :  1162.800 MB/sec
[    0.410185] xor: using function: arm4regs (1243.600 MB/sec)
[    0.410347] pinctrl core: initialized pinctrl subsystem
[    0.411606] NET: Registered protocol family 16
[    0.412902] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.440239] cpuidle: using governor ladder
[    0.465613] cpuidle: using governor menu
[    0.472881] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.472935] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.650896] raid6: int32x1  gen()   138 MB/s
[    0.820725] raid6: int32x1  xor()   111 MB/s
[    0.990841] raid6: int32x2  gen()   185 MB/s
[    1.160980] raid6: int32x2  xor()   120 MB/s
[    1.331063] raid6: int32x4  gen()   197 MB/s
[    1.501266] raid6: int32x4  xor()   122 MB/s
[    1.671270] raid6: int32x8  gen()   179 MB/s
[    1.841361] raid6: int32x8  xor()   116 MB/s
[    2.011398] raid6: neonx1   gen()   436 MB/s
[    2.181461] raid6: neonx1   xor()   324 MB/s
[    2.351629] raid6: neonx2   gen()   577 MB/s
[    2.521717] raid6: neonx2   xor()   423 MB/s
[    2.691793] raid6: neonx4   gen()   706 MB/s
[    2.861899] raid6: neonx4   xor()   480 MB/s
[    3.032006] raid6: neonx8   gen()   640 MB/s
[    3.202171] raid6: neonx8   xor()   451 MB/s
[    3.202191] raid6: using algorithm neonx4 gen() 706 MB/s
[    3.202210] raid6: .... xor() 480 MB/s, rmw enabled
[    3.202228] raid6: using intx1 recovery algorithm
[    3.202663] reg-fixed-voltage ahci-5v: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/ahci_pwr_pin@1, deferring probe
[    3.202750] reg-fixed-voltage usb0-vbus: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/usb0_vbus_pin@0, deferring probe
[    3.202807] reg-fixed-voltage usb1-vbus: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/usb1_vbus_pin@0, deferring probe
[    3.202866] reg-fixed-voltage usb2-vbus: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/usb2_vbus_pin@0, deferring probe
[    3.204619] SCSI subsystem initialized
[    3.204981] libata version 3.00 loaded.
[    3.205329] usbcore: registered new interface driver usbfs
[    3.205420] usbcore: registered new interface driver hub
[    3.205525] usbcore: registered new device driver usb
[    3.205813] media: Linux media interface: v0.10
[    3.205900] Linux video capture interface: v2.00
[    3.206007] pps_core: LinuxPPS API ver. 1 registered
[    3.206029] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    3.206085] PTP clock support registered
[    3.207862] clocksource: Switched to clocksource arch_sys_counter
[    3.209025] simple-framebuffer bf817000.framebuffer: framebuffer at 0xbf817000, 0x7e9000 bytes, mapped to 0xf0900000
[    3.209077] simple-framebuffer bf817000.framebuffer: format=x8r8g8b8, mode=1920x1080x32, linelength=7680
[    3.245584] Console: switching to colour frame buffer device 240x67
[    3.281331] simple-framebuffer bf817000.framebuffer: fb0: simplefb registered!
[    3.291489] NET: Registered protocol family 2
[    3.292403] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    3.292714] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    3.293022] TCP: Hash tables configured (established 8192 bind 8192)
[    3.293307] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    3.293541] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    3.294031] NET: Registered protocol family 1
[    3.295088] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    3.296637] futex hash table entries: 512 (order: 3, 32768 bytes)
[    3.297307] Initialise system trusted keyring
[    3.305907] zbud: loaded
[    3.309905] JFS: nTxBlock = 8192, nTxLock = 65536
[    3.321399] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[    3.329707] bounce: pool size: 64 pages
[    3.330181] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    3.330692] io scheduler noop registered
[    3.330837] io scheduler deadline registered
[    3.331020] io scheduler cfq registered (default)
[    3.331662] sun4i-usb-phy 1c13400.phy: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/usb0_id_detect_pin@0, deferring probe
[    3.334718] sun7i-a20-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    3.402394] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    3.425903] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 44, base_baud = 1500000) is a U6_16550A
[    3.434817] loop: module loaded
[    3.436970] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.437190] ehci-platform: EHCI generic platform driver
[    3.437697] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.438028] ohci-platform: OHCI generic platform driver
[    3.438617] usbcore: registered new interface driver usb-storage
[    3.439993] sunxi-rtc 1c20d00.rtc: rtc core: registered rtc-sunxi as rtc0
[    3.440221] sunxi-rtc 1c20d00.rtc: RTC enabled
[    3.440468] i2c /dev entries driver
[    3.441645] axp20x 0-0034: AXP20x variant AXP209 found
[    3.454821] input: axp20x-pek as /devices/platform/soc@01c00000/1c2ac00.i2c/i2c-0/0-0034/axp20x-pek/input/input0
[    3.462393] axp20x 0-0034: Backup (RTC) battery charging is enabled
[    3.462808] axp20x 0-0034: AXP20X driver loaded
[    3.465758] sunxi-wdt 1c20c90.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    3.476238] sunxi-mmc 1c0f000.mmc: No vqmmc regulator found
[    3.486649] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[    3.528128] sunxi-mmc 1c0f000.mmc: base:0xf08b2000 irq:26
[    3.538382] sunxi-mmc 1c12000.mmc: No vqmmc regulator found
[    3.548791] sunxi-mmc 1c12000.mmc: allocated mmc-pwrseq
[    3.565806] mmc0: host does not support reading read-only switch, assuming write-enable
[    3.578162] mmc0: new high speed SDHC card at address 59b4
[    3.588631] mmcblk0: mmc0:59b4 00000 14.9 GiB
[    3.598318] sunxi-mmc 1c12000.mmc: base:0xf08b6000 irq:27
[    3.599846]  mmcblk0: p1
[    3.606529] sunxi-mmc 1c12000.mmc: smc 1 err, cmd 8, RTO !!
[    3.615821] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    3.617317] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    3.618823] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    3.621513] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    3.636739] mmc1: new high speed SDIO card at address 0001
[    3.673336] ledtrig-cpu: registered to indicate activity on CPUs
[    3.682668] hidraw: raw HID events driver (C) Jiri Kosina
[    3.691982] usbcore: registered new interface driver usbhid
[    3.701127] usbhid: USB HID core driver
[    3.711479] Initializing XFRM netlink socket
[    3.721697] NET: Registered protocol family 10
[    3.731856] NET: Registered protocol family 17
[    3.740958] NET: Registered protocol family 15
[    3.749888] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    3.759056] 8021q: 802.1Q VLAN Support v1.8
[    3.768165] Key type dns_resolver registered
[    3.777645] Registering SWP/SWPB emulation handler
[    3.787467] registered taskstats version 1
[    3.796360] Loading compiled-in X.509 certificates
[    3.805280] zswap: loaded using pool lzo/zbud
[    3.817008] Btrfs loaded
[    3.827152] Key type encrypted registered
[    3.907911] ahci-sunxi 1c18000.sata: controller can't do PMP, turning off CAP_PMP
[    3.916710] ahci-sunxi 1c18000.sata: SSS flag set, parallel bus scan disabled
[    3.925422] ahci-sunxi 1c18000.sata: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[    3.934160] ahci-sunxi 1c18000.sata: flags: ncq sntf stag pm led clo only pio slum part ccc
[    3.944119] scsi host0: ahci-sunxi
[    3.953209] ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 32
[    3.962474] ehci-platform 1c14000.usb: EHCI Host Controller
[    3.971298] ehci-platform 1c14000.usb: new USB bus registered, assigned bus number 1
[    3.980363] ehci-platform 1c14000.usb: irq 29, io mem 0x01c14000
[    4.007888] ehci-platform 1c14000.usb: USB 2.0 started, EHCI 1.00
[    4.016924] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    4.025646] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.034288] usb usb1: Product: EHCI Host Controller
[    4.042844] usb usb1: Manufacturer: Linux 4.4.3-sunxi ehci_hcd
[    4.051457] usb usb1: SerialNumber: 1c14000.usb
[    4.061015] hub 1-0:1.0: USB hub found
[    4.069628] hub 1-0:1.0: 1 port detected
[    4.078819] ehci-platform 1c1c000.usb: EHCI Host Controller
[    4.087082] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 2
[    4.095608] ehci-platform 1c1c000.usb: irq 33, io mem 0x01c1c000
[    4.117865] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
[    4.126234] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    4.134299] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.142318] usb usb2: Product: EHCI Host Controller
[    4.150261] usb usb2: Manufacturer: Linux 4.4.3-sunxi ehci_hcd
[    4.158215] usb usb2: SerialNumber: 1c1c000.usb
[    4.166901] hub 2-0:1.0: USB hub found
[    4.174947] hub 2-0:1.0: 1 port detected
[    4.183682] ohci-platform 1c14400.usb: Generic Platform OHCI controller
[    4.191788] ohci-platform 1c14400.usb: new USB bus registered, assigned bus number 3
[    4.199916] ohci-platform 1c14400.usb: irq 30, io mem 0x01c14400
[    4.262146] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    4.269938] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.277624] usb usb3: Product: Generic Platform OHCI controller
[    4.285356] usb usb3: Manufacturer: Linux 4.4.3-sunxi ohci_hcd
[    4.293073] usb usb3: SerialNumber: 1c14400.usb
[    4.301630] hub 3-0:1.0: USB hub found
[    4.309482] ata1: SATA link down (SStatus 0 SControl 300)
[    4.309536] hub 3-0:1.0: 1 port detected
[    4.310496] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
[    4.310536] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 4
[    4.310811] ohci-platform 1c1c400.usb: irq 34, io mem 0x01c1c400
[    4.372143] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    4.379966] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.387698] usb usb4: Product: Generic Platform OHCI controller
[    4.395432] usb usb4: Manufacturer: Linux 4.4.3-sunxi ohci_hcd
[    4.403226] usb usb4: SerialNumber: 1c1c400.usb
[    4.411928] hub 4-0:1.0: USB hub found
[    4.420003] hub 4-0:1.0: 1 port detected
[    4.433537] vcc3v0: disabling
[    4.441512] vcc5v0: disabling
[    4.449705] usb0-vbus: disabling
[    4.488390] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[    4.496396] VFS: Mounted root (ext4 filesystem) readonly on device 179:1.
[    4.508742] devtmpfs: mounted
[    4.517072] Freeing unused kernel memory: 328K (c086c000 - c08be000)
[    4.687908] usb 3-1: new low-speed USB device number 2 using ohci-platform
[    4.921029] usb 3-1: New USB device found, idVendor=046d, idProduct=c315
[    4.929260] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.937126] usb 3-1: Product: Logitech USB Keyboard
[    4.945056] usb 3-1: Manufacturer: Logitech
[    4.963116] input: Logitech Logitech USB Keyboard as /devices/platform/soc@01c00000/1c14400.usb/usb3/3-1/3-1:1.0/0003:046D:C315.0001/input/input1
[    5.028370] hid-generic 0003:046D:C315.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech Logitech USB Keyboard] on usb-1c14400.usb-1/input0
[    5.139270] random: init urandom read with 12 bits of entropy available
[    5.331117] init: hwclock main process (114) terminated with status 1
[    6.427183] systemd-udevd[235]: starting version 204
[    6.825036] Bluetooth: Core ver 2.21
[    6.825197] NET: Registered protocol family 31
[    6.825208] Bluetooth: HCI device and connection manager initialized
[    6.825232] Bluetooth: HCI socket layer initialized
[    6.825246] Bluetooth: L2CAP socket layer initialized
[    6.825280] Bluetooth: SCO socket layer initialized
[    6.856273] Bluetooth: RFCOMM TTY layer initialized
[    6.856324] Bluetooth: RFCOMM socket layer initialized
[    6.856359] Bluetooth: RFCOMM ver 1.11
[    6.877743] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    6.877789] Bluetooth: HIDP socket layer initialized
[    6.955825] Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
[    7.017611] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Apr 22 2013 14:50:00 version 5.90.195.89.6 FWID 01-b30a427d
[    7.028817] fuse init (API version 7.23)
[    7.118715] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[    7.235638] sun4i-ss 1c15000.crypto-engine: no reset control found
[    7.237201] sun4i-ss 1c15000.crypto-engine: Die ID 0
[    7.489452] sun7i-dwmac 1c50000.ethernet: no regulator found
[    7.489568] sun7i-dwmac 1c50000.ethernet: no reset control found
[    7.489582]  Ring mode enabled
[    7.489590]  No HW DMA feature register supported
[    7.489597]  Normal descriptors
[    7.489602]  TX Checksum insertion supported
[    7.560598] libphy: stmmac: probed
[    7.560635] eth0: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[    7.560644] eth0: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[    7.564999] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[    7.627626] EXT4-fs (mmcblk0p1): re-mounted. Opts: data=writeback,commit=600,errors=remount-ro
[    8.303949] Adding 131068k swap on /var/swap.  Priority:-1 extents:2 across:139260k SSFS
[    9.861714] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    9.861738] Bluetooth: BNEP filters: protocol multicast
[    9.861768] Bluetooth: BNEP socket layer initialized
[   11.149737]  RX IPC Checksum Offload disabled
[   11.149771]  No MAC Management Counters available
[   19.128402] sun7i-dwmac 1c50000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[   31.786759] init: failsafe main process (403) killed by TERM signal
[   40.656360] random: nonblocking pool is initialized
dmesg (booting from mmc after attaching usb)
[  639.527917] usb 2-1: new high-speed USB device number 2 using ehci-platform
[  639.709592] usb 2-1: New USB device found, idVendor=152d, idProduct=3562
[  639.709624] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  639.709641] usb 2-1: Product: AD TO BE II
[  639.709664] usb 2-1: Manufacturer: ADMKIV
[  639.709680] usb 2-1: SerialNumber: DB12345678987C
[  639.745209] scsi host1: uas
[  639.748763] scsi 1:0:0:0: Direct-Access     ADplus   SuperVer         6302 PQ: 0 ANSI: 6
[  639.754495] sd 1:0:0:0: [sda] 250069680 512-byte logical blocks: (128 GB/119 GiB)
[  639.754532] sd 1:0:0:0: [sda] 4096-byte physical blocks
[  639.754675] sd 1:0:0:0: Attached scsi generic sg0 type 0
[  639.756362] sd 1:0:0:0: [sda] Write Protect is off
[  639.756405] sd 1:0:0:0: [sda] Mode Sense: 53 00 00 08
[  639.756457] usbcore: registered new interface driver uas
[  639.757395] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[  639.769851]  sda: sda1 sda2 sda3
[  639.775233] sd 1:0:0:0: [sda] Attached SCSI disk
lsmod (booting from mmc no usb connected)
root@cubietruck:~# lsmod
bnep                    9892  2
realtek                 2455  0
sun4i_codec            10303  3
dwmac_sunxi             2239  0
snd_soc_core          102678  1 sun4i_codec
snd_pcm_dmaengine       2943  1 snd_soc_core
snd_pcm                69300  2 snd_soc_core,snd_pcm_dmaengine
snd_timer              17960  1 snd_pcm
evdev                  11268  2
sun4i_ts                3798  0
input_leds              2484  0
snd                    41799  3 snd_soc_core,snd_timer,snd_pcm
soundcore                858  1 snd
nvmem_sunxi_sid         2359  0
nvmem_core              7504  1 nvmem_sunxi_sid
pwm_sun4i               4308  0
sun4i_ss               14914  0
fuse                   72800  0
bonding                94395  0
hidp                   12522  0
rfcomm                 30514  0
cpufreq_dt              4010  0
bluetooth             299193  11 bnep,hidp,rfcomm
thermal_sys            36472  2 cpufreq_dt,sun4i_ts
uio_pdrv_genirq         2908  0
uio                     6784  1 uio_pdrv_genirq
brcmfmac              162570  0
brcmutil                4957  1 brcmfmac
cfg80211              214121  1 brcmfmac
rfkill                  9328  3 cfg80211,bluetooth
lsmod (booting from mmc after attaching usb)
uas                    11631  0
bnep                    9892  2
realtek                 2455  0
sun4i_codec            10303  3
dwmac_sunxi             2239  0
evdev                  11268  2
sun4i_ts                3798  0
input_leds              2484  0
soundcore                858  1 snd
pwm_sun4i               4308  0
sun4i_ss               14914  0
fuse                   72800  0
bonding                94395  0
hidp                   12522  0
rfcomm                 30514  0
cpufreq_dt              4010  0
brcmfmac              162570  0
blkid (strangely, blkid does not povide PARTUUID on cubietruck. Attaching the same USB disck on my laptop, blkid provides PATRUUID as specified in the boot.cmd below)
/dev/mmcblk0p1: UUID="09b27937-cb52-4954-9b3c-a1417504395a" TYPE="ext4"
/dev/sda1: LABEL="cubie" UUID="c546b875-ab71-4d1d-9b51-1ce2f75c3c9a" TYPE="ext4"
/dev/sda2: LABEL="data" UUID="02588c89-6eed-4494-9783-a4128fe9c3fe" TYPE="ext4"
/dev/sda3: UUID="57315f9f-31e7-4dc3-9718-5892d41689c5" TYPE="ext4"
root@cubietruck:/var/log# mount -V
mount from util-linux 2.20.1 (with libblkid and selinux support)
root@cubietruck:/var/log# mount PARTUUID=74f0e0db-03 /media/
mount: special device PARTUUID=74f0e0db-03 does not exist
root@cubietruck:/var/log# mount UUID=57315f9f-31e7-4dc3-9718-5892d41689c5 /media/
mount from my laptop
$ mount -V
mount from util-linux 2.26.2 (libmount 2.26.0: selinux, assert, debug)
Boot.cmd (rootfs @USB)
root@cubietruck:/boot# cat boot.cmd
setenv bootargs "console=tty1 root=PARTUUID=74f0e0db-03 rootwait rootfstype=ext4 cgroup-enable=memory swapaccount=1 sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_no_mali_mem_reserve sunxi_fb_mem_reserve=16 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 enforcing=0 loglevel=7"
#setenv bootargs "console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 cgroup-enable=memory swapaccount=1 sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 #sunxi_no_mali_mem_reserve sunxi_fb_mem_reserve=16 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 enforcing=0 loglevel=7"
# Boot loader script to boot with different boot methods for old and new kernel
if ext4load mmc 0 0x00000000 /boot/.next || fatload mmc 0 0x00000000 .next || ext4load mmc 0 0x00000000 .next
then
# sunxi mainline kernel
ext4load mmc 0 0x49000000 /boot/dtb/${fdtfile} || fatload mmc 0 0x49000000 /dtb/${fdtfile} || ext4load mmc 0 0x49000000 /dtb/${fdtfile}
ext4load mmc 0 0x46000000 /boot/zImage || fatload mmc 0 0x46000000 zImage || ext4load mmc 0 0x46000000 zImage
env set fdt_high ffffffff
bootz 0x46000000 - 0x49000000
else
# sunxi android kernel
ext4load mmc 0 0x43000000 /boot/script.bin || fatload mmc 0 0x43000000 script.bin || ext4load mmc 0 0x43000000 script.bin
ext4load mmc 0 0x48000000 /boot/zImage || fatload mmc 0 0x48000000 zImage || ext4load mmc 0 0x48000000 zImage
bootz 0x48000000
fi
# Recompile with:
fstab (I tried with UUID and PARTUUID)
# UNCONFIGURED FSTAB FOR BASE SYSTEM
UUID=57315f9f-31e7-4dc3-9718-5892d41689c5	/           ext4    defaults,noatime,nodiratime,commit=600,errors=remount-ro        0       0
#PARTUUID=74f0e0db-03	/           ext4    defaults,noatime,nodiratime,commit=600,errors=remount-ro        0       0
/var/swap none swap sw 0 0
/dev/mmcblk0p1        /media/mmc   ext4    defaults        0       0
/media/mmc/boot   /boot   none    bind        0       0
According to this page https://forums.linuxmint.com/viewtopic.php?t=162677(linuxmint being based on Ubuntu), the package util-linux in which there is blkid could be outdated and not supporting PARTUUID.
My desktop is Linuxmint 17.3 based on Ubuntu 14.04 ant util-linux version is "2.20.1-5.1 ubuntu20.7".
Command blkid on my desktop doesn't show "PARTUUID", only "UUID".
On my Cubieboard2 with Debian 8 Jessie, This package is in version "2.25.2-6". And PARTUUID is shown with blkid.
Maybe this is the reason ? PARTUUID on your Ubuntu version is not supported and you can't mount it from it ?
I am not an expert, though.
Well, I also tried the Debian 8 Jessie image with util-linux version "2.25.2-6".
I am able to boot from mmc using root=PARTUUID=... but not from the usb(uas usb to sata)
It seems that with the new images (I used Armbian_5.10_Cubietruck_Debian_jessie_4.5.2) moving to usb(ssd) is solved
