Ok, i do have one, but not a vim4.
I have a vim 3.
But armbian doesnt install on a vim3 as far as i can tell.  No applicable or verified instructions exist for installing it there.
I would like a working vim board with armbian. So maybe a vim4 is my only choice.
I have not seen the screen work outside of android that came with it. On an edge V or vim 3 with any mainline distro.
But it is expected to work?
I will have to buy a vim4 to try.
Ah. Yea those are no longer valid instructions as krescue no longen exists and khadas is against its use even if you can find it. I have it, but the instructions didnt work in June so they are less likely to work now..
I'm hoping that because vim 4 is in a higher support tier that it will all work. Although I know that linux support for embedded displays is terrible and almost non existant.
Thank you. It would be good to clarify those instructions.  I read through the thread that I started in june and its not clear to me that a solution was found.
If I get a vim 4 I'll let you know if the screen works.
We did get the nanopc t4 working with it's screen last year so i know its possible.
