after update to stable v23.11 branch i cannot build anymore under WSL2
i get the following error when the process starts to create the image:
"Error: Partition(s) 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64 on /dev/loop0 have been written, but we have been unable to inform the kernel of the change, probably because it/they are in use.  As a result, the old partition(s) will remain in use.  You should reboot now before making further changes."
here's the full log:
https://paste.next.armbian.com/kilubovuru
Any help would be very much appreciated.
Thanks
EDIT: solved by replacing the kernel with the armbian one ( https://github.com/armbian/build/pull/5978#issuecomment-1826840715 )
Edited by sgufa
  • Igor featured, pinned and unfeatured this topic
The hint has been given on the LOG, and you should try again as suggested above
  • Igor unpinned this topic
