ytn Posted October 13, 2015 Posted October 13, 2015 I created a Wheezy and Jessie image. Whenever I try extracting the Jessie image, I get a CRC error. I am using 7zip. I tried extracting the zip also using Windows Explorer (Win10) and it also runs into an error. It seems like there might be an issue with the Jessie images being created. I cleaned my output folder and created a new clean image and still run into the same problem. This is using the latest libs and creating a 4.2.3 image (the default settings in the lib config). FYI, the Wheezy image extracts without any problems. Any ideas why the Jessie image is corrupt? Thanks.
Igor Posted October 14, 2015 Posted October 14, 2015 This is something odd. I built new image set two days ago and had zero problems. Jessie was under heavy testing since we had some boot problems. None of image has and signs of corruption.
ytn Posted October 15, 2015 Author Posted October 15, 2015 I cleaned all my folders, synched libs to the latest and kicked off a new build and it seems to be fine now. Not sure what was causing the hiccup before, but all is good now. 1
