chpi Posted January 25, 2017 Share Posted January 25, 2017 I installed Armbian_5.24_Orangepizero_Ubuntu_xenial_dev_4.9.4 on my Orange Pi Zero. Because it has no video out, I try to login via SSH. Unfortunately the password "1234" does not work for user root. I get "Permission denied (publickey,password).". Is the password wrong? Link to comment Share on other sites More sharing options...
tkaiser Posted January 25, 2017 Share Posted January 25, 2017 Did you check download integrity and more importantly used Etcher as recommended to burn the SD card? When I tested with broken SD cards symtpoms were the same (due to read-only filesystem due to corrupted OS image on SD card). Apart from that you should be aware that dev images are for devs and to get dev feedback (at least serial console attached since this is to improve things and not doing unpaid 1st level support for no reason). Link to comment Share on other sites More sharing options...
zador.blood.stained Posted January 25, 2017 Share Posted January 25, 2017 @chpi Are you entering the password interactively or supplying it prior to connecting? Forced password change may not work with the latter option. Link to comment Share on other sites More sharing options...
Ford Prefect Posted January 25, 2017 Share Posted January 25, 2017 Hi It also doesn't work on my OrangePI PC neither with ssh or in a text console It doesn't bother me too much as I use Midnight Commander mainly and sudo mc makes me "master of the world " First I thought it was inherited from ubuntu that always want to forbid me to break my machine. In fact I think it is a bad idea as it even prevent from changing the unknown root password witch seems to be the basis of system security. Link to comment Share on other sites More sharing options...
chpi Posted January 25, 2017 Author Share Posted January 25, 2017 @tkaiser No, I used dd. I am going to retry with etcher. The dev image is the only image available on Mainline for the Orange Pi Zero. If etcher does not help, I am going to try Legacy 3.4.113. @zador.blood.stained I entered the password interactively. Link to comment Share on other sites More sharing options...
chpi Posted January 27, 2017 Author Share Posted January 27, 2017 Flashing with etcher did not change anything but going to Legacy 3.4.113 helped. I guess the dev image simply has a different password. Thank you for your help! Link to comment Share on other sites More sharing options...
tkaiser Posted January 27, 2017 Share Posted January 27, 2017 Flashing with etcher did not change anything but going to Legacy 3.4.113 helped. I guess the dev image simply has a different password. Nope, it hasn't. And that's the reason why I asked whether you also checked download integrity (yes, this also happens from time to time: corrupted downloads for whatever reasons): https://docs.armbian.com/User-Guide_Getting-Started/#how-to-check-download-authenticity Please check this if you've the old 4.9.4 image around. Another reason could be that these nightly builds are fully automated and untested builds and stuff might be broken anyway. Well, maybe I should learn to ignore any questions regarding nightly images since every user happily ignores the warning [1] on download page, we get zero constructive feedback and only waste our time with useless support questions. Maybe we should just stop providing these images... maybe the best idea. [1] Warning: nightly downloads are automated untested builds and no end user support is provided for them! Link to comment Share on other sites More sharing options...
ThomasGB Posted June 17, 2017 Share Posted June 17, 2017 Take the easy way: sudo losetup /dev/loop0 Armbian_5.30_Orangepipc_Ubuntu_xenial_default_3.4.113.img (alternatively when burned on sd-card the same with e.g. /dev/sdg or similar). sudo partprobe /dev/loop0 sudo mount /dev/loop0p1 XX sudo cp /usr/bin/qemu-arm-static XX/usr/bin sudo chroot XX passwd ----> Enter new Password for root exit sync sudo umount XX sudo losetup -d /dev/loop0 (If this doesn't work, there is something worn with the image ...) Cheers Thomas GB Link to comment Share on other sites More sharing options...
Leonid Kokhnovych Posted April 6, 2018 Share Posted April 6, 2018 I had a similar issue. I had to specify a user while using ssh command like: ssh root@192.168.1.75 Link to comment Share on other sites More sharing options...
