lds6 Posted January 26, 2017 Posted January 26, 2017 Hi, I've tried to use the Ubuntu Xenial Mainline 4.9.4 server on my orange pi one. The u-boot log messages appear on the HDMI monitor but after the "Starting Kernel" message, the monitor shows "No Signal". I can still acess it through SSH. Executing dmesg, there is a log "simple-framebuffer: probe of 59f42000.framebuffer failed with error -12". I'm new to Linux, Is there a way I can fix it ? Thx.
jgrulich Posted January 31, 2017 Posted January 31, 2017 I have the same issue, may be it's still related to use of HDMI-to-DVI adapter cable. At Jessie I've used the h3disp utility to set the -d parameter. But with the mainline there is dtb instead of bin boot configuration file and therefor no this utility anymore available.
Christos Posted January 31, 2017 Posted January 31, 2017 Had this issue too. It is fixed today evening so if you can build now a new image it will be ok.
jgrulich Posted January 31, 2017 Posted January 31, 2017 Oops, but I have OrangePi PC, which is not listed. When it will be fixed for this board?
jgrulich Posted January 31, 2017 Posted January 31, 2017 Hence I've modified a image a lot, don't want to do is again. What to modify to get it working on older image than from today?
