Did a clean build (deleted all cache & sources), for OPi+2E, Ubuntu development, with desktop.
(up to commit 633824d)
Build ok and copied on SD, yet after boot no HDMI screen came out
boot
[  OK  ] Started Create list of required sta...ce nodes for the current kernel.
[  OK  ] Started Set console keymap.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[  OK  ] Started Remount Root and Kernel File Systems.
[  OK  ] Started Nameserver information manager.
root@orangepiplus2e:~# systemctl status systemd-modules-load.service
Warning: systemd-modules-load.service changed on disk. Run 'systemctl daemon-reload' to reload units.
â— systemd-modules-load.service - Load Kernel Modules
   Loaded: loaded (/lib/systemd/system/systemd-modules-load.service; static; vendor preset: enabled)
  Drop-In: /etc/systemd/system/systemd-modules-load.service.d
           └─10-timeout.conf
   Active: failed (Result: exit-code) since Tue 2017-01-31 14:18:41 UTC; 10min ago
     Docs: man:systemd-modules-load.service(8)
           man:modules-load.d(5)
  Process: 246 ExecStart=/lib/systemd/systemd-modules-load (code=exited, status=1/FAILURE)
 Main PID: 246 (code=exited, status=1/FAILURE)
Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
dmesg
[    3.250482] ------------[ cut here ]------------
[    3.250502] WARNING: CPU: 2 PID: 1 at arch/arm/mm/ioremap.c:303 __arm_ioremap_pfn_caller+0x5d/0x12c
[    3.250505] Modules linked in:
[    3.250517] CPU: 2 PID: 1 Comm: swapper/0 Not tainted 4.9.4-sun8i #1
[    3.250520] Hardware name: Allwinner sun8i Family
[    3.250543] [<c010b891>] (unwind_backtrace) from [<c0108ec3>] (show_stack+0xb/0xc)
[    3.250556] [<c0108ec3>] (show_stack) from [<c04266d7>] (dump_stack+0x67/0x74)
[    3.250570] [<c04266d7>] (dump_stack) from [<c0117411>] (__warn+0xa9/0xbc)
[    3.250579] [<c0117411>] (__warn) from [<c011748f>] (warn_slowpath_null+0x13/0x18)
[    3.250589] [<c011748f>] (warn_slowpath_null) from [<c0111dbd>] (__arm_ioremap_pfn_caller+0x5d/0x12c)
[    3.250600] [<c0111dbd>] (__arm_ioremap_pfn_caller) from [<c0111eb9>] (__arm_ioremap_caller+0x2d/0x38)
[    3.250612] [<c0111eb9>] (__arm_ioremap_caller) from [<c046150f>] (simplefb_probe+0x1c3/0x654)
[    3.250625] [<c046150f>] (simplefb_probe) from [<c0497517>] (platform_drv_probe+0x33/0x74)
[    3.250635] [<c0497517>] (platform_drv_probe) from [<c049658b>] (driver_probe_device+0x14f/0x1c8)
[    3.250647] [<c049658b>] (driver_probe_device) from [<c04953ab>] (bus_for_each_drv+0x37/0x54)
[    3.250659] [<c04953ab>] (bus_for_each_drv) from [<c049639b>] (__device_attach+0x6f/0xb8)
[    3.250670] [<c049639b>] (__device_attach) from [<c0495c71>] (bus_probe_device+0x55/0x5c)
[    3.250681] [<c0495c71>] (bus_probe_device) from [<c0494a3d>] (device_add+0x2d9/0x400)
[    3.250695] [<c0494a3d>] (device_add) from [<c05a2ec3>] (of_platform_device_create_pdata+0x5b/0x84)
[    3.250712] [<c05a2ec3>] (of_platform_device_create_pdata) from [<c0a15227>] (simplefb_init+0x43/0x58)
[    3.250725] [<c0a15227>] (simplefb_init) from [<c01016b9>] (do_one_initcall+0x31/0x110)
[    3.250736] [<c01016b9>] (do_one_initcall) from [<c0a00b83>] (kernel_init_freeable+0x17f/0x1e4)
[    3.250749] [<c0a00b83>] (kernel_init_freeable) from [<c069dbd7>] (kernel_init+0x7/0xd4)
[    3.250761] [<c069dbd7>] (kernel_init) from [<c0105f31>] (ret_from_fork+0x11/0x20)
[    3.250771] ---[ end trace d6bff669de280e74 ]---
[    3.250788] simple-framebuffer: probe of b9f40000.framebuffer failed with error -12
P.S.
Trying now again this time for a mainliine Debian/Desktop, but it takes about two hours on my system..
P.S.2
-> same problem in Debian mainline desktop build.
Performed another H3 OPi+2E build, Ubuntu mainline desktop, up to commit 36ae17d
Now the screen/HDMI does work, yet there still is a reported error
[  OK  ] Mounted Debug File System.
[  OK  ] Started Restore / save the current clock.
           └─10-timeout.conf
   Active: failed (Result: exit-code) since Tue 2017-01-31 20:14:29 EET; 5min ago
  Process: 237 ExecStart=/lib/systemd/systemd-modules-load (code=exited, status=1/FAILURE)
 Main PID: 237 (code=exited, status=1/FAILURE)
Dont know exactly where it comes from so I report the entire dmesg
root@orangepiplus2e:~# dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.4-sun8i (root@Ubuntu16041VM) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #2 SMP Tue Jan 31 18:35:49 EET 2017
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt:Machine model: Xunlong Orange Pi Plus 2E
[    0.000000] cma: Reserved 16 MiB at 0xbe800000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 522263
[    0.000000] free_area_init_node: node 0, pgdat c0b4e680, node_mem_map eee01000
[    0.000000]   Normal zone: 1728 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 196608 pages, LIFO batch:31
[    0.000000]   HighMem zone: 325655 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: Using PSCI v0.1 Function IDs from DT
[    0.000000] percpu: Embedded 14 pages/cpu @eedaf000 s26188 r8192 d22964 u57344
[    0.000000] pcpu-alloc: s26188 r8192 d22964 u57344 alloc=14*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 520535
[    0.000000] Kernel command line: root=UUID=39dc4b8a-4172-4493-9c35-8951c8349da6 rootwait rootfstype=ext4 console=tty1 console=ttyS0,115200 cgroup_enable=memory swapaccount=1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 enforcing=0 loglevel=1 ubootpart=01b516de-01 ubootsource=mmc   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 2037180K/2089052K available (6144K kernel code, 316K rwdata, 2248K rodata, 1024K init, 310K bss, 35488K reserved, 16384K cma-reserved, 1286228K highmem)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
                   lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
                   pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
                   modules : 0xbf800000 - 0xbfe00000   (   6 MB)
                     .text : 0xc0008000 - 0xc0700000   (7136 kB)
                     .init : 0xc0a00000 - 0xc0b00000   (1024 kB)
                     .data : 0xc0b00000 - 0xc0b4f280   ( 317 kB)
                      .bss : 0xc0b51000 - 0xc0b9e940   ( 311 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000015] Switching to timer-based delay loop, resolution 41ns
[    0.000179] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000458] Console: colour dummy device 80x30
[    0.000470] console [tty1] enabled
[    0.000491] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000502] pid_max: default: 32768 minimum: 301
[    0.000702] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000709] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001457] CPU: Testing write buffer coherency: ok
[    0.001766] CPU0: update cpu_capacity 1024
[    0.001772] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.001793] Setting up static identity map for 0x40100000 - 0x4010004c
[    0.013535] CPU1: update cpu_capacity 1024
[    0.013541] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.024195] CPU2: update cpu_capacity 1024
[    0.024200] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.034857] CPU3: update cpu_capacity 1024
[    0.034862] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.034926] Brought up 4 CPUs
[    0.034936] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.034939] CPU: All CPU(s) started in HYP mode.
[    0.034941] CPU: Virtualization extensions available.
[    0.036016] devtmpfs: initialized
[    0.044783] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.045034] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.045648] xor: measuring software checksum speed
[    0.144727]    arm4regs  :  1263.200 MB/sec
[    0.244778]    8regs     :   733.200 MB/sec
[    0.344829]    32regs    :   787.600 MB/sec
[    0.444880]    neon      :  1280.800 MB/sec
[    0.444884] xor: using function: neon (1280.800 MB/sec)
[    0.444969] pinctrl core: initialized pinctrl subsystem
[    0.445900] NET: Registered protocol family 16
[    0.447003] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.473716] cpuidle: using governor ladder
[    0.513724] cpuidle: using governor menu
[    0.514408] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.514412] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.695157] raid6: int32x1  gen()   190 MB/s
[    0.865172] raid6: int32x1  xor()   161 MB/s
[    1.035291] raid6: int32x2  gen()   255 MB/s
[    1.205433] raid6: int32x2  xor()   198 MB/s
[    1.375466] raid6: int32x4  gen()   258 MB/s
[    1.545607] raid6: int32x4  xor()   191 MB/s
[    1.715614] raid6: int32x8  gen()   248 MB/s
[    1.885790] raid6: int32x8  xor()   172 MB/s
[    2.055862] raid6: neonx1   gen()   494 MB/s
[    2.225902] raid6: neonx1   xor()   366 MB/s
[    2.396060] raid6: neonx2   gen()   649 MB/s
[    2.566092] raid6: neonx2   xor()   470 MB/s
[    2.736222] raid6: neonx4   gen()   785 MB/s
[    2.906300] raid6: neonx4   xor()   528 MB/s
[    3.076373] raid6: neonx8   gen()   697 MB/s
[    3.246490] raid6: neonx8   xor()   480 MB/s
[    3.246493] raid6: using algorithm neonx4 gen() 785 MB/s
[    3.246496] raid6: .... xor() 528 MB/s, rmw enabled
[    3.246499] raid6: using intx1 recovery algorithm
[    3.246736] reg-fixed-voltage usb0-vbus: could not find pctldev for node /soc/pinctrl@01f02c00/usb0_vbus_pin@0, deferring probe
[    3.247298] reg-fixed-voltage gmac-3v3: could not find pctldev for node /soc/pinctrl@01c20800/gmac_power_pin@0, deferring probe
[    3.247807] SCSI subsystem initialized
[    3.247985] libata version 3.00 loaded.
[    3.248213] usbcore: registered new interface driver usbfs
[    3.248264] usbcore: registered new interface driver hub
[    3.248324] usbcore: registered new device driver usb
[    3.248506] media: Linux media interface: v0.10
[    3.248555] Linux video capture interface: v2.00
[    3.248613] pps_core: LinuxPPS API ver. 1 registered
[    3.248617] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    3.248633] PTP clock support registered
[    3.249951] clocksource: Switched to clocksource arch_sys_counter
[    3.250837] simple-framebuffer bf817000.framebuffer: framebuffer at 0xbf817000, 0x7e9000 bytes, mapped to 0xf0880000
[    3.250847] simple-framebuffer bf817000.framebuffer: format=x8r8g8b8, mode=1920x1080x32, linelength=7680
[    3.288638] Console: switching to colour frame buffer device 240x67
[    3.325747] simple-framebuffer bf817000.framebuffer: fb0: simplefb registered!
[    3.333925] NET: Registered protocol family 2
[    3.334485] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    3.334569] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    3.334680] TCP: Hash tables configured (established 8192 bind 8192)
[    3.334735] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    3.334790] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    3.334989] NET: Registered protocol family 1
[    3.335370] RPC: Registered named UNIX socket transport module.
[    3.335375] RPC: Registered udp transport module.
[    3.335378] RPC: Registered tcp transport module.
[    3.335381] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    3.335641] Trying to unpack rootfs image as initramfs...
[    3.629734] Freeing initrd memory: 4988K (c9b21000 - ca000000)
[    3.631412] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    3.631777] Initialise system trusted keyrings
[    3.632122] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[    3.639907] zbud: loaded
[    3.643414] NFS: Registering the id_resolver key type
[    3.643435] Key type id_resolver registered
[    3.643439] Key type id_legacy registered
[    3.643451] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    3.643454] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    3.644906] JFS: nTxBlock = 8192, nTxLock = 65536
[    3.654665] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[    3.661545] Key type asymmetric registered
[    3.661606] bounce: pool size: 64 pages
[    3.661841] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[    3.661952] io scheduler noop registered
[    3.661957] io scheduler deadline registered
[    3.662314] io scheduler cfq registered (default)
[    3.663068] sun4i-usb-phy 1c19400.phy: could not find pctldev for node /soc/pinctrl@01c20800/usb0_id_detect_pin@0, deferring probe
[    3.667160] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    3.668867] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[    3.724379] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    3.726967] console [ttyS0] disabled
[    3.747125] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 41, base_baud = 1500000) is a U6_16550A
[    3.747167] console [ttyS0] enabled
[    3.750864] brd: module loaded
[    3.756768] loop: module loaded
[    3.758066] libphy: Fixed MDIO Bus: probed
[    3.759114] usbcore: registered new interface driver catc
[    3.759159] usbcore: registered new interface driver kaweth
[    3.759164] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    3.759205] usbcore: registered new interface driver pegasus
[    3.759258] usbcore: registered new interface driver rtl8150
[    3.759316] usbcore: registered new interface driver r8152
[    3.759358] usbcore: registered new interface driver lan78xx
[    3.759413] usbcore: registered new interface driver asix
[    3.759455] usbcore: registered new interface driver ax88179_178a
[    3.759497] usbcore: registered new interface driver cdc_ether
[    3.759539] usbcore: registered new interface driver cdc_eem
[    3.759580] usbcore: registered new interface driver dm9601
[    3.759631] usbcore: registered new interface driver sr9700
[    3.759688] usbcore: registered new interface driver CoreChips
[    3.759747] usbcore: registered new interface driver smsc75xx
[    3.759805] usbcore: registered new interface driver smsc95xx
[    3.759848] usbcore: registered new interface driver gl620a
[    3.759891] usbcore: registered new interface driver net1080
[    3.759975] usbcore: registered new interface driver plusb
[    3.760035] usbcore: registered new interface driver rndis_host
[    3.760080] usbcore: registered new interface driver cdc_subset
[    3.760125] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    3.760199] usbcore: registered new interface driver cdc_ncm
[    3.760243] usbcore: registered new interface driver huawei_cdc_ncm
[    3.760286] usbcore: registered new interface driver cdc_mbim
[    3.760295] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.760299] ehci-platform: EHCI generic platform driver
[    3.760668] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.760683] ohci-platform: OHCI generic platform driver
[    3.761041] usbcore: registered new interface driver cdc_wdm
[    3.761105] usbcore: registered new interface driver usb-storage
[    3.761815] sun6i-rtc 1f00000.rtc: rtc core: registered rtc-sun6i as rtc0
[    3.761821] sun6i-rtc 1f00000.rtc: RTC enabled
[    3.761883] i2c /dev entries driver
[    3.765366] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    3.766674] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[    3.829975] sunxi-mmc 1c0f000.mmc: base:0xf152e000 irq:24
[    3.830518] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
[    3.880909] mmc0: host does not support reading read-only switch, assuming write-enable
[    3.883254] mmc0: new high speed SDHC card at address aaaa
[    3.883778] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[    3.885965]  mmcblk0: p1
[    3.890002] sunxi-mmc 1c10000.mmc: base:0xf1532000 irq:25
[    3.896300] sunxi-mmc 1c10000.mmc: smc 1 err, cmd 8, RTO !!
[    3.906770] mmc1: new high speed SDIO card at address 0001
[    3.949963] sunxi-mmc 1c11000.mmc: base:0xf153f000 irq:26
[    3.951045] ledtrig-cpu: registered to indicate activity on CPUs
[    3.951122] hidraw: raw HID events driver (C) Jiri Kosina
[    3.951288] usbcore: registered new interface driver usbhid
[    3.951291] usbhid: USB HID core driver
[    3.951537] Initializing XFRM netlink socket
[    3.952262] NET: Registered protocol family 10
[    3.953087] NET: Registered protocol family 17
[    3.953108] NET: Registered protocol family 15
[    3.953139] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    3.953193] 8021q: 802.1Q VLAN Support v1.8
[    3.953231] Key type dns_resolver registered
[    3.953588] Registering SWP/SWPB emulation handler
[    3.954229] registered taskstats version 1
[    3.954234] Loading compiled-in X.509 certificates
[    3.954309] zswap: loaded using pool lzo/zbud
[    3.955732] Btrfs loaded, crc32c=crc32c-generic
[    3.956938] sunxi-mmc 1c11000.mmc: smc 2 err, cmd 8, RTO !!
[    3.961093] sunxi-mmc 1c11000.mmc: smc 2 err, cmd 55, RTO !!
[    3.964873] sunxi-mmc 1c11000.mmc: smc 2 err, cmd 55, RTO !!
[    3.968586] sunxi-mmc 1c11000.mmc: smc 2 err, cmd 55, RTO !!
[    3.969427] sunxi-mmc 1c11000.mmc: smc 2 err, cmd 55, RTO !!
[    3.971565] Key type encrypted registered
[    3.977963] sun8i-emac 1c30000.ethernet: PHY regulator found
[    3.979006] ehci-platform 1c1a000.usb: EHCI Host Controller
[    3.979035] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    3.979435] ehci-platform 1c1a000.usb: irq 28, io mem 0x01c1a000
[    4.000035] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    4.000245] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    4.000253] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.000259] usb usb1: Product: EHCI Host Controller
[    4.000264] usb usb1: Manufacturer: Linux 4.9.4-sun8i ehci_hcd
[    4.000269] usb usb1: SerialNumber: 1c1a000.usb
[    4.000874] hub 1-0:1.0: USB hub found
[    4.000911] hub 1-0:1.0: 1 port detected
[    4.001500] ehci-platform 1c1b000.usb: EHCI Host Controller
[    4.001533] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 2
[    4.001688] ehci-platform 1c1b000.usb: irq 30, io mem 0x01c1b000
[    4.039958] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
[    4.040127] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    4.040134] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.040139] usb usb2: Product: EHCI Host Controller
[    4.040145] usb usb2: Manufacturer: Linux 4.9.4-sun8i ehci_hcd
[    4.040150] usb usb2: SerialNumber: 1c1b000.usb
[    4.040667] hub 2-0:1.0: USB hub found
[    4.040701] hub 2-0:1.0: 1 port detected
[    4.041253] ehci-platform 1c1c000.usb: EHCI Host Controller
[    4.041275] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 3
[    4.041413] ehci-platform 1c1c000.usb: irq 32, io mem 0x01c1c000
[    4.054084] mmc2: new DDR MMC card at address 0001
[    4.054659] mmcblk2: mmc2:0001 AWPD3R 14.6 GiB
[    4.054920] mmcblk2boot0: mmc2:0001 AWPD3R partition 1 4.00 MiB
[    4.055180] mmcblk2boot1: mmc2:0001 AWPD3R partition 2 4.00 MiB
[    4.056312]  mmcblk2: p1
[    4.079958] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
[    4.080159] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    4.080167] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.080172] usb usb3: Product: EHCI Host Controller
[    4.080177] usb usb3: Manufacturer: Linux 4.9.4-sun8i ehci_hcd
[    4.080183] usb usb3: SerialNumber: 1c1c000.usb
[    4.080773] hub 3-0:1.0: USB hub found
[    4.080808] hub 3-0:1.0: 1 port detected
[    4.081442] ehci-platform 1c1d000.usb: EHCI Host Controller
[    4.081479] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 4
[    4.081669] ehci-platform 1c1d000.usb: irq 34, io mem 0x01c1d000
[    4.109968] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
[    4.110137] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    4.110145] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.110150] usb usb4: Product: EHCI Host Controller
[    4.110156] usb usb4: Manufacturer: Linux 4.9.4-sun8i ehci_hcd
[    4.110161] usb usb4: SerialNumber: 1c1d000.usb
[    4.110744] hub 4-0:1.0: USB hub found
[    4.110777] hub 4-0:1.0: 1 port detected
[    4.399960] usb 2-1: new high-speed USB device number 2 using ehci-platform
[    4.590595] usb 2-1: New USB device found, idVendor=1a40, idProduct=0101
[    4.590603] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    4.590609] usb 2-1: Product: USB 2.0 Hub
[    4.591249] hub 2-1:1.0: USB hub found
[    4.591342] hub 2-1:1.0: 4 ports detected
[    4.909957] usb 2-1.1: new low-speed USB device number 3 using ehci-platform
[    5.010331] random: fast init done
[    5.066090] usb 2-1.1: New USB device found, idVendor=046d, idProduct=c521
[    5.066097] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    5.066103] usb 2-1.1: Product: USB Receiver
[    5.066108] usb 2-1.1: Manufacturer: Logitech
[    5.073136] input: Logitech USB Receiver as /devices/platform/soc/1c1b000.usb/usb2/2-1/2-1.1/2-1.1:1.0/0003:046D:C521.0001/input/input0
[    5.073305] hid-generic 0003:046D:C521.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-1c1b000.usb-1.1/input0
[    5.081445] input: Logitech USB Receiver as /devices/platform/soc/1c1b000.usb/usb2/2-1/2-1.1/2-1.1:1.1/0003:046D:C521.0002/input/input1
[    5.120074] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    5.120099] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 5
[    5.120263] ohci-platform 1c1a400.usb: irq 29, io mem 0x01c1a400
[    5.150315] hid-generic 0003:046D:C521.0002: input,hiddev0,hidraw1: USB HID v1.11 Device [Logitech USB Receiver] on usb-1c1b000.usb-1.1/input1
[    5.194109] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    5.194116] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.194122] usb usb5: Product: Generic Platform OHCI controller
[    5.194127] usb usb5: Manufacturer: Linux 4.9.4-sun8i ohci_hcd
[    5.194132] usb usb5: SerialNumber: 1c1a400.usb
[    5.194682] hub 5-0:1.0: USB hub found
[    5.194720] hub 5-0:1.0: 1 port detected
[    5.195360] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
[    5.195385] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6
[    5.195527] ohci-platform 1c1b400.usb: irq 31, io mem 0x01c1b400
[    5.249964] usb 2-1.4: new low-speed USB device number 4 using ehci-platform
[    5.264097] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    5.264105] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.264110] usb usb6: Product: Generic Platform OHCI controller
[    5.264116] usb usb6: Manufacturer: Linux 4.9.4-sun8i ohci_hcd
[    5.264121] usb usb6: SerialNumber: 1c1b400.usb
[    5.264653] hub 6-0:1.0: USB hub found
[    5.264687] hub 6-0:1.0: 1 port detected
[    5.265239] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
[    5.265261] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7
[    5.265383] ohci-platform 1c1c400.usb: irq 33, io mem 0x01c1c400
[    5.334109] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[    5.334116] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.334121] usb usb7: Product: Generic Platform OHCI controller
[    5.334127] usb usb7: Manufacturer: Linux 4.9.4-sun8i ohci_hcd
[    5.334132] usb usb7: SerialNumber: 1c1c400.usb
[    5.334680] hub 7-0:1.0: USB hub found
[    5.334712] hub 7-0:1.0: 1 port detected
[    5.335249] ohci-platform 1c1d400.usb: Generic Platform OHCI controller
[    5.335271] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8
[    5.335375] ohci-platform 1c1d400.usb: irq 35, io mem 0x01c1d400
[    5.404153] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
[    5.404160] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.404166] usb usb8: Product: Generic Platform OHCI controller
[    5.404171] usb usb8: Manufacturer: Linux 4.9.4-sun8i ohci_hcd
[    5.404176] usb usb8: SerialNumber: 1c1d400.usb
[    5.404743] hub 8-0:1.0: USB hub found
[    5.404782] hub 8-0:1.0: 1 port detected
[    5.405421] usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    5.405730] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    5.405739] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 9
[    5.405935] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002
[    5.405942] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.405947] usb usb9: Product: MUSB HDRC host driver
[    5.405952] usb usb9: Manufacturer: Linux 4.9.4-sun8i musb-hcd
[    5.405957] usb usb9: SerialNumber: musb-hdrc.1.auto
[    5.406511] hub 9-0:1.0: USB hub found
[    5.406574] hub 9-0:1.0: 1 port detected
[    5.409089] usb 2-1.4: New USB device found, idVendor=1c4f, idProduct=0027
[    5.409096] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    5.409102] usb 2-1.4: Product: USB Keyboard
[    5.409107] usb 2-1.4: Manufacturer: SIGMACHIP
[    5.413506] input: SIGMACHIP USB Keyboard as /devices/platform/soc/1c1b000.usb/usb2/2-1/2-1.4/2-1.4:1.0/0003:1C4F:0027.0003/input/input2
[    5.450491] of_cfs_init
[    5.450576] of_cfs_init: OK
[    5.450692] vcc3v0: disabling
[    5.450699] vcc5v0: disabling
[    5.450705] gmac-3v3: disabling
[    5.452247] Freeing unused kernel memory: 1024K (c0a00000 - c0b00000)
[    5.480281] hid-generic 0003:1C4F:0027.0003: input,hidraw2: USB HID v1.10 Keyboard [SIGMACHIP USB Keyboard] on usb-1c1b000.usb-1.4/input0
[    5.485575] input: SIGMACHIP USB Keyboard as /devices/platform/soc/1c1b000.usb/usb2/2-1/2-1.4/2-1.4:1.1/0003:1C4F:0027.0004/input/input3
[    5.550282] hid-generic 0003:1C4F:0027.0004: input,hidraw3: USB HID v1.10 Device [SIGMACHIP USB Keyboard] on usb-1c1b000.usb-1.4/input1
[    5.770000] usb 7-1: new low-speed USB device number 2 using ohci-platform
[    6.038037] usb 7-1: New USB device found, idVendor=16c0, idProduct=05dc
[    6.038048] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    6.038054] usb 7-1: Product: DG8SAQ-I2C
[    6.038060] usb 7-1: Manufacturer: www.obdev.at
[    6.038065] usb 7-1: SerialNumber: PE0FKO-0
[    6.591496] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[    6.932231] systemd[1]: System time before build time, advancing clock.
[    6.960138] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[    6.960647] systemd[1]: Detected architecture arm.
[    7.004291] systemd[1]: Set hostname to <orangepiplus2e>.
[    7.353840] systemd[1]: Listening on udev Kernel Socket.
[    7.380369] systemd[1]: Listening on Journal Socket (/dev/log).
[    7.410150] systemd[1]: Listening on fsck to fsckd communication Socket.
[    7.440179] systemd[1]: Listening on Journal Socket.
[    7.470185] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    7.500493] systemd[1]: Created slice User and Session Slice.
[    7.530761] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    7.892456] ######platform_wifi_power_on:
[    7.897729] 29
[    7.897735] 81
[    7.897737] 03
[    7.897740] CC
[    7.897742] 00
[    7.897744] 00
[    7.897746] 50
[    7.897748] 00
[    7.897750] 00
[    7.897753] 00
[    7.897754] 04
[    7.897757] CC
[    7.897758] 0A
[    7.897761] 0C
[    7.897762] 00
[    7.897764] 00
[    7.897766] FF
[    7.897769] FF
[    7.897770] FF
[    7.897773] FF
[    7.897774] FF
[    7.897777] FF
[    7.897778] FF
[    7.897781] FF
[    7.897782] FF
[    7.897785] FF
[    7.897786] FF
[    7.897789] FF
[    7.897790] FF
[    7.897793] FF
[    7.897794] FF
[    7.897796] FF
[    7.897798] FF
[    7.897800] FF
[    7.897802] FF
[    7.897805] FF
[    7.897806] FF
[    7.897808] FF
[    7.897810] FF
[    7.897812] FF
[    7.897814] FF
[    7.897816] FF
[    7.897818] FF
[    7.897820] FF
[    7.897822] FF
[    7.897824] FF
[    7.897826] FF
[    7.897828] FF
[    7.897830] FF
[    7.897832] FF
[    7.897834] FF
[    7.897836] FF
[    7.897838] FF
[    7.897840] FF
[    7.897842] FF
[    7.897844] FF
[    7.897846] FF
[    7.897848] FF
[    7.897850] FF
[    7.897852] FF
[    7.897854] FF
[    7.897856] FF
[    7.897858] FF
[    7.897860] FF
[    7.897862] FF
[    7.897864] FF
[    7.897866] FF
[    7.897868] FF
[    7.897870] FF
[    7.897872] FF
[    7.897874] FF
[    7.897876] FF
[    7.897878] FF
[    7.897880] FF
[    7.897882] FF
[    7.897884] FF
[    7.897886] FF
[    7.897888] FF
[    7.897890] FF
[    7.897892] FF
[    7.897893] FF
[    7.897896] FF
[    7.897898] FF
[    7.897900] FF
[    7.897902] FF
[    7.897904] FF
[    7.897905] FF
[    7.897908] FF
[    7.897910] FF
[    7.897912] FF
[    7.897914] FF
[    7.897916] FF
[    7.897917] FF
[    7.897920] FF
[    7.897921] FF
[    7.897924] FF
[    7.897925] FF
[    7.897928] FF
[    7.897929] FF
[    7.897932] FF
[    7.897933] FF
[    7.897936] FF
[    7.897937] FF
[    7.897940] FF
[    7.897941] FF
[    7.897944] FF
[    7.897946] FF
[    7.897948] FF
[    7.897949] FF
[    7.897952] FF
[    7.897953] FF
[    7.897956] FF
[    7.897957] FF
[    7.897960] FF
[    7.897962] FF
[    7.897964] FF
[    7.897966] FF
[    7.897968] FF
[    7.897970] FF
[    7.897972] FF
[    7.897974] FF
[    7.897976] FF
[    7.897978] FF
[    7.897980] FF
[    7.897982] FF
[    7.897984] FF
[    7.897985] FF
[    7.897988] FF
[    7.897989] FF
[    7.897992] FF
[    7.897993] FF
[    7.897996] FF
[    7.897997] FF
[    7.898000] FF
[    7.898001] FF
[    7.898004] FF
[    7.898005] FF
[    7.898008] FF
[    7.898009] FF
[    7.898012] FF
[    7.898013] FF
[    7.898015] FF
[    7.898017] FF
[    7.898019] FF
[    7.898021] FF
[    7.898023] FF
[    7.898025] FF
[    7.898028] FF
[    7.898029] FF
[    7.898031] FF
[    7.898033] FF
[    7.898035] FF
[    7.898037] FF
[    7.898040] FF
[    7.898041] FF
[    7.898043] FF
[    7.898045] FF
[    7.898047] FF
[    7.898049] FF
[    7.898051] FF
[    7.898053] FF
[    7.898055] FF
[    7.898057] FF
[    7.898059] FF
[    7.898061] FF
[    7.898063] FF
[    7.898065] FF
[    7.898067] FF
[    7.898069] FF
[    7.898071] FF
[    7.898073] FF
[    7.898075] FF
[    7.898077] FF
[    7.898079] FF
[    7.898081] FF
[    7.898083] FF
[    7.898085] FF
[    7.898087] FF
[    7.898089] FF
[    7.898091] FF
[    7.898093] FF
[    7.898095] FF
[    7.898097] FF
[    7.898099] FF
[    7.898101] FF
[    7.898103] FF
[    7.898105] FF
[    7.898107] FF
[    7.898109] FF
[    7.898111] FF
[    7.898113] FF
[    7.898115] FF
[    7.898117] FF
[    7.898119] FF
[    7.898121] FF
[    7.898123] FF
[    7.898125] FF
[    7.898127] FF
[    7.898129] FF
[    7.898131] FF
[    7.898133] FF
[    7.898135] FF
[    7.898137] FF
[    7.898139] FF
[    7.898141] FF
[    7.898143] FF
[    7.898145] FF
[    7.898147] FF
[    7.898149] FF
[    7.898151] FF
[    7.898153] FF
[    7.898155] FF
[    7.898157] FF
[    7.898159] FF
[    7.898161] FF
[    7.898163] FF
[    7.898165] FF
[    7.898167] FF
[    7.898169] FF
[    7.898171] FF
[    7.898173] FF
[    7.898175] FF
[    7.898177] FF
[    7.898179] FF
[    7.898181] FF
[    7.898183] FF
[    7.898185] FF
[    7.898187] FF
[    7.898189] FF
[    7.898191] FF
[    7.898193] FF
[    7.898195] FF
[    7.898197] FF
[    7.898199] FF
[    7.898201] FF
[    7.898203] FF
[    7.898205] FF
[    7.898207] FF
[    7.898208] FF
[    7.898211] FF
[    7.898212] FF
[    7.898215] FF
[    7.898216] FF
[    7.898219] FF
[    7.898220] FF
[    7.898223] FF
[    7.898224] FF
[    7.898227] FF
[    7.898228] FF
[    7.898231] FF
[    7.898232] FF
[    7.898235] FF
[    7.898236] FF
[    7.898238] FF
[    7.898240] FF
[    7.898242] FF
[    7.898244] FF
[    7.898246] FF
[    7.898248] FF
[    7.898250] FF
[    7.898252] FF
[    7.898254] FF
[    7.898256] FF
[    7.898258] FF
[    7.898260] FF
[    7.898262] FF
[    7.898264] FF
[    7.898266] FF
[    7.898268] FF
[    7.898270] FF
[    7.898272] FF
[    7.898274] FF
[    7.898276] FF
[    7.898278] FF
[    7.898280] FF
[    7.898282] FF
[    7.898284] FF
[    7.898286] FF
[    7.898288] FF
[    7.898290] FF
[    7.898292] FF
[    7.898295] FF
[    7.898296] FF
[    7.898298] FF
[    7.898300] FF
[    7.898302] FF
[    7.898304] FF
[    7.898306] FF
[    7.898308] FF
[    7.898310] FF
[    7.898312] FF
[    7.898315] FF
[    7.898316] FF
[    7.898318] FF
[    7.898320] FF
[    7.898322] FF
[    7.898324] FF
[    7.898326] FF
[    7.898328] FF
[    7.898330] FF
[    7.898332] FF
[    7.898334] FF
[    7.898336] FF
[    7.898338] FF
[    7.898340] FF
[    7.898342] FF
[    7.898344] FF
[    7.898346] FF
[    7.898348] FF
[    7.898350] FF
[    7.898352] FF
[    7.898354] FF
[    7.898356] FF
[    7.898358] FF
[    7.898360] FF
[    7.898362] FF
[    7.898364] FF
[    7.898366] FF
[    7.898368] FF
[    7.898370] FF
[    7.898372] FF
[    7.898374] FF
[    7.898376] FF
[    7.898378] FF
[    7.898380] FF
[    7.898382] FF
[    7.898384] FF
[    7.898386] FF
[    7.898388] FF
[    7.898390] FF
[    7.898392] FF
[    7.898394] FF
[    7.898396] FF
[    7.898398] FF
[    7.898400] FF
[    7.898402] FF
[    7.898404] FF
[    7.898406] FF
[    7.898408] FF
[    7.898410] FF
[    7.898412] FF
[    7.898414] FF
[    7.898416] FF
[    7.898418] FF
[    7.898420] FF
[    7.898422] FF
[    7.898424] FF
[    7.898426] FF
[    7.898428] FF
[    7.898430] FF
[    7.898432] FF
[    7.898434] FF
[    7.898435] FF
[    7.898438] FF
[    7.898439] FF
[    7.898442] FF
[    7.898444] FF
[    7.898446] FF
[    7.898447] FF
[    7.898450] FF
[    7.898451] FF
[    7.898454] FF
[    7.898456] FF
[    7.898458] FF
[    7.898459] FF
[    7.898462] FF
[    7.898463] FF
[    7.898465] FF
[    7.898467] FF
[    7.898470] FF
[    7.898471] FF
[    7.898474] FF
[    7.898476] FF
[    7.898478] FF
[    7.898480] FF
[    7.898482] FF
[    7.898484] FF
[    7.898486] FF
[    7.898488] FF
[    7.898490] FF
[    7.898492] FF
[    7.898494] FF
[    7.898496] FF
[    7.898498] FF
[    7.898500] FF
[    7.898502] FF
[    7.898504] FF
[    7.898506] FF
[    7.898508] FF
[    7.898510] FF
[    7.898512] FF
[    7.898514] FF
[    7.898516] FF
[    7.898518] FF
[    7.898520] FF
[    7.898522] FF
[    7.898523] FF
[    7.898526] FF
[    7.898527] FF
[    7.898530] FF
[    7.898531] FF
[    7.898534] FF
[    7.898535] FF
[    7.898538] FF
[    7.898539] FF
[    7.898542] FF
[    7.898543] FF
[    7.898546] FF
[    7.898547] FF
[    7.898550] FF
[    7.898551] FF
[    7.898554] FF
[    7.898555] FF
[    7.898557] FF
[    7.898559] FF
[    7.898561] FF
[    7.898563] FF
[    7.898565] FF
[    7.898567] FF
[    7.898569] FF
[    7.898571] FF
[    7.898573] FF
[    7.898575] FF
[    7.898577] FF
[    7.898579] FF
[    7.898582] FF
[    7.898583] FF
[    7.898585] FF
[    7.898587] FF
[    7.898589] FF
[    7.898591] FF
[    7.898593] FF
[    7.898595] FF
[    7.898597] FF
[    7.898599] FF
[    7.898601] FF
[    7.898603] FF
[    7.898605] FF
[    7.898607] FF
[    7.898609] FF
[    7.898611] FF
[    7.898613] FF
[    7.898615] FF
[    7.898617] FF
[    7.898619] FF
[    7.898621] FF
[    7.898623] FF
[    7.898625] FF
[    7.898627] FF
[    7.898629] FF
[    7.898631] FF
[    7.898633] FF
[    7.898635] FF
[    7.898637] FF
[    7.898639] FF
[    7.898641] FF
[    7.898643] FF
[    7.898645] FF
[    7.898647] FF
[    7.898649] FF
[    7.898651] FF
[    7.898653] FF
[    7.898655] FF
[    7.898657] FF
[    7.898659] FF
[    7.898661] FF
[    7.898663] FF
[    7.898665] FF
[    7.898667] FF
[    7.898669] FF
[    7.898671] FF
[    7.898673] FF
[    7.898675] FF
[    7.898677] FF
[    7.898679] FF
[    7.898681] FF
[    7.898683] FF
[    7.898685] FF
[    7.898687] FF
[    7.898689] FF
[    7.898691] FF
[    7.898693] FF
[    7.898695] FF
[    7.898697] FF
[    7.898699] FF
[    7.898701] FF
[    7.898703] FF
[    7.898705] FF
[    7.898707] FF
[    7.898709] FF
[    7.898711] FF
[    7.898713] FF
[    7.898715] FF
[    7.898717] FF
[    7.898719] FF
[    7.898721] FF
[    7.898723] FF
[    7.898725] FF
[    7.898727] FF
[    7.898729] FF
[    7.898731] FF
[    7.898733] FF
[    7.898735] FF
[    7.898737] FF
[    7.898739] FF
[    7.898741] FF
[    7.898743] FF
[    7.898745] FF
[    7.898747] FF
[    7.898749] FF
[    7.898750] FF
[    7.898753] FF
[    8.149416] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[    8.806679] Adding 131068k swap on /var/swap.  Priority:-1 extents:1 across:131068k SSFS
[    9.496855] input: r_gpio_keys as /devices/platform/r_gpio_keys/input/input4
[    9.769421] thermal thermal_zone0: failed to read out thermal zone (-16)
[    9.812628] Registered IR keymap rc-empty
[    9.812974] input: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc0/input5
[    9.812993] rc rc0: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc0
[    9.822070] sunxi-ir 1f02000.ir: initialized sunXi IR driver
[    9.826782] lirc_dev: IR Remote Control driver registered, major 245
[    9.835254] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-ir) registered at minor = 0
[    9.835264] IR LIRC bridge handler initialized
[   10.115701] systemd-journald[323]: Received request to flush runtime journal from PID 1
[   10.431436] libphy: 1c30000.ethernet: probed
[   10.448236] RTL8211E Gigabit Ethernet 1c30000.ethernet:00: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=1c30000.ethernet:00, irq=-1)
[   10.448251] sun8i-emac 1c30000.ethernet: device MAC address slot 0 02:81:39:d3:17:03
[   10.448935] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   10.896140] random: crng init done
[   13.601322] sun8i-emac 1c30000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   13.601408] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   16.366334] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   17.644459] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   18.115773] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   22.852823] fuse init (API version 7.26)
