Mac Address Assignment on Orange Zero
jerryc
Hi
Wondering if anyone knew the algorithm that assigns mac addresses to orange zero.  Is it based on something static/cpu id /...?  or it is purely random.
Will this mac change over time or after it is generated, it will stay the same?
I have one zero that mac is pretty static and another changed mac after I did a upgrade.
If I want better control of the mac address, what's the best way to make it static?
this is on the mainline
-jerry
Using latest nightly (5.27.170309) with 4.10.1 kernel on OPi PC. I'm trying to override the mac address since it changed after switching over from legacy kernel.
I followed martinayotte's post at https://forum.armbian.com/index.php?/topic/1738-opi-lite-mac-address/&do=findComment&comment=15574 and added a mac-address option to the corresponding device tree section. Unfortunately it doesn't have any effect and the value at /sys/firmware/devicetree/base/soc/ethernet@1c30000/mac-address does not seem to change.
Is this the expected behavior? If so, what would be the right way to do it?
I've looked into driver/of/of_net.c, and all those 3 keywords are supported : address/mac-address/local-mac-address.
I've tried it myself, and effectively it doesn't work.
This means that some bug has been introduced in last few months.
I will have to dig further by adding traces into a custom kernel build.
