OPi 5 + Images / Server images missing from download page
Go to solution Solved by Werner,
Depends on the branch you are on. Mainly used for RK3588 atm are legacy and edge. Latter is following mainline which will probably receive another bump once 6.8 has released and then maybe, if there is enough interesting code, bumped further to 6.9-rc.
Legacy is based on vendor bsp and occasionally people try to fix the flaws within this messy code which is then adopted and pushed via apt.
Switching branches is possible via armbian-config. Also switching to beta is possible.
Thanks Wener.
I did read the vendor bsp was a hack job.  What a shame.  They make a great SOC and then release poor and probably inefficient BSP to go with it.
I might hold off until 6.8 comes out in a month then do a clean install.
You get is what you pay for. With low price there is no money left for software development.
I don't think its worth the wait. There won't be significant improvements anymore in this version but that is up to you. You can always check the diff between the RCs and whole versions:https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/diff/?id=v6.8-rc4&id2=v6.8-rc3&dt=2
