Stephen Graf Posted February 14, 2024 Posted February 14, 2024 Yesterday I started to have problems using the build environment. Any build I have tried fails with something as shown below. (https://paste.armbian.com/noloqaquqo) Today I updated vbox, reinstalled ubuntu git cloned master and tried again with the similar results (different loopx sometimes). Any help would be greatly appreciated. 🔨] The partition table has been altered. [🔨] Syncing disks. [🌿] Allocated loop device [ LOOP=/dev/loop3 ] [🔨] Error: Partition(s) 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64 on /dev/loop3 have been written, but we have been unable to inform the kernel of the change, probably because it/they are in use. As a result, the old partition(s) will remain in use. You should reboot now before making further changes. [💥] Error 1 occurred in main shell [ at /home/sysadmin/build/lib/functions/logging/runners.sh:211 run_host_command_logged_raw() --> lib/functions/logging/runners.sh:211 run_host_command_logged() --> lib/functions/logging/runners.sh:193 prepare_partitions() --> lib/functions/image/partitioning.sh:230 do_with_logging() --> lib/functions/logging/section-logging.sh:81 build_rootfs_and_image() --> lib/functions/main/rootfs-image.sh:86 full_build_packages_rootfs_and_image() --> lib/functions/main/default-build.sh:36 do_with_default_build() --> lib/functions/main/default-build.sh:42 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:25 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:176 main() --> compile.sh:50 ] [💥] Cleaning up [ please wait for cleanups to finish ] [🌿] Unmounting recursively [ SDCARD - be patient ] [🌿] Unmounting recursively [ MOUNT - be patient ] [🚸] Freeing loop [ trap_handler_cleanup_rootfs_and_image /dev/loop3 ] [🌿] Freeing loop device [ /dev/loop3 ]
SteeMan Posted February 14, 2024 Posted February 14, 2024 I suspect this is the same issue as recently reported here:
Stephen Graf Posted February 14, 2024 Author Posted February 14, 2024 @SteeMan Yes it is. I just found it also. After reading those posts I loaded ubuntu 23.10 with kernel 6.5 and am having success creating images. Can you add my posts to the other thread? What changed a few days ago to cause this? I had been using the official ubuntu build for months without ant changes of snags.
