Hi all, special thanks to Igor for his work and all who are involved,
thank you for reading this,
  • THE MISSION:
I am trying to install Armbian 5.25 Cubietruck Ubuntu xenial onto a cubietruck v1.0-0606.
  • THE SITUATION:
My computer I am creating the SD-Card from is:
OS: Ubuntu 16.04.1 LTS x86_64
Model: 3484JBG ThinkCentre Edge72
Kernel: 4.4.0-62-generic
Uptime: 2 days, 1 hour, 11 mins
Packages: 3307
Shell: bash 4.3.46
Resolution: 1920x1080, 1920x1080
DE: KDE
WM: KWin
Theme: Breeze
Icons: Emoticonsoxygen
Terminal: konsole
Terminal Font: Monospace 14
CPU: Intel i5-3470S (4) @ 3.6GHz
GPU: Intel Ivybridge Desktop
Memory: 4199MiB / 7807Mi
First I tried to copy
Armbian_5.25_Cubietruck_Ubuntu_xenial_next_4.9.7_desktop.img
then I copied
root root 2946498560 Feb  5 12:04 Armbian_5.25_Cubietruck_Ubuntu_xenial_dev_4.10.0_desktop.img
root root 2942304256 Feb  5 02:43 Armbian_5.25_Cubietruck_Ubuntu_xenial_next_4.9.8_desktop.img
sudo dd bs=1M if=Armbian_5.25_Cubietruck_Ubuntu_xenial_dev_4.10.0_desktop.img of=/dev/sde
sync
My cardreader is a
Bus 002 Device 009: ID 058f:6362 Alcor Micro Corp. Flash Card Reader/Writer
My SD-Card is a
micro SD-Card SanDisk Ultra 16GB with an SD-Card-Adapter
  • THE OBSTACLE
The message I get is:
Then the cubitruck tries to boot from pxe.
  • THANKS
What am I doing wrong. Thank you for your input!
with kind regards
Hans
What if you use our prebuild images and other writing tool (Etcher) and some other SD card ?
Error only indicates some state of fs corruption while "Warning - bad CRC, using default environment" is normal, ask Google.
Thanks again Igor, this time for your fast reply. Etcher installed in Ubuntu didn't show the SD card. Trying to use etcher using a virtualized win7 hangs at >>starting...<<
Next approach:
change of computers. Now I am using:
 Model: 23923RG ThinkPad T530
 Uptime: 22 minutes
 Packages: 4308
 Shell: bash 4.3.46
 Resolution: 1600x900
 DE: Xfce
 WM: Xfwm4
 WM Theme: Default
 Theme: Raleigh [GTK2], Breeze [GTK3]
 Icons: Elementary-xfce-dark [GTK2], Breeze [GTK3]
 Terminal: x-terminal-emul
 CPU: Intel i5-3210M (4) @ 3.1GHz
 GPU: Intel Integrated Graphics
 GPU: NVIDIA NVS 5400M
 Memory: 3149MiB / 15772MiB
with a built in sd card reader...
It seems to work now... I'll keep you posted
Armbian_5.25_Cubietruck_Ubuntu_xenial_next_4.9.7_desktop.img works
Is there a changelog to what I am missing not using the compiled versions?
Thank you!
