herrmeier Posted February 5, 2017 Posted February 5, 2017 Hi all, special thanks to Igor for his work and all who are involved, thank you for reading this, THE MISSION:I am trying to install Armbian 5.25 Cubietruck Ubuntu xenial onto a cubietruck v1.0-0606. THE SITUATION:My computer I am creating the SD-Card from is: Quote OS: Ubuntu 16.04.1 LTS x86_64Model: 3484JBG ThinkCentre Edge72Kernel: 4.4.0-62-genericUptime: 2 days, 1 hour, 11 minsPackages: 3307Shell: bash 4.3.46Resolution: 1920x1080, 1920x1080DE: KDEWM: KWinTheme: BreezeIcons: EmoticonsoxygenTerminal: konsoleTerminal Font: Monospace 14CPU: Intel i5-3470S (4) @ 3.6GHzGPU: Intel Ivybridge DesktopMemory: 4199MiB / 7807Mi First I tried to copy Armbian_5.25_Cubietruck_Ubuntu_xenial_next_4.9.7_desktop.img then I copied root root 2946498560 Feb 5 12:04 Armbian_5.25_Cubietruck_Ubuntu_xenial_dev_4.10.0_desktop.imgroot root 2942304256 Feb 5 02:43 Armbian_5.25_Cubietruck_Ubuntu_xenial_next_4.9.8_desktop.img sudo dd bs=1M if=Armbian_5.25_Cubietruck_Ubuntu_xenial_dev_4.10.0_desktop.img of=/dev/sde sync My cardreader is a Bus 002 Device 009: ID 058f:6362 Alcor Micro Corp. Flash Card Reader/Writer My SD-Card is a micro SD-Card SanDisk Ultra 16GB with an SD-Card-Adapter THE OBSTACLEThe message I get is: *** Warning - bad CRC, using default environment Then the cubitruck tries to boot from pxe. THANKS What am I doing wrong. Thank you for your input! with kind regards Hans
Igor Posted February 5, 2017 Posted February 5, 2017 What if you use our prebuild images and other writing tool (Etcher) and some other SD card ?Error only indicates some state of fs corruption while "Warning - bad CRC, using default environment" is normal, ask Google.
herrmeier Posted February 5, 2017 Author Posted February 5, 2017 Thanks again Igor, this time for your fast reply. Etcher installed in Ubuntu didn't show the SD card. Trying to use etcher using a virtualized win7 hangs at >>starting...<< Next approach: change of computers. Now I am using: ---------- OS: Ubuntu 16.04.1 LTS x86_64 Model: 23923RG ThinkPad T530 Kernel: 4.4.0-62-generic Uptime: 22 minutes Packages: 4308 Shell: bash 4.3.46 Resolution: 1600x900 DE: Xfce WM: Xfwm4 WM Theme: Default Theme: Raleigh [GTK2], Breeze [GTK3] Icons: Elementary-xfce-dark [GTK2], Breeze [GTK3] Terminal: x-terminal-emul CPU: Intel i5-3210M (4) @ 3.1GHz GPU: Intel Integrated Graphics GPU: NVIDIA NVS 5400M Memory: 3149MiB / 15772MiB with a built in sd card reader... It seems to work now... I'll keep you posted Armbian_5.25_Cubietruck_Ubuntu_xenial_next_4.9.7_desktop.img works Is there a changelog to what I am missing not using the compiled versions? Thank you!
Igor Posted February 5, 2017 Posted February 5, 2017 I have no idea what you did wrong at self compiled - most likely you failed at writing stage. For diagnosing the problem, you need to provide build logs and you need to do more tests, not just one. What hardware you have is pretty much irrelevant - just follow the guideline: https://github.com/igorpecovnik/lib#how-to-build-my-own-image-or-kernel
