Macsaba Posted February 5, 2017 Posted February 5, 2017 After the latest kernel update I don't have wired connection on my Orange pi+2. I have a fix IP address and it worked well until the update. ping -c 100 8.8.8.8 shows 100 % packet loss What cause the problem?
Igor Posted February 5, 2017 Posted February 5, 2017 Can you provide your network configuration, possible boot logs too.
Monino Posted February 5, 2017 Posted February 5, 2017 After the kernel update the mac address of eth0 changed , i deleted the arp entry at my router and works fine. 1
Monino Posted February 5, 2017 Posted February 5, 2017 After the latest kernel update I don't have wired connection on my Orange pi+2. I have a fix IP address and it worked well until the update. ping -c 100 8.8.8.8 shows 100 % packet loss What cause the problem? Try to apply the WA 1
Monino Posted February 5, 2017 Posted February 5, 2017 That was my problem too. Thank you! Can you provide your network configuration, possible boot logs too. Logs and config ok, solved with my WA, thx for the support. PD: i need the kernel 4.9 for pi2plus to run Dockeeeeeeeeeeer (Kernel > 3.10) !
Igor Posted February 5, 2017 Posted February 5, 2017 PD: i need the kernel 4.9 for pi2plus to run Dockeeeeeeeeeeer (Kernel > 3.10) ! Soon. It's around the corner
