Orange PI 5 (b & +) , RK3588(s) USB thread
Go to solution Solved by Gullik,
A fall backwards,
both 24.5.0-trunk.409 Noble and 24.5.0-trunk.410 Noble and trunk.411
seem to be missing:
[    6.828040] panthor fb000000.gpu: [drm] *ERROR* Failed to load firmware image 'mali_csffw.bin'
a find / does not find it, so it seems to be missing from packaging....
I m trying to find it ....
G
24 minutes ago, Gullik said:
A fall backwards,
seem to be missing:
Install armbian-firmware-full
Yes, I did and that fixed the problem initially. However, now I do not get that message but .411 gives a black screen.
The system boot but needs a serial line to set up, else no cigar.
G
My  final comment in this thread (unless something USB related comes up)
USB works fine for me, and I have tested it with hub's and my own usb-device design.
Also, kernels are now at 6.8.5 build.417, and boot just fine.
Regards,
Gullik
I am running current rolling release Armbian trixie minimal with build.416 and USB is not working for me, also no the USB 2.0 ones. Was working with manjraro for OPI5+.
Never mind, used the non plus image for the plus. The Armbian page for the orange pi 5 kind of makes you think that it also works for the plus, where there is a different image if you search through all the available arm images. Very confusing.
