Hi all,
today I tried ubuntu xenial (dev) with kernel 4.9.4 for OrangePi Plus2.
seems to work fine, but the screen resolution is 3840x2160. That is cool but a smaller resulution would be better.
I tryed to change the screen settings over Settings -> Display, but it is not possible to change the values there.
I also tried it with: sudo h3disp, but it is not installed on my system.
What is the best way to change the screen res?
Hi!
I don´t get it done. I can´t reduce the resulution.
I modified the /boot/boot.cmd and added the line:
# default values
setenv load_addr "0x44000000"
setenv rootdev "/dev/mmcblk0p1"
setenv verbosity "1"
setenv console "both"
setenv disp_mem_reserves "off"
setenv disp_mode "1920x1080p60"
setenv video-mode sunxi:1920x1080-24@60,monitor=hdmi,hpd=0,edid=0
setenv rootfstype "ext4"
Then:
$ mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr
and reboot
But the resulution is still 3840x2160
What am I doing wrong?
saveenv
You need to save uboot environment and it will manifest at second reboot. First saves, second make action. U-boot must have those parameters before reading boot script ...
