fabiobassa Posted Saturday at 11:28 AM Posted Saturday at 11:28 AM @Lucas Gomes you should force it go in maskrom ( if no phisical damage occurred) finding the appropriate pins on the board 0 Quote
cheaplinuxbox Posted Saturday at 11:22 PM Posted Saturday at 11:22 PM Hi there, just created an account to say thanks ! I randomly bought a clearance media player on tuesday thinking "there must be something I can do with this and need a project" https://www.jaycar.co.nz/4k-android-media-player/p/XC6012 A bit of DuckDuckgoing later and found this forum, and well, it's all been done! Good work guys, this device has nand flash and rk3228a so after a few nand reflashes and general messing about etc I decided to flash the latest image to SD card and well, it runs really well. As previously noted this board has horrible thermal design so active cooling is basically mandatory - anyone experiencing "freezes" or crashes during system updates, note the board temp, it heats rapidly and appears to thermal shutdown at around 80 degrees C. Have since added a USB wifi dongle which works fine as the onboard wifi isn't driver compat (as previously noted) So this board appears to have comparable performance to a Raspberry Pi 2b, so as long as you temper your expectations this is a fun system to mess around with. Thanks ! 1 Quote
Koishi 1108 Posted Sunday at 02:21 AM Posted Sunday at 02:21 AM Hi everyone, I hope you're all doing well. A couple of days ago, I got interested in installing Linux on one of these Chinese TV boxes to use it with a 3D printer. I've been trying to follow the tutorial step by step, but I'm having a problem. The box boots into Multitool correctly, and at first, it let me burn the image to the flash, but it didn't work. Now I'm trying again, but it's giving me an error saying there is no eMMC. I'm not sure what’s going on — could someone please help me? Thanks in advance! 0 Quote
cheaplinuxbox Posted Sunday at 03:03 AM Posted Sunday at 03:03 AM Hi again, one quick question -- I previously made the mistake of running apt upgrade of the system packages and had installed armbian-configNG over the included armbian-config, so I basically nuked the SD card and reinstalled the image to roll back to the old config. This likely has been covered, but is there a way to reinstall armbian-config or is this a known issue and "DON'T UPGRADE" ? Cheers! 0 Quote
Benedito Portela Posted 18 hours ago Posted 18 hours ago Hi everyone, i bought a MX10 tvbox, to try my system in H313 box, but the box came in is a RK3228A, so i try install my system, that working well in others rk3229 boxes, i did it how normal protocol, boot from multitools card, did it Android image backup and burned my OK image, turner off, and don't working, black screen e red led on! Do not boot from other sdcards and multiools sdcard too! I do not found the Maskrom pin, i believe to be a new board design, if anybody know this board, i do glad by help-me! Thanks!!! 0 Quote
Orcus Posted 14 hours ago Posted 14 hours ago (edited) Hi there. Maybe I'm doing something wrong, but how do I get WIFi to work on a board with an ESP8089 module? The first message says that this module is supported. Based on the answers from the respected @jock , this module is also supported. Maybe someone will help and give a clear answer or an algorithm for launching. I tried 2 images - the current and Armbian_24.2.5.-trunk_Rk322x-box_jammy_current_6.6.22_minimal.img.xz Edited 13 hours ago by Orcus 0 Quote
RaptorSDS Posted 11 hours ago Posted 11 hours ago vor 2 Stunden schrieb Orcus: get WIFi to work on a board with an ESP8089 please tell us do have try setup LED-config in rk322x-config tool 0 Quote
RaptorSDS Posted 11 hours ago Posted 11 hours ago @Benedito Portela be aware this looks like a eMCP (emmc and RAM in one chip) , do you try running from a usb drive 0 Quote
Benedito Portela Posted 6 hours ago Posted 6 hours ago @RaptorSDS, it is a eMCP (kmqn10006m-b318), in others board, that use same type chip, working no problems, in this board, do not working nothing, it is lock, red led turn on! Before use the multitools, the board do not boot from my system in sdcard, it is not a good indicator and even so i did the burning image in board, It was stupid of me! I hope find the maskrom pin, it is a new board, do not believe that i lost it! Thank by attention! 0 Quote
fabiobassa Posted 2 hours ago Posted 2 hours ago @Benedito Portela you are a long term user on this forum to don't know that debugging is a MUST !!!!!!! And you have such WONDERFULL uart pads, even with names ( tx rx gnd) ... why don't you use them and let all of us know what going in your box ??😇 😉 0 Quote
Orcus Posted 2 hours ago Posted 2 hours ago 8 часов назад, RaptorSDS сказал: please tell us do have try setup LED-config in rk322x-config tool I forgot to specify that I tried different combinations in the config. With any of these configurations in this tool after each restart the Wi-Fi module is not recognized. All the time is written - unknown 0 Quote
