fabiobassa Posted June 21, 2025 Posted June 21, 2025 @Lucas Gomes you should force it go in maskrom ( if no phisical damage occurred) finding the appropriate pins on the board 0 Quote
cheaplinuxbox Posted June 21, 2025 Posted June 21, 2025 Hi there, just created an account to say thanks ! I randomly bought a clearance media player on tuesday thinking "there must be something I can do with this and need a project" https://www.jaycar.co.nz/4k-android-media-player/p/XC6012 A bit of DuckDuckgoing later and found this forum, and well, it's all been done! Good work guys, this device has nand flash and rk3228a so after a few nand reflashes and general messing about etc I decided to flash the latest image to SD card and well, it runs really well. As previously noted this board has horrible thermal design so active cooling is basically mandatory - anyone experiencing "freezes" or crashes during system updates, note the board temp, it heats rapidly and appears to thermal shutdown at around 80 degrees C. Have since added a USB wifi dongle which works fine as the onboard wifi isn't driver compat (as previously noted) So this board appears to have comparable performance to a Raspberry Pi 2b, so as long as you temper your expectations this is a fun system to mess around with. Thanks ! 1 Quote
Koishi 1108 Posted June 22, 2025 Posted June 22, 2025 Hi everyone, I hope you're all doing well. A couple of days ago, I got interested in installing Linux on one of these Chinese TV boxes to use it with a 3D printer. I've been trying to follow the tutorial step by step, but I'm having a problem. The box boots into Multitool correctly, and at first, it let me burn the image to the flash, but it didn't work. Now I'm trying again, but it's giving me an error saying there is no eMMC. I'm not sure what’s going on — could someone please help me? Thanks in advance! 0 Quote
cheaplinuxbox Posted June 22, 2025 Posted June 22, 2025 Hi again, one quick question -- I previously made the mistake of running apt upgrade of the system packages and had installed armbian-configNG over the included armbian-config, so I basically nuked the SD card and reinstalled the image to roll back to the old config. This likely has been covered, but is there a way to reinstall armbian-config or is this a known issue and "DON'T UPGRADE" ? Cheers! 0 Quote
Benedito Portela Posted June 25, 2025 Posted June 25, 2025 Hi everyone, i bought a MX10 tvbox, to try my system in H313 box, but the box came in is a RK3228A, so i try install my system, that working well in others rk3229 boxes, i did it how normal protocol, boot from multitools card, did it Android image backup and burned my OK image, turner off, and don't working, black screen e red led on! Do not boot from other sdcards and multiools sdcard too! I do not found the Maskrom pin, i believe to be a new board design, if anybody know this board, i do glad by help-me! Thanks!!! 0 Quote
Orcus Posted June 25, 2025 Posted June 25, 2025 (edited) Hi there. Maybe I'm doing something wrong, but how do I get WIFi to work on a board with an ESP8089 module? The first message says that this module is supported. Based on the answers from the respected @jock , this module is also supported. Maybe someone will help and give a clear answer or an algorithm for launching. I tried 2 images - the current and Armbian_24.2.5.-trunk_Rk322x-box_jammy_current_6.6.22_minimal.img.xz Edited June 25, 2025 by Orcus 0 Quote
RaptorSDS Posted June 25, 2025 Posted June 25, 2025 vor 2 Stunden schrieb Orcus: get WIFi to work on a board with an ESP8089 please tell us do have try setup LED-config in rk322x-config tool 0 Quote
RaptorSDS Posted June 25, 2025 Posted June 25, 2025 @Benedito Portela be aware this looks like a eMCP (emmc and RAM in one chip) , do you try running from a usb drive 0 Quote
Benedito Portela Posted June 26, 2025 Posted June 26, 2025 @RaptorSDS, it is a eMCP (kmqn10006m-b318), in others board, that use same type chip, working no problems, in this board, do not working nothing, it is lock, red led turn on! Before use the multitools, the board do not boot from my system in sdcard, it is not a good indicator and even so i did the burning image in board, It was stupid of me! I hope find the maskrom pin, it is a new board, do not believe that i lost it! Thank by attention! 0 Quote
fabiobassa Posted June 26, 2025 Posted June 26, 2025 @Benedito Portela you are a long term user on this forum to don't know that debugging is a MUST !!!!!!! And you have such WONDERFULL uart pads, even with names ( tx rx gnd) ... why don't you use them and let all of us know what going in your box ??😇 😉 0 Quote
Orcus Posted June 26, 2025 Posted June 26, 2025 8 часов назад, RaptorSDS сказал: please tell us do have try setup LED-config in rk322x-config tool I forgot to specify that I tried different combinations in the config. With any of these configurations in this tool after each restart the Wi-Fi module is not recognized. All the time is written - unknown 0 Quote
Orcus Posted June 26, 2025 Posted June 26, 2025 (edited) 15 часов назад, RaptorSDS сказал: please tell us do have try setup LED-config in rk322x-config tool damn, it looks like I screwed up the WiFi chip model Actually I have p9012s in my box. And if I understand correctly, there are no drivers for it and it won't work. I had a USB WiFi adapter on a Ralink MT7601U chip. It worked in this box right away. P.S. I still don't understand why I assumed that I have an esp8089 chip. Since I have two such TV boxes, I even disassembled the second one to check - but it also has a c9012p chip. A mystery to me) ___ By the way, the other day after an unsuccessful Armbian firmware update I almost got a brick. If earlier I was able to restore it using a PC and a USB-A - USB-A cable, this time the PC didn't even see this box. Maybe this will be useful to someone. I revived it by switching to mask mode by shorting contacts on emmc. launched RK Batch Tool 1.8 and specified the path to the stock firmware (don't forget about the drivers) completely disconnected the power supply to the box shorted contacts 29 and 30 to each other connected the box to the PC. The program immediately recognized it. All that was left was to flash it My box specifications: Rockchip RK3228A (Aida64 for some reason says that it is 3229), 2/16gb, WiFi S9012P. Board: MXQ_RK3229_V2.0 2019.07.2022 Скрытый текст Edited June 26, 2025 by Orcus 1 Quote
Benedito Portela Posted June 26, 2025 Posted June 26, 2025 Hi @fabiobassa, Until recently, I thought that the TTY serial port and the SSH terminal were the same thing, just the different forms of communication! I learned how to use SSH here, it helped me a lot with remote access, which I didn't know about. A few days ago I was even trying to find out how the serial port works, even though I don't have the TTY USB adapter, I have Arduino boards here, Nano and Uno, could I use them as an adapter? Could you give a brief explanation of how it works? I'll try to do it, because just as SSH was very useful, I believe that this communication via the TTY port is more important for diagnostics! I'm grateful for the dedication of all of you who maintain this forum, thank you very much! P.S.: I'm using the oscilloscope, and I can't find the memory clock pin that enables markrom mode, and I didn't see a signal on the serial port! 0 Quote
Benedito Portela Posted July 5, 2025 Posted July 5, 2025 I get it: DDR Version V1.10 20190926 In ID:0xFFF 330MHz LPDDR3 Bus Width=32 Col=10 Bank=8 Row=15 CS=2 Die Bus-Width=32 Size=2048MB mach:14 rd addr 0xC0000000 = 0xFFED ERR 0 Quote
comose Posted July 6, 2025 Posted July 6, 2025 Hello djmuted. I'm a german beginner. I have a Box Labeld Greva 8k Android 13 4G DDR3 / 64G emmc and CPU RK3528 from Amazon.de. She have an WiFi Chip EA6521QT . You have Compile it for 32bit Cpu RK322x . I need compile this driver for 64bit . It this possible? I have no idea how to compile it. Can you show me a way how I can compile it? I have Flashed armbian from this Site : https://github.com/fensoft/dq08-haos/blob/master/README.md and running HAOS & Gnome for Touchscreen . Works perfekt without Wifi. The power consumption 2.5W ( for Home Assistent Server Wonderfull) the Version is 5.10.160-legacy-rk3528-tvbox. Thanks 0 Quote
RaptorSDS Posted July 6, 2025 Posted July 6, 2025 vor 3 Stunden schrieb comose: m a german beginner. I have a Box Labeld Greva 8k Android 13 4G DDR3 / 64G emmc and CPU RK3528 from Amazon.de. She have an WiFi Chip EA6521QT . You have Compile it for 32bit Cpu RK322x dear Comose your are in the wrong topic this is not about rk3528 , please look at armbian forum for right please of rk3528 hallo Comose du bist hier am falschen ort , dies hier ist über rk322x board und nicht rk3528 , biite schaue in den anderen Bereichen nach rk35xx (Rk3518 / Rk3528) 0 Quote
Benedito Portela Posted July 6, 2025 Posted July 6, 2025 Hi friends, I have good news, I found the Maskrom pin and managed to solve the problem with my MX10 box! By grounding the pin at boot time, it was able to boot from the sdcard and I used Multitools to burn a minimal Armbian image, after that it worked! My modified system, that uses the legacy kernel, only works the boot from sdcard, I tested it by burning the image and using the armbian-install command and it doesn't work! Even in maskrom mode the rkdeveloptool commands didn't work! These emcp memories are complicated, and this is 1.5Gb RAM and 8Gb of storage! 0 Quote
RaptorSDS Posted July 7, 2025 Posted July 7, 2025 vor 6 Stunden schrieb Benedito Portela: found the Maskrom pin and managed to solve the problem with my MX10 box! 🤩🤪 super , thanks for the information 0 Quote
stanelie Posted July 7, 2025 Posted July 7, 2025 Hi @Benedito Portela. I managed to get a original firmware dump of my MX10 unit with rkdumper before hosing it like you did. I am currently working to restore mine. Would that firmware dump be of interest? If so, where do I upload it? Is there a page somewhere where we could compile all the data we find about those MX10 units? Thanks! 0 Quote
stanelie Posted July 7, 2025 Posted July 7, 2025 @Benedito Portela Thanks for finding the maskrom pin, my device is now successfully in maskrom mode, ready for recovery. However, I fail to go any further. With the rkdevtool, I tried to flash back the original firmware, so I can restart from there, but after it says Test device start, I get a test device fail message : Do you have any tips? Thanks! 0 Quote
stanelie Posted July 7, 2025 Posted July 7, 2025 (edited) @Benedito Portela Thanks!! You saved my ass, I was able to install Armbian even if I was not able to restore the original firmware. I used the SD card method with the multitool : Edited July 7, 2025 by stanelie add info link 0 Quote
Benedito Portela Posted July 7, 2025 Posted July 7, 2025 Hi @stanelie, I so very happy because you can restored your box, I was only able to read the messages now, I'm just a curious, but I'm available to help! 0 Quote
remlei Posted July 9, 2025 Posted July 9, 2025 On 7/7/2025 at 11:39 PM, stanelie said: I fail to go any further. With the rkdevtool, I tried to flash back the original firmware, so I can restart from there, but after it says Test device start, I get a test device fail message : This is nothing new, its Windows related issue. Probably had something with the drivers. But ultimately I just use a older windows version, I had a machine running a Windows 10 1809 LTSC and for some reason it works there. One thing that also works is using a ubuntu live CD and using the upgrade_tool for rockchip. 0 Quote
stanelie Posted July 11, 2025 Posted July 11, 2025 @remlei I've tried several different versions of rkdevtool, and I also tried under linux with rkflashtool and with the official rockchip flash tool, it all failed. @Benedito Portela Are you able to flash the original loader back? If so, which file do you use? My rkdumper dump does not seem to have the loader included. 0 Quote
k405 Posted July 13, 2025 Posted July 13, 2025 Good evening, I managed to complete the installation of my R29 without any problems, but it simply isn't recognized by my gigabit router. It works on my other secondary router, but I need it on my main one. I can also connect directly through my Ethernet notebook. I saw that it could be a problem with the router not accepting 10 Mbps, but ethtool says the TV Box is working at 100 Mbps. I don't know what else to try. 0 Quote
stanelie Posted July 13, 2025 Posted July 13, 2025 I have the same issue with my tv box (RK3228A, the same one @Benedito Portela uses, only wireless lan works, the wired ethernet port does not work. It is present, the kernel sees the interface (end0), it detects the cable being plugged in, it even requests an IP address from DHCP, but it never takes it. I've tried to force it with a static IP, but I get no connectivity with that. 0 Quote
Benedito Portela Posted July 13, 2025 Posted July 13, 2025 Hi @stanelie, after I found the Maskrom pin and did the recovery with Multitools, I didn't test it via USB using rkdeveloptools anymore, so I didn't load the bootloader, nor did I try to restore the Android image I had backed up before! On the other ones I have, when I used rkdeveloptools, I used the rk322x_loader_v1.10.238_256.bin that's on the first page with the instructions to recover the boot! @k405, as for the network, it's working normally here, but my router is a bit old, isn't there an option on the router to configure a port for 100mbs speed? 0 Quote
stanelie Posted July 13, 2025 Posted July 13, 2025 My switch correctly negotiates a 100mbps speed, and I also tried forcing it to 100mbps. In both cases, it links (LED on the switch is on and info from the switch says it is correctly negotiates 100mbps), and I see the TV box send a request for DHCP, and I see the answer from my DHCP server, but it stops there, I get no IP assigned in my interface. Setting a static IP on the interface also fails. I think I will start a new thread about this issue to better track this bug. 0 Quote
k405 Posted July 14, 2025 Posted July 14, 2025 @Benedito Portela thanks for reply I have another gigabit router that works, but It doesnt have Fiber optics and tnelefone. Idk If this is useful. I contacted my provider because they don't offer access to the router. They said all ports are on automatic and it only works at 100/1000 Mbps. I've tried everything, even changing the TV Box's speed negotiation, but it doesn't support it. The only way that works is to put a device between it and the main router. 0 Quote
lebestnoob Posted July 31, 2025 Posted July 31, 2025 I've started using an MXQ-4K box as a file server, but writing files over the network is slow, with speeds in the 3-5 MB/s range. Reads cap out at the fast ethernet link speed (~11 MB/s). I don't believe there's a CPU, disc, or RAM bottleneck as the speeds are the same regardless of file size or transfer protocol as SMB, FTP, and WebDAV all give me the same speeds, and checking in htop, they are never at 100%. These speeds are also observed when downloading a file from another device on the local network using wget or aria2 while sshed into it, with faster speeds on other devices. As far as I can tell, iostat doesn't suggest high io wait times are the culprit. If it matters, I'm writing to an external USB HDD, but the write speeds are the same when writing to the SD card through the network, which makes me believe this is not an issue. If I write a ~1.0GB file using dd to the HDD while sshed into it with `dd if=/dev/random of=/mnt/disk/tmp.bin bs=64k count=16500 conv=fdatasync`, it gives a local disk speed of ~20 MB/s, which is more than enough to saturate the 100 mbps link. Has anyone else experienced similar results? Are the slow network speeds just a limitation of the onboard nic/hardware? I'm open to suggestions. 0 Quote
