ua3nbw Posted February 8, 2017 Posted February 8, 2017 Hi there # uname -a Linux orangepipc 3.4.113-sun8i #28 SMP PREEMPT Thu Feb 2 02:01:28 CET 2017 armv7l GNU/Linux #apt-get install pciutils-dev pkg-config #git clone https://github.com/flashrom/flashrom.git #cd flashrom#make CONFIG_INTERNAL=no CONFIG_RAYER_SPI=no CONFIG_NIC3COM=no CONFIG_GFXNVIDIA=no CONFIG_SATASII=no \CONFIG_ATAHPT=no CONFIG_DRKAISER=no CONFIG_NICREALTEK=no CONFIG_NICNATSEMI=no \CONFIG_NICINTEL=no CONFIG_NICINTEL_SPI=no CONFIG_OGP_SPI=no CONFIG_SATAMV=no No work! hooked: spi_mosi = port:PC00spi_miso = port:PC01spi_sclk = port:PC02spi_cs0 = port:PC03 root@orangepipc:~/flashrom# ./flashrom -p linux_spi:dev=/dev/spidev0.0flashrom v0.9.9-unknown on Linux 3.4.113-sun8i (armv7l)flashrom is free software, get the source code at https://flashrom.org Calibrating delay loop... OK.No EEPROM/flash device found.Note: flashrom can never write if the flash chip isn't found automatically.root@orangepipc:~/flashrom# Who runs the program respond. Thank you
ua3nbw Posted February 9, 2017 Author Posted February 9, 2017 No work. where is me mistake ? http://www.orangepi.org/orangepibbscn/forum.php?mod=viewthread&tid=326
martinayotte Posted February 9, 2017 Posted February 9, 2017 Could be several possibilities : - check your wiring again. - check if the Flash chip part number/manufacturer is in the list of flashrom/flashchips.h - provide us the log output of the execution to see what JEDEC ID is reported.
