[Share] OrangePiZero OpenWrt Chaos Calmer 15.05.1
Pulpstone OrangePiZero
Orange Pi Zero Hardware specification
CPU H2 Quad-core Cortex-A7 H.265/HEVC 1080P.
GPU Mali400MP2 GPU @600MHz
Memory 512MB DDR3
TF card (Max. 64GB)/ NOR Flash(2MB Default not posted)
10/100M Ethernet
WIFI XR819, IEEE 802.11 b/g/n
[http://www.orangepi.org/orangepizero/]
Added :
All Modem Packages
Support 4G Modem
Support HiLink Modem
Support USB Tethering Android
Support SFTP Server
Pulpstone Mikodemos v5 (fix restart OpenVPN)
Pulpstone MJPG Streamer (gigi webcam-uvc)
Pulpstone Tramsmission
Pulpstone miniDLNA
LuCI-App-SQM
LuCI-App-Access-Control
LuCI-App-HD-Idle
LuCI-Theme-DarkMatter
3G/4G Info by eko.one.pl
Samba Network Shares (NTFS/EXT4)
MPD (soundcard internal + fix volume button n sound)
ping_loop v3 Mikodemos - Design by Andriawan
Simple Network Interface Profile
Fix Bridging Lan and Wireless
Support USB WiFi  (Atheros, Ralink)
Basic Information :
LAN = LAN
LuCI '192.168.1'
Username/Password 'root / root'
SSID Wifi 'OrangePiZero'
SSID Password 'internet'
Default Modem Device '/dev/tty/USB0'
Service Type 'UMTS Only'
APN 'internet'
3G/4G Info '192.168.1.1:81'
ping_loop GUI '192.168.1.1/cgi-bin/pingloop'
Pulpstone Mikodemos v5 '192.168.1.1/pulpstone'
Pulpstone MJPG Streamer '192.168.1.1:8291' **
Pulpstone Tramsmission '192.168.1.1:9091' **
**username/password = pulpstone/pulpstone
How to flash OpenWrt to MicroSD card
On a Linux desktop and Windows desktop
insert your MicroSD
Extract file
use Etcher software to write the img file to your MicroSD card's. [https://etcher.io/#downloads]
Regrads,
FuadSalim
[ https://www.facebook.com/fuad.salim.drg ]
download : http://pulpstone.pw/
  On 2/22/2017 at 8:21 AM, renaudrenaud said:
Wha! So impressive! Gonna try it immediately (err, after 4 hours of download if everything is ok).
Thank you.
Four hours later: it is working. Crazy!
update img :)
Posted (edited)
Memory 512MB DDR3
10/100M Ethernet
Added :
All Modem Packages
Support 4G Modem
Support SFTP Server
Pulpstone miniDLNA
LuCI-App-SQM
LuCI-App-HD-Idle
Support USB WiFi
Basic Information :
LAN = LAN
LuCI '192.168.1'
APN 'internet'
insert your MicroSD
Extract image
Regrads,
FuadSalim [https://www.facebook.com/fuad.salim.drg]
Edited by tkaiser
Moved here from wrong thread
  On 2/22/2017 at 3:34 PM, Fuad Salim said:
update img :)
You should really update the image if you're still using kernel 3.4.113. Crazy, there are a couple of OpenWRT images flying around that are all based on legacy kernel (most probably without integrating Armbian's kernel update mechanism?) where Wi-Fi driver reveiced none of these fixes.
Memory 512MB DDR3
10/100M Ethernet
Added :
All Modem Packages
Support 4G Modem
Support SFTP Server
Pulpstone miniDLNA
LuCI-App-SQM
LuCI-App-HD-Idle
Basic Information :
LAN = LAN
LuCI '192.168.1'
APN 'internet'
insert your MicroSD
Extract file
Regrads,
FuadSalim
running flawlessly-smooth.. .  :)  Great thanks.. .
is there any openwrt/lede-pulpstone images for Orange Pi PC Plus??
If it is like other OpenWrt, there should be accessible using sysfs, ie : /sys/class/gpio, doing such commands :
echo 20 > /sys/class/gpio/export
echo out > /sys/class/gpio20/direction
echo 1 > /sys/class/gpio20/value
HI!
I tried to connect a USB-Lan adapter asix ax88179 to OrangePi Zero (OpenWrt Pulpstone v3.1 OrangePiZero r01062017). But unfortunately I couldn't make the driver by manual - https://github.com/FreddyXin/ax88179_178a. Can you help me with this? I will be most grateful if you make this driver for this kernel or tell me how to do it.
Link to drivers sourse -http://www.asix.com.tw/products.php?op=pItemdetail&PItemID=131;71;112
I'm playing with this image and i'm very pleased, it does seems to work flawless a part a couple of issues:
1. I've tryed to install the kmod-leds-netdev the packages, It seems to install fine but doesn't seems to be avilable in luci
2. Softether vpn is missing from the packages, i've managed to build one (avilable here Softether vpn Sunxi 4.21) it seems to be working a part that during vpncmd "test" fails network but is quite common with openwrt)
3. All the canbus stuff is missing, i would really love to have the canbus packages compiled (MCP trough SPI interface) and all the canbus kernel modules are missing (slcan raw mcp etc)
A part from this minor issues great work guys !
Cool now bas canbus stuff is avilable trough opkg install , can somebody help with the MCP spi canbus driver ? Would be really great.
I've tryed to put manually netdev in the config file but still it doesn't work.
