UDOO Latest images (next + default) fail to boot after custom kernel
Hey All -
So I decided to upgrade my Udoo from 4.5 (Debian Jessia, kernel 3.14.28) to the latest 5.25 Xenial.
I gave next (4.4.46) a try, and it seemed to work awesome, however it seems like no one wants 1wire (still - it only takes up 1 gpio!).
I built custom kernels enabling 1wire in the kernel and updated (or for default adding) 1wire to be enabiled in the imx6qdl-udoo.dtsi, however after I install the kernels, it just sits indefinitely at the red Armbian logo on boot.
On 4.4.46, i was able to just install all the debs via dpkg -i *.deb
On 3.14.56, I had to use dpkg --force-all -i *.deb
Any ideas on what I'm doing wrong?  Its been a while, so I'm sure a bunch has changed, but adding 1wire in the kernel shouldn't cause a freeze
Strange, upgrade / kernel install should work this way. Can you catch boot log via serial console, that we can see more?
So one thing I noticed is that armbian's udoo kernel configs (both default & next) are pretty different than from both default & next in respective git repos (patrykk's has all the 1wire stuff as modules, with 1wire as disabled, but you can just rebuild the dtb file) - shouldn't be an issue since I assume you build with the configs in your repo vs theirs..  Below are the my kernel diffs vs armbian, install, and boot log.  I just edited imx6qdl-udoo.dtsi and changed "disabled" to "okay" during kernel config & made the mods - don't think that should cause the boot to break
Kernel diffs:
$ diff armbian_default/linux-udoo-next.config linux-udoo-next.config
3c3
< # Linux/arm 4.4.6 Kernel Configuration
> # Linux/arm 4.4.0 Kernel Configuration
2055c2055,2082
< # CONFIG_W1 is not set
> CONFIG_W1=y
> CONFIG_W1_CON=y
> # 1-wire Bus Masters
> # CONFIG_W1_MASTER_DS2490 is not set
> # CONFIG_W1_MASTER_DS2482 is not set
> CONFIG_W1_MASTER_MXC=y
> # CONFIG_W1_MASTER_DS1WM is not set
> CONFIG_W1_MASTER_GPIO=y
> # 1-wire Slaves
> CONFIG_W1_SLAVE_THERM=y
> # CONFIG_W1_SLAVE_SMEM is not set
> # CONFIG_W1_SLAVE_DS2408 is not set
> # CONFIG_W1_SLAVE_DS2413 is not set
> # CONFIG_W1_SLAVE_DS2406 is not set
> # CONFIG_W1_SLAVE_DS2423 is not set
> # CONFIG_W1_SLAVE_DS2431 is not set
> # CONFIG_W1_SLAVE_DS2433 is not set
> # CONFIG_W1_SLAVE_DS2760 is not set
> # CONFIG_W1_SLAVE_DS2780 is not set
> # CONFIG_W1_SLAVE_DS2781 is not set
> # CONFIG_W1_SLAVE_DS28E04 is not set
> # CONFIG_W1_SLAVE_BQ27000 is not set
4175a4203
> # CONFIG_DEBUG_UART_BCM63XX is not set
Update:
root@udoo:~/kupdate# ls -la
total 17072
drwxr-xr-x 2 root root    4096 Feb 11 23:28 .
drwx------ 7 root root    4096 Feb 11 23:28 ..
-rwxr--r-- 1 root root   50196 Feb 11 06:11 linux-firmware-image-4.4.0-udoo_5.25_armhf.deb
-rwxr--r-- 1 root root 7188908 Feb 11 06:11 linux-headers-4.4.0-udoo_5.25_armhf.deb
-rwxr--r-- 1 root root 9289516 Feb 11 06:12 linux-image-4.4.0-udoo_5.25_armhf.deb
-rwxr--r-- 1 root root  799462 Feb 11 06:11 linux-libc-dev_5.25_armhf.deb
-rwxr--r-- 1 root root  135072 Feb 11 06:03 linux-u-boot-next-udoo_5.25_armhf.deb
root@udoo:~/kupdate# dpkg -i *.deb
Selecting previously unselected package linux-firmware-image-4.4.0-udoo.
(Reading database ... 140089 files and directories currently installed.)
Preparing to unpack linux-firmware-image-4.4.0-udoo_5.25_armhf.deb ...
Unpacking linux-firmware-image-4.4.0-udoo (5.25) ...
Selecting previously unselected package linux-headers-4.4.0-udoo.
Preparing to unpack linux-headers-4.4.0-udoo_5.25_armhf.deb ...
Unpacking linux-headers-4.4.0-udoo (5.25) ...
Selecting previously unselected package linux-image-4.4.0-udoo.
Preparing to unpack linux-image-4.4.0-udoo_5.25_armhf.deb ...
Unpacking linux-image-4.4.0-udoo (5.25) ...
Preparing to unpack linux-libc-dev_5.25_armhf.deb ...
Unpacking linux-libc-dev (5.25) over (4.4.0-59.80) ...
Preparing to unpack linux-u-boot-next-udoo_5.25_armhf.deb ...
Unpacking linux-u-boot-udoo-next (5.25) over (5.25) ...
Setting up linux-firmware-image-4.4.0-udoo (5.25) ...
Setting up linux-headers-4.4.0-udoo (5.25) ...
Setting up linux-image-4.4.0-udoo (5.25) ...
update-initramfs: Generating /boot/initrd.img-4.4.0-udoo
update-initramfs: Converting to u-boot format
Setting up linux-libc-dev (5.25) ...
Setting up linux-u-boot-udoo-next (5.25) ...
Updating u-boot on device /dev/mmcblk0
Boot Log (after update):
U-Boot SPL 2015.10-armbian (Feb 10 2017 - 23:03:32)
U-Boot 2015.10-armbian (Feb 10 2017 - 23:03:32 -0700)
CPU:   Freescale i.MX6Q rev1.2 at 792 MHz
Reset cause: POR
Board: UDOO Quad
DRAM:  1 GiB
MMC:   FSL_SDHC: 0
auto-detected panel HDMI
Display: HDMI (1280x720)
In:    serial
Out:   serial
Err:   serial
Net:   using phy at 6
FEC [PRIME]
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc0 is current device
Device Tree: dts/imx6q-udoo-hdmi.dtb
Booting from net ...
FEC Waiting for PHY auto negotiation to complete......... TIMEOUT !
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
Retry time exceeded; starting again
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
Bad Linux ARM zImage magic!
Here's the first boot I captured.. I'm going to try again, without updating uboot, just linux-image-4.4.0-udoo_5.25_armhf.deb and linux-firmware-image-4.4.0-udoo_5.25_armhf.deb
U-Boot SPL 2015.10-armbian (Feb 02 2017 - 03:15:42)
U-Boot 2015.10-armbian (Feb 02 2017 - 03:15:42 +0100)
Reset cause: POR
Board: UDOO Quad
DRAM:  1 GiB
MMC:   FSL_SDHC: 0
In:    serial
Out:   serial
Err:   serial
Net:   using phy at 6
FEC [PRIME]
Scanning mmc
Found U-Boot script /boot.scr
** File not found /boot.scr **
1757 bytes read in 109 ms (15.6 KiB/s)
Running bootscript from mmc ...
## Executing script at 12000000
Booting from SD
** File not found /boot/armbianEnv.txt **
4764730 bytes read in 379 ms (12 MiB/s)
6144136 bytes read in 497 ms (11.8 MiB/s)
0 bytes read in 98 ms (0 Bytes/s)
37690 bytes read in 564 ms (64.5 KiB/s)
Kernel image @ 0x12000000 [ 0x000000 - 0x5dc088 ]
## Loading init Ramdisk from Legacy Image at 14800000 ...
   Image Name:   uInitrd
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    4764666 Bytes = 4.5 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 18000000
   Booting using the fdt blob at 0x18000000
   Using Device Tree in place at 18000000, end 1800c339
Starting kernel ...
Loading, please wait...
starting version 229
done.
Begin: Will now check root file system ... fsck from util-linux 2.27.1
[/sbin/fsck.ext4 (1) -- /dev/mmcblk0p1] fsck.ext4 -a -C0 /dev/mmcblk0p1
/dev/mmcblk0p1: clean, 147301/178816 files, 526555/713984 blocks
done.
done.
Welcome to Ubuntu 16.04.1 LTS!
[  OK  ] Listening on udev Control Socket.
[  OK  ] Set up automount Arbitrary Executab...ats File System Automount Point.
[  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
[  OK  ] Reached target Remote File Systems (Pre).
[  OK  ] Created slice System Slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[  OK  ] Reached target Swap.
[  OK  ] Listening on Journal Socket.
         Starting Restore / save the current clock...
[  OK  ] Listening on Syslog Socket.
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Created slice User and Session Slice.
         Starting Create list of required st... nodes for the current kernel...
[  OK  ] Reached target Encrypted Volumes.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Listening on fsck to fsckd communication Socket.
[  OK  ] Listening on udev Kernel Socket.
         Mounting POSIX Message Queue File System...
[  OK  ] Reached target Remote File Systems.
[  OK  ] Reached target User and Group Name Lookups.
         Starting Nameserver information manager...
         Starting Load Kernel Modules...
         Starting Set console keymap...
[  OK  ] Reached target Slices.
         Starting Remount Root and Kernel File Systems...
[  OK  ] Listening on Journal Socket (/dev/log).
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Started Restore / save the current clock.
[  OK  ] Started Create list of required sta...ce nodes for the current kernel.
[  OK  ] Started Load Kernel Modules.
[  OK  ] Started Set console keymap.
[  OK  ] Started Remount Root and Kernel File Systems.
[  OK  ] Started Nameserver information manager.
         Starting udev Coldplug all Devices...
         Starting Load/Save Random Seed...
         Starting Apply Kernel Variables...
         Mounting FUSE Control File System...
         Starting Create Static Device Nodes in /dev...
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Create Static Device Nodes in /dev.
         Starting udev Kernel Device Manager...
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /tmp...
[  OK  ] Mounted /tmp.
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started Entropy daemon using the HAVEGE algorithm.
         Starting Journal Service...
[  OK  ] Reached target Local File Systems.
         Starting Raise network interfaces...
         Starting Set console font and keymap...
         Starting Armbian enhanced Log2Ram...
[  OK  ] Found device /dev/ttymxc1.
[  OK  ] Reached target Sound Card.
[  OK  ] Started Journal Service.
[  OK  ] Started Armbian enhanced Log2Ram.
[  OK  ] Started Raise network interfaces.
[  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[  OK  ] Started ifup for eth0.
         Starting Flush Journal to Persistent Storage...
[  OK  ] Started Flush Journal to Persistent Storage.
         Starting Create Volatile Files and Directories...
         Starting Load/Save RF Kill Switch Status...
[  OK  ] Started Create Volatile Files and Directories.
[  OK  ] Started Load/Save RF Kill Switch Status.
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Paths.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Started Daily apt activities.
[  OK  ] Reached target Timers.
         Starting Armbian filesystem resize service...
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Reached target Sockets.
[FAILED] Failed to start Set console font and keymap.
See 'systemctl status console-setup.service' for details.
[  OK  ] Started Armbian filesystem resize service.
[  OK  ] Reached target Basic System.
         Starting LSB: Start/stop sysstat's sadc...
         Starting Accounts Service...
[  OK  ] Started Armbian first run tasks.
[  OK  ] Created slice system-getty.slice.
         Starting Avahi mDNS/DNS-SD Stack...
         Starting LSB: No Display Manager...
         Starting Login Service...
         Starting System Logging Service...
         Starting LSB: Starts LIRC daemon....
[  OK  ] Started Regular background program processing daemon.
         Starting LSB: Load kernel modules needed to enable cpufreq scaling...
         Starting LSB: Armbian gathering hardware information...
[  OK  ] Started D-Bus System Message Bus.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
         Starting Network Manager...
         Starting Permit User Sessions...
         Starting Save/Restore Sound Card State...
[  OK  ] Started System Logging Service.
[  OK  ] Started Permit User Sessions.
[  OK  ] Started Save/Restore Sound Card State.
[  OK  ] Started LSB: Start/stop sysstat's sadc.
[  OK  ] Started LSB: Armbian gathering hardware information.
[  OK  ] Started LSB: No Display Manager.
[  OK  ] Started LSB: Starts LIRC daemon..
[  OK  ] Started LSB: Load kernel modules needed to enable cpufreq scaling.
[  OK  ] Started Network Manager.
[  OK  ] Started Login Service.
         Starting Network Manager Script Dispatcher Service...
[  OK  ] Reached target Network.
         Starting OpenBSD Secure Shell server...
         Starting Network Manager Wait Online...
         Starting Authenticate and Authorize Users to Run Privileged Tasks...
         Starting LSB: set CPUFreq kernel parameters...
         Starting Set console scheme...
[  OK  ] Started Network Manager Script Dispatcher Service.
[  OK  ] Started Set console scheme.
[  OK  ] Started LSB: set CPUFreq kernel parameters.
         Starting LSB: Set sysfs variables from /etc/sysfs.conf...
         Starting Hostname Service...
[  OK  ] Started LSB: Set sysfs variables from /etc/sysfs.conf.
[  OK  ] Started Authenticate and Authorize Users to Run Privileged Tasks.
[  OK  ] Started Accounts Service.
[  OK  ] Started Hostname Service.
[  OK  ] Started OpenBSD Secure Shell server.
         Starting WPA supplicant...
[  OK  ] Started WPA supplicant.
[  OK  ] Started Network Manager Wait Online.
[  OK  ] Reached target Network is Online.
         Starting LSB: disk temperature monitoring daemon...
         Starting LSB: Start NTP daemon...
         Starting LSB: Advanced IEEE 802.11 management daemon...
         Starting /etc/rc.local Compatibility...
[  OK  ] Started LSB: Advanced IEEE 802.11 management daemon.
[  OK  ] Started /etc/rc.local Compatibility.
[  OK  ] Started LSB: disk temperature monitoring daemon.
[  OK  ] Started Serial Getty on ttymxc1.
[  OK  ] Started Getty on tty1.
[  OK  ] Reached target Login Prompts.
[  OK  ] Started LSB: Start NTP daemon.
[  OK  ] Reached target Multi-User System.
[  OK  ] Reached target Graphical Interface.
         Starting Update UTMP about System Runlevel Changes...
[  OK  ] Started Update UTMP about System Runlevel Changes.
Ubuntu 16.04.1 LTS udoo ttymxc1
udoo login: root
Password:
You are required to change your password immediately (root enforced)
Changing password for root.
(current) UNIX password:
Enter new UNIX password:
Retype new UNIX password:
 _   _     _
| | | | __| | ___   ___
| | | |/ _` |/ _ \ / _ \
| |_| | (_| | (_) | (_) |
 \___/ \__,_|\___/ \___/
Welcome to ARMBIAN 5.25 stable Ubuntu 16.04.1 LTS 4.4.46-udoo
System load:   1.77             Up time:       1 min
Memory usage:  3 % of 1002Mb    IP:
CPU temp:      26°C
Usage of /:    8% of 28G
New to Armbian? Check the documentation first: docs.armbian.com
Thank you for choosing Armbian! Support: www.armbian.com
Creating a new user account. Press <Ctrl-C> to abort
Desktop environment will not be enabled if you abort the new user creation
Please provide a username (eg. your forename):
<blah blah blah>
Now starting desktop environment...
So I did this:
sed -i "s/apt/beta/" /etc/apt/sources.list.d/armbian.list
apt-get update
apt-get upgrade
and it still boots ("deb http://beta.armbian.com $(lsb_release -cs) main utils $(lsb_release -cs)-desktop" didn't work on xenial)
Also - I updated just the custom kernel and firmware, and the board booted, so I'm guessing it's something with uboot
OK, thank you. Will try to recreate and fix.
Good uboot (prior to updating custom kernel):
baudrate=115200
board_rev=MX6Q
boot_a_script=ext2load mmc ${mmcdev}:${mmcpart} ${loadaddr} ${prefix}${script} || fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${prefix}${script}
boot_fdt=try
boot_prefixes=/ /boot/
bootcmd=mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; fi; udooinit; if run loadimage; then run mmcboot; else run netboot; fi; else run netboot; fi
bootdelay=3
bootscript=echo Running bootscript from mmc ...; source
console=ttymxc1
ethact=FEC
ethaddr=00:c0:08:88:10:2c
ethprime=FEC
fdt_addr=0x18000000
fdt_file=undefined
fdt_high=0xffffffff
image=zImage
initrd_high=0xffffffff
ip_dyn=yes
loadaddr=0x12000000
loadbootscript=run scan_dev_for_boot;
loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}
loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}
mmcargs=setenv bootargs console=${console},${baudrate} ${video} ${memory} root=${mmcroot} rootfstype=${mmcrootfstype} ahci_imx.hotplug=1
mmcboot=echo Booting from mmc ...; run mmcargs; if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if run loadfdt; then bootz ${loadaddr} - ${fdt_addr}; else if test ${boot_fdt} = try; then bootz; else echo WARN: Cannot load the DT; fi; fi; else bootz; fi;
mmcdev=0
mmcpart=1
mmcroot=/dev/mmcblk0p2 rootwait rw
mmcrootfstype=ext4
netargs=setenv bootargs console=${console},${baudrate} root=/dev/nfs ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp
netboot=echo Booting from net ...; run netargs; if test ${ip_dyn} = yes; then setenv get_cmd dhcp; else setenv get_cmd tftp; fi; ${get_cmd} ${image}; if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if ${get_cmd} ${fdt_addr} ${fdt_file}; then bootz ${loadaddr} - ${fdt_addr}; else if test ${boot_fdt} = try; then bootz; else echo WARN: Cannot load the DT; fi; fi; else bootz; fi;
scan_dev_for_boot=echo Scanning mmc ; for prefix in ${boot_prefixes}; do run scan_dev_for_scripts; done
scan_dev_for_scripts=if test -e ${mmcdev}:${mmcpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; else echo Checking here ${prefix} ... not found; fi;
script=boot.scr
splashpos=m,m
update_sd_firmware=if test ${ip_dyn} = yes; then setenv get_cmd dhcp; else setenv get_cmd tftp; fi; if mmc dev ${mmcdev}; then if ${get_cmd} ${update_sd_firmware_filename}; then setexpr fw_sz ${filesize} / 0x200; setexpr fw_sz ${fw_sz} + 1; mmc write ${loadaddr} 0x2 ${fw_sz}; fi; fi
update_sd_firmware_filename=u-boot.imx
Environment size: 2528/8188 bytes
Bad uboot (after updating custom kernel):
baudrate=115200
board_rev=MX6Q
boot_fdt=try
bootdelay=3
bootscript=echo Running bootscript from mmc ...; env import -t ${loadaddr} ${filesize};
console=ttymxc1
ethact=FEC
ethprime=FEC
fdt_addr=0x18000000
fdt_file=undefined
fdt_high=0xffffffff
image=zImage
ip_dyn=yes
loadaddr=0x12000000
loadbootscript=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};
mmcdev=0
mmcpart=1
mmcrootfstype=ext4
script=uEnv.txt
splashpos=m,m
Environment size: 2116/8188 bytes
I did a diff and updated all the variables to match the good uboot, and the new kernel loaded, however I don't see one wire..  I'll mess around more today
Find anything?
Yes. You must compile kernel by using our tools or include our kernel patches and it will work. We also fixed bugs and prepare kernel packages for our boot scenario. Just in this case everything works simply by installing the package. If not ... you need to set and adjust paths and boot scripts manually.
So I must be doing something wrong.  Just did a pull on your repo - attached are my changes:
compile.sh
16,17c16,17
< KERNEL_ONLY=""				# leave empty to select each time, set to "yes" or "no" to skip dialog prompt
< KERNEL_CONFIGURE="no"			# change provided kernel configuration
> KERNEL_ONLY="yes"				# leave empty to select each time, set to "yes" or "no" to skip dialog prompt
> KERNEL_CONFIGURE="yes"			# change provided kernel configuration
27c27
< KERNEL_KEEP_CONFIG="no"			# do not overwrite kernel config before compilation
> KERNEL_KEEP_CONFIG="yes"			# do not overwrite kernel config before compilation
31c31
< FORCE_CHECKOUT="yes"			# ignore manual changes to source
> FORCE_CHECKOUT="no"			# ignore manual changes to source
kernel config diffs (from your repo):
3c3
2055c2055,2082
> CONFIG_W1=y
> CONFIG_W1_CON=y
> # 1-wire Slaves
4175a4203
git diff from sources/linux-udoo-next/4.4-5.0.11.p7.3 (this is the only change for the whole tree):
diff --git a/arch/arm/boot/dts/imx6qdl-udoo.dtsi b/arch/arm/boot/dts/imx6qdl-udoo.dtsi
old mode 100644
new mode 100755
index 502e741..7ad9abe
--- a/arch/arm/boot/dts/imx6qdl-udoo.dtsi
+++ b/arch/arm/boot/dts/imx6qdl-udoo.dtsi
@@ -231,7 +231,7 @@
         	compatible = "w1-gpio";
                 pinctrl-names = "default";
                 pinctrl-0 = <&w1_gpio_pins>;
-                status = "disabled";
+                status = "okay";
                 gpios = <&gpio1 21 0>;
I run my compile.sh, and install all the generated debs:
linux-firmware-image-4.4.0-udoo_5.26_armhf.deb
linux-headers-4.4.0-udoo_5.26_armhf.deb
linux-image-4.4.0-udoo_5.26_armhf.deb
linux-libc-dev_5.26_armhf.deb
linux-u-boot-next-udoo_5.26_armhf.deb
via "dpkg -i *.deb" - so I assume that it will use your tools & install your kernel patches.
After the install - goes straight to trying to boot off net
Leave this as is
and use
CREATE_PATCHES="yes"
Apply change to source when asked and pickup patch which will be created userpatches/patch ... this patch should be moved to appropriate dir:
userpatches/kernel/udoo-next
or move it to
lib/patch/kernel/udoo-next
and create PR to our repository since it might be useful for others too.
Option which you used is working properly only on source where no patches are initially involved  ... we have to change / note this.
Leave this as is
and use
or move it to
perfect - that worked!
I try this procedure (without PR) but I can't succeed, I modify this file :
./sources/linux-sun8i/sun8i/drivers/media/rc/sunxi-cir.c
Before compiling I have this :
[ warn ] Make your changes in this directory: [ /root/crosscompile/sources/u-boot/v2017.03 ]
[ warn ] Press <Enter> after you are done [ waiting ]
I paste the file, but I have :
[ warn ] No changes found, skipping patch creation
Where I must copy paste my "sunxi-cir.c" file ?
