Sid Boyce Posted February 26, 2024 Posted February 26, 2024 (edited) Searches suggest a USB reset script will fix but that says nothing found. It comes up after unplugging and replugging the dongle. Already configured with "nmcli c add type ethernet ifname enx00e04c68080d con-name HiQSDR autoconnect yes save yes ip4 192.168.2.196/24" After boot, nothing in lsusb for it and dmesg -T does not show it. Bus 001 Device 014: ID 0bda:8152 Realtek Semiconductor Corp. RTL8152 Fast Ethernet Adapter Things tried:- root@rpi4b:~# cat /etc/os-release PRETTY_NAME="Armbian 24.2.1 jammy" NAME="Ubuntu" VERSION_ID="22.04" VERSION="22.04.3 LTS (Jammy Jellyfish)" VERSION_CODENAME=jammy ID=ubuntu ID_LIKE=debian HOME_URL="https://www.armbian.com" SUPPORT_URL="https://forum.armbian.com" BUG_REPORT_URL="https://www.armbian.com/bugs" PRIVACY_POLICY_URL="https://www.armbian.com" UBUNTU_CODENAME=jammy ARMBIAN_PRETTY_NAME="Armbian 24.2.1 jammy" root@rpi4b:~# cat /etc/udev/rules.d/40-modeswitch.rules # Copyright (C) 2009-2014 Stephan Raue (stephan@openelec.tv) ACTION!="add|change", GOTO="end_modeswitch" KERNEL!="sr[0-9]*", GOTO="end_modeswitch" SUBSYSTEM!="block", GOTO="end_modeswitch" root@rpi4b:~# vcgencmd bootloader_config [all] BOOT_UART=0 WAKE_ON_GPIO=1 POWER_OFF_ON_HALT=0 # Realtek RTL8152 chipset USB lan NIC # initial cdrom mode 0bda:8152, lan mode 0bda:8153 ATTRS{idVendor}=="0bda", ATTRS{idProduct}=="8152", RUN+="/tmp/setupusblanadapter.sh" LABEL="end_modeswitch" https://forums.raspberrypi.com/viewtopic.php?t=336517 doesn't help --- didn't try installing the suggested firmware root@rpi4b:~# raspi-config nonint do_boot_rom E1 /usr/bin/raspi-config: 1506: [: Illegal number: BOOTLOADER: up to date CURRENT: Thu May 11 06:26:03 AM UTC 2023 (1683786363) LATEST: Thu May 11 06:26:03 AM UTC 2023 (1683786363) RELEASE: stable (/lib/firmware/raspberrypi/bootloader-2711/stable) Use raspi-config to change the release. VL805_FW: Dedicated VL805 EEPROM VL805: up to date CURRENT: 000138c0 LATEST: 000138c0 Edited February 26, 2024 by Sid Boyce Added bootloader details raspi-config 0 Quote
