Hi everyone,
I have an orange pi pc+ (also a orange pi one) and i'm trying to use one of them as a wifi-wifi router. I've been able to do it work several times, with different wifi dongles, armbian versions (both debian and ubuntu legacy and mainline) but I always get low wifi speed in the AP interface.
The problem is that the AP network through the orange pi always gives  me around 30-10% of the full internet connection. That is, if my connection gives me 1.5mb/s, the client interface at orange pi gives around 1.5mb/s but at the AP interface is only 200-500 kb/s.
I'm going to show here the last configuration I've tried. I would like to achieve a "decent" wifi speed in the AP interface.
Current configuration information:
Orange PI PC+
Armbian server, ubuntu, legacy 5.25 (updated)
WIFI client: wlan0 interface, internal wifi of opipc+
WIFI ap: ra0 interface. MT7601u using this driver (https://github.com/muratdemirtas/MT7601u)
/etc/network/interfaces
# Wired adapter #1
allow-hotplug eth0
no-auto-down eth0
iface eth0 inet dhcp
# Local loopback
auto lo
iface lo inet loopback
#CLIENT
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
#AP
allow-hotplug ra0
iface ra0 inet static
address 192.168.42.1
netmask 255.255.255.0
/etc/default/isc-dhcp-server
# Defaults for isc-dhcp-server initscript
# sourced by /etc/init.d/isc-dhcp-server
# installed at /etc/default/isc-dhcp-server by the maintainer scripts
# This is a POSIX shell fragment
# Path to dhcpd's config file (default: /etc/dhcp/dhcpd.conf).
#DHCPD_CONF=/etc/dhcp/dhcpd.conf
# Path to dhcpd's PID file (default: /var/run/dhcpd.pid).
#DHCPD_PID=/var/run/dhcpd.pid
# Additional options to start dhcpd with.
#	Don't use options -cf or -pf here; use DHCPD_CONF/ DHCPD_PID instead
#OPTIONS=""
# On what interfaces should the DHCP server (dhcpd) serve DHCP requests?
#	Separate multiple interfaces with spaces, e.g. "eth0 eth1".
INTERFACES="ra0"
ddns-update-style none;
default-lease-time 600;
max-lease-time 7200;
authoritative;
log-facility local7;
    subnet 192.168.42.0 netmask 255.255.255.0 {
    range 192.168.42.10 192.168.42.50;
    option broadcast-address 192.168.42.255;
    option routers 192.168.42.1;
    option domain-name "local";
    option domain-name-servers 8.8.8.8, 8.8.4.4;
iptables
# Generated by iptables-save v1.6.0 on Fri Feb 10 23:53:52 2017
*filter
:INPUT ACCEPT [158:23636]
:FORWARD ACCEPT [0:0]
:OUTPUT ACCEPT [121:19924]
-A FORWARD -i wlan0 -o ra0 -m state --state RELATED,ESTABLISHED -j ACCEPT
-A FORWARD -i ra0 -o wlan0 -j ACCEPT
COMMIT
# Completed on Fri Feb 10 23:53:52 2017
*nat
:PREROUTING ACCEPT [0:0]
:INPUT ACCEPT [0:0]
:OUTPUT ACCEPT [3:195]
:POSTROUTING ACCEPT [3:195]
-A POSTROUTING -o wlan0 -j MASQUERADE
COMMIT
/etc/sysctl.conf
net.ipv4.ip_forward=1
vm.swappiness=0
/etc/Wireless/RT2870AP/RT2870AP.dat (equivalent to hostapd.conf)
#The word of "Default" must not be removed
Default
CountryRegion=5
CountryRegionABand=7
CountryCode=TW
BssidNum=1
SSID=HD_MESH_1
WirelessMode=9
TxRate=0
Channel=11
BasicRate=15
BeaconPeriod=100
DtimPeriod=1
TxPower=100
DisableOLBC=0
BGProtection=0
TxAntenna=
RxAntenna=
TxPreamble=0
RTSThreshold=2347
FragThreshold=2346
TxBurst=1
PktAggregate=0
TurboRate=0
WmmCapable=0
APSDCapable=0
DLSCapable=0
APAifsn=3;7;1;1
APCwmin=4;4;3;2
APCwmax=6;10;4;3
APTxop=0;0;94;47
APACM=0;0;0;0
BSSAifsn=3;7;2;2
BSSCwmin=4;4;3;2
BSSCwmax=10;10;4;3
BSSTxop=0;0;94;47
BSSACM=0;0;0;0
AckPolicy=0;0;0;0
NoForwarding=0
NoForwardingBTNBSSID=0
HideSSID=0
StationKeepAlive=0
ShortSlot=1
AutoChannelSelect=0
IEEE8021X=0
IEEE80211H=0
CSPeriod=10
WirelessEvent=0
IdsEnable=0
AuthFloodThreshold=32
AssocReqFloodThreshold=32
ReassocReqFloodThreshold=32
ProbeReqFloodThreshold=32
DisassocFloodThreshold=32
DeauthFloodThreshold=32
EapReqFooldThreshold=32
PreAuth=0
AuthMode=WPA2PSK
EncrypType=TKIP;AES
RekeyInterval=0
RekeyMethod=DISABLE
PMKCachePeriod=10
WPAPSK=12345678
DefaultKeyID=1
Key1Type=0
Key1Str=
Key2Type=0
Key2Str=
Key3Type=0
Key3Str=
Key4Type=0
Key4Str=
HSCounter=0
AccessPolicy0=0
AccessControlList0=
AccessPolicy1=0
AccessControlList1=
AccessPolicy2=0
AccessControlList2=
AccessPolicy3=0
AccessControlList3=
WdsEnable=0
WdsEncrypType=NONE
WdsList=
WdsKey=
RADIUS_Server=192.168.2.3
RADIUS_Port=1812
RADIUS_Key=ralink
own_ip_addr=192.168.5.234
EAPifname=br0
PreAuthifname=br0
HT_HTC=0
HT_RDG=0
HT_EXTCHA=0
HT_LinkAdapt=0
HT_OpMode=0
HT_MpduDensity=5
HT_BW=1
HT_AutoBA=1
HT_AMSDU=0
HT_BAWinSize=64
HT_GI=1
HT_MCS=33
MeshId=MESH
MeshAutoLink=1
MeshAuthMode=OPEN
MeshEncrypType=NONE
MeshWPAKEY=
MeshDefaultkey=1
MeshWEPKEY=
WscManufacturer=
WscModelName=
WscDeviceName=
WscModelNumber=
WscSerialNumber=
RadioOn=1
PMFMFPC=0
PMFMFPR=0
PMFSHA256=0
As I said before, this configuratin works. I've also tried with other wifi dongle, using the pertinent "hostapd.conf" file and the result is the same. One more thing:
local network wifi speed is around 14-15 Mbits/S. Tested with iperf
So I think the problem is when the opi fordwars internet thorugh from wlan0 to ra0.
Any ideas or questions?
Deeply grateful guys!
don't understand your usecase are you trying to do some kind of repeater ?
change the client connection to lan and recheck the speeds
if the transfer speed is slow it usually always means that the client connection is too weak.
any 20-30EUR wlan router will always outperform just by using pure antenna power
