Khadas Posted March 1, 2024 Posted March 1, 2024 I was looking for a low-cost S905W tv box. I discovered this counterfeitby accident because I couldn't boot any armbian image for S905W soc and I accidentally tried the multitool and it started right away 1GB/8GB version and not 2GB/16GB. So be very careful what you buy and if possible send it back to these dishonest Chinese sellers! 1 Quote
SteeMan Posted March 1, 2024 Posted March 1, 2024 I know you mentioned this elsewhere, but I thought I would point it out for those that stumble across this post. Notice that they even go so far as to change the markings on the CPU to say it is something that it is not. It is also common that manufacturers will customize the android firmware to report incorrect ram/storage amounts. So sell you a 2G/16G box that android reports as being that, only to find out it really only has 1G/8G of real components. When it comes to these cheap boxes, the only thing that matters to the end customer is the price generally, so the manufacturers do everything they can to cut the cost. Because when you have 100 boxes being sold that all essentially do the same thing, a consumer naturally looks to the lowest price to make their buy. 0 Quote
Khadas Posted March 4, 2024 Author Posted March 4, 2024 @SteeMan I completely agree with you, by chance I discovered this forum dedicated to TV boxes and I wanted to have some fun with these cheap low quality TV boxes. Now I understand well why Armbian does not officially support TV boxes and I wanted to share my recent discoveries with that interesting forum. 0 Quote
SteeMan Posted March 4, 2024 Posted March 4, 2024 @Khadas and I thank you for what you have posted. Armbian is always in need of intelligent people helping in anyway they can. Things as simple as reporting your findings help others 0 Quote
Vito Dgb Posted November 14, 2024 Posted November 14, 2024 (edited) Hello @Khadas Which version of armbian could you run ? i can't boot armbiand for s905w... the heat sink is glued on the cpu so i can't check which one is it Thanks for your help Edited November 14, 2024 by Vito Dgb 0 Quote
Khadas Posted November 20, 2024 Author Posted November 20, 2024 @Vito Dgb I'm sorry but I returned that TV box to the seller for free because it was counterfeit. You could put the Multitool for TV boxes with RK322x Soc that you find in this forum on a USB drive. if the multitool boots you have confirmation that it is a sox 322x I recommend an old kernel to start with, like 5. Good luck 0 Quote
Vito Dgb Posted November 27, 2024 Posted November 27, 2024 Thanks @Khadas I installed cpu-z.apk on android, and i saw it was Cortex A7 cpu instead of A53, and also a very slow GPU So i returned it, and took a Vontar x3, that is legit 0 Quote
